  4. Nichts geht mehr..SD Karte?/Frage zum Backup
    6.0k
45 Beiträge 5 Kommentatoren 4.9k Aufrufe
  • J Offline
    jafloor
    iobroker kann ich leider nicht stoppen:
    pi@ioBroker-RasPi:/opt/iobroker $ sudo iobroker stop
    module.js:478
        throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (module.js:476:15)
        at Function.Module._load (module.js:424:25)
        at Module.runMain (module.js:611:10)
        at run (bootstrap_node.js:387:7)
        at startup (bootstrap_node.js:153:9)
        at bootstrap_node.js:500:3
    JS Controller Neu installieren? Nope :lol:
    pi@ioBroker-RasPi:/opt/iobroker $ sudo npm install iobroker.js-controller --production
    npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
    > iobroker.js-controller@1.4.2 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstall_check.js
    │              npm update check failed              │
    │        Try running with sudo or get access        │
    │       to the local update config store via        │
    │ sudo chown -R $USER:$(id -gn $USER) /root/.config │
    NPM version: 5.8.0
    npm version >= 5: disabling package-lock
    fs.js:642
      return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
    Error: EACCES: permission denied, open '/opt/iobroker/.npmrc'
        at Error (native)
        at Object.fs.openSync (fs.js:642:18)
        at Object.fs.writeFileSync (fs.js:1356:33)
        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/preinstall_check.js:56:5)
        at Module._compile (module.js:577:32)
        at Object.Module._extensions..js (module.js:586:10)
        at Module.load (module.js:494:32)
        at tryModuleLoad (module.js:453:12)
        at Function.Module._load (module.js:445:3)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@1.4.2 preinstall: `node lib/preinstall_check.js`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@1.4.2 preinstall script.
    npm ERR!     /root/.npm/_logs/2018-04-24T16_05_53_428Z-debug.log</anonymous>
    ich kann nichtmal problemlos den npm cache leeren…
    pi@ioBroker-RasPi:/opt/iobroker $ npm cache clean
    npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead.
    npm ERR!
    npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
    npm ERR!     /home/pi/.npm/_logs/2018-04-24T16_11_17_452Z-debug.log
    Langsam bekomme ich leichte Panik… meine schöne VIS heul
    Viiiielen Dank für Eure Hilfe!!!!
    • HomoranH Offline
      HomoranH Offline
      sudo npm cache clean --force
      dann fragt er ob du weisst was du tust, da sagst du ja ;-)
      exakt den Fall hatte ich letzten Donnerstag, da habe ich auch schon in die Tonne treten wollen, da lief es dann auf einmal
      • J Offline
        jafloor
        jetzt geht echt garnix mehr.
        egeal ob sudo iobroker start, stop, status… ich bekomme immer das zurück:
        pi@ioBroker-RasPi:/opt/iobroker $ sudo iobroker start
        module.js:478
            throw err;
        hat noch jemand eine Idee was ich tun kann?
        • wendy2702W Offline
          wendy2702W Offline
          Hast du nach dem npm cache clean noch mal versucht den JS-Controller zu installieren?
          • J Offline
            jafloor
            ja habe ich. Es kommt wieder die Fehlermeldung:
            NPM version: 5.8.0
            fs.js:642
                at Error (native)
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /root/.npm/_logs/2018-04-24T16_34_13_878Z-debug.log</anonymous>
              wendy2702W Offline
              Kannst du mal abfragen:
              sudo ls -la /root/.config
              Und mal blöd gefragt… hast du das mal ausgeführt und dann nochmal versucht den JS-Controller zu installieren:
              Und eventuell auch mal für den User PI:
              sudo chown -R $USER:$(id -gn $USER) /home/pi/.config
              • HomoranH Offline
                HomoranH Offline
                in der Phase hatte ich dann ganz verzweifelt tatsächlich ein npm downgrade gemacht mit:
                sudo npm install -g npm@4
                • J Offline
                  jafloor
                  @wendy2702:
                  das brachte:
                  insgesamt 12
                  drwx------ 3 root root 4096 Apr 24 17:50 .
