Test Adapter luxtronik2-controller V1.0.x
0.24.0 (2026-11-09)
🐛 Bugfixes & Tweaks
- Operating Mode & Write Protection (
jsonConfig.json,main.ts):- Explicit Operating Mode Selection: Added a central "Operating Mode" selector in the Connection tab with color-coded status banners to clearly distinguish between Read-Only (Monitoring), Read & Write without Modbus (Native via Port 8889), and Read & Write with Modbus TCP (Hybrid RAM access).
- Dynamic UI Locking: When "Read-Only" is selected, all write-related configuration tabs (Modbus, Idle Defaults, Cycle Optimization, HUP, ZIP, and PV Surplus) and their inputs are automatically grayed out and disabled. Selecting native write mode unlocks the optimization tabs while keeping the Modbus tab disabled.
- Strict Backend Write Lock: Enforced a global hardware write lock in Read-Only mode across
onReady,syncConfigValue,runOptimizationSchedule, andonStateChange(while keeping diagnostic functions like debug logging, raw dumps, and firmware checks active). - Automatic Config Migration: Existing installations are seamlessly migrated on startup to the matching operating mode based on their previously active Modbus and optimization settings.
0.23.2 (2026-11-07)
- COP & Efficiency Calculation (
copManager.ts):- Isolated Counter Tracking: Introduced dedicated reference states for Total, Heating, and Hot Water counters (
last_raw_power_*andlast_raw_thermal_*). Each counter is now compared strictly against its own previous value, completely preventing cross-mode "ghost deltas" and astronomical COP spikes during cycle transitions. - Automatic Total-Delta Fallback: Added seamless fallback detection for controllers with firmware bugs (e.g., Novelan LAV) where mode-specific counters like
energy_warmwaterremain permanently at0. If a specific counter reports a delta of0during an active cycle, the adapter automatically uses the live delta of the corresponding total counter (energy_total/thermalenergy_total) without requiring manual configuration workarounds.
0.23.1 (2026-11-07)
- COP & Efficiency Calculation Fix (
copManager.ts):- Fixed Astronomical COP Values: Resolved a critical bug where the internal calculation logic switched between specific and total energy counters, causing massive "ghost deltas" and resulting in astronomical COP values (e.g., > 1000).
- Restored Robust Routing: The adapter now strictly and safely relies on the continuous total counters (
energy_totalandthermalenergy_total). It calculates the delta over the polling interval and dynamically routes it into the Heating or Hot Water buckets based on the active operating state. - Note: Users facing the hardware bug where the heat pump does not track DHW power internally should select "External Object ID" in the adapter settings and link their
energy_totaldatapoint as a workaround.
0.23.0 (2026-11-07)
🐛 Bugfixes & Tweaks
- Configuration & Baseline Logic:
- Custom Heating Offset Baseline: Added a new configuration field in the "Idle Defaults" tab for the default heating target temperature offset (Parallelverschiebung)[cite: 10].
- Preserved Baselines: The idle reset mechanism (
main.ts) and the PV surplus manager (pvManager.ts) now respect this custom baseline (e.g., +1 K) instead of hard-resetting the offset to0 K[cite: 7, 13]. This ensures that your manual baseline heating curve is perfectly preserved when returning from a PV boost or entering standby.
1.0.0 (2026-11-16)
STABLE
0.25.2 (2026-11-16)
- Fix i18n
0.25.1 (2026-11-16)
- Removed Dependencies:
- WS
0.25.0 (2026-11-16)
- Operating Mode & UI Protection (
jsonConfig.json,main.ts):- Explicit Operating Mode Selection: Added a central selector in the Connection tab with color-coded status banners to clearly distinguish between Read-Only (Monitoring), Read & Write without Modbus (Native via Port 8889), and Read & Write with Modbus TCP (Hybrid RAM access).
- Dynamic UI & Backend Write Locking: In Read-Only mode, all write-related configuration tabs (Modbus, Idle Defaults, Cycle Optimization, HUP, ZIP, PV Surplus) are automatically grayed out and all hardware write commands are strictly blocked in the backend.
