  4. Test Adaper Discovergy v0.4.x
energie
294 Beiträge 33 Kommentatoren 69.6k Aufrufe 21 Beobachtet
  • DutchmanD Offline
    DutchmanD Offline
    Dutchman
    Nice !
    Ich werde heute Abend extra logging einbauen da ich nicht weiß welche Werte alles kommen können also ich mache alles blind ;)
    Hast du nur Strommesser ? 1ne, 2 oder 3 Faden?
    • WebrangerW Offline
      WebrangerW Offline
      Webranger
      Das kommt momentan im log bei mir:
      2018-12-05 17:20:43.085 - info: discovergy.0 meterId : 928bbbc346c34c1fafc867467396712e
      2018-12-05 17:20:43.086 - error: discovergy.0 MeterId_Found
      2018-12-05 17:20:43.087 - info: discovergy.0 serialNumber : 60867681
      2018-12-05 17:20:43.089 - info: discovergy.0 location : [object Object]
      2018-12-05 17:20:43.089 - info: discovergy.0 administrationNumber : DE0002883254700000000102547100000
      2018-12-05 17:20:43.089 - info: discovergy.0 type : EASYMETER
      2018-12-05 17:20:43.090 - info: discovergy.0 measurementType : ELECTRICITY
      2018-12-05 17:20:43.090 - info: discovergy.0 scalingFactor : 1
      2018-12-05 17:20:43.090 - info: discovergy.0 currentScalingFactor : 1
      2018-12-05 17:20:43.090 - info: discovergy.0 voltageScalingFactor : 1
      2018-12-05 17:20:43.090 - info: discovergy.0 internalMeters : 1
      2018-12-05 17:20:43.090 - info: discovergy.0 firstMeasurementTime : 1537888127652
      2018-12-05 17:20:43.090 - info: discovergy.0 lastMeasurementTime : 1544026883602
      2018-12-05 17:20:43.338 - info: history.0 enabled logging of discovergy.0.928bbbc346c34c1fafc867467396712e.Power, Alias=false
      2018-12-05 17:20:43.345 - info: history.0 enabled logging of discovergy.0.928bbbc346c34c1fafc867467396712e.Power_Total, Alias=false
      2018-12-05 17:20:46.052 - info: discovergy.0 meterId : 928bbbc346c34c1fafc867467396712e
      2018-12-05 17:20:46.056 - error: discovergy.0 MeterId_Found
      2018-12-05 17:20:46.057 - info: discovergy.0 serialNumber : 60867681
      2018-12-05 17:20:46.057 - info: discovergy.0 location : [object Object]
      2018-12-05 17:20:46.057 - info: discovergy.0 administrationNumber : DE0002883254700000000102547100000
      2018-12-05 17:20:46.057 - info: discovergy.0 type : EASYMETER
      2018-12-05 17:20:46.057 - info: discovergy.0 measurementType : ELECTRICITY
      2018-12-05 17:20:46.057 - info: discovergy.0 scalingFactor : 1
      2018-12-05 17:20:46.058 - info: discovergy.0 currentScalingFactor : 1
      2018-12-05 17:20:46.058 - info: discovergy.0 voltageScalingFactor : 1
      2018-12-05 17:20:46.058 - info: discovergy.0 internalMeters : 1
      2018-12-05 17:20:46.058 - info: discovergy.0 firstMeasurementTime : 1537888127652
      2018-12-05 17:20:46.058 - info: discovergy.0 lastMeasurementTime : 1544026886602
      2018-12-05 17:20:46.234 - info: history.0 enabled logging of discovergy.0.928bbbc346c34c1fafc867467396712e.Power, Alias=false
      2018-12-05 17:20:46.241 - info: history.0 enabled logging of discovergy.0.928bbbc346c34c1fafc867467396712e.Power_Total, Alias=false
      2018-12-05 17:20:49.068 - info: discovergy.0 meterId : 928bbbc346c34c1fafc867467396712e
      2018-12-05 17:20:49.072 - error: discovergy.0 MeterId_Found
      Alle 3 Sekunden````
      Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        Ups hohle ich in Version 0.3.1 raus danke !
          WebrangerW Offline
          Webranger
          Sagst du bescheid wenn es eine neue Version gibt?
          • DutchmanD Offline
            DutchmanD Offline
            Dutchman
            Jup, das wird wohl irgendwo zwischen 9 und 10 sein möchte par Sachen verbessern.
