  4. Yet another HomeKit adapter
1.8k Beiträge 206 Kommentatoren 1.1m Aufrufe 68 Beobachtet
  • R Offline
    rh1212
    #609
    @Hohenbostler:
    Hallo zusmmen,
    ich bekomme den Adapter leider nicht installiert.
    kann mir jemand genau sagen wo das Problem ist ?
    $ ./iobroker add yahka
    NPM version: 3.10.10
    npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
     #include <dns_sd.h>^
    compilation terminated.
    make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
    gyp
     ERR! build error
    gyp
     ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack     at emitTwo (events.js:106:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.9.59-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/mdns
    gyp ERR! node -v v6.13.0
    gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok
    npm
     WARN
     optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
    npm
    WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm
    ERR! Linux 4.9.59-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.yahka" "--production" "--save" "--prefix" "/opt/iobroker"
    npm ERR! node v6.13.0
    npm ERR! npm  v3.10.10
    npm ERR! code ELIFECYCLE
    npm ERR! mdns@2.3.4 install: `node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR! npm ERR! Failed at the mdns@2.3.4 install script 'node-gyp rebuild'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the mdns package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node-gyp rebuild
    npm ERR!
     You can get information on how to open an issue for this project with:npm ERR!     npm bugs mdns
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls mdns
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:npm ERR!
         /npm-debug.lognpm ERR! code 1
    host.raspberrypi install adapter yahka
    NPM version: 3.10.10npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    gyp
     ERR! build error
    gyp
    gyp
    ERR! stack     at emitTwo (events.js:106:13)gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    gyp
    gyp ERR! cwd /opt/iobroker/node_modules/mdnsgyp ERR! node -v v6.13.0
    gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents):
    npm ERR! Linux 4.9.59-v7+
    npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.yahka" "--production" "--save" "--prefix" "/opt/iobroker"npm ERR! node v6.13.0
    npm ERR!
    npm ERR!
    npm ERR!
    gyp
     ERR! build error gyp
    gyp
    gyp ERR! not ok
    npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm
    npm ERR! node v6.13.0npm ERR! npm  v3.10.10
    npm ERR!
     mdns@2.3.4 install: `node-gyp rebuild`npm ERR! Exit status 1
    npm ERR!
    npm ERR!
    npm
    ERROR: host.raspberrypi Cannot install yahka
    ERROR: process exited with code 13</dns_sd.h></dns_sd.h></dns_sd.h>
    Hast du ]das gemacht?
    "Wichtig vor der Installation müssen einige Pakete installiert werden: sudo apt-get install libavahi-compat-libdnssd-dev"
    Lese Seite 30 da hatte ich auch Probleme hab alles was die anderen vorgeschlagen gemacht. Glaube apt-get update hat mein Problem gelöst
    • H Offline
      Hohenbostler
      #610
      Sorry auch alles andere ohne erfolg . hier nochmal ein versuch
      Using username "root".
      root@192.168.178.55's password:
      Access denied
      Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l
      ! The programs included with the Debian GNU/Linux system are free software;
      ! Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sun Mar 25 19:19:28 2018 from 192.168.178.31
      root@raspberrypi:~# cd /opt/iobroker
      root@raspberrypi:/opt/iobroker# npm cache clean
      root@raspberrypi:/opt/iobroker# sudo npm install --unsafe-perm mdns
      ! > mdns@2.3.4 install /opt/iobroker/node_modules/mdns
      node-gyp rebuild
      ! make: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird betreten
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
      ../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefun den
      dns_sd_bindings.target.mk:149: die Regel für Ziel „Release/obj.target/dns_sd_bin dings/src/dns_sd.o“ scheiterte
      make: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module s/node-gyp/lib/build.js:276:23)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_proces s.js:219:12)
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy p/bin/node-gyp.js" "rebuild"
      gyp ERR! node -v v6.13.1
      gyp ERR! not ok
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/ch okidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@ 1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"} )
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/io broker.js2fs/node_modules/chokidar/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modu les/noble/node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-conne ction@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch": "arm"})
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "--unsafe-perm" "mdns"
      npm ERR! node v6.13.1
      ! npm ERR! mdns@2.3.4 install: node-gyp rebuild
      npm ERR!
      npm ERR! You can get information on how to open an issue for this project with:
      ! npm ERR! Please include the following file with any support request:
      npm ERR! /opt/iobroker/npm-debug.log
      root@raspberrypi:/opt/iobroker# ^C
      root@raspberrypi:/opt/iobroker#</dns_sd.h>
      • W Offline
        W Offline
        Wunk
        #611
        Hallo Leute!
        Bei mir läuft der Yahka-Adapter zeitweise ganz gut, aber immer wieder mal sind einige Geräte plötzlich "weg". Ich hatte schon dass gar kein Gerät (außer yahka.0 selbst) mehr im Homekit angezeigt wird, in letzter Zeit fehlte meistens ein gutes Drittel.
        Starte ich den Adapter neu, tauchen die Geräte in Homekit zwar wieder auf, aber haben natürlich ihre Raumzuordnungen verloren und müssen neu sortiert werden. :(
        Kennt irgendjemand das Problem und/oder hat ne Idee was man tun könnte?
        Ich habe das Forum schon durchstöbert und Beiträge mit vertraut klingenden Problembeschreibungen gefunden, aber leider nichts in Richtung Lösung. Mit einem "das hat außer euch keiner" ist mir leider nicht geholfen :lol:
        ! @thoduh:
        ! > In dem Link geht es aber um homebridge, ich habe aber Probleme mit yahka.
        Oder hab ich was falsch verstanden?
