  3. Cloud Dienste
  4. Http requests via Alexa an Denon Receiver senden
    6.4k
97 Beiträge 6 Kommentatoren 16.8k Aufrufe 2 Beobachtet
  • BBTownB Offline
    BBTownB Offline
    BBTown
    Und das wäre ein Vorschlag um den Blockly Code zusammenzubauen
    <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="UOdt?(t{Z=~|8j`o/t#d" x="-212" y="-137"><mutation items="1"></mutation>
    <value name="OID0"><shadow type="field_oid" id="O^i|+{HHFGg}oA#NT@G"><field name="oid">MultiMedia.0.Denon.Lautstärke_Denon</field></shadow></value> <statement name="STATEMENT"><block type="request" id="hWq]a^0,RR/{G*/zvL%*"><mutation with_statement="false"></mutation> <field name="WITH_STATEMENT">FALSE</field> <field name="LOG">log</field> <value name="URL"><shadow type="text" id="!J6#5n3%ohYbM|e2r]/i"><field name="TEXT">text</field></shadow> <block type="text_join" id="%kc/v;oE/EWZs*v%LG{x"><mutation items="2"></mutation> <value name="ADD0"><block type="text" id="8DU{-Vb7b1ebG@^fA;2K"><field name="TEXT">http://192.168.200.36/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/$</field></block></value> <value name="ADD1"><block type="math_round" id=".!2WtTVAm#,3j4si-au"><field name="OP">ROUND</field>
    <value name="NUM"><shadow type="math_number" id="o@jdd6w#hn52KFHG6mFb"><field name="NUM">3.1</field></shadow>
    <block type="math_arithmetic" id="!KX5E8BoqHRCku[99m%~"><field name="OP">MINUS</field>
    <value name="A"><shadow type="math_number" id="8H2QIQr@!fml({/w(10"><field name="NUM">1</field></shadow>
    <block type="math_arithmetic" id="L5pq5jsBY7W#yOLp,X3
    "><field name="OP">DIVIDE</field>
    <value name="A"><shadow type="math_number" id="_Y_ap==mVi7yAC:oLo31"><field name="NUM">1</field></shadow>
    <block type="convert_tonumber" id="!gTxu5O34YyX~dU!VM)e"><value name="VALUE"><block type="get_value" id=":@J?uHW[L32WTNj33a`M"><field name="ATTR">val</field>
    <field name="OID">MultiMedia.0.Denon.Lautstärke_Denon</field></block></value></block></value>
    <value name="B"><shadow type="math_number" id="4OdVW+Plb[8U~+sWGF9x"><field name="NUM">2.55</field></shadow></value></block></value>
    <value name="B"><shadow type="math_number" id="x#/f%42-;#^^|{~4+C}0"><field name="NUM">80</field></shadow></value></block></value></block></value></block></value></block></statement></block>
    [1917_denon_4.png](/assets/uploads/files/1917_denon_4.png)
    • dslraserD Offline
      dslraserD Offline
      dslraser
      Hallo, für meinem Denon läuft dieses Script für die Lautstärke.
      ! /* – do not edit following lines - START --
      ! "debug": false,
      ! "verbose": false
      ! -- do not edit previous lines - END --*/
      ! createState('Denon.Denon_Lautstärke', {
      ! type: 'number',
      ! name:'Denon-Lautstärke',
      ! min: 0,
      ! max: 100,
      ! def: 50,
      ! read: true,
      ! write: true,
      ! role: 'level.volume'});
      ! var http = "http://192.168.180.6/goform/formiPhoneAppDirect.xml?";
      ! on({id: "javascript.0.Denon.Denon_Lautstärke", change: "any"},
      ! function (obj) {
      ! var x = obj.state.val;
      ! if (x === 0) {
      ! require("request")(http + 'MUON'); // Bei Befehl "aus" wird Vol. auf Mute gesetzt.
      ! console.log("Lautstärke AVR-4520 auf -MUTE- gesetzt.");
      ! } else {
      ! require("request")(http + 'MV' + x);
      ! console.log("Lautstärke AVR-4520 auf " + x + " gesetzt.");
      Die 80% Begrenzung habe ich bei mir direkt im Verstärker eingestellt. (so sind in dem Script Deine 80% dann trotzdem 100% für die Alexa Geschichte)
      Der Alexa Befehl bei mir : Alexa, Lautstärke im Wohnzimmer (so heißt das Ding bei mir als Smartgerät im Cloud Adapter) auf xy Prozent. (also nicht dimmen oder so…)
        thronis
        Puh. ich habe mir den Link von dir jetzt 2x durch gelesen, aber das ist mir wirklich zu hoch… habe
        echt keine Ahnung davon...