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              version 0.2.0 ist raus.
              der adapter ist jetzt auch per NPM verfuegbar, wird demnaest in die ioBroker repository aufgenommen.
              Also installation entwerder per github oder per npm :
              cd /opt/iobroker
              npm install iobroker.discovergy
              <size size="85">Edit: sudo entfernt (AlCalzone)</size>
              ` > ### 0.2.0
              • (Dutchman) reduced logging from every 3 seconds to only error if values are received which cannot be handled
              • (Dutchman) last time step of syncronisation added, currenlty unix time needs to be converted in next release `
                WebrangerW Offline
                Webranger
                Das sieht nicht gut aus bei mir.
                discovergy.0	2018-12-05 21:17:02.678	error	Send this information to developer : power226880
                discovergy.0	2018-12-05 21:17:02.678	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:17:02.677	error	Send this information to developer : power1312370
                discovergy.0	2018-12-05 21:17:02.677	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:17:02.676	error	Send this information to developer : power333610
                discovergy.0	2018-12-05 21:17:02.668	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:17:02.665	error	Send this information to developer : voltage3229500
                discovergy.0	2018-12-05 21:17:02.665	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:17:02.665	error	Send this information to developer : voltage2230100
                discovergy.0	2018-12-05 21:17:02.664	error	Send this information to developer : voltage1229100
                discovergy.0	2018-12-05 21:17:02.662	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:17:02.659	info	query result of meter : {"time":1544041022095,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":229100,"voltage2":230100,"voltage3":229500,"energyOut1":0,"power":372860,"energyOut2":
                discovergy.0	2018-12-05 21:16:59.711	error	Send this information to developer : power227060
                discovergy.0	2018-12-05 21:16:59.711	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:16:59.710	error	Send this information to developer : power1324140
                discovergy.0	2018-12-05 21:16:59.709	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:16:59.709	error	Send this information to developer : power333610
                discovergy.0	2018-12-05 21:16:59.708	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:16:59.708	error	Send this information to developer : voltage3229400
                discovergy.0	2018-12-05 21:16:59.707	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:16:59.704	error	Send this information to developer : voltage2230100
                discovergy.0	2018-12-05 21:16:59.704	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:16:59.703	error	Send this information to developer : voltage1228900
                discovergy.0	2018-12-05 21:16:59.703	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:16:59.701	info	query result of meter : {"time":1544041019095,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":228900,"voltage2":230100,"voltage3":229400,"energyOut1":0,"power":384810,"energyOut2":
                discovergy.0	2018-12-05 21:16:56.757	error	Send this information to developer : power227000
                discovergy.0	2018-12-05 21:16:56.756	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:16:56.750	error	Send this information to developer : power1324430
                discovergy.0	2018-12-05 21:16:56.749	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:16:56.748	error	Send this information to developer : power333820
                discovergy.0	2018-12-05 21:16:56.745	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:16:56.744	error	Send this information to developer : voltage3229300
                discovergy.0	2018-12-05 21:16:56.742	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:16:56.740	error	Send this information to developer : voltage2230100
                discovergy.0	2018-12-05 21:16:56.736	error	Information received from Discovergy which is not yet part of this adapter
                discovergy.0	2018-12-05 21:16:56.731	error	Send this information to developer : voltage1229100
                discovergy.0	2018-12-05 21:16:56.728	error	Information received from Discovergy which is not yet part of this adapter
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  @ringdingringding:
                  Das sieht nicht gut aus bei mir. `
                  doch danke ! Du hast halt daten welche ich noch nicht kannte ;)
                  https://github.com/DutchmanNL/ioBroker. … /issues/10
                  • DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    so, du hattest extra werte fuer jede fase die voltage & nog den jetzigen verbrauch :) (power 1 & 2)
                    probier mal bitte version 0.2.2 von github
                    du solltest unter objecten in iobroker die datenpunkte und werte sehen
                      WebrangerW Offline
                      Webranger
                      Schnell vor der Arbeit 0.2.2 installoert.
                      Kommt noch das an fehlern.
