  4. History: Restart alle paar Minuten - Downgrade geht nicht
51 Beiträge 4 Kommentatoren 3.8k Aufrufe 1 Beobachtet
    klassisch
    Jetzt wird im debug-mode jedes empfangene Datum dreifach eingetragen:
    history.0	2018-03-12 03:50:09.095	debug	value not changed hm-rpc.1.CUX9000007.1.STATE, last-value=2, new-value=2, ts=1520823009084
    history.0	2018-03-12 03:50:09.093	debug	value not changed hm-rpc.1.CUX9000007.1.STATE, last-value=2, new-value=2, ts=1520823009084
    history.0	2018-03-12 03:50:09.062	debug	value not changed hm-rpc.1.CUX9000009.1.STATE, last-value=1, new-value=1, ts=1520823009050
    history.0	2018-03-12 03:50:09.060	debug	value not changed hm-rpc.1.CUX9000009.1.STATE, last-value=1, new-value=1, ts=1520823009050
    Dann gab es noch sowas
    ! 2018-03-11 10:45:29.180 - [34mdebug[39m: history.0 Min-Delta ignored because no number hm-rpc.0.JEQ012345678.1.MOTION, last-value=true, new-value=false, ts=1520761529168 2018-03-11 10:45:34.007 - [32minfo[39m: web.0 2018-03-11T09:45:34.006Z Connected system.user.admin 2018-03-11 10:45:34.149 - [34mdebug[39m: history.0 use parallel requests 2018-03-11 10:45:34.188 - [34mdebug[39m: history.0 use parallel requests 2018-03-11 10:45:34.214 - [34mdebug[39m: history.0 got 1 datapoints for data.0.Lock.FrontDoor.rfid.alive 2018-03-11 10:45:34.218 - [34mdebug[39m: history.0 after getCachedData: length = 1, isFull=false 2018-03-11 10:45:34.318 - [34mdebug[39m: history.0 after getFileData: cacheData.length = 1, fileData.length = 408 2018-03-11 10:45:34.331 - [34mdebug[39m: history.0 Send: 408 values in: 121ms 2018-03-11 10:45:34.335 - [34mdebug[39m: history.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0 2018-03-11 10:45:34.820 - [34mdebug[39m: history.0 got 0 datapoints for hm-rpc.1.CUX9000007.1.STATE 2018-03-11 10:45:34.850 - [34mdebug[39m: history.0 got 1 datapoints for hm-rpc.1.CUX9000009.1.STATE 2018-03-11 10:45:34.953 - [34mdebug[39m: history.0 Send: 218 of: 508 in: 804ms 2018-03-11 10:45:34.955 - [34mdebug[39m: history.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0 2018-03-11 10:45:34.971 - [34mdebug[39m: history.0 Send: 171 of: 269 in: 783ms 2018-03-11 10:45:34.972 - [34mdebug[39m: history.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0 !
      klassisch
      Bin jetzt nach heftigen downgraden und Pausieren einiger Adapter auf einem restart von history pro Tag. Nach einigen Restarts gibt es aber generelle Probleme. So geht es also nicht weiter.
      Möchte demnächst das System neu aufsetzen, möglichst in einen Zustand, bei dem ein reconnect der DB keinen restart von History auslöst und möglichst wenige reconnects auftreten.
      Welche Konfigurationen (node, npm, js-controller, admin, history, HM-adapter etc.) laufen stabil? Kann mir jemand Tipps geben?
      • apollon77A Offline
        bei mir läuft alles auf latest und stabil!
        Ich verstehe einige Dinge aus deinem Log nicht. An sich sollte es nie vorkommen das Adapterinstanzen parallel mehrfach laufen. Das stellt an sich der js-controller sicher.
