  4. IoBroker mach nur noch Probleme
46 Beiträge 6 Kommentatoren 7.6k Aufrufe
  • E Offline
    Elektroman
    Erst einmal vielen dank für die Antworten!
    1. Mittlere Host ist der NAS " Marvell PJ4Bv7 Processor " (Funktionierte auch lange Zeit Gut)
    2. Ja habe alles und in jeder Art und Weise neu gestartet
    3. Master ist der raspberrypi, Nasserver und ioBroker-Pi3-slave-sw sind die Slaves
    • E Offline
      Elektroman
      hier noch mal der Log von heute
      2018-10-07 07:35:52.639 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
      2018-10-07 07:35:52.659 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2018-10-07 07:35:52.660 - info: host.raspberrypi hostname: raspberrypi, node: v8.11.4
      2018-10-07 07:35:52.671 - info: host.raspberrypi ip addresses: 192.168.168.222 fe80::8bcf:e410:ed6f:584a
      2018-10-07 07:35:54.169 - info: host.raspberrypi inMem-states listening on port 9000
      2018-10-07 07:36:06.112 - info: host.raspberrypi inMem-objects listening on port 9001
      2018-10-07 07:36:06.156 - info: host.raspberrypi InMemoryDB connected
      2018-10-07 07:36:06.484 - info: host.raspberrypi 61 instances found
      2018-10-07 07:36:06.564 - info: host.raspberrypi starting 4 instances
      2018-10-07 07:36:06.792 - info: host.raspberrypi instance system.adapter.admin.11 started with pid 1159
      2018-10-07 07:36:10.620 - info: host.raspberrypi instance system.adapter.email.0 started with pid 1165
      2018-10-07 07:36:15.026 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 1173
      2018-10-07 07:36:16.012 - info: email.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.4
      2018-10-07 07:36:21.479 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1183
      2018-10-07 07:36:24.202 - error: harmony.0 no connection to objects DB
      2018-10-07 07:36:27.802 - info: admin.11 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 07:36:28.501 - info: admin.11 requesting all states
      2018-10-07 07:36:28.509 - info: admin.11 requesting all objects
      2018-10-07 07:36:28.513 - info: admin.11 Request actual repository...
      2018-10-07 07:36:34.914 - error: zigbee.0 no connection to objects DB
      2018-10-07 07:36:38.374 - info: harmony.0 starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.11.4
      2018-10-07 07:36:38.424 - info: harmony.0 searching for Harmony Hubs...
      2018-10-07 07:36:39.760 - info: harmony.0 discovered Remote-Hub-Wohnzimmer
      2018-10-07 07:36:43.109 - error: zigbee.0 no connection to states DB: Connection timeout
      2018-10-07 07:37:28.773 - warn: harmony.0 Reconnection to DB.
      2018-10-07 07:37:28.779 - warn: harmony.0 Reconnection to DB.
      2018-10-07 07:37:29.392 - error: email.0 already running
      2018-10-07 07:37:29.398 - error: harmony.0 already running
      2018-10-07 07:37:29.799 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (Adapter already running)
      2018-10-07 07:37:29.800 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
      2018-10-07 07:37:29.898 - error: host.raspberrypi instance system.adapter.harmony.0 terminated with code 7 (Adapter already running)
      2018-10-07 07:37:29.899 - info: host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
      2018-10-07 07:37:30.153 - info: zigbee.0 starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.11.4
      2018-10-07 07:37:30.165 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1CD67-if00 with panID 6754 channel 11
      2018-10-07 07:37:30.365 - info: zigbee.0 starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.11.4
      2018-10-07 07:37:30.369 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1CD67-if00 with panID 6754 channel 11
      2018-10-07 07:37:31.018 - error: zigbee.0 uncaught exception: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js-controller/../../iobroker-data/zigbee_0/shepherd.db~' -> '/opt/iobroker/node_modules/iobroker.js-controller/../../iobroker-data/zigbee_0/shepherd.db'
      2018-10-07 07:37:31.019 - error: zigbee.0 Error: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js-controller/../../iobroker-data/zigbee_0/shepherd.db~' -> '/opt/iobroker/node_modules/iobroker.js-controller/../../iobroker-data/zigbee_0/shepherd.db'
      2018-10-07 07:37:31.029 - info: zigbee.0 zigbee-shepherd stopped
      2018-10-07 07:37:31.058 - info: zigbee.0 terminating
      2018-10-07 07:37:31.255 - error: Caught by controller[0]: Sun, 07 Oct 2018 07:37:30 GMT zigbee-shepherd:init zigbee-shepherd booting...
      2018-10-07 07:37:31.256 - error: Caught by controller[0]: Sun, 07 Oct 2018 07:37:30 GMT cc-znp The serialport /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1CD67-if00 is opened.
      2018-10-07 07:37:31.256 - error: Caught by controller[0]: Sun, 07 Oct 2018 07:37:30 GMT zigbee-shepherd:request REQ --> SYS:osalNvRead
      2018-10-07 07:37:31.256 - error: Caught by controller[0]: Sun, 07 Oct 2018 07:37:30 GMT cc-znp:SREQ --> SYS:osalNvRead, { id: 3840, offset: 0, len: 1, value: [ 85 ] }
      2018-10-07 07:37:31.257 - error: Caught by controller[0]: Sun, 07 Oct 2018 07:37:30 GMT zigbee-shepherd:init zigbee-shepherd booting...
      2018-10-07 07:37:31.257 - error: Caught by controller[0]: Sun, 07 Oct 2018 07:37:30 GMT zigbee:controller debug Error while starting zigbee-shepherd, attemping to fix... (takes 60 seconds) undefined
      2018-10-07 07:37:31.257 - error: Caught by controller[0]: { Error: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js-controller/../../iobroker-data/zigbee_0/shepherd.db~' -> '/opt/iobroker/node_modules/iobroker.js-controller/../../iobroker-data/zigbee_0/shepherd.db'
      2018-10-07 07:37:31.258 - error: Caught by controller[0]: errno: -2,
      2018-10-07 07:37:31.258 - error: Caught by controller[0]: code: 'ENOENT',
      2018-10-07 07:37:31.258 - error: Caught by controller[0]: syscall: 'rename',
      2018-10-07 07:37:31.259 - error: Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.js-controller/../../iobroker-data/zigbee_0/shepherd.db~',
      2018-10-07 07:37:31.259 - error: Caught by controller[0]: dest: '/opt/iobroker/node_modules/iobroker.js-controller/../../iobroker-data/zigbee_0/shepherd.db' }
      2018-10-07 07:37:31.259 - error: Caught by controller[0]: Sun, 07 Oct 2018 07:37:31 GMT zigbee:controller info zigbee-shepherd stopped undefined
      2018-10-07 07:37:31.260 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 0 (OK)
      2018-10-07 07:37:31.260 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2018-10-07 07:37:31.537 - warn: admin.11 Reconnection to DB.
      2018-10-07 07:37:31.553 - warn: admin.11 Reconnection to DB.