                      2018-12-06 06:06:02.710 - info: discovergy.0 query result of meter : {"time":1544072762135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225700,"voltage3":225400,"energyOut1":0,"power":758380,"energyOut2":0,"power3":10380,"power1":396440,"energy":7886260708000,"power2":351560}}
                      2018-12-06 06:06:02.758 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:02.759 - error: discovergy.0 Send this information to developer : power310380
                      2018-12-06 06:06:03.851 - info: javascript.0 script.js.common.System.Bei_Störung_E-Mail: trigger für Adapterüberwachung aktiv
                      2018-12-06 06:06:04.263 - info: discovergy.0 query result of meter : {"time":1544072762135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225700,"voltage3":225400,"energyOut1":0,"power":758380,"energyOut2":0,"power3":10380,"power1":396440,"energy":7886260708000,"power2":351560}}
                      2018-12-06 06:06:04.307 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:04.308 - error: discovergy.0 Send this information to developer : power310380
                      2018-12-06 06:06:05.068 - info: host.debian-iobroker instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                      2018-12-06 06:06:07.290 - info: discovergy.0 query result of meter : {"time":1544072767135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225800,"voltage3":225400,"energyOut1":0,"power":901230,"energyOut2":0,"power3":10150,"power1":539030,"energy":7886272786000,"power2":352050}}
                      2018-12-06 06:06:07.317 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:07.317 - error: discovergy.0 Send this information to developer : power310150
                      2018-12-06 06:06:10.279 - info: discovergy.0 query result of meter : {"time":1544072770135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225800,"voltage3":225300,"energyOut1":0,"power":759150,"energyOut2":0,"power3":10360,"power1":396820,"energy":7886279111000,"power2":351970}}
                      2018-12-06 06:06:10.305 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:10.306 - error: discovergy.0 Send this information to developer : power310360
                      2018-12-06 06:06:13.256 - info: discovergy.0 query result of meter : {"time":1544072772135,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225800,"voltage3":225200,"energyOut1":0,"power":757840,"energyOut2":0,"power3":10150,"power1":395690,"energy":7886283324000,"power2":352000}}
                      2018-12-06 06:06:13.276 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:13.277 - error: discovergy.0 Send this information to developer : power310150
                      2018-12-06 06:06:16.244 - info: discovergy.0 query result of meter : {"time":1544072775136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225500,"voltage2":225900,"voltage3":225200,"energyOut1":0,"power":664820,"energyOut2":0,"power3":10310,"power1":395450,"energy":7886289386000,"power2":259060}}
                      2018-12-06 06:06:16.279 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:16.281 - error: discovergy.0 Send this information to developer : power310310
                      2018-12-06 06:06:19.313 - info: discovergy.0 query result of meter : {"time":1544072779136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225500,"voltage2":226000,"voltage3":225100,"energyOut1":0,"power":490440,"energyOut2":0,"power3":10130,"power1":394230,"energy":7886294957000,"power2":86080}}
                      2018-12-06 06:06:19.333 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:19.333 - error: discovergy.0 Send this information to developer : power310130
                      2018-12-06 06:06:22.263 - info: discovergy.0 query result of meter : {"time":1544072781136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225100,"energyOut1":0,"power":490630,"energyOut2":0,"power3":10250,"power1":394110,"energy":7886297682000,"power2":86270}}
                      2018-12-06 06:06:22.288 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:22.289 - error: discovergy.0 Send this information to developer : power310250
                      2018-12-06 06:06:25.300 - info: discovergy.0 query result of meter : {"time":1544072785136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225200,"energyOut1":0,"power":490040,"energyOut2":0,"power3":10260,"power1":393640,"energy":7886303129000,"power2":86140}}
                      2018-12-06 06:06:25.354 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:25.354 - error: discovergy.0 Send this information to developer : power310260
                      2018-12-06 06:06:28.314 - info: discovergy.0 query result of meter : {"time":1544072788136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225900,"voltage3":225100,"energyOut1":0,"power":490940,"energyOut2":0,"power3":10400,"power1":394210,"energy":7886307222000,"power2":86330}}
                      2018-12-06 06:06:28.338 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:28.339 - error: discovergy.0 Send this information to developer : power310400
                      2018-12-06 06:06:31.283 - info: discovergy.0 query result of meter : {"time":1544072790136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225100,"energyOut1":0,"power":491540,"energyOut2":0,"power3":10360,"power1":394940,"energy":7886309951000,"power2":86240}}
                      2018-12-06 06:06:31.303 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:31.303 - error: discovergy.0 Send this information to developer : power310360
                      2018-12-06 06:06:34.639 - info: discovergy.0 query result of meter : {"time":1544072794136,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225000,"voltage2":225800,"voltage3":225000,"energyOut1":0,"power":494190,"energyOut2":0,"power3":10580,"power1":397180,"energy":7886315447000,"power2":86430}}