        PS: Habe macOS 10.13
        Das Logfile von iobroker:
        `Caught	2017-10-05 21:50:22.474	error	by controller[26]: :"CurrentRelativeHumidity","enabled":true,"inOutFunction":"ioBroker.State","inOutParameters":"hm-rpc.0.LEQ1213764.2.ACTUAL_HUMIDITY"}]}]},{"manufacturer":"Homematic","model":"HM-Se
        Caught	2017-10-05 21:50:22.474	error	by controller[25]: roker.State","inOutParameters":"hm-rpc.0.LEQ1214207.2.ACTUAL_HUMIDITY"}]}]},{"manufacturer":"Homematic","model":"HM-TC-IT-WM-W-EU","name":"Temperatur Wohnzimmer","serial":"KEQ01144
        Caught	2017-10-05 21:50:22.474	error	by controller[24]: Thu, 05 Oct 2017 19:50:22 GMT engine.io-client:socket socket receive: type "message", data "2["message","system.adapter.*","system.adapter.yahka.0",{"_id":"system.adapter.yahka.0",
        Caught	2017-10-05 21:50:22.474	error	by controller[23]: Thu, 05 Oct 2017 19:50:18 GMT socket.io-client:socket emitting event ["message","hm-rpc.0.KEQ1074517.1.STATE","hm-rpc.0.KEQ1074517.1.STATE",{"val":false,"ack":true,"ts":15072330189
        Caught	2017-10-05 21:50:22.474	error	by controller[22]: Thu, 05 Oct 2017 19:50:18 GMT socket.io-parser decoded 2["message","hm-rpc.0.KEQ1074517.1.STATE","hm-rpc.0.KEQ1074517.1.STATE",{"val":false,"ack":true,"ts":1507233018942,"q":0,"fro
        Caught	2017-10-05 21:50:22.474	error	by controller[21]: Thu, 05 Oct 2017 19:50:18 GMT engine.io-client:socket socket receive: type "message", data "2["message","hm-rpc.0.KEQ1074517.1.STATE","hm-rpc.0.KEQ1074517.1.STATE",{"val":false,"ac
        Caught	2017-10-05 21:50:22.474	error	by controller[20]: Thu, 05 Oct 2017 19:50:17 GMT engine.io-client:socket flushing 7 packets in socket
        Caught	2017-10-05 21:50:22.474	error	by controller[19]: Thu, 05 Oct 2017 19:50:17 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"},null],
        Caught	2017-10-05 21:50:22.474	error	by controller[19]: Thu, 05 Oct 2017 19:50:17 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"
        Caught	2017-10-05 21:50:22.474	error	by controller[19]: Thu, 05 Oct 2017 19:50:17 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.y
        Caught	2017-10-05 21:50:22.474	error	by controller[18]: Thu, 05 Oct 2017 19:50:17 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"},null],"
        Caught	2017-10-05 21:50:22.474	error	by controller[18]: Thu, 05 Oct 2017 19:50:17 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"}
        Caught	2017-10-05 21:50:22.474	error	by controller[17]: Thu, 05 Oct 2017 19:50:17 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.ya
        Caught	2017-10-05 21:50:22.474	error	by controller[17]: Thu, 05 Oct 2017 19:50:17 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":301,"ack":true,"from":"system.adapter.yahka.0"},null],"op
        Caught	2017-10-05 21:50:22.474	error	by controller[17]: Thu, 05 Oct 2017 19:50:17 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":301,"ack":true,"from":"system.adapter.yahka.0"},n
        Caught	2017-10-05 21:50:22.473	error	by controller[17]: Thu, 05 Oct 2017 19:50:17 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":301,"ack":true,"from":"system.adapter.yahk[/code]`
        Zwischendurch funktioniert yahka dann mal wieder, allerdings sind alle Geräte (72 Stück) dem Standardraum zugeordnet. Sehr ärgerlich, da nicht zum ersten mal...
        Lässt sich Homebridge von: [https://github.com/nfarina/homebridge](https://github.com/nfarina/homebridge) und [https://github.com/thkl/homebridge-homematic](https://github.com/thkl/homebridge-homematic) nicht in ioBroker einbinden?
        Diese laufen wesentlich stabiler, es gibt regelmäßige Updates und auch Dimmer funktionieren Problemlos.
        • P Offline
          peer6969
          #612
          @rom.wagner80:
          @eumats:
          Hast du ihn nur ganz kurz (also 3%) fahren lassen? Lass ihn mal bitte länger fahre. Natürlich manuell und dann das Log posten. `
          Werd ich morgen mal machen… weiß nicht mehr ob’s 3% waren... könnte aber sein.
          Schönen Abend noch `
          Hat sich das Problem mit den KNX Rolladenaktoren gelöst? Plane etwas ähnliches umzusetzen und würde gern vorher sichergehen, dass es klappt ;)
          • R Offline
            rom.wagner80
            #613
            @peer6969:
            @rom.wagner80:
            @eumats:
            Hat sich das Problem mit den KNX Rolladenaktoren gelöst? Plane etwas ähnliches umzusetzen und würde gern vorher sichergehen, dass es klappt ;) `
            Nein, leider noch nicht. Hab das Script erstmal wieder deaktiviert. Werde, wenn die Zeit es zulässt nochmal daran herum probieren. Solange muss ich erstmal auf die Positionierung über Homekit verzichten und nutze die X1 Software von Gira.
            Schönen Gruß
            • W Offline
              W Offline
              worfinator
              #614
              Funktionieren bei euch eigentlich die Automationen von iOS? Bei mir haut das irgendwie nicht hin. Normal sollte immer eine Lampe angehen, wenn ich Heim komme. Tut sie aber leider nicht…
              • P Offline
                peer6969
                #615
                Ja. Die Automations funktionieren einwandfrei. Sowohl zeit- als auch ereignis- oder standortbasiert. Hast du einen Apple TV oder ein iPad als Hub für HomeKit eingerichtet das dauerhaft am Strom hängt? Sonst geht es nicht.
                • R Offline
                  rom.wagner80
                  #616
                  @worfinator:
                  Funktionieren bei euch eigentlich die Automationen von iOS? Bei mir haut das irgendwie nicht hin. Normal sollte immer eine Lampe angehen, wenn ich Heim komme. Tut sie aber leider nicht… `
                  Also die standortbasierten regeln funktionieren nicht wirklich zuverlässig. Bei meinem device schon aber das von meiner Frau wird nicht verarbeitet…
                  • P Offline
                    peer6969
                    #617
                    In den iCloud Settings unter „Share my location“ ist „this device“ ausgewählt und beim Location Sharing ist es auch nicht vielleicht überall deaktiviert? Bisher war es noch bei jedem im Bekanntenkreis so, dass sie die standortdienste an irgendeiner Stelle abgedreht haben und dann geschimpft haben, dass es nicht funktioniert…
                    • W Offline
                      W Offline
                      worfinator
                      #618
                      Ich schaue mir das grad an. Also "Dieses Gerät" ist bei meinem iPhone auf jeden Fall ausgewählt für die Freigabe des Standorts. So einfach wird es nicht werden. Aber wenn es bei dir geht peer6969 stimmt es mich optimistisch, dass ich es auch ans Laufen bekomme.
