  4. Neuer Robonect HX Adapter
robonectgardenahusqvarnamährobotergarten
470 Beiträge 59 Kommentatoren 167.1k Aufrufe 43 Beobachtet
    mameier1234
    Genau so habe ich es gemacht….
    Grüße,
    Martin
      darkiop
      Ich jetzt auch, falls es jemand braucht (Blockly Import):
       <xml xmlns="http://www.w3.org/1999/xhtml"><block type="create" id="wNq%qfGC20jG:5FHgvIu" x="-1262" y="-112"><field name="NAME">Garten.Rasenmaehroboter.Status</field>
          <next><block type="comment" id="`o*^YK^x2GS8xhlEJ]WY"><field name="COMMENT">Status Rasenroboter aus Zahl wird Text</field>
              <next><block type="comment" id="NJzR}Y_1c;hL-u.il{bG"><field name="COMMENT">http://192.168.1.200/json?cmd=status</field>
                  <next><block type="on_ext" id="-B/i{)JmeNNtfm#+y*,T"><mutation items="1"></mutation>
                      <value name="OID0"><shadow type="field_oid" id="an8k{`9WavP`j9Ii!0F5"><field name="oid">robonect.0.status.status</field></shadow></value>
                      <statement name="STATEMENT"><block type="controls_if" id="8r9y{dBZ/putAzAMN:(T"><mutation elseif="9"></mutation>
                          <value name="IF0"><block type="logic_compare" id="]{H@q-E31KX[g{L}=?(D"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="HqT+m/+P!ZH3E?JdW7~9"><field name="ATTR">val</field>
                                  <field name="OID">robonect.0.status.status</field></block></value>
                              <value name="B"><block type="math_number" id="K9cj`OY`:={BNYkT4:)q"><field name="NUM">0</field></block></value></block></value>
                          <statement name="DO0"><block type="control" id=")[dRZf|IwXo`GBz{(~q%"><mutation delay_input="false"></mutation>
                              <field name="OID">javascript.0.Garten.Rasenmaehroboter.Status</field>
                              <value name="VALUE"><block type="text" id="J8O9uo-_F`UV/1,-.rAJ"><field name="TEXT">Unbekannt</field></block></value></block></statement>
                          <value name="IF1"><block type="logic_compare" id="D-W^PenR~EBTf,SR,Drr"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="b2i3y+mUrh?/=TYVPb{{"><field name="ATTR">val</field>
                              <value name="B"><block type="math_number" id="/]AK/,9)EDuTtTuZX+yN"><field name="NUM">1</field></block></value></block></value>
                          <statement name="DO1"><block type="control" id="6l9#Jbgv+1l6{KS=tP;x"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="text" id="#j6G+s+yVaMD~R:jVUe#"><field name="TEXT">Parken</field></block></value></block></statement>
                          <value name="IF2"><block type="logic_compare" id="H-@m@esL`H%1pyrC%vo5"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="w{dW?wNtQz2/N`BdN4W#"><field name="ATTR">val</field>
                              <value name="B"><block type="math_number" id="*74BIyzbf2Zu(u]BnQJc"><field name="NUM">2</field></block></value></block></value>
                          <statement name="DO2"><block type="control" id="@AcaO@P=ERP((Mj,GVcC"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="text" id="I%g1~j0xv+-zyKz4f)#e"><field name="TEXT">Mähen</field></block></value></block></statement>
                          <value name="IF3"><block type="logic_compare" id="vL_7{!)KG.OZk3T8Vd~0"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="[wa@wSrf9h~KLU:cz|O;"><field name="ATTR">val</field>
                              <value name="B"><block type="math_number" id="q#4zs]1/SYRw^KT|w({V"><field name="NUM">3</field></block></value></block></value>
                          <statement name="DO3"><block type="control" id="KZG[gNyjtJr]7TZd.Bgs"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="text" id="0pF{qi5WoQn|C7L35yOQ"><field name="TEXT">Heimweg</field></block></value></block></statement>
                          <value name="IF4"><block type="logic_compare" id="9cLNe#wOZHO?ufo{n+qd"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="~KS)U]7%Tq0M[7b7:G,5"><field name="ATTR">val</field>
                              <value name="B"><block type="math_number" id="km)]e-6;lP9,M?Up5)}p"><field name="NUM">4</field></block></value></block></value>
                          <statement name="DO4"><block type="control" id="I9xZ1;JaS2N9igLGDX9b"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="text" id="OaDfAVugZc{Qz(^IPEh,"><field name="TEXT">Laden</field></block></value></block></statement>
                          <value name="IF5"><block type="logic_compare" id="vm{PKJR[7A4b5(OGg`a3"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="w.Fh|6/Ie0|*p=nOEt;z"><field name="ATTR">val</field>
                              <value name="B"><block type="math_number" id="YhrorUcm-q^peG*i5fq)"><field name="NUM">5</field></block></value></block></value>