      2018-10-07 07:37:33.586 - error: admin.11 already running
      2018-10-07 07:37:33.668 - error: host.raspberrypi instance system.adapter.admin.11 terminated with code 7 (Adapter already running)
      2018-10-07 07:37:33.669 - info: host.raspberrypi Restart adapter system.adapter.admin.11 because enabled
      2018-10-07 07:37:59.848 - info: host.raspberrypi instance system.adapter.email.0 started with pid 1255
      2018-10-07 07:37:59.960 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 1261
      2018-10-07 07:38:01.357 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1267
      2018-10-07 07:38:03.230 - info: email.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.4
      2018-10-07 07:38:05.067 - info: host.raspberrypi instance system.adapter.admin.11 started with pid 1277
      2018-10-07 07:38:05.948 - info: harmony.0 starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.11.4
      2018-10-07 07:38:06.020 - info: harmony.0 searching for Harmony Hubs...
      2018-10-07 07:38:05.978 - info: zigbee.0 starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.11.4
      2018-10-07 07:38:07.310 - info: harmony.0 discovered Remote-Hub-Wohnzimmer
      2018-10-07 07:38:06.004 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1CD67-if00 with panID 6754 channel 11
      2018-10-07 07:38:11.989 - info: zigbee.0 zigbee-shepherd started!
      2018-10-07 07:38:12.003 - info: zigbee.0 zigbee-shepherd ready
      2018-10-07 07:38:12.022 - info: zigbee.0 (0x00158d0001e148e6): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      2018-10-07 07:38:14.570 - error: admin.11 no connection to objects DB
      2018-10-07 07:38:15.346 - info: harmony.0 connecting to Remote-Hub-Wohnzimmer
      2018-10-07 07:38:16.898 - info: admin.11 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 07:38:17.415 - info: admin.11 requesting all states
      2018-10-07 07:38:17.424 - info: admin.11 requesting all objects
      2018-10-07 07:38:17.441 - info: admin.11 Request actual repository...
      2018-10-07 07:38:17.797 - info: harmony.0 connected to Remote-Hub-Wohnzimmer
      2018-10-07 07:38:18.900 - info: harmony.0 synced hub config
      2018-10-07 07:38:39.381 - info: admin.11 received all states
      2018-10-07 07:38:51.898 - warn: admin.11 Reconnection to DB.
      2018-10-07 07:38:51.907 - warn: admin.11 Reconnection to DB.
      2018-10-07 07:40:15.502 - info: host.raspberrypi object change system.adapter.admin.12
      2018-10-07 07:40:30.048 - error: admin.11 already running
      2018-10-07 07:40:30.558 - error: host.raspberrypi instance system.adapter.admin.11 terminated with code 7 (Adapter already running)
      2018-10-07 07:40:30.559 - info: host.raspberrypi Restart adapter system.adapter.admin.11 because enabled
      2018-10-07 07:40:59.402 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2018-10-07 07:41:01.350 - info: host.raspberrypi instance system.adapter.admin.11 started with pid 1312
      2018-10-07 07:41:09.754 - info: admin.11 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 07:41:10.031 - info: admin.11 requesting all states
      2018-10-07 07:41:10.037 - info: admin.11 requesting all objects
      2018-10-07 07:41:10.040 - info: admin.11 Request actual repository...
      2018-10-07 07:41:27.197 - warn: host.raspberrypi some hosts are offline
      2018-10-07 07:41:42.361 - warn: email.0 Reconnection to DB.
      2018-10-07 07:41:42.368 - warn: email.0 Reconnection to DB.
      2018-10-07 07:41:42.386 - warn: zigbee.0 Reconnection to DB.
      2018-10-07 07:41:42.391 - warn: harmony.0 Reconnection to DB.
      2018-10-07 07:41:42.399 - warn: harmony.0 Reconnection to DB.
      2018-10-07 07:41:42.398 - warn: zigbee.0 Reconnection to DB.
      2018-10-07 07:41:42.430 - warn: admin.11 Reconnection to DB.
      2018-10-07 07:41:42.438 - warn: admin.11 Reconnection to DB.
      2018-10-07 07:41:42.567 - error: email.0 already running
      2018-10-07 07:41:42.626 - error: zigbee.0 already running
      2018-10-07 07:41:42.641 - error: harmony.0 already running
      2018-10-07 07:41:43.201 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (Adapter already running)
      2018-10-07 07:41:43.202 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
      2018-10-07 07:41:43.257 - error: host.raspberrypi instance system.adapter.harmony.0 terminated with code 7 (Adapter already running)
      2018-10-07 07:41:43.257 - info: host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
      2018-10-07 07:41:43.311 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
      2018-10-07 07:41:43.312 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2018-10-07 07:41:43.426 - error: admin.11 already running
      2018-10-07 07:41:45.937 - error: host.raspberrypi instance system.adapter.admin.11 terminated with code 7 (Adapter already running)
      2018-10-07 07:41:45.938 - info: host.raspberrypi Restart adapter system.adapter.admin.11 because enabled
      2018-10-07 07:42:17.923 - info: host.raspberrypi instance system.adapter.email.0 started with pid 1324
      2018-10-07 07:42:18.025 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 1330
      2018-10-07 07:42:18.127 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1335
      2018-10-07 07:42:18.237 - info: host.raspberrypi instance system.adapter.admin.11 started with pid 1341
      2018-10-07 07:42:25.888 - info: email.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.4
      2018-10-07 07:42:28.082 - info: harmony.0 starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.11.4
      2018-10-07 07:42:28.202 - info: harmony.0 searching for Harmony Hubs...
      2018-10-07 07:42:28.075 - info: zigbee.0 starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.11.4
      2018-10-07 07:42:28.150 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1CD67-if00 with panID 6754 channel 11
      2018-10-07 07:42:29.188 - info: admin.11 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 07:42:29.490 - info: harmony.0 discovered Remote-Hub-Wohnzimmer
      2018-10-07 07:42:29.550 - info: admin.11 requesting all states
      2018-10-07 07:42:29.577 - info: admin.11 requesting all objects
      2018-10-07 07:42:29.592 - info: admin.11 Request actual repository...
      2018-10-07 07:42:29.747 - info: zigbee.0 zigbee-shepherd started!
      2018-10-07 07:42:29.764 - info: zigbee.0 zigbee-shepherd ready
      2018-10-07 07:42:29.782 - info: zigbee.0 (0x00158d0001e148e6): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      2018-10-07 07:42:35.071 - info: harmony.0 connecting to Remote-Hub-Wohnzimmer
      2018-10-07 07:42:37.629 - info: harmony.0 connected to Remote-Hub-Wohnzimmer
      2018-10-07 07:42:38.710 - info: harmony.0 synced hub config
      2018-10-07 07:42:56.704 - warn: admin.11 Reconnection to DB.
      2018-10-07 07:42:56.752 - warn: admin.11 Reconnection to DB.
      2018-10-07 07:43:05.973 - error: admin.11 already running
      2018-10-07 07:43:06.471 - error: host.raspberrypi instance system.adapter.admin.11 terminated with code 7 (Adapter already running)
      2018-10-07 07:43:06.473 - info: host.raspberrypi Restart adapter system.adapter.admin.11 because enabled
      2018-10-07 07:43:26.997 - warn: host.raspberrypi too delayed answer for ioBroker-Pi3-slave-sw
      2018-10-07 07:43:37.199 - info: host.raspberrypi instance system.adapter.admin.11 started with pid 1365
      2018-10-07 07:43:42.357 - info: admin.11 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 07:43:42.719 - info: admin.11 requesting all states
      2018-10-07 07:43:42.727 - info: admin.11 requesting all objects
      2018-10-07 07:43:42.731 - info: admin.11 Request actual repository...
