  4. Javascript terminated with code 7 - Ursache?
    1.0k
    6.1k
25 Beiträge 5 Kommentatoren 6.3k Aufrufe
  • L Offline
    LJSven
    Das kommt bei mir bei dem Befehl:
    root@raspberrypi:~# ps auxww|grep io.
    root        10  0.0  0.0      0     0 ?        S    04:00   0:00 [migration/0]
    root        13  0.0  0.0      0     0 ?        S    04:00   0:00 [migration/1]
    root        18  0.0  0.0      0     0 ?        S    04:00   0:00 [migration/2]
    root        23  0.0  0.0      0     0 ?        S    04:00   0:00 [migration/3]
    root        40  0.0  0.0      0     0 ?        I<   04:00   0:00 [rpciod]
    root        41  0.0  0.0      0     0 ?        I<   04:00   0:00 [xprtiod]
    root        45  0.0  0.0      0     0 ?        I<   04:00   0:00 [nfsiod]
    root        58  0.0  0.0      0     0 ?        I<   04:00   0:00 [DWC Notificatio]
    message+   298  0.0  0.3   6508  3388 ?        Ss   04:00   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
    root     15488  0.0  0.0   4776   544 pts/0    S+   10:07   0:00 grep io.
    Log vom Neustart:
    2018-06-28 10:07:18.784 - info: host.raspberrypi received SIGTERM
    2018-06-28 10:07:24.788 - info: host.raspberrypi received SIGTERM
    2018-06-28 10:07:28.905 - info: host.raspberrypi force terminating
    2018-06-28 10:07:28.907 - info: Adapter admin still running
    2018-06-28 10:07:28.908 - info: Adapter discovery still running
    2018-06-28 10:07:28.909 - info: Adapter javascript still running
    2018-06-28 10:07:28.909 - info: Adapter sonos still running
    2018-06-28 10:07:28.909 - info: Adapter fritzdect still running
    2018-06-28 10:07:28.910 - info: Adapter sonoff still running
    2018-06-28 10:07:28.911 - info: Adapter cloud still running
    2018-06-28 10:07:28.911 - info: Adapter geofency still running
    2018-06-28 10:07:28.911 - info: Adapter rpi2 still running
    2018-06-28 10:07:28.912 - info: Adapter scenes still running
    2018-06-28 10:07:28.912 - info: Adapter web still running
    2018-06-28 10:07:28.913 - info: Adapter fritzbox still running
    2018-06-28 10:07:28.913 - info: Adapter sayit still running
    2018-06-28 10:07:28.914 - info: Adapter lgtv11 still running
    2018-06-28 10:07:28.915 - info: Adapter history still running
    2018-06-28 10:07:28.916 - info: Adapter email still running
    2018-06-28 10:07:28.916 - info: Adapter parser still running
    2018-06-28 10:07:28.917 - info: Adapter telegram still running
    2018-06-28 10:07:28.917 - info: Adapter text2command still running
    2018-06-28 10:07:28.918 - info: Adapter mqtt still running
    2018-06-28 10:07:28.918 - info: Adapter simple-api still running
    2018-06-28 10:07:28.918 - info: Adapter mihome still running
    2018-06-28 10:08:37.567 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
    2018-06-28 10:08:37.592 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2018-06-28 10:08:37.594 - info: host.raspberrypi hostname: raspberrypi, node: v6.14.3
    2018-06-28 10:08:37.598 - info: host.raspberrypi ip addresses: 192.168.178.44 fe80::ba6f:5d66:56f0:9b94
    2018-06-28 10:08:37.951 - info: host.raspberrypi inMem-states listening on port 9000
    2018-06-28 10:08:38.753 - info: host.raspberrypi inMem-objects listening on port 9001
    2018-06-28 10:08:38.800 - info: host.raspberrypi InMemoryDB connected
    2018-06-28 10:08:38.869 - info: host.raspberrypi 38 instances found
    2018-06-28 10:08:38.984 - info: host.raspberrypi starting 33 instances
    2018-06-28 10:08:39.129 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 15506
    2018-06-28 10:08:43.022 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 15512
    2018-06-28 10:08:46.201 - info: admin.0 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v6.14.3
    2018-06-28 10:08:46.297 - info: admin.0 requesting all states
    2018-06-28 10:08:46.307 - info: admin.0 requesting all objects
    2018-06-28 10:08:46.311 - info: admin.0 Request actual repository...
    2018-06-28 10:08:48.012 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 15522
    2018-06-28 10:08:48.563 - info: discovery.0 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.14.3
    2018-06-28 10:08:48.777 - info: admin.0 received all states
    2018-06-28 10:08:51.025 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 15532
    2018-06-28 10:08:52.168 - info: admin.0 received all objects
    2018-06-28 10:08:52.547 - info: admin.0 http server listening on port 8081
    2018-06-28 10:08:52.548 - info: admin.0 Use link "http://localhost:8081" to configure.
    2018-06-28 10:08:53.207 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    2018-06-28 10:08:55.064 - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 15538
    2018-06-28 10:08:57.638 - debug: javascript.0 objectDB connected
    2018-06-28 10:08:57.769 - debug: javascript.0 statesDB connected
    2018-06-28 10:08:57.967 - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.14.3
    2018-06-28 10:08:58.004 - info: javascript.0 requesting all states
    2018-06-28 10:08:58.013 - info: javascript.0 requesting all objects
    2018-06-28 10:08:58.201 - info: admin.0 Repository received successfully.
    2018-06-28 10:08:59.880 - info: host.raspberrypi instance system.adapter.sonoff.0 started with pid 15548
    2018-06-28 10:09:00.782 - info: sonos.0 starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.sonos, node: v6.14.3
    2018-06-28 10:09:01.226 - info: sonos.0 http sonos server listening on port 8083
    2018-06-28 10:09:01.299 - info: javascript.0 received all states
    2018-06-28 10:09:02.116 - info: fritzdect.0 starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v6.14.3
    2018-06-28 10:09:02.160 - info: fritzdect.0 entered ready
    2018-06-28 10:09:04.269 - info: sonoff.0 starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.14.3
    2018-06-28 10:09:04.511 - info: sonoff.0 Starting MQTT authenticated server on port 1883
    2018-06-28 10:09:06.809 - info: javascript.0 received all objects
    2018-06-28 10:09:07.336 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 15572
    2018-06-28 10:09:08.077 - info: fritzdect.0 Talking to FritzBox with firmware: 06.93
    2018-06-28 10:09:08.590 - info: fritzdect.0 create Devices 3
    2018-06-28 10:09:08.600 - info: fritzdect.0 setting up Thermostat/DECT3xx object Wohnzimmer Heizung
    2018-06-28 10:09:08.648 - info: fritzdect.0 setting up Switch/DECT2xx object Galerie TV
    2018-06-28 10:09:08.671 - info: fritzdect.0 setting up Switch/DECT2xx object Deko
    2018-06-28 10:09:08.534 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
    2018-06-28 10:09:08.873 - info: javascript.0 Start javascript script.js.common.Sonstige.Anwesenheit
    2018-06-28 10:09:09.087 - info: vis.0 vis license is OK.
