  4. Bekomme Noble nicht richtig installiert.
24 Beiträge 2 Kommentatoren 4.6k Aufrufe
    Belei
    Ich habs jetzt mal im RFLINK Ordner gemacht, jetzt läuft der auch wieder ;)
      Belei
      Aktuelle Fehlermeldung beim starten des Zigbee Adapters:
      host.ioBroker-Pi3	2018-10-26 14:02:38.958	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.ioBroker-Pi3	2018-10-26 14:02:38.958	error	instance system.adapter.zigbee.0 terminated with code 1 ()
      Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
      Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Module._compile (module.js:653:30)
      Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
      Caught	2018-10-26 14:02:38.958	error	by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at require (internal/module.js:11:18)
      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Module.require (module.js:597:17)
      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Function.Module._load (module.js:498:3)
      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at tryModuleLoad (module.js:506:12)
      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Module.load (module.js:566:32)
      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Object.Module._extensions..node (module.js:682:18)
      Caught	2018-10-26 14:02:38.956	error	by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      Caught	2018-10-26 14:02:38.956	error	by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
      Caught	2018-10-26 14:02:38.956	error	by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
      Caught	2018-10-26 14:02:38.956	error	by controller[0]: was compiled against a different Node.js version using
      Caught	2018-10-26 14:02:38.956	error	by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
      Caught	2018-10-26 14:02:38.956	error	by controller[0]: ^
      Caught	2018-10-26 14:02:38.955	error	by controller[0]: throw e
      Caught	2018-10-26 14:02:38.955	error	by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
      host.ioBroker-Pi3	2018-10-26 14:02:37.949	info	instance system.adapter.zigbee.0 started with pid 929</anonymous>
      npm im Zigbee Ordner Ergebniss:
      pi@ioBroker-Pi3:/opt/iobroker/node_modules/iobroker.zigbee $ npm rebuild
      debug@3.2.6 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/debug
      ms@2.1.1 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/ms
      npm im /opt/iobroker/node_modules/serialport/node_modules/bindings
      keine Reaktion
      npm rebuild im /opt/iobroker/node_modules/serialport/build/Release
      pi@ioBroker-Pi3:/opt/iobroker/node_modules/serialport/build/Release $ npm rebuild
      bindings@1.3.0 /opt/iobroker/node_modules/serialport/node_modules/bindings
      debug@3.2.5 /opt/iobroker/node_modules/serialport/node_modules/debug
      ms@2.1.1 /opt/iobroker/node_modules/serialport/node_modules/ms
      nan@2.11.0 /opt/iobroker/node_modules/serialport/node_modules/nan
      prebuild-install@4.0.0 /opt/iobroker/node_modules/serialport/node_modules/prebuild-install
      minimist@1.2.0 /opt/iobroker/node_modules/serialport/node_modules/minimist
      prompt-list@3.2.0 /opt/iobroker/node_modules/serialport/node_modules/prompt-list
      safe-buffer@5.1.2 /opt/iobroker/node_modules/serialport/node_modules/safe-buffer
      Im Zigbee Adapter ist nicht der USB anschluss zur auswahl vorhanden somit bleibt der Bursche rot
      • apollon77A Offline
        Fürhre das rebuild mal eher in
        aus
          Belei
          Dann kommt
          pi@ioBroker-Pi3:/opt/iobroker/node_modules/serialport $ npm rebuild
          Aber der Fehler im Log ist immer noch da und adapter bleibt rot!
            dann such mal ob in node_modules des Adapters selbst ggf nochmal ein serialport drin ist
              Belei
              Nichts zu finden. Nur debug und ms
              Auch eine neuinstallation von zigbee hat nix gebracht.
                ich meine in /opt/iobroker/node_modules
                  Belei
                  Da gibts nur ein serialport
                    Dann kann ich nur sagen: lösch den serialport malund installiere adapter nochmal. Dann wäre ich am Ende der Ideen
                      Belei
                      öhmm also den Ordner Serialport löschen und dann zigbee adapter neuinstallieren?
                      installiert der dan den serialport wieder mit?
                      Gleich fliegt das Ding aus dem Fenster... Jetzt geht wieder gar nix... nach folgender Aktion:
                      sudo apt-get update
                      sudo apt-get install build-essential git
                      cd /opt/iobroker
                      npm install iobroker.Zigbee
                      http://www.iobroker.net/docu/?page_id=5510&lang=de
                      Jetzt startet io nicht mehr….
                      pi@ioBroker-Pi3:~ $ iobroker start
                      module.js:550
                          throw err;
                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                          at Function.Module._resolveFilename (module.js:548:15)
                          at Function.Module._load (module.js:475:25)
                          at Function.Module.runMain (module.js:694:10)
                          at startup (bootstrap_node.js:204:16)
                          at bootstrap_node.js:625:3
                        Belei
                        Ich habe ein Backup eingespielt, und die ganzen rebuilds nochmal gemacht, diesmal immer den betreffenden adapter vorher ausgeschaltet.
                        Jetzt läuft es wieder und siehe da:
                        RADAR erkennt endlich auch meine beiden BT Anhänger und auch diverse Unknown Devices :P
                        Noble wird auch als aktiv angezeigt und ich bin auf
                        Node.js: v8.12.0
                        NPM: 6.4.1
                        Sind die Versionen OK?
                        PUH was ein Krampf wird Zeit für eine Virtuelle Umgebung um mal eben was zu testen :lol:
                        Danke an apollon77 ;)
                          Komischer Tag heute :-)
                          Ja die Versionen sind perfekt so
