  4. [Aufruf] fullyBrowser Adapter
    6.6k
fullybrowserfullybrowser adapter
289 Beiträge 45 Kommentatoren 72.4k Aufrufe 26 Beobachtet
  • ChaotC Offline
    ChaotC Offline
    Chaot
    #119
    Da ist eben gar nichts:
    host.haus 2018-12-31 19:00:00.029 info instance system.adapter.dwd.0 started with pid 32052
    pushover.0 2018-12-31 18:59:56.817 info Send pushover notification: {"message":"Wohnzimmerfenster zu","title":"ioBroker","priority":"0"}
    fritzdect.0 2018-12-31 18:59:56.810 info HGROUP ID: 9D:72:75-900 identified for command (mode) : 0
    fritzdect.0 2018-12-31 18:59:56.807 info HGROUP ID: 9D:72:75-900 identified for command (targettemp) : 22
    fritzdect.0 2018-12-31 18:59:34.108 info HGROUP ID: 9D:72:75-900 identified for command (mode) : 0
    pushover.0 2018-12-31 18:59:34.106 info Send pushover notification: {"message":"Wohnzimmerfenster offen","title":"ioBroker","priority":"0"}
    fritzdect.0 2018-12-31 18:59:34.098 info HGROUP ID: 9D:72:75-900 identified for command (targettemp) : 12
    fritzdect.0 2018-12-31 18:59:34.097 info HGROUP ID: 9D:72:75-900 identified for command (mode) : 0
    fritzdect.0 2018-12-31 18:59:34.087 info HGROUP ID: 9D:72:75-900 identified for command (targettemp) : 12
    host.haus 2018-12-31 18:56:02.220 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:55:03.168 info instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:55:00.101 info instance system.adapter.dwd.0 started with pid 32035
    host.haus 2018-12-31 18:55:00.029 info instance system.adapter.tvspielfilm.0 started with pid 32030
    host.haus 2018-12-31 18:54:13.410 info instance system.adapter.daswetter.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:54:03.550 info instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:54:00.049 info instance system.adapter.tankerkoenig.0 started with pid 32014
    host.haus 2018-12-31 18:54:00.029 info instance system.adapter.daswetter.0 started with pid 32009
    host.haus 2018-12-31 18:51:01.970 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:50:02.502 info instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:50:00.081 info instance system.adapter.tvspielfilm.0 started with pid 31991
    host.haus 2018-12-31 18:50:00.060 info instance system.adapter.dwd.0 started with pid 31986
    host.haus 2018-12-31 18:46:01.819 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:45:02.207 info instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:45:00.084 info instance system.adapter.dwd.0 started with pid 31970
    host.haus 2018-12-31 18:45:00.035 info instance system.adapter.tvspielfilm.0 started with pid 31965
    host.haus 2018-12-31 18:41:02.104 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:40:02.557 info instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:40:00.107 info instance system.adapter.tvspielfilm.0 started with pid 31946
    host.haus 2018-12-31 18:40:00.037 info instance system.adapter.dwd.0 started with pid 31941
    host.haus 2018-12-31 18:36:12.939 info instance system.adapter.daswetter.0 terminated with code 0 (OK)
    daswetter.0 2018-12-31 18:36:06.637 error DasWetter.com reported an error: null or response 409
    host.haus 2018-12-31 18:36:02.900 info instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:36:01.833 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:36:00.048 info instance system.adapter.daswetter.0 started with pid 31924
    host.haus 2018-12-31 18:36:00.023 info instance system.adapter.tankerkoenig.0 started with pid 31919
    host.haus 2018-12-31 18:35:02.126 info instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:35:00.081 info instance system.adapter.dwd.0 started with pid 31903
    host.haus 2018-12-31 18:35:00.023 info instance system.adapter.tvspielfilm.0 started with pid 31898
    host.haus 2018-12-31 18:31:02.718 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:30:09.363 info instance system.adapter.ical.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:30:03.293 info instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:30:00.171 info instance system.adapter.ical.0 started with pid 31878
    host.haus 2018-12-31 18:30:00.121 info instance system.adapter.tvspielfilm.0 started with pid 31871
