  4. [Frage] Blockly zufällig im Zeitbereich
    5.6k
40 Beiträge 6 Kommentatoren 6.6k Aufrufe 2 Beobachtet
    Belei
    Wäre super.
     <xml xmlns="http://www.w3.org/1999/xhtml"><block type="procedures_defnoreturn" id="]aih=G55?HS]7lpb*vSc" x="538" y="-337"><field name="NAME">ZufallEins</field>
        <statement name="STACK"><block type="debug" id="m(8lX4`Y:**J%J^9ti)M"><field name="Severity">log</field>
            <value name="TEXT"><shadow type="text" id="`7k{/9%WdRZg%WaMby}Z"><field name="TEXT">5 Min</field></shadow>
              <block type="variables_get" id="y1Q1BFtS+I+?X!T;vdJ|"><field name="VAR">valZufall</field></block></value>
            <next><block type="comment" id="UD8iI_FNE6Pa0}07og*["><field name="COMMENT">Schalte etwas ein</field>
                <next><block type="control" id="ED=cN8;vC^#@G{/Ar}X9"><mutation delay_input="false"></mutation>
                    <field name="OID">rflink.0.channels.TriState_2.SWITCH_0</field>
                    <value name="VALUE"><block type="logic_boolean" id="QbwuRS!E)91vs04SFhcx"><field name="BOOL">TRUE</field></block></value>
                    <next><block type="variables_set" id="gc%||Eu?4a-GR[lV#V+9"><field name="VAR">TimerAktiv1</field>
                        <value name="VALUE"><block type="logic_boolean" id=".f:;9;bHuW@Q8uTIM7cx"><field name="BOOL">TRUE</field></block></value>
                        <next><block type="timeouts_settimeout" id="KUky=Au9Hf42KvR*saZi"><field name="NAME">timeout</field>
                            <field name="DELAY">4</field>
                            <field name="UNIT">min</field>
                            <statement name="STATEMENT"><block type="comment" id="!/W#E)^phCi/#d:rZ11M"><field name="COMMENT">Schalte etwas wieder aus</field>
                                <next><block type="control" id="J97f}9hq6rb2=*.3;mt5"><mutation delay_input="false"></mutation>
                                    <value name="VALUE"><block type="logic_boolean" id="!~cb-+ln/td1zDut0#O!"><field name="BOOL">FALSE</field></block></value>
                                    <next><block type="variables_set" id="45qLb@}f0E5vBYwGUs,H"><field name="VAR">TimerAktiv1</field>
                                        <value name="VALUE"><block type="logic_boolean" id="M69l1/uK.(zT^%3mbA|@"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></statement></block>
      <block type="schedule" id="#q]X?XA6,T#oVG0~p2-k" x="-118" y="-158"><field name="SCHEDULE">*/2 * * * *</field>
        <statement name="STATEMENT"><block type="controls_if" id="SPb@1vaoX%#8}Ztk9|.{"><value name="IF0"><block type="logic_operation" id="(ui;wwx,m7~KV@=ZeIUK" inline="false"><field name="OP">OR</field>
                <value name="A"><block type="logic_compare" id=")|K*D~LFn0EfiYM^m@Nn"><field name="OP">NEQ</field>
                    <value name="A"><block type="variables_get" id="d71W,pX%p`J72;8{kfdS"><field name="VAR">TimerAktiv1</field></block></value>
                    <value name="B"><block type="logic_boolean" id="(%,AB0sDN!#y4ic_{VjS"><field name="BOOL">TRUE</field></block></value></block></value>
                <value name="B"><block type="logic_operation" id="GCxABfmY9)n2`vpps=u-" inline="false"><field name="OP">OR</field>
                    <value name="A"><block type="logic_compare" id="^m+ouKh|qzf=TbS~_9mR"><field name="OP">NEQ</field>
                        <value name="A"><block type="variables_get" id="2lHQKNO*mK.%;jMHNz,R"><field name="VAR">TimerAktiv2</field></block></value>
                        <value name="B"><block type="logic_boolean" id="*5::xUcUsAP(GD7FbIP7"><field name="BOOL">TRUE</field></block></value></block></value>
                    <value name="B"><block type="logic_compare" id="7wfI*kc/lun-#h?#3Kp4"><field name="OP">NEQ</field>
                        <value name="A"><block type="variables_get" id="eAK,rKQ|x[!;:KUE3;Tq"><field name="VAR">TimerAktiv3</field></block></value>
