  4. [Aufruf] Test Shelly Adapter
shellyadapter
717 Beiträge 81 Kommentatoren 262.3k Aufrufe 30 Beobachtet
  • I Offline
    I Offline
    ingostein
    Ach, lässt mir jetzt keine Ruhe…
    Hat leider nix gebracht.
    Wechselt nur wieder kurz von false auf true.
    Hier das Log:
    shelly.0 2018-09-30 21:13:08.720 debug stateChange shelly.0.SHSW-21#9F6224#1.Relay1.Switch {"val":false,"ack":true,"ts":1538334788714,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1538334788714}
    shelly.0 2018-09-30 21:13:08.712 debug Status update received for SHSW-21#9F6224#1: {"G":[[0,112,0],[0,122,0],[0,111,0]]}
    shelly.0 2018-09-30 21:13:08.712 debug CoAP status package received: {"3332":"SHSW-21#9F6224#1","3412":38400,"3420":52736,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,111,0]]}
    shelly.0 2018-09-30 21:13:08.633 debug REST Response {"state":"stop","power":0,"is_valid":true,"safety_switch":false,"stop_reason":"normal","last_direction":"close"}
    shelly.0 2018-09-30 21:13:08.611 debug Call REST GET http://192.168.178.30/roller/0 with {"go":"stop","duration":20}
    shelly.0 2018-09-30 21:13:08.610 debug RollerDown: {"go":"stop","duration":20}
    shelly.0 2018-09-30 21:13:08.609 debug stateChange shelly.0.SHSW-21#9F6224#1.Shutter.Close {"val":false,"ack":false,"ts":1538334788604,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1538334788604}
    shelly.0 2018-09-30 21:13:08.456 debug CoAP data ignored: {"3332":"SHSW-44#062073#1","3412":38400,"3420":16640,"Uri-Path":"cit/s"} / {"G":[[0,111,0],[0,112,0],[0,121,0],[0,122,0],[0,131,0],[0,132,0],[0,141,0],[0,142,0]]}
    shelly.0 2018-09-30 21:13:07.731 debug stateChange shelly.0.SHSW-21#9F6224#1.Relay1.Switch {"val":true,"ack":true,"ts":1538334787726,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1538334787726}
    shelly.0 2018-09-30 21:13:07.724 debug Status update received for SHSW-21#9F6224#1: {"G":[[0,112,0],[0,122,1],[0,111,0]]}
    shelly.0 2018-09-30 21:13:07.723 debug CoAP status package received: {"3332":"SHSW-21#9F6224#1","3412":38400,"3420":52480,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,1],[0,111,0]]}
    shelly.0 2018-09-30 21:13:07.625 debug REST Response {"state":"close","power":0,"is_valid":true,"safety_switch":false,"stop_reason":"normal","last_direction":"close"}
    shelly.0 2018-09-30 21:13:07.597 debug Call REST GET http://192.168.178.30/roller/0 with {"go":"close","duration":20}
    shelly.0 2018-09-30 21:13:07.597 debug RollerDown: {"go":"close","duration":20}
    shelly.0 2018-09-30 21:13:07.596 debug stateChange shelly.0.SHSW-21#9F6224#1.Shutter.Close {"val":true,"ack":false,"ts":1538334787590,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1538334787590}
    • StuebiS Offline
      StuebiS Offline
      Stuebi
      wenn ich mir das Logfile anschaue, dann hast Du eine Duration von 20 Sekunden mitgegeben.
      Drücke in ioBroker mit z.B. einer Duration von 30 Sekunden close oder open und schaue parallel auf die Shelly App. Da siehst Du dann (hoffentlich), dass der der open oder close Prozess dann 30 Sek. dauert.
      Du kannst auch beim drücken von open/close dir einmal den Status unter relay0/switch (open) und relay1/switch (close) anschauen. Die Werte sollten auf true stehen und nach 30 Sekunden (bei Duration 30) auf false wechseln. Passt das?
      ioBroker auf Synology DS216+II im Docker Container
      • apollon77A Offline
        Die Frage wäre auch ob eine Bedienung per Shelly App genauso tickt wie bei 20s oder anders …
        • I Offline
          I Offline
          ingostein
          Also…
          wie schon geschrieben, ist das Problem nur wenn ich ein Tast-Signal vorgebe.
          Lasse ich das Signal anstehen,durch gedrückt lassen des Widgets oder ändern auf schaltend, läuft die vorgegebene Zeit ab und das Relais fällt ab.