                      2018-12-06 06:06:34.659 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:34.660 - error: discovergy.0 Send this information to developer : power310580
                      2018-12-06 06:06:37.289 - info: discovergy.0 query result of meter : {"time":1544072797137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225800,"voltage3":225100,"energyOut1":0,"power":492690,"energyOut2":0,"power3":10530,"power1":395770,"energy":7886319552000,"power2":86390}}
                      2018-12-06 06:06:37.308 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:37.308 - error: discovergy.0 Send this information to developer : power310530
                      2018-12-06 06:06:40.337 - info: discovergy.0 query result of meter : {"time":1544072799137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225200,"voltage2":225900,"voltage3":225200,"energyOut1":0,"power":491030,"energyOut2":0,"power3":10360,"power1":394600,"energy":7886322286000,"power2":86070}}
                      2018-12-06 06:06:40.355 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:40.356 - error: discovergy.0 Send this information to developer : power310360
                      2018-12-06 06:06:43.338 - info: discovergy.0 query result of meter : {"time":1544072802137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225300,"voltage2":225800,"voltage3":225400,"energyOut1":0,"power":611030,"energyOut2":0,"power3":10490,"power1":514390,"energy":7886327820000,"power2":86150}}
                      2018-12-06 06:06:43.392 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:43.393 - error: discovergy.0 Send this information to developer : power310490
                      2018-12-06 06:06:46.309 - info: discovergy.0 query result of meter : {"time":1544072806137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225500,"voltage2":225800,"voltage3":225500,"energyOut1":0,"power":491650,"energyOut2":0,"power3":10260,"power1":395180,"energy":7886333280000,"power2":86210}}
                      2018-12-06 06:06:46.328 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:46.329 - error: discovergy.0 Send this information to developer : power310260
                      2018-12-06 06:06:49.304 - info: discovergy.0 query result of meter : {"time":1544072809137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225600,"voltage2":225700,"voltage3":225300,"energyOut1":0,"power":490680,"energyOut2":0,"power3":10310,"power1":394420,"energy":7886337372000,"power2":85950}}
                      2018-12-06 06:06:49.323 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:49.324 - error: discovergy.0 Send this information to developer : power310310
                      2018-12-06 06:06:52.308 - info: discovergy.0 query result of meter : {"time":1544072812137,"values":{"energyOut":2208756000,"energy2":0,"energy1":0,"voltage1":225400,"voltage2":225800,"voltage3":225100,"energyOut1":0,"power":492380,"energyOut2":0,"power3":10200,"power1":395830,"energy":7886341470000,"power2":86350}}
                      2018-12-06 06:06:52.334 - error: discovergy.0 Information received from Discovergy which is not yet part of this adapter
                      2018-12-06 06:06:52.334 - error: discovergy.0 Send this information to developer : power310200
                      Hier mehr log:  ![2958_discovergylog.txt](/assets/uploads/files/2958_discovergylog.txt)
                       ![2958_bildschirmfoto_2018-12-06_um_06.10.19.png](/assets/uploads/files/2958_bildschirmfoto_2018-12-06_um_06.10.19.png)
                      evtl auch noch mehr …
                      • DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        @ringdingringding:
                        Kommt noch das an fehlern. `
                        Danke ! Habe die fehler aus deinem log behoben :-)
                        @All,
                        Version 0.2.5 is gerade eben fertiggestellt, es sollte jetzt eigentlich fast alle werte verarbeitet werden.
                        Da ich abhaenging bin von demo account kan ich nur daten verarbeiten welche ueber diesen demo account anwesend sind.
                        Also bitte immer log im auge behalten nach adapterstart, fuer circa 20 sekunden, kommt da eine meldung :
                        ` > Information received from Discovergy which is not yet part of this adapter"
                        "Send this information to developer : xxxxx `
                        Dan brauche ich diese information um den fehler zu korrigieren, bitte die komplette information aus dem log (log downloaden) und nicht copy/paste aus dem webinterface da fehlen daten !
                        Wichtig : Der object baum wird jetzt per seriennummer aufgebaut, also vor starten der version 0.2.5 bitte erst den jetzigen object baum loeschen !
                        changelog :
                        0.2.5
                        (Dutchman) Please remove all current objects within tree discoververgy.x, version 0.2.5 introduce device creation by serial number !
                        (Dutchman) Changed object tree of device from meterId to sererialnumber, please not this means all vallue are now in a different tree
                        (Dutchman) Implemented multiple meter support
                        (Dutchman) implemented "info" object which provides basic information of the device
                        (Dutchman) Implemented all values which are available by demo-account of discovergy
                        (Dutchman) Remark : not all possbile devices are in the demo, if a device cannot be handled you will get an error message i need that information to implement !