                        <value name="B"><block type="logic_boolean" id="Fc6Bpci,#--yqGe0==Jt"><field name="BOOL">TRUE</field></block></value></block></value></block></value></block></value>
            <statement name="DO0"><block type="variables_set" id="}.-BM_s!1lz.V*hvU@AY"><field name="VAR">valZufall</field>
                <value name="VALUE"><block type="math_random_int" id="3Q/HHpL~EpbBr^HE~1df"><value name="FROM"><shadow type="math_number" id="A.LJ5W.UeB`qK(Tl2GvZ"><field name="NUM">1</field></shadow></value>
                    <value name="TO"><shadow type="math_number" id="T{/dDJqQ1%YlMESV9(Nv"><field name="NUM">3</field></shadow></value></block></value>
                <next><block type="controls_if" id="kGg5uFcR8[gxXgSzVl5n"><mutation elseif="3"></mutation>
                    <value name="IF0"><block type="logic_compare" id="?nV9axQ.ztUS+?mvR:^v"><field name="OP">EQ</field>
                        <value name="A"><block type="variables_get" id="eGQClh}yINaaminM]h@M"><field name="VAR">valZufall</field></block></value>
                        <value name="B"><block type="math_number" id="w)p6@Kl(M%rZZC2w[fk^"><field name="NUM">1</field></block></value></block></value>
                    <statement name="DO0"><block type="procedures_callnoreturn" id="K0BT]GJP:#6Le6RdwqF8"><mutation name="ZufallEins"></mutation></block></statement>
                    <value name="IF1"><block type="logic_compare" id="M0[QB+35R8YTEh=5Xge*"><field name="OP">EQ</field>
                        <value name="A"><block type="variables_get" id="(tpMntf[RTlhk6nXF#Xk"><field name="VAR">valZufall</field></block></value>
                        <value name="B"><block type="math_number" id="Nc.|J~M;eYEIWS|Q!J;l"><field name="NUM">2</field></block></value></block></value>
                    <statement name="DO1"><block type="procedures_callnoreturn" id="W87g2nl8jprwJXB]J[hw"><mutation name="ZufallZwei"></mutation></block></statement>
                    <value name="IF2"><block type="logic_compare" id="g*j}gnPUy#/5aHdoBnr@"><field name="OP">EQ</field>
                        <value name="A"><block type="variables_get" id="leS?FhGaeYN^U_eW=UC@"><field name="VAR">valZufall</field></block></value>
                        <value name="B"><block type="math_number" id="L+jsa(J@;}6M8Rr%a}Yd"><field name="NUM">3</field></block></value></block></value>
                    <statement name="DO2"><block type="procedures_callnoreturn" id="{;AN3#fKQQ0kBms}=oDy"><mutation name="ZufallDrei"></mutation></block></statement>
                    <value name="IF3"><block type="logic_compare" id="Kula=B]?Qm,8|hl@Lfw9"><field name="OP">EQ</field>
                        <value name="A"><block type="variables_get" id=".Jh!eEfh;x(*4U6_axex"><field name="VAR">valZufall</field></block></value>
                        <value name="B"><block type="math_number" id="wO2~:2csDCrDbtSo]847"><field name="NUM">4</field></block></value></block></value>
                    <statement name="DO3"><block type="procedures_callnoreturn" id="@/vd7WZAX_Z^jPucS.%+"><mutation name="ZufallVier"></mutation></block></statement></block></next></block></statement></block></statement></block>
      <block type="procedures_defnoreturn" id="j6lr*@jITsr]ms8yhUh0" x="537" y="-13"><field name="NAME">ZufallZwei</field>
        <statement name="STACK"><block type="debug" id="Yj?[d2mz/jUbw6B@}i^w"><field name="Severity">log</field>
              <block type="variables_get" id=")6F1e[,wecN:0#OxtHo5"><field name="VAR">valZufall</field></block></value>
            <next><block type="comment" id="(K~gPu|WTF3rn%_]Wu|p"><field name="COMMENT">Schalte etwas ein</field>
                <next><block type="control" id="hF)HlaS*VSz}`sd3u(K*"><mutation delay_input="false"></mutation>
                    <field name="OID">rflink.0.channels.TriState_1.SWITCH_0</field>
                    <value name="VALUE"><block type="logic_boolean" id="VEqZzRpfd`LSx-UGb(Yp"><field name="BOOL">TRUE</field></block></value>