- Automatic Config Migration: Existing installations are seamlessly migrated on startup to the matching operating mode based on previously active settings.
- Modbus V3.9x Smart Home Interface (SHI) & Diagnostics (
modbusManager.ts,settings.ts,info.ts):- Dual-Protocol Auto-Detection: The Modbus manager now automatically detects and supports both the classic Modbus register mapping (
0..23) and the modern V3.90+ / V3.92.x Smart Home Interface (SHI) register architecture (10000+). - Automated SHI Mode-Gating: Writing to SHI setpoints and offsets (
10001,10002,10006) automatically activates the required SHI control mode registers (10000,10005,10065) and releases heating curve control (mode = 0) when the offset returns to0 K. - Granular Register Polling & Diagnostic Scanner: Replaced rigid block reads with individual register polling to prevent
Exception 2 (Illegal data address)crashes on unsupported registers, and integrated a full Modbus register scanner intoDump_Raw_To_Log.
- Core Stability, COP & Pure TCP Communication (
main.ts,rawFunctions.ts,copManager.ts):- Pure Native TCP Architecture: Removed deprecated WebSocket (port 8214) code in favor of stable, password-free native TCP communication over port
8889. - Isolated COP & Energy Tracking: Enforced strict separation of reference states for heating, hot water, and total consumption with fallback logic for controllers affected by zero-value firmware bugs.
- Bug Fixes: Fixed Modbus RAM vs. EEPROM sync loops (
hardwareOutOfSync), unified°Ctemperature scaling across all data sources, and fixed offline detection (info.connection&errorCount) when telemetry reads fail. - Repository Checker & i18n: Completed missing 11-language translations in
jsonConfig.jsonand updated@iobroker/testingto6.3.2.
Hallo TbsJah,
vielen Dank für den super Adapter und das Update auf v1.0.3 – der Modbus-Hybrid-Modus läuft damit bei mir absolut stabil und verschleißfrei für die PV-Überschuss-Steuerung!
Mir ist bei der Überwachung von write_cycles_today noch ein kleines Detail aufgefallen:
Wenn die Intelligente Takt-Optimierung („Takt-Kopplung startet“ / „Heizen nach WW“) aktiv wird, um den Rücklauf-Sollwert temporär auf 35 °C anzuheben, schreibt der Adapter diesen Wert offenbar über das native Luxtronik-Protokoll (Port 8889) in Settings.02_Heating.heating_curve_parallel_offset (Wert: 35), was jedes Mal einen EEPROM-Schreibzyklus (write_cycles_today +1) auslöst.
Mein System-Setup:
• Adapter-Version: luxtronik2-controller v1.0.3
• Luxtronik Firmware: V3.92.3 (Modernes SHI-Interface mit Register 10000+ wurde beim Start sauber erkannt)
• Modbus Hybrid: Aktiviert (Port 502), u. a. mit Haken bei Heizen Parallelverschiebung (Holding 23) und Feste Rücklaufsolltemperatur (Holding 2)
Wäre es in einem künftigen Update möglich, die Sollwert-Anhebung der Takt-Optimierung bei aktiviertem Hybrid-Modus ebenfalls über Modbus TCP (RAM) statt über Port 8889 auszuführen, um diese Schreibzyklen auch noch einzusparen?
Vielen Dank vorab und beste Grüße! -
Hallo TbsJah,
Beim Überwachen der EEPROM-Schreibzyklen im Hybrid-Modus mit aktiviertem SHI (V3.92.3) sind mir noch drei Stellen im Code aufgefallen, die trotz aktivem SHI weiterhin über WebSocket/Legacy ins EEPROM schreiben:- Takt-Optimierung / Vorheizen vor Warmwasser & Zwangsheizen (main.ts & actionHandlers.ts):
• In runOptimizationSchedule() (istWarmwasser && nachWasser, istLeerlauf, istHeizen), setIdleDefaults() sowie in handleZwangsheizen() wird heating_curve_parallel_offset temporär auf 35 °C bzw. wieder zurück auf den Fußpunkt (config.fusspunkt) gesetzt.
