  4. Radar Adapter terminiert gleich wieder
28 Beiträge 6 Kommentatoren 4.0k Aufrufe 1 Beobachtet
    daniello
    Hmm .. mein ioBroker läuft im Docker auf NUC. Weiß weder ob BT an ist oder ob Radar in der Lage ist den BT-Stack auf NUC anzusprechen.
    Oder liegt der Hase vielleicht woanders im Pfeffer? VG
    host.ioBroker	2018-10-26 12:46:26.535	error	instance system.adapter.radar.0 terminated with code null ()
    host.ioBroker	2018-10-26 12:46:26.534	warn	instance system.adapter.radar.0 terminated due to SIGSEGV
    radar.0	2018-10-26 12:46:20.304	info	Init item sonoff-garage with { name: 'sonoff-garage', ip: '192.168.xx.xx', macs: '60:01:94:A3:XX:81', bluetooth: '', id: 'sonoff-garage', hasMAC: [ '60:01:94:A3:XX:81' ], hasBT: false,
    radar.0	2018-10-26 12:46:18.048	info	BT Bin Dir = '/opt/iobroker/node_modules/iobroker.radar\bin\bluetoothview\'
    radar.0	2018-10-26 12:46:18.048	info	radar set to scan every 60 sec and printers every 500 scans.
    radar.0	2018-10-26 12:46:18.048	info	starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.radar, node: v8.12.0
    host.ioBroker	2018-10-26 12:46:17.604	info	instance system.adapter.radar.0 started with pid 28673
    host.ioBroker	2018-10-26 12:45:47.599	info	Restart adapter system.adapter.radar.0 because enabled
    host.ioBroker	2018-10-26 12:45:47.599	error	instance system.adapter.radar.0 terminated with code null ()
    host.ioBroker	2018-10-26 12:45:47.599	warn	instance system.adapter.radar.0 terminated due to SIGABRT
    host.ioBroker	2018-10-26 12:45:47.598	error	Caught by controller[0]: 0: ../deps/uv/src/unix/poll.c:120: uv_poll_start: Assertion `!(((handle)->flags & (UV_CLOSING | UV_CLOSED)) != 0)' failed.
    radar.0	2018-10-26 12:45:46.352	info	Init item sonoff-garage with { name: 'sonoff-garage', ip: '192.168.xx.xx', macs: '60:01:94:A3:XX:81', bluetooth: '', id: 'sonoff-garage', hasMAC: [ '60:01:94:A3:XX:81' ], hasBT: false,
    radar.0	2018-10-26 12:45:44.117	info	BT Bin Dir = '/opt/iobroker/node_modules/iobroker.radar\bin\bluetoothview\'
    radar.0	2018-10-26 12:45:44.117	info	radar set to scan every 60 sec and printers every 500 scans.
    radar.0	2018-10-26 12:45:44.116	info	starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.radar, node: v8.12.0
    host.ioBroker	2018-10-26 12:45:43.674	info	instance system.adapter.radar.0 started with pid 28656
    host.ioBroker	2018-10-26 12:45:13.667	info	Restart adapter system.adapter.radar.0 because enabled
    • apollon77A Offline
      Segmentation Fault ist eine Speicherverletzung im Prozess.
      Versuch mal eine Neuinstallation bzw starte den Adapter an der Kommandozeile und gibts es vllt mehr Logs
        daniello
        War ganz frisch installiert .. lief noch nie.
        Also ein Adapter-Restart aus der Shell .. dann such ich mal den Befehl :-)
          node /op7/iobroker/node_modules/iobroker.radar/radar.js –force --logs
          (oder main.ja habs nicht im kopf)
            daniello
            Dankeschön :-) .. glaube aber nicht, dass das die erwartete Ausgabe ist.
            TypeError: Cannot read property 'warn' of undefined
                at _W (/opt/iobroker/node_modules/iobroker.radar/radar.js:42:17)
                at stop (/opt/iobroker/node_modules/iobroker.radar/radar.js:154:5)
                at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.radar/radar.js:164:28)
                at emitOne (events.js:116:13)
                at Adapter.emit (events.js:211:7)
                at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5033:18)
                at Object.onceWrapper (events.js:315:30)
                at process.emit (events.js:211:7)
                at process.exit (internal/process.js:146:15)
              Du sagtest jungfräulich und noch ncie genutzt? Aber konfiguriert hast Du es? Mal so mindestens ein Device eingetragen?
                daniello
                Ja .. das ist richtig .. aber noch nie korrekt durchgestartet. Das IF ist mir auch nicht so ganz klar .. die umrahmten Felder scheinen zur Suche zu sein und nicht zur Eingabe .. irgendwie hab ich's dann hinbekommen dass ein Device eingetragen ist.
                  daniello
                  mit main.js
                  module.js:550
                      throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.radar/main.js'
                      at Function.Module._resolveFilename (module.js:548:15)
                      at Function.Module._load (module.js:475:25)
                      at Function.Module.runMain (module.js:694:10)
                      at startup (bootstrap_node.js:204:16)
                      at bootstrap_node.js:625:3
                    daniello
                    @apollon77
                    Du kannst zaubern .. grad schweift mein Blick über die Instanzen RADAR GRÜN .. offenbar hat das neu Starten aus der Schell irgendwas gute bewirkt.