                    <next><block type="variables_set" id="{(kXy~N;Z`.QRt}v*r3I"><field name="VAR">TimerAktiv2</field>
                        <value name="VALUE"><block type="logic_boolean" id="G6@Xxm=)a-dD[j{I=Yfv"><field name="BOOL">TRUE</field></block></value>
                        <next><block type="timeouts_settimeout" id="xefMj,DIwtkW*2@Phw1Q"><field name="NAME">timeout2</field>
                            <field name="DELAY">3</field>
                            <statement name="STATEMENT"><block type="comment" id="A[?425Oyazos+*y8;Y2:"><field name="COMMENT">Schalte etwas wieder aus</field>
                                <next><block type="control" id=")u;,dqM7ph}ThmI^d%]_"><mutation delay_input="false"></mutation>
                                    <value name="VALUE"><block type="logic_boolean" id="Vk8^EBNG^g8LdOV)VAEU"><field name="BOOL">FALSE</field></block></value>
                                    <next><block type="variables_set" id="W,)iWjtj;*J1`9I8rbs8"><field name="VAR">TimerAktiv2</field>
                                        <value name="VALUE"><block type="logic_boolean" id="P=PZWs~Sdnb/7A_g1IMp"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></statement></block>
      <block type="procedures_defnoreturn" id=",%sXx)neL(hBuOH~l%%9" x="538" y="313"><field name="NAME">ZufallDrei</field>
        <statement name="STACK"><block type="debug" id="k}),=oVBLM[qL:1,0K=%"><field name="Severity">log</field>
              <block type="variables_get" id="zY3NJB^6bk2C?gA/]Qa9"><field name="VAR">valZufall</field></block></value>
            <next><block type="comment" id="|;jKXPh/w,O.!TE~)5y6"><field name="COMMENT">Schalte etwas ein</field>
                <next><block type="control" id="m4+CXk,T|or#|aW{.i+T"><mutation delay_input="false"></mutation>
                    <field name="OID">hm-rpc.0.LEQ0494524.1.STATE</field>
                    <value name="VALUE"><block type="logic_boolean" id="Q(S#(BE#-.9p9oL,hK5N"><field name="BOOL">TRUE</field></block></value>
                    <next><block type="variables_set" id="WDYnD=%[7`Ot3b94P*cl"><field name="VAR">TimerAktiv3</field>
                        <value name="VALUE"><block type="logic_boolean" id="m{t-glCB~U:?~U6VhWvj"><field name="BOOL">TRUE</field></block></value>
                        <next><block type="timeouts_settimeout" id="TX2ufws`26#AES|*Hmty"><field name="NAME">timeout3</field>
                            <field name="DELAY">2</field>
                            <statement name="STATEMENT"><block type="comment" id=";6|h5I,9xy=NsXaK6Pv{"><field name="COMMENT">Schalte etwas wieder aus</field>
                                <next><block type="control" id="!jhRkjpNWwMSGP@^rT2."><mutation delay_input="false"></mutation>
                                    <value name="VALUE"><block type="logic_boolean" id="Ejqj;h))SCTnq(A_hjDJ"><field name="BOOL">FALSE</field></block></value>
                                    <next><block type="variables_set" id="q7GtkJVZ!-R+JVdai^K("><field name="VAR">TimerAktiv3</field>
                                        <value name="VALUE"><block type="logic_boolean" id="p!%n^3t8Q}JFG!y8~NPI"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></statement></block>
      <block type="procedures_defnoreturn" id="Do%_Mz5D3j+7_(%A?wk/" disabled="true" x="-12" y="438"><field name="NAME">ZufallVier</field>
        <statement name="STACK"><block type="debug" id="SddePCHNGEv*O5)[L!|L"><field name="Severity">log</field>
              <block type="variables_get" id="UT4Hs.*B(lrwTl%wbB)k"><field name="VAR">valZufall</field></block></value>
            <next><block type="comment" id="3YLO0h:c=8-gQE:yK^UE"><field name="COMMENT">Schalte etwas ein</field>
                <next><block type="control" id="3#h:eG@SGDYzq+.PR}-#"><mutation delay_input="false"></mutation>
                    <field name="OID">rflink.0.channels.TriState_3.SWITCH_0</field>