                  drwx------ 7 root root 4096 Apr 24 17:50 ..
                  drwx------ 2 root root 4096 Apr 24 18:56 configstore
                  habe ich gemacht und versucht den js Controller zu installieren…
                  da ratterte dann im Terminal minutenlang immer wieder und hörte nicht auf:
                  gyp WARN EACCES user attempting to reinstall using temporary dev dir "home/pi/node_modules/unix-dgram/.node-gyp"
                  gyp WARN EACCES user "root" does not have permission to access the dev dir "home/pi/node_modules/unix-dgram/.node-gyp/6.14.1"
                  seit wann kann root etwas nicht was nur User pi kann? :lol:
                  Ok, ich denke ich habe alles versucht. Wenn jetzt keine Ideen mehr sind… gebe ich es auf. Irgendwas stimmt ja wohl mit meinen Node nicht :(
                  Und da ich auch nicht wirklich weiß was ich hier tue, habe ich auch Sorge dann ein vermurxtes System zu haben. Vielleicht habe ich ja Glück und kann später wenigstens die Views aus dem gesicherten Ordner retten, wenn ich alles neu aufgesetzt habe. Die Adapter im Broker waren mir eh nicht so wichtig. Nur die Views... da steckte die meiste Arbeit drin.
                    wendy2702W Offline
                    Hast du das „minuten lange“ abgebrochen !?
                    Das ist nur ein PI… das dauert schonmal.
                    Solche Code Schnipsel sind in deinem Fall leider nicht so hilfreich :(
                    • J Offline
                      jafloor
                      ja das habe ich abgebrochen…
                      es waren immer wieder diese beiden Zeilen... mehr kam da nicht.
                      Habe jetzt auch einfach mal nach Anleitung alles gelöscht:
                      sudo apt-get remove nodejs
                      sudo apt-get remove npm
                      und neu istalliert
                      curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
                      Alles ohne Fehlermeldung. Leichte Freude kam auf. ABER:
                      pi@ioBroker-RasPi:~ $ sudo iobroker status
                      module.js:478
                          throw err;
                      Mein System ist wohl endgültig gestorben. Ich habe keine Idee mehr. Ich hasse es aufzugeben :roll:
                      • HomoranH Offline
                        HomoranH Offline
                        @jafloor:
                        es waren immer wieder diese beiden Zeilen... mehr kam da nicht. `
                        die laufen aber einige Minuten durch, das sind immer leicht andere Zeilen
                        @jafloor:
                        Leichte Freude kam auf. ABER: `
                        jetzt bitte sofort ein
                        sudo npm install iobroker --unsafe-perm --production
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          Hast du vor dem kopieren ioBroker gestoppt ?
                          Hast du nach dem kopieren reinstall.sh ausgeführt?
                          Das lese ich so nirgends in deinen berichten
                          Send from mobile device
                          Das schöne ios hat Auto Korrektur zum k****
                          Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
                          • J Offline
                            jafloor
                            ok, werde ich später mal versuchen. aber nach:
                            ist ja mein gesicherter iobroker Ordner wieder weg, oder? Dann ist der Broker wieder "nackig"?
                            Der Fehler scheint ja irgendwie schon in meinem Backup zu stecken. Somit ist mein gesicherter ioBroker Ordner wohl für die Tonne :(
                            Denn auch mit der neuen SD Karte schmierte mir der PI ab, wenn ich auf die 8081 will. Das hatte ich ja beim alten System auch so.
                            Und das alles nur weil ich DAU in der Weboberfläche vom Admin rumgeklickt habe. Leider weis ich nicht mehr was ich da gemacht habe, als er sich verabschiedet hat. Egal, ist dann wohl Lehrgeld
                            Ok, dann bleibt mir wohl wirklich nur alles neu zu machen. Seht Ihr denn eine Chance aus meinem gesicherten Ordner wenigstens die VIEWS zu retten? Oder werde ich da auch Probleme bekommen?
                            P.S.
                            Ich danke Euch vielmals für Eure Mühe und Eure Geduld. Ihr seid Großartig!!!!!!!