    2018-06-28 10:09:10.851 - info: fritzdect.0 Comet ID: 109710237552 identified for command (targettemp) : 0
    2018-06-28 10:09:08.992 - info: javascript.0 script.js.common.Sonstige.Anwesenheit: registered 3 subscriptions and 0 schedules
    2018-06-28 10:09:08.994 - info: javascript.0 Start javascript script.js.common.Sonstige.Heizungssteuerung
    2018-06-28 10:09:09.092 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: Heizung - Mai bis September aus! Aussentemperatur beträgt 22
    2018-06-28 10:09:09.102 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: registered 2 subscriptions and 2 schedules
    2018-06-28 10:09:09.104 - info: javascript.0 Start javascript script.js.common.Sonstige.Dekobeleuchtung
    2018-06-28 10:09:09.154 - info: javascript.0 script.js.common.Sonstige.Dekobeleuchtung: registered 0 subscriptions and 1 schedule
    2018-06-28 10:09:09.156 - info: javascript.0 Start javascript script.js.common.Sonstige.Text-To-Speech
    2018-06-28 10:09:09.169 - info: javascript.0 script.js.common.Sonstige.Text-To-Speech: registered 1 subscription and 0 schedules
    2018-06-28 10:09:09.172 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Sport_2
    2018-06-28 10:09:09.289 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Sport_2: registered 0 subscriptions and 0 schedules
    2018-06-28 10:09:09.291 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Eurosport_HD_2
    2018-06-28 10:09:09.312 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Eurosport_HD_2: registered 0 subscriptions and 0 schedules
    2018-06-28 10:09:09.314 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Off
    2018-06-28 10:09:09.327 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Off: registered 1 subscription and 0 schedules
    2018-06-28 10:09:09.329 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_On
    2018-06-28 10:09:09.340 - info: javascript.0 script.js.common.Dreambox_EG.Standby_On: registered 1 subscription and 0 schedules
    2018-06-28 10:09:09.342 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Bundesliga
    2018-06-28 10:09:09.358 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Bundesliga: registered 0 subscriptions and 0 schedules
    2018-06-28 10:09:09.360 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Sport_1
    2018-06-28 10:09:09.377 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Sport_1: registered 0 subscriptions and 0 schedules
    2018-06-28 10:09:09.380 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Toggle
    2018-06-28 10:09:09.390 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Toggle: registered 1 subscription and 0 schedules
    2018-06-28 10:09:09.429 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Szene_Fussball_Bundesliga_Sky
    2018-06-28 10:09:09.452 - info: javascript.0 script.js.common.Dreambox_EG.Szene_Fussball_Bundesliga_Sky: registered 1 subscription and 0 schedules
    2018-06-28 10:09:09.472 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Standby_Off
    2018-06-28 10:09:09.482 - info: javascript.0 script.js.common.Dreambox_OG.Standby_Off: registered 1 subscription and 0 schedules
    2018-06-28 10:09:09.484 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Standby_On
    2018-06-28 10:09:09.539 - info: javascript.0 script.js.common.Dreambox_OG.Standby_On: request: http://root:LJSven300878@192.168.178.220:88/web/powerstate?newstate=4
    2018-06-28 10:09:09.541 - info: javascript.0 script.js.common.Dreambox_OG.Standby_On: registered 0 subscriptions and 0 schedules
    2018-06-28 10:09:09.555 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Sender.Eurosport_HD_2
    2018-06-28 10:09:09.597 - info: javascript.0 script.js.common.Dreambox_OG.Sender.Eurosport_HD_2: registered 0 subscriptions and 0 schedules
    2018-06-28 10:09:09.622 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Sender.Sky_Bundesliga
    2018-06-28 10:09:09.633 - info: javascript.0 script.js.common.Dreambox_OG.Sender.Sky_Bundesliga: registered 0 subscriptions and 0 schedules
    2018-06-28 10:09:09.635 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Key_EXIT
    2018-06-28 10:09:09.648 - info: javascript.0 script.js.common.Dreambox_OG.Key_EXIT: registered 1 subscription and 0 schedules
    2018-06-28 10:09:09.650 - info: javascript.0 Start javascript script.js.common.Sonstige.Alles_Aus_-_Schaltung
    2018-06-28 10:09:09.662 - info: javascript.0 script.js.common.Sonstige.Alles_Aus_-_Schaltung: registered 2 subscriptions and 0 schedules
    2018-06-28 10:09:09.665 - info: javascript.0 Start javascript script.js.common.Sonstige.Astro-Tageszeit
    2018-06-28 10:09:09.756 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: es wird Nacht: false
    2018-06-28 10:09:09.790 - warn: javascript.0 Cannot calculate "night" for 52.0882309, 7.0213161
    2018-06-28 10:09:09.792 - warn: javascript.0 Cannot calculate "nightEnd" for 52.0882309, 7.0213161
    2018-06-28 10:09:09.822 - warn: javascript.0 Cannot calculate "night" for 52.0882309, 7.0213161
    2018-06-28 10:09:10.133 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: registered 0 subscriptions and 10 schedules
    2018-06-28 10:09:10.137 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Status_DB_EG
    2018-06-28 10:09:10.470 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Status_DB_EG: registered 0 subscriptions and 1 schedule
    2018-06-28 10:09:10.472 - info: javascript.0 Start javascript script.js.common.Sonstige.Dreambox_OG_Standby-Prüfung
    2018-06-28 10:09:10.482 - info: javascript.0 script.js.common.Sonstige.Dreambox_OG_Standby-Prüfung: registered 1 subscription and 0 schedules
    2018-06-28 10:09:10.485 - info: javascript.0 Start javascript script.js.common.Bad.Bad_Sonos_Automation
    2018-06-28 10:09:10.495 - info: javascript.0 script.js.common.Bad.Bad_Sonos_Automation: registered 1 subscription and 0 schedules
    2018-06-28 10:09:10.498 - info: javascript.0 Start javascript script.js.common.Sonstige.Telegram_Button
    2018-06-28 10:09:10.511 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
    2018-06-28 10:09:10.514 - info: javascript.0 script.js.common.Sonstige.Telegram_Button: registered 0 subscriptions and 0 schedules
    2018-06-28 10:09:10.538 - info: javascript.0 Start javascript script.js.common.Sonstige.Bewegungsmelder_Script
    2018-06-28 10:09:10.548 - info: javascript.0 script.js.common.Sonstige.Bewegungsmelder_Script: registered 1 subscription and 0 schedules
    2018-06-28 10:09:10.550 - info: javascript.0 Start javascript script.js.common.Sensoren.RF-Bridge
    2018-06-28 10:09:10.562 - info: javascript.0 script.js.common.Sensoren.RF-Bridge: registered 1 subscription and 0 schedules
    2018-06-28 10:09:10.564 - info: javascript.0 Start javascript script.js.common.Sensoren.Kontakte.Terrassentür
    2018-06-28 10:09:10.574 - info: javascript.0 script.js.common.Sensoren.Kontakte.Terrassentür: registered 1 subscription and 0 schedules
    2018-06-28 10:09:10.576 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Dreambox_Auto_Power
    2018-06-28 10:09:10.586 - info: javascript.0 script.js.common.Dreambox_OG.Dreambox_Auto_Power: registered 2 subscriptions and 0 schedules
    2018-06-28 10:09:10.588 - info: javascript.0 Start javascript script.js.common.Sensoren.BWM.BWM_Bad
    2018-06-28 10:09:10.598 - info: javascript.0 script.js.common.Sensoren.BWM.BWM_Bad: registered 1 subscription and 0 schedules
    2018-06-28 10:09:10.600 - info: javascript.0 Start javascript script.js.common.Sonstige.OG_Flur_Nachtlicht
    2018-06-28 10:09:10.613 - info: javascript.0 script.js.common.Sonstige.OG_Flur_Nachtlicht: registered 1 subscription and 0 schedules
    2018-06-28 10:09:10.616 - info: javascript.0 Start javascript script.js.common.Sonstige.EG_Wohnzimmer_Nachtschaltung
    2018-06-28 10:09:10.632 - info: javascript.0 script.js.common.Sonstige.EG_Wohnzimmer_Nachtschaltung: registered 1 subscription and 1 schedule
    2018-06-28 10:09:10.635 - info: javascript.0 Start javascript script.js.common.Sonstige.EG_HWR_Gateway
    2018-06-28 10:09:10.646 - info: javascript.0 script.js.common.Sonstige.EG_HWR_Gateway: registered 1 subscription and 0 schedules
    2018-06-28 10:09:10.648 - info: javascript.0 Start javascript script.js.common.Sonstige.TOTAL_Überprüfung_Türen
    2018-06-28 10:09:10.657 - info: javascript.0 script.js.common.Sonstige.TOTAL_Überprüfung_Türen: registered 1 subscription and 0 schedules
    2018-06-28 10:09:10.659 - info: javascript.0 Start javascript script.js.common.Testfenster
    2018-06-28 10:09:10.668 - info: javascript.0 script.js.common.Testfenster: registered 1 subscription and 0 schedules
    2018-06-28 10:09:10.670 - info: javascript.0 Start javascript script.js.common.Sonstige.TOTAL_Alarmanlage
    2018-06-28 10:09:10.680 - info: javascript.0 script.js.common.Sonstige.TOTAL_Alarmanlage: registered 1 subscription and 0 schedules
    2018-06-28 10:09:10.683 - info: javascript.0 Start javascript script.js.common.Sonstige.LaufendeProzesse
    2018-06-28 10:09:10.702 - info: javascript.0 script.js.common.Sonstige.LaufendeProzesse: registered 0 subscriptions and 1 schedule
    2018-06-28 10:09:10.705 - info: javascript.0 Start javascript script.js.common.Sonstige.Aktuellen_Tag_vom_Jahr
    2018-06-28 10:09:10.720 - info: javascript.0 script.js.common.Sonstige.Aktuellen_Tag_vom_Jahr: registered 0 subscriptions and 1 schedule
    2018-06-28 10:09:10.721 - info: javascript.0 Start javascript script.js.common.Sonstige.Verpasster_Anruf
    2018-06-28 10:09:10.730 - info: javascript.0 script.js.common.Sonstige.Verpasster_Anruf: registered 1 subscription and 0 schedules
    2018-06-28 10:09:11.118 - info: fritzdect.0 Comet ID: 109710237552 identified for command (mode) : 1
    2018-06-28 10:09:11.252 - info: host.raspberrypi instance system.adapter.geofency.0 started with pid 15582
    2018-06-28 10:09:13.957 - error: javascript.0 script.js.common.Dreambox_OG.Standby_On: Error: connect EHOSTUNREACH 192.168.178.220:88
    2018-06-28 10:09:17.538 - error: cloud.0 no connection to states DB: Connection timeout
    2018-06-28 10:09:18.784 - error: geofency.0 no connection to objects DB
    2018-06-28 10:09:23.967 - info: sonoff.0 Client [Highboard-Long] connected with secret 1530173363906_663
    2018-06-28 10:09:24.041 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 15599
    2018-06-28 10:09:24.093 - info: host.raspberrypi instance system.adapter.scenes.0 started with pid 15605
    2018-06-28 10:09:24.281 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    2018-06-28 10:09:24.644 - info: sonoff.0 Client [Highboard-Small] connected with secret 1530173364622_304
    2018-06-28 10:09:24.846 - debug: javascript.0 system.adapter.admin.0: logging true
    2018-06-28 10:09:27.204 - info: cloud.0 starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.14.3
    2018-06-28 10:09:27.304 - info: geofency.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.geofency, node: v6.14.3
    2018-06-28 10:09:27.322 - info: geofency.0 Adapter got 'Ready' Signal - initiating Main function...
