  4. [Fehler] ModBus-Adapter 2.0.3
24 Beiträge 4 Kommentatoren 3.3k Aufrufe
  • StabilostickS Offline
    Stabilostick
    Noch zwei Screenshots mit den Settings, die zum Fehler führen:
    Die Dialoge für die "Diskreten Ein- und Augänge" sowie die "Eingangsregister" sind leer.
      Stabilostick
      DIe Dateien und Verzeichnisse, die von jsmodbus/index.js angesprochen werden sind
      C:\dev\iobroker\node_modules\iobroker.modbus\lib\jsmodbus/transports/modbus-server-tcp.js
      C:\dev\iobroker\node_modules\iobroker.modbus\lib\jsmodbus/handler/server
      C:\dev\iobroker\node_modules\iobroker.modbus\lib\jsmodbus/handler/server/ReadCoils.js -> vor require
      C:\dev\iobroker\node_modules\iobroker.modbus\lib\jsmodbus/handler/server/ReadCoils.js -> require gelaufen
      function Factory(refs) {
          for (var _len9 = arguments.length, args = Array(_len9 > 1 ? _len9 - 1 : 0), _key9 = 1; _key9 < _len9; _key9++) {
            args[_key9 - 1] = arguments[_key9];
          var instance = (0, _supermixer.mixin)(create(fixed.methods), fixed.refs, refs);
          (0, _supermixer.mergeUnique)(instance, fixed.props); // props are safely merged into refs
          var nextPromise = null;
          if (fixed.init.length > 0) {
            (0, _lodashCollectionForEach2['default'])(fixed.init, function (fn) {
              if (!(0, _lodashLangIsFunction2['default'])(fn)) {
                return; // not a function, do nothing.
              // Check if we are in the async mode.
              if (!nextPromise) {
                // Call the init().
                var callResult = fn.call(instance, { args: args, instance: instance, stamp: factory });
                if (!callResult) {
                  return; // The init() returned nothing. Proceed to the next init().
                // Returned value is meaningful.
                // It will replace the stampit-created object.
                if (!isThenable(callResult)) {
                  instance = callResult; // stamp is synchronous so far.
                  return;
                // This is the sync->async conversion point.
                // Since now our factory will return a promise, not an object.
                nextPromise = callResult;
              } else {
                // As long as one of the init() functions returned a promise,
                // now our factory will 100% return promise too.
                // Linking the init() functions into the promise chain.
                nextPromise = nextPromise.then(function (newInstance) {
                  // The previous promise might want to return a value,
                  // which we should take as a new object instance.
                  instance = newInstance || instance;
                  // Calling the following init().
                  // NOTE, than `fn` is wrapped to a closure within the forEach loop.
                  // Check if call result is truthy.
                  if (!callResult) {
                    // The init() returned nothing. Thus using the previous object instance.
                    return instance;
                    // This init() was synchronous and returned a meaningful value.
                    // Resolve the instance for the next `then()`.
                    return instance;
                  // The init() returned another promise. It is becoming our nextPromise.
                  return callResult;
          // At the end we should resolve the last promise and
          // return the resolved value (as a promise too).
          return nextPromise ? nextPromise.then(function (newInstance) {
            return newInstance || instance;
          }) : instance;
      -> nach compose
      C:\dev\iobroker\node_modules\iobroker.modbus\lib\jsmodbus/handler/server/ReadDiscreteInputs.js -> vor require
      Dann ist Stille.
      Obiges kam aus -> krudes Logging in jsmodbus/index.js eingefügt:
      'use strict';
      const fs = require('fs');
      var util = require('util');
      var log_file = fs.createWriteStream('C:/debug.log', {flags : 'w'});
      var log_stdout = process.stdout;
      console.log = function(d) { //
        log_file.write(util.format(d) + '\n');
        log_stdout.write(util.format(d) + '\n');
      function Modbus(type, transport) {
      console.log(__dirname + `/transports/modbus-${type}-${transport || 'tcp'}.js`);
      console.log(__dirname + `/handler/${type}`);
          let core = require(__dirname + `/transports/modbus-${type}-${transport || 'tcp'}.js`);
          fs.readdirSync(__dirname + `/handler/${type}`)
              .filter(file => file.substr(-3) === '.js').forEach(file => {
                  console.log(__dirname + `/handler/${type}/${file} -> vor require`);
                  const handler = require(__dirname + `/handler/${type}/${file}`);
                  console.log(__dirname + `/handler/${type}/${file} -> require gelaufen`);
                  core = core.compose(handler);
                  console.log(handler + ` -> nach compose`);
                  //core.handler[file.substr(0, file.length - 3)] = handler;
          return core;
      module.exports = Modbus;
        Stabilostick
        Es scheint mir so, als ob die letzte Zeile der Datei /handler/server/ReadDiscreteInputs.js unnötig ist?