• Da der Fußpunkt im V3.9x-SHI-Protokoll kein flüchtiges Register hat, erzeugt jeder Takt- und Vorheizvorgang zwei EEPROM-Schreibzyklen.
• Vorschlag: Wenn modbusManager.isAvailable && modbusManager.protocolVersion === 'shi' aktiv ist, stattdessen flüchtig einen Offset von +10.0 K (modbusManager.writeRegister(23, 100) → SHI-Register 10002 / Modus 10000 = 2) setzen und beim Beenden bzw. im Leerlauf wieder auf 0 (modbusManager.writeRegister(23, 0)) zurückstellen. - PV-Überschuss-Heizungsboost (pvManager.ts):
• In evaluatePvBoost(), deactivateBoost() und initiateDeactivation() wird für die Heizungsanhebung aktuell heating_temperature (klassisches Holding-Register 15) beschrieben. Laut ModbusManager hat Register 15 im V3.9x-SHI-Protokoll jedoch kein direktes Gegenstück und erzeugt eine Log-Warnung bzw. schreibt über WebSocket ins EEPROM.
• Vorschlag: Im SHI-Modus die Heizungs-Offset-Anhebung (boostHzAmount * 10) ebenfalls flüchtig über modbusManager.writeRegister(23, ...) (SHI 10002) abwickeln. - Start-Reihenfolge in onReady() (main.ts & pvManager.ts):
• Beim Adapterstart wird initPvManagement(this) aktuell vor this.modbusManager.checkAvailability() aufgerufen und schreibt bei aktivem idle_defaults_aktiv sofort heating_temperature = 0 über WebSocket ins EEPROM (da modbusManager.isAvailable zu dem Zeitpunkt noch false ist).
• Vorschlag: this.modbusManager.checkAvailability() vor initPvManagement(this) ausführen und den Reset beim Start nur dann senden, wenn pv_boost_active tatsächlich noch auf true stand.
Ich teste gerade diese drei Anpassungen lokal bei mir und bisher läuft der Adapter inklusive Neustarts, PV-Boost und Vorheiz-Optimierung mit 0 EEPROM-Schreibzyklen.
Viele Grüße!
Hallo JuergenH,
vielen Dank für die super Analyse und das direkte Mitdenken – solche detaillierten Rückmeldungen aus dem Echtbetrieb mit V3.92.3 SHI sind Gold wert!
Ich habe mir alle drei Punkte im Code angeschaut und direkt für das nächste Update umgesetzt:
Takt-Optimierung, Vorheizen & Zwangsheizen (
main.ts/actionHandlers.ts):
Volltreffer – der Heizkurven-Fußpunkt (heating_curve_parallel_offset, Parameter 12) lief im SHI-Modus bisher ins EEPROM, weil es dafür kein flüchtiges SHI-Register gibt. Wenn SHI-Modbus aktiv und Holding 23 angehakt ist, nutzt der Adapter jetzt für Takt-Kopplung, Vorheizen und Zwangsheizen flüchtig den Offset+10.0 Küber Holding 23 (SHI10002, Modus10000 = 2) und setzt ihn anschließend sauber zurück (inkl. Wiederherstellung eines ggf. laufenden PV-Boosts). Auch insetIdleDefaults()werden Endpunkt/Fußpunkt im SHI-Modus nicht mehr unnötig angefasst. -
pvManager.ts):
Hier kurz zur Einordnung: InpvManager.tswird bereitsheating_temperaturebeschrieben – und der liegt im Mapping schon auf Holding 23 (SHI10002), nicht auf Holding 15 (das wäre der Heizkurven-Endpunkt). Dass beim Start trotzdem ein EEPROM-Write kam, war tatsächlich die Folge von deinem Punkt 3. Ich habe den PV-Manager aber zusätzlich gegen die neue SHI-Takt-Kopplung abgesichert, damit sich beide Offsets auf Register10002nicht gegenseitig überschreiben. -
Start-Reihenfolge & PV-Recovery (
main.ts/pvManager.ts):
Ebenfalls ein echter Bug!modbusManager.checkAvailability()läuft jetzt direkt vorinitPvManagement(), und das Recovery beim Start setzt die Sollwerte nur noch zurück, wennpv_boost_activevor dem Neustart tatsächlichtruewar.