        Also überhaupt das da zwei History-Instanzen laufen ist komisch. Das wäre aber das einzige was in meinen Augen das doppellogging erklären würde. Nur mal um sicherzugehen: Die Logs hier kommen aus dem Admin oder aus dem "echten Logfile"? Wenn Admin - zeigt das echter Logfile das gleiche? (Nicht das Admin Müll anzeigt).
        Ich denke nicht das Versionsänderungen hier helfen werden - das kann an sich alles gar nicht sein :-(
        Ich hätte malversucht alle Adapter auszuschalten. Dann iobroker neustarten, Log ansehen, dann die wichtigen Adapter und History starten - eins nach dem anderen und immer wieder log beobachten. Und am besten History auf Debug lassen.
          klassisch
          Vielen Dank!
          Ich verstehe es leider auch nicht.
          Logfile zeigt immer nur einen History-enabled Eintrag pro Datenpunkt.
          Im Admin-Log Window werden aber nach history Neustart eine immer wachsende Zahl von History enabled pro Datenpunkt gezeigt.
          Das scheint auch plausibel, weil mit jedem Neustart die ganze enable Prozedur länger dauert und nauch einigen Neustarts gar nicht mehr ganz durchläuft.
            oookkkkk …wenn das Logfile nur eins anzeigt dann ist es eher ein Thema vom Admin bzw vom "streamed logging handling für Admin".
            Das Logfile auf Platte hat hier "mehr recht" als die Admin-Anzeige
            Welche Version js-controler? Welche Version Admin?
              klassisch
              Admin ist
              2018-03-21 10:16:38.917  - [32minfo[39m: admin.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v6.13.1
              Controller
              `2018-03-21 10:16:32.839  - [32minfo[39m: host.orangepiplus2e iobroker.js-controller version 1.2.3 js-controller starting[/code]`
              Habe jetzt mal nur das Nötigste am Laufen.
              Das erste History enablen geht immer flott, bei Folgeaktionen dauert es immer lämnger.
              Hatte auch schon früher ab und an ein reconnect DB, aber ohne den history Neustart.
              Wenn Du sagst, daß Dein "neuestes" System stabil läuft, dann kann ich mal eine nächtliche Neuinstallation wagen.
              Bin immer nur unsicher welches node, npm etc mit was kompatibel ist und wie man dann das richtige zusammenbekommt.
              Die udate / upgrade -Feinheiten sind mir noch immer fremd. Liegt wohl daran, dass ich mich bisher nicht wirklich damit beschäftigt habe - weil ich es auch nicht wirklich musste.
                klassisch
                Beim Einschalten von web meldet sich history und sagt etwas von "parallel requests". Hat das was zu bedeuten?
                ! 2018-03-21 10:39:16.980 - [32minfo[39m: web.0 2018-03-21T09:39:16.980Z Connected system.user.admin 2018-03-21 10:39:16.991 - [32minfo[39m: web.0 2018-03-21T09:39:16.990Z Connected system.user.admin 2018-03-21 10:39:17.317 - [34mdebug[39m: history.0 use parallel requests 2018-03-21 10:39:17.375 - [34mdebug[39m: history.0 use parallel requests 2018-03-21 10:39:17.401 - [34mdebug[39m: history.0 use parallel requests 2018-03-21 10:39:17.423 - [34mdebug[39m: history.0 use parallel requests 2018-03-21 10:39:17.475 - [34mdebug[39m: history.0 use parallel requests 2018-03-21 10:39:17.529 - [34mdebug[39m: history.0 use parallel requests 2018-03-21 10:39:17.602 - [34mdebug[39m: history.0 use parallel requests 2018-03-21 10:39:17.824 - [32minfo[39m: web.0 2018-03-21T09:39:17.824Z Connected system.user.admin 2018-03-21 10:39:17.875 - [32minfo[39m: web.0 2018-03-21T09:39:17.875Z Connected system.user.admin 2018-03-21 10:39:17.899 - [32minfo[39m: web.0 2018-03-21T09:39:17.899Z Connected system.user.admin 2018-03-21 10:39:18.026 - [32minfo[39m: web.0 2018-03-21T09:39:18.025Z Connected system.user.admin 2018-03-21 10:39:18.189 - [32minfo[39m: web.0 2018-03-21T09:39:18.188Z Connected system.user.admin 2018-03-21 10:39:18.281 - [32minfo[39m: web.0 2018-03-21T09:39:18.280Z Connected system.user.admin 2018-03-21 10:39:18.396 - [34mdebug[39m: history.0 use parallel requests 2018-03-21 10:39:18.333 - [32minfo[39m: web.0 2018-03-21T09:39:18.333Z Connected system.user.admin 2018-03-21 10:39:18.689 - [32minfo[39m: web.0 2018-03-21T09:39:18.689Z Connected system.user.admin 2018-03-21 10:39:18.991 - [34mdebug[39m: history.0 got 1 datapoints for data.0.Ofi.heating.WC.H-rel !
