  4. Hilfe für Nachkommastellen
    5.8k
13 Beiträge 5 Kommentatoren 3.4k Aufrufe
  • sigi234S Online
    sigi234S Online
    Wie kann ich das auf 0 Nachkommastellen ändern?
            "id": "dafa224e.cd323",
            "type": "Memory",
            "z": "e3a6205a.2fabe",
            "name": "",
            "x": 340,
            "y": 240,
            "wires": [
                    "98787022.374fb"
            "id": "98787022.374fb",
            "type": "change",
            "name": "totalmem",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.totalmem",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 720,
            "y": 240,
            "wires": [
                    "1e85db4e.dbe685"
            "id": "1e85db4e.dbe685",
            "type": "function",
            "name": "Totalmem in GB",
            "func": "var totalmem = (parseInt(msg.payload))/1000000000;\n//var totalmen = totalmemgb/1000000000;\nmsg.payload = totalmem;\nreturn msg;\n",
            "outputs": 1,
            "noerr": 0,
            "x": 900,
            "y": 240,
            "wires": [
                    "d99e7c70.67ceb"
            "id": "d99e7c70.67ceb",
            "type": "ui_text",
            "group": "d337825b.0c0f6",
            "order": 0,
            "width": 0,
            "height": 0,
            "name": "Totalmem",
            "label": "Totalmem :",
            "format": "{{msg.payload}} GB",
            "layout": "row-spread",
            "x": 1100,
            "y": 240,
            "wires": []
            "id": "d337825b.0c0f6",
            "type": "ui_group",
            "z": "",
            "name": "System",
            "tab": "71264ddd.7a9174",
            "order": 1,
            "disp": true,
            "width": "6",
            "collapse": false
            "id": "71264ddd.7a9174",
            "type": "ui_tab",
            "z": "",
            "name": "Windows",
            "icon": "dashboard",
            "order": 8
    • R Offline
      rewenode
      var x = "1234567";
      console.log(parseInt(x));  //1234567
      console.log(parseInt(x)/1000000); //1.234567
      console.log(parseInt(x/1000000)); //1
      Setz deine Klammer entsprechend
      • paul53P Offline
        @sigi234:
        Wie kann ich das auf 0 Nachkommastellen ändern? `
        Mit
        x = Math.round(x);
        • sigi234S Online
          sigi234S Online
          Danke, wohin muss ich das setzen?
          Oh Mann, Red Node ist nicht so einfach….......
          • paul53P Offline
            @sigi234:
            wohin muss ich das setzen? `
            Von Node-Red habe ich keine Ahnung. Vermutlich so ?
            var totalmem = Math.round(parseInt(msg.payload) / 1000000000);
            • R Offline
              rewenode
              Besser so, wenn es klappen soll:
              var totalmem = Math.round(msg.payload/1000000);
              • sigi234S Online
                sigi234S Online
                @paul53:
                Von Node-Red habe ich keine Ahnung. Vermutlich so ? `
                Ja, aber ich lese und teste viel und schau Videos, aber ein bisschen was kommt da schon heraus.
                Manchmal stehe ich einfach auf der Leitung.
                • R Offline
                  rewenode
                  Sieht doch klasse aus!!!
                    alexalex
                    Mal was anderes, was nutzt du denn als Wetterstation? :)
                    Gesendet von meinem Redmi 5 Plus mit Tapatalk
                    • sigi234S Online
                      sigi234S Online
                      openweathermap
                      • E Offline
                        erastephan
                        sieht sehr gut aus.
                        habe so etwas ähnliches als poolsteuerung am laufen.
                        was mich brennend interessiert ist: wie hast du das mit den temperaturen in verschieden zimmer gelöst.
                        ich meine bei meiner steuerung ist ein ds18b20 angeschlossen
                        der in der leitung vom schwimmbad sitzt.
                        nun ich gehe nicht davon aus das du in jedes zimmer
                        ein kabel verlegt hast um die temperatur zu messen.
                        mfg
                        steph
                        • sigi234S Online
                          sigi234S Online
                          Was meinst du?
                          Die Temp sind einmal vom Wetter Adapter, dann von Hue, und von Homematic.
                          • E Offline
                            erastephan
                            ich meinte welche sensoren das sind die die temperatur von den räumen liefern.
                            habe schon viel gegooglet aber nun bin ich mehr verwirrt als zuvor.
                            ist das ein hue gerät das mit batterie in den raum gestellt wird
                            und dann per wlan die daten ans node sendet?
                            oder eventuell ein raumthermostat das mit wifi funktioniert?