      2018-10-07 07:43:56.786 - info: admin.11 received all states
      2018-10-07 07:44:07.512 - info: admin.11 received all objects
      2018-10-07 07:44:08.153 - info: admin.11 http server listening on port 8086
      2018-10-07 07:44:08.154 - info: admin.11 Use link "http://localhost:8086" to configure.
      2018-10-07 07:44:08.613 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2018-10-07 07:44:13.547 - info: admin.11 Repository received successfully.
      2018-10-07 08:04:20.829 - info: host.raspberrypi object change system.adapter.admin.13
      2018-10-07 08:07:01.524 - warn: admin.11 Reconnection to DB.
      2018-10-07 08:07:01.552 - warn: admin.11 Reconnection to DB.
      2018-10-07 08:07:02.028 - error: admin.11 already running
      2018-10-07 08:07:02.209 - error: host.raspberrypi instance system.adapter.admin.11 terminated with code 7 (Adapter already running)
      2018-10-07 08:07:02.210 - info: host.raspberrypi Restart adapter system.adapter.admin.11 because enabled
      2018-10-07 08:07:32.661 - error: uncaught exception: spawn ENOMEM
      2018-10-07 08:07:32.914 - info: harmony.0 terminating
      2018-10-07 08:07:33.007 - info: zigbee.0 zigbee-shepherd stopped
      2018-10-07 08:07:33.354 - error: harmony.0 websocket error
      2018-10-07 08:07:33.434 - error: zigbee.0 websocket error
      2018-10-07 08:07:33.473 - error: zigbee.0 Error: websocket error
      at WS.Transport.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:64:13)
      at WebSocket.ws.onerror (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:150:10)
      at WebSocket.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/EventTarget.js:109:16)
      at emitOne (events.js:116:13)
      at WebSocket.emit (events.js:211:7)
      at WebSocket.finalize (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:182:41)
      at Socket.emit (events.js:211:7)
      at onwriteError (_stream_writable.js:418:12)
      at onwrite (_stream_writable.js:440:5)
      2018-10-07 08:07:33.429 - error: harmony.0 Error: websocket error
      at emitErrorNT (internal/streams/destroy.js:64:8)
      at _combinedTickCallback (internal/process/next_tick.js:138:11)
      2018-10-07 08:07:34.421 - info: zigbee.0 terminating with timeout
      2018-10-07 08:07:34.464 - info: email.0 terminating with timeout
      2018-10-07 08:07:34.560 - info: harmony.0 terminating with timeout
      2018-10-07 08:27:07.443 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
      2018-10-07 08:27:07.458 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2018-10-07 08:27:07.459 - info: host.raspberrypi hostname: raspberrypi, node: v8.11.4
      2018-10-07 08:27:07.467 - info: host.raspberrypi ip addresses: 192.168.168.222 fe80::8bcf:e410:ed6f:584a
      2018-10-07 08:27:08.165 - info: host.raspberrypi inMem-states listening on port 9000
      2018-10-07 08:27:11.569 - info: host.raspberrypi inMem-objects listening on port 9001
      2018-10-07 08:27:11.605 - info: host.raspberrypi InMemoryDB connected
      2018-10-07 08:27:11.918 - info: host.raspberrypi 64 instances found
      2018-10-07 08:27:11.997 - info: host.raspberrypi starting 3 instances
      2018-10-07 08:27:12.140 - info: host.raspberrypi instance system.adapter.email.0 started with pid 1614
      2018-10-07 08:27:15.308 - info: email.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.4
      2018-10-07 08:27:16.535 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 1624
      2018-10-07 08:27:20.604 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1630
      2018-10-07 08:27:29.355 - error: zigbee.0 no connection to objects DB
      2018-10-07 08:27:38.978 - info: zigbee.0 starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.11.4
      2018-10-07 08:27:38.990 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1CD67-if00 with panID 6754 channel 11
      2018-10-07 08:27:40.611 - info: zigbee.0 zigbee-shepherd started!
      2018-10-07 08:27:40.625 - info: zigbee.0 zigbee-shepherd ready
      2018-10-07 08:27:40.644 - info: zigbee.0 (0x00158d0001e148e6): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      2018-10-07 08:28:31.863 - info: host.raspberrypi object change system.adapter.admin.10
      2018-10-07 08:28:50.254 - info: harmony.0 starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.11.4
      2018-10-07 08:28:50.340 - info: harmony.0 searching for Harmony Hubs...
      2018-10-07 08:28:50.373 - info: harmony.0 starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.11.4
      2018-10-07 08:28:51.627 - info: harmony.0 discovered Remote-Hub-Wohnzimmer
      2018-10-07 08:28:54.197 - info: harmony.0 connecting to Remote-Hub-Wohnzimmer
      2018-10-07 08:28:56.761 - info: harmony.0 connected to Remote-Hub-Wohnzimmer
      2018-10-07 08:28:59.576 - info: harmony.0 synced hub config
      2018-10-07 08:29:57.828 - info: host.raspberrypi object change system.adapter.admin.11
      2018-10-07 08:29:57.829 - info: host.raspberrypi "system.adapter.admin.11" enabled
      2018-10-07 08:29:57.899 - info: host.raspberrypi instance system.adapter.admin.11 started with pid 1674
      2018-10-07 08:30:13.002 - error: admin.11 setObject id missing!!
      2018-10-07 08:30:13.030 - info: admin.11 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 08:30:13.056 - info: admin.11 requesting all states
      2018-10-07 08:30:13.061 - info: admin.11 requesting all objects
      2018-10-07 08:30:13.064 - info: admin.11 Request actual repository...
      2018-10-07 08:30:22.249 - info: admin.11 received all states
      2018-10-07 08:30:31.279 - info: admin.11 received all objects
      2018-10-07 08:30:32.006 - info: admin.11 http server listening on port 8086
      2018-10-07 08:30:32.006 - info: admin.11 Use link "http://localhost:8086" to configure.
      2018-10-07 08:30:32.867 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2018-10-07 08:30:38.360 - info: admin.11 Repository received successfully.