                Web is so konfiguriert
                IP: IPv4 0.0.0
                Port: 8082
                Verschlüsselung(HTTPS): No
                Authentifikation: No
                Puffer: No
                Socket.IO Instanz (Optional): integriert (Wird von Rickshaw oder Vis benutzt)
                Nur Web-Sockets: no
                Eingebautes 'Simple-API': yes (Gehe aber mit meinen ESP8266 direkt über simple API-Port)
                Laufen unter Anwender: Admin
                Nach einiger zeit:
                2018-03-21 10:39:20.862  - [34mdebug[39m: history.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                2018-03-21 10:39:20.866  - [34mdebug[39m: history.0 got 0 datapoints for data.0.heating.Keller-See.H-rel
                2018-03-21 10:39:20.868  - [34mdebug[39m: history.0 after getCachedData: length = 0, isFull=false
                2018-03-21 10:39:20.950  - [34mdebug[39m: history.0 after getFileData: cacheData.length = 0, fileData.length = 412
                2018-03-21 10:39:20.953  - [34mdebug[39m: history.0 Send: 395 values in: 87ms
                2018-03-21 10:39:20.955  - [34mdebug[39m: history.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                2018-03-21 10:39:20.999  - [34mdebug[39m: history.0 use parallel requests
                2018-03-21 10:39:21.044  - [34mdebug[39m: history.0 use parallel requests
                2018-03-21 10:39:21.104  - [34mdebug[39m: history.0 use parallel requests
                2018-03-21 10:39:21.134  - [34mdebug[39m: history.0 use parallel requests
                2018-03-21 10:39:21.180  - [34mdebug[39m: history.0 got 1 datapoints for hm-rpc.1.CUX9002005.0.RSSI_PEER
                  @klassisch:
                  Admin ist
                  Controller
                  Alles stable Versionen, von daher sollte es keinerlei Probleme haben.
                  ~~[quote]~~
                  Wie oft schaltest DU das einund aus? :-) Or jetzt zum testen?
                  ~~[quote]~~
                  Das Reconnect weist an sich darauf hin das ggf zuviel Last auf dem System ist. Diese "States-DB" ist eine "in-memory-DB" auf Port 900x und wird vom jscontroller bereitgestellt. Darüber bekommt der Adapter Zugriff auf die States inkl. Updates und so. Ein "Reconnect" heisst dasdie Verbindung weg war und das sollte an sich nicht vorkommen.
                  ~~[quote]~~
                  Das "neuestes" hast Du reingemogelt ... Mein System hab ich vor 2 Jahren installiert und seitdem nur geupdatet ... Das System läuft aber auf dem Latest Repo und nicht "Stable".
