  4. Iobroker Installation hängt bei creating conf/iobroker.json
    6.1k
23 Beiträge 3 Kommentatoren 4.2k Aufrufe
  • apollon77A Offline
    EIne Frage von mir:
    Wenn das dort "hängt" und Du checks im ioBroker-verzeichnis:
    • existing das Verzeichnis iobroker-data?
    • existiert das angegebene File dort?
      Allodo
      Also habe gerade nachgeschaut, das Verzeichnis iobroker-data existiert und darin enthalten ist ein File iobroker.json (3KB)
      Ich musste den Prozess mit Strg + C abbrechen, weil sich gar nichts mehr tat, auf der Console.
      ` > pi@raspberrypi:/opt/iobroker $ iobroker start
      Starting iobroker controller daemon…
      iobroker controller daemon started. PID: 7870
      pi@raspberrypi:/opt/iobroker $ iobroker status
      iobroker is not running `
      ` > pi@raspberrypi:/opt/iobroker $ sudo chmod 777 /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker.js-controller –production --save
      npm WARN lifecycle iobroker.js-controller@1.4.2~preinstall: cannot run in wd %s %s (wd=%s) iobroker.js-controller@1.4.2 node lib/preinstall_check.js /opt/iobroker/node_modules/.staging/iobroker.js-controller-a76002ca
      iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
      node iobroker.js setup first
      Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
      iobroker.inst@1.1.2 /opt/iobroker
      └── iobroker.js-controller@1.4.2
      Starting iobroker controller daemon...
      /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
      throw new Error(msg.error);
      Error: Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/'
      at Error (native)
      at Object.fs.mkdirSync (fs.js:932:18)
      at new StatesInMemory (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:109:16)
      at createStates (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:186:12)
      at init (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2543:14)
      at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2624:1)
      at Module._compile (module.js:577:32)
      at Object.Module._extensions..js (module.js:586:10)
      at Module.load (module.js:494:32)
      at tryModuleLoad (module.js:453:12)
      at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
      at emitTwo (events.js:106:13)
      at ChildProcess.emit (events.js:191:7)
      at process.nextTick (internal/child_process.js:787:12)
      at _combinedTickCallback (internal/process/next_tick.js:73:7)
      at process._tickCallback (internal/process/next_tick.js:104:9)
      pi@raspberrypi:/opt/iobroker $ ls -l
      total 32
      drwxr-xr-x 2 root root 4096 Jun 12 21:53 iobroker-data
      -rw-r--r-- 1 root root 91 Jun 12 21:53 killall.sh
      drwxr-xr-x 2 root root 4096 Jun 12 21:53 log
      drwxr-xr-x 334 root root 12288 Jun 13 21:35 node_modules
      -rw-r--r-- 1 root root 254 Jun 13 21:35 package.json
      -rw-r--r-- 1 root root 655 Jun 12 21:53 reinstall.sh</anonymous></anonymous> `
        Ok, dann hangeln wir uns weiter durch.
        Existiert das "logs" Verzeichnis im ioBroker-Verzeichnis?
        Ansonsten bitte mal prüfen ob auf Port 9000 oder 9001 irgendetwas läuft ohne das iobroker läuft.
        Auch bitte mal den Inhalt der iobroker-conf file schicken.
          Und wenn bitte:
          sudo chmod -R 777 /opt/iobroker
            Allodo
            @apollon77
            Ja, das logs-Verzeichnis existiert ebenfalls. Leider bin ich gerade bei der Arbeit und kann die Sachen nur per Handy probieren.
            Habe mal mit 'netstart -tnl | grep ":9001"' geschaut, ob etwas auf dem Port läuft, die Ausgabe lautet wie folgt:
            tcp 0 0 0.0.0.0:9001 0.0.0.0.* LISTEN
            Allerdings habe ich endlich einen LOG-File und darin folgende Errors:
            error: Another instance is running or same application uses port!
            error: uncaught exception: listen EADDRINUSE 127.0.0.1:9001
            error: host.raspberrypi_design/system missing - call node iobroker.js setup
              Dann ist das dein Problem!! Port 9000 und 9001 werden gebraucht.
              Finde raus was genau da läuft und mach es weg ;-)
              Ich denke es ist etwas anderes, ioBroker connected dahin und hängt dann weil er nicht seine Antwort bekommt oder so.
              Und denke das das der Grund ist
                Allodo
                Habe jetzt mal die Ports auf 9002 und 9003 geändert und iobroker status ergibt iobroker is running.
                Soweit so gut, aber ich komme immer noch nicht auf das WebInterface :(
                Dieser Fehler taucht immer noch im Logfile auf:
                  Naja jetzt löscher alles und installiere neu.Der Setup-Prozess ist mittendrin hängen geblieben und du hast abgebrochen. Damit "kaputt".
                  Mach das was da steht: iobroker setup aufrufen oder löschen und neu
                    Allodo
                    Ich habe jetzt herausgefunden, wer den Port 9001 blockiert. Es ist node selbst.
                    Zumindest zeigt mir netstat -nlp folgendes an:
                    tcp 0  0.0.0.0:9001 0.0.0.0.* LISTEN 297/Node
                    Wenn ich jetzt alles neu installiere, müsste doch eigentlich dasselbe Problem wieder auftreten, da Standardmäßig ja Port 9000 und Port 9001 frei sein müssen. Dies habe ich ja gerade in der iobroker.json umgebogen auf 9002 und 9003. Jedoch alles gelöscht, somit auch das umbiegen.
                      Hm dann hättet vllt einspringen gehabt den Server auf Port 9000 zu starten?
                      Es ist ja ok weil ioBroker die Ports selbst öffnet. Aber er müsste beide machen. Wenn nur 9001 da war dann ist die Frage: warum fehlt 9000?