    2018-06-28 10:09:27.375 - info: geofency.0 http server listening on port 7999
    2018-06-28 10:09:27.611 - info: cloud.0 Connecting with https://iobroker.net:10555 with "***********@trackquiz.com_a**********************"
    2018-06-28 10:09:27.682 - info: rpi2.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v6.14.3
    2018-06-28 10:09:27.683 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v6.14.3
    2018-06-28 10:09:30.751 - info: cloud.0 Trying to connect as system.user.admin
    2018-06-28 10:09:32.943 - error: cloud.0 Cloud says: timeout
    2018-06-28 10:09:33.958 - info: cloud.0 Connection changed: io server disconnect
    2018-06-28 10:09:34.550 - info: rpi2.0 GPIO ports are not configured
    2018-06-28 10:09:43.058 - info: host.raspberrypi instance system.adapter.web.0 started with pid 15655
    2018-06-28 10:09:46.491 - info: web.0 starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.web, node: v6.14.3
    2018-06-28 10:09:47.495 - info: web.0 socket.io server listening on port 8082
    2018-06-28 10:09:47.510 - info: web.0 http server listening on port 8082
    2018-06-28 10:09:49.749 - info: vis-google-fonts.0 starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v6.14.3
    2018-06-28 10:09:50.437 - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
    2018-06-28 10:09:55.047 - info: host.raspberrypi instance system.adapter.fritzbox.0 started with pid 15675
    2018-06-28 10:09:58.241 - info: fritzbox.0 starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v6.14.3
    2018-06-28 10:09:58.300 - info: fritzbox.0 try to connect: 192.168.178.1
    2018-06-28 10:09:58.402 - info: fritzbox.0 adapter connected to fritzbox: 192.168.178.1
    2018-06-28 10:09:59.047 - info: host.raspberrypi instance system.adapter.sayit.0 started with pid 15685
    2018-06-28 10:10:01.866 - info: sayit.0 starting. Version 1.6.8 in /opt/iobroker/node_modules/iobroker.sayit, node: v6.14.3
    2018-06-28 10:10:01.901 - info: sayit.0 Upload announce mp3 files
    2018-06-28 10:10:02.094 - info: sayit.0 All files uploaded
    2018-06-28 10:10:03.047 - info: host.raspberrypi instance system.adapter.lgtv11.0 started with pid 15698
    2018-06-28 10:10:05.682 - info: lgtv11.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.lgtv11, node: v6.14.3
    2018-06-28 10:10:05.717 - info: lgtv11.0 Ready. Configured LG TV IP: 192.168.178.20, Port: , Pairing Key: 789905
    2018-06-28 10:10:07.048 - info: host.raspberrypi instance system.adapter.history.0 started with pid 15708
    2018-06-28 10:10:09.684 - info: history.0 starting. Version 1.8.4 in /opt/iobroker/node_modules/iobroker.history, node: v6.14.3
    2018-06-28 10:10:09.822 - info: history.0 enabled logging of javascript.0.Stromzähler.Hausstrom.Aktuell_Tag (Count=1), Alias=false
    2018-06-28 10:10:09.830 - info: history.0 enabled logging of mihome.0.devices.gateway_7811dcfd6e12.illumination (Count=2), Alias=false
    2018-06-28 10:10:09.833 - info: history.0 enabled logging of mihome.0.devices.sensor_motion_aq2_158d000200d283.lux (Count=3), Alias=false
    2018-06-28 10:10:15.103 - info: host.raspberrypi instance scheduled system.adapter.yr.0 0 * * * *
    2018-06-28 10:10:15.158 - info: host.raspberrypi instance system.adapter.yr.0 started with pid 15718
    2018-06-28 10:10:18.393 - info: yr.0 starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.yr, node: v6.14.3
    2018-06-28 10:10:18.914 - info: yr.0 got weather data from yr.no
    2018-06-28 10:10:18.988 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: Heizung - Aussentemperatur liegt bei: 22
    2018-06-28 10:10:19.028 - info: fritzdect.0 Comet ID: 109710237552 identified for command (targettemp) : 0
    2018-06-28 10:10:19.055 - info: fritzdect.0 Comet ID: 109710237552 identified for command (mode) : 1
    2018-06-28 10:10:23.042 - info: host.raspberrypi instance system.adapter.email.0 started with pid 15728
    2018-06-28 10:10:24.094 - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 0 (OK)
    2018-06-28 10:10:25.743 - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v6.14.3
    2018-06-28 10:10:27.043 - info: host.raspberrypi instance system.adapter.parser.0 started with pid 15738
    2018-06-28 10:10:27.681 - info: cloud.0 Trying to connect as system.user.admin
    2018-06-28 10:10:27.836 - info: cloud.0 Adapter redirected temporally to "https://iobroker.net:10560" in one minute. Reason: command from server
    2018-06-28 10:10:27.840 - info: cloud.0 Connection changed: io client disconnect
    2018-06-28 10:10:29.782 - info: parser.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.parser, node: v6.14.3
    2018-06-28 10:10:31.044 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 15748
    2018-06-28 10:10:35.048 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 15790
    2018-06-28 10:10:37.520 - info: telegram.0 starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.telegram, node: v6.14.3
    2018-06-28 10:10:37.900 - info: text2command.0 starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.text2command, node: v6.14.3
    2018-06-28 10:10:38.194 - info: telegram.0 getMe: {"id":556776579,"is_bot":true,"first_name":"SperberBot","username":"SperberBot"}
    2018-06-28 10:10:39.044 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 15804
    2018-06-28 10:10:41.807 - info: mqtt.0 starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v6.14.3
    2018-06-28 10:10:42.604 - info: mqtt.0 Starting MQTT ' authenticated server on port 1884
    2018-06-28 10:10:43.035 - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 15814
    2018-06-28 10:10:45.697 - info: simple-api.0 starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v6.14.3
    2018-06-28 10:10:45.790 - info: simple-api.0 simpleAPI server listening on port 8087
    2018-06-28 10:10:45.792 - info: simple-api.0 Allow states only when user is owner: false
    2018-06-28 10:10:45.804 - info: simple-api.0 http server listening on port 8087
    2018-06-28 10:10:47.029 - info: host.raspberrypi instance system.adapter.mihome.0 started with pid 15824
    2018-06-28 10:10:49.803 - info: mihome.0 starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.mihome, node: v6.14.3
    2018-06-28 10:10:49.952 - info: mihome.0 Change connection status: false
    2018-06-28 10:10:50.019 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
    2018-06-28 10:10:50.091 - info: mihome.0 Change connection status: true
    2018-06-28 10:10:50.101 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
    2018-06-28 10:11:27.870 - info: cloud.0 Trying to connect as system.user.admin
    2018-06-28 10:11:28.031 - info: cloud.0 Connection changed: connect
    Ist das das was du meintest mit Log nach dem Neustart?
    • apollon77A Offline
      Ja, aber in dem Log siegt alles sauber aus … nicht mit Error 7 ... wann kommt das denn?