    host.haus 2018-12-31 18:30:00.042 info instance system.adapter.dwd.0 started with pid 31866
    host.haus 2018-12-31 18:26:02.011 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:25:02.252 info instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:25:00.090 info instance system.adapter.dwd.0 started with pid 31848
    host.haus 2018-12-31 18:25:00.025 info instance system.adapter.tvspielfilm.0 started with pid 31843
    host.haus 2018-12-31 18:21:01.971 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:20:02.547 info instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:20:00.099 info instance system.adapter.tvspielfilm.0 started with pid 31825
    host.haus 2018-12-31 18:20:00.034 info instance system.adapter.dwd.0 started with pid 31820
    host.haus 2018-12-31 18:18:13.063 info instance system.adapter.daswetter.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:18:03.348 info instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:18:00.040 info instance system.adapter.tankerkoenig.0 started with pid 31803
    host.haus 2018-12-31 18:18:00.021 info instance system.adapter.daswetter.0 started with pid 31798
    host.haus 2018-12-31 18:16:01.854 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:15:02.252 info instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:15:00.098 info instance system.adapter.dwd.0 started with pid 31778
    host.haus 2018-12-31 18:15:00.039 info instance system.adapter.tvspielfilm.0 started with pid 31773
    host.haus 2018-12-31 18:11:02.064 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:10:02.504 info instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:10:00.123 info instance system.adapter.tvspielfilm.0 started with pid 31756
    host.haus 2018-12-31 18:10:00.037 info instance system.adapter.dwd.0 started with pid 31751
    host.haus 2018-12-31 18:06:01.873 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:05:02.085 info instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus 2018-12-31 18:05:00.055 info instance system.adapter.dwd.0 started with pid 31733
      Allodo
      #120
      Ich habe den Fully Kiosk Browser auf einem Fire HD 8 (5gen) laufen und den Adapter installiert. Da ich gerade noch herumteste, ist es noch nicht die Pro-Version. Allerdings habe ich keinen Datenpunkt mit Batterielevel bei mir, kann es damit zusammenhängen, oder muss eine bestimmte Einstellung vorgenommen werden?
      Den Screen Ein-und Ausschalten kann ich bereits, immerhin etwas. Beim einschalten erhalte ich aber wieder den Lockscreen vom Fire OS. Kann man das irgendwie umgehen?
      • WebrangerW Offline
        WebrangerW Offline
        Webranger
        #121
        Batterie Level müsste auch so kommen. Glaube unter info
        Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
        • ChaotC Offline
          ChaotC Offline
          Chaot
          #122
          Ich habe noch eine weitere Baustelle eröffnet :oops:
          Ich möchte beim Klingeln das der Browser aud den View vom Kamerabild springt.
          Aber scheinbar reagiert der Adapter darauf nicht.
          Muss ich da noch was ändern?
          Klingelscript:
          var sperre = false;
          ! on({id: 'sonoff.0.Eingang.POWER2', change: "any"}, function (obj) {
          if(!sperre) {
          sperre = true;
          setState("fullybrowser.0.192_168_8_225.Commands.loadURL"/loadURL/, 'http://192.168.8.243:8082/vis/index.html?Neu#Tuer', true);
          setState("tr-064.0.states.ring"/ring/, '**611, 15');
          sendTo("pushover", "send", {
          message: 'Klingel',
          sound: ""
          timeout = setTimeout(function () {
          setState("alexa2.0.Echo-Devices.G2XXXXX774060LLE.Player.volume"/volume/, 90, true);
          }, 500);
          setState("alexa2.0.Echo-Devices.G2XXXXX774060LLE.Commands.speak"/speak/, 'Es ist jemand an der Tür');
          }, 1000);
          setState("alexa2.0.Echo-Devices.G2XXXXX774060LLE.Player.volume"/volume/, 50, true);
          }, 1500);
          setTimeout(function() {
          sperre = false;
          }, 5000);
          Ich dachte mit der Zeile:
          sollte das eigentlich klappen.
