  4. Bekomme Noble nicht richtig installiert.
24 Beiträge 2 Kommentatoren 4.6k Aufrufe
  • apollon77A Offline
    Und tuts?
      Belei
      Ich habs jetzt mal im RFLINK Ordner gemacht, jetzt läuft der auch wieder ;)
        Belei
        Aktuelle Fehlermeldung beim starten des Zigbee Adapters:
        host.ioBroker-Pi3	2018-10-26 14:02:38.958	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.ioBroker-Pi3	2018-10-26 14:02:38.958	error	instance system.adapter.zigbee.0 terminated with code 1 ()
        Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
        Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Module._compile (module.js:653:30)
        Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
        Caught	2018-10-26 14:02:38.958	error	by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
        Caught	2018-10-26 14:02:38.957	error	by controller[0]: at require (internal/module.js:11:18)
        Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Module.require (module.js:597:17)
        Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Function.Module._load (module.js:498:3)
        Caught	2018-10-26 14:02:38.957	error	by controller[0]: at tryModuleLoad (module.js:506:12)
        Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Module.load (module.js:566:32)
        Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Object.Module._extensions..node (module.js:682:18)
        Caught	2018-10-26 14:02:38.956	error	by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        Caught	2018-10-26 14:02:38.956	error	by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
        Caught	2018-10-26 14:02:38.956	error	by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
        Caught	2018-10-26 14:02:38.956	error	by controller[0]: was compiled against a different Node.js version using
        Caught	2018-10-26 14:02:38.956	error	by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
        Caught	2018-10-26 14:02:38.956	error	by controller[0]: ^
        Caught	2018-10-26 14:02:38.955	error	by controller[0]: throw e
        Caught	2018-10-26 14:02:38.955	error	by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
        host.ioBroker-Pi3	2018-10-26 14:02:37.949	info	instance system.adapter.zigbee.0 started with pid 929</anonymous>
        npm im Zigbee Ordner Ergebniss:
        pi@ioBroker-Pi3:/opt/iobroker/node_modules/iobroker.zigbee $ npm rebuild
        debug@3.2.6 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/debug
        ms@2.1.1 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/ms
        npm im /opt/iobroker/node_modules/serialport/node_modules/bindings
        keine Reaktion
        npm rebuild im /opt/iobroker/node_modules/serialport/build/Release
        pi@ioBroker-Pi3:/opt/iobroker/node_modules/serialport/build/Release $ npm rebuild
        bindings@1.3.0 /opt/iobroker/node_modules/serialport/node_modules/bindings
        debug@3.2.5 /opt/iobroker/node_modules/serialport/node_modules/debug
        ms@2.1.1 /opt/iobroker/node_modules/serialport/node_modules/ms
        nan@2.11.0 /opt/iobroker/node_modules/serialport/node_modules/nan
        prebuild-install@4.0.0 /opt/iobroker/node_modules/serialport/node_modules/prebuild-install
        minimist@1.2.0 /opt/iobroker/node_modules/serialport/node_modules/minimist
        prompt-list@3.2.0 /opt/iobroker/node_modules/serialport/node_modules/prompt-list
        safe-buffer@5.1.2 /opt/iobroker/node_modules/serialport/node_modules/safe-buffer
        Im Zigbee Adapter ist nicht der USB anschluss zur auswahl vorhanden somit bleibt der Bursche rot
          Fürhre das rebuild mal eher in
          aus
            Belei
            Dann kommt
            pi@ioBroker-Pi3:/opt/iobroker/node_modules/serialport $ npm rebuild
            Aber der Fehler im Log ist immer noch da und adapter bleibt rot!
              dann such mal ob in node_modules des Adapters selbst ggf nochmal ein serialport drin ist
                Belei
                Nichts zu finden. Nur debug und ms
                Auch eine neuinstallation von zigbee hat nix gebracht.
                  ich meine in /opt/iobroker/node_modules
                    Belei
                    Da gibts nur ein serialport
                      Dann kann ich nur sagen: lösch den serialport malund installiere adapter nochmal. Dann wäre ich am Ende der Ideen
                        Belei
                        öhmm also den Ordner Serialport löschen und dann zigbee adapter neuinstallieren?
                        installiert der dan den serialport wieder mit?
                        Gleich fliegt das Ding aus dem Fenster... Jetzt geht wieder gar nix... nach folgender Aktion:
                        sudo apt-get update
                        sudo apt-get install build-essential git
                        cd /opt/iobroker
                        npm install iobroker.Zigbee
                        http://www.iobroker.net/docu/?page_id=5510&lang=de
                        Jetzt startet io nicht mehr….
                        pi@ioBroker-Pi3:~ $ iobroker start
                        module.js:550
                            throw err;
                        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                            at Function.Module._resolveFilename (module.js:548:15)
                            at Function.Module._load (module.js:475:25)
                            at Function.Module.runMain (module.js:694:10)
                            at startup (bootstrap_node.js:204:16)
                            at bootstrap_node.js:625:3
                          Belei
                          Ich habe ein Backup eingespielt, und die ganzen rebuilds nochmal gemacht, diesmal immer den betreffenden adapter vorher ausgeschaltet.
                          Jetzt läuft es wieder und siehe da:
                          RADAR erkennt endlich auch meine beiden BT Anhänger und auch diverse Unknown Devices :P
                          Noble wird auch als aktiv angezeigt und ich bin auf
                          Node.js: v8.12.0
                          NPM: 6.4.1
                          Sind die Versionen OK?
                          PUH was ein Krampf wird Zeit für eine Virtuelle Umgebung um mal eben was zu testen :lol:
                          Danke an apollon77 ;)
                            Komischer Tag heute :-)
                            Ja die Versionen sind perfekt so