      • L Offline
        LJSven
        Auf jeden Fall nach einem Reboot des Raspberry. Ich mache jede Nacht um 4 Uhr den Befehl
        sudo reboot
        via Crontab.
          warum auch immer Du das tust :-)
          dann schick halt mal log von danach vom start von iobroker bis zu dem wo das kommt
          • L Offline
            LJSven
            Hier mal der Reboot Prozess
            2018-06-28 04:00:00.132 - info: host.raspberrypi instance system.adapter.yr.0 started with pid 23968
            2018-06-28 04:00:03.753 - info: yr.0 starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.yr, node: v6.14.3
            2018-06-28 04:00:04.401 - info: yr.0 got weather data from yr.no
            2018-06-28 04:00:04.511 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: Heizung - Aussentemperatur liegt bei: 15
            2018-06-28 04:00:04.532 - info: fritzdect.0 Comet ID: 109710237552 identified for command (targettemp) : 0
            2018-06-28 04:00:04.582 - info: fritzdect.0 Comet ID: 109710237552 identified for command (mode) : 1
            2018-06-28 04:00:04.691 - info: host.raspberrypi received SIGTERM
            2018-06-28 04:00:09.642 - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 0 (OK)
            2018-06-28 04:00:10.713 - info: host.raspberrypi received SIGTERM
            2018-06-28 04:00:14.769 - info: host.raspberrypi force terminating
            2018-06-28 04:00:14.771 - info: Adapter admin still running
            2018-06-28 04:00:14.772 - info: Adapter discovery still running
            2018-06-28 04:00:14.773 - info: Adapter javascript still running
            2018-06-28 04:00:14.774 - info: Adapter sonos still running
            2018-06-28 04:00:14.775 - info: Adapter fritzdect still running
            2018-06-28 04:00:14.777 - info: Adapter sonoff still running
            2018-06-28 04:00:14.778 - info: Adapter cloud still running
            2018-06-28 04:00:14.779 - info: Adapter geofency still running
            2018-06-28 04:00:14.780 - info: Adapter rpi2 still running
            2018-06-28 04:00:14.781 - info: Adapter scenes still running
            2018-06-28 04:00:14.782 - info: Adapter web still running
            2018-06-28 04:00:14.783 - info: Adapter fritzbox still running
            2018-06-28 04:00:14.783 - info: Adapter sayit still running
            2018-06-28 04:00:14.784 - info: Adapter lgtv11 still running
            2018-06-28 04:00:14.785 - info: Adapter history still running
            2018-06-28 04:00:14.787 - info: Adapter email still running
            2018-06-28 04:00:14.788 - info: Adapter parser still running
            2018-06-28 04:00:14.789 - info: Adapter telegram still running
            2018-06-28 04:00:14.790 - info: Adapter text2command still running
            2018-06-28 04:00:14.791 - info: Adapter mqtt still running
            2018-06-28 04:00:14.792 - info: Adapter simple-api still running
            2018-06-28 04:00:14.792 - info: Adapter mihome still running
            2018-06-28 04:00:33.851 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
            2018-06-28 04:00:33.876 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
            2018-06-28 04:00:33.878 - info: host.raspberrypi hostname: raspberrypi, node: v6.14.3
            2018-06-28 04:00:33.882 - info: host.raspberrypi ip addresses: 192.168.178.44 fe80::ba6f:5d66:56f0:9b94
            2018-06-28 04:00:34.318 - info: host.raspberrypi inMem-states listening on port 9000
            2018-06-28 04:00:35.229 - info: host.raspberrypi inMem-objects listening on port 9001
            2018-06-28 04:00:35.284 - info: host.raspberrypi InMemoryDB connected
            2018-06-28 04:00:35.353 - info: host.raspberrypi 38 instances found
            2018-06-28 04:00:35.514 - info: host.raspberrypi starting 33 instances
            2018-06-28 04:00:35.688 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 541
            2018-06-28 04:00:39.570 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 548
            2018-06-28 04:00:43.548 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 554
            2018-06-28 04:00:44.626 - info: admin.0 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v6.14.3
            2018-06-28 04:00:44.733 - info: admin.0 requesting all states
            2018-06-28 04:00:44.635 - info: discovery.0 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.14.3
            2018-06-28 04:00:44.746 - info: admin.0 requesting all objects
            2018-06-28 04:00:44.751 - info: admin.0 Request actual repository...
            2018-06-28 04:00:47.162 - info: admin.0 received all states
            2018-06-28 04:00:47.573 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 568
            2018-06-28 04:00:58.619 - info: admin.0 received all objects
            2018-06-28 04:00:59.443 - info: admin.0 http server listening on port 8081
            2018-06-28 04:00:59.445 - info: admin.0 Use link "http://localhost:8081" to configure.
            2018-06-28 04:00:59.586 - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 575
            2018-06-28 04:01:00.142 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
            2018-06-28 04:01:03.254 - error: sonos.0 no connection to objects DB
            2018-06-28 04:01:04.617 - info: host.raspberrypi instance system.adapter.sonoff.0 started with pid 589
            2018-06-28 04:01:04.917 - debug: javascript.0 objectDB connected
            2018-06-28 04:01:05.835 - debug: javascript.0 statesDB connected
            2018-06-28 04:01:05.901 - info: sonos.0 starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.sonos, node: v6.14.3
            2018-06-28 04:01:06.179 - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.14.3
            2018-06-28 04:01:06.199 - info: sonos.0 http sonos server listening on port 8083
            2018-06-28 04:01:06.227 - info: javascript.0 requesting all states
            2018-06-28 04:01:06.245 - info: javascript.0 requesting all objects
            2018-06-28 04:01:08.553 - info: admin.0 Repository received successfully.
            2018-06-28 04:01:09.747 - info: javascript.0 received all states
            2018-06-28 04:01:09.471 - info: fritzdect.0 starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v6.14.3
            2018-06-28 04:01:09.536 - info: fritzdect.0 entered ready
            2018-06-28 04:01:09.751 - info: sonoff.0 starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.14.3
            2018-06-28 04:01:10.414 - info: sonoff.0 Starting MQTT authenticated server on port 1883
            2018-06-28 04:01:11.607 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 613
            2018-06-28 04:01:14.059 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
            2018-06-28 04:01:14.501 - info: vis.0 vis license is OK.
            2018-06-28 04:01:14.642 - info: javascript.0 received all objects
            2018-06-28 04:01:15.252 - info: javascript.0 Start javascript script.js.common.Sonstige.Anwesenheit
            2018-06-28 04:01:15.388 - info: fritzdect.0 Talking to FritzBox with firmware: 06.93
            2018-06-28 04:01:15.590 - info: host.raspberrypi instance system.adapter.geofency.0 started with pid 623
            2018-06-28 04:01:15.886 - info: fritzdect.0 create Devices 3
            2018-06-28 04:01:15.890 - info: fritzdect.0 setting up Thermostat/DECT3xx object Wohnzimmer Heizung
            2018-06-28 04:01:16.520 - info: fritzdect.0 setting up Switch/DECT2xx object Galerie TV
            2018-06-28 04:01:16.539 - info: fritzdect.0 setting up Switch/DECT2xx object Deko
            2018-06-28 04:01:18.497 - info: cloud.0 starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.14.3
            2018-06-28 04:01:19.087 - info: cloud.0 Connecting with https://iobroker.net:10555 with "i************"
            2018-06-28 04:01:19.594 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 633
            2018-06-28 04:01:20.048 - info: cloud.0 Trying to connect as system.user.admin
            2018-06-28 04:01:20.190 - info: geofency.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.geofency, node: v6.14.3
            2018-06-28 04:01:20.270 - info: geofency.0 Adapter got 'Ready' Signal - initiating Main function...
