  4. JavaScript Adapter - Objekte fehlen
    6.7k
23 Beiträge 7 Kommentatoren 3.6k Aufrufe
    msiemers
    Ich habe auch die Version 4.06 auf dem neuen System.
    • hg6806H Offline
      hg6806H Offline
      hg6806
      hatte auf 4.0.6 geupdated, jetzt wird Javascript Adapter nach einigen Sekunden immer rot.
      Im Log ist nicht wirklich viel zu sehen:
      javascript.0	2018-12-28 23:37:55.420	info	received all objects
      javascript.0	2018-12-28 23:37:52.207	info	received all states
      javascript.0	2018-12-28 23:37:47.132	info	requesting all objects
      javascript.0	2018-12-28 23:37:47.128	info	requesting all states
      javascript.0	2018-12-28 23:37:47.104	info	starting. Version 4.0.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.12.0
      javascript.0	2018-12-28 23:36:35.304	info	Adapter is disabled => stop
      javascript.0	2018-12-28 23:35:33.230	info	received all objects
      javascript.0	2018-12-28 23:35:27.362	info	received all states
      javascript.0	2018-12-28 23:35:24.521	info	requesting all objects
      javascript.0	2018-12-28 23:35:24.517	info	requesting all states
      javascript.0	2018-12-28 23:35:24.489	info	starting. Version 4.0.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.12.0
      javascript.0	2018-12-28 23:34:37.260	info	Adapter is disabled => stop
      javascript.0	2018-12-28 23:34:15.804	info	received all objects
      javascript.0	2018-12-28 23:34:14.747	error	already running
      javascript.0	2018-12-28 23:34:13.973	warn	Reconnection to DB.
      javascript.0	2018-12-28 23:34:13.961	warn	Reconnection to DB.
      javascript.0	2018-12-28 23:34:07.956	info	received all states
      javascript.0	2018-12-28 23:33:48.635	info	requesting all objects
      javascript.0	2018-12-28 23:33:48.630	info	requesting all states
      javascript.0	2018-12-28 23:33:48.598	info	starting. Version 4.0.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.12.0
      javascript.0	2018-12-28 23:33:48.596	warn	Reconnection to DB.
      javascript.0	2018-12-28 23:33:48.591	info	requesting all objects
      javascript.0	2018-12-28 23:33:48.579	info	requesting all states
      javascript.0	2018-12-28 23:33:48.563	info	starting. Version 4.0.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.12.0
      javascript.0	2018-12-28 23:33:48.517	warn	Reconnection to DB.
      • X Offline
        X Offline
        xxxspxxx
        Hallo also es ist wirklich so. Ich habe mal zum Beispiel nur einen das Zeit Objekt (CRON) hinzugefügt. und bekomme beim Speichern des Scripts schon direkt mehrere Fehler im LOG
        Also ich glaube es wäre besser erst noch auf der alten Version zu bleiben…
          msiemers
          Fehler bekomme ich gar keine. Das Log zu JavaScript ist leer.
          Ich habe zwischendurch einmal ein Downgrade auf 3.6.4 gemacht. Leider Ohne erfolg.
          Ich hab dann die Java Instanz und den kompletten Adapter gelöscht und in der Version 4.06 wieder installiert.
          Nun habe ich das Problem, das in den Objekten gar keine JavaScript Objekte mehr angezeigt werden. Diese werden
          nur angezeigt wenn man den Expertenmodus aktiviert. Das bringt wei schon geschrieben aber im Text2Command Adpater nichts
          dort kann man den Expertenmodus nicht aktvieren. Ich bin ein wenig ratlos.
          • X Offline
            X Offline
            xxxspxxx
            Guten Morgen,
            also ich habe auch mal ein downgrade auf die 3.6.4 gemacht und damit funktioniert der CRON wieder. Oha. Ich werde in den nächsten Tagen nochmal einen neuen Test ioBroker aufbauen und schauen was da genau los ist.
            • AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @msiemers:
              Diese werden
              dort kann man den Expertenmodus nicht aktvieren. Ich bin ein wenig ratlos. `
              Workaround: Verwende die Skripte so wie sie gedacht sind. Schalte deine Skripte an und lass sie an. Lege Trigger-Datenpunkte an, auf die du im Skript lauschst und beschreibe diese mit dem Text2Command-Adapter.
                msiemers
                Dafür fehlt mir wohl das nötige KnowHow in der Script Programmierung.