                      Vor Yahka hatte ich Homebridge verwendet. Damit ging es auf jeden Fall. Ich schau auf jeden Fall nochmal rum. Stand jetzt wird die Lampe nicht eingeschaltet, wenn ich "nach Hause" komme.
                      • U Offline
                        U Offline
                        useful_idiot
                        #619
                        ich hatte den yahka eine ganze Zeit problemlos am laufen, da ist auch nur ein Gerät drin. Seit gestern zeigte yahka als Status disconnected an und gab auch keine Lebenszeichen - auchkann ich yahka nicht mehr über das Webinterface starten, es kommt im Log nur der Code 1
                        host.raspberrypi	2018-05-22 22:07:38.700	info	Restart adapter system.adapter.yahka.0 because enabled
                        host.raspberrypi	2018-05-22 22:07:38.699	error	instance system.adapter.yahka.0 terminated with code 1 ()
                        host.raspberrypi	2018-05-22 22:07:37.892	info	instance system.adapter.yahka.0 started with pid 4533
                        host.raspberrypi	2018-05-22 22:07:07.873	info	Restart adapter system.adapter.yahka.0 because enabled
                        host.raspberrypi	2018-05-22 22:07:07.872	error	instance system.adapter.yahka.0 terminated with code 1 ()
                        host.raspberrypi	2018-05-22 22:07:07.066	info	instance system.adapter.yahka.0 started with pid 4521
                        host.raspberrypi	2018-05-22 22:06:37.047	info	Restart adapter system.adapter.yahka.0 because enabled
                        host.raspberrypi	2018-05-22 22:06:37.046	error	instance system.adapter.yahka.0 terminated with code 1 ()
                        host.raspberrypi	2018-05-22 22:06:36.228	info	instance system.adapter.yahka.0 started with pid 4253
                        host.raspberrypi	2018-05-22 22:06:06.216	info	Restart adapter system.adapter.yahka.0 because enabled
                        Ich verstehe nicht, wo ich noch weiter ansetzen kann, alle Voraussetzungen sind noch da, ein detaillierteres Log zu yahka finde ich nicht… die Ausgabe wiederholt sich endlos. Ich habe den Adapter schon einige Male neu installiert, auch /opt/iobroker/node_modules/iobroker.yahka gelöscht, die "yahka_meta" in den Objekten gelöscht, "sudo npm cache clean" bzw. "verify" ausgeführt und neu heruntergeladen... immer wieder lande ich bei diesem Status. Node Version ist 8.9.4
                        Wenn ich dagegen in /opt/iobroker/node_modules/iobroker.yahka wechsle und "node main.js --force --logs" ausführe, dann startet es und wird auch im Webinterface als Verbunden mit Lebenszeichen angezeigt, aber ich kann ja nicht immer die Konsole offen lassen... Da die Ausgabe dann relativ umfangreich ist, packe ich es mal in einen Spoiler
                        508 history | grep npm
                        root@raspberrypi:/home/pi# cd /opt/iobroker/node_modules/iobroker.yahka
                        root@raspberrypi:/opt/iobroker/node_modules/iobroker.yahka# node -v
                        v8.9.4
                        root@raspberrypi:/opt/iobroker/node_modules/iobroker.yahka# node main.js --force --logs
                        socket.io-client:url parse http://127.0.0.1:9001 +0ms
                        socket.io-client new io instance for http://127.0.0.1:9001 +8ms
                        socket.io-client:manager readyState closed +4ms
                        socket.io-client:manager opening http://127.0.0.1:9001 +0ms
                        engine.io-client:socket creating transport "polling" +0ms
                        engine.io-client:polling polling +4ms
                        engine.io-client:polling-xhr xhr poll +1ms
                        engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=ME9VrcL&b64=1 +6ms
                        engine.io-client:polling-xhr xhr data null +2ms
                        engine.io-client:socket setting transport polling +39ms
                        socket.io-client:manager connect attempt will timeout after 20000 +59ms
                        socket.io-client:manager readyState opening +10ms
                        engine.io-client:polling polling got data 97:0{"sid":"Gw5j89wIrizAfDAbAAAQ","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000} +123ms
                        engine.io-client:socket socket receive: type "open", data "{"sid":"Gw5j89wIrizAfDAbAAAQ","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000}" +4ms
                        engine.io-client:socket socket open +2ms
                        socket.io-client:manager open +118ms
                        socket.io-client:manager cleanup +1ms
                        socket.io-client:socket transport is open - connecting +2ms
                        engine.io-client:socket starting upgrade probes +5ms
                        engine.io-client:socket probing transport "websocket" +1ms
                        engine.io-client:socket creating transport "websocket" +1ms
                        engine.io-client:polling polling +18ms
                        engine.io-client:polling-xhr xhr poll +0ms
                        engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=ME9VrfT&b64=1&sid=Gw5j89wIrizAfDAbAAAQ +1ms
                        engine.io-client:polling-xhr xhr data null +1ms
                        engine.io-client:socket probe transport "websocket" opened +38ms
                        engine.io-client:polling polling got data 2:40 +16ms
                        engine.io-client:socket socket receive: type "message", data "0" +1ms
                        socket.io-client:url parse http://127.0.0.1:9000 +94ms
                        socket.io-client new io instance for http://127.0.0.1:9000 +1ms
                        socket.io-client:manager readyState closed +1ms
                        socket.io-client:manager opening http://127.0.0.1:9000 +0ms
                        engine.io-client:socket creating transport "polling" +19ms
                        engine.io-client:polling polling +1ms
                        engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=ME9Vrgg&b64=1 +1ms
                        engine.io-client:polling-xhr xhr data null +0ms
                        engine.io-client:socket setting transport polling +2ms
                        socket.io-client:manager connect attempt will timeout after 20000 +5ms
                        socket.io-client:manager readyState opening +1ms
                        engine.io-client:polling polling +3ms
                        engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=ME9Vrgm&b64=1&sid=Gw5j89wIrizAfDAbAAAQ +1ms
                        engine.io-client:socket probe transport "websocket" pong +11ms
                        engine.io-client:socket pausing current transport "polling" +1ms