                        (Dutchman) Reduced logging
                        Wuerde mich freuen ueber jeden feedback, ueberprueft bitte auch ob alle werte richtig reinkommen.
                        Fuer fehler, ergaenzungen oder vorschlaege bitte issue auf git erstellen : https://github.com/DutchmanNL/ioBroker. … rgy/issues
                        Have Fun !
                        Dutch
                          WebrangerW Offline
                          Webranger
                          Moin
                          Log jetzt Fehlerfrei und Daten kommen an.
                          Mal weiter beobachten.
                          Super arbeit.
                          Gruss Danyel
                          • DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            Nice!
                            Werden die Datenpunkte bei dir richtig angelegt ?
                            Stimmen alle Werte und Einheiten ?
                              WebrangerW Offline
                              Webranger
                              Sieht auf den ersten Blick super aus.
                              Selbst die Angaben unter info werden richtig angezeigt (Adresse und so)
                              Gruss Danyel
                              • DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                Sehr schön :D
                                  WebrangerW Offline
                                  Webranger
                                  Jetzt muss nur noch das Script um Stromverbrauch protokollieren funktionieren damit mir die Kosten richtig angezeigt werden.
                                  • DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    Hmm…
                                    Das Script geht doch super :)
                                    Oh Ehm ja Ehm, ich habe mir vorgenommen auch das zu einem Adapter zu Porten wird aber bisl länger dauern erwarte die Beta aber nog im Dezember...
                                    Der Script Bauer hat da wirklich super Arbeit geleistet aber ich schätze Mal für die meisten User ist Script gerade so einen Schritt zu weit und ist ein Adapter wo man nur die Geräte eintragen muss sinnvoller
                                    Oh man ersten Adapter gebaut (Discovergy), macht Spass kommen bestimmt mehr
                                      WebrangerW Offline
                                      Webranger
                                      Das Script läuft seit ne Stunde aber zeigt seit dem kosten von 0,20€?
                                      Ich warte da einfach mal paar Tage ab.
                                      Ein Adapter wäre da bestimmt viel einfacher.
                                      Naja ich warte da mal ab was du da zauberst.
                                      Dein erster Adapter ist schon mal top geworden.
                                      Evtl sind die drei Sekunden zu "aggressiv"
                                      Habe das Gefühl das alles bisl behäbiger läuft mit dem Script zusammen aber kann mich auch täuschen.
                                      Im Script hab ich ja den datenpunkt vom Zählerstand eingetragen, das doch richtig oder?
                                      • DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        @ringdingringding:
                                        Ich warte da einfach mal paar Tage ab. `
                                        Das script arbeitet standard mit einem kumulierten wert, also scriptstart = 0 linie
                                        Man kan das beinflussen :
                                        1. script stoppen
                                        2. adapter welcher die daten einliest stoppen
                                        3. im baum der werte den wert kumuliert aufsuchen, hier den jetzigen wert eintragen
                                        4. bei bedarf auch die werte zaehlerstand tages, wochen, monat, kwartal, jahr eintregen
                                        5. script starten
                                        6. adapter starten (der die werte auspuckt
                                        sobald sich jetzt ein werte aendert wird alles neu berechnet, je nach dem ob man die anfangsstaende eingetragaen hat auch den tages, wochen, monat usw…
                                        @ringdingringding:
                                        Habe das Gefühl das alles bisl behäbiger läuft mit dem Script zusammen aber kann mich auch täuschen. `
                                        Ja das werde ich noch aendern, bin am ueberlegen :
                                        1. einen fest definierten wert in den adapter einstellungen (polling interva)
                                        2. eventuell susaetzlich den wert ""momentan verbrauch" alle x sekunden auslesen und den gesamt zaelherstand nur einmal pro 30 sec/minuten
                                        ich denke mal das wuerden raichen fuer die algemein werte, den jetzigen verbrauch moechte man ja dan doch aktuell haben
                                        vorschlaege gerne :)
                                          WebrangerW Offline
                                          Webranger
                                          @Dutchman:
                                          1. script stoppen
                                          5. script starten
                                          6. adapter starten `
                                          genau so habe ich das gemacht. Der Zählerstand wird im script auch richtig übermittelt aber der wert steht immer noch bei 0,20€
                                          Ich werde mal morgen abwarten und schauen was da passiert.
                                          Gruß Danyel