      2018-10-07 08:31:00.538 - warn: host.raspberrypi some hosts are offline
      2018-10-07 08:31:01.092 - warn: host.raspberrypi too delayed answer for ioBroker-Pi3-slave-sw
      2018-10-07 08:34:15.194 - info: host.raspberrypi received SIGTERM
      2018-10-07 08:34:15.218 - info: admin.11 terminating http server on port 8086
      2018-10-07 08:34:15.223 - info: harmony.0 terminating
      2018-10-07 08:34:15.201 - info: host.raspberrypi stopInstance system.adapter.sayit.0
      2018-10-07 08:34:15.201 - warn: host.raspberrypi stopInstance system.adapter.sayit.0 not running
      2018-10-07 08:34:15.202 - info: host.raspberrypi stopInstance system.adapter.email.0
      2018-10-07 08:34:15.202 - info: host.raspberrypi stopInstance system.adapter.email.0 killing pid 1614
      2018-10-07 08:34:15.204 - info: host.raspberrypi stopInstance system.adapter.rflink.0
      2018-10-07 08:34:15.204 - warn: host.raspberrypi stopInstance system.adapter.rflink.0 not running
      2018-10-07 08:34:15.205 - info: host.raspberrypi stopInstance system.adapter.tr-064.0
      2018-10-07 08:34:15.205 - warn: host.raspberrypi stopInstance system.adapter.tr-064.0 not running
      2018-10-07 08:34:15.206 - info: host.raspberrypi stopInstance system.adapter.mobile.0
      2018-10-07 08:34:15.206 - info: host.raspberrypi stopInstance system.adapter.s7.0
      2018-10-07 08:34:15.206 - warn: host.raspberrypi stopInstance system.adapter.s7.0 not running
      2018-10-07 08:34:15.207 - info: host.raspberrypi stopInstance system.adapter.ble.0
      2018-10-07 08:34:15.207 - warn: host.raspberrypi stopInstance system.adapter.ble.0 not running
      2018-10-07 08:34:15.207 - info: host.raspberrypi stopInstance system.adapter.harmony.0
      2018-10-07 08:34:15.208 - info: host.raspberrypi stopInstance system.adapter.harmony.0 killing pid 1624
      2018-10-07 08:34:15.208 - info: host.raspberrypi stopInstance system.adapter.zigbee.0
      2018-10-07 08:34:15.209 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 1630
      2018-10-07 08:34:15.210 - info: host.raspberrypi stopInstance system.adapter.admin.11
      2018-10-07 08:34:15.210 - info: host.raspberrypi stopInstance system.adapter.admin.11 killing pid 1674
      2018-10-07 08:34:15.211 - info: host.raspberrypi stopInstance system.adapter.admin.14
      2018-10-07 08:34:15.212 - warn: host.raspberrypi stopInstance system.adapter.admin.14 not running
      2018-10-07 08:34:15.247 - info: zigbee.0 zigbee-shepherd stopped
      2018-10-07 08:34:15.250 - info: zigbee.0 terminating
      2018-10-07 08:34:15.253 - info: admin.11 terminating
      2018-10-07 08:34:15.270 - info: harmony.0 terminating
      2018-10-07 08:34:15.403 - info: host.raspberrypi instance system.adapter.harmony.0 terminated with code 0 (OK)
      2018-10-07 08:34:16.712 - info: email.0 terminating with timeout
      2018-10-07 08:34:15.404 - info: host.raspberrypi All instances are stopped.
      2018-10-07 08:34:15.513 - error: Caught by controller[1]: Sun, 07 Oct 2018 08:34:15 GMT zigbee-shepherd:request REQ --> ZDO:mgmtPermitJoinReq
      2018-10-07 08:34:15.513 - error: Caught by controller[1]: Sun, 07 Oct 2018 08:34:15 GMT cc-znp:SREQ --> ZDO:mgmtPermitJoinReq, { addrmode: 15, dstaddr: 65532, duration: 0, tcsignificance: 0 }
      2018-10-07 08:34:15.514 - error: Caught by controller[1]: Sun, 07 Oct 2018 08:34:15 GMT cc-znp The serialport /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1CD67-if00 is closed.
      2018-10-07 08:34:15.514 - error: Caught by controller[2]: Sun, 07 Oct 2018 08:34:15 GMT zigbee:controller info zigbee-shepherd stopped undefined
      2018-10-07 08:34:15.514 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 0 (OK)
      2018-10-07 08:34:15.515 - info: host.raspberrypi All instances are stopped.
      2018-10-07 08:34:15.591 - info: host.raspberrypi instance system.adapter.admin.11 terminated with code 0 (OK)
      2018-10-07 08:34:15.592 - info: host.raspberrypi All instances are stopped.
      2018-10-07 08:34:16.950 - info: host.raspberrypi terminated
      2018-10-07 08:34:17.387 - info: host.raspberrypi instance system.adapter.email.0 terminated with code 0 (OK)
      2018-10-07 08:37:00.358 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
      2018-10-07 08:37:00.372 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2018-10-07 08:37:00.373 - info: host.raspberrypi hostname: raspberrypi, node: v8.11.4
      2018-10-07 08:37:00.381 - info: host.raspberrypi ip addresses: 192.168.168.222 fe80::8bcf:e410:ed6f:584a
      2018-10-07 08:37:01.114 - info: host.raspberrypi inMem-states listening on port 9000
      2018-10-07 08:37:04.508 - info: host.raspberrypi inMem-objects listening on port 9001
      2018-10-07 08:37:04.538 - info: host.raspberrypi InMemoryDB connected
      2018-10-07 08:37:04.851 - info: host.raspberrypi 64 instances found
      2018-10-07 08:37:04.934 - info: host.raspberrypi starting 4 instances
      2018-10-07 08:37:05.162 - info: host.raspberrypi instance system.adapter.admin.11 started with pid 1786
      2018-10-07 08:37:09.014 - info: host.raspberrypi instance system.adapter.email.0 started with pid 1792
      2018-10-07 08:37:13.011 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 1798
      2018-10-07 08:37:14.299 - info: email.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.4
      2018-10-07 08:37:14.350 - error: admin.11 setObject id missing!!
      2018-10-07 08:37:14.408 - info: admin.11 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 08:37:15.166 - info: admin.11 requesting all states
      2018-10-07 08:37:15.187 - info: admin.11 requesting all objects
      2018-10-07 08:37:15.191 - info: admin.11 Request actual repository...
      2018-10-07 08:37:20.481 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1812
      2018-10-07 08:37:26.485 - info: harmony.0 starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.11.4
      2018-10-07 08:37:26.575 - info: harmony.0 searching for Harmony Hubs...
      2018-10-07 08:37:27.786 - info: harmony.0 discovered Remote-Hub-Wohnzimmer
      2018-10-07 08:37:33.604 - info: harmony.0 connecting to Remote-Hub-Wohnzimmer
      2018-10-07 08:37:33.673 - info: zigbee.0 starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.11.4
      2018-10-07 08:37:33.697 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1CD67-if00 with panID 6754 channel 11
      2018-10-07 08:37:36.178 - info: harmony.0 connected to Remote-Hub-Wohnzimmer
      2018-10-07 08:37:37.408 - info: harmony.0 synced hub config
      2018-10-07 08:37:38.119 - info: zigbee.0 zigbee-shepherd started!
      2018-10-07 08:37:38.137 - info: zigbee.0 zigbee-shepherd ready
      2018-10-07 08:37:38.159 - info: zigbee.0 (0x00158d0001e148e6): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      2018-10-07 08:37:40.087 - info: admin.11 received all states
      2018-10-07 08:37:45.089 - warn: admin.11 Reconnection to DB.
      2018-10-07 08:37:45.111 - warn: admin.11 Reconnection to DB.
      2018-10-07 08:40:20.131 - info: host.raspberrypi object change system.adapter.admin.11
      2018-10-07 08:40:20.142 - info: admin.11 terminating http server on port 8086
      2018-10-07 08:40:20.132 - info: host.raspberrypi object deleted system.adapter.admin.11
      2018-10-07 08:40:20.136 - info: host.raspberrypi stopInstance system.adapter.admin.11
      2018-10-07 08:40:20.137 - info: host.raspberrypi stopInstance system.adapter.admin.11 killing pid 1786
      2018-10-07 08:40:20.155 - info: admin.11 terminating
      2018-10-07 08:40:20.298 - error: host.raspberrypi instance system.adapter.admin.11 terminated with code 0 (OK)
      2018-10-07 08:40:20.298 - info: host.raspberrypi Do not restart adapter system.adapter.admin.11 because disabled or deleted
      2018-10-07 08:40:51.464 - info: host.raspberrypi object change system.adapter.admin.12
      2018-10-07 08:42:13.129 - info: host.raspberrypi object change system.adapter.admin.14
      2018-10-07 08:42:13.130 - info: host.raspberrypi object deleted system.adapter.admin.14
      2018-10-07 08:44:28.192 - info: host.raspberrypi object change system.adapter.admin.13
      2018-10-07 08:44:51.340 - info: host.raspberrypi object change system.adapter.admin.10
      2018-10-07 08:45:15.730 - info: host.raspberrypi object change system.adapter.admin.0
      2018-10-07 08:45:15.774 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1900
      2018-10-07 08:45:20.294 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 08:45:20.348 - info: admin.0 requesting all states
      2018-10-07 08:45:20.354 - info: admin.0 requesting all objects
      2018-10-07 08:45:20.356 - info: admin.0 Request actual repository...
