  4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
    6.5k
547 Beiträge 97 Kommentatoren 208.8k Aufrufe 20 Beobachtet
  • H Offline
    homecineplexx
    #108
    das ist normal beim installieren vom adapter?
    $ ./iobroker url "https://github.com/Apollon77/ioBroker.tuya"
    install https://github.com/Apollon77/ioBroker.tuya/tarball/master
    npm install https://github.com/Apollon77/ioBroker.tuya/tarball/master --production --save --prefix "/opt/iobroker" (System call)
    npm
     WARN deprecated clipboard-js@0.3.6: Please migrate to https://github.com/lgarron/clipboard-polyfill
    npm WARN deprecated bcrypt@1.0.3: bcrypt < v2.0.0 is susceptible to bcrypt wrap-around bug. Upgrade to bcrypt >= v2.0.0 for improved support for newer bcrypt hashes
    node-pre-gyp ERR! Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.3/bcrypt_lib-v1.0.3-node-v64-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for bcrypt@1.0.3 and node@10.10.0 (node-v64 ABI) (falling back to source compile with node-gyp)
    node-pre-gyp ERR! Tried to download(undefined): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.3/bcrypt_lib-v1.0.3-node-v64-linux-arm.tar.gz
    rm: das Entfernen von './Release/.deps/Release/obj.target/bcrypt_lib/src/blowfish.o.d.raw' ist nicht möglich
    : Datei oder Verzeichnis nicht gefunden
    make: *** [Release/obj.target/bcrypt_lib/src/blowfish.o] Fehler 1
    gyp
     ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
    gyp ERR! System Linux 4.14.71-v7+
    gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node" "--module_name=bcrypt_lib" "--module_path=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding"
    gyp ERR! cwd /opt/iobroker/node_modules/node-red/node_modules/bcrypt
    gyp ERR! node -v v10.10.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding' (1)
    node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:962:16)
    node-pre-gyp
    ERR! stack
         at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
    node-pre-gyp ERR! System Linux 4.14.71-v7+
    node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-red/node_modules/bcrypt
    node-pre-gyp ERR! node -v v10.10.0node-pre-gyp ERR! node-pre-gyp -v v0.6.36
    node-pre-gyp ERR! not ok
    ../src/bcrypt.cc:322:1: fatal error: opening dependency file ./Release/.deps/Release/obj.target/bcrypt_lib/src/bcrypt.o.d.raw: Datei oder Verzeichnis nicht gefunden }
    compilation terminated.
    make: *** [Release/obj.target/bcrypt_lib/src/bcrypt.o] Fehler 1
    gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR!
    stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
    gyp ERR! not ok
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/alexa-cookie/package.json'npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
    npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
    npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@1.0.3 (node_modules/node-red/node_modules/bcrypt):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@1.0.3 install: `node-pre-gyp install --fallback-to-build`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    process exited with code 0</anonymous>
    • H Offline
      homecineplexx
      #109
      @apollon77:
      Genauer Fehler bitte.
      Anyproxy global … ja kannst du, hilft aber nix weil der adapter das nicht nutzt weil seinen eigenen mitbringt.
      Gesendet vom Handy ... `
      genauer kann ichs nicht sagen, denn das ist ein kleines fenster am handy, welches sagt netzwerkfehler
      • apollon77A Offline
        #110
        @homecineplexx:
        npm
        gyp
        gyp ERR! not ok
        node-pre-gyp
        ERR! stack
        gyp ERR!
        gyp ERR! not ok
        Hm … Versuch mal mit sudo. Der bcrypt Fehler ist an sich optional ...
        Ich habe es unter node 10 noch nicht genutzt ... daher kann ich nicht sagen ob es vllt daran liegt .... hm ....
        • H Offline
          homecineplexx
          #111
          @apollon77:
          @homecineplexx:
          npm
          gyp
          gyp ERR! not ok
          node-pre-gyp
          ERR! stack
          gyp ERR!
          gyp ERR! not ok
          selbst problem
            #112
            Genug ram ist auch frei auch dem iobroker Host? Der Proxy braucht wohl eeeeeecht viel ram.