        Flugs dort auskommentiert:
        // module.exports = handler;
        Jetzt läuft jsmodbus/index.js durch.
        Als Belohnung gibt es einen neuen Fehler:
        2018-06-21 09:30:29.849 - info: host.ARBEITSZIMMER instance system.adapter.modbus.2 started with pid 1608
        2018-06-21 09:30:30.268 - debug: modbus.2 objectDB connected
        2018-06-21 09:30:30.277 - debug: modbus.2 statesDB connected
        2018-06-21 09:30:30.288 - info: modbus.2 starting. Version 2.0.3 in C:/dev/iobroker/node_modules/iobroker.modbus, node: v8.11.1
        2018-06-21 09:30:30.654 - silly: modbus.2 inMem message modbus.2.* modbus.2.info.connection val=0, ack=true, ts=1529566230655, q=0, from=system.adapter.modbus.2, lc=1529535577826
        2018-06-21 09:30:30.721 - error: modbus.2 uncaught exception: Cannot read property 'tcp' of undefined
        2018-06-21 09:30:30.721 - error: modbus.2 TypeError: Cannot read property 'tcp' of undefined
        at init (C:\dev\iobroker\node_modules\iobroker.modbus\lib\jsmodbus\transports\modbus-server-tcp.js:19:36)
        at Object. (C:\dev\iobroker\node_modules\iobroker.modbus\lib\jsmodbus\transports\modbus-server-tcp.js:148:9)
        at C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\stampit\dist\stampit.js:185:31
        at arrayEach (C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\lodash\internal\arrayEach.js:15:9)
        at C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\lodash\internal\createForEach.js:15:9
        at Factory (C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\stampit\dist\stampit.js:177:48)
        at Slave.initValues (C:\dev\iobroker\node_modules\iobroker.modbus\lib\slave.js:149:51)
        at adapter.getStates (C:\dev\iobroker\node_modules\iobroker.modbus\lib\slave.js:141:13)
        at C:\dev\iobroker\node_modules\iobroker.js-controller\lib\adapter.js:4036:61
        at Socket. (C:\dev\iobroker\node_modules\iobroker.js-controller\lib\states\statesInMemClient.js:153:27)
        2018-06-21 09:30:31.738 - error: Caught by controller[0]: TypeError: Cannot read property 'tcp' of undefined
        2018-06-21 09:30:31.738 - error: Caught by controller[0]: at init (C:\dev\iobroker\node_modules\iobroker.modbus\lib\jsmodbus\transports\modbus-server-tcp.js:19:36)
        2018-06-21 09:30:31.738 - error: Caught by controller[0]: at Object. (C:\dev\iobroker\node_modules\iobroker.modbus\lib\jsmodbus\transports\modbus-server-tcp.js:148:9)
        2018-06-21 09:30:31.738 - error: Caught by controller[0]: at C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\stampit\dist\stampit.js:185:31
        2018-06-21 09:30:31.738 - error: Caught by controller[0]: at arrayEach (C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\lodash\internal\arrayEach.js:15:9)
        2018-06-21 09:30:31.738 - error: Caught by controller[0]: at C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\lodash\internal\createForEach.js:15:9
        2018-06-21 09:30:31.738 - error: Caught by controller[0]: at Factory (C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\stampit\dist\stampit.js:177:48)
        2018-06-21 09:30:31.738 - error: Caught by controller[0]: at Slave.initValues (C:\dev\iobroker\node_modules\iobroker.modbus\lib\slave.js:149:51)
        2018-06-21 09:30:31.738 - error: Caught by controller[0]: at adapter.getStates (C:\dev\iobroker\node_modules\iobroker.modbus\lib\slave.js:141:13)
        2018-06-21 09:30:31.738 - error: Caught by controller[0]: at C:\dev\iobroker\node_modules\iobroker.js-controller\lib\adapter.js:4036:61
        2018-06-21 09:30:31.738 - error: Caught by controller[0]: at Socket. (C:\dev\iobroker\node_modules\iobroker.js-controller\lib\states\statesInMemClient.js:153:27)
        2018-06-21 09:30:31.738 - error: host.ARBEITSZIMMER instance system.adapter.modbus.2 terminated with code 6 (uncaught exception)
        2018-06-21 09:30:31.738 - info: host.ARBEITSZIMMER Restart adapter system.adapter.modbus.2 because enabled
        Hey, erst mal was positives aus dem Log: Der Adapter hat sowas wie Daten empfangen:
        Hrrm…
        • apollon77A Offline
          Ja das eine exports war denke zuviel. Soweit war ich auch gekommen kurz bevor ich es hier gelesen habe :-)
          Ein TCP Objekt wird nur "gebaut" wenn slave gewählt ist … Ich hae mal was rumgebastelt. Bitte Github Version testen
          Aber generell ist bei TCP noch was unvollständig!!