            2018-06-28 04:01:20.346 - info: geofency.0 http server listening on port 7999
            2018-06-28 04:01:15.322 - info: javascript.0 script.js.common.Sonstige.Anwesenheit: registered 3 subscriptions and 0 schedules
            2018-06-28 04:01:15.325 - info: javascript.0 Start javascript script.js.common.Sonstige.Heizungssteuerung
            2018-06-28 04:01:15.394 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: Heizung - Mai bis September aus! Aussentemperatur beträgt 15
            2018-06-28 04:01:15.402 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: registered 2 subscriptions and 2 schedules
            2018-06-28 04:01:15.407 - info: javascript.0 Start javascript script.js.common.Sonstige.Dekobeleuchtung
            2018-06-28 04:01:16.488 - info: javascript.0 script.js.common.Sonstige.Dekobeleuchtung: registered 0 subscriptions and 1 schedule
            2018-06-28 04:01:16.490 - info: javascript.0 Start javascript script.js.common.Sonstige.Text-To-Speech
            2018-06-28 04:01:16.503 - info: javascript.0 script.js.common.Sonstige.Text-To-Speech: registered 1 subscription and 0 schedules
            2018-06-28 04:01:16.506 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Sport_2
            2018-06-28 04:01:16.571 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Sport_2: registered 0 subscriptions and 0 schedules
            2018-06-28 04:01:16.573 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Eurosport_HD_2
            2018-06-28 04:01:16.593 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Eurosport_HD_2: registered 0 subscriptions and 0 schedules
            2018-06-28 04:01:16.595 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Off
            2018-06-28 04:01:16.608 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Off: registered 1 subscription and 0 schedules
            2018-06-28 04:01:16.610 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_On
            2018-06-28 04:01:16.620 - info: javascript.0 script.js.common.Dreambox_EG.Standby_On: registered 1 subscription and 0 schedules
            2018-06-28 04:01:16.622 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Bundesliga
            2018-06-28 04:01:16.636 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Bundesliga: registered 0 subscriptions and 0 schedules
            2018-06-28 04:01:16.638 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Sender.Sky_Sport_1
            2018-06-28 04:01:16.663 - info: javascript.0 script.js.common.Dreambox_EG.Sender.Sky_Sport_1: registered 0 subscriptions and 0 schedules
            2018-06-28 04:01:16.665 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Toggle
            2018-06-28 04:01:16.676 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Toggle: registered 1 subscription and 0 schedules
            2018-06-28 04:01:16.684 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Szene_Fussball_Bundesliga_Sky
            2018-06-28 04:01:16.696 - info: javascript.0 script.js.common.Dreambox_EG.Szene_Fussball_Bundesliga_Sky: registered 1 subscription and 0 schedules
            2018-06-28 04:01:16.700 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Standby_Off
            2018-06-28 04:01:16.710 - info: javascript.0 script.js.common.Dreambox_OG.Standby_Off: registered 1 subscription and 0 schedules
            2018-06-28 04:01:16.712 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Standby_On
            2018-06-28 04:01:16.726 - info: javascript.0 script.js.common.Dreambox_OG.Standby_On: request: http://root:LJSven300878@192.168.178.220:88/web/powerstate?newstate=4
            2018-06-28 04:01:16.728 - info: javascript.0 script.js.common.Dreambox_OG.Standby_On: registered 0 subscriptions and 0 schedules
            2018-06-28 04:01:16.729 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Sender.Eurosport_HD_2
            2018-06-28 04:01:16.745 - info: javascript.0 script.js.common.Dreambox_OG.Sender.Eurosport_HD_2: registered 0 subscriptions and 0 schedules
            2018-06-28 04:01:16.746 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Sender.Sky_Bundesliga
            2018-06-28 04:01:16.759 - info: javascript.0 script.js.common.Dreambox_OG.Sender.Sky_Bundesliga: registered 0 subscriptions and 0 schedules
            2018-06-28 04:01:16.760 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Key_EXIT
            2018-06-28 04:01:16.775 - info: javascript.0 script.js.common.Dreambox_OG.Key_EXIT: registered 1 subscription and 0 schedules
            2018-06-28 04:01:16.777 - info: javascript.0 Start javascript script.js.common.Sonstige.Alles_Aus_-_Schaltung
            2018-06-28 04:01:16.787 - info: javascript.0 script.js.common.Sonstige.Alles_Aus_-_Schaltung: registered 2 subscriptions and 0 schedules
            2018-06-28 04:01:16.789 - info: javascript.0 Start javascript script.js.common.Sonstige.Astro-Tageszeit
            2018-06-28 04:01:16.818 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: es wird Nacht: false
            2018-06-28 04:01:16.827 - warn: javascript.0 Cannot calculate "night" for 52.0882309, 7.0213161
            2018-06-28 04:01:16.835 - warn: javascript.0 Cannot calculate "nightEnd" for 52.0882309, 7.0213161
            2018-06-28 04:01:16.844 - warn: javascript.0 Cannot calculate "night" for 52.0882309, 7.0213161
            2018-06-28 04:01:20.402 - info: javascript.0 script.js.common.Sonstige.Astro-Tageszeit: registered 0 subscriptions and 10 schedules
            2018-06-28 04:01:20.406 - info: javascript.0 Start javascript script.js.common.Dreambox_EG.Standby_Status_DB_EG
            2018-06-28 04:01:21.240 - info: javascript.0 script.js.common.Dreambox_EG.Standby_Status_DB_EG: registered 0 subscriptions and 1 schedule
            2018-06-28 04:01:21.242 - info: javascript.0 Start javascript script.js.common.Sonstige.Dreambox_OG_Standby-Prüfung
            2018-06-28 04:01:21.252 - info: javascript.0 script.js.common.Sonstige.Dreambox_OG_Standby-Prüfung: registered 1 subscription and 0 schedules
            2018-06-28 04:01:21.254 - info: javascript.0 Start javascript script.js.common.Bad.Bad_Sonos_Automation
            2018-06-28 04:01:21.264 - info: javascript.0 script.js.common.Bad.Bad_Sonos_Automation: registered 1 subscription and 0 schedules
            2018-06-28 04:01:21.266 - info: javascript.0 Start javascript script.js.common.Sonstige.Telegram_Button
            2018-06-28 04:01:21.279 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
            2018-06-28 04:01:21.282 - info: javascript.0 script.js.common.Sonstige.Telegram_Button: registered 0 subscriptions and 0 schedules
            2018-06-28 04:01:21.299 - info: javascript.0 Start javascript script.js.common.Sonstige.Bewegungsmelder_Script
            2018-06-28 04:01:21.312 - info: javascript.0 script.js.common.Sonstige.Bewegungsmelder_Script: registered 1 subscription and 0 schedules
            2018-06-28 04:01:21.314 - info: javascript.0 Start javascript script.js.common.Sensoren.RF-Bridge
            2018-06-28 04:01:21.325 - info: javascript.0 script.js.common.Sensoren.RF-Bridge: registered 1 subscription and 0 schedules
            2018-06-28 04:01:21.327 - info: javascript.0 Start javascript script.js.common.Sensoren.Kontakte.Terrassentür
            2018-06-28 04:01:21.337 - info: javascript.0 script.js.common.Sensoren.Kontakte.Terrassentür: registered 1 subscription and 0 schedules
            2018-06-28 04:01:21.338 - info: javascript.0 Start javascript script.js.common.Dreambox_OG.Dreambox_Auto_Power
            2018-06-28 04:01:21.348 - info: javascript.0 script.js.common.Dreambox_OG.Dreambox_Auto_Power: registered 2 subscriptions and 0 schedules
            2018-06-28 04:01:21.350 - info: javascript.0 Start javascript script.js.common.Sensoren.BWM.BWM_Bad
            2018-06-28 04:01:21.359 - info: javascript.0 script.js.common.Sensoren.BWM.BWM_Bad: registered 1 subscription and 0 schedules
            2018-06-28 04:01:21.361 - info: javascript.0 Start javascript script.js.common.Sonstige.OG_Flur_Nachtlicht
            2018-06-28 04:01:21.371 - info: javascript.0 script.js.common.Sonstige.OG_Flur_Nachtlicht: registered 1 subscription and 0 schedules
            2018-06-28 04:01:21.373 - info: javascript.0 Start javascript script.js.common.Sonstige.EG_Wohnzimmer_Nachtschaltung
            2018-06-28 04:01:21.391 - info: javascript.0 script.js.common.Sonstige.EG_Wohnzimmer_Nachtschaltung: registered 1 subscription and 1 schedule
            2018-06-28 04:01:21.393 - info: javascript.0 Start javascript script.js.common.Sonstige.EG_HWR_Gateway
            2018-06-28 04:01:21.403 - info: javascript.0 script.js.common.Sonstige.EG_HWR_Gateway: registered 1 subscription and 0 schedules
            2018-06-28 04:01:21.405 - info: javascript.0 Start javascript script.js.common.Sonstige.TOTAL_Überprüfung_Türen
            2018-06-28 04:01:21.414 - info: javascript.0 script.js.common.Sonstige.TOTAL_Überprüfung_Türen: registered 1 subscription and 0 schedules
            2018-06-28 04:01:21.416 - info: javascript.0 Start javascript script.js.common.Testfenster
            2018-06-28 04:01:21.425 - info: javascript.0 script.js.common.Testfenster: registered 1 subscription and 0 schedules
            2018-06-28 04:01:21.427 - info: javascript.0 Start javascript script.js.common.Sonstige.TOTAL_Alarmanlage
            2018-06-28 04:01:21.437 - info: javascript.0 script.js.common.Sonstige.TOTAL_Alarmanlage: registered 1 subscription and 0 schedules
            2018-06-28 04:01:21.439 - info: javascript.0 Start javascript script.js.common.Sonstige.LaufendeProzesse
            2018-06-28 04:01:21.460 - info: javascript.0 script.js.common.Sonstige.LaufendeProzesse: registered 0 subscriptions and 1 schedule
            2018-06-28 04:01:21.463 - info: javascript.0 Start javascript script.js.common.Sonstige.Aktuellen_Tag_vom_Jahr
            2018-06-28 04:01:21.474 - info: javascript.0 script.js.common.Sonstige.Aktuellen_Tag_vom_Jahr: registered 0 subscriptions and 1 schedule
            2018-06-28 04:01:21.476 - info: javascript.0 Start javascript script.js.common.Sonstige.Verpasster_Anruf
            2018-06-28 04:01:21.485 - info: javascript.0 script.js.common.Sonstige.Verpasster_Anruf: registered 1 subscription and 0 schedules
            2018-06-28 04:01:23.229 - info: sonoff.0 Client [Highboard-Small] connected with secret 1530151283172_9015
            2018-06-28 04:01:23.438 - info: fritzdect.0 Comet ID: 109710237552 identified for command (targettemp) : 0
            2018-06-28 04:01:23.738 - info: host.raspberrypi instance system.adapter.scenes.0 started with pid 646
            2018-06-28 04:01:23.758 - info: fritzdect.0 Comet ID: 109710237552 identified for command (mode) : 1
            2018-06-28 04:01:24.285 - info: rpi2.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v6.14.3
            2018-06-28 04:01:24.400 - error: cloud.0 Cloud says: timeout
            2018-06-28 04:01:24.677 - error: javascript.0 script.js.common.Dreambox_OG.Standby_On: Error: connect EHOSTUNREACH 192.168.178.220:88
            2018-06-28 04:01:25.408 - info: cloud.0 Connection changed: io server disconnect
            2018-06-28 04:01:26.511 - info: sonoff.0 Client [Highboard-Long] connected with secret 1530151286502_3470
            2018-06-28 04:01:28.160 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v6.14.3
            2018-06-28 04:01:30.264 - info: rpi2.0 GPIO ports are not configured
            2018-06-28 04:01:47.603 - info: host.raspberrypi instance system.adapter.web.0 started with pid 696
            2018-06-28 04:01:57.064 - info: vis-google-fonts.0 starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v6.14.3
            2018-06-28 04:01:58.399 - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
            2018-06-28 04:01:59.618 - info: host.raspberrypi instance system.adapter.fritzbox.0 started with pid 712
            2018-06-28 04:02:03.619 - info: host.raspberrypi instance system.adapter.sayit.0 started with pid 721
            2018-06-28 04:02:06.776 - warn: vis.0 Reconnection to DB.