          Die Zeile wird auch in den Objekten eingetragen. Wie bringe ich jetzt Fully dazu die Seite aufzurufen?
          • E Offline
            eve11
            #123
            ich habe im Moment den Adapter mit der Version 0.0.11 installiert. Leider bekomme ich keine Verbindung zum Fully. Im "Fullyisalive" object steht auch false. In Chrome bekomme ich aber unter der im Adapter eingegebenen IP-Adresse, Port und Passwort Zugriff auf Fully ohne Probleme.
            Vielen Dank für eine Rückmeldung.
            Update:
            Was sehr komisch ist, ich kann Befehle über Commands absetzen, sowohl Screen brightness als auch Screen OFF/ON funktionieren ohne Probleme, nur Infos bekomme ich keine, als auch "isFullyalive" ist auf false.
            Danke für eine Rückmeldung
            Mfg
            eve11
            • ChaotC Offline
              ChaotC Offline
              Chaot
              #124
              Bei mir gibt das Update diesen Fehler:
              iobroker	2019-01-02 23:05:22.774	info	exit 0
              iobroker	2019-01-02 23:05:22.765	error	Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
              iobroker	2019-01-02 23:05:22.686	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","ar
              iobroker	2019-01-02 23:05:22.683	info	npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.npm WARN svg-inline-react@1.0.3 requires a peer of react
              host.haus	2019-01-02 23:05:03.983	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
              host.haus	2019-01-02 23:05:00.104	info	instance system.adapter.dwd.0 started with pid 25175
              host.haus	2019-01-02 23:05:00.051	info	instance system.adapter.tvspielfilm.0 started with pid 25170
              iobroker	2019-01-02 23:04:05.546	info	npm install https://github.com/arteck/iobroker.fullyBrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
              iobroker	2019-01-02 23:04:04.850	info	install https://github.com/arteck/iobroker.fullyBrowser/tarball/master
              iobroker	2019-01-02 23:04:04.331	info	url "https://github.com/arteck/iobroker.fullyBrowser"
              • 0 Offline
                0 Offline
                0018
                #125
                @Chaot:
                Ich möchte beim Klingeln das der Browser aud den View vom Kamerabild springt. `
                Ohne jetzt in die Analyse deiner Vorgehensweise zu gehen…. hier gibt es über VIS bereits eine "interne" Lösung um Views zu wechseln.
                Ist denke ich einfacher als über den Fully Adapter zu machen.
                https://www.forum.iobroker.net/viewtopic.php?t=789
                Sollte mit dem Befehl:
                setState('vis.0.control.command', '{"instance": "FFFFFFFF", "data": "###Name_deiner_View####", "command": "changeView"}');
                funktionieren.
                Mfg
                0018
                • arteckA Offline
                  arteckA Offline
                  arteck
                  #126
                  @Chaot:
                  Klingelscript:
                  var sperre = false;
                  if(!sperre) {
                  sperre = true;
                  message: 'Klingel',
                  sound: ""
                  }, 500);
                  }, 1000);
                  }, 1500);
                  sperre = false;
                  }, 5000);
                  Die Zeile wird auch in den Objekten eingetragen. Wie bringe ich jetzt Fully dazu die Seite aufzurufen? `
                  ich check das mal heute abend
                  • E Offline
                    eve11
                    #127
                    ` > Hallo zusammen,
                    Update:
                    Mfg
                    eve11 `
                    Ich habe jetzt einmal das Script von Mic probiert.
                    folgende Fehlermeldung.