            Dann hab ich keine Idee mehr.
            Gesendet vom Handy …
            • H Offline
              homecineplexx
              #113
              @apollon77:
              Gesendet vom Handy … `
              180Mb sind frei….
              • ElzersharkE Offline
                ElzersharkE Offline
                Elzershark
                #114
                Liegt an Node 10. Zu hoch.
                6.* oder 8.* Node installieren.
                Alles lesen was da steht ab" Node installieren.."
                http://www.iobroker.net/docu/?page_id=5106&lang=de
                https://www.youtube.com/c/Elzershark
                https://t.me/joinchat/BD87n3xMU0QzYmUy
                https://www.facebook.com/elzershark
                  #115
                  Vermutung oder wissen? Was genau macht mit node 10 Probleme?
                  • H Offline
                    homecineplexx
                    #116
                    @Elzershark:
                    http://www.iobroker.net/docu/?page_id=5106&lang=de `
                    kann ich zurücksteigen auf eine 8er?
                      ElzersharkE Offline
                      Elzershark
                      #117
                      Halbwissen, Wissen, Vermutung.. Alles von allem..
                      Frage.. Wie kommt man an Node 10?
                      Upgrade? Danach auch alle Adapter neu geladen? auf Node 10 alle Adapter eingerichtet?
                      Das machen/wissen die wenigsten und nichts geht mehr.
                      Daher kann man fast nicht sagen ob es mit Node 10 geht oder nicht.
                      Außer man "weiß" wie man auf Node 10 ioBroker richtig installiert und dann Testet..
                      Dann fängt aber alles wieder wie oben an-.. xD
                        thor1967
                        #118
                        @sigi234:
                        geht auch ohne der Windows App…..
                        Screenshot (1168)_LI.jpg `
                        und wie?
                        Jörg
                        • H Offline
                          homecineplexx
                          #119
                          @Elzershark:
                          Dann fängt aber alles wieder wie oben an-.. xD `
                          Funktioniert bei mir nun auch nicht mit der 8er Version. Selber Fehler :-(
                          • sigi234S Online
                            sigi234S Online
                            #120
                            @thor1967:
                            @sigi234:
                            und wie?
                            Jörg `
                            https://github.com/Apollon77/ioBroker.t … r/PROXY.md
                              madd268hotmail.de
                              #121
                              <code>tuya.0 new Shema added for product type HPiNfakVX1Z9hWsO. Please send next line from logfile on disk to developer!
                              2018-11-14 21:43:04.500 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power3\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"延迟\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"add_ele\",\"name\":\"电量\",\"property\":{\"unit\":\"度\",\"min\":0,\"max\":500000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":3,\"type\":\"obj\",\"desc\":\"上报的为放大100倍之后的值,即上报56,实际值为0.56度\"},{\"mode\":\"ro\",\"code\":\"cur_current\",\"name\":\"电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_power\",\"name\":\"功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_voltage\",\"name\":\"电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[]"}
                              2018-11-14 21:43:04.501 - info: tuya.0 new Shema added for product type n8iVBAPLFKAAAszH. Please send next line from logfile on disk to developer!
                              2018-11-14 21:43:04.501 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_time\",\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"}]","schemaExt":"[{\"id\":2,\"inputType\":\"\"}]"}
                              2018-11-14 21:43:04.502 - info: tuya.0 new Shema added for product type ocNB89IgPygEpdnE. Please send next line from logfile on disk to developer!