            Stabilostick
            Nope, leider nix guut.
            [...npm install]
            2018-06-21 10:51:32.943 - info: iobroker url "https://github.com/ioBroker/ioBroker.modbus/tarball/master" modbus
            2018-06-21 10:51:33.339 - info: iobroker install https://github.com/ioBroker/ioBroker.modbus/tarball/master
            2018-06-21 10:51:33.399 - info: iobroker npm install https://github.com/ioBroker/ioBroker.modbus/tarball/master --production --prefix "C:/dev/iobroker" (System call)
            2018-06-21 10:51:37.419 - info: iobroker npm
            2018-06-21 10:51:37.419 - info: iobroker WARN deprecated parser-readline@1.0.2: reanmed to @serialport/parser-readline
            2018-06-21 10:51:37.419 - info: iobroker WARN deprecated parser-byte-length@1.0.2: renamed to @serialport/parser-byte-length
            2018-06-21 10:51:37.419 - info: iobroker WARN deprecated parser-cctalk@1.0.2: reanmed to @serialport/parser-cctalk
            2018-06-21 10:51:37.419 - info: iobroker WARN deprecated parser-delimiter@1.0.2: reanmed to @serialport/parser-delimiter
            2018-06-21 10:51:37.428 - info: iobroker npm
            2018-06-21 10:51:37.428 - info: iobroker WARN deprecated parser-ready@1.0.2: reanmed to @serialport/parser-readynpm WARN deprecated parser-regex@1.0.2: reanmed to @serialport/parser-regex
            2018-06-21 10:51:42.728 - info: iobroker got C:/dev/iobroker/node_modules/iobroker.modbus/admin
            2018-06-21 10:51:42.758 - info: iobroker upload [19] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/words.js words.js application/javascript
            2018-06-21 10:51:42.838 - info: iobroker upload [18] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
            2018-06-21 10:51:42.918 - info: iobroker upload [17] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.js lib/js/jsgrid.js application/javascript
            2018-06-21 10:51:42.995 - info: iobroker upload [16] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-ru.js lib/js/grid.locale-ru.js application/javascript
            2018-06-21 10:51:43.070 - info: iobroker upload [15] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-de.js lib/js/grid.locale-de.js application/javascript
            2018-06-21 10:51:43.125 - info: iobroker upload [14] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.min.css lib/css/jsgrid.min.css text/css
            2018-06-21 10:51:43.191 - info: iobroker upload [13] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.css lib/css/jsgrid.css text/css
            2018-06-21 10:51:43.256 - info: iobroker upload [12] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.min.css lib/css/jsgrid-theme.min.css text/css
            2018-06-21 10:51:43.318 - info: iobroker upload [11] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.css lib/css/jsgrid-theme.css text/css
            2018-06-21 10:51:43.398 - info: iobroker upload [10] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/index.html index.html text/html
            2018-06-21 10:51:43.478 - info: iobroker upload [9] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/img/plc_back.png img/plc_back.png image/png
            2018-06-21 10:51:43.558 - info: iobroker upload [8] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            2018-06-21 10:51:43.638 - info: iobroker upload [7] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            2018-06-21 10:51:43.719 - info: iobroker upload [6] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            2018-06-21 10:51:43.798 - info: iobroker upload [5] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            2018-06-21 10:51:43.878 - info: iobroker upload [4] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/i18n/it/translations.json i18n/it/translations.json application/json