                    <value name="VALUE"><block type="logic_boolean" id=":fB4T3=1f;/p~BLGV0Gw"><field name="BOOL">TRUE</field></block></value>
                    <next><block type="variables_set" id="J@aYvxZPi`trWAlqpW25"><field name="VAR">TimerAktiv1</field>
                        <value name="VALUE"><block type="logic_boolean" id="]`2SP#p@h51soMT{%i1q"><field name="BOOL">TRUE</field></block></value>
                        <next><block type="timeouts_settimeout" id="ggJ~{/7+?n-Rgwq7%#EQ"><field name="NAME">timeout4</field>
                            <field name="DELAY">5</field>
                            <statement name="STATEMENT"><block type="comment" id="%vHRMF@eG`;S!9BX6!V-"><field name="COMMENT">Schalte etwas wieder aus</field>
                                <next><block type="control" id="R]o7o!C%.3q{`rFY}+=t"><mutation delay_input="false"></mutation>
                                    <value name="VALUE"><block type="logic_boolean" id="jm^qvJMwt6Lfc)MQLuF,"><field name="BOOL">FALSE</field></block></value>
                                    <next><block type="variables_set" id="P+H2zSavaOy=W@s*t)u?"><field name="VAR">TimerAktiv1</field>
                                        <value name="VALUE"><block type="logic_boolean" id="%##r%nr.Eg/VQGyd{[6f"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></statement></block>
      <block type="logic_compare" id="7oAh/Wmv*}k2Jb;t;V}U" disabled="true" x="-188" y="462"><field name="OP">NEQ</field>
        <value name="A"><block type="variables_get" id="umU+ee~y5%..vm%CJy7~"><field name="VAR">TimerAktiv3</field></block></value>
        <value name="B"><block type="logic_boolean" id="oA*;4q5PIsP+{LTQ8w7w"><field name="BOOL">TRUE</field></block></value></block></xml>
    • rantanplanR Offline
      rantanplanR Offline
      rantanplan
      Ganz schön faul ;)
      Habe noch einen Datenpunkt hinzugefügt "SimulationAktiv".
      Wenn Du das Script einmal startest wird der Datenpunkt unter "javascript.0" angelegt.
      Den kannst Du dann über VIS wahr/unwahr schalten.
      Sonst werden Deine Geräte IMMER alle 2 Minuten geschaltet.
      Wenn Du weitere "Zufälle" hinzufügst, musst Du auch die Generierung der Zufallszahl anpassen.
      Wenn Du das zwischen 1 und 3 lässt, wird 4 NIE ausgeführt.
      Habe ich noch NICHT angepasst. Ein bisschen kannst Du ja auch noch machen :)
      ! <xml xmlns="http://www.w3.org/1999/xhtml"><block type="procedures_defnoreturn" id="]aih=G55?HS]7lpb*vSc" x="613" y="-337"><field name="NAME">ZufallEins</field> <comment pinned="false" h="80" w="160">Beschreibe diese Funktion …</comment> <statement name="STACK"><block type="debug" id="m(8lX4`Y:**J%J^9ti)M"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="`7k{/9%WdRZg%WaMby}Z"><field name="TEXT">5 Min</field></shadow> <block type="variables_get" id="y1Q1BFtS+I+?X!T;vdJ|"><field name="VAR">valZufall</field></block></value> <next><block type="comment" id="UD8iI_FNE6Pa0}07og*["><field name="COMMENT">Schalte etwas ein</field> <next><block type="control" id="ED=cN8;vC^#@G{/Ar}X9"><mutation delay_input="false"></mutation> <field name="OID">rflink.0.channels.TriState_2.SWITCH_0</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="QbwuRS!E)91vs04SFhcx"><field name="BOOL">TRUE</field></block></value> <next><block type="variables_set" id="gc%||Eu?4a-GR[lV#V+9"><field name="VAR">TimerAktiv1</field> <value name="VALUE"><block type="logic_boolean" id=".f:;9;bHuW@Q8uTIM7cx"><field name="BOOL">TRUE</field></block></value> <next><block type="timeouts_settimeout" id="KUky=Au9Hf42KvR*saZi"><field name="NAME">timeout</field> <field name="DELAY">4</field> <field name="UNIT">min</field> <statement name="STATEMENT"><block type="comment" id="!/W#E)^phCi/#d:rZ11M"><field name="COMMENT">Schalte etwas wieder aus</field> <next><block type="control" id="J97f}9hq6rb2=*.3;mt5"><mutation delay_input="false"></mutation> <field name="OID">rflink.0.channels.TriState_2.SWITCH_0</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="!