                  ~~[quote]~~
                  Es sei denn DU brauchst spezielle Adapter ist nodejs 4.x mit npm 3 (was da standard ist) immer noch passend. Node 6 geht auch. node 8 ist grenzwertig :-) Nodejs 4 ist noch bis April offiziell supported, dann sollte man Richtung nodejs 6 gehen. (oder halt 8)
                    @klassisch:
                    Beim Einschalten von web meldet sich history und sagt etwas von "parallel requests". Hat das was zu bedeuten? `
                    Das sind "getHistory"-Abfragen von flot/riskshaw. "parallel requests" heisst an der Stelle das zur Verarbeiten und Sammeln der Statistikdaten mehrere Threads verwendet werden - ist aber nur zur Datenaufbereitung.
                    Wieviele Datenpunkte hast Du aktiv im History-Adapter?
                      klassisch
                      Danke, ein paar hundert, HM komplett. Das aber schon lange und die Zahl hat sich in jüngster Zeit kaum erhöht.
                      Bin unterwegs, schaue heute Abend nach der Zahl
                        Wie geht es denn dem System so? Bedenke das "History" das ganze in JSON-Files auf die Platte legt und ggf immer das ganze File neu schreibt wenn Daten dazukommen. Das ist recht viel "I/O", was sich ggf dann in CPU-Auslastung ausdrückt.
                        Die Alternativen wie SQL oder InfluxDB sind ab einer gewissen Größe vorzuziehen
                          klassisch
                          Bis vor der letzten Updaterunde ging es dem System entspannt und jetzt auch noch - wenn nicht gerade die history-enable Geschichte einsetzt oder sich gerade hochschaukelt.
                          CPU-Auslastung zwischen 0.05 bis 0.5 selten mehr im Normalbetrieb.
                          Die "reconnect DB" gab es wie gesagt früher auch ab und an aber ohne Folgeaktionen seitens history.
                          Zur Zahl der subscibierten items: Die HM-Adapter habe ich seinerseits alle global subscribiert. Das läuft schon lange so. Dann noch einige Werte von diversen ESP8266 über simpleApi, wenig tradfri, Xiami robovac, seit einiger Zeit ein wenig sonoff und vielleicht 15 RFLink Geräte.
                          Habe jetzt im Logfile die Anzahl Zeilen der history-enable events gezählt.
                          Beim ersten Durchlauf waren es um 7700 und beim zweiten um 11617 Zeilen.
                          Ich habe ersten nicht verstanden warum es so viele sind (so viele Geräte habe ich nicht) und warum die Zahl von Durchlauf zu Durchlauf schwankt.
                          Die History-Daten werden auf eine 32GB SSD geschoben, die via USB-Sata-Adapter angebunden ist. Ist aber schon geraume Zeit so und war bis zur letzten update session auch stabil.
                          Pro Tag werden normalerweise 5 bis 6 MByte history-Daten erzeugt. Das geht schon geraume Zeit so problemlos.
                          Mit MySQL und Influx kenne ich mich noch gar nicht aus.
                          Wenn mein PC läuft sind oft 20 browser Tabs mit FLOT-Diagrammen auf. Da sieht man dann nach dem Hochfahren aus dem Resume mode auch mal 70 "Connected system.user.admin" im Logfile, die der Frefox wohl im Hintergrund generiert.
                            Und das ist im echten Logfile auch alles so mit mehreren Enabled und allem ?! Oder ist da alles einmal und ok ?
                              klassisch
                              Danke für Deine Geduld.
                              Aus dem Logfile (/opt/iobroker/log/iobroker.log.2018-03-20) eines Starts von gestern. Das ist das kleinste history-enable Ereignis der letzten Tage was ich auf die Schnelle finden konnte. history-log war da noch auf info.