                          <statement name="DO5"><block type="control" id="9uTl5]/#[kJ_;cjEc@Ru"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="text" id="KX`k)x~QE6G:_BSXU?Ak"><field name="TEXT">Umsetzen</field></block></value></block></statement>
                          <value name="IF6"><block type="logic_compare" id="y4y6y0YP;oECHzaChe?k"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="Y!|PPtO(,[i6uJBMn1a3"><field name="ATTR">val</field>
                              <value name="B"><block type="math_number" id="s7gZ9nxE.!O#_u0uZz~v"><field name="NUM">7</field></block></value></block></value>
                          <statement name="DO6"><block type="control" id="BoH6M[{+@Ti7YQae]9.P"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="text" id="@JbK2^k?Cj?N|y,rc7cI"><field name="TEXT">Fehler</field></block></value></block></statement>
                          <value name="IF7"><block type="logic_compare" id="H6S;T5uWMfZNcaQl,E-D"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="C%@5XTqznC5?-LJ`^BFZ"><field name="ATTR">val</field>
                              <value name="B"><block type="math_number" id="D^X;NvhKn+]-8_47(*Zc"><field name="NUM">8</field></block></value></block></value>
                          <statement name="DO7"><block type="control" id="yBv2n82jhaho]zDiW2Pd"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="text" id="U{cb)@yPpoCf;7u8LbP3"><field name="TEXT">Schleifensignal verloren</field></block></value></block></statement>
                          <value name="IF8"><block type="logic_compare" id="0`(DDd4(eurNc9ULEd0k"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="R^Ud_rXao`2|#O5Wf6N~"><field name="ATTR">val</field>
                              <value name="B"><block type="math_number" id="+4nr;0^vG(CGHXl/]En="><field name="NUM">16</field></block></value></block></value>
                          <statement name="DO8"><block type="control" id="9bXjr,Xi9T66aBXkD)=@"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="text" id="}{EyFUA(Y,y^9e%v9I@k"><field name="TEXT">Abgeschaltet</field></block></value></block></statement>
                          <value name="IF9"><block type="logic_compare" id="Qv9@bF3g82oaaszlkIps"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="NLCX}_=_smm*elwm@_p["><field name="ATTR">val</field>
                              <value name="B"><block type="math_number" id="7-6I5ln!.ov@d3:G({*q"><field name="NUM">17</field></block></value></block></value>
                          <statement name="DO9"><block type="control" id="ET7SB`S^RLl~_Fv_@,:q"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="text" id="{C|TqZmr7a2-Usj3LMg9"><field name="TEXT">Schläft</field></block></value></block></statement></block></statement></block></next></block></next></block></next></block></xml>
      Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
        darkiop
        Aktuell werden die DPs next_date, next_time und next_unix nicht befüllt. Im JSON sind diese Werte auch nicht vorhanden:
        Ist der Fehler bekannt?
          Schmaviator
          Was kann ich mit dem Blockly Skript nun anfangen?
          Bekomme meinen Status nicht in den Cloud Adapter reingepackt. :|
            mameier1234
            Das war ja auch nicht gefragt…
            Aber du kannst den Status im VIS sichtbar machen....
            Grüße,
            Martin
            • braindeadB Offline
              braindeadB Offline
              braindead
              So, mein Mäher funktioniert wieder. Das Problem war nicht der Begrenzungsdraht. Das Kabel vom Netzteil zur Ladestation hatte einen Kabelbruch, so dass die Ladestation mal Strom hatte und mal nicht. :-(
              @Schmaviator:
              Wollte wissen ob mir jemand sagen kann wie man den Robonect Adapter in Verbindung mit IoBroker und Alexa verknüpfen kann. `
              Da kann ich leider nicht helfen. Ich habe zwar eine Alexa, mein Mäher läuft aber rein über Timer.
              @darkiop:
              Aktuell werden die DPs next_date, next_time und next_unix nicht befüllt. Im JSON sind diese Werte auch nicht vorhanden.
              Ist der Fehler bekannt? `
              Das ist kein Fehler, sondern so gewollt. Robonect gibt die Werte nur aus, wenn gerade kein Timer läuft und er auf den nächsten Timer wartet. Mein Mäher ist für heute fertig und zeigt mir an, dass er morgen um 13:00 Uhr wieder anfangen wir zu mähen.
              Ein Frage in die Runde: Läuft der Adapter bei Euch so stabil, dass ich ihn in die offizielle ioBroker Adapter Liste aufnehmen lassen kann? Wie schon öfters erwähnt, habe ich absolut keine Probleme, aber ich habe auch sehr guten WLAN Empfang im Garten.