      2018-10-07 08:45:29.887 - info: admin.0 received all states
      2018-10-07 08:45:41.050 - info: admin.0 received all objects
      2018-10-07 08:45:41.709 - info: admin.0 http server listening on port 8081
      2018-10-07 08:45:41.710 - info: admin.0 Use link "http://localhost:8081" to configure.
      2018-10-07 08:45:42.109 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2018-10-07 08:45:44.493 - info: email.0 Send email: {"text":"backitup","to":"nachrichtensysteme@gmail.com","subject":"Updates für ioBroker","from":"ioBroker "}
      2018-10-07 08:45:46.448 - info: email.0 sent to nachrichtensysteme@gmail.com
      2018-10-07 08:45:53.898 - warn: admin.0 Reconnection to DB.
      2018-10-07 08:45:53.928 - warn: admin.0 Reconnection to DB.
      2018-10-07 08:45:54.298 - error: admin.0 already running
      2018-10-07 08:45:54.594 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      2018-10-07 08:45:54.595 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2018-10-07 08:46:24.637 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1933
      2018-10-07 08:46:29.398 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 08:46:29.780 - info: admin.0 requesting all states
      2018-10-07 08:46:29.786 - info: admin.0 requesting all objects
      2018-10-07 08:46:29.789 - info: admin.0 Request actual repository...
      2018-10-07 08:46:38.380 - info: admin.0 received all states
      2018-10-07 08:46:47.702 - info: admin.0 received all objects
      2018-10-07 08:46:48.347 - info: admin.0 http server listening on port 8081
      2018-10-07 08:46:48.347 - info: admin.0 Use link "http://localhost:8081" to configure.
      2018-10-07 08:46:48.633 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2018-10-07 08:46:52.285 - info: admin.0 Repository received successfully.
      2018-10-07 09:05:28.889 - warn: host.raspberrypi some hosts are offline
      2018-10-07 09:06:03.847 - warn: email.0 Reconnection to DB.
      2018-10-07 09:06:03.852 - warn: email.0 Reconnection to DB.
      2018-10-07 09:06:05.523 - error: email.0 already running
      2018-10-07 09:06:07.528 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (Adapter already running)
      2018-10-07 09:06:07.530 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
      2018-10-07 09:06:40.902 - error: uncaught exception: spawn ENOMEM
      2018-10-07 09:06:40.938 - info: harmony.0 terminating
      2018-10-07 09:06:40.950 - info: admin.0 terminating http server on port 8081
      2018-10-07 09:06:41.048 - info: zigbee.0 zigbee-shepherd stopped
      2018-10-07 09:06:41.428 - error: admin.0 websocket error
      2018-10-07 09:06:41.456 - error: admin.0 Error: websocket error
      2018-10-07 09:06:42.454 - info: harmony.0 terminating with timeout
      2018-10-07 09:06:42.468 - info: admin.0 terminating with timeout
      2018-10-07 09:06:42.468 - info: zigbee.0 terminating with timeout
      2018-10-07 09:12:55.103 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
      2018-10-07 09:12:55.117 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2018-10-07 09:12:55.118 - info: host.raspberrypi hostname: raspberrypi, node: v8.11.4
      2018-10-07 09:12:55.131 - info: host.raspberrypi ip addresses: 192.168.168.222 fe80::8bcf:e410:ed6f:584a
      2018-10-07 09:12:55.851 - info: host.raspberrypi inMem-states listening on port 9000
      2018-10-07 09:12:59.148 - info: host.raspberrypi inMem-objects listening on port 9001
      2018-10-07 09:12:59.197 - info: host.raspberrypi InMemoryDB connected
      2018-10-07 09:12:59.512 - info: host.raspberrypi 60 instances found
      2018-10-07 09:12:59.600 - info: host.raspberrypi starting 4 instances
      2018-10-07 09:12:59.735 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2005
      2018-10-07 09:13:09.567 - error: admin.0 no connection to objects DB
      2018-10-07 09:13:13.125 - info: host.raspberrypi instance system.adapter.email.0 started with pid 2015
      2018-10-07 09:13:16.086 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 2021
      2018-10-07 09:13:16.402 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2028
      2018-10-07 09:13:22.100 - info: email.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.4
      2018-10-07 09:13:25.338 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 09:13:25.805 - info: admin.0 requesting all states
      2018-10-07 09:13:25.811 - info: admin.0 requesting all objects
      2018-10-07 09:13:25.815 - info: admin.0 Request actual repository...
      2018-10-07 09:13:30.357 - info: harmony.0 starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.11.4
      2018-10-07 09:13:30.466 - info: harmony.0 searching for Harmony Hubs...
      2018-10-07 09:13:31.711 - info: harmony.0 discovered Remote-Hub-Wohnzimmer
      2018-10-07 09:13:37.433 - info: harmony.0 connecting to Remote-Hub-Wohnzimmer
      2018-10-07 09:13:37.075 - info: zigbee.0 starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.11.4
      2018-10-07 09:13:37.132 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1CD67-if00 with panID 6754 channel 11
      2018-10-07 09:13:38.835 - info: zigbee.0 zigbee-shepherd started!
      2018-10-07 09:13:38.852 - info: zigbee.0 zigbee-shepherd ready
      2018-10-07 09:13:38.879 - info: zigbee.0 (0x00158d0001e148e6): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      2018-10-07 09:13:39.847 - info: harmony.0 connected to Remote-Hub-Wohnzimmer
      2018-10-07 09:13:40.939 - info: harmony.0 synced hub config
      2018-10-07 09:13:47.920 - warn: email.0 Reconnection to DB.
      2018-10-07 09:13:47.948 - warn: email.0 Reconnection to DB.
      2018-10-07 09:13:48.616 - warn: admin.0 Reconnection to DB.
      2018-10-07 09:13:48.638 - warn: admin.0 Reconnection to DB.
      2018-10-07 09:13:51.083 - info: admin.0 received all states
      2018-10-07 09:16:56.598 - info: host.raspberrypi object change system.adapter.admin.0
      2018-10-07 09:16:56.609 - info: admin.0 terminating http server on port 8081
      2018-10-07 09:16:56.603 - info: host.raspberrypi stopInstance system.adapter.admin.0
      2018-10-07 09:16:56.604 - info: host.raspberrypi stopInstance system.adapter.admin.0 killing pid 2005
      2018-10-07 09:16:56.625 - info: admin.0 terminating
      2018-10-07 09:16:56.759 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
      2018-10-07 09:16:59.137 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2059
      2018-10-07 09:17:04.151 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 09:17:04.207 - info: admin.0 requesting all states
      2018-10-07 09:17:04.213 - info: admin.0 requesting all objects
      2018-10-07 09:17:04.216 - info: admin.0 Request actual repository...