                        engine.io-client:polling we are currently polling - waiting to pause +1ms
                        engine.io-client:polling polling got data 97:0{"sid":"1d25fAFFFb9XerGLAAAR","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000} +8ms
                        engine.io-client:socket socket receive: type "open", data "{"sid":"1d25fAFFFb9XerGLAAAR","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000}" +2ms
                        engine.io-client:socket socket open +0ms
                        socket.io-client:manager open +27ms
                        socket.io-client:manager cleanup +0ms
                        socket.io-client:socket transport is open - connecting +1ms
                        engine.io-client:socket starting upgrade probes +2ms
                        engine.io-client:socket creating transport "websocket" +0ms
                        engine.io-client:polling polling +5ms
                        engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=ME9VrhG&b64=1&sid=1d25fAFFFb9XerGLAAAR +1ms
                        engine.io-client:socket probe transport "websocket" opened +10ms
                        engine.io-client:polling polling got data 2:40 +6ms
                        socket.io-client:socket emitting packet with ack id 0 +29ms
                        socket.io-client:manager writing packet {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/"} +1ms
                        engine.io-client:socket flushing 1 packets in socket +8ms
                        engine.io-client:polling-xhr xhr open POST: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=ME9Vrhk&b64=1&sid=1d25fAFFFb9XerGLAAAR +4ms
                        engine.io-client:polling-xhr xhr data 46:420["getState","system.adapter.yahka.0.alive"] +1ms
                        engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=ME9Vrhp&b64=1&sid=1d25fAFFFb9XerGLAAAR +1ms
                        engine.io-client:socket probe transport "websocket" pong +5ms
                        engine.io-client:polling we are currently polling - waiting to pause +0ms
                        engine.io-client:polling we are currently writing - waiting to pause +0ms
                        engine.io-client:polling polling got data 1:6 +4ms
                        engine.io-client:socket socket receive: type "noop", data "undefined" +1ms
                        engine.io-client:polling pre-pause polling complete +2ms
                        engine.io-client:polling paused +0ms
                        engine.io-client:socket changing transport and sending upgrade packet +1ms
                        engine.io-client:socket setting transport websocket +1ms
                        engine.io-client:socket clearing existing transport polling +0ms
                        engine.io-client:polling ignoring poll - transport state "paused" +2ms
                        engine.io-client:polling pre-pause writing complete +9ms
                        engine.io-client:polling polling got data 111:430[null,{"val":false,"ack":true,"ts":1527020214245,"q":0,"from":"system.host.raspberrypi","lc":1527018357361}] +3ms
                        engine.io-client:socket socket receive: type "message", data "30[null,{"val":false,"ack":true,"ts":1527020214245,"q":0,"from":"system.host.raspberrypi","lc":1527018357361}]" +1ms
                        socket.io-client:socket calling ack 0 with [null,{"val":false,"ack":true,"ts":1527020214245,"q":0,"from":"system.host.raspberrypi","lc":1527018357361}] +44ms
                        socket.io-client:socket emitting packet with ack id 0 +2ms
                        socket.io-client:manager writing packet {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/"} +1ms
                        engine.io-client:socket flushing 1 packets in socket +5ms
                        engine.io-client:socket changing transport and sending upgrade packet +0ms
                        engine.io-client:polling ignoring poll - transport state "paused" +1ms
                        engine.io-client:socket socket receive: type "message", data "30[null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka","version":"0.7.1","news":{"0.7.1":{"en":"Fixed the ID select dialog in Admin 2.0.9. restructured repo to allow install via git-url","de":"Der ID-Auswahldialog in Admin 2.0.9 wurde korrigiert. Repository umstrukturiert um Installation via git-url zu ermöglichen"},"0.7.0":{"en":"Fixed the ID select dialog in Admin3, added new services and fixed some other bugs","de"(GEKÜRZT) Homekit"},"platform":"Javascript/Node.js","mode":"daemon","icon":"yahka.png","enabled":true,"extIcon":"https://raw.githubusercontent.com/jensweigele/ioBroker.yahka/master/admin/yahka.png","keywords":["homekit","siri"],"readme":"https://github.com/jensweigele/ioBroker.yahka/blob/master/README.md","loglevel":"info","type":"iot-systems","materialize":true,"config":{"minWidth":800,"width ":1440,"minHeight":600,"height ":860},"authors":[{"name":"Jens Weigele","email":"iobroker.yahka@gmail.com"}],"installedVersion":"0.7.1","host":"raspberrypi"},"native":{"firstTimeInitialized":false,"bridge":{"devices":[{"configType":"customdevice","manufacturer":"RFTEC","model":"PointClick","name":"Bett","serial":"2525A25","enabled":true,"category":"5","services":[{"name":"Bett","subType":"Bett","type":"Lightbulb","characteristics":[{"name":"On","enabled":true,"inOutFunction":"ioBroker.State","inOutParameters":"broadlink2.0.States.Bett"}]}]}],"configType":"bridge","name":"ioBroker","manufacturer":"Raspberry","model":"ioBroker","serial":":yahka.0","username":"1A:43:23:52:41:42","pincode":"534-23-242","port":"0"},"cameras":[]},"from":"system.adapter.admin.0","ts":1527019225616,"acl":{"object":1636}}]" +31ms
                        socket.io-client:socket calling ack 0 with [null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka","version":"0.7.1","news":{"0.7.1":{"en":"Fixed the ID select dialog in Admin 2.0.9. restructured repo to allow install via git-url","de":"Der ID-Auswahldialog in Admin 2.0.9 wurde korrigiert. Repository umstrukturiert um Installation via git-url zu ermöglichen"},"0(GEKÜRZT)es":"otro adaptador para el Homekit","pl":"kolejny adapter Homekit"},"platform":"Javascript/Node.js","mode":"daemon","icon":"yahka.png","enabled":true,"extIcon":"https://raw.githubusercontent.com/jensweigele/ioBroker.yahka/master/admin/yahka.png","keywords":["homekit","siri"],"readme":"https://github.com/jensweigele/ioBroker.yahka/blob/master/README.md","loglevel":"info","type":"iot-systems","materialize":true,"config":{"minWidth":800,"width ":1440,"minHeight":600,"height ":860},"authors":[{"name":"Jens Weigele","email":"iobroker.yahka@gmail.com"}],"installedVersion":"0.7.1","host":"raspberrypi"},"native":{"firstTimeInitialized":false,"bridge":{"devices":[{"configType":"customdevice","manufacturer":"RFTEC","model":"PointClick","name":"Bett","serial":"2525A25","enabled":true,"category":"5","services":[{"name":"Bett","subType":"Bett","type":"Lightbulb","characteristics":[{"name":"On","enabled":true,"inOutFunction":"ioBroker.State","inOutParameters":"broadlink2.0.States.Bett"}]}]}],"configType":"bridge","name":"ioBroker","manufacturer":"Raspberry","model":"ioBroker","serial":":yahka.0","username":"1A:43:23:52:41:42","pincode":"534-23-242","port":"0"},"cameras":[]},"from":"system.adapter.admin.0","ts":1527019225616,"acl":{"object":1636}}] +37ms