                Schmaviator
                Kann man da wirklich nix dran machen den "Status" als Schalter einzubinden?
                Eine Timerprogrammierung mit fest eingestellten Tagen macht keinen Sinn finde ich, da man nie weiss wie das Wetter so mitspielt.
                Man kann da bestimmt anhand der Wettervorhersage was programmieren, jedoch bin ich in dem Gebiet zu unerfahren was programmieren angeht.
                Sofern ich den Status ausgewählt habe, wäre es da nicht möglich dann im Broker auf das + zu tippen um den aktuell ausgewählten Status als Verknüpfung anzulegen?
                Mit einem Landroid Worx habe ich gelesen geht dies ohne Probleme.
                  darkiop
                  @braindead:
                  Das ist kein Fehler, sondern so gewollt. Robonect gibt die Werte nur aus, wenn gerade kein Timer läuft und er auf den nächsten Timer wartet. Mein Mäher ist für heute fertig und zeigt mir an, dass er morgen um 13:00 Uhr wieder anfangen wir zu mähen. `
                  Ok, dann werde ich mir das nochmal im Detail anschauen.
                  @braindead:
                  Ein Frage in die Runde: Läuft der Adapter bei Euch so stabil, dass ich ihn in die offizielle ioBroker Adapter Liste aufnehmen lassen kann? Wie schon öfters erwähnt, habe ich absolut keine Probleme, aber ich habe auch sehr guten WLAN Empfang im Garten. `
                  Bisher stabil, allerdings hatte ich heut Mittag ein paar Erros im Log, falls ich die wieder sehe schreibe ich sie hier.
                  Kann ich über den Adapter dem Roboter auch einen Einzelauftrag geben (Job)? Bisher noch nicht gesehen, wollte mir morgen mal deinen Code genauer anschauen.
                  @Schmaviator: Du kannst du den Status über robonect.0.status.mode setzen?
                    braindeadB Offline
                    braindead
                    @Schmaviator:
                    Eine Timerprogrammierung mit fest eingestellten Tagen macht keinen Sinn finde ich, da man nie weiss wie das Wetter so mitspielt. `
                    Ich habe genau einen Timer. Jeden Tag von 13-20 Uhr wird gemäht. Regnet es dann setze ich den Mode auf Home. Regnet es nicht mehr, dann wird der Mode auf Auto gesetzt. Mehr Logik brauche ich nicht.
                    @darkiop:
                    Kann ich über den Adapter dem Roboter auch einen Einzelauftrag geben (Job)? Bisher noch nicht gesehen, wollte mir morgen mal deinen Code genauer anschauen. `
                    Job ist noch nicht implementiert. Wenn Du das übernehmen kannst, dann wäre das eine super Sache. Ansonsten guck ich mir das auch nochmal an, auch wenn ich es nicht brauche. Siehe oben.
                      Schmaviator
                      Ja den Status JOB kann ich auswählen und der Robbi fährt daraufhin los. Nur über den Status JOB ist es auch möglich den RI40 aus seinem Parkzustand aufzuwecken und daraufhin loszufahren. AUTO geht ja nur bei programmierten Timer und bei MANUELL wartet er bis er manuell aus der Station genommen wird und seine Arbeit verrichtet bis der Akku leer ist und das Teil stehen bleibt.
                        braindeadB Offline
                        braindead
                        Ich habe mir die Doku der API gerade mal angesehen: https://forum.robonect.de/viewtopic.php … &hilit=job
                        Eigentlich fehlen nur die fünf Datenpunkte remotestart, after, start, end und duration. Die Implementierung könnte so aussehen, dass der User die fünf Datenpunke nach eigenen Wünschen setzt und anschließend den Mode auf Job stellt. Der Job wird an Robonect übertragen und die fünf Datenpunkte geleert. Entspricht das Euren Erwartungen?
                        Edit: Sowohl im Robonect WebUI, als auch in der Robonect App kann man die Duration nicht setzen. Ich würde es also erstmal analog dazu umsetzen.
                          darkiop
                          #66
                          @braindead:
                          Job ist noch nicht implementiert. Wenn Du das übernehmen kannst, dann wäre das eine super Sache. Ansonsten guck ich mir das auch nochmal an, auch wenn ich es nicht brauche. Siehe oben. `
                          Muss ich mir anschauen ob ich das hinbekommen würde, habe aktuell auch nur einen Timer: Mo,Di,Do,Fr 9-16 Uhr
                          Am WE gönne ich dem Rasen 2 Tage Pause vom Mähen und unter der Woche nochmal einen Tag am Mittwoch.