~cb-+ln/td1zDut0#O!"><field name="BOOL">FALSE</field></block></value> <next><block type="variables_set" id="45qLb@}f0E5vBYwGUs,H"><field name="VAR">TimerAktiv1</field> <value name="VALUE"><block type="logic_boolean" id="M69l1/uK.(zT^%3mbA|@"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></statement></block> <block type="create" id="luNmgal2UD@aFdYv,`C`" x="-187" y="-238"><field name="NAME">SimulationAktiv</field> <next><block type="update" id="hA:I]9Ku^t7[x@{7Qi3m"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.SimulationAktiv</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="oIQ|l4%)dx}A]mI[f:k["><field name="BOOL">FALSE</field></block></value></block></next></block> <block type="schedule" id="#q]X?XA6,T#oVG0~p2-k" x="-187" y="-113"><field name="SCHEDULE">*/2 * * * *</field> <statement name="STATEMENT"><block type="controls_if" id="~;[H.[R{e=dWR0!iB2:B"><value name="IF0"><block type="logic_compare" id="u~,(kd8d}xP0WqN1aPwD"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="IDX9-iJ,hn%9WZ7ocwn_"><field name="ATTR">val</field> <field name="OID">javascript.0.SimulationAktiv</field></block></value> <value name="B"><block type="logic_boolean" id="gAU:(7O6x#^1YPjw#.%]"><field name="BOOL">TRUE</field></block></value></block></value> <statement name="DO0"><block type="variables_set" id="}.-BM_s!1lz.V*hvU@AY"><field name="VAR">valZufall</field> <value name="VALUE"><block type="math_random_int" id="3Q/HHpL~EpbBr^HE~1df"><value name="FROM"><shadow type="math_number" id="A.LJ5W.UeB`qK(Tl2GvZ"><field name="NUM">1</field></shadow></value> <value name="TO"><shadow type="math_number" id="T{/dDJqQ1%YlMESV9(Nv"><field name="NUM">3</field></shadow></value></block></value> <next><block type="controls_if" id="kGg5uFcR8[gxXgSzVl5n"><mutation elseif="3"></mutation> <value name="IF0"><block type="logic_operation" id="xjiFi#7YQNI7]`z,33Mu"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="?nV9axQ.ztUS+?mvR:^v"><field name="OP">EQ</field> <value name="A"><block type="variables_get" id="eGQClh}yINaaminM]h@M"><field name="VAR">valZufall</field></block></value> <value name="B"><block type="math_number" id="w)p6@Kl(M%rZZC2w[fk^"><field name="NUM">1</field></block></value></block></value> <value name="B"><block type="logic_compare" id="NzT3W6+2/WT;2uey(k24"><field name="OP">EQ</field> <value name="A"><block type="variables_get" id="d71W,pX%p`J72;8{kfdS"><field name="VAR">TimerAktiv1</field></block></value> <value name="B"><block type="logic_boolean" id="(%,AB0sDN!#y4ic_{VjS"><field name="BOOL">FALSE</field></block></value></block></value></block></value> <statement name="DO0"><block type="procedures_callnoreturn" id="K0BT]GJP:#6Le6RdwqF8"><mutation name="ZufallEins"></mutation></block></statement> <value name="IF1"><block type="logic_operation" id="3I.%g:o.nI/5~#DJ.hzt"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="M0[QB+35R8YTEh=5Xge*"><field name="OP">EQ</field> <value name="A"><block type="variables_get" id="(tpMntf[RTlhk6nXF#Xk"><field name="VAR">valZufall</field></block></value> <value name="B"><block type="math_number" id="Nc.|J~M;eYEIWS|Q!J;l"><field name="NUM">2</field></block></value></block></value> <value name="B"><block type="logic_compare" id=")hk;+S;aGF4(LrZFiBGg"><field name="OP">EQ</field> <value name="A"><block type="variables_get" id="2lHQKNO*mK.%;jMHNz,R"><field name="VAR">TimerAktiv2</field></block></value> <value name="B"><block type="logic_boolean" id="*5::xUcUsAP(GD7FbIP7"><field name="BOOL">FALSE</field></block></value></block></value></block></value> <statement name="DO1"><block type="procedures_callnoreturn" id="W87g2nl8jprwJXB]J[hw"><mutation name="ZufallZwei"></mutation></block></statement> <value name="IF2"><block type="logic_operation" id="gKdCsn^p71oA=GfsuDQF"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="g*j}gnPUy#/5aHdoBnr@"><field name="OP">EQ</field> <value name="A"><block type="variables_get" id="leS?FhGaeYN^U_eW=UC@"><field