                In Text2Command gibt es doch auch keine andere Möglichkeit, oder?
                • stoamandlS Offline
                  stoamandlS Offline
                  stoamandl
                  Guten Morgen zusammen,
                  zu dem hier beschriebenen Problem gibt es nun einen Issue auf GitHub https://github.com/ioBroker/ioBroker.te … /issues/35
                  Ist zwar nicht gut erklärt….. aber der Entwickler wird schon wissen was gemeint ist.
                  Hoffe das es bald gefixt wird.
                  Bis dahin kann man ja das Scriptpfad manuell eintragen.
                  Stoamandl
                    AlCalzoneA Offline
                    AlCalzone
                    Ich würde nicht davon ausgehen dass das in naher Zukunft gefixt wird. Im blockly brauchst du genau zwei Blöcke (state erstellen und trigger) um ohne diese Krücke auszukommen.
                    Scriptenabled ist nicht offiziell dokumentiert und aud gutem Grund versteckt.
                    https://github.com/ioBroker/ioBroker.ja … eate-state
                    Unter typische Anwendung dieses blocks siehst du ein beispiel wie es richtig geht.
                    Gesendet von unterwegs
                    • hg6806H Offline
                      hg6806H Offline
                      hg6806
                      Also bei mir ist der ioBroker Admin besonders Javascript und die Scripte nun sehr langsam geworden, seitdem ich Javascript auf 4.0.6 geupdated hatte.
                      Irgendwas stimmt da nicht.
                        AlCalzoneA Offline
                        AlCalzone
                        Kann ich tatsächlich nicht bestätigen. 4.x rennt bei mir im Vergleich zu 3.7
                        • thexbrainT Offline
                          thexbrainT Offline
                          thexbrain
                          @msiemers
                          Ich hatte das auch das die nicht bei Objekten usw. angezeigt wurden.
                          Mach folgendes, experten Ansicht an und dann das sichtbare Script rechts bearbeiten.
                          Dann sollte expert angeklickt sein, das musst du weg klicken und schon werden die Scripte richtig angezigt.
                          • hg6806H Offline
                            hg6806H Offline
                            hg6806
                            Wenn ich auf ein Objekt in einem Script klicke dauert es Minuten bis sich die Liste mit den Objekten öffnet.
                            Ich bekomme auch seit dem eine Menge Warnings
                            javascript.0	2018-12-31 17:59:26.113	warn	at Timer.listOnTimeout (timers.js:290:5)
                            javascript.0	2018-12-31 17:59:26.113	warn	at tryOnTimeout (timers.js:323:5)
                            javascript.0	2018-12-31 17:59:26.113	warn	at ontimeout (timers.js:511:34)
                            javascript.0	2018-12-31 17:59:26.113	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1794:34)
                            javascript.0	2018-12-31 17:59:26.112	warn	at Object.leseDatum (script.js.common.Sonstiges.Kalender:713:5)
                            javascript.0	2018-12-31 17:59:26.111	warn	Wrong type of javascript.0.Kalender.Datuminfo.de.Tag.Feiertag: "object". Please fix, while deprecated and will not work in next versions.
                            javascript.0	2018-12-31 17:59:26.111	warn	at Timer.listOnTimeout (timers.js:290:5)
                            javascript.0	2018-12-31 17:59:26.111	warn	at tryOnTimeout (timers.js:323:5)
                            javascript.0	2018-12-31 17:59:26.110	warn	at ontimeout (timers.js:511:34)
                            javascript.0	2018-12-31 17:59:26.110	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1794:34)
                            javascript.0	2018-12-31 17:59:26.110	warn	at Object.leseDatum (script.js.common.Sonstiges.Kalender:712:5)
                            javascript.0	2018-12-31 17:59:26.109	warn	Wrong type of javascript.0.Kalender.Datuminfo.de.Tag.Name: "object". Please fix, while deprecated and will not work in next versions.