            2018-06-28 04:02:06.783 - warn: vis.0 Reconnection to DB.
            2018-06-28 04:02:06.886 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
            2018-06-28 04:02:07.056 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
            2018-06-28 04:02:07.624 - info: host.raspberrypi instance system.adapter.lgtv11.0 started with pid 731
            2018-06-28 04:02:07.813 - info: web.0 starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.web, node: v6.14.3
            2018-06-28 04:02:07.872 - info: fritzbox.0 starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v6.14.3
            2018-06-28 04:02:08.140 - info: sayit.0 starting. Version 1.6.8 in /opt/iobroker/node_modules/iobroker.sayit, node: v6.14.3
            2018-06-28 04:02:07.941 - info: fritzbox.0 try to connect: 192.168.178.1
            2018-06-28 04:02:08.057 - info: fritzbox.0 adapter connected to fritzbox: 192.168.178.1
            2018-06-28 04:02:08.183 - info: sayit.0 Upload announce mp3 files
            2018-06-28 04:02:17.909 - error: lgtv11.0 no connection to objects DB
            2018-06-28 04:02:24.253 - error: cloud.0 Cloud says: timeout
            2018-06-28 04:02:12.320 - info: host.raspberrypi instance system.adapter.history.0 started with pid 745
            2018-06-28 04:02:26.428 - info: host.raspberrypi instance scheduled system.adapter.yr.0 0 * * * *
            2018-06-28 04:02:26.472 - info: host.raspberrypi instance system.adapter.yr.0 started with pid 755
            2018-06-28 04:02:26.786 - warn: geofency.0 Reconnection to DB.
            2018-06-28 04:02:26.829 - warn: scenes.0 Reconnection to DB.
            2018-06-28 04:02:26.836 - warn: rpi2.0 Reconnection to DB.
            2018-06-28 04:02:26.856 - warn: sonos.0 Reconnection to DB.
            2018-06-28 04:02:26.852 - warn: geofency.0 Reconnection to DB.
            2018-06-28 04:02:26.892 - info: cloud.0 Trying to connect as system.user.admin
            2018-06-28 04:02:26.867 - warn: rpi2.0 Reconnection to DB.
            2018-06-28 04:02:26.886 - warn: scenes.0 Reconnection to DB.
            2018-06-28 04:02:26.911 - warn: sonos.0 Reconnection to DB.
            2018-06-28 04:02:07.103 - info: vis.0 vis license is OK.
            2018-06-28 04:02:28.521 - info: vis.0 vis license is OK.
            2018-06-28 04:02:32.143 - error: lgtv11.0 no connection to states DB: Connection timeout
            2018-06-28 04:02:42.249 - error: yr.0 no connection to objects DB
            2018-06-28 04:02:42.327 - error: history.0 no connection to objects DB
            2018-06-28 04:02:52.768 - info: host.raspberrypi instance system.adapter.email.0 started with pid 805
            2018-06-28 04:02:52.863 - info: host.raspberrypi instance system.adapter.parser.0 started with pid 811
            2018-06-28 04:02:52.931 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 817
            2018-06-28 04:02:52.984 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 823
            2018-06-28 04:02:53.148 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 829
            2018-06-28 04:02:53.258 - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 835
            2018-06-28 04:02:53.357 - info: host.raspberrypi instance system.adapter.mihome.0 started with pid 841
            2018-06-28 04:02:54.094 - warn: javascript.0 Reconnection to DB.
            2018-06-28 04:02:54.979 - warn: discovery.0 Reconnection to DB.
            2018-06-28 04:02:55.004 - warn: fritzbox.0 Reconnection to DB.
            2018-06-28 04:02:55.040 - warn: sayit.0 Reconnection to DB.
            2018-06-28 04:02:55.013 - warn: discovery.0 Reconnection to DB.
            2018-06-28 04:02:55.080 - warn: sayit.0 Reconnection to DB.
            2018-06-28 04:02:55.116 - warn: cloud.0 Reconnection to DB.
            2018-06-28 04:02:55.118 - warn: fritzdect.0 Reconnection to DB.
            2018-06-28 04:02:55.162 - warn: admin.0 Reconnection to DB.
            2018-06-28 04:02:55.127 - warn: cloud.0 Reconnection to DB.
            2018-06-28 04:02:55.071 - warn: fritzbox.0 Reconnection to DB.
            2018-06-28 04:02:55.279 - warn: fritzdect.0 Reconnection to DB.
            2018-06-28 04:02:55.234 - warn: admin.0 Reconnection to DB.
            2018-06-28 04:02:55.678 - warn: javascript.0 Reconnection to DB.
            2018-06-28 04:02:55.938 - error: geofency.0 already running
            2018-06-28 04:02:56.071 - error: rpi2.0 already running
            2018-06-28 04:02:56.141 - error: cloud.0 already running
            2018-06-28 04:02:56.633 - error: host.raspberrypi instance system.adapter.cloud.0 terminated with code 7 (Adapter already running)
            2018-06-28 04:02:56.563 - info: sonos.0 starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.sonos, node: v6.14.3
            2018-06-28 04:02:56.634 - info: host.raspberrypi Restart adapter system.adapter.cloud.0 because enabled
            2018-06-28 04:02:56.702 - error: host.raspberrypi instance system.adapter.geofency.0 terminated with code 7 (Adapter already running)
            2018-06-28 04:02:56.704 - info: host.raspberrypi Restart adapter system.adapter.geofency.0 because enabled
            2018-06-28 04:02:56.787 - error: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 7 (Adapter already running)
            2018-06-28 04:02:56.789 - info: host.raspberrypi Restart adapter system.adapter.rpi2.0 because enabled
            2018-06-28 04:02:56.939 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v6.14.3
            2018-06-28 04:02:57.378 - error: sayit.0 already running
            2018-06-28 04:02:57.383 - error: discovery.0 already running
            2018-06-28 04:02:57.399 - error: admin.0 already running
            2018-06-28 04:02:57.441 - error: fritzbox.0 already running
            2018-06-28 04:02:57.691 - warn: vis.0 Reconnection to DB.
            2018-06-28 04:02:57.698 - warn: vis.0 Reconnection to DB.
