  4. (gelöst) Bekomme ioBroker nicht installiert
    1.0k
    6.1k
46 Beiträge 10 Kommentatoren 10.3k Aufrufe 1 Beobachtet
    Daniel84
    ok dan teste ich die zweite
      Daniel84
      node_modules/registry-url/node_modules
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/update-notifier/node_modules/latest-version/node_modules
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-license/node_modules/spdx-correct/node_modules
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-name/node_modules
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which/node_modules
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/worker-farm/node_modules/errno/node_modules
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs
      npm ERR! path /usr/lib/node_modules/npm/node_modules/ansi-regex
      npm ERR! code EACCES
      npm ERR! errno -13
      npm ERR! syscall access
      npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/ansi-regex'
      npm ERR!  { Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/ansi-regex'
      npm ERR!   stack: 'Error: EACCES: permission denied, access \'/usr/lib/node_modules/npm/node_modules/ansi-regex\'',
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/ansi-regex' }
      npm ERR!
      npm ERR! Please try running this command again as root/Administrator.
      npm ERR!     /home/pi/.npm/_logs/2018-07-14T18_37_30_085Z-debug.log
      pi@raspberrypi:~ $
      Edit by eric2905, Code bitte immer in Code-Tags setzen!
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        Welchen Befehl hat du eingegeben?
        Sudo davor gesetzt?
          Daniel84
          instaliert er auch nicht . denke ich versuchs mal mit formatieren. und dan direkt die npm 5 drauf oder?
            Daniel84
            ne nur (npm install -g npm@latest)
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              @Daniel84:
              instaliert er auch nicht . denke ich versuchs mal mit formatieren. und dan direkt die npm 5 drauf oder? `
              Wen das eine Möglichkeit ist Jah.
              Neuinstallation und Dan npm 8 installieren, Dan npm Updaten und danach ioBroker installieren
              • DutchmanD Offline
                DutchmanD Offline
                Dutchman
                @Daniel84:
                ne nur (npm install -g npm@latest) `
                Ok, das Log sagt "write permission Error" also sudo davor !
                  Daniel84
                  Grosser got!
                  iobroker installation läuft :)
                  Man ist auch manchmal vorm baum gelaufen…
                  Danke!!
                    Na denn viel Glück weiterhin!
                    Sieht also so aus, als ob bei nodejs.org das repo für die Version 6.x defekt ist :(
                    Da können wir auch nichts dran ändern.
                    @all
                    Bitte ebenfalls mit
                     curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                    installieren.
                      MarkusP
                      @Homoran:
                      Nach welcher Anleitung genau???
                      du hast zwei verschiedene Installationen parallel drauf.
                      Rainer `
                      Nach dem 14. Neuaufsetzen des Systems hat es nun endlich geklappt. Node / Nodejs Version ist nun 8.x und NPM war 5.x und wurde von mir auf 4.x downgegraded. ioBorker läuft und Restore vom Backup hat auch funktioniert.
                      Frage mich nur, warum bei den ersten Versuchen Node/js falsch und NPM nicht mitinstalliert wurden.
                        @MarkusP:
                        Frage mich nur, warum bei den ersten Versuchen Node/js falsch und NPM nicht mitinstalliert wurde `
                        @Homoran:
                        Sieht also so aus, als ob bei nodejs.org das repo für die Version 6.x defekt ist `
                        streiche "ist" -> setze "war"
                        Habe nämlich gerade auch meine produktive Installation upgedatet, ohne Probleme.
                        ich gehe davon aus, dass das Repo wieder rund läuft.
                        Mal sehen ob es noch weiterhin User mit Problemen geben wird.
                          Daniel84
                          Hallo zusamen,
                          Ich habe erneut ein Problem iobroker zu instalieren.
                          pi@phoscon:/opt/iobroker $ sudo npm install iobroker –unsafe-perm
                          iobroker@1.1.2 install /opt/iobroker/node_modules/iobroker
                          node lib/prepareSetup.js && node lib/setup.js
                          NPM version: 5.6.0
                          NPM 5 is only supported starting with version 5.7.1!
                          Please use "npm install -g npm@4" to downgrade npm to 4.x or
                          use "npm install -g npm@latest" to install a supported version of npm 5!
                          You need to make sure to repeat this step after installing an update to NodeJS and/or npm.
                          npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
                          npm WARN iobroker No description
                          npm WARN iobroker No repository field.
                          npm WARN iobroker No README data
                          npm WARN iobroker No license field.
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 4
                          npm ERR! iobroker@1.1.2 install: node lib/prepareSetup.js && node lib/setup.js
                          npm ERR! Exit status 4
                          npm ERR!
                          npm ERR! Failed at the iobroker@1.1.2 install script.
                          npm ERR! /root/.npm/_logs/2018-07-21T10_02_16_898Z-debug.log
                            Du hast aber schon gelesen was du hier postest?
                            @Daniel84:
                            use "npm install -g npm@latest" to install a supported version of npm 5! `
                            Gruß Rainer
                              Daniel84
                              Ja Sorry.
                              Bin etwas durch den wind.
                              Hab denn wald vor lauter bäumen nicht gesehen.
                              MFG Daniel