                            • DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              Warte jetzt Mal langsam du hast da jetzt einige Sachen hintereinander gemacht die einander beissem können.
                              Zurück zu Basis:
                              • Image nemen und auf Pi spielen
                              • Backup auf ein Verzeichnis auf dem Pi hochladen
                              • ioBroker stoppen
                              • das Backup ins Verzeichnis kopieren (mit dem cp -R commando nach /opt/iobroker)
                              • zur Sicherheit rechte gut setzen
                              sudo chmod -R 777 /opt/iobroker
                              • reinstall.sh ausführen (im Verzeichnis /opt/iobroker)
                              • probieren ioBroker zu starten
                              Hattest du diese Reihenfolge ausgeführt?
                              Wen nein mach das mal bitte und poste schritt für schritt ob die Commando geklappt haben oder Fehler kommen.
                              Vielleicht liegt es nur an mir aber blicke nicht ganz durch was du in welcher Reihenfolge gemacht hast
                              • J Offline
                                jafloor
                                ok, ich werde morgen nochmal von vorne anfangen. Schritt für Schritt und ganz langsam.
                                Nochmals Tausend Dank!!
                                • J Offline
                                  jafloor
                                  @Dutchman:
                                  Hast du nach dem kopieren reinstall.sh ausgeführt? `
                                  gestoppt hab ich ihn.
                                  Aber es wurde doch gesagt, das reinstall.sh nur notwendig ist, wenn die Hauptversion von node geändert wurde? also von 6 auf 8 o.ä.
                                  Da ich immer die 6 hatte, dachte ich es ist nicht notwendig?
                                  @Homoran:
                                  Ein upgrade von node innerhalb einer Hauptversion, also 6.10 auf 6.14 ist absolut unkritisch.
                                  nur beim Wechsel von 4.x auf 6.x oder 8.x (Vorsicht!!) ist ein reinstall notwendig
                                  Rainer `
                                  • DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    Trotzdem nach backup Einspielung reinstall.sh bitte in der Reihenfolge wie ich genannt habe.
                                    Mach das alles aber bitte mit einem frischen image und mit dem user root````
                                    sudo su
                                    An der jetzigen Installation ist zuviel hon und her passiert auch das kopieren ging an anfang schief also durchatmen und nochmal von vorne kriegen das schon irgendwie hin
                                      wendy2702W Offline
                                      @Dutchman:
                                      Mach das alles aber bitte mit einem frischen image und mit dem user rootsudo su `
                                      Warum soll er das als „root“ user machen?
                                      Ich habe 4 Installationen, davon 2 mal immer eine neu installation und Backup einspielt aber nie als „root“.
                                      • DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        @wendy2702:
                                        Ich habe 4 Installationen, davon 2 mal immer eine neu installation und Backup einspielt aber nie als „root“. `
                                        Um für jetzt potentiellen Fehlerquellen aus zu schließen.
                                        Weiß nicht genau welches Image er nimmt und eventuell npm 5 böse mitspielen
                                        • J Offline
                                          jafloor
                                          so, nun konnte ich es endlich nochmal probieren.
                                          soweit klappte alles Fehlerfrei. reinstall.sh hat aber scheinbar nicht korrekt gearbeitet. nach ca 10.min scheinbar sauberes arbeiten kam die Meldung unerwartetes Dateiende.
                                          Ist die reinstall.sh im Image irgendwie fehlerhaft? Ist da etwas bekannt?
                                          Kann den ioBroker zwar jetzt starten, aber ich sehe beim adminaufruf das selbe problem wie bei meinem "defekten System"
                                          Ich bekomme die Frames und Farben zwar angezeigt aber ohne inhalt und dann die ganze Zeit das Spinningwheel bzw. der Blaue Lade Balken der von links nach rechts wandert.
                                          Fazit: es ist jetzt alles genauso wie beim defekten System. Vorteil: Es hat sich nicht verschlechtert !! :lol: :lol: :lol:
                                          Und der Pi stürzt auch direkt wieder ab nach einer weile. Das kann doch nicht schon wieder die sd karte sein :?: :?:
