  4. HomematicRPC 1.8 + REGA 2.0 testen
    6.4k
83 Beiträge 10 Kommentatoren 17.9k Aufrufe 4 Beobachtet
  • foxriver76F Offline
    foxriver76F Offline
    foxriver76
    @RolfFrie:
    In CCU Authentifizierung eingeschaltte un Firewall/Sicheheit alles offen. Beide obigen Adapter installiert:
    Bleibt ROT
    im LOG
    hm-rega.0 2018-12-02 16:00:38.408 error at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    hm-rega.0 2018-12-02 16:00:38.408 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    hm-rega.0 2018-12-02 16:00:38.408 error at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    hm-rega.0 2018-12-02 16:00:38.408 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    hm-rega.0 2018-12-02 16:00:38.408 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    hm-rega.0 2018-12-02 16:00:38.408 error at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    hm-rega.0 2018-12-02 16:00:38.408 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    hm-rega.0 2018-12-02 16:00:38.408 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    hm-rega.0 2018-12-02 16:00:38.408 error at Socket.adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js:98:50)
    hm-rega.0 2018-12-02 16:00:38.408 error at Object.decrypt (/opt/iobroker/node_modules/iobroker.hm-rega/lib/crypto.js:29:30)
    hm-rega.0 2018-12-02 16:00:38.408 error TypeError: Cannot read property 'length' of undefined
    hm-rega.0 2018-12-02 16:00:38.406 error uncaught exception: Cannot read property 'length' of undefined
    hm-rega.0 2018-12-02 16:00:38.289 info starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.15.0
    CUXD scheint alles OK: GRÜN
    HM wireless
    Wahll von https, Nutzername/Passwort deaktiviert: Ergebnis GELB
    im LOG
    hm-rpc.1 2018-12-02 16:08:38.428 error init error: Error: response timeout
    HMIP
    Wahll von https, Nutzername/Passwort erledigt: Ergebnis GELB
    Keine Fehler im LOG
    Weiß jemand was hier passiert?</anonymous></anonymous> `
    Bezüglich dem cannot read prop length of udnefined error: Hast du ein Upload des Adapters durchgeführt?
    @RolfFrie:
    HM wireless
    Wahll von https, Nutzername/Passwort deaktiviert: Ergebnis GELB `
    Wenn du in der CCU Authentifizierung eingeschaltet hast musst du auch ein Nutzername PW angeben. Ansonsten kann sich der Adapter ja nicht authentifizieren. Zudem muss das Protokoll auf XML-RPC stehen.
    Videotutorials & mehr
    • R Offline
      RolfFrie
      Ein Upload hat REGA repariert: GRÜN:
      CUXD: Sowieso GRÜN
      Aber WIRELESS unD HMIP auch mit xml und Passwort weiterhin GELB, obwohl im LOG kein Fehler
      habe auch schon verschiedene Nutzer einschließlich root verwendet: Kein Unterschied.
      wirelss
      hm-rpc.1 2018-12-02 18:41:55.504 info xmlrpc client is trying to connect to 192.168.178.32:2001/ with ["https://192.168.178.61:12001","hm-rpc.1"]
      hm-rpc.1 2018-12-02 18:41:55.502 info xmlrpc server is trying to listen on 192.168.178.61:12001
      hm-rpc.1 2018-12-02 18:41:55.149 info starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.15.0
      hm-rpc.1 2018-12-02 18:41:53.599 info xmlrpc -> 192.168.178.32:2001/ init ["https://192.168.178.61:12001",""]
      hm-rpc.1 2018-12-02 18:41:51.596 info xmlrpc -> 192.168.178.32:2001/ init ["https://192.168.178.61:12001",""]
      HMIP
      hm-rpc.2 2018-12-02 18:41:48.608 info xmlrpc client is trying to connect to 192.168.178.32:2010/ with ["https://192.168.178.61:12010","hm-rpc.2"]
      hm-rpc.2 2018-12-02 18:41:48.604 info xmlrpc server is trying to listen on 192.168.178.61:12010
      hm-rpc.2 2018-12-02 18:41:48.199 info starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.15.0
      hm-rpc.2 2018-12-02 18:41:46.578 info xmlrpc -> 192.168.178.32:2010/ init ["https://192.168.178.61:12010",""]
      hm-rpc.2 2018-12-02 18:41:44.583 info xmlrpc -> 192.168.178.32:2010/ init ["https://192.168.178.61:12010",""]
        foxriver76F Offline
        foxriver76
        Hast du die Ports geändert? Statt den 12001 sollte es 42001 sein und statt 12010 => 42010
        Und bei den Nutzerdaten, sind die gemeint, mit denen du dich an der CCU anmeldest. Per Default gibts da den User Admin.