            2018-06-21 10:51:43.959 - info: iobroker upload [3] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            2018-06-21 10:51:44.039 - info: iobroker upload [2] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/i18n/es/translations.json i18n/es/translations.json application/json
            2018-06-21 10:51:44.119 - info: iobroker upload [1] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/i18n/en/translations.json i18n/en/translations.json application/json
            2018-06-21 10:51:44.199 - info: iobroker upload [0] modbus.admin C:/dev/iobroker/node_modules/iobroker.modbus/admin/i18n/de/translations.json i18n/de/translations.json application/json
            2018-06-21 10:51:44.289 - info: iobroker exit 0
            2018-06-21 10:51:44.400 - info: host.ARBEITSZIMMER Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
            [...running - oder eher nicht ;-) ]
            2018-06-21 10:52:09.228 - info: host.ARBEITSZIMMER object change system.adapter.modbus.2
            2018-06-21 10:52:09.228 - info: host.ARBEITSZIMMER instance system.adapter.modbus.2 started with pid 8232
            2018-06-21 10:52:09.658 - debug: modbus.2 objectDB connected
            2018-06-21 10:52:09.668 - debug: modbus.2 statesDB connected
            2018-06-21 10:52:09.688 - info: modbus.2 starting. Version 2.0.3 in C:/dev/iobroker/node_modules/iobroker.modbus, node: v8.11.1
            2018-06-21 10:52:10.088 - silly: modbus.2 inMem message modbus.2.* modbus.2.info.connection val=0, ack=true, ts=1529571130088, q=0, from=system.adapter.modbus.2, lc=1529535577826
            2018-06-21 10:52:10.159 - error: modbus.2 uncaught exception: Cannot read property 'tcp' of undefined
            2018-06-21 10:52:10.159 - error: modbus.2 TypeError: Cannot read property 'tcp' of undefined
            2018-06-21 10:52:11.167 - error: Caught by controller[0]: TypeError: Cannot read property 'tcp' of undefined
            2018-06-21 10:52:11.167 - error: Caught by controller[0]: at init (C:\dev\iobroker\node_modules\iobroker.modbus\lib\jsmodbus\transports\modbus-server-tcp.js:19:36)
            2018-06-21 10:52:11.167 - error: Caught by controller[0]: at Object. (C:\dev\iobroker\node_modules\iobroker.modbus\lib\jsmodbus\transports\modbus-server-tcp.js:148:9)
            2018-06-21 10:52:11.167 - error: Caught by controller[0]: at C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\stampit\dist\stampit.js:185:31
            2018-06-21 10:52:11.167 - error: Caught by controller[0]: at arrayEach (C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\lodash\internal\arrayEach.js:15:9)
            2018-06-21 10:52:11.167 - error: Caught by controller[0]: at C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\lodash\internal\createForEach.js:15:9
            2018-06-21 10:52:11.167 - error: Caught by controller[0]: at Factory (C:\dev\iobroker\node_modules\iobroker.modbus\node_modules\stampit\dist\stampit.js:177:48)
            2018-06-21 10:52:11.167 - error: Caught by controller[0]: at Slave.initValues (C:\dev\iobroker\node_modules\iobroker.modbus\lib\slave.js:149:51)
            2018-06-21 10:52:11.167 - error: Caught by controller[0]: at adapter.getStates (C:\dev\iobroker\node_modules\iobroker.modbus\lib\slave.js:141:13)
            2018-06-21 10:52:11.167 - error: Caught by controller[0]: at C:\dev\iobroker\node_modules\iobroker.js-controller\lib\adapter.js:4036:61
            2018-06-21 10:52:11.167 - error: Caught by controller[0]: at Socket. (C:\dev\iobroker\node_modules\iobroker.js-controller\lib\states\statesInMemClient.js:153:27)
            2018-06-21 10:52:11.167 - error: host.ARBEITSZIMMER instance system.adapter.modbus.2 terminated with code 6 (uncaught exception)