                              Startet mit
                              ! 2018-03-20 09:44:23.139 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.0.INSTALL_MODE 2018-03-20 09:44:23.145 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.1.LEVEL 2018-03-20 09:44:23.148 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.1.PRESS_LONG 2018-03-20 09:44:23.150 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.1.PRESS_SHORT 2018-03-20 09:44:23.195 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.2.LEVEL 2018-03-20 09:44:23.198 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.2.PRESS_LONG 2018-03-20 09:44:23.205 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.2.PRESS_SHORT 2018-03-20 09:44:23.212 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.3.LEVEL 2018-03-20 09:44:23.220 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.3.PRESS_LONG 2018-03-20 09:44:23.226 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.3.PRESS_SHORT 2018-03-20 09:44:23.255 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.4.LEVEL 2018-03-20 09:44:23.269 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.4.PRESS_LONG 2018-03-20 09:44:23.272 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.4.PRESS_SHORT !
                              endet mit
                              ! 2018-03-20 09:44:31.558 - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_5.SWITCH_07 2018-03-20 09:44:31.559 - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_5.SWITCH_0a 2018-03-20 09:44:31.560 - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_5.SWITCH_0e 2018-03-20 09:44:31.562 - [32minfo[39m: history.0 enabled logging of data.0.motion.Hobby-doorCounterToday 2018-03-20 09:44:31.563 - [32minfo[39m: history.0 enabled logging of data.0.motion.Hobby-doorCounterUntilMidnight 2018-03-20 09:44:31.564 - [32minfo[39m: history.0 enabled logging of data.0.motion.Hobby-doorCounter 2018-03-20 09:44:31.565 - [32minfo[39m: history.0 enabled logging of data.0.motion.Hobby-DoorClosed 2018-03-20 09:44:31.566 - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_6.SWITCH_07 2018-03-20 09:44:31.568 - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_6.SWITCH_0a 2018-03-20 09:44:31.569 - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_6.SWITCH_0e 2018-03-20 09:44:31.570 - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_8.SWITCH_07 2018-03-20 09:44:31.571 - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_8.SWITCH_0e 2018-03-20 09:44:31.573 - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_8.SWITCH_0a !
                              auf Zeite 3846, gezählt mit notepad++
                              Also keine unmittelbaren Doppelungen und läuft rasch durch.
                              Habe eine Stichprobe von 10 Zeilen auf Doppelungen untersucht
                              Ausbeute:
                              2018-03-20 09:44:29.745 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.IEQ0243774.0.CONFIG_PENDING_ALARM[/code]
                              ~~[code]~~2018-03-20 09:44:25.683 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.IEQ0243774.0.CONFIG_PENDING [/code]
                                Und wie gesagt: Logfile hat recht. Also hast du ca. 2846 Datenpunkte im History aktiviert. Ist erstmal ok so. alles gut.
                                Jetzt die nächste Frage: Wie oft kommt denn diese "enabled" Arie im echteh Logfile? Sollte nur EINMALIG kommen wenn der History-Adapter gestartet wird. Danach sollte das einfach laufen.
                                  klassisch
                                  Ja, so war das auch das letzte Jahr seit ich auf den OPI umgezogen bin und ich hatte logfiles von 10k bis 60k /Tag. Aber seit der letzten update-Runde startete history enable nach jedem "reconnect DB", was vorher nicht der Fall war und von diesen reconnect DB gab es auch mehr. In Abständen von ca. 10, 20, 60 Minuten. Scheint eher "zufällig" Das logfile schwoll auf 20 MB an, fast nur history enabled Einträge, history log Infostufe.
                                  Habe gestern um 10:20 ioBroker mit den wichtigsten Adaptern gestartet und erst mal Ruhe.
                                  Habe gestern Abend um 20:34 RFLink zugeschaltet und dort ein neues Gerät eingebaut.
