  4. Iobroker Installation hängt bei creating conf/iobroker.json
    6.0k
23 Beiträge 3 Kommentatoren 4.2k Aufrufe
  • echoDaveE Offline
    echoDaveE Offline
    echoDave
    Die Ausgabe sieht so aus:
    [09:58:55] openhabian@openHABianPi:/opt/iobroker$ sudo rm /opt/iobroker/ -R
    [09:59:09] openhabian@openHABianPi:/opt/iobroker$ la -l
    total 0
    [09:59:12] openhabian@openHABianPi:/opt/iobroker$ ls -l                            total 0
    [10:00:21] openhabian@openHABianPi:/opt/iobroker$ sudo npm install iobroker.js-controller@stable --production --save
    path.js:1167
              cwd = process.cwd();
    Error: ENOENT: no such file or directory, uv_cwd
        at Object.resolve (path.js:1167:25)
        at Function.Module._resolveLookupPaths (module.js:424:17)
        at Function.Module._resolveFilename (module.js:541:20)
        at Function.Module._load (module.js:474:25)
        at Module.require (module.js:596:17)
        at require (internal/module.js:11:18)
        at /usr/local/lib/node_modules/npm/bin/npm-cli.js:19:21
        at Object. <anonymous>(/usr/local/lib/node_modules/npm/bin/npm-cli.js:92:3)
        at Module._compile (module.js:652:30)
        at Object.Module._extensions..js (module.js:663:10)
    [10:01:07] openhabian@openHABianPi:/opt/iobroker$</anonymous>
    • apollon77A Offline
      Ist das Verzeichnis echt noch da nach dem Befehl oben ?! hmmm ….
      Auch ls -la mit Total 0" kommt mir komisch vor. Stell mal sicher das /opt/iobroker wirklich noch da ist :-)
      Ansonsten versuch mal
      sudo npm install iobroker.js-controller --production --save
      • echoDaveE Offline
        echoDaveE Offline
        echoDave
        jop das dir war weg, ist mir dann auch aufgefallen.
        habe es angelegt und hier die neue Ausgabe:
        [10:13:17] openhabian@openHABianPi:/opt$ sudo mkdir iobroker
        [sudo] password for openhabian:
        [10:13:28] openhabian@openHABianPi:/opt$ ls
        afterfirstboot.lock  iobroker    openHABian-install-successful
        FireMotD             openhabian  vc
        [10:13:30] openhabian@openHABianPi:/opt$ cd iobroker/
        [10:13:35] openhabian@openHABianPi:/opt/iobroker$ sudo npm cache clean -f
        npm WARN using --force I sure hope you know what you are doing.
        [10:13:51] openhabian@openHABianPi:/opt/iobroker$ sudo npm install iobroker.js-controller@stable --production --save
        npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
        > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
        > node-gyp rebuild
        gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.10.0"
        gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/unix-dgram/.node-gyp"
        make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
          COPY Release/unix_dgram.node
        make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
        > ursa@0.9.4 install /opt/iobroker/node_modules/ursa
        > node-gyp rebuild
        gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/ursa/.node-gyp"
        make: Entering directory '/opt/iobroker/node_modules/ursa/build'
          CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
          SOLINK_MODULE(target) Release/obj.target/ursaNative.node
          COPY Release/ursaNative.node
        make: Leaving directory '/opt/iobroker/node_modules/ursa/build'
        > iobroker.js-controller@1.2.3 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
        fs.js:885
          return binding.mkdir(pathModule._makeLong(path),
        Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../iobroker-data/'
            at Object.fs.mkdirSync (fs.js:885:18)
            at mkpathSync (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:23:24)
            at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:154:13)
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:630:27
            at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:662:15)
            at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3105:5)
            at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
            at Module.load (module.js:565:32)
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
        npm WARN iobroker No description
        npm WARN iobroker No repository field.
        npm WARN iobroker No README data
        npm WARN iobroker No license field.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! iobroker.js-controller@1.2.3 install: `node iobroker.js setup first`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the iobroker.js-controller@1.2.3 install script.
        npm ERR!     /root/.npm/_logs/2018-03-20T09_16_20_813Z-debug.log
        [10:16:21] openhabian@openHABianPi:/opt/iobroker$ ls -l
        total 12
        drwxr-xr-x 3 root root 12288 Mar 20 10:16 node_modules</anonymous>
          Hm … permission denied.mach mal ein
          chmod 777 /opt/iobroker
          und vorher wieder leer machen
          dann?