                            javascript.0	2018-12-31 17:59:26.109	warn	at Timer.listOnTimeout (timers.js:290:5)
                            javascript.0	2018-12-31 17:59:26.108	warn	at tryOnTimeout (timers.js:323:5)
                            javascript.0	2018-12-31 17:59:26.108	warn	at ontimeout (timers.js:511:34)
                            javascript.0	2018-12-31 17:59:26.108	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1794:34)
                            javascript.0	2018-12-31 17:59:26.108	warn	at Object.leseDatum (script.js.common.Sonstiges.Kalender:710:23)
                            javascript.0	2018-12-31 17:59:26.107	warn	getState "feiertage.0.heute.boolean" not found (3)
                            javascript.0	2018-12-31 17:59:26.106	warn	at Timer.listOnTimeout (timers.js:290:5)
                            javascript.0	2018-12-31 17:59:26.106	warn	at tryOnTimeout (timers.js:323:5)
                            javascript.0	2018-12-31 17:59:26.106	warn	at ontimeout (timers.js:511:34)
                            javascript.0	2018-12-31 17:59:26.106	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1794:34)
                            javascript.0	2018-12-31 17:59:26.105	warn	at Object.leseDatum (script.js.common.Sonstiges.Kalender:709:26)
                            javascript.0	2018-12-31 17:59:26.103	warn	getState "feiertage.0.heute.Name" not found (3)
                            Kann mir jemand beschreiben wie ich auf 3.64 downgrade?
                            Ich habe Angst wenn ich Javascript lösche, dass meine ganze Programme weg sind und auch die Daten vom Stromverbrauchsscript verschunden sind.
                              thexbrainT Offline
                              thexbrain
                              @hg6806:
                              Ich habe Angst wenn ich Javascript lösche, dass meine ganze Programme weg sind und auch die Daten vom Stromverbrauchsscript verschunden sind. `
                              Die Scripte kannst du sichern (exportieren).
                              Downgrade schau mal im Bild
                              • hg6806H Offline
                                hg6806H Offline
                                hg6806
                                Danke für die Info.
                                Habe nun die 4.0.7 aufgespielt.
                                Jetzt habe ich folgende Fehlermeldung:
                                host.ioBroker-Pi3	2019-01-01 17:11:34.066	info	Restart adapter system.adapter.javascript.0 because enabled
                                host.ioBroker-Pi3	2019-01-01 17:11:34.065	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
                                javascript.0	2019-01-01 17:11:34.003	error	already running
                                Ich glaube das war aber vorher auch schon da.
                                  msiemers
                                  Könnte es sein, das Du zwei gleiche Instanzen vom JawaScript Adpater laufen hat?
                                  • hg6806H Offline
                                    hg6806H Offline
                                    hg6806
                                    Nein, ist nur eine Javascript Instanz installiert .
                                    • hg6806H Offline
                                      hg6806H Offline
                                      hg6806
                                      Instanz ist schon wioeder rot geworden.
                                      Log:
                                      avascript.0	2019-01-01 18:55:19.112	error	at Timer.listOnTimeout (timers.js:290:5)
                                      javascript.0	2019-01-01 18:55:19.112	error	at tryOnTimeout (timers.js:323:5)
                                      javascript.0	2019-01-01 18:55:19.112	error	at ontimeout (timers.js:498:11)
                                      javascript.0	2019-01-01 18:55:19.112	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/polling-xhr.js:256:18)
                                      javascript.0	2019-01-01 18:55:19.112	error	at Request.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/polling-xhr.js:309:8)
                                      javascript.0	2019-01-01 18:55:19.112	error	at Request.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                      javascript.0	2019-01-01 18:55:19.112	error	at Request. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/polling-xhr.js:109:10)
                                      javascript.0	2019-01-01 18:55:19.112	error	at XHR.Transport.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:64:13)
                                      javascript.0	2019-01-01 18:55:19.112	error	Error: xhr post error
                                      javascript.0	2019-01-01 18:55:19.110	error	xhr post error</anonymous>
                                      • G Offline
                                        Greg-nrw
                                        Danke thexbrain
                                        Das war die Lösung den Expter Modus für die jeweiligen Java Skripte deaktivieren und schon hat es geklappt
