  4. Philips Hue Szenen
    5.8k
Philips Hue Szenen
13 Beiträge 7 Kommentatoren 2.9k Aufrufe 1 Beobachtet
  • dslraserD Offline
    dslraserD Offline
    dslraser
    Du könntest mit diesem Script alle Hue Szenen auslesen und dann recht einfache Blocklys erstellen für den Cloudadater.
    `/* -- do not edit following lines - START --
    "debug": false,
    "verbose": false
    -- do not edit previous lines - END --*/
    var HueApi = require("node-hue-api").HueApi;
    ! // Replace IP and username!!!
    var host = "192.168.180.xx",
    username = "xxx",
    api = new HueApi(host, username);
    var groups_ = [],
    lights_ = [],
    objects_ = [];
    ! // Log JSON results
    var displayResults = function(result) {
    console.log('Reponse: '+JSON.stringify(result, null, 2));
    ! // Parse Light Group 0 (All Lights)
    var parseGroup0 = function(result) {
    if (!result.lights){return} // Empty group
    var id = result.id,
        lights = result.lights,
        name = "All Lights";
    console.debug('group: '+name+', lights: '+lights);
    groups_[lights] = name;
    ! // Parse Light Groups
    var parseGroups = function(result) {
    for (var i = 0; i < result.length; i++) {
    if (!result[i].lights){continue} // Empty group
        var id = result[i].id,
            lights = result[i].lights,
            name = result[i].name;
    ! // Parse Lights
    var parseLights = function(result) {
    console.debug('light: '+name+', id: '+id);
    lights_[id] = name;
    ! // Create States in ioBroker
    var createStates = function(result) {
    // Resync button
    createState('PhilipsHue.Scenes.Resync', false, {role: "button", name: 'Resync Philips Hue Groups, Lights and Scenes'});
    ! for (var i = 0; i < result.length; i++) {
    if (!result[i].appdata.data){continue} // skip internal szenes
    ! var id = result[i].id,
    name = result[i].name.replace(/"/g,''),
    pathname = name.replace(/ /g,'_');
        // Get light names
        var light_names = [];
        for (var j = 0; j < lights.length; j++) {
            var light_name = lights_[lights[j]];
            light_names.push(light_name);
    ! // Room, group or lights linked with scene
    var group = 'Group: '+groups_[lights] || 'Lights: '+light_names.join(", ");
        // Create States and skip duplicates
        if (!objects_[lights+pathname]){
            console.debug('scene: '+name+', '+group);
            createState('PhilipsHue.Scenes.'+pathname+'.'+id, false, {role: "button", name: 'Scene: '+name+' ('+group+')'});
            objects_[lights+pathname] = true;
    ! // Delete States
    function deleteStates(){
    console.log('Deleting current objects for scenes...');
    objects_ = [];
    $('javascript.0.PhilipsHue.Scenes.*').each(function (id) {
    deleteState(id);
    ! // Fetch data from Hue API
    function init(){
    api.getGroup(0, function(err, group0) {
    if (err) throw err;
    console.log('Processing group 0...');
    //displayResults(group0);
    parseGroup0(group0);
    api.groups(function(err, groups) {
    if (err) throw err;
    console.log('Processing ' + groups.length + ' groups...');
    //displayResults(groups);
    parseGroups(groups);
    ! api.lights(function(err, lights) {
    if (err) throw err;
    console.log('Processing ' + lights.lights.length + ' lights...');
    //displayResults(lights);
    parseLights(lights.lights);
    ! api.scenes(function(err, scenes) {
    if (err) throw err;
    console.log('Processing ' + scenes.length + ' scenes...');
    //displayResults(scenes);
    createStates(scenes);
    ! // Init on start
    init();
    ! // Activate scene
    on({id: /^javascript.0.PhilipsHue.Scenes./, val: true}, function (obj) {
    if (obj.id == 'javascript.0.PhilipsHue.Scenes.Resync'){return}
    sceneId = obj.id.split('.').pop();
    console.log('Activating '+obj.name);
    api.activateScene(sceneId, function(err, result) {
    if (err) throw err;
    displayResults(result);
    setState(obj.id, false);
    ! // Resync
    on({id: 'javascript.0.PhilipsHue.Scenes.Resync', val: true}, function (obj) {
    console.log('Resync triggered...');
    groups_ = [];
    lights_ = [];
    deleteStates();
    init();
    ! schedule("0 3 * * *", function () {
    groups_ = [];
    lights_ = [];
    deleteStates();
    init();
    Du musst nur Deine IP Adresse und Benutzer von der HUE Bridge eintragen.
    ! Die Szenen findest Du dann unter javascript.0
    ! Wenn Du Hilfe beim Blockly brauchst sag Bescheid.
    ! PS: Im Javascript Adapter noch diesen Eintrag wie im Bild vornehmen[img]https://uploads.tapatalk-cdn.com/201809 ... c9b6c2.jpg[/img][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i]
    • N Offline
      N Offline
      Nakashi
      Vielen Dank werde ich morgen Nachmittag ausprobieren und mich dann melden
      • N Offline
        N Offline
        Nakashi
        Das Script hat super funktioniert danke dafür
        habe auch die einbindung ins homekit wia blockly geschafft muss jetzt nur noch einen anzeigefehler geheben wenn ich direkt von normalem licht auf nachtlicht umschalte und umgekehrt
        • dslraserD Offline
          dslraserD Offline
          dslraser
          prima, freut mich das ich helfen konnte.
          Ich finde das Script auch gut, weil man so an die Hue Szenen drann kommt.
          • haselchenH Offline
            haselchenH Offline
            haselchen
            Muss mich mal mit einklinken.
            Danke erstmal fürs Skript.
            Wie verarbeite ich die Szenen in Blockly?
            Mit welchen Bausteinen.
            • dslraserD Offline
              dslraserD Offline
              dslraser
              @haselchen:
              Mit welchen Bausteinen. ` ich verstehe die Frage zwar nicht so genau, aber anbei mal ein Beispiel mit einer Standard Szene - Energie tanken. (geht auch mit selbst erstellten Szenen)
              Falls Du das meinst…![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201812 ... b462d1.jpg">https://uploads.tapatalk-cdn.com/20181206/55994dcbbe433fe00629fb9f9bb462d1.jpg</link_text>" />
                haselchenH Offline
                haselchen
                Genau das meinte ich. Vielen Dank für das Beispiel.
                  Alex975
                  ich hänge mal meine Frage aus nem anderen Unterforum hier an:
                  viewtopic.php?f=20&t=19332
                  • siggi85S Offline
                    siggi85S Offline
                    siggi85
                    Kann man das Script zum Import der in der Bridge gespeicherten Szenen nicht auch in den Hue Adapter einbauen? Ich denke dass viele Leute so etwas gebrauchen können.
                      aleks-83
                      @siggi85:
                      Kann man das Script zum Import der in der Bridge gespeicherten Szenen nicht auch in den Hue Adapter einbauen? Ich denke dass viele Leute so etwas gebrauchen können. `
                      Das denke ich auch!
                      Ich nutze das Skript auch. Richtig super!
                      Ich schalte damit bestimmte hie Szenen wenn ich an meiner harmony Aktionen starte oder stoppe.
                      Funktioniert auch wie gewünscht.
                      Gibt es eine Möglichkeit, die Szenen langsam über zu blenden?
                      Also aktuell wird die neue Szene einfach eingeschaltet.
                      Ich möchte gerne dass die aktuelle Einstellung in die neue Szene überblendet. Innerhalb z.B. 3 Sekunden.
                      = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
                      = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
                      Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
                      Glasfaser 400