      2018-10-07 09:17:13.969 - info: admin.0 received all states
      2018-10-07 09:17:22.238 - info: admin.0 received all objects
      2018-10-07 09:17:22.970 - info: admin.0 http server listening on port 8081
      2018-10-07 09:17:22.971 - info: admin.0 Use link "http://localhost:8081" to configure.
      2018-10-07 09:17:23.332 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2018-10-07 09:17:28.299 - info: admin.0 Repository received successfully.
      2018-10-07 09:38:50.901 - warn: harmony.0 lost Remote-Hub-Wohnzimmer
      2018-10-07 09:38:52.942 - info: harmony.0 client ended: Remote-Hub-Wohnzimmer
      2018-10-07 09:38:53.005 - info: harmony.0 discovered Remote-Hub-Wohnzimmer
      2018-10-07 09:38:54.599 - info: harmony.0 connecting to Remote-Hub-Wohnzimmer
      2018-10-07 09:38:55.204 - info: harmony.0 keep alive failed: Error: Timed out after 5000 ms
      2018-10-07 09:38:56.929 - info: harmony.0 connected to Remote-Hub-Wohnzimmer
      2018-10-07 09:38:57.889 - info: harmony.0 synced hub config
      2018-10-07 09:39:26.808 - warn: host.raspberrypi some hosts are offline
      2018-10-07 09:40:43.558 - warn: harmony.0 lost Remote-Hub-Wohnzimmer
      2018-10-07 09:40:43.569 - info: harmony.0 client ended: Remote-Hub-Wohnzimmer
      2018-10-07 09:40:43.576 - info: harmony.0 discovered Remote-Hub-Wohnzimmer
      2018-10-07 09:40:48.245 - info: harmony.0 connecting to Remote-Hub-Wohnzimmer
      2018-10-07 09:40:51.182 - info: harmony.0 connected to Remote-Hub-Wohnzimmer
      2018-10-07 09:40:52.788 - info: harmony.0 synced hub config
      2018-10-07 09:41:12.318 - warn: admin.0 Reconnection to DB.
      2018-10-07 09:41:12.324 - warn: admin.0 Reconnection to DB.
      2018-10-07 09:41:12.373 - error: admin.0 already running
      2018-10-07 09:41:12.711 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      2018-10-07 09:41:12.712 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2018-10-07 09:41:42.744 - error: uncaught exception: spawn ENOMEM
      2018-10-07 09:41:42.864 - info: harmony.0 terminating
      2018-10-07 09:41:43.125 - info: zigbee.0 zigbee-shepherd stopped
      2018-10-07 09:41:43.280 - error: harmony.0 websocket error
      2018-10-07 09:41:43.389 - error: zigbee.0 websocket error
      2018-10-07 09:41:43.330 - error: harmony.0 Error: websocket error
      2018-10-07 09:41:43.405 - error: zigbee.0 Error: websocket error
      2018-10-07 09:41:44.407 - info: harmony.0 terminating with timeout
      2018-10-07 09:41:44.439 - info: zigbee.0 terminating with timeout
      2018-10-07 09:41:44.438 - info: email.0 terminating with timeout
      2018-10-07 09:44:05.726 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
      2018-10-07 09:44:05.750 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2018-10-07 09:44:05.751 - info: host.raspberrypi hostname: raspberrypi, node: v8.11.4
      2018-10-07 09:44:05.761 - info: host.raspberrypi ip addresses: 192.168.168.222 fe80::8bcf:e410:ed6f:584a
      2018-10-07 09:44:06.672 - info: host.raspberrypi inMem-states listening on port 9000
      2018-10-07 09:44:09.983 - info: host.raspberrypi inMem-objects listening on port 9001
      2018-10-07 09:44:10.026 - info: host.raspberrypi InMemoryDB connected
      2018-10-07 09:44:10.346 - info: host.raspberrypi 60 instances found
      2018-10-07 09:44:10.425 - info: host.raspberrypi starting 4 instances
      2018-10-07 09:44:10.558 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2132
      2018-10-07 09:44:15.021 - info: host.raspberrypi instance system.adapter.email.0 started with pid 2138
      2018-10-07 09:44:19.961 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 2144
      2018-10-07 09:44:22.175 - info: email.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.4
      2018-10-07 09:44:22.591 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2158
      2018-10-07 09:44:22.758 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 09:44:23.155 - info: admin.0 requesting all states
      2018-10-07 09:44:23.173 - info: admin.0 requesting all objects
      2018-10-07 09:44:23.177 - info: admin.0 Request actual repository...
      2018-10-07 09:44:29.875 - error: harmony.0 no connection to objects DB
      2018-10-07 09:44:30.523 - info: harmony.0 starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.11.4
      2018-10-07 09:44:30.577 - info: harmony.0 searching for Harmony Hubs...
      2018-10-07 09:44:31.843 - info: harmony.0 discovered Remote-Hub-Wohnzimmer
      2018-10-07 09:44:30.542 - info: zigbee.0 starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.11.4
      2018-10-07 09:44:30.577 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1CD67-if00 with panID 6754 channel 11
      2018-10-07 09:44:33.564 - info: harmony.0 connecting to Remote-Hub-Wohnzimmer
      2018-10-07 09:44:34.199 - info: zigbee.0 zigbee-shepherd started!
      2018-10-07 09:44:34.212 - info: zigbee.0 zigbee-shepherd ready
      2018-10-07 09:44:34.231 - info: zigbee.0 (0x00158d0001e148e6): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      2018-10-07 09:44:36.130 - info: harmony.0 connected to Remote-Hub-Wohnzimmer
      2018-10-07 09:44:37.310 - info: admin.0 received all states
      2018-10-07 09:44:37.318 - info: harmony.0 synced hub config
      2018-10-07 09:44:53.037 - warn: admin.0 Reconnection to DB.
      2018-10-07 09:44:53.047 - warn: email.0 Reconnection to DB.
      2018-10-07 09:44:53.055 - warn: email.0 Reconnection to DB.
      2018-10-07 09:44:53.066 - warn: admin.0 Reconnection to DB.
      2018-10-07 09:54:35.610 - warn: admin.0 Reconnection to DB.
      2018-10-07 09:54:35.620 - warn: admin.0 Reconnection to DB.
      2018-10-07 09:54:35.629 - warn: email.0 Reconnection to DB.
      2018-10-07 09:54:35.635 - warn: email.0 Reconnection to DB.
      2018-10-07 10:28:28.390 - info: host.raspberrypi object change system.adapter.admin.0
      2018-10-07 10:28:28.401 - info: admin.0 terminating http server on port 8081
      2018-10-07 10:28:28.395 - info: host.raspberrypi stopInstance system.adapter.admin.0
      2018-10-07 10:28:28.395 - info: host.raspberrypi stopInstance system.adapter.admin.0 killing pid 2132
      2018-10-07 10:28:28.415 - info: admin.0 terminating
      2018-10-07 10:28:28.555 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
      2018-10-07 10:28:30.936 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2241
      2018-10-07 10:28:37.560 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 10:28:38.080 - info: admin.0 requesting all states
      2018-10-07 10:28:38.087 - info: admin.0 requesting all objects
      2018-10-07 10:28:38.090 - info: admin.0 Request actual repository...
      2018-10-07 10:28:47.997 - info: admin.0 received all states
      2018-10-07 10:29:00.293 - info: admin.0 received all objects
      2018-10-07 10:29:02.219 - info: admin.0 http server listening on port 8081
      2018-10-07 10:29:02.219 - info: admin.0 Use link "http://localhost:8081" to configure.