                        socket.io-client:socket emitting packet with ack id 1 +5ms
                        socket.io-client:manager writing packet {"type":2,"data":["getKeys",".logging"],"options":{"compress":true},"id":1,"nsp":"/"} +0ms
                        socket.io-client:manager writing packet {"type":2,"data":["subscribe","
                        .logging",null],"options":{"compress":true},"nsp":"/"} +4ms
                        starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v8.9.4
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":30,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +14ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":35.3,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":16.49,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":8.96,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +0ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":4,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +0ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +0ms
                        adapter ready, checking config
                        first time initialization
                        system config:{"system":{"memoryLimitMB":0,"hostname":""},"multihostService":{"enabled":false,"secure":true},"network":{"IPv4":true,"IPv6":true,"bindAddress":null,"useSystemNpm":true},"objects":{"type":"file","typeComment":"Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].","host":"127.0.0.1","port":9001,"user":"","pass":"","noFileCache":false,"connectTimeout":2000},"states":{"type":"file","typeComment":"Possible values: 'file' - [port 9000], 'redis' - [port 6379].","host":"127.0.0.1","port":9000,"maxQueue":1000,"options":{"auth_pass":null,"retry_max_delay":15000}},"log":{"level":"info","maxDays":7,"noStdout":true,"transport":{"file1":{"type":"file","enabled":true,"filename":"log/iobroker","fileext":".log","maxsize":null,"maxFiles":null},"syslog1":{"type":"syslog","enabled":false,"host":"localhost","host_comment":"The host running syslogd, defaults to localhost.","port_comment":"The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).","protocol":"udp4","protocol_comment":"The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).","path_comment":"The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).","facility_comment":"Syslog facility to use (Default: local0).","localhost":"iobroker","localhost_comment":"Host to indicate that log messages are coming from (Default: localhost).","sysLogType_comment":"The type of the syslog protocol to use (Default: BSD).","app_name_comment":"The name of the application (Default: process.title).","eol_comment":"The end of line character to be added to the end of the message (Default: Message without modifications)."}}},"dataDirComment":"Always relative to iobroker.js-controller/","dataDir":"../../iobroker-data/","forceIfDisabled":true,"consoleOutput":true}
                        socket.io-client:manager writing packet {"type":2,"data":["extendObject","system.adapter.yahka.0",{"native":{"firstTimeInitialized":true,"bridge":{"devices":[{"configType":"customdevice","manufacturer":"RFTEC","model":"PointClick","name":"Bett","serial":"2525A25","enabled":true,"category":"5","services":[{"name":"Bett","subType":"Bett","type":"Lightbulb","characteristics":[{"name":"On","enabled":true,"inOutFunction":"ioBroker.State","inOutParameters":"broadlink2.0.States.Bett"}]}]}],"configType":"bridge","name":":yahka.0","manufacturer":"Raspberry","model":"ioBroker","serial":":yahka.0","username":"b1:dc:1b:94:c1:12","pincode":"123-45-678","port":0,"ident":":yahka.0","verboseLogging":false},"cameras":[]},"from":"system.adapter.yahka.0","ts":1527020215149},null,null],"options":{"compress":true},"nsp":"/"} +23ms
                        engine.io-client:socket flushing 1 packets in socket +45ms
                        creating bridge
                        adding Bett with UUID: 6ec733ba-7739-4b70-b449-2a75d3bda8d8
                        socket.io-client:socket emitting packet with ack id 1 +38ms
                        socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"yahka","systemConfig":true}],"options":{"compress":true},"id":1,"nsp":"/"} +0ms
                        socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null],"options":{"compress":true},"nsp":"/"} +1ms
                        added subscription for: [state]broadlink2.0.States.Bett
                        socket.io-client:manager writing packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"} +54ms
                        engine.io-client:socket flushing 10 packets in socket +106ms
                        engine.io-client:socket flushing 2 packets in socket +9ms
                        engine.io-client:socket socket receive: type "message", data "31[null,["system.adapter.admin.0.logging"]]" +18ms
                        socket.io-client:socket calling ack 1 with [null,["system.adapter.admin.0.logging"]] +43ms
                        socket.io-client:socket emitting packet with ack id 2 +3ms
                        socket.io-client:manager writing packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":2,"nsp":"/"} +1ms
                        engine.io-client:socket socket receive: type "message", data "32[null,[{"val":true,"ack":true,"ts":1527018644708,"q":0,"from":"system.adapter.admin.0","lc":1527017803436}]]" +37ms
                        socket.io-client:socket calling ack 2 with [null,[{"val":true,"ack":true,"ts":1527018644708,"q":0,"from":"system.adapter.admin.0","lc":1527017803436}]] +40ms
                        socket.io-client:manager writing packet {"type":2,"data":["pushLog","system.adapter.admin.0",{"message":"yahka.0 starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v8.9.4","severity":"info","from":"yahka.0","ts":1527020215306},null],"options":{"compress":true},"nsp":"/"} +2ms
                        socket.io-client:manager writing packet {"type":2,"data":["pushLog","system.adapter.admin.0",{"message":"yahka.0 adapter ready, checking config","severity":"info","from":"yahka.0","ts":1527020215309},null],"options":{"compress":true},"nsp":"/"} +4ms