name="VAR">valZufall</field></block></value> <value name="B"><block type="math_number" id="L+jsa(J@;}6M8Rr%a}Yd"><field name="NUM">3</field></block></value></block></value> <value name="B"><block type="logic_compare" id="V.0UinW/HOMtzsSO~vfn"><field name="OP">EQ</field> <value name="A"><block type="variables_get" id="eAK,rKQ|x[!;:KUE3;Tq"><field name="VAR">TimerAktiv3</field></block></value> <value name="B"><block type="logic_boolean" id="Fc6Bpci,#--yqGe0==Jt"><field name="BOOL">FALSE</field></block></value></block></value></block></value> <statement name="DO2"><block type="procedures_callnoreturn" id="{;AN3#fKQQ0kBms}=oDy"><mutation name="ZufallDrei"></mutation></block></statement> <value name="IF3"><block type="logic_compare" id="Kula=B]?Qm,8|hl@Lfw9"><field name="OP">EQ</field> <value name="A"><block type="variables_get" id=".Jh!eEfh;x(*4U6_axex"><field name="VAR">valZufall</field></block></value> <value name="B"><block type="math_number" id="wO2~:2csDCrDbtSo]847"><field name="NUM">4</field></block></value></block></value> <statement name="DO3"><block type="procedures_callnoreturn" id="@/vd7WZAX_Z^jPucS.%+"><mutation name="ZufallVier"></mutation></block></statement></block></next></block></statement></block></statement></block> <block type="procedures_defnoreturn" id="j6lr*@jITsr]ms8yhUh0" x="613" y="-12"><field name="NAME">ZufallZwei</field> <comment pinned="false" h="80" w="160">Beschreibe diese Funktion …</comment> <statement name="STACK"><block type="debug" id="Yj?[d2mz/jUbw6B@}i^w"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="`7k{/9%WdRZg%WaMby}Z"><field name="TEXT">5 Min</field></shadow> <block type="variables_get" id=")6F1e[,wecN:0#OxtHo5"><field name="VAR">valZufall</field></block></value> <next><block type="comment" id="(K~gPu|WTF3rn%_]Wu|p"><field name="COMMENT">Schalte etwas ein</field> <next><block type="control" id="hF)HlaS*VSz}`sd3u(K*"><mutation delay_input="false"></mutation> <field name="OID">rflink.0.channels.TriState_1.SWITCH_0</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="VEqZzRpfd`LSx-UGb(Yp"><field name="BOOL">TRUE</field></block></value> <next><block type="variables_set" id="{(kXy~N;Z`.QRt}v*r3I"><field name="VAR">TimerAktiv2</field> <value name="VALUE"><block type="logic_boolean" id="G6@Xxm=)a-dD[j{I=Yfv"><field name="BOOL">TRUE</field></block></value> <next><block type="timeouts_settimeout" id="xefMj,DIwtkW*2@Phw1Q"><field name="NAME">timeout2</field> <field name="DELAY">3</field> <field name="UNIT">min</field> <statement name="STATEMENT"><block type="comment" id="A[?425Oyazos+*y8;Y2:"><field name="COMMENT">Schalte etwas wieder aus</field> <next><block type="control" id=")u;,dqM7ph}ThmI^d%]_"><mutation delay_input="false"></mutation> <field name="OID">rflink.0.channels.TriState_1.SWITCH_0</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="Vk8^EBNG^g8LdOV)VAEU"><field name="BOOL">FALSE</field></block></value> <next><block type="variables_set" id="W,)iWjtj;*J1`9I8rbs8"><field name="VAR">TimerAktiv2</field> <value name="VALUE"><block type="logic_boolean" id="P=PZWs~Sdnb/7A_g1IMp"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></statement></block> <block type="procedures_defnoreturn" id=",%sXx)neL(hBuOH~l%%9" x="638" y="313"><field name="NAME">ZufallDrei</field> <comment pinned="false" h="80" w="160">Beschreibe diese Funktion …</comment> <statement name="STACK"><block type="debug" id="k}),=oVBLM[qL:1,0K=%"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="`7k{/9%WdRZg%WaMby}Z"><field name="TEXT">5 Min</field></shadow> <block type="variables_get" id="zY3NJB^6bk2C?gA/]Qa9"><field name="VAR">valZufall</field></block></value> <next><block type="comment" id="|;jKXPh/w,O.!TE~)5y6"><field name="COMMENT">Schalte etwas ein</field> <next><block type="control" id="m4+CXk,T|or#|aW{.i+T"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.0.LEQ0494524.1.STATE</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="Q(S#(BE#-.9p9oL,hK5N"><field name="BOOL">TRUE</field></block></value> <next><block type="variables_set" id="WDYnD=%[7`Ot3b94P*cl"><field name="VAR">TimerAktiv3</field> <value name="VALUE"><block type="logic_boolean" id="m{t-glCB~U:?