          • echoDaveE Offline
            echoDaveE Offline
            echoDave
            dann hängt er wieder beim creating.
            der opt ordner gehört openhab:openhabian, hängt das vllt damit zusammen?
            [11:05:31] openhabian@openHABianPi:/opt$ sudo rm iobroker/ -dR
            [11:05:54] openhabian@openHABianPi:/opt$ ls
            afterfirstboot.lock  FireMotD  openhabian  openHABian-install-successful  vc
            [11:05:56] openhabian@openHABianPi:/opt$ sudo mkdir iobroker
            [11:06:05] openhabian@openHABianPi:/opt$ sudo chmod 777 /opt/iobroker
            [11:06:20] openhabian@openHABianPi:/opt$ ls -l
            total 20
            -rw-rw-r-- 1 openhab openhabian   91 Dec 20 22:16 afterfirstboot.lock
            drwxrwxr-x 5 openhab openhabian 4096 Dec 20 22:10 FireMotD
            drwxrwxrwx 2 root    root       4096 Mar 20 11:06 iobroker
            drwxrwxr-x 8 openhab openhabian 4096 Feb  7 08:24 openhabian
            -rw-rw-r-- 1 openhab openhabian    0 Dec 20 22:16 openHABian-install-successful
            drwxrwxr-x 7 openhab openhabian 4096 Apr 10  2017 vc
            [11:06:32] openhabian@openHABianPi:/opt$ cd iobroker/
            [11:06:40] openhabian@openHABianPi:/opt/iobroker$ sudo npm install iobroker.js-controller --production --save
            npm WARN lifecycle iobroker.js-controller@1.3.0~preinstall: cannot run in wd %s %s (wd=%s) iobroker.js-controller@1.3.0 node lib/preinstall_check.js /opt/iobroker/node_modules/.staging/iobroker.js-controller-a76002ca
            > node-gyp rebuild
            > node-gyp rebuild
            > iobroker.js-controller@1.3.0 install /opt/iobroker/node_modules/iobroker.js-controller
            • echoDaveE Offline
              echoDaveE Offline
              echoDave
              Ich habe es jetzt unter meinem Ubuntuserver zum laufen gebracht, kommt wohl mit irgendwas auf dem Raspi nicht zurecht.
                Allodo
                Hänge mich hier mal dran, da ich dasselbe Problem habe. Bekomme iobroker partout nicht auf meinem RPi2 (Stretch) installiert.
                Stretch Image installiert, danach piVCCU, (OH2 war installiert, jedoch wieder gelöscht), FHEM läuft.
                Habe nodejs in mehreren Versionen installiert, jedes Mal ohne Erfolg :(
                  Es scheint wohl ein Rechtsproblem zu sein.
                    Allodo
                    Ich habe vorher chmod 777 /opt/iobroker gemacht, von daher sollten die Rechte doch korrekt vergeben worden sein, oder nicht?
                    Ggf. wie kann ich das überprüfen? Bin kein Linuxcrack ;)
                      EIne Frage von mir:
                      Wenn das dort "hängt" und Du checks im ioBroker-verzeichnis:
                      • existing das Verzeichnis iobroker-data?
                      • existiert das angegebene File dort?
                        Allodo
                        Also habe gerade nachgeschaut, das Verzeichnis iobroker-data existiert und darin enthalten ist ein File iobroker.json (3KB)
                        Ich musste den Prozess mit Strg + C abbrechen, weil sich gar nichts mehr tat, auf der Console.
                        ` > pi@raspberrypi:/opt/iobroker $ iobroker start
                        Starting iobroker controller daemon…
                        iobroker controller daemon started. PID: 7870
                        pi@raspberrypi:/opt/iobroker $ iobroker status
                        iobroker is not running `
                        ` > pi@raspberrypi:/opt/iobroker $ sudo chmod 777 /opt/iobroker
                        pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker.js-controller –production --save
                        npm WARN lifecycle iobroker.js-controller@1.4.2~preinstall: cannot run in wd %s %s (wd=%s) iobroker.js-controller@1.4.2 node lib/preinstall_check.js /opt/iobroker/node_modules/.staging/iobroker.js-controller-a76002ca
                        iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
                        iobroker.inst@1.1.2 /opt/iobroker
                        └── iobroker.js-controller@1.4.2
                        Starting iobroker controller daemon...