        • R Offline
          RolfFrie
          Ports von Wireless und HMIP sind jetzt auf 4…. geändert
          Admin-Passwort für CCU genutzt
          Leider gleiches Ergebnis
            foxriver76F Offline
            foxriver76
            Kannst du evtl mal ein Screenshot von CCU Firewall und der Instanzconfig hochladen (sensible Daten bitte unkenntlich).
            • R Offline
              RolfFrie
              IstanzConfig ? Meinst DU das:
              • system.adapter.hm-rega.0 : hm-rega - enabled
              • system.adapter.hm-rpc.0 : hm-rpc - enabled, port: 18701
              • system.adapter.hm-rpc.1 : hm-rpc - enabled, port: 42001
              • system.adapter.hm-rpc.2 : hm-rpc - enabled, port: 42010
              CCU Firewall: 7396_ccu_firewall_2018-12-03_200424.jpg
              • E Offline
                eve11
                Hallo zusammen, bei mir ist das Problem komplett dito wie bei RolfFrie.
                Im LOG keinerlei Fehlermeldungen.
                eve11
                  foxriver76F Offline
                  foxriver76
                  @RolfFrie:
                  CCU Firewall:CCU Firewall 2018-12-03 200424.jpg `
                  Gib mal bitte explizit die Vierer Ports frei in der CCU FW. Auf welcher Raspmatic Version bist du. Die vom 26.11? Ich bin mit den FW Settings noch nicht so 100 % warm geworden, anscheinend gab es auch einen kleinen bug in der vom 24.11.
                  Und nach ändern der FW Einstellungen ist ein CCU Neustart erforderlich.
                    foxriver76F Offline
                    foxriver76
                    Anbei mal Minimal Settings die bei mir funktionieren (und Auth ist an unter dem Pubkt Sicherheit). 6392_b3a37806-c8ad-4fee-8062-41b0c153b41f.jpeg
                    Wenn HM-IP genutzt wird, sollte der Port 42010 noch ergänzt werden.
                    • R Offline
                      RolfFrie
                      Hi again
                      Meine CCU Version ist 3.41.11.20181126
                      Habe jetzt so wie bei Dir alle Port-Freigane manuell eingetragen. Und es sowohl mit Ports blockiert als auch offen versucht:
                      Ergebnis:
                      Mit Ports blockiert CUXD,Wireless UND HMIP alle GELB
                      MIt Ports offen: CUXD GRÜN, aber weiterhin Wireless UND HMIP GELB
                        foxriver76F Offline
                        foxriver76
                        Und der Log sagt nach wie vor response timeout?
                        Am besten ein Screenshot der Instanz Config und sensible Sachen wie Nutzername einfach abändern oder schwärzen.
                        Also wenn der Port jetzt explizit geöffnet ist und das auch geklappt hat sollte zumindest kein response Timeouts mehr kommen.
                        • R Offline
                          RolfFrie
                          Der log ist schon länger fehlerfrei. Aber es ist halt immer ich GELB und nicht Grün.
                          Was meinst du mit Instanz konfig?
                            foxriver76F Offline
                            foxriver76
                            Die Konfigurationsseite (Instanzen - hm-rpc.X und auf das Tool dahinter geklickt) im ioB und irgendwas sollte im Log stehen, response Timeout dauert gerne etwas. Hast du die Ports der CCU irgendwie geändert/ bei dir läuft ja CuxD auch unter einem anderen als default?
                            • R Offline
                              RolfFrie
                              Tatsächlich jrtzt gibt bei beiden nur noch Fehler :
                              Init error: socket hang up
                              Also bewusst habe ich keine ports angepasst
                                foxriver76F Offline
                                foxriver76
                                @RolfFrie:
                                Also bewusst habe ich keine ports angepasst `
                                Das könnte daran liegen, wenn nutze https nicht angehakt ist in den zusätzlichen Einstellungen der Instanz. Dann versucht er ohne https zu verbinden und das geht an diesem Port nicht.
                                • R Offline
                                  RolfFrie
                                  Hier alle Seiten der Konfiguration
                                    foxriver76F Offline
                                    foxriver76
                                    Ports stimmen nicht. Habe da nochmal was gepusht, dass die Ports auf jeden Fall korrekt ausgefüllt werden in der GUI: muss 42010 und 42001 sein.
                                    • R Offline
                                      RolfFrie
                                      Aber bei mir steht doch 42001 und 42010. Was muss ich anpassen?
                                      • F Offline
                                        Flauschi
                                        nicht adapter, die müssen auf homematic so sein :)
                                          foxriver76F Offline
                                          foxriver76
                                          Flauschi hat’s schon geschrieben.
                                          Der Homematic Port muss angepasst werden.