                        socket.io-client:manager writing packet {"type":2,"data":["pushLog","system.adapter.admin.0",{"message":"yahka.0 first time initialization","severity":"info","from":"yahka.0","ts":1527020215309},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["pushLog","system.adapter.admin.0",{"message":"yahka.0 adding Bett with UUID: 6ec733ba-7739-4b70-b449-2a75d3bda8d8","severity":"info","from":"yahka.0","ts":1527020215309},null],"options":{"compress":true},"nsp":"/"} +1ms
                        engine.io-client:socket flushing 3 packets in socket +7ms
                        engine.io-client:socket socket receive: type "message", data "31[null,{"rows":[{"id":"system.adapter.admin.0","value":{"_id":"system.adapter.admin.0","type":"instance","common":{"name":"admin","title":"ioBroker Admin","version":"2.0.9","news":{"2.0.9":{"en":"fix sorting, when using adapters with more than one instance","de":"Sortierung für Adapter mit mehr als einer Instanz repariert"},"2.0.8":{"en":"fix quickEdit: number with boolean value","de":"behoben: quickEdit, (GEKÜRZT)pens a webserver for the ioBroker admin UI","de":"Stellt Webserver für 'ioBroker Admin UI' zur Verfügung","ru":"Запускает веб сервер с 'ioBroker admin UI' для удобной настройки через веб интерфейс"},"docs":{"en":"docs/en/admin.md","ru":"docs/ru/admin.md","de":["docs/de/admin.md","docs/de/admin/tab-adapters.md","docs/de/admin/tab-instances.md","docs/de/admin/tab-objects.md","docs/de/admin/tab-states.md","docs/de/admin/tab-groups.md","docs/de/admin/tab-users.md","docs/de/admin/tab-events.md","docs/de/admin/tab-hosts.md","docs/de/admin/tab-enums.md","docs/de/admin/tab-log.md","docs/de/admin/tab-system.md"]},"mode":"daemon","platform":"Javascript/Node.js","loglevel":"info","icon":"admin.png","messagebox":true,"enabled":true,"extIcon":"https://raw.githubusercontent.com/ioBroker/ioBroker.admin/master/admin/admin.png","keywords":["setup","config","update","upgrade","system","konfiguration","administration","einrichtung","wartung"],"readme":"https://github.com/ioBroker/ioBroker.admin/blob/master/README.md","authors":["bluefox bluefox@ccu.io","hobbyquaker hq@ccu.io"],"dependencies":[{"js-controller":">=0.12.0"}],"type":"general","license":"MIT","logTransporter":true,"stopBeforeUpdate":true,"wwwDontUpload":true,"welcomeScreenPro":{"link":"admin/index.html","name":"Admin","img":"admin/img/gear.png","color":"pink","order":5,"localLink":true},"localLink":"%protocol%://%ip%:%port%","installedVersion":"2.0.9","host":"raspberrypi"},"native":{"port":8081,"auth":false,"secure":false,"bind":"0.0.0.0","cache":false,"certPublic":"","certPrivate":"","certChained":"","ttl":3600,"defaultUser":"admin","tmpPath":"/tmp","tmpPathAllow":false,"leEnabled":false,"leUpdate":false,"leCheckPort":80},"from":"system.host.raspberrypi.cli","ts":1526732851507,"acl":{"object":1636}}},{"id":"system.adapter.discovery.0","value":{"_id":"system.adapter.discovery.0","type":"instance","common":{"name":"discovery","version":"1.1.0","news":{"1.1.0":{"en":"Support of admin3","de":"Unterstützung von admin3","ru":"Поддержка admin3","pt":"Suporte de admin3","nl":"Ondersteuning van admin3","fr":"Support de admin3","it":"Supporto di admin3","es":"Soporte de admin3"},"1.0.1":{"en":"Fix Epson Stylus PX830\nAdd Bose Soundtouch","de":"Epson Stylus PX830 KORRIGIERT\nBose Soundtouch hinzugefügt","ru":"Fix Epson Stylus PX830\nAdd Bose Soundtouch"},"1.0.0":{"en":"Add Epson Stylus PX830, Loxone\nAdd Homepilot","de":"Epson Stylus PX830, Loxone und Homepilot sind hinzugefügt","ru":"Добавлены Epson Stylus PX830, Loxone и Homepilot"},"0.4.5":{"en":"Fixes in mihome","de":"Fixes in mihome","ru":"Fixes in mihome"},"0.4.4":{"en":"Add lgtv","de":"LGTV hinzugefügt","ru":"Добавлен lgtv"},"0.4.2":{"en":"Add discovery methods selection","de":"Methodenauswahl hinzugefügt","ru":"Добавлен выбор методов поиска"},"0.4.0":{"en":"add SamsungTV, Lightify, Miele and yamaha\nadd new discovery method mDNS","de":"SamsungTV, Lightify, Miele und yamaha sind hinzugefügt\nNeues Discovery Methode mDNS hinzugefügt","ru":"Добавлены SamsungTV, Lightify, Miele and yamaha\nДобавлен новый метод обнаружения - mDNS"},"0.3.3":{"en":"Add Philips HUE","de":"Philips HUE hinzugefügt","ru":"Добавлен Philips HUE"},"0.3.2":{"en":"Add discovery of USB mysensors","de":"Erkennung für den USB mysensors hinzugefügt","ru":"Добавлено обнаружение USB mysensors"},"0.3.1":{"en":"Add discovery of Daikin Adapter","de":"Erkennung für den Daikin-Adapter hinzugefügt","ru":"Add discovery of Daikin Adapter"},"0.3.0":{"en":"Fixed serial discovery","de":"Serialsuche korrigiert","ru":"исправлен поиск на последовательных портах"},"0.2.3":{"en":"added more adapters","de":"Wietere Adapters hinzugefügt","ru":"Добавлены дополнительные драйвера"},"0.2.2":{"en":"Fix typo","de":"Fix typo","ru":"Исправлена синтаксическая ошибка"},"0.2.1":{"en":"initial commit","de":"initial commit","ru":"initial commit"}},"title":"Discovery devices","titleLang":{"en":"Discovery devices","de":"Gerätesuche","ru":"Драйвер поиска устройств","pt":"Dispositivos de descoberta","nl":"Ontdekkingsapparaten","fr":"Dispositifs de découverte","it":"Dispositivi di scoperta","es":"Dispositivos de descubrimiento","pl":"Urządzenia Discovery"},"desc":{"en":"This adapter tries to discover all known devices in your network and on your machine","de":"Dieser Adapter versucht, alle bekannten Geräte in Ihrem Netzwerk und auf Ihrem Computer zu finden","ru":"Этот адаптер пытается обнаружить все известные устройства в вашей сети и на вашем компьютере","pt":"Este adaptador tenta descobrir todos os dispositivos conhecidos da sua rede e da sua máquina","nl":"Deze adapter probeert alle bekende apparaten in uw netwerk en op uw computer te ontdekken","fr":"Cet adaptateur essaie de découvrir tous les périphériques connus sur votre réseau et sur votre machine","it":"Questo adattatore tenta di rilevare tutti i dispositivi noti nella rete e sulla macchina","es":"Este adaptador intenta descubrir todos los dispositivos conocidos en su red y en su máquina","pl":"Ten adapter próbuje wykryć wszystkie znane urządzenia w sieci i na twoim komputerze"},"authors":["bluefox dogafox@gmail.com"],"license":"MIT","platform":"Javascript/Node.js","mode":"daemon","enabled":true,"singletonHost":true,"materialize":true,"messagebox":true,"readme":"https://github.com/ioBroker/ioBroker.discovery/blob/master/README.md","dependencies":[{"js-controller":">=1.2.0"}],"loglevel":"info","icon":"discovery.png","keywords":["poll","discovery","ip"],"extIcon":"https://raw.githubusercontent.com/ioBroker/ioBroker.discovery/master/admin/discovery.png","type":"general","config":{"width":1224,"height":700},"installedVersion":"1.1.0","host":"raspberrypi"},"native":{"pingTimeout":1000,"pingBlock":20},"from":"system.host.raspberrypi.cli","ts":1526732894714,"acl":{"object":1636}}},{"id":"system.adapter.web.0","v
                        GEKÜRZT, hier kommen 1000e Changelog Einträge...