~U6VhWvj"><field name="BOOL">TRUE</field></block></value> <next><block type="timeouts_settimeout" id="TX2ufws`26#AES|*Hmty"><field name="NAME">timeout3</field> <field name="DELAY">2</field> <field name="UNIT">min</field> <statement name="STATEMENT"><block type="comment" id=";6|h5I,9xy=NsXaK6Pv{"><field name="COMMENT">Schalte etwas wieder aus</field> <next><block type="control" id="!jhRkjpNWwMSGP@^rT2."><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.0.LEQ0494524.1.STATE</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="Ejqj;h))SCTnq(A_hjDJ"><field name="BOOL">FALSE</field></block></value> <next><block type="variables_set" id="q7GtkJVZ!-R+JVdai^K("><field name="VAR">TimerAktiv3</field> <value name="VALUE"><block type="logic_boolean" id="p!%n^3t8Q}JFG!y8~NPI"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></statement></block> <block type="procedures_defnoreturn" id="Do%_Mz5D3j+7_(%A?wk/" disabled="true" x="-12" y="438"><field name="NAME">ZufallVier</field> <comment pinned="false" h="80" w="160">Beschreibe diese Funktion …</comment> <statement name="STACK"><block type="debug" id="SddePCHNGEv*O5)[L!|L"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="`7k{/9%WdRZg%WaMby}Z"><field name="TEXT">5 Min</field></shadow> <block type="variables_get" id="UT4Hs.*B(lrwTl%wbB)k"><field name="VAR">valZufall</field></block></value> <next><block type="comment" id="3YLO0h:c=8-gQE:yK^UE"><field name="COMMENT">Schalte etwas ein</field> <next><block type="control" id="3#h:eG@SGDYzq+.PR}-#"><mutation delay_input="false"></mutation> <field name="OID">rflink.0.channels.TriState_3.SWITCH_0</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id=":fB4T3=1f;/p~BLGV0Gw"><field name="BOOL">TRUE</field></block></value> <next><block type="variables_set" id="J@aYvxZPi`trWAlqpW25"><field name="VAR">TimerAktiv1</field> <value name="VALUE"><block type="logic_boolean" id="]`2SP#p@h51soMT{%i1q"><field name="BOOL">TRUE</field></block></value> <next><block type="timeouts_settimeout" id="ggJ~{/7+?n-Rgwq7%#EQ"><field name="NAME">timeout4</field> <field name="DELAY">5</field> <field name="UNIT">min</field> <statement name="STATEMENT"><block type="comment" id="%vHRMF@eG`;S!9BX6!V-"><field name="COMMENT">Schalte etwas wieder aus</field> <next><block type="control" id="R]o7o!C%.3q{`rFY}+=t"><mutation delay_input="false"></mutation> <field name="OID">rflink.0.channels.TriState_3.SWITCH_0</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="jm^qvJMwt6Lfc)MQLuF,"><field name="BOOL">FALSE</field></block></value> <next><block type="variables_set" id="P+H2zSavaOy=W@s*t)u?"><field name="VAR">TimerAktiv1</field> <value name="VALUE"><block type="logic_boolean" id="%##r%nr.Eg/VQGyd{[6f"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></statement></block> <block type="logic_compare" id="7oAh/Wmv*}k2Jb;t;V}U" disabled="true" x="-188" y="462"><field name="OP">NEQ</field> <value name="A"><block type="variables_get" id="umU+ee~y5%..vm%CJy7~"><field name="VAR">TimerAktiv3</field></block></value> <value name="B"><block type="logic_boolean" id="oA*;4q5PIsP+{LTQ8w7w"><field name="BOOL">TRUE</field></block></value></block></xml> !
      Rantanplan
        Belei
        Vielen Dank werde mich morgen damit mal beschäftigen.
        Ja den 4rten bekomme ich alleine fertig ;)
        Den Zustand erzeugen und aktualisieren läst man dan drin im Script?
          rantanplanR Offline
          rantanplan
          @Belei:
          Den Zustand erzeugen und aktualisieren läst man dan drin im Script? `
          Ein angelegter Datenpunkt wird nicht doppelt angelegt. Kann raus, muss aber nicht.
          Aktualisieren wird nur beim Scriptstart ausgeführt. Datenpunkt wird also beim Start immer auf unwahr gesetzt.
          Wenn Du das nicht möchtest, raus damit.