            2018-06-28 04:02:57.753 - info: sonos.0 starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.sonos, node: v6.14.3
            2018-06-28 04:02:57.856 - info: sonos.0 http sonos server listening on port 8083
            2018-06-28 04:02:57.934 - error: sonos.0 uncaught exception: listen EADDRINUSE :::8083
            2018-06-28 04:02:57.946 - error: sonos.0 Error: listen EADDRINUSE :::8083
            at Object.exports._errnoException (util.js:1020:11)
            at exports._exceptionWithHostPort (util.js:1043:20)
            at Server._listen2 (net.js:1271:14)
            at listen (net.js:1307:10)
            at Server.listen (net.js:1403:5)
            at main (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:1923:16)
            at Socket. (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:197:13)
            at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:319:9)
            at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:244:12)
            at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
            at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:345:8)
            at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
            at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:251:12)
            at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:335:16)
            2018-06-28 04:02:57.952 - info: sonos.0 terminating
            2018-06-28 04:02:58.213 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
            2018-06-28 04:02:58.222 - debug: javascript.0 system.adapter.admin.0: logging false
            2018-06-28 04:02:58.373 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v6.14.3
            2018-06-28 04:02:58.415 - info: sonos.0 terminating
            2018-06-28 04:02:59.061 - info: history.0 starting. Version 1.8.4 in /opt/iobroker/node_modules/iobroker.history, node: v6.14.3
            2018-06-28 04:02:59.086 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
            2018-06-28 04:02:59.138 - info: lgtv11.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.lgtv11, node: v6.14.3
            2018-06-28 04:02:59.194 - info: lgtv11.0 Ready. Configured LG TV IP: 192.168.178.20, Port: , Pairing Key: 789905
            2018-06-28 04:02:59.364 - info: lgtv11.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.lgtv11, node: v6.14.3
            2018-06-28 04:02:59.387 - info: lgtv11.0 Ready. Configured LG TV IP: 192.168.178.20, Port: , Pairing Key: 789905
            2018-06-28 04:02:58.216 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
            2018-06-28 04:02:58.244 - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
            2018-06-28 04:02:58.266 - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
            2018-06-28 04:02:58.292 - error: host.raspberrypi instance system.adapter.fritzbox.0 terminated with code 7 (Adapter already running)
            2018-06-28 04:02:58.294 - info: host.raspberrypi Restart adapter system.adapter.fritzbox.0 because enabled
            2018-06-28 04:02:58.332 - error: host.raspberrypi instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
            2018-06-28 04:02:58.333 - info: host.raspberrypi Restart adapter system.adapter.sayit.0 because enabled
            2018-06-28 04:02:59.231 - info: vis.0 vis license is OK.
            2018-06-28 04:03:03.381 - error: Caught by controller[0]: { Error: listen EADDRINUSE :::8083
            2018-06-28 04:03:03.382 - error: Caught by controller[0]: at Object.exports._errnoException (util.js:1020:11)
            2018-06-28 04:03:03.382 - error: Caught by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
            2018-06-28 04:03:03.383 - error: Caught by controller[0]: at Server._listen2 (net.js:1271:14)
            2018-06-28 04:03:03.383 - error: Caught by controller[0]: at listen (net.js:1307:10)
            2018-06-28 04:03:03.384 - error: Caught by controller[0]: at Server.listen (net.js:1403:5)
            2018-06-28 04:03:03.384 - error: Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:1923:16)
            2018-06-28 04:03:03.384 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:197:13)
            2018-06-28 04:03:03.385 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:319:9)
            2018-06-28 04:03:03.385 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:244:12)
            2018-06-28 04:03:03.386 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            2018-06-28 04:03:03.386 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
            2018-06-28 04:03:03.386 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:345:8)
            2018-06-28 04:03:03.387 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            2018-06-28 04:03:03.387 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
            2018-06-28 04:03:03.388 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:251:12)
            2018-06-28 04:03:03.388 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:335:16)
            2018-06-28 04:03:03.388 - error: Caught by controller[0]: code: 'EADDRINUSE',
            2018-06-28 04:03:03.389 - error: Caught by controller[0]: errno: 'EADDRINUSE',
            2018-06-28 04:03:03.389 - error: Caught by controller[0]: syscall: 'listen',
            2018-06-28 04:03:03.390 - error: Caught by controller[0]: address: '::',
            2018-06-28 04:03:03.390 - error: Caught by controller[0]: port: 8083 }
            2018-06-28 04:03:03.391 - error: host.raspberrypi instance system.adapter.sonos.0 terminated with code 0 (OK)
            2018-06-28 04:03:03.391 - info: host.raspberrypi Restart adapter system.adapter.sonos.0 because enabled
            2018-06-28 04:03:03.442 - info: history.0 enabled logging of javascript.0.Stromzähler.Hausstrom.Aktuell_Tag (Count=1), Alias=false
            2018-06-28 04:03:03.582 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
            2018-06-28 04:03:04.445 - info: parser.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.parser, node: v6.14.3
            2018-06-28 04:03:03.453 - info: history.0 enabled logging of mihome.0.devices.gateway_7811dcfd6e12.illumination (Count=2), Alias=false
            2018-06-28 04:03:03.457 - info: history.0 enabled logging of mihome.0.devices.sensor_motion_aq2_158d000200d283.lux (Count=3), Alias=false
            2018-06-28 04:03:08.867 - error: text2command.0 no connection to objects DB
            2018-06-28 04:03:10.327 - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v6.14.3
            2018-06-28 04:03:10.349 - info: mihome.0 starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.mihome, node: v6.14.3
            2018-06-28 04:03:10.281 - info: simple-api.0 starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v6.14.3
            2018-06-28 04:03:10.783 - info: vis.0 vis license is OK.
            2018-06-28 04:03:10.639 - info: simple-api.0 simpleAPI server listening on port 8087
            2018-06-28 04:03:10.643 - info: simple-api.0 Allow states only when user is owner: false
            2018-06-28 04:03:10.670 - info: simple-api.0 http server listening on port 8087
            2018-06-28 04:03:10.596 - info: mqtt.0 starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v6.14.3
            2018-06-28 04:03:12.819 - info: mihome.0 Change connection status: false
            2018-06-28 04:03:12.924 - info: yr.0 starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.yr, node: v6.14.3
            2018-06-28 04:03:13.048 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
            2018-06-28 04:03:13.110 - info: mihome.0 Change connection status: true
            2018-06-28 04:03:13.119 - debug: javascript.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
            2018-06-28 04:03:13.173 - info: text2command.0 starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.text2command, node: v6.14.3
            2018-06-28 04:03:13.539 - info: yr.0 got weather data from yr.no
            2018-06-28 04:03:13.653 - info: javascript.0 script.js.common.Sonstige.Heizungssteuerung: Heizung - Aussentemperatur liegt bei: 15
            2018-06-28 04:03:14.473 - info: mqtt.0 Starting MQTT ' authenticated server on port 1884
            2018-06-28 04:03:16.143 - info: fritzdect.0 Comet ID: 109710237552 identified for command (targettemp) : 0
            2018-06-28 04:03:16.240 - info: fritzdect.0 Comet ID: 109710237552 identified for command (mode) : 1
            2018-06-28 04:03:17.272 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
            2018-06-28 04:03:22.003 - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 0 (OK)
            2018-06-28 04:03:23.466 - info: web.0 socket.io server listening on port 8082
            2018-06-28 04:03:23.483 - info: web.0 http server listening on port 8082
            2018-06-28 04:03:23.578 - error: web.0 websocket error
            2018-06-28 04:03:23.588 - error: web.0 Error: websocket error
            at WS.Transport.onError (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:64:13)
            at WebSocket.ws.onerror (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:150:10)
            at WebSocket.onError (/opt/iobroker/node_modules/ws/lib/EventTarget.js:109:16)
            at emitOne (events.js:96:13)
            at WebSocket.emit (events.js:188:7)
            at WebSocket.finalize (/opt/iobroker/node_modules/ws/lib/WebSocket.js:182:41)
            at Socket.emit (events.js:188:7)
            at onwriteError (_stream_writable.js:345:10)
            at onwrite (_stream_writable.js:363:5)
            2018-06-28 04:03:24.576 - warn: web.0 Reconnection to DB.
            2018-06-28 04:03:24.583 - warn: web.0 Reconnection to DB.
            2018-06-28 04:03:24.633 - info: web.0 starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.web, node: v6.14.3
            2018-06-28 04:03:24.718 - info: web.0 starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.web, node: v6.14.3
            2018-06-28 04:03:25.007 - info: web.0 socket.io server listening on port 8082
            2018-06-28 04:03:25.110 - info: web.0 socket.io server listening on port 8082
            2018-06-28 04:03:25.164 - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 ()
            2018-06-28 04:03:25.165 - info: host.raspberrypi Restart adapter system.adapter.web.0 because enabled
            2018-06-28 04:03:26.707 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 871
            2018-06-28 04:03:26.741 - info: host.raspberrypi instance system.adapter.geofency.0 started with pid 877
            2018-06-28 04:03:26.818 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 883
            2018-06-28 04:03:29.710 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 889
            2018-06-28 04:03:29.742 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 895
            2018-06-28 04:03:29.774 - info: host.raspberrypi instance system.adapter.fritzbox.0 started with pid 901
            2018-06-28 04:03:29.849 - info: host.raspberrypi instance system.adapter.sayit.0 started with pid 902
            2018-06-28 04:03:31.303 - info: geofency.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.geofency, node: v6.14.3
            2018-06-28 04:03:31.396 - info: geofency.0 Adapter got 'Ready' Signal - initiating Main function...