                        dattatore Homekit","es":"otro adaptador para el Homekit","pl":"kolejny adapter Homekit"},"platform":"Javascript/Node.js","mode":"daemon","icon":"yahka.png","enabled":true,"extIcon":"https://raw.githubusercontent.com/jensweigele/ioBroker.yahka/master/admin/yahka.png","keywords":["homekit","siri"],"readme":"https://github.com/jensweigele/ioBroker.yahka/blob/master/README.md","loglevel":"info","type":"iot-systems","materialize":true,"config":{"minWidth":800,"width ":1440,"minHeight":600,"height ":860},"authors":[{"name":"Jens Weigele","email":"iobroker.yahka@gmail.com"}],"installedVersion":"0.7.1","host":"raspberrypi"},"native":{"firstTimeInitialized":true,"bridge":{"devices":[{"configType":"customdevice","manufacturer":"RFTEC","model":"PointClick","name":"Bett","serial":"2525A25","enabled":true,"category":"5","services":[{"name":"Bett","subType":"Bett","type":"Lightbulb","characteristics":[{"name":"On","enabled":true,"inOutFunction":"ioBroker.State","inOutParameters":"broadlink2.0.States.Bett"}]}]}],"configType":"bridge","name":":yahka.0","manufacturer":"Raspberry","model":"ioBroker","serial":":yahka.0","username":"b1:dc:1b:94:c1:12","pincode":"123-45-678","port":0,"ident":":yahka.0","verboseLogging":false},"cameras":[]},"from":"system.adapter.yahka.0","ts":1527020215149,"acl":{"object":1636}}}]}] +68ms
                        socket.io-client:manager writing packet {"type":2,"data":["subscribe","broadlink2.0.States.Bett",null],"options":{"compress":true},"nsp":"/"} +8ms
                        engine.io-client:socket flushing 1 packets in socket +24ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":30,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +15s
                        engine.io-client:socket flushing 1 packets in socket +15s
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +3ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":36.61,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +2ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":16.99,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +2ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":10.25,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +3ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":19,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +2ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +2ms
                        engine.io-client:socket flushing 7 packets in socket +15ms
                        engine.io-client:socket writing ping packet - expecting pong within 60000ms +10s
                        engine.io-client:socket flushing 1 packets in socket +1ms
                        engine.io-client:socket socket receive: type "pong", data "undefined" +5ms
                        engine.io-client:socket writing ping packet - expecting pong within 60000ms +107ms
                        engine.io-client:socket socket receive: type "pong", data "undefined" +3ms
                        engine.io-client:socket flushing 1 packets in socket +5s
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":36.86,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":16.99,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":10.47,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +2ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":34,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        engine.io-client:socket flushing 7 packets in socket +12ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":37.12,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":10.63,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":49,"ack":true,"from":"system.adapter.yahka.0"},null],"options":{"compress":true},"nsp":"/"} +1ms
                        engine.io-client:socket flushing 7 packets in socket +11ms
                        engine.io-client:socket writing ping packet - expecting pong within 60000ms +5s
                        engine.io-client:socket flushing 1 packets in socket +0ms
                        engine.io-client:socket socket receive: type "pong", data "undefined" +4ms
                        engine.io-client:socket writing ping packet - expecting pong within 60000ms +108ms
                        engine.io-client:socket flushing 1 pack/dogafox@gmail.com/hq@ccu.io/bluefox@ccu.io
                        Im WebIF versucht er offenbar immer noch weiter zu starten, der erfolgreiche Start per Konsole taucht dann aber auch auf.
                        host.raspberrypi 2018-05-22 22:17:26.957 info Restart adapter system.adapter.yahka.0 because enabled
                        host.raspberrypi 2018-05-22 22:17:26.957 error instance system.adapter.yahka.0 terminated with code 1 ()
                        host.raspberrypi 2018-05-22 22:17:26.081 info instance system.adapter.yahka.0 started with pid 5014
                        host.raspberrypi 2018-05-22 22:16:56.061 info Restart adapter system.adapter.yahka.0 because enabled
                        host.raspberrypi 2018-05-22 22:16:56.060 error instance system.adapter.yahka.0 terminated with code 1 ()
                        yahka.0 2018-05-22 22:16:55.174 info adding Bett with UUID: 6ec733ba-7739-4b70-b449-2a75d3bda8d8
                        yahka.0 2018-05-22 22:16:55.147 info first time initialization
                        yahka.0 2018-05-22 22:16:55.145 info adapter ready, checking config
                        yahka.0 2018-05-22 22:16:55.115 info starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v8.9.4
                        host.raspberrypi 2018-05-22 22:16:55.192 info instance system.adapter.yahka.0 started with pid 4987
                        host.raspberrypi 2018-05-22 22:16:55.177 info object change system.adapter.yahka.0
                        host.raspberrypi 2018-05-22 22:16:54.249 info Restart adapter system.adapter.yahka.0 because enabled
                        host.raspberrypi 2018-05-22 22:16:54.249 error instance system.adapter.yahka.0 terminated with code 1 ()
                        host.raspberrypi 2018-05-22 22:16:53.379 info instance system.adapter.yahka.0 started with pid 4977
                        host.raspberrypi 2018-05-22 22:16:23.368 info Restart adapter system.adapter.yahka.0 because enabled
                        host.raspberrypi 2018-05-22 22:16:23.367 error instance system.adapter.yahka.0 terminated with code 1 ()
                        host.raspberrypi 2018-05-22 22:16:22.549 info instance system.adapter.yahka.0 started with pid 4959
                        host.raspberrypi 2018-05-22 22:15:52.531 info Restart adapter system.adapter.yahka.0 because enabled
                        host.raspberrypi 2018-05-22 22:15:52.530 error instance system.adapter.yahka.0 terminated with code 1 ()
                        host.raspberrypi 2018-05-22 22:15:51.677 info instance system.adapter.yahka.0 started with pid 4945
                        host.raspberrypi 2018-05-22 22:15:21.657 info Restart adapter system.adapter.yahka.0 because enabled
                        host.raspberrypi 2018-05-22 22:15:21.657 error instance system.adapter.yahka.0 terminated with code 1 ()
                        EDIT: Ich habe jetzt den Service mal herausgenommen und manuell ioBroker über die Konsole gestartet. yahka wurde mitgestartet, ich probiere morgen weiter und ergänze dann.