                            mameier1234
                            #67
                            Ich habe aktuell das Problem , das mit der Beta 5 der Roby wieder unmoviviert zu Piepen anfängt (hatten wir ja schonmal , wenn die Infos abgefragt wurden…)
                            Dann wäre für mich noch ein Feature cool.... Die Duration des letzten Status wird ja momentan nur in Sekunden ausgegeben... Kann man das nicht gleich im Adapter in einen eigenen Datenpunkt als Zeitangabe übergeben ? Um das schön lesbar im VIS zu machen, muss man schon ein bisschen um die Ecke denken.. (ich kriegs auf jeden Fall nicht sauber hin ..)
                            Grüße,
                            Martin
                            • HALH Offline
                              HALH Offline
                              HAL
                              #68
                              Tatsächlich, mit setzen des Status "Job" fährt mein Mower los und mäht :-) . Im Status bei Robonect steht dann :
                              Ich erwarte, dass er mäht, bis das Akku leer ist und dann zur Ladestation zurück fährt und auf den nächsten Timer wartet. Mehr bräuchte ich nicht und direkt in der GUI von Robonect kann ich das nicht auslösen :-)
                              [edit] . Klappt leider doch nicht so ganz. Der Mower hat einige Minuten gemäht und ist dann wieder in die Ladestation zurückgefahren. Offensichtlich muss man bei Job doch noch mehr Parameter mitgeben.
                              [edit 2 ] es gibt doch die Möglichkeit einen Mähauftrag "Job" auch in der Robonect GUI auszuführen, hatte ich bisher übersehen.
                              Alle Raspberry ( 5 ) gegen NUC (N100, 16GB Ram und 500GB M2 SSD, extern 2TB SSD ) mit Proxmox 8.3.3 gewechselt. Läuft absolut super !
                              (Iobroker, Grafana, Teslalogger, Nextcloud, go2rtc, PiHole, IOB-VIS2, Teslamate, homeassistant nur als test)
                                Schmaviator
                                #69
                                Der Robbi fährt über den Status JOB für die vorher eingestellte Zeit los. Vorkonfiguriert ist eine Stunde.
                                Wie schon erwähnt geht es leider nicht den Status in die Iobroker Cloud einzubinden. Wenn man den Status versucht einzubinden erscheint die Meldung
                                "Wird nicht unterstützt".
                                • HALH Offline
                                  HALH Offline
                                  HAL
                                  #70
                                  Auch wenn ich es eigentlich nicht benötige, habe ich mal kurz meinen Mower per Alexa gesteuert.
                                  Allerdings benutze ich ausschließlich für die Alexasteuerung Note-Red und keine Cloud.
                                  Ein bisschen holprig aber es funktioniert:
                                  Befehle:
                                  0 = "Auto",
                                  1 = "Manuell",
                                  2 = "Home",
                                  98 = "End of day",
                                  99 = "Job"
                                  note-red:
                                  Alexa, setzte Rasen auf 99
                                  Mower fährt für eine Stunde mähen "Job"
                                  Alexa , setzte Rasen auf 98
                                  Mower macht Feierabend und fährt in die Ladestation
                                  VG Uwe
                                    Schmaviator
                                    #71
                                    @HAL:
                                    Ein bisschen holprig aber es funktioniert: `
                                    Könntest du mir sagen wie das mit Note-Red funktioniert ohne Cloud?
                                    • HALH Offline
                                      HALH Offline
                                      HAL
                                      #72
                                      Schau Dir bitte diesen Thread an, da steht alles drin:
                                      viewtopic.php?f=37&t=11302
                                        Schmaviator
                                        #73
                                        Hat sich erledigt. Der Hersteller der Robonect Module für den RI40 hat ein Alexa Skill gebastelt. Es funktioniert damit perfekt.
                                        https://www.amazon.de/Michael-Eckel-Rob … B072PXYSQ9
                                        Unterstützte Befehle:
                                        • "Alexa, starte Mähroboter" oder "Alexa, frage Mähroboter nach dem Status" fragt den aktuellen Status ab
                                        • "Alexa, sage Mähroboter dass er den Modus auf Auto/Manuell/Home/Feierabend setzen soll" setzt den Modus auf Auto/Manuell/Home/Feierabend
                                        • "Alexa, sage Mähroboter dass er Feierabend machen soll" setzt den Modus auf Feierabend
                                        • "Alexa, sage Mähroboter dass er mähen soll" setzt einen Mähauftrag und macht anschließend Feierabend
                                        • "Alexa, frage Mähroboter nach Hilfe" schickt eine Liste der Befehle auf die Alexa App
                                        Es funktioniert auch der Befehl : "Alexa, sage Mähroboter mähen."
                                        Viel Spass
                                          darkiop
                                          #74
                                          Hier ist noch das Log das ab und zu erscheint:
                                          robonect.0	2018-06-30 10:51:00.409	error	Error: read ECONNRESET