            2018-06-21 10:52:11.167 - info: host.ARBEITSZIMMER Restart adapter system.adapter.modbus.2 because enabled
            Dem Weg würde ich folgen:
              Stabilostick
              Ups, du hast verschlimmbessert. Die anderen Adapter (Master) bringen jetzt den folgenden Fehler:
              2018-06-21 11:02:26.973 - info: host.ARBEITSZIMMER instance system.adapter.modbus.1 started with pid 25028
              2018-06-21 11:02:27.412 - debug: modbus.1 objectDB connected
              2018-06-21 11:02:27.422 - debug: modbus.1 statesDB connected
              2018-06-21 11:02:27.436 - info: modbus.1 starting. Version 2.0.3 in C:/dev/iobroker/node_modules/iobroker.modbus, node: v8.11.1
              2018-06-21 11:02:27.951 - info: history.0 enabled logging of modbus.1.inputRegisters.30775_AC_Leistung_Gesamt
              2018-06-21 11:02:27.992 - info: history.0 enabled logging of modbus.1.inputRegisters.30803_Netzfrequenz
              2018-06-21 11:02:28.032 - info: history.0 enabled logging of modbus.1.inputRegisters.30843_Batterie_Strom
              2018-06-21 11:02:28.072 - info: history.0 enabled logging of modbus.1.inputRegisters.30845_Batterie_SOC
              2018-06-21 11:02:28.112 - info: history.0 enabled logging of modbus.1.inputRegisters.30849_Batterie_Temperatur
              2018-06-21 11:02:28.152 - info: history.0 enabled logging of modbus.1.inputRegisters.30851_Batterie_Spannung
              2018-06-21 11:02:28.192 - info: history.0 enabled logging of modbus.1.inputRegisters.30855_Batterie_SetSpannung
              2018-06-21 11:02:28.232 - info: history.0 enabled logging of modbus.1.inputRegisters.30861_Last_Leistung
              2018-06-21 11:02:28.272 - info: history.0 enabled logging of modbus.1.inputRegisters.30867_Einspeiseleistung
              2018-06-21 11:02:28.312 - info: history.0 enabled logging of modbus.1.inputRegisters.30869_PV_Gesamtleistung
              2018-06-21 11:02:28.352 - info: history.0 enabled logging of modbus.1.inputRegisters.30873_Einverbrauchserhöhung
              2018-06-21 11:02:29.514 - error: modbus.1 Socket Error
              2018-06-21 11:02:29.514 - error: modbus.1 Client in error state.
              2018-06-21 11:02:29.514 - warn: modbus.1 On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
              2018-06-21 11:02:29.515 - debug: modbus.1 Socket closed with error
              2018-06-21 11:02:29.515 - debug: modbus.1 Cleaning up request fifo.
              2018-06-21 11:02:30.521 - debug: modbus.1 Closing client on purpose.
                Ja ich sehe den grund … aber da bin ich jetzt raus ...
                @Bluefus muss da ran. Das kann so nicht gehen ...
                  Stabilostick
                  Achtung, die von Bluefox auf Github eingestellte Version 2.0.4 ist weiterhin fehlerbehaftet. Es funktionieren bei TCP-Typ jetzt weder Master- noch-Slave-Konfigurationen. Damit Master wieder geht, in Datei "modbus-client-tcp.js" die Zeile 25 von
                  tcp.host = tcp.bind || 'localhost';
                  nach
                  tcp.host = tcp.host || 'localhost';
                  ändern.
                  Zudem sind mindestens in der Datei "slave.js" ab Zeile 150 weitere Anpassungen nötig, damit der Wert von "tcp" definiert ist:
                       options: {
                       tcp: {
                              hostname: '127.0.0.1',  //??????
                              port: parseInt(options.config.tcp.port, 10) || 502
                  Übrig bleibt dann als nächstes die undefinierte "server"-Variable/Objekt? in
                  .compose(server.tcp.complete)
                  ein paar Zeilen weiter unten.
                  Da gebe ich erst einmal auf… Ich kann leider kein Javascript.