          Duration in Iobroker auf 30sek gestellt, bringt nichts, Relais fällt wieder ab.(Tastend)
          Zu sehen auch in der App, Symbol ändert sich kurz und springt dann auf up oder down.
          Schaltend funktionierts (30sek)
          Über die Shelly-App geschaltet, eingestellte Zeit in der App von 20sek,läuft und schaltet nach Zeit ab.
          Alles auch paralell zu sehen in Iobroker unter Objekte bei Relay0 und Relay1 (false/true)
          oder in der App.
          Sind die Settings in der Shelly-App für Iobroker (außer natürlich Rollermode) irgendwie relevant??
          Ich habe im Haus, Standard Jalousieschalter mit zwei Wippen verbaut und dementsprechend auch die Settings in der App angepasst.
          Input Buttons Mode - Open&Close Buttons - Use seperate buttons for open&close
          Button-Type - Momentary - Press Button 1 for open and Button 2 for close.
          Mode - Roller Shutter
          Nicht dass das irgendwie dazwischen funkt...
            @ingostein:
            Also…
            oder in der App. `
            Ok, dann genauer: Was genau "tastest" Du und wie? Welche Datenpunkte. Ich habe das gefühl das da irgendwas komisch ist - oder die API von Shelly macht nicht was Sie soll.
            Im Roller/Shutter Modus solltest Du ausschliesslich per Shutter.up/down/stop arbeiten!
            Im Relaymodus sind die RelayX.Swith Datenpunkte als Schalter definiert die Du auf true setzt für "Ein" oder auf False für "Aus".
            @ingostein:
            Nicht dass das irgendwie dazwischen funkt… `
            Weil wir uns genau in die Settings der App nicht einmischen wollen senden wir nur "hoch", "runter" und "stop" kommandos und alles was bei Roller/Shutter in der App eingestellt ist sollte gelten weil die Logik von dem Shelly device gemacht wird.
            Also am allerbesten: Debug-Log einschalten.
            Dann machst Du eine Aktion, schreibst genau was Du getan hast und schickst das Stückchen Log dazu was da passiert ist …
            Sowohl Thorsten als auch ich habe das getestet und bei uns tut es wie es soll.
            Ich würde gern verstehen was da bei Dir passiert.
            • I Offline
              I Offline
              ingostein
              Anbei drei Bilder vom Widget open/pause/close mit den Datenpunkten vom Shelly.
              Getastet wird open/pause/close.
              Widget "open" angeklickt:
              shelly.0 2018-09-30 23:54:24.428 debug stateChange shelly.0.SHSW-21#9F6224#1.Relay0.Switch {"val":false,"ack":true,"ts":1538344464424,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1538344464424}
              shelly.0 2018-09-30 23:54:24.413 debug Status update received for SHSW-21#9F6224#1: {"G":[[0,112,0],[0,122,0],[0,111,0]]}
              shelly.0 2018-09-30 23:54:24.412 debug CoAP status package received: {"3332":"SHSW-21#9F6224#1","3412":38400,"3420":15361,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,111,0]]}
              shelly.0 2018-09-30 23:54:24.345 debug REST Response {"state":"stop","power":0,"is_valid":true,"safety_switch":false,"stop_reason":"normal","last_direction":"open"}
              shelly.0 2018-09-30 23:54:24.325 debug Call REST GET http://192.168.178.30/roller/0 with {"go":"stop","duration":30}
              shelly.0 2018-09-30 23:54:24.324 debug RollerUp: {"go":"stop","duration":30}
              shelly.0 2018-09-30 23:54:24.324 debug stateChange shelly.0.SHSW-21#9F6224#1.Shutter.Open {"val":false,"ack":false,"ts":1538344464319,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1538344464319}
              shelly.0 2018-09-30 23:54:23.419 debug stateChange shelly.0.SHSW-21#9F6224#1.Relay0.Switch {"val":true,"ack":true,"ts":1538344463414,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1538344463414}
              shelly.0 2018-09-30 23:54:23.412 debug Status update received for SHSW-21#9F6224#1: {"G":[[0,112,1],[0,122,0],[0,111,0]]}
              shelly.0 2018-09-30 23:54:23.412 debug CoAP status package received: {"3332":"SHSW-21#9F6224#1","3412":38400,"3420":15105,"Uri-Path":"cit/s"} / {"G":[[0,112,1],[0,122,0],[0,111,0]]}