                    Außer einer External Network IP wird allerdings nichts angezeigt .. hätte jetze einen Node erwartet mit meinem einen eingetragenen Gerät.
                      daniello
                      Hab die Instanz nochmal frisch gemacht .. noch immer kein Objekt zu sehen das ich auswerten könnte?!
                        Und wie siehst die Konfig aus?
                          daniello
                          so ..
                            daniello
                            Bleibt grün .. schaut aber weiterhin nicht so gut aus …
                            host.ioBroker	2018-10-28 18:55:40.425	error	instance system.adapter.radar.0 terminated with code null ()
                            host.ioBroker	2018-10-28 18:55:40.425	warn	instance system.adapter.radar.0 terminated due to SIGABRT
                            Caught	2018-10-28 18:55:40.425	error	by controller[0]: 0: ../deps/uv/src/unix/core.c:883: uv__io_stop: Assertion `w->fd >= 0' failed.
                            radar.0	2018-10-28 18:55:40.412	info	radar adapter initialized 1 devices, ExternalNetwork = 300.
                            radar.0	2018-10-28 18:55:39.618	info	New IP address 5.147.2.178
                            radar.0	2018-10-28 18:55:39.227	info	MyIP Error { Error: connect ETIMEDOUT 198.27.74.146:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1191:14) errno: 'ETIMEDOUT', code: 'ETIMEDOUT', syscall: 'connect', address:
                            radar.0	2018-10-28 18:49:07.120	info	Init item sonoff-garage with { name: 'sonoff-garage', ip: '192.168.xx.6xx2', macs: '60:01:94:A3:xx:xx', bluetooth: '', id: 'sonoff-garage', hasMAC: [ '60:01:94:A3:61:81' ], hasBT: false,
                            radar.0	2018-10-28 18:49:04.836	info	BT Bin Dir = '/opt/iobroker/node_modules/iobroker.radar\bin\bluetoothview\'
                            radar.0	2018-10-28 18:49:04.836	info	radar set to scan every 60 sec and printers every 500 scans.
                            radar.0	2018-10-28 18:49:04.816	info	starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.radar, node: v8.12.0
                            host.ioBroker	2018-10-28 18:49:04.411	info	instance system.adapter.radar.0 started with pid 9712
                            host.ioBroker	2018-10-28 18:48:34.405	info	Restart adapter system.adapter.radar.0 because enabled
                            host.ioBroker	2018-10-28 18:48:34.404	error	instance system.adapter.radar.0 terminated with code null ()
                              daniello
                              Keiner eine Idee? VG
                                irgendwas ist mit libuv … kannst mal mit der meldung googeln ob es ewas gibt.
                                Linux ist aktuell? Kernel? Alle Updates?
                                Ingo F
                                  daniello
                                  Muss ich heute abend mal schauen .. ist ein Debian Docker auf Proxmox.
                                    Unter welchem user läuft iobroker? Root oder ein echter user? Weiss gerade nicht was radar braucht, aberwäre vllt auch ein Ansatz
                                      daniello
                                      Hmmm .. hab a nichts explizit eingeschränkt .. und unter Root installiert .. insofern sollte es Root sein?!
                                        daniello
                                        Nichts gemacht .. auf einmal hab ich Ojekte und auch Wetter und so. Merkwürdig .. was hat es eigentlich mit dieser externen IP auf sich?
                                          daniello
                                          hab grad mal
                                          apt-get install libuv1
                                          nachinstalliert .. mal gucken wie es sich mit dem Log jetzt verhält.
                                          bleibt aber hierbei:
                                          host.ioBroker	2018-11-02 15:46:56.113	info	Restart adapter system.adapter.radar.0 because enabled
                                          host.ioBroker	2018-11-02 15:46:56.113	error	instance system.adapter.radar.0 terminated with code null ()
                                          host.ioBroker	2018-11-02 15:46:56.113	warn	instance system.adapter.radar.0 terminated due to SIGSEGV
                                          und
                                          host.ioBroker	2018-11-02 15:54:02.120	info	Restart adapter system.adapter.radar.0 because enabled
                                          host.ioBroker	2018-11-02 15:54:02.120	error	instance system.adapter.radar.0 terminated with code null ()
                                          host.ioBroker	2018-11-02 15:54:02.120	warn	instance system.adapter.radar.0 terminated due to SIGABRT
                                          host.ioBroker	2018-11-02 15:54:02.120	error	Caught by controller[0]: 0: ../deps/uv/src/unix/poll.c:120: uv_poll_start: Assertion `!(((handle)->flags & (UV_CLOSING | UV_CLOSED)) != 0)' failed.