                        /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                        throw new Error(msg.error);
                        Error: Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/'
                        at Error (native)
                        at Object.fs.mkdirSync (fs.js:932:18)
                        at new StatesInMemory (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:109:16)
                        at createStates (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:186:12)
                        at init (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2543:14)
                        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2624:1)
                        at Module._compile (module.js:577:32)
                        at Object.Module._extensions..js (module.js:586:10)
                        at Module.load (module.js:494:32)
                        at tryModuleLoad (module.js:453:12)
                        at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
                        at emitTwo (events.js:106:13)
                        at ChildProcess.emit (events.js:191:7)
                        at process.nextTick (internal/child_process.js:787:12)
                        at _combinedTickCallback (internal/process/next_tick.js:73:7)
                        at process._tickCallback (internal/process/next_tick.js:104:9)
                        pi@raspberrypi:/opt/iobroker $ ls -l
                        total 32
                        drwxr-xr-x 2 root root 4096 Jun 12 21:53 iobroker-data
                        -rw-r--r-- 1 root root 91 Jun 12 21:53 killall.sh
                        drwxr-xr-x 2 root root 4096 Jun 12 21:53 log
                        drwxr-xr-x 334 root root 12288 Jun 13 21:35 node_modules
                        -rw-r--r-- 1 root root 254 Jun 13 21:35 package.json
                        -rw-r--r-- 1 root root 655 Jun 12 21:53 reinstall.sh</anonymous></anonymous> `
                          Ok, dann hangeln wir uns weiter durch.
                          Existiert das "logs" Verzeichnis im ioBroker-Verzeichnis?
                          Ansonsten bitte mal prüfen ob auf Port 9000 oder 9001 irgendetwas läuft ohne das iobroker läuft.
                          Auch bitte mal den Inhalt der iobroker-conf file schicken.
                            Und wenn bitte:
                            sudo chmod -R 777 /opt/iobroker
                              Allodo
                              @apollon77
                              Ja, das logs-Verzeichnis existiert ebenfalls. Leider bin ich gerade bei der Arbeit und kann die Sachen nur per Handy probieren.
                              Habe mal mit 'netstart -tnl | grep ":9001"' geschaut, ob etwas auf dem Port läuft, die Ausgabe lautet wie folgt:
                              tcp 0 0 0.0.0.0:9001 0.0.0.0.* LISTEN
                              Allerdings habe ich endlich einen LOG-File und darin folgende Errors:
                              error: Another instance is running or same application uses port!
                              error: uncaught exception: listen EADDRINUSE 127.0.0.1:9001
                              error: host.raspberrypi_design/system missing - call node iobroker.js setup
                                Dann ist das dein Problem!! Port 9000 und 9001 werden gebraucht.
                                Finde raus was genau da läuft und mach es weg ;-)
                                Ich denke es ist etwas anderes, ioBroker connected dahin und hängt dann weil er nicht seine Antwort bekommt oder so.
                                Und denke das das der Grund ist
                                  Allodo
                                  Habe jetzt mal die Ports auf 9002 und 9003 geändert und iobroker status ergibt iobroker is running.
                                  Soweit so gut, aber ich komme immer noch nicht auf das WebInterface :(
                                  Dieser Fehler taucht immer noch im Logfile auf:
                                    Naja jetzt löscher alles und installiere neu.Der Setup-Prozess ist mittendrin hängen geblieben und du hast abgebrochen. Damit "kaputt".
                                    Mach das was da steht: iobroker setup aufrufen oder löschen und neu
                                      Allodo
                                      Ich habe jetzt herausgefunden, wer den Port 9001 blockiert. Es ist node selbst.
                                      Zumindest zeigt mir netstat -nlp folgendes an:
                                      tcp 0  0.0.0.0:9001 0.0.0.0.* LISTEN 297/Node
                                      Wenn ich jetzt alles neu installiere, müsste doch eigentlich dasselbe Problem wieder auftreten, da Standardmäßig ja Port 9000 und Port 9001 frei sein müssen. Dies habe ich ja gerade in der iobroker.json umgebogen auf 9002 und 9003. Jedoch alles gelöscht, somit auch das umbiegen.
                                        Hm dann hättet vllt einspringen gehabt den Server auf Port 9000 zu starten?
                                        Es ist ja ok weil ioBroker die Ports selbst öffnet. Aber er müsste beide machen. Wenn nur 9001 da war dann ist die Frage: warum fehlt 9000?