              shelly.0 2018-09-30 23:54:23.347 debug REST Response {"state":"open","power":0,"is_valid":true,"safety_switch":false,"stop_reason":"normal","last_direction":"open"}
              shelly.0 2018-09-30 23:54:23.323 debug Call REST GET http://192.168.178.30/roller/0 with {"go":"open","duration":30}
              shelly.0 2018-09-30 23:54:23.322 debug RollerUp: {"go":"open","duration":30}
              shelly.0 2018-09-30 23:54:23.322 debug stateChange shelly.0.SHSW-21#9F6224#1.Shutter.Open {"val":true,"ack":false,"ts":1538344463315,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1538344463315}
              Widget "close" angeklickt:
              shelly.0 2018-09-30 23:56:10.289 debug stateChange shelly.0.SHSW-21#9F6224#1.Relay1.Switch {"val":false,"ack":true,"ts":1538344570285,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1538344570285}
              shelly.0 2018-09-30 23:56:10.284 debug Status update received for SHSW-21#9F6224#1: {"G":[[0,112,0],[0,122,0],[0,111,0]]}
              shelly.0 2018-09-30 23:56:10.283 debug CoAP status package received: {"3332":"SHSW-21#9F6224#1","3412":38400,"3420":15873,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,111,0]]}
              shelly.0 2018-09-30 23:56:10.217 debug REST Response {"state":"stop","power":0,"is_valid":true,"safety_switch":false,"stop_reason":"normal","last_direction":"close"}
              shelly.0 2018-09-30 23:56:10.200 debug Call REST GET http://192.168.178.30/roller/0 with {"go":"stop","duration":30}
              shelly.0 2018-09-30 23:56:10.200 debug RollerDown: {"go":"stop","duration":30}
              shelly.0 2018-09-30 23:56:10.199 debug stateChange shelly.0.SHSW-21#9F6224#1.Shutter.Close {"val":false,"ack":false,"ts":1538344570195,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1538344570195}
              shelly.0 2018-09-30 23:56:09.308 debug stateChange shelly.0.SHSW-21#9F6224#1.Relay1.Switch {"val":true,"ack":true,"ts":1538344569304,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1538344569304}
              shelly.0 2018-09-30 23:56:09.302 debug Status update received for SHSW-21#9F6224#1: {"G":[[0,112,0],[0,122,1],[0,111,0]]}
              shelly.0 2018-09-30 23:56:09.301 debug CoAP status package received: {"3332":"SHSW-21#9F6224#1","3412":38400,"3420":15617,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,1],[0,111,0]]}
              shelly.0 2018-09-30 23:56:09.220 debug REST Response {"state":"close","power":0,"is_valid":true,"safety_switch":false,"stop_reason":"normal","last_direction":"close"}
              shelly.0 2018-09-30 23:56:09.201 debug Call REST GET http://192.168.178.30/roller/0 with {"go":"close","duration":30}
              shelly.0 2018-09-30 23:56:09.200 debug RollerDown: {"go":"close","duration":30}
              shelly.0 2018-09-30 23:56:09.199 debug stateChange shelly.0.SHSW-21#9F6224#1.Shutter.Close {"val":true,"ack":false,"ts":1538344569189,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1538344569189}
              Widge "open" "gedrückt" gehalten:
              shelly.0 2018-09-30 23:57:47.699 debug REST Response {"state":"stop","power":0,"is_valid":true,"safety_switch":false,"stop_reason":"normal","last_direction":"open"}
              shelly.0 2018-09-30 23:57:47.680 debug Call REST GET http://192.168.178.30/roller/0 with {"go":"stop","duration":30}
              shelly.0 2018-09-30 23:57:47.680 debug RollerUp: {"go":"stop","duration":30}
              shelly.0 2018-09-30 23:57:47.679 debug stateChange shelly.0.SHSW-21#9F6224#1.Shutter.Open {"val":false,"ack":false,"ts":1538344667675,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1538344667675}
              shelly.0 2018-09-30 23:57:46.979 debug stateChange shelly.0.SHSW-21#9F6224#1.Relay0.Switch {"val":false,"ack":true,"ts":1538344666975,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1538344666975}
              shelly.0 2018-09-30 23:57:46.973 debug Status update received for SHSW-21#9F6224#1: {"G":[[0,112,0],[0,122,0],[0,111,0]]}
              shelly.0 2018-09-30 23:57:46.973 debug CoAP status package received: {"3332":"SHSW-21#9F6224#1","3412":38400,"3420":16385,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,111,0]]}