      2018-10-07 10:29:02.844 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2018-10-07 10:29:12.158 - info: admin.0 Repository received successfully.
      2018-10-07 10:44:05.726 - info: host.raspberrypi Delete log file iobroker.2018-09-30.log
      2018-10-07 10:50:34.720 - warn: zigbee.0 Reconnection to DB.
      2018-10-07 10:50:34.747 - error: email.0 already running
      2018-10-07 10:50:34.738 - warn: zigbee.0 Reconnection to DB.
      2018-10-07 10:50:34.985 - error: harmony.0 already running
      2018-10-07 10:50:35.149 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (Adapter already running)
      2018-10-07 10:50:35.150 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
      2018-10-07 10:50:35.205 - error: host.raspberrypi instance system.adapter.harmony.0 terminated with code 7 (Adapter already running)
      2018-10-07 10:50:35.206 - info: host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
      2018-10-07 10:50:35.427 - error: zigbee.0 already running
      2018-10-07 10:50:35.581 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
      2018-10-07 10:50:35.582 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2018-10-07 10:51:05.981 - error: uncaught exception: spawn ENOMEM
      2018-10-07 10:51:06.010 - info: admin.0 terminating http server on port 8081
      2018-10-07 10:51:06.398 - error: admin.0 websocket error
      2018-10-07 10:51:06.422 - error: admin.0 Error: websocket error
      2018-10-07 10:51:07.523 - info: admin.0 terminating with timeout
      2018-10-07 11:03:55.125 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
      2018-10-07 11:03:55.149 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2018-10-07 11:03:55.150 - info: host.raspberrypi hostname: raspberrypi, node: v8.11.4
      2018-10-07 11:03:55.158 - info: host.raspberrypi ip addresses: 192.168.168.222 fe80::8bcf:e410:ed6f:584a
      2018-10-07 11:03:56.070 - info: host.raspberrypi inMem-states listening on port 9000
      2018-10-07 11:03:59.342 - info: host.raspberrypi inMem-objects listening on port 9001
      2018-10-07 11:03:59.397 - info: host.raspberrypi InMemoryDB connected
      2018-10-07 11:03:59.717 - info: host.raspberrypi 60 instances found
      2018-10-07 11:03:59.805 - info: host.raspberrypi starting 4 instances
      2018-10-07 11:04:00.059 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2305
      2018-10-07 11:04:05.985 - info: host.raspberrypi instance system.adapter.email.0 started with pid 2311
      2018-10-07 11:04:09.604 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 2317
      2018-10-07 11:04:10.629 - error: admin.0 no connection to objects DB
      2018-10-07 11:04:12.675 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2328
      2018-10-07 11:04:18.327 - error: email.0 no connection to states DB: Connection timeout
      2018-10-07 11:04:21.333 - error: harmony.0 no connection to objects DB
      2018-10-07 11:04:22.095 - info: email.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.4
      2018-10-07 11:04:22.125 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 11:04:22.933 - info: admin.0 requesting all states
      2018-10-07 11:04:22.939 - info: admin.0 requesting all objects
      2018-10-07 11:04:22.953 - info: admin.0 Request actual repository...
      2018-10-07 11:04:28.537 - info: harmony.0 starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.11.4
      2018-10-07 11:04:28.594 - info: harmony.0 searching for Harmony Hubs...
      2018-10-07 11:04:29.818 - info: harmony.0 discovered Remote-Hub-Wohnzimmer
      2018-10-07 11:04:29.096 - info: zigbee.0 starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.11.4
      2018-10-07 11:04:29.121 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1CD67-if00 with panID 6754 channel 11
      2018-10-07 11:04:32.035 - info: harmony.0 connecting to Remote-Hub-Wohnzimmer
      2018-10-07 11:04:32.257 - info: zigbee.0 zigbee-shepherd started!
      2018-10-07 11:04:32.272 - info: zigbee.0 zigbee-shepherd ready
      2018-10-07 11:04:32.296 - info: zigbee.0 (0x00158d0001e148e6): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      2018-10-07 11:04:34.551 - info: harmony.0 connected to Remote-Hub-Wohnzimmer
      2018-10-07 11:04:35.396 - info: admin.0 received all states
      2018-10-07 11:04:35.638 - info: harmony.0 synced hub config
      2018-10-07 11:04:43.381 - warn: admin.0 Reconnection to DB.
      2018-10-07 11:04:43.399 - warn: admin.0 Reconnection to DB.
      2018-10-07 11:05:28.979 - info: host.raspberrypi object change system.adapter.admin.0
      2018-10-07 11:05:28.990 - info: admin.0 terminating http server on port 8081
      2018-10-07 11:05:28.984 - info: host.raspberrypi stopInstance system.adapter.admin.0
      2018-10-07 11:05:28.985 - info: host.raspberrypi stopInstance system.adapter.admin.0 killing pid 2305
      2018-10-07 11:05:29.035 - info: admin.0 terminating
      2018-10-07 11:05:29.185 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
      2018-10-07 11:05:31.532 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2355
      2018-10-07 11:05:39.555 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.4
      2018-10-07 11:05:40.069 - info: admin.0 requesting all states
      2018-10-07 11:05:40.076 - info: admin.0 requesting all objects
      2018-10-07 11:05:40.080 - info: admin.0 Request actual repository...
      2018-10-07 11:05:54.014 - info: admin.0 received all states
      2018-10-07 11:06:04.289 - info: admin.0 received all objects
      2018-10-07 11:06:05.267 - info: admin.0 http server listening on port 8081
      2018-10-07 11:06:05.268 - info: admin.0 Use link "http://localhost:8081" to configure.
      2018-10-07 11:06:05.633 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2018-10-07 11:06:21.207 - info: admin.0 Repository received successfully.
      2018-10-07 11:09:16.050 - warn: host.raspberrypi some hosts are offline
      2018-10-07 11:09:21.798 - warn: host.raspberrypi too delayed answer for ioBroker-Pi3-slave-sw
      • eric2905E Offline
        eric2905E Offline
        eric2905
        @Elektroman:
        2. Ja habe alles und in jeder Art und Weise neu gestartet `
        Das kann eigentlich nicht sein.
        Der NAS-Host meldet eine Uptime von fast 4 Tagen:
        ~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201810 ... 35479a.jpg">https://uploads.tapatalk-cdn.com/20181007/adb1b61012598d748e25959dfb35479a.jpg</link_text>" />
        Reboote den erst mal und installiere ein anderes npm.
        Bzw. schau mal auf der Konsole, welche npm-Version installiert ist.
        Gruß,
        Eric
        Von unterwegs getippert~~
        • E Offline
          Elektroman
          sorry war kein aktuelles Bild
          • eric2905E Offline
            eric2905E Offline
            eric2905
            @Elektroman:
            sorry war kein aktuelles Bild `
            Danke für das in die Irre leiten.
            Jetzt die npm-Version anpassen.
            Gruß,
            Eric
            • E Offline
              Elektroman
              das funktioniert leider nicht beim NAS
              sudo apt-get –purge remove node
              sudo apt-get --purge remove nodejs
              sudo apt-get autoremove
              curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
              sudo apt-get install -y nodejs
              node -v
              sudo npm install -g npm@4
              npm -v
              • E Offline
                Elektroman
                sudo npm install -g npm@4.6.1
                hat funktioniert
                Zeigt aber 5 noch an
                • E Offline
                  Elektroman
                  Siehe hier
                  • apollon77A Offline
                    Dann hilft ggf ein "which npm" um zu sehen wo er es installiert hat … scheinbar hast Du es jetzt doppelt drauf.