        • dslraserD Offline
          dslraserD Offline
          dslraser
          was verstehst Du denn nicht ?
          Du musst nur ein neues leeres Script erstellen und das von mir dort rein kopieren. Die IP Adresse musst Du noch mit der Deines Verstärkers überschreiben. (Sollte eigentlich beim Denon funktionieren. Welchen hast Du eigentlich ?)
          Das Script erstellt Dir dann einen Datenpunkt, wenn es gestartet wird.
          Dann gehst Du in den Cloud Adapter und fügst ein neues Smart Gerät über das + Zeichen hinzu. Den Datenpunkt findest Du dann unter JavaScript in den Objekten. Dann vergibst Du einen Namen, z.B. Lautstärke im Wohnzimmer, oder Verstärker, oder halt so wie es heißen soll. Danach sagst Du nur: Alexa, suche neue Geräte und es sollte gefunden werden.
          Sonst frage einfach….
          ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201804 ... 6e72fd.jpg">https://uploads.tapatalk-cdn.com/20180417/11a1f76fd629c860f2729313536e72fd.jpg</link_text>" />
          E 1 Antwort Letzte Antwort
          • BBTownB Offline
            BBTownB Offline
            BBTown
            @dslraser:
            was verstehst Du denn nicht ? ` ich glaube es ging hier um die Erläuterungen in dem von mir empfohlenen Link viewtopic.php?f=24&t=5461&hilit=broadli … =60#p77911
            • BBTownB Offline
              BBTownB Offline
              BBTown
              ist deine Grundlautstärke wirklich volle Pulle (100%) ?? :o :o
              • dslraserD Offline
                dslraserD Offline
                dslraser
                @BBTown:
                ist deine Grundlautstärke wirklich volle Pulle (100%) ?? :o :o ` Ich habe die Lautstärke im Verstärker auf 80% begrenzt. Wenn das Gerät eingeschaltet wird steht es immer auf 50%. (dev:50)
                ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201804 ... a97ce1.jpg">https://uploads.tapatalk-cdn.com/20180417/966dc8798045b2c2171d7b481da97ce1.jpg</link_text>" />
                • BBTownB Offline
                  BBTownB Offline
                  BBTown
                  aber wenn du sagen würdest "Alexa, schalte den Verstärker ein" dann würde der mit100% (entsprechend 80% im Verstärker) losbrüllen da Du den default für on auf 100% gestellt hast :o
                    thronis
                    Ich lach mich schlapp. ehrlich gesagt ich weiß nicht warum aber es funktioniert :-)
                    Vielen Dank für eure Hilfe^^
                    Werde später mal versuchen das zu verstehen.
                    • BBTownB Offline
                      BBTownB Offline
                      BBTown
                      @thronis:
                      Werde später mal versuchen das zu verstehen. ` na, geht doch 8-)
                      Hast Du das Script von dslraser genommen, oder bist Du den Weg gegangen, den ich beschrieben habe?
                        thronis
                        Habe das Script von dslraser genommen :-)
                        Und funktionierte auf Anhieb.
                        Jetzt möchte ich noch versuchen meinen Receiver (VU Zero 4k) im Schlafzimmer über Alexa an zu machen.
                        Habt ihr da auch noch einen Tipp für mich? :-)
                        Hatte dafür auch ein http request für die ha bridge, aber den habe ich ausversehen gelöscht, aber den werde ich finden.
                        Edit: Da sah der http request so aus
                        http://192.168.200.81/web/remotecontrol?command=116
                        Wie müsste dann das Script aussehen?