                                  Heute um 00:14 gab es wieder ein event (history log debugstufe)
                                  ! 2018-03-22 00:14:35.614 - [34mdebug[39m: history.0 Min-Delta reached hm-rpc.0.LEQ053xxxx.2.POWER, last-value=0.06, new-value=0.05, ts=1521674067985 2018-03-22 00:14:35.616 - [34mdebug[39m: history.0 value not changed hm-rpc.0.LEQ0539xxxx.2.CURRENT, last-value=0, new-value=0, ts=1521674067990 2018-03-22 00:14:35.618 - [34mdebug[39m: history.0 Min-Delta reached hm-rpc.0.LEQ053xxxx.2.VOLTAGE, last-value=232.2, new-value=232.8, ts=1521674067992 2018-03-22 00:14:35.620 - [34mdebug[39m: history.0 Min-Delta reached hm-rpc.0.LEQ053xxxx.2.FREQUENCY, last-value=49.98, new-value=49.99, ts=1521674067993 2018-03-22 00:14:36.726 - [34mdebug[39m: history.0 statesDB connected 2018-03-22 00:14:36.786 - [33mwarn[39m: history.0 Reconnection to DB. 2018-03-22 00:14:36.852 - [34mdebug[39m: history.0 statesDB connected 2018-03-22 00:14:36.892 - [33mwarn[39m: history.0 Reconnection to DB. 2018-03-22 00:14:37.083 - [32minfo[39m: history.0 starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.history, node: v6.13.1 2018-03-22 00:14:37.109 - [32minfo[39m: history.0 starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.history, node: v6.13.1 2018-03-22 00:14:37.221 - [34mdebug[39m: history.0 value not changed hm-rpc.1.CUX9000009.1.STATE, last-value=0, new-value=0, ts=1521674077201 2018-03-22 00:14:37.224 - [34mdebug[39m: history.0 value not changed hm-rpc.1.CUX9000007.1.STATE, last-value=3, new-value=3, ts=1521674077207 2018-03-22 00:14:37.825 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.updated 2018-03-22 00:14:37.826 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.0.INSTALL_MODE 2018-03-22 00:14:37.828 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.1.LEVEL 2018-03-22 00:14:37.828 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.1.PRESS_LONG 2018-03-22 00:14:37.829 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.1.PRESS_SHORT 2018-03-22 00:14:37.829 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.2.LEVEL 2018-03-22 00:14:37.830 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.2.PRESS_LONG 2018-03-22 00:14:37.831 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.2.PRESS_SHORT 2018-03-22 00:14:37.831 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.3.LEVEL !
                                  2018-03-22 00:14:51.387  - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_5.SWITCH_0a
                                  2018-03-22 00:14:51.388  - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_5.SWITCH_0e
                                  2018-03-22 00:14:51.389  - [32minfo[39m: history.0 enabled logging of data.0.motion.Hobby-doorCounterToday
                                  2018-03-22 00:14:51.390  - [32minfo[39m: history.0 enabled logging of data.0.motion.Hobby-doorCounterUntilMidnight
                                  2018-03-22 00:14:51.391  - [32minfo[39m: history.0 enabled logging of data.0.motion.Hobby-doorCounter
                                  2018-03-22 00:14:51.392  - [32minfo[39m: history.0 enabled logging of data.0.motion.Hobby-DoorClosed
                                  2018-03-22 00:14:51.393  - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_6.SWITCH_07
                                  2018-03-22 00:14:51.394  - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_6.SWITCH_0a
                                  2018-03-22 00:14:51.394  - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_6.SWITCH_0e
                                  2018-03-22 00:14:51.395  - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_8.SWITCH_07
                                  2018-03-22 00:14:51.396  - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_8.SWITCH_0e
                                  2018-03-22 00:14:51.397  - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_8.SWITCH_0a
                                  2018-03-22 00:14:51.398  - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_9.SWITCH_07