                  • J Offline
                    JackWolfskind
                    Habe auch gerade festgestellt das Modbus TCP mit der Version 2.0.4 nicht mehr geht und daher ein Issue auf github aufgemacht…
                    Update:
                    Mit der 2.0.6 ist Modbus TCP wieder gefixt!
                      Stabilostick
                      Nur der Master-Typ. Slave braucht noch. :D
                        Stabilostick
                        Bluefox hat eine neue Revision der v2.0.6 auf Guthub bereitgestellt. Der TCP-Slave Modus soll laut seiner Angabe gefixed sein.
                        Zwar sind die augenscheinlichen Exceptions jetzt weg. Leider findet bei mir aber mit der neuen Version keine Kommunikation statt. Der Status des Adapers bleibt auf gelb stehen.
                        Ich verwende diese Konfiguration: 7446_2018-06-28_17_26_05-instances_-_iobroker.png
                        In der Anleitung zum Adapter steht:
                        Partner IP Address = IP address of modbus partner.
                        Port = TCP Port of modbus partner if configured as master (client) or own port if configured as slave(server).
                        Die Eingänge sind Holding Registers.
                        Mit diesen Einstellungen hat V1.1.1 des Adpaters funktioniert. Jetzt wirft der Adapter v2.0.6(neu) den Fehler
                        2018-06-28 11:56:28.913 - info: host.ARBEITSZIMMER instance system.adapter.modbus.2 started with pid 45604
                        2018-06-28 11:56:29.331 - debug: modbus.2 objectDB connected
                        2018-06-28 11:56:29.342 - debug: modbus.2 statesDB connected
                        2018-06-28 11:56:29.342 - info: modbus.2 starting. Version 2.0.6 in C:/dev/iobroker/node_modules/iobroker.modbus, node: v8.11.1
                        2018-06-28 11:56:29.612 - debug: modbus.2 Slave ready to start
                        2018-06-28 11:56:29.682 - debug: modbus.2 server is listening on port
                        2018-06-28 11:56:29.682 - debug: modbus.2 initiating read coils request handler.
                        2018-06-28 11:56:29.682 - debug: modbus.2 setting request handler
                        2018-06-28 11:56:29.682 - debug: modbus.2 initiating read discrete inputs request handler.
                        2018-06-28 11:56:29.682 - debug: modbus.2 initiating read holding registers request handler.
                        2018-06-28 11:56:29.682 - debug: modbus.2 initiating read input registers request handler.
                        2018-06-28 11:56:29.682 - debug: modbus.2 initiating write multiple coils request handler.
                        2018-06-28 11:56:29.682 - debug: modbus.2 initiating write multiple registers request handler.
                        2018-06-28 11:56:29.682 - debug: modbus.2 initiating write single coil request handler.
                        2018-06-28 11:56:29.682 - debug: modbus.2 initiating write single register request handler.
                        2018-06-28 11:56:29.692 - error: modbus.2 uncaught exception: listen EADDRNOTAVAIL 192.168.179.28:502
                        2018-06-28 11:56:29.692 - error: modbus.2 Error: listen EADDRNOTAVAIL 192.168.179.28:502
                        at Object._errnoException (util.js:1022:11)
                        at _exceptionWithHostPort (util.js:1044:20)
                        at Server.setupListenHandle [as _listen2] (net.js:1350:19)
                        at listenInCluster (net.js:1408:12)
                        at doListen (net.js:1517:7)
                        at _combinedTickCallback (internal/process/next_tick.js:141:11)
                        at process._tickCallback (internal/process/next_tick.js:180:9)
                        2018-06-28 11:56:29.692 - info: modbus.2 terminating
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: { Error: listen EADDRNOTAVAIL 192.168.179.28:502
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: at Object._errnoException (util.js:1022:11)
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: at _exceptionWithHostPort (util.js:1044:20)
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1350:19)
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: at listenInCluster (net.js:1408:12)
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: at doListen (net.js:1517:7)
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:141:11)
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:180:9)
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: code: 'EADDRNOTAVAIL',
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: errno: 'EADDRNOTAVAIL',
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: syscall: 'listen',
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: address: '192.168.179.28',
                        2018-06-28 11:56:29.703 - error: Caught by controller[0]: port: 502 }
                        2018-06-28 11:56:29.703 - error: host.ARBEITSZIMMER instance system.adapter.modbus.2 terminated with code 0 (OK)
                        2018-06-28 11:56:29.703 - info: host.ARBEITSZIMMER Restart adapter system.adapter.modbus.2 because enabled
                        Auf dem Modbus-Master 192.168.179.28 ist der Port 502 nicht geöffnet (war noch nie).