              shelly.0 2018-09-30 23:57:16.989 debug stateChange shelly.0.SHSW-21#9F6224#1.Relay0.Switch {"val":true,"ack":true,"ts":1538344636985,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1538344636985}
              shelly.0 2018-09-30 23:57:16.983 debug Status update received for SHSW-21#9F6224#1: {"G":[[0,112,1],[0,122,0],[0,111,0]]}
              shelly.0 2018-09-30 23:57:16.982 debug CoAP status package received: {"3332":"SHSW-21#9F6224#1","3412":38400,"3420":16129,"Uri-Path":"cit/s"} / {"G":[[0,112,1],[0,122,0],[0,111,0]]}
              shelly.0 2018-09-30 23:57:16.927 debug REST Response {"state":"open","power":0,"is_valid":true,"safety_switch":false,"stop_reason":"normal","last_direction":"open"}
              shelly.0 2018-09-30 23:57:16.878 debug Call REST GET http://192.168.178.30/roller/0 with {"go":"open","duration":30}
              shelly.0 2018-09-30 23:57:16.877 debug RollerUp: {"go":"open","duration":30}
              shelly.0 2018-09-30 23:57:16.877 debug stateChange shelly.0.SHSW-21#9F6224#1.Shutter.Open {"val":true,"ack":false,"ts":1538344636873,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1538344636873}
              Ich habe die "CoAP data ignored" Punkte entfernt, sonst wird das Log zu lang.
              • StuebiS Offline
                StuebiS Offline
                Stuebi
                Ich habe das Problem gefunden. Du nutzt einen Taster als Widget. Sobald Du den Taster drückst, wird einmal kurz true und gleich danach false an das close bzw. oben Shelly Objekt gesendet. Ich habe aber es im Shelly Adapter momentan so programmiert, das beim Objekt open/close bei Status false die Rollläden auch gestoppt werden.
                Tu mir bitte einmal den Gefallen und lade über Adapter -> GitHub -> externen Link https://github.com/schmupu/ioBroker.shelly die neuste Version (0.2.3). Dann nimm den Hacken bei Taster für open/close/stop heraus. Wenn Du jetzt z.B. open drückst, wird dir bei einer Duration von 20 sek (Default Wert), 20 Sekunden open, als aktiv angezeigt, danach als inaktiv.
                • I Offline
                  I Offline
                  ingostein
                  danke für Eure Mühe.
                  Update habe ich gemacht auf 0.2.3.
                  Ohne die Option "Taster" also als Schalter, hatte es auch vorher funktioniert.
                  Das Problem ist, das der Button optisch nicht zurückspringt und optisch geschaltet bleibt, ist dann ja als Schalter definiert.
                  Somit muss man diesen wieder händlich zurückschalten auf 0.
                  Auch ein entfernen der Werte false/true bei Wert min: max: im Widget, bringt leider nix.
                  Wie habt Ihr denn optisch Euro Rolladenschalter visualisiert?
                  • StuebiS Offline
                    StuebiS Offline
                    Stuebi
                    wundert mich jetzt, genau das habe ich in Version 0.2.3 angepaßt. Wenn du jetzt z.B. auf Open drückst, wird der Wert auf true gesetzt und nach 20 Sekunden (duration time) wechselt der Wert von true auf false. Dementsprechend wird die Farbe des Widget angepaßt.
                      ok, mal ein paar Infos zum Aufräumen der Verwirrungen:
                      Die Datenpunkte für Up, Down und Stop sind als "Buttons" definiert. Dies bedeutet Sie werden mit einem Wert von true getriggert, haben aber selbst keinen "State" (So wie ein Taster an deiner Wand - dem siehst DU auch nicht an ob er gerade gedrückt wurde). Das ist genau das was wir auch API Technisch an den Shelly weitergeben. Ein Steuerkommando auf den Button sendet einen Befehl an den Shelly. Was der dann tut wissen wir auf Adapterseite nicht. Die Up, Down und Stop Datenpunkte können daher auch nicht für eine Visualisierung genutzt werden, weil Sie halt keinen Status haben!
                      Formal (laut Definition und wie es z.B. Homematic macht) werden Buttons auch nie auf "value=false" zurückgesetzt sondern bleiben auch value=true mit "unbestätigt" stehen weil der Button nur getriggert hat und nicht weiss was danach passiert. Hier hat Thorsten schon hier und da ein Rücksetzen eingebaut. Aber auch dann ist es nicht gesetzt das z.B. Up so lange auf true steht wie nach oben gefahren wird - weil das wissen wir gar nicht.