                                  2018-03-22 00:14:51.398  - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_9.SWITCH_0e
                                  2018-03-22 00:14:51.399  - [32minfo[39m: history.0 enabled logging of rflink.0.channels.EV1527_9.SWITCH_0a
                                  2018-03-22 00:15:56.060  - [34mdebug[39m: history.0 Min-Delta reached hm-rpc.1.CUX9002008.1.DEW_POINT, last-value=-3.1, new-value=-3.14, ts=1521674156052
                                  2018-03-22 00:15:56.072  - [34mdebug[39m: history.0 Min-Delta reached hm-rpc.1.CUX9002008.1.ABS_HUMIDITY, last-value=3.74, new-value=3.73, ts=1521674156059
                                  2018-03-22 00:17:37.412  - [34mdebug[39m: history.0 value not changed hm-rpc.0.HEQ051xxxx.1.TEMPERATURE, last-value=19.4, new-value=19.4, ts=1521674257398
                                  2018-03-22 00:17:37.434  - [34mdebug[39m: history.0 value not changed hm-rpc.0.HEQ051xxxx.1.HUMIDITY, last-value=37, new-value=37, ts=1521674257421
                                  2018-03-22 00:17:44.117  - [34mdebug[39m: history.0 value not changed hm-rpc.0.MEQ04xxxx.4.CONTROL_MODE, last-value=0, new-value=0, ts=1521674264108
                                  2018-03-22 00:17:44.127  - [34mdebug[39m: history.0 value not changed hm-rpc.0.MEQ044xxxx.4.FAULT_REPORTING, last-value=0, new-value=0, ts=1521674264118
                                  2018-03-22 00:17:44.139  - [34mdebug[39m: history.0 value not changed hm-rpc.0.MEQ044xxxx.4.BATTERY_STATE, last-value=2.4, new-value=2.4, ts=1521674264131
                                  2018-03-22 00:17:44.166  - [34mdebug[39m: history.0 value not changed hm-rpc.0.MEQ044xxxx.4.VALVE_STATE, last-value=0, new-value=0, ts=1521674264137
                                  2018-03-22 00:17:44.173  - [34mdebug[39m: history.0 value not changed hm-rpc.0.MEQ044xxxx.4.BOOST_STATE, last-value=0, new-value=0, ts=1521674264139
                                    Wenn du "ps auxww|grep history" machst kommt dann da ein Prozess oder laufen echt zwei?
                                      klassisch
                                      Zur Zeit sieht es so aus:
                                      root@orangepiplus2e:~# ps auxww|grep history
                                      root     16753  0.0  0.0   3668   756 pts/0    S+   10:16   0:00 grep history
                                      root     28003  2.7  1.2 137476 25452 ?        Sl   Mar21  39:24 io.history.0
                                        Schonmal gut, nur ein Prozess. Was das log das sagt ist eeecht strange …
                                        Am ENd ebin ich aber dabei: Finde den Grund für die Reconnect-DBs! ... Wie: keine ahnung :-(
                                          klassisch
                                          Aus meiner Sicht sind es zei Themen:
                                          • reconnect DB. Das habe ich schon seit Anfang des Jahres viewtopic.php?p=118988#p118988 . Bisher aber friedlich ohne sichtbare Auswirkungen.
                                          • Jetzt startet aber history eine Runde enable nach dieser Fehlermeldung. Die neuen histories haben dann dummerweise auch noch den letzten Datenpunkt wiederholt eingetragen, was meine Kurven von täglich (nur einmal täglich) gemessenen Werten verunstaltet. Wahrscheinlich ein gewolltes Feature, was in meiner Konstellation aber unschön ist.
                                          Wenn ich wüsste, dass eine Neuinstallation hülfe, könnte ich eine Nachtschicht einlegen. Habe gerade Urlaub.
                                          Wenn ich wüßte wie dem connection loss auf die Spur kommen kann würde ich natürlich auch das tun. Aber dazu reichen meine EDV-Kenntnisse nicht. Hätte nicht mal bei Windows ne Idee, geschweige den bei Linux. Wenn es keine passenden Logs oder Ereignisanzeigen gibt, wüßte ich auch nicht wo man heutzutage noch nachschauen kann. Glaube nicht, daß das an der SSD liegt, so langsam ist die auch wieder nicht - zumindest nicht an Windows.
