  4. Iobroker Installation hängt bei creating conf/iobroker.json
    6.0k
23 Beiträge 3 Kommentatoren 4.2k Aufrufe
  • apollon77A Offline
    Hm … permission denied.mach mal ein
    chmod 777 /opt/iobroker
    und vorher wieder leer machen
    dann?
    • echoDaveE Offline
      echoDaveE Offline
      echoDave
      dann hängt er wieder beim creating.
      der opt ordner gehört openhab:openhabian, hängt das vllt damit zusammen?
      [11:05:31] openhabian@openHABianPi:/opt$ sudo rm iobroker/ -dR
      [sudo] password for openhabian:
      [11:05:54] openhabian@openHABianPi:/opt$ ls
      afterfirstboot.lock  FireMotD  openhabian  openHABian-install-successful  vc
      [11:05:56] openhabian@openHABianPi:/opt$ sudo mkdir iobroker
      [11:06:05] openhabian@openHABianPi:/opt$ sudo chmod 777 /opt/iobroker
      [11:06:20] openhabian@openHABianPi:/opt$ ls -l
      total 20
      -rw-rw-r-- 1 openhab openhabian   91 Dec 20 22:16 afterfirstboot.lock
      drwxrwxr-x 5 openhab openhabian 4096 Dec 20 22:10 FireMotD
      drwxrwxrwx 2 root    root       4096 Mar 20 11:06 iobroker
      drwxrwxr-x 8 openhab openhabian 4096 Feb  7 08:24 openhabian
      -rw-rw-r-- 1 openhab openhabian    0 Dec 20 22:16 openHABian-install-successful
      drwxrwxr-x 7 openhab openhabian 4096 Apr 10  2017 vc
      [11:06:32] openhabian@openHABianPi:/opt$ cd iobroker/
      [11:06:40] openhabian@openHABianPi:/opt/iobroker$ sudo npm install iobroker.js-controller --production --save
      npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
      npm WARN lifecycle iobroker.js-controller@1.3.0~preinstall: cannot run in wd %s %s (wd=%s) iobroker.js-controller@1.3.0 node lib/preinstall_check.js /opt/iobroker/node_modules/.staging/iobroker.js-controller-a76002ca
      > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
      > node-gyp rebuild
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.10.0"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/unix-dgram/.node-gyp"
      make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
        COPY Release/unix_dgram.node
      make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
      > ursa@0.9.4 install /opt/iobroker/node_modules/ursa
      > node-gyp rebuild
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/ursa/.node-gyp"
      make: Entering directory '/opt/iobroker/node_modules/ursa/build'
        CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
        SOLINK_MODULE(target) Release/obj.target/ursaNative.node
        COPY Release/ursaNative.node
      make: Leaving directory '/opt/iobroker/node_modules/ursa/build'
      > iobroker.js-controller@1.3.0 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      • echoDaveE Offline
        echoDaveE Offline
        echoDave
        Ich habe es jetzt unter meinem Ubuntuserver zum laufen gebracht, kommt wohl mit irgendwas auf dem Raspi nicht zurecht.
          Allodo
          Hänge mich hier mal dran, da ich dasselbe Problem habe. Bekomme iobroker partout nicht auf meinem RPi2 (Stretch) installiert.
          Stretch Image installiert, danach piVCCU, (OH2 war installiert, jedoch wieder gelöscht), FHEM läuft.
          Habe nodejs in mehreren Versionen installiert, jedes Mal ohne Erfolg :(
            Es scheint wohl ein Rechtsproblem zu sein.
              Allodo
              Ich habe vorher chmod 777 /opt/iobroker gemacht, von daher sollten die Rechte doch korrekt vergeben worden sein, oder nicht?
              Ggf. wie kann ich das überprüfen? Bin kein Linuxcrack ;)
                EIne Frage von mir:
                Wenn das dort "hängt" und Du checks im ioBroker-verzeichnis:
                • existing das Verzeichnis iobroker-data?
                • existiert das angegebene File dort?
                  Allodo
                  Also habe gerade nachgeschaut, das Verzeichnis iobroker-data existiert und darin enthalten ist ein File iobroker.json (3KB)
                  Ich musste den Prozess mit Strg + C abbrechen, weil sich gar nichts mehr tat, auf der Console.
                  ` > pi@raspberrypi:/opt/iobroker $ iobroker start
                  Starting iobroker controller daemon…
                  iobroker controller daemon started. PID: 7870
                  pi@raspberrypi:/opt/iobroker $ iobroker status
                  iobroker is not running `
                  ` > pi@raspberrypi:/opt/iobroker $ sudo chmod 777 /opt/iobroker
                  pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker.js-controller –production --save
                  npm WARN lifecycle iobroker.js-controller@1.4.2~preinstall: cannot run in wd %s %s (wd=%s) iobroker.js-controller@1.4.2 node lib/preinstall_check.js /opt/iobroker/node_modules/.staging/iobroker.js-controller-a76002ca
                  iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
                  Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
                  iobroker.inst@1.1.2 /opt/iobroker
                  └── iobroker.js-controller@1.4.2
                  Starting iobroker controller daemon...