                      Visualisieren müsstest Du über die RelayX Datenpunkte weil auch nur Du als User weisst was wie konfiguriert ist - also welcher Relay hoch und welcher runter ist.
                      Der Trick wäre hier also die Visualisiserung so zu machen das Du den Status von Relay0.Switch und Relay1.Switch nutzt um deine zwei Pfeile und den Stop Button anzuzeigen vom Status her (z.B. per "Working Datenpunkte im Widget), aber die entsprechenden Roller.XY Datenpunkte triggerst wenn jemand drückt (z.B. SIgnal Objekt-ID im Widget).
                      Ingo
                        Stoni
                        Hallo, von den Homematic Aktoren weiß ich, dass sie besonders sensibel bei Led Leuchten reagieren. Da sollte man grundsätzlich Einschaltstrom-Begrenzer zwischen bauen.
                        Wie verhält es sich dazu mit den Shellys??
                        Wird beim Einbau hinter den Lichtschalter die tiefe Einbaudose benötigt oder hat es schon jemand geschafft, den Shelly in eine normale (47mm Hohlraum-) Dose einzubauen?
                        • StuebiS Offline
                          StuebiS Offline
                          Stuebi
                          Ingo, ich habe auf GitHub den Shelly Adapter jetzt so angepasst, dass er im Rolladen Modus als Button agiert. Wert ist kurz true und dann gleich false. Status ist wie appolon77 beschrieben abzufragen
                          • E Offline
                            eagleye
                            @tstueben:
                            @eagleye:
                            @apollon77:
                            Naja aktuell ist das kein bug sondern „intended“. Müssen wir mal schauen. `
                            naja, ist schon frustrierend und die usability leidet sehr wenn mann in einer script-Umgebung nicht weiß was gerade geschaltet wird und jedesmal per try and error herausgefunden werden muss. hoffe das wird bald gefixt, dass ist IMHO sehr wichtig.
                            Danke `
                            Den Device Namen kannst Du jetzt anpassen! In meinem Bsp. heißt das Device jetzt "Haustür"
                            Bildschirmfoto 2018-09-29 um 15.57.04.png `
                            Super!!
                            Vielen Dank für die tolle Arbeit
                            • I Offline
                              I Offline
                              ingostein
                              @tstueben:
                              Gesendet von iPhone mit Tapatalk `
                              Super!!
                              Eben funktionierts!
                              Vielen Dank Euch!
                              • StuebiS Offline
                                StuebiS Offline
                                Stuebi
                                eben auf https://www.facebook.com/groups/1686781668087857/permalink/1773415342757822/ entdeckt. Falls Ihr den Shelly1 in Version 2 besitzt umbedingt lesen!
                                __IMPORTANT ANNOUNCEMENT:
                                If you receive Shelly1 witch have on the label: Shelly V2 - DO NOT WIRE IT as showing in user manual and label
                                There is a correct wire diagram and label.
                                Why V2: We try to switch L and N terminal to make programing port safer, but unfortunately this cause another issue and device can burn in some situations (when use standard light switch connected to SW). The devices inside are absolutely same, just label for V2 are changed.
                                There is a limited numbers Shelly1 with label v2 shipped from 21. Sept to 30. Sept. We will send e-mail and make a call to everyone witch will received.__
                                • F Offline
                                  FoxMulder
                                  Habe auch vorhin eine Hinweis Mail von denen bekommen .
                                  Bin gespannt, was meine so für aufkleber haben .Am besten währe ,wenn sie die alten Aufkleber an die kunden verschicken ,um es zu überkleben .
                                  Wer weiß ob man sich nach Jahren noch dran erinnern kann, daß N und L gedreht ist
                                  Gesendet von meinem SM-G950F mit Tapatalk
                                    Naja zum Glück gibts auch schwarzen Edding :-)
                                    • J Offline
                                      jerzimeik
                                      Wann meint ihr ungefährt, dass das Update kommt? #neugierig
                                      • StuebiS Offline
                                        StuebiS Offline
                                        Stuebi
                                        @jerzimeik:
                                        Wann meint ihr ungefährt, dass das Update kommt? #neugierig `
                                        Was für ein Update meinst du?
                                        • J Offline
                                          jerzimeik
                                          #66
                                          Sorry, ich hatte die falsche Seite noch aufgerufen.
                                          Update ist ja schon längst da ;-)
                                          Kämpfe mich jetzt mal da durch.
