  4. Backup File löschen
    3.2k
    3.1k
Backup File löschen
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
backup file löschen
7 Beiträge 5 Kommentatoren 1.8k Aufrufe
  • N Offline
    N Offline
    NetFritz
    Hallo
    Bekomme z.Z. viele Meldungen das ioBroker Backup Files nicht löschen kann.
    host.netfritz-FUTRO-S900 2018-08-03 16:16:31.448 error Cannot delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-07-26_14-37_objects.json.gz: {}
    host.netfritz-FUTRO-S900 2018-08-03 16:16:31.448 error Cannot delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-07-25_14-37_objects.json.gz: {}
    host.netfritz-FUTRO-S900 2018-08-03 16:16:31.448 error Cannot delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-07-24_14-37_objects.json.gz: {}
    host.netfritz-FUTRO-S900 2018-08-03 16:16:31.448 error Cannot delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-07-23_14-37_objects.json.gz: {}
    host.netfritz-FUTRO-S900 2018-08-03 16:16:31.448 error Cannot delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-07-22_14-37_objects.json.gz: {}
    host.netfritz-FUTRO-S900 2018-08-03 16:16:31.448 error Cannot delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-07-21_14-37_objects.json.gz: {}
    host.netfritz-FUTRO-S900 2018-08-03 16:16:31.448 error Cannot delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-07-20_14-37_objects.json.gz: {}
    host.netfritz-FUTRO-S900 2018-08-03 16:16:31.448 error Cannot delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-07-19_14-37_objects.json.gz: {}
    host.netfritz-FUTRO-S900 2018-08-03 16:16:31.447 error Cannot delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-07-18_14-37_objects.json.gz: {}
    host.netfritz-FUTRO-S900 2018-08-03 16:16:31.447 error Cannot delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-07-17_14-37_objects.json.gz: {}
    host.netfritz-FUTRO-S900 2018-08-03 16:16:31.445 error Cannot delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/backup-objects/2018-07-16_14-37_objects.json.gz: {}
    Was kann ich machen , das das nicht mehr vorkommt ?
    Gruß NetFritz
    • sissiwupS sissiwup
      bekomme auch zu Hauf:
      Was auffällt: Hier steht "Cannot" in der Spalte des Absenders. Wird wohl ein Programmierfehler sein?
      Linux zotac 4.9.0-7-amd64 #1 SMP Debian 4.9.110-1 (2018-07-05) x86_64 GNU/Linux
      node -v
      v10.8.0
      npm -v
      6.3.0
      Alles auf den aktuellsten Stand. Welche Tipps gibt es ausser irgend eine andere node oder npm Version zu verwenden.
      Umgehungslösung: Lösche die Dateien per cron (/etc/crontab) (&=Kaufmannsund)
      55    * * * *   root     cd /opt/iobroker/iobroker-data/backup-objects && find . -type f -mtime +1 -name "*.json.gz" -exec rm {} \;
      David McNeillD Offline
      David McNeill
      root cause is explained by @voretsen ... here
      Die Ursache wird vom Benutzer @voretsen erklärt ... hier
      • N Offline
        N Offline
        NetFritz
        Hallo
        Nochmal nachgeschaut wo sich die Files befinden
        Gruß NetFritz
        • haselchenH Offline
          haselchenH Offline
          haselchen
          Geht auch über Filezilla.
          Da kannst du dein Backup auf deine Pc/Laptop Festplatte kopieren und die alten Backups vom Server dann löschen.
          • N Offline
            N Offline
            NetFritz
            Hallo
            Wie ich die Files von Hand löschen kann ist mir klar.
            ioBroker möchte diese Files löschen, aber Pfad stimmt nicht.
            Wo kann ich das Einstellen das, das ioBroker den Pfad findet.
            Gruß NetFritz
            • paul53P Offline
              @NetFritz:
              Der Pfad stimmt. Vermutlich ist es ein Zugriffsrechte-Problem. Was sagt ?
              node -v
              Wenn es eine Version 10.x ist, dann auf Version 8.x downgraden !
              • sissiwupS Offline
                sissiwupS Offline
                sissiwup
                node -v
                v10.8.0
                npm -v
                6.3.0
                MfG
                Sissi
                1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
                David McNeillD 1 Antwort Letzte Antwort
                  node -v
                  v10.8.0
                  npm -v
                  6.3.0
                  David McNeill