                    Mit "npm root -g" bekommst Du eine Info zum Basisverzeichnis wo npm sich selbst global installiert hat (und globale Module)
                    Da musst Du jetzt malschauen
                    • E Offline
                      Elektroman
                      Hallo und danke für Deine Hilfe!!!
                      Und was jetzt ???
                      <u>Master:</u>
                      root@raspberrypi:~# npm root -g
                      /usr/lib/node_modules
                      <u>Slave Raspi:</u>
                      pi@ioBroker-Pi3-slave:~ $ npm root -g
                      <u>Slave NAS:</u>
                      admin@nasserver:~$ npm root -g
                      /volume1/@appstore/Node.js_v6/usr/local/lib/node_modules
                        und was sagt which npm
                        auf dem NAS Slave (nur der Macht probleme korrekt?)
                        • E Offline
                          Elektroman
                          Alles macht leider Probleme.
                          Meine Vermutung ist nur das es an npm 5x liegt(NAS). Habe ich so irgendwo gelesen
                          Ich muss sehr oft den Master neu starten (iobroker start und admin.0 restart)
                          Bin leider auch kein Profi 😢
                          Master Raspi:
                          root@raspberrypi:/opt/iobroker# which npm
                          /usr/bin/npm
                          Slave Raspi:
                          pi@ioBroker-Pi3-slave:~ $ which npm
                          /usr/bin/npm
                          NAS:
                          admin@nasserver:~$ which npm
                          /usr/local/bin/npm
                            Also mal eins nach dem anderen!!
                            Du hast scheinbar mehrere Probleme in deinem Setup die im ersten Schritt mal unabhängig sind, wenn ich das so richtig lese.
                            Ich sehe mindestens 2:
                            1.) Auf deinem pi hast du öfter meldungen über doppelt laufende Prozesse
                            2.) Auf deinem nas kannst du npm nicht updaten (und ja 5.6.0 ist böse, sollte aber dann nur den Slave betreffen und dem Master erstmal egal sein!)
                            Die Probleme mit Admin und so könnten von ersterem herrühren.
                            Sonst noch mehr?
                            zu 1.) Zu diesem Thema findest Du mehrere Threads hier im Forum.
                            Ohne weitere Infos (wieveiele Adapter laufen da in Summe und auch dem Pi? Redis oder nicht? CPU/Speicher-Auslastung?…) ist hier alles Glaskugel. Solche Probleme sind meistens irgendwie wegen Ressourcenlimits (i/o, CPU, RAM) verursacht und am Ende ist ein Logauszug von "wenn es schon passiert ist" zu spät. Du musst finden was das log sagt wenn diese Themen anfangen!
                            Auch ein Check in /var/log/syslog ist ggf interessant falls da das wort killer (genau genommen OOM killer) vorkommt, dann ist Dir nämlich der RAM ausgegangen!
                            Was Du hier tun kannst ist dich annähern. Schalte auf dem pi alle Adapterinstanzen aus auser Admin und reboote. Dann hast Du einen cleanen stand. jetzt nach und nach die Instanzen einschalten. Dabei "top" (und damit CPU und RAM und so im Auge behalten) und ioBroker Logfile auf der Platte (/opt/iobroker/log/...) anschauen. Dann siehst Du ggf was passiert wenn deine probleme starten und du kannst von da aus weiter probieren und ggf auch hier die relevanten Teile posten.
                            zu 2.) Scheinbar hat deine NAS den Pfad von originalen NPM version im pfad und so wird die neue nicht geladen. Jetzt musst Du für deine NAS schauen ob Du den Pfad (PATH) dauerhaft anpassen kannst oder ob Du die /usr/local/bin/npm in einen symbolischen Link verwandelst der auf die andere globale Installations-Lokation zeigt. Dann sollte die npm version von dort genutzt werden.
                            Ingo
                            • E Offline
                              Elektroman
                              Erst einmal vielen dank für die ausführliche Hilfe!!!!!
                              Den RAM habe ich eigentlich immer im Auge (selten unter 30%)
                              wie sieht es aus wenn ich das iobroker Verzeichnis in iobrokerOLD umbenenne und nach einer Neuinstallierung alles zurück kopiere? Kopiere ich den Fehler auch mit? oder ist das ein Versuch wert ? (Ja ist klar Glaskugel und so ;-) )
                              Zu 2.
                              Sorry aber ich komm da nicht mit
                                @Elektroman:
                                wie sieht es aus wenn ich das iobroker Verzeichnis in iobrokerOLD umbenenne und nach einer Neuinstallierung alles zurück kopiere? Kopiere ich den Fehler auch mit? oder ist das ein Versuch wert ? (Ja ist klar Glaskugel und so ;-) ) `
                                Welchen "Fehler" meinst Du denn? Für mich ist nicht klar das ein Fehler überhaupt da ist.
                                Wenn schon dann backup machen und das zurückspielen nach einer Neuinstallation, aber wenn die Adapter an sich starten und alles läuft bis plötzlich diese Probleme anfangen dann ist das nichts was eine neuinstallation fixen sollte denke ich.
                                • E Offline
                                  Elektroman
                                  Ich starte jetzt langsam die Adapter wieder zu !
                                  Bin gerade bei der CCU
                                  läuft !
                                  Nur wie bekomme ich das mit dem npm 5x auf den NAS behoben. Das habe ich leider noch nicht verstanden
                                  • E Offline
                                    Elektroman
                                    ich glaube Du hast recht mit dem Hauptspeicher
                                    es läuft auf dem Master nur noch der Admin Adapter und nach einem neustart wird der freie Speicher immer geringer nach der Zeit
                                    Anfang 70% nach 15 min. nur noch 8% (deshalb ist mir das auch nicht aufgefallen)
                                    • E Offline
                                      Elektroman
                                      Jetzt habe ich noch den Admin Adapter auf den Slave ausgelagert
                                      Jetzt läuft kein Adapter mehr auf dem Master und laut Instanzen habe ich nur noch 25 % frei
                                      root@raspberrypi:/opt/iobroker# free -h
                                      total used free shared buffers cached
                                      Mem: 970M 708M 262M 1,1M 23M 75M
                                      -/+ buffers/cache: 608M 361M
                                      Swap: 99M 15M 84M
                                      • E Offline
                                        Elektroman
                                        Moin,
                                        habe jetzt ältere img auf die Raspi´s geschoben. Ist jetzt zwar ein bisschen arbeit das alles zu aktualisieren und Blockly programme neu zu schreiben aber egal
                                        ABER wie bekomme ich den downgrade auf 4.6.1 oder Update auf 5.7.1 hin ???
                                        Habe einiges schon im Forum ausprobiert nichts hat geholfen
                                        z.B. wie hier beschrieben
                                        viewtopic.php?f=22&t=12490&p=132372#p132372
                                        • paul53P Offline
                                          @Elektroman:
                                          ABER wie bekomme ich den downgrade auf 4.6.1 oder Update auf 5.7.1 hin ??? `
                                          So, wie Du es schon einmal gemacht hast.
                                          npm -v
                                          Falls npm -v eine andere Version anzeigen sollte, poste bitte den Terminalinhalt in Code tags.
