  4. Installisation Javascript (Scriptausführung Adapter)
5 Beiträge 3 Kommentatoren 720 Aufrufe
    trilfitz
    Hallo Ihr,
    bei der Installisation vom Adapter Scriptausführung erhalte ich folgenden Fehler:
    "Fertig mit Fehler: host.raspberrypi Cannot install iobroker.javascript: 243"
    Habt ihr einen Tipp für mich?
    Vielen Dank schon mal :)
    root@raspberrypi:/opt/iobroker# npm install iobroker.javascript --production --save --prefix
    npm WARN invalid config prefix=true
    npm WARN invalid config Must be a valid filesystem path
    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    > iobroker.javascript@4.0.1 postinstall /opt/iobroker/node_modules/iobroker.javascript
    > node ./install/installTypings.js
    installing NodeJS typings...
    npm ERR! path /root/.npm/_logs
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall scandir
    npm ERR! Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    npm ERR!  { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    npm ERR!   stack: 'Error: EACCES: permission denied, scandir \'/root/.npm/_logs\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'scandir',
    npm ERR!   path: '/root/.npm/_logs' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    glob error { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
      errno: -13,
      code: 'EACCES',
      syscall: 'scandir',
    npm ERR! path /root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be
    npm ERR! errno -13
    npm ERR! syscall open
    npm ERR! Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'
    npm ERR!  { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'
    npm ERR!   cause:
    npm ERR!      syscall: 'open',
    npm ERR!      path: '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be' },
    npm ERR!   isOperational: true,
    npm ERR!   stack: 'Error: EACCES: permission denied, open \'/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be\'',
    npm ERR!
    npm ERR!
    npm ERR! code ELIFECYCLE
    npm ERR! errno 243
    npm ERR! iobroker.javascript@4.0.1 postinstall: `node ./install/installTypings.js`
    npm ERR! Exit status 243
    npm ERR!
    npm ERR! Failed at the iobroker.javascript@4.0.1 postinstall script.
    npm ERR!     /root/.npm/_logs/2018-12-04T21_57_15_481Z-debug.log
    root@raspberrypi:/opt/iobroker# ^C
    root@raspberrypi:/opt/iobroker# /root/.npm/_logs/2018-12-04T21_57_15_481Z-debug.log
    bash: /root/.npm/_logs/2018-12-04T21_57_15_481Z-debug.log: Permission denied
    root@raspberrypi:/opt/iobroker# sudo /root/.npm/_logs/2018-12-04T21_57_15_481Z-debug.log
    sudo: /root/.npm/_logs/2018-12-04T21_57_15_481Z-debug.log: command not found
    npm ERR! errno -13
    npm ERR!
    npm ERR!
      errno: -13,
      code: 'EACCES',
      syscall: 'scandir',
    npm ERR! errno -13
    npm ERR!   cause:
    npm ERR!
    npm ERR!
    npm ERR! errno 243
    npm ERR!
    npm ERR!     /root/.npm/_logs/2018-12-04T21_59_09_576Z-debug.log
    • ? Offline
      Schau mal da….
      viewtopic.php?f=20&t=19155
      und da
      viewtopic.php?f=22&t=19182
        trilfitz
        Danke Menne,
        ich werde es heute abend mal ausprobieren. Wenn ich das richtig gelesen haben ist das mögliche Problem das ich ein kleines L bei einem Kommentar geschrieben habe.
        Ich werde berichten ob es daran lag.
        • AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          Bei dir wurde irgendeine Installation mit sudo durchgeführt und hat die Berechtigungen zerschossen:
          Folgender Befehl auf der Konsole sollte das beheben:
          sudo chown -R $(whoami) ~/.npm
          Danach nochmal JavaScript-Adapter installieren.
            trilfitz
            Danke AlCalzone!
            Dein Code hat geholfen. :)