                  /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                  throw new Error(msg.error);
                  Error: Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/'
                  at Error (native)
                  at Object.fs.mkdirSync (fs.js:932:18)
                  at new StatesInMemory (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:109:16)
                  at createStates (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:186:12)
                  at init (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2543:14)
                  at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2624:1)
                  at Module._compile (module.js:577:32)
                  at Object.Module._extensions..js (module.js:586:10)
                  at Module.load (module.js:494:32)
                  at tryModuleLoad (module.js:453:12)
                  at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
                  at emitTwo (events.js:106:13)
                  at ChildProcess.emit (events.js:191:7)
                  at process.nextTick (internal/child_process.js:787:12)
                  at _combinedTickCallback (internal/process/next_tick.js:73:7)
                  at process._tickCallback (internal/process/next_tick.js:104:9)
                  pi@raspberrypi:/opt/iobroker $ ls -l
                  total 32
                  drwxr-xr-x 2 root root 4096 Jun 12 21:53 iobroker-data
                  -rw-r--r-- 1 root root 91 Jun 12 21:53 killall.sh
                  drwxr-xr-x 2 root root 4096 Jun 12 21:53 log
                  drwxr-xr-x 334 root root 12288 Jun 13 21:35 node_modules
                  -rw-r--r-- 1 root root 254 Jun 13 21:35 package.json
                  -rw-r--r-- 1 root root 655 Jun 12 21:53 reinstall.sh</anonymous></anonymous> `
                    Ok, dann hangeln wir uns weiter durch.
                    Existiert das "logs" Verzeichnis im ioBroker-Verzeichnis?
                    Ansonsten bitte mal prüfen ob auf Port 9000 oder 9001 irgendetwas läuft ohne das iobroker läuft.
                    Auch bitte mal den Inhalt der iobroker-conf file schicken.
                      Und wenn bitte:
                      sudo chmod -R 777 /opt/iobroker
                        Allodo
                        @apollon77
                        Ja, das logs-Verzeichnis existiert ebenfalls. Leider bin ich gerade bei der Arbeit und kann die Sachen nur per Handy probieren.
                        Habe mal mit 'netstart -tnl | grep ":9001"' geschaut, ob etwas auf dem Port läuft, die Ausgabe lautet wie folgt:
                        tcp 0 0 0.0.0.0:9001 0.0.0.0.* LISTEN
                        Allerdings habe ich endlich einen LOG-File und darin folgende Errors:
                        error: Another instance is running or same application uses port!
                        error: uncaught exception: listen EADDRINUSE 127.0.0.1:9001
                        error: host.raspberrypi_design/system missing - call node iobroker.js setup
                          Dann ist das dein Problem!! Port 9000 und 9001 werden gebraucht.
                          Finde raus was genau da läuft und mach es weg ;-)
                          Ich denke es ist etwas anderes, ioBroker connected dahin und hängt dann weil er nicht seine Antwort bekommt oder so.
                          Und denke das das der Grund ist
                            Allodo
                            Habe jetzt mal die Ports auf 9002 und 9003 geändert und iobroker status ergibt iobroker is running.
                            Soweit so gut, aber ich komme immer noch nicht auf das WebInterface :(
                            Dieser Fehler taucht immer noch im Logfile auf:
                              Naja jetzt löscher alles und installiere neu.Der Setup-Prozess ist mittendrin hängen geblieben und du hast abgebrochen. Damit "kaputt".
                              Mach das was da steht: iobroker setup aufrufen oder löschen und neu
                                Allodo
                                Ich habe jetzt herausgefunden, wer den Port 9001 blockiert. Es ist node selbst.
                                Zumindest zeigt mir netstat -nlp folgendes an:
                                tcp 0  0.0.0.0:9001 0.0.0.0.* LISTEN 297/Node
                                Wenn ich jetzt alles neu installiere, müsste doch eigentlich dasselbe Problem wieder auftreten, da Standardmäßig ja Port 9000 und Port 9001 frei sein müssen. Dies habe ich ja gerade in der iobroker.json umgebogen auf 9002 und 9003. Jedoch alles gelöscht, somit auch das umbiegen.
                                  Hm dann hättet vllt einspringen gehabt den Server auf Port 9000 zu starten?
                                  Es ist ja ok weil ioBroker die Ports selbst öffnet. Aber er müsste beide machen. Wenn nur 9001 da war dann ist die Frage: warum fehlt 9000?