                              2018-11-14 21:43:04.502 - info: tuya.0 {"schema":"[{\"mode\":\"ro\",\"code\":\"switch\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\",\"desc\":\"上报门窗开关状态\"},{\"mode\":\"ro\",\"code\":\"TamperedAlarm\",\"name\":\"防拆报警\",\"property\":{\"type\":\"bool\"},\"id\":102,\"type\":\"obj\",\"desc\":\"mcu 上报拆除信息\"},{\"mode\":\"ro\",\"code\":\"Battery\",\"name\":\"电池电量\",\"property\":{\"unit\":\"%\",\"min\":0,\"max\":100,\"scale\":0,\"step\":10,\"type\":\"value\"},\"id\":103,\"type\":\"obj\",\"desc\":\"mcu 上报电池电量信息\"},{\"mode\":\"ro\",\"code\":\"state\",\"name\":\"状态\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\",\"desc\":\"上报产品是“休眠”还是“离线”\"}]","schemaExt":"[]"}
                              2018-11-14 21:43:04.502 - info: tuya.0 new Shema added for product type PUyaDrOGMhJfCExd. Please send next line from logfile on disk to developer!
                              2018-11-14 21:43:04.503 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"add_ele\",\"name\":\"增加电量\",\"property\":{\"unit\":\"度\",\"min\":0,\"max\":50000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":3,\"trigger\":\"direct\",\"type\":\"obj\",\"desc\":\"上报的为放大1000倍之后的值,即上报56,实际值为0.056度\"},{\"mode\":\"ro\",\"code\":\"cur_current\",\"name\":\"当前电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_power\",\"name\":\"当前功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_voltage\",\"name\":\"当前电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[{\"id\":2,\"inputType\":\"\"},{\"id\":3,\"inputType\":\"\"},{\"id\":4,\"inputType\":\"\"},{\"id\":5,\"inputType\":\"\"},{\"id\":6,\"inputType\":\"\"}]"}</code>
                              • R Offline
                                RKBroker
                                #122
                                Mal wieder etwas neues:
                                <code>2018-11-15 23:56:34.240  - [32minfo[39m: tuya.0 new Shema added for product type r15JnoGqWPM4PPtl. Please send next line from logfile on disk to developer!
                                2018-11-15 23:56:34.240  - [32minfo[39m: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_1\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_time2\",\"id\":11,\"type\":\"obj\",\"desc\":\"可根据产品实际倒计时功能修改。\"}]","schemaExt":"[]"}[/code]</code>
                                • R Offline
                                  rewenode
                                  #123
                                  und noch einer:
                                  3fach Steckdosenleiste mit 4er USB
                                  https://de.aliexpress.com/item/Smart-Wi … 4c4djD7d7L
                                  <code>2018-11-16 00:28:39.644 - info: tuya.0 new Shema added for product type JtCDjzmKcUNKEBzO. Please send next line from logfile on disk to developer!
                                  2018-11-16 00:28:39.645 - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_s1\",\"name\":\"开关1\",\"property\":{\"type\":\"bool\"},\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_s2\",\"name\":\"开关 2\",\"property\":{\"type\":\"bool\"},\"id\":2,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_s3\",\"name\":\"开关 3\",\"property\":{\"type\":\"bool\"},\"id\":3,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_usb1\",\"name\":\"USB\",\"property\":{\"type\":\"bool\"},\"id\":4,\"type\":\"obj\",\"desc\":\"switch_s4修改为switch_usb1\"}]","schemaExt":"[]"}[/code]</code>
                                    #124
                                    Danke, sind jetzt alle in der 1.0.4 drin.
                                    • sigi234S Online
                                      sigi234S Online
                                      #125
                                      Hallo Apollon77,
                                      Nächste Woche bekomme ich wieder ein Spielzeug für die Weihnachtsbeleuchtung…...
                                      Ich hoffe sie funktioniert mit deinen Adapter. :)
                                      Heute bekommen, Funktioniert!
                                        #126
                                        Gute Chancen ;-)
                                          ElzersharkE Offline
                                          Elzershark
                                          #127
                                          Die Steckdose funzt. Hab die installiert. Die müsste auch schon integriert sein, da ich kein neues schema bekomme