                        Die Konfiguration auf dem Master, die mit Version 1.1.1 funktioniert hat, sieht so aus:
                        Die Dokumentation des Masters sagt dazu:
                        IP, Gerärt, Funktion, Adresse = Eingabe der IP-Adresse und der herstellerspezifischen Angaben des Modbus-Geräts (= Slave), an das der Wert gesendet wird
                        Was nun? Mache ich etwas falsch? Muss ich 127.0.0.1 angeben beim Slave (funktioniert aber auch nicht!)?
                          du hast bei ioberoker in der Konfig aber "Master" ausgewählt. Wenn DU lesen willst bist Du eher ein Slave oder ?!
                            Stabilostick
                            Zwischenzeitlich ging der Master Mode bei der Version 2.0.6 (ohne neu) auch nicht. Im vorletzten Post zeige ich die Slave-Konfiguration für 2.0.6neu. Und ich will nicht lesen. Der ferne Master 192.168.179.28 schreibt in mich (192.168.179.56) als Slave rein.
                            Also dürfte der ioBroker also gar nicht bei einer Slave-Konfiguration auf den Master zugreifen, oder?
                            Wenn ich das so richtig verstanden habe…
                              Stabilostick
                              In der Version 1.1.2 stand noch in der Datei modbus-tcp-client.js
                                          if (!this.protocolVersion) { this.protocolVersion = 0; }
                                          if (!this.port) { this.port = 502; }
                                          if (!this.host) { this.host = 'localhost'; }
                                          if (!this.autoReconnect) { this.autoReconnect = false; }
                                          if (!this.reconnectTimeout) { this.reconnectTimeout = 0; }
                              Edit: Quatsch, was ich hier gerade schreibe. Steht nicht im Zusammenhang. Der Server-Prozess in modbus-tcp-server.js macht da nichts anderes:
                                          if (!this.port) {
                                              this.port = 502;
                                          if (!this.hostname) {
                                              this.hostname = '0.0.0.0';
                                        server.listen(this.port, this.hostname, function (err) {
                                Stabilostick
                                Der Modbus-Master hat auch ein Log.
                                2018.06.28 23:10:01 [R854/V1.30.2] ( 39) Message: #FFFFFFFA Cannot connect to Modbus device
                                Die Netzwerksockets sind am Master wie folgt:
                                  Stabilostick
                                  Setze ich die Partner-ID auf 127.0.0.1, dann überwacht der ioBroker (192.168.179.56) den lokalen Port 502:
                                   TCP    127.0.0.1:502          0.0.0.0:0              ABHÖREN       [node.exe]
                                  Jedoch sagt der Master weiterhin, dass er keine Verbindung zum Slave aufbauen kann.
                                    Stabilostick
                                    Das zeigt Ananas, ein Modbus Slave, gestartet auf dem ioBroker-Rechner an: 7446_2018-06-29_12_09_07-ananas_-modbus_tcp_server_at__192.168.179.56.png Der Modbus-Master funktioniert also.
                                      Stabilostick
                                      Oookkkkkkaaaayyyyy,
                                      wenn ich die Parter-ID in der Modbus-Adapter-Konfiguration beim Typ Slave auf 0.0.0.0 stelle, funktioniert augenscheinlich die Kommunikation (muss noch weiter testen).
                                      Hmm, muss das (jetzt) so sein?
                                      • BluefoxB Offline
                                        BluefoxB Offline
                                        Es ist ein Fehler in der Dialog beim Label.
                                        Partner IP muss "Eigene IP" heissen.
                                          Stabilostick
                                          Aber mit 127.0.0.1 geht es nicht.
                                          Slave geht nur mit 0.0.0.0 (alle Interfaces?) oder 192.168.179.56, also ein bestimmtes lokales Netzwerk-Interface.
                                          Könntest Du bitte auch die Doku in der README.md anpassen:
                                          Bislang:
                                          Danke für Deine super Leistungen rund um den ioBroker! :D