          Rantanplan
            Belei
            Guten Morgen,
            ich habe den Punkt Simulation auf True gesetzt und den Script gestartet.
            Mehr als das hier passiert leider nicht?
            ` > 09:33:23.691 [info] javascript.0 Start javascript script.js.Test.Skript1
            09:33:23.691 [info] javascript.0 script.js.Test.Skript1: schedule(cron=*/2 * * * *)
            09:33:23.692 [info] javascript.0 script.js.Test.Skript1: registered 0 subscriptions and 1 schedule
            09:34:00.689 [info] javascript.0 script.js.Test.Skript1: getState(id=javascript.0.SimulationAktiv, timerId=19) => {"val":true,"ack":true,"ts":1538724345666,"q":0,"from":"system.adapter.admin.0","lc":1538724050714}
            09:36:00.687 [info] javascript.0 script.js.Test.Skript1: getState(id=javascript.0.SimulationAktiv, timerId=19) => {"val":true,"ack":true,"ts":1538724345666,"q":0,"from":"system.adapter.admin.0","lc":1538724050714 `
              rantanplanR Offline
              rantanplan
              @Belei:
              ich habe den Punkt Simulation auf True gesetzt und den Script gestartet. `
              Und das "aktualisiere auf unwahr" beim Script-Start raus genommen?
              Wenn nicht, ist sehr kontraproduktiv den Datenpunkt auf "wahr" zu setzen und danach das Script zu starten.
              Rantanplan
                Belei
                Nein den Teil hab ich deaktiviert.
                  rantanplanR Offline
                  rantanplan
                  Hmm, zeig mal Dein aktuelles Blockly. (Export)
                  Rantanplan
                    Belei
                      <block type="create" id="luNmgal2UD@aFdYv,`C`" disabled="true" x="-187" y="-238"><field name="NAME">SimulationAktiv</field>
                        <next><block type="update" id="hA:I]9Ku^t7[x@{7Qi3m" disabled="true"><mutation delay_input="false"></mutation>
                                                        <value name="VALUE"><block type="logic_boolean" id="%##r%nr.Eg/VQGyd{[6f"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></statement></block></xml>
                      rantanplanR Offline
                      rantanplan
                      Hallo Belei
                      Sorry, mein Fehler :(
                      Lokale Variablen haben beim Script-Start keinen definierten Zustand.
                      Man sollte diese immer initialisieren!
                      Habe ich bei diesem "Schnellschuss" nicht gemacht. :oops:
                      Rantanplan
                      • rantanplanR rantanplan
                        Hallo Belei
                        michael_4358
                        Hallo
                        Ich weiß das Thema ist schon etwas angestaubt... 😇
                        Aber
                        Hat das schonmal wer weiter gemacht???
                        • David G.D Online
                          David G.D Online
                          David G.
                          Hier haben wir auch eine ganz schöne Lösung erarbeitet, für einen zufälligen Zeitbereich
                          klick
                          • David G.D David G.
                            klick
                            michael_4358
                            @David-G
                            da läuft das script immer nur ein mal durch....
                            wie kann ich das einstellen das es immer in dauerschleife rennt?
                            David G.D 2 Antworten Letzte Antwort
                            • M michael_4358
                              @David-G
                              David G.D Online
                              David G.D Online
                              David G.
                              @michael_4358
                              Es wird jeden Tag neu getriggert. In meinem Fall zum Sonnenuntergang minus 30min.
                              Ergänze es gleich mal komplett.
                                @michael_4358
                                michael_4358
                                schrieb am zuletzt editiert von michael_4358
                                @David-G
                                aber kann ich es nicht mittels telegram starten und dann solange laufen lassen bis ich es wieder auf false setze?
                                sonst ist nach einmal stop
                                EdiT:
                                oder mittels eine telegram auswahl mit wiederholungen starten?
                                • M michael_4358
                                  @David-G
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  @michael_4358
                                  Auf die schnelle mal so, morgen bin ich wieder am Rechner.
                                  Könnte man ggf noch mit einer Schleife optimieren.
                                    @michael_4358
                                    michael_4358
                                    @David-G
                                    ich hab das ähnlich mir fehlt halt die schleife das es immer neu startet... das bekomme ich nicht hin
                                    • M michael_4358
                                      @David-G
                                      David G.D Online
                                      David G.D Online
                                      David G.
                                      @michael_4358
                                      Am Ende vom Script kann man ggf einen Datenpunkt ändern, auf den dann wieder ein zufallstrigger gestartet wird der das Script zum Lampen schalten Triggert.