                        • dslraserD Offline
                          dslraserD Offline
                          dslraser
                          @BBTown:
                          aber wenn du sagen würdest "Alexa, schalte den Verstärker ein" dann würde der mit100% (entsprechend 80% im Verstärker) losbrüllen da Du den default für on auf 100% gestellt hast :o `
                          an/aus ist ein anderer Befehl
                          ! "debug": false,
                          ! "verbose": false
                          ! createState('Denon.Denon_Power', {
                          ! type: 'boolean',
                          ! name:'Denon-Power',
                          ! read: true,
                          ! write: true,
                          ! role: 'switch.active'
                          ! var http = "http://192.168.180.6/goform/formiPhoneAppPower.xml?";
                          ! on({id: "javascript.0.Denon.Denon_Power", change: "ne"},
                          ! function (obj) {
                          ! var oldValue = obj.oldState.val;
                          ! if (getState("javascript.0.Denon.Denon_Power").val === true) {
                          ! require("request")(http + '1+PowerOn');
                          ! } else {
                          ! require("request")(http + '1+PowerStandby');
                          • BBTownB Offline
                            BBTownB Offline
                            BBTown
                            @thronis:
                            Wie müsste dann das Script aussehen? ` so:````
                            • dslraserD Offline
                              dslraserD Offline
                              dslraser
                              @thronis:
                              Wie müsste dann das Script aussehen? ` Hier mal ein Beispiel für ARD
                              http://192.168.180.3/web/zap?sRef=1:0:1 … 0000:0:0:0:
                              und hier kannst Du lesen wie es geht.
                              https://dream.reichholf.net/wiki/Enigma2:WebInterface
                              Für die Sender gib das mal in den Browser mit Deiner IP Adresse ein(wenn die Box an ist, dann siehst Du die jeweilige Kanalreferenz, einfach umschalten und Browser aktualisieren)
                              http://192.168.180.3/web/subservices
                                thronis
                                Habe das jetzt tatsächlich ohne hier lesen so gemacht
                                try {
                                  require("request")('http://192.168.200.81/web/remotecontrol?command=116').on("error", function (e) {console.error(e);});
                                } catch (e) { console.error(e); }
                                Geht auch an, nur nicht aus :-(
                                Zum umschalten etc. benötige ich kein Script, dafür gibt es ja nen Skill von Hmmmdada
                                • BBTownB Offline
                                  BBTownB Offline
                                  BBTown
                                  @dslraser:
                                  an/aus ist ein anderer Befehl ` dein Smart Gerät "Verstärker" kennt doch: "An", "Aus", "Level" und damit die Kommandos:
                                  "Alexa, setze Verstärker auf xx %"
                                  "Alexa, schalte Verstärker ein" (On = 100%)
                                  "Alexa, schalte Verstärker aus" (Off = 0%)
                                  • dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    @BBTown:
                                    @dslraser:
                                    an/aus ist ein anderer Befehl ` dein Samrt Gerät "Verstärker" kennt doch: "An", "Aus", "Level" und damit die Kommandos:
                                    "Alexa, schalte Verstärker aus" (Off = 0%) `
                                    ja, aber im Verstärker selbst(in der Weboberfläche steht er auf 50 beim einschalten)
                                    Da wo set steht sind 50 vorgegeben. Und im Script steht bei dev:50, das bewirkt auch das das Gerät immer auf 50% eingeschaltet wird, jedenfalls hat er es noch nie falsch gemacht…![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201804 ... 70742c.jpg">https://uploads.tapatalk-cdn.com/20180418/3a1b234a5b92230b98e47e6d5870742c.jpg</link_text>" />
                                      thronis
                                      Also wenn ich jetzt sage "Alexa schalte den Receiver an" geht er an, wenn ich bei angeschalteten Receiver
                                      sage: "Alexa schalte Receiver aus" passiert nichts, wenn ich aber nochmal sagen: "Alexa, schalte Receiver an" geht
                                      er aus. ist ja der selbe Befehl. Wie bekomme ich es eleganter hin, dass er auch aus geht wenn ich "aus" sage?
                                      • BBTownB Offline
                                        BBTownB Offline
                                        BBTown
                                        @thronis:
                                        er aus. ist ja der selbe Befehl. Wie bekomme ich es eleganter hin, dass er auch aus geht wenn ich "aus" sage? ` zeige doch mal einen Screenshot des Smart Gerätes im cloud adapter
                                        [Edit] und auch vom Script
                                        • dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          @thronis:
                                          er aus. ist ja der selbe Befehl. Wie bekomme ich es eleganter hin, dass er auch aus geht wenn ich "aus" sage? ` Bei dem Befehl aus geht er mit meinem Script auf lautlos.
                                          Für an / aus habe ich weiter oben ein zweites Script gepostet.
                                          (Steht aber auch in den Kommentaren beim Script)