                    10:18:20.906	[info]	javascript.0 script.js.common.fully: Fully Browser: Schedule zum Abruf der Informationen gestartet (*/1 * * * *)
                    10:18:23.854	[warn]	javascript.0 script.js.common.fully: Fully Browser: Folgender Fehler bei http-Request aufgetreten: Error: ESOCKETTIMEDOUT
                    10:19:02.851	[warn]	javascript.0 script.js.common.fully: Fully Browser: Folgender Fehler bei http-Request aufgetreten: Error: ESOCKETTIMEDOUT
                    10:19:02.913	[warn]	javascript.0 script.js.common.fully: Fully Browser: Folgender Fehler bei http-Request aufgetreten: Error: ESOCKETTIMEDOUT
                    10:19:02.913	[warn]	javascript.0 script.js.common.fully: setForeignState(id=javascript.0.mic.FullyBrowser.Info2.isFullyAlive, state=false) - was not executed, while debug mode is active
                    • ChaotC Offline
                      ChaotC Offline
                      Chaot
                      #128
                      Ich danke euch für die Tips.
                      Mir war nicht bewusst das Klingeln sooo kompliziert sein kann :lol:
                      Falls es jemand nutzen möchte hier mein geändertes Script:
                      var sperre = false;
                      if(!sperre) {
                      sperre = true;
                      setState("vis.0.control.command", '{"instance": "FFFFFFFF", "command": "changeView", "data": "Neu/Tuer"}');
                      // oder
                      //setState("vis.0.control.instance", 'FFFFFFFF');
                      //setState("vis.0.control.data", 'DemoView');
                      //setState("vis.0.control.command", 'changeView'); // muss immer letzte sein
                      // Nach 10 Sekunden, zeige wieder Start View
                      setState("vis.0.control.command", '{"instance": "FFFFFFFF", "command": "changeView", "data": "Neu/Info"}');
                      }, 60000);
                      message: 'Klingel',
                      sound: ""
                      setState("alexa2.0.Echo-Devices.G2A0P30774060LLE.Player.volume"/volume/, 90, true);
                      }, 500);
                      setState("alexa2.0.Echo-Devices.G2A0P30774060LLE.Commands.speak"/speak/, 'Es ist jemand an der Tür');
                      }, 1000);
                      setState("alexa2.0.Echo-Devices.G2A0P30774060LLE.Player.volume"/volume/, 50, true);
                      }, 1500);
                      sperre = false;
                      }, 5000);
                      Folgende Funktionen enthalten:
                      - Klingelsperre (wenn jemand mehrfach den Knopf drückt)
                      - Pushover Meldung
                      - Alexa Ansage (vorher Lautstärke erhöhen und hinterher wieder absenken)
                      - View auf Kamera umschalten und nach 60 s zurück. (Fully wird dabei auch aufgeweckt)
                      - Klingelsignal am DECT Telefon für 15 Sekunden.
                      Den Ansagetext "Ayse mach mal die sch…e Tür auf" musste ich auf drängen meiner Frau leider ändern [https://www.youtube.com/watch?v=nI0tnzVlX8Q](https://www.youtube.com/watch?v=nI0tnzVlX8Q) :lol:
                      • JB_SullivanJ Offline
                        JB_Sullivan
                        #129
                        @ Chaot
                        SUPER Sache - ein Skript gefällt mir sehr gut und es funktioniert super.
                        Kann man auch mehrere "Alexen" gleichzeit sprechen lassen? Wenn ja, wie müsste die Zeile im Skript erweiterte werden?
                        Sorry, aber ich habe es nicht so der Skript programmiererei.
                        • G Offline
                          Georgius
                          #130
                          Entweder eine Gruppe in Alexa erstellen oder einfach weitere Zeilen für andere Alexa. Aber egal wie man es macht es ist nicht syncron.
                            JB_Sullivan
                            #131
                            Das heißt, man muss die folgenden Zeilen immer wieder duplizieren?
                                setState("alexa2.0.Echo-Devices.G2A0P30774060LLE.Player.volume"/*volume*/, 90, true);
                                }, 500);
                                setState("alexa2.0.Echo-Devices.G2A0P30774060LLE.Commands.speak"/*speak*/, 'Es ist jemand an der Tür');
                                }, 1000);
                                setState("alexa2.0.Echo-Devices.G2A0P30774060LLE.Player.volume"/*volume*/, 50, true);
                                }, 1500);
                                   sperre = false;
                                }, 5000);
                            Ich hatte gehofft, das es evtl. einfacher geht - so in der Art - aber wie gesagt, ich habe keine Ahnung von Skript Programmierung.