                        • eumatsE Offline
                          eumatsE Offline
                          eumats
                          #620
                          Du könntest zzgl. das Debug-Level von yahka noch mal auf debug stellen. Dann werden ein paar mehr Infos ausgegeben…
                            Matze1708
                            #621
                            Ich möchte bei dem Thermostat immer Heizen weitergeben.
                            Aktuell habe ich in heatingCooling State bzw targetheating cooling statr nichts drin stehen.
                            Was muss ich eingeben, dass immer heizen auf dem Iphone steht?
                              D2xU
                              #622
                              Hallo liebe SmartHomies,
                              ich bin ganz neu in Sachen iOBroker und versuche da gerade mein Smarthome einzurichten und habe mit dem Broadlink und 433mhz-Steckdosen angefangen. Dank der guten Videos von Dennis habe ich es auch geschafft, dass zwei Schalter/Steckdosen über Alexa bereits schaltbar sind, allerdings scheitere ich bei der Einbindung in den Yahka-Adapter, denn bei Änderung der Kategorie ändern sich die einstellbaren Attribute nicht, sodass bei dem Switch "On etc." nicht erscheint…
                              Ich hab mal einen Screenshot angehängt...
                              Habe auch schon alle vorhandenen Adapter auf den neusten Stand gebracht und bei dem "Troubleshooting-Guide" auf GitHub kommt immer die Meldung, dass jeweils die neusten Versionen der Datenbanken bereits installiert sind. Ich kann den Adapter auch und Homekit bereits einfügen etc., aber Geräte hinzufügen funktioniert leider nicht so wirklich…
                              Ich hoffe Ihr könnt einen Anfänger da weiterhelfen.
                              Vielen Dank!
                              Hat sich erledigt, der IE läuft da nicht… Hab Firefox genommen, damit lief es problemlos.
                                Matze1708
                                #623
                                Gaaaanz einfach :-)
                                Wichtig die Bridge muss erstmal hinterlegt sein.
                                Wenn das ok. Neue Funktionen anlegen in deinem Fall Lightbulb , dann den Service dazu anlegen. Und unter on deinen State von den Objekten einfügen.
                                Fertig.
                                Hat aber nix mit Alexa zutun…. ist was sinnvolleres....HomeKit für Apple.
                                War nur meine eigene Meinung [emoji12]
                                  D2xU
                                  #624
                                  Vielen Dank für deine Hilfe, aber irgendwie stehe ich auf dem Schlauch…
                                  Den Adapter konnte ich schon erfolgreich am iPhone hinzufügen, dass klappt alles problemlos, aber jetzt möchte die schaltbare Steckdose am iPhone schalten und das haut irgendwie nicht hin...
                                  Ich ändere sowohl den die "Kategorie" und den "Service-Typ" auf "Switch" bzw. jetzt "Lightbulb", aber im unteren Feld ändern sich (wie gesagt) die Attribute nicht, sodass "On" und "Off" nicht auftauchen...
                                  Irgendwas muss ich irgendwo vergessen/übersehen haben...
                                  Ich habe es gelöst, es lag am IE… Habe es mit Firefox getestet und läuft...
                                  • W Offline
                                    W Offline
                                    Walkinlarge2010
                                    #625
                                    @Matze1708:
                                    Gesendet von iPhone mit Tapatalk `
                                    Ich habe einen Status erzeugt und diesen dort hinterlegt. Wenn du diesen mit zahlen füllst ändert sich der Status von heizen, auf kühlen bzw. auf aus. Einfach etwas testen [emoji3]
                                    Hab eben bei mir nachgesehen, 1 ist heizen, 0 ist aus.
                                    Gesendet von iPad mit Tapatalk
                                      stoffel67
                                      #626
                                      > Hab es hinbekommen. Die Homebridge Erkennung funktioniert über multicast. Das muss man natürlich im Netzwerk erlauben :lol:
                                      kannst du da mal mehr dazu sagen, hab' das gleiche Problem…
                                      Mein Adapter: JUNG/GIRA eNet-Adapter
                                        Matze1708
                                        #627
                                        @Walkinlarge2010!:
                                        @Matze1708:
                                        Gesendet von iPad mit Tapatalk `
                                        Hallo, danke für deine Hilfe.
                                        Probiere ich mal aus.
                                        Ich dachte, man könnte in den Adapter direkt diese Zahl eintragen.
                                          D2xU
                                          #628
                                          Hallo liebe Smarthomies,
                                          ich bin am überlegen eine HiKam S6, als eine Art Türspion, umzufunktionieren. Aufgrund der Befestigungsplatte lässt sich diese, so glaube ich, am einfachsten an der Tür (hat Fenstereinsätze) befestigen. Solange ich irgendwann (in entfernter Zukunft) eine Visualisierung gebastelt habe möchte ich gerne alle meine Geräte, mittels Yahka-Adapter, über Homekit, als Steuerzentrale, nutzen.
                                          Hat schon mal Jemand eine HiKam eingebunden und kann mir da etwas zu den möglichen Funktionen sagen, welche dann über Homekit nutzbar sind?
                                          (Also wird die Bewegungserkennung unterstütz etc.?)
                                          Vielen Dank!