            2018-06-28 04:03:31.509 - info: geofency.0 http server listening on port 7999
            2018-06-28 04:03:31.434 - info: rpi2.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v6.14.3
            2018-06-28 04:03:34.365 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 921
            2018-06-28 04:03:35.418 - info: cloud.0 starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.14.3
            2018-06-28 04:03:36.617 - info: cloud.0 Connecting with https://iobroker.net:10555 with "i*************"
            2018-06-28 04:03:36.764 - info: sayit.0 starting. Version 1.6.8 in /opt/iobroker/node_modules/iobroker.sayit, node: v6.14.3
            2018-06-28 04:03:36.854 - info: sayit.0 Upload announce mp3 files
            2018-06-28 04:03:36.952 - info: discovery.0 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.14.3
            2018-06-28 04:03:37.222 - error: telegram.0 no connection to objects DB
            2018-06-28 04:03:37.866 - info: sayit.0 All files uploaded
            2018-06-28 04:03:38.444 - info: cloud.0 Trying to connect as system.user.admin
            2018-06-28 04:03:38.127 - info: fritzbox.0 starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v6.14.3
            2018-06-28 04:03:38.223 - info: fritzbox.0 try to connect: 192.168.178.1
            2018-06-28 04:03:38.426 - info: fritzbox.0 adapter connected to fritzbox: 192.168.178.1
            2018-06-28 04:03:38.818 - info: admin.0 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v6.14.3
            2018-06-28 04:03:38.890 - info: admin.0 requesting all states
            2018-06-28 04:03:38.900 - info: admin.0 requesting all objects
            2018-06-28 04:03:38.905 - info: admin.0 Request actual repository...
            2018-06-28 04:03:41.253 - info: telegram.0 starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.telegram, node: v6.14.3
            2018-06-28 04:03:41.446 - info: admin.0 received all states
            2018-06-28 04:03:42.071 - info: telegram.0 getMe: {"id":556776579,"is_bot":true,"first_name":"SperberBot","username":"SperberBot"}
            2018-06-28 04:03:41.796 - info: sonos.0 starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.sonos, node: v6.14.3
            2018-06-28 04:03:42.058 - info: sonos.0 http sonos server listening on port 8083
            2018-06-28 04:03:42.188 - error: cloud.0 Cloud says: timeout
            2018-06-28 04:03:43.202 - info: cloud.0 Connection changed: io server disconnect
            2018-06-28 04:03:44.272 - info: rpi2.0 GPIO ports are not configured
            2018-06-28 04:03:45.376 - info: admin.0 received all objects
            2018-06-28 04:03:45.732 - info: admin.0 http server listening on port 8081
            2018-06-28 04:03:45.733 - info: admin.0 Use link "http://localhost:8081" to configure.
            2018-06-28 04:03:46.274 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
            2018-06-28 04:03:49.154 - info: admin.0 Repository received successfully.
            2018-06-28 04:03:55.237 - info: host.raspberrypi instance system.adapter.web.0 started with pid 991
            2018-06-28 04:03:58.826 - info: web.0 starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.web, node: v6.14.3
            2018-06-28 04:03:59.834 - info: web.0 socket.io server listening on port 8082
            2018-06-28 04:03:59.848 - info: web.0 http server listening on port 8082
            2018-06-28 04:04:36.733 - info: cloud.0 Trying to connect as system.user.admin
            2018-06-28 04:04:36.858 - info: cloud.0 Adapter redirected temporally to "https://iobroker.net:10560" in one minute. Reason: command from server
            2018-06-28 04:04:36.862 - info: cloud.0 Connection changed: io client disconnect
            2018-06-28 04:05:36.892 - info: cloud.0 Trying to connect as system.user.admin
            2018-06-28 04:05:37.020 - info: cloud.0 Connection changed: connect
              aaaahhhh … now I see ...
              was läuft denn so neben ioBroker noch auf dem Host?
              Also was passiert ist das scheinbar bei einem Reboot und dann dem Start der ganzen Adapter (33 Stück bei dir!!) ich tippe die CPU an ihre grenzen stösst und damit das Starten der Adapter länger dauert. So lange das die nach dem Connect zur State/Objects-DB verlieren bzw der "20 Sekunden Keepalive-check" nicht klappt. Damit wird reconnected und das startet plötzlich die Adapter nochmal neu und dann kommen komische Dinge.
              Wie "am limit" ist denn das system lso als Raspi mit 33 Instanzen?
              • L Offline
                LJSven
                Ich habe das komplett neu aufgesetzt.
                Raspberry mit Stretch Lite & iobroker. Das ist alles. Anschließend habe ich ein Backup vom iobroker eingespielt. Sonst habe ich auf dem Raspberry nichts installiert.
                • L Offline
                  LJSven
                  Sind 33 Instanzen viel? Soll ich welche löschen?
                    Kommt aufs ein System an.
                    Wenn alles gut läuft wieviel Speicher hat das System so frei? Was sagt „top“?
                    Gesendet vom Handy …
                    • L Offline
                      LJSven
                      Ich habe einen ganz normalen Raspberry 3 / kann oder soll ich da was aufstocken? Ist da im Bios was falsch?
                      • L Offline
                        LJSven
                        Das zeigt TOP an - ich bin echt ratlos :-(
                        top - 15:45:40 up 11:45,  1 user,  load average: 0,85, 1,12, 0,93
                        Tasks: 116 total,   1 running,  71 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  3,8 us,  0,3 sy,  0,0 ni, 95,8 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
                        KiB Mem :   949452 total,   170680 free,   581700 used,   197072 buff/cache
                        KiB Swap:   102396 total,    98556 free,     3840 used.   304676 avail Mem
                          PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
                        28720 root      20   0  174844  79516  19844 S   5,6  8,4   0:22.20 io.javascript.0
                        28688 root      20   0  159764  60036  17820 S   4,3  6,3   0:57.03 iobroker.js-con
                        28747 root      20   0  139552  41148  17620 S   2,0  4,3   0:11.09 io.sonos.0
                        28779 root      20   0    8512   3432   2864 R   1,0  0,4   0:02.54 top
                        28879 root      20   0  124452  32772  17640 S   1,0  3,5   0:05.83 io.web.0
                        29049 root      20   0  142808  40888  18212 S   1,0  4,3   0:07.67 io.telegram.0
                        28763 root      20   0  127340  35876  17516 S   0,7  3,8   0:07.41 io.sonoff.0
                        27732 root      20   0       0      0      0 I   0,3  0,0   0:02.60 kworker/u8:1
                        28260 root      20   0       0      0      0 I   0,3  0,0   0:00.04 kworker/1:0
                        28753 root      20   0  137332  37888  17464 S   0,3  4,0   0:09.47 io.fritzdect.0
                        28833 root      20   0  129624  44168  17604 S   0,3  4,7   0:04.47 io.scenes.0
                        29016 root      20   0  121272  34984  17624 S   0,3  3,7   0:03.65 io.mqtt.0
                        29036 root      20   0  120652  32252  17552 S   0,3  3,4   0:03.52 io.mihome.0
                            1 root      20   0   27004   5944   4804 S   0,0  0,6   0:02.91 systemd
                            2 root      20   0       0      0      0 S   0,0  0,0   0:00.02 kthreadd
                            4 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 kworker/0:0H
                            6 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 mm_percpu_wq
                            7 root      20   0       0      0      0 S   0,0  0,0   0:01.56 ksoftirqd/0
                            8 root      20   0       0      0      0 I   0,0  0,0   0:10.44 rcu_sched
                            9 root      20   0       0      0      0 I   0,0  0,0   0:00.00 rcu_bh
                           10 root      rt   0       0      0      0 S   0,0  0,0   0:00.01 migration/0
                           11 root      20   0       0      0      0 S   0,0  0,0   0:00.00 cpuhp/0
                           12 root      20   0       0      0      0 S   0,0  0,0   0:00.00 cpuhp/1
                           13 root      rt   0       0      0      0 S   0,0  0,0   0:00.01 migration/1
                           14 root      20   0       0      0      0 S   0,0  0,0   0:00.52 ksoftirqd/1
                           16 root       0 -20       0      0      0 I   0,0  0,0   0:00.00 kworker/1:0H
                          Abgesehen vom Fakt das 5MB Swap benutzt sind ist das alles ok …
                          In js.-controller 1.5.0 wird eine Änderung drin sein die das Problem ggf vermindert. Müsste man dann mal testen
                            PS: Überlege einfach ob du wirklich jede Nacht den Raspi neu starten musst … eigentlich sollte das unötig sein
                            • L Offline
                              LJSven
                              @apollon77:
                              Abgesehen vom Fakt das 5MB Swap benutzt sind ist das alles ok … `
                              Ich nehme den Reboot mal raus - was bedeutet der Satz? Kann / muss ich da was ändern?