                            setState("alexa2.0.Echo-Devices.G2A0P30774060LLE.Player.volume"/*volume*/, 50, true);("alexa2.0.Echo-Devices.yyyyyyyyy.Player.volume"/*volume*/, 50, true);("alexa2.0.Echo-Devices.xxxxxxxxxx.Player.volume"/*volume*/, 50, true)
                            usw., usw.,
                            • ChaotC Offline
                              ChaotC Offline
                              Chaot
                              #132
                              Ich hatte das mal drin mit mehreren Echos.
                              Aber das hat irgendwie nie so richtig funktioniert.
                              Ich hatte aber da immer Amazon im Verdacht das sie keine zeitgleichen "speak" Befehle verarbeiten.
                              Wenn ich die Befehle stark verzögert (20 Sekunden) hintereinander abgesetzt habe hat es funktioniert.
                              Umgesetzt war es so (mit der fehlerhaften Funktion):
                              setState("alexa2.0.Echo-Devices. ERSTES DEVICE .Commands.speak"/*speak*/, 'Es ist jemand an der Tür');
                              setState("alexa2.0.Echo-Devices. ZWEITES DEVICE .Commands.speak"/*speak*/, 'Es ist jemand an der Tür');
                              • arteckA Offline
                                arteckA Offline
                                arteck
                                #133
                                setState('fullybrowser.0.ip_bla_bla.Commands.loadURL', "www.google.de");
                                geht die Seite wird aufgerufen
                                • E Offline
                                  eve11
                                  #134
                                  Update: Ich habe bemerkt das die Command Befehle zwar gesendet werden aber sehr zeit verzögert bei Fully ankommen, ca. 6 - 8 sec.
                                  Wenn ich die Befehle direkt im Webinterface des Fully absetze (Screen on/off) wird der Befehl sofort umgesetzt.
                                  eve11
                                  • ChaotC Offline
                                    ChaotC Offline
                                    Chaot
                                    #135
                                    Ok, den Fehler verstehe ich jetzt nicht ganz.
                                    setState("fullybrowser.0.192_168_8_225.Commands.loadURL", 'www.google.de');
                                    Funktioniert und ruft google auf
                                    setState("fullybrowser.0.192_168_8_225.Commands.loadURL", 'http://192.168.8.243:8082/vis/index.html?Neu#Tuer');
                                    funktioniert nicht
                                    Was ist da jetzt falsch? :?: :?:
                                    • apollon77A Offline
                                      #136
                                      Danke für den Super Adapter, habe gerade Paw damit abgelöst. Schlanker auf dem Tablet und so … Super!
                                        #137
                                        @Arteck: Ich hätte aber noch ein paar Review Themen:
                                        • Wenn Du admin2 Admin Seite nicht pflegst (z.B, asswort verschlüsselung ist nur in index_m.html drin … dann wird Admin2 bitte raus
                                        • Adapter testing fehlt. sowohl die Files für das echte Adapter testing wie auch die Aktivierung in travis-ci bei Dir im Repo.
                                        • Adapter type "hardware" in repo and io-package ... we should rethink, maybe better utility or visualisation?
                                        • arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #138
                                          @apollon77:
                                          • Wenn Du admin2 Admin Seite nicht pflegst (z.B, asswort verschlüsselung ist nur in index_m.html drin … dann wird Admin2 bitte raus `
                                          mach ich
                                          @apollon77:
                                          • Adapter testing fehlt. sowohl die Files für das echte Adapter testing wie auch die Aktivierung in travis-ci bei Dir im Repo. `
                                          ich weiss… ich weiss...
                                          @apollon77:
                                          • Adapter type "hardware" in repo and io-package … we should rethink, maybe better utility or visualisation? `
                                          wie ist de Aufteilung .. ich hätte jtzt eher gesagt Software