Als kleinen Bonus habe ich gleich noch drei verwandte Stellen mitgezogen:
disableHardwareZipTimer()läuft erst nach dem erstenupdateData(), damit der Read-Before-Write-Cache (currentRawParams) beim Start schon gefüllt ist.- HUP-Spannungen werden in
setIdleDefaults()nur noch geschrieben, wenn die HUP-Optimierung auch aktiviert ist. - Beim Zurücksetzen von Warmwasser-Soll auf den Basiswert im SHI-Modus wird
10005jetzt wieder auf0gesetzt, damit manuelle Änderungen am WP-Display nicht dauerhaft übersteuert bleiben.
Das Ganze kommt mit dem nächsten Release – gib danach gerne kurz Bescheid, ob der Zähler bei dir damit dauerhaft auf 0 bleibt!
Viele Grüße
1.0.4 (2026-11-21)
**Thanks to @juergenh **
- Optimized V3.9x SHI Modbus Hybrid mode to achieve zero EEPROM write cycles during cycle optimization, pre-heating, and forced heating (uses volatile SHI offset
+10.0 Kvia Holding 23 /10002instead of base point parameter12) - Fixed startup order in
onReady()so Modbus TCP availability is checked before PV initialization and hardware ZIP timer disable runs after initial raw parameter fetch - Improved PV startup recovery to only reset setpoints if a PV boost was actually active before restart, and decoupled PV heating boost from active SHI cycle optimization
- Released SHI DHW mode (
10005 = 0) when reverting hot water target to baseline and avoided unnecessary HUP voltage writes insetIdleDefaults()when HUP optimization is disabled
Hallo JuergenH,
pvManager.ts):
Viele Grüße
Hallo TbsJah,
nochmals vielen Dank für die schnelle Umsetzung der EEPROM-Fixes! Diesen werde ich morgen einsetzen und testen. Aus meinen DTA-Auswertungen im Echtbetrieb hat sich noch ein wichtiger Verbesserungsvorschlag für die „Intelligente Takt-Optimierung“ ergeben, der besonders für gut gedämmte Gebäude und Passivhäuser mit Fußbodenheizung einen riesigen Unterschied machen würde:
Das aktuelle Problem bei milden Außentemperaturen in der Übergangszeit:
In meinem Passivhaus mit Fußbodenheizung entsteht das Problem speziell bei milden Außentemperaturen in der Übergangszeit (ca. +5 °C bis +12 °C). Während die Funktion im tiefen Winter (bei Dauerfrost und ohnehin höherem Rücklauf) gut funktionieren wird, liegt der reguläre Rücklauf-Sollwert ((TRL_{soll})) in der Übergangszeit sehr niedrig bei etwa 25,0 bis 26,5 °C. Wenn die Takt-Optimierung den Rücklauf-Sollwert (bzw. nun das flüchtige SHI-Register 10002) pauschal hart auf 35 °C (bzw. +10,0 K) anhebt, entsteht bei geringer Heizlast ein schlagartiger Temperatursprung von +8,5 bis +10 K.
Unser Estrich kann diese enorme Wärmemenge in der Übergangszeit nicht schnell genug abnehmen. Die konkreten Auswirkungen in meinem aktuellen DTA-Log:
• Regulärer Heizbetrieb (ohne Eingriff): Sehr ruhige, lange Verdichterläufe von 1 Std. 40 Min. bis knapp 5 Stunden bei ca. 30,4 °C Vorlauf und einer Arbeitszahl (AZ1/AZ2) von 3,88 bis 4,03.
• Mit aktiver Takt-Optimierung (+10 K / 35 °C): Die Vorlauftemperatur schoss sofort auf ca. 33,8 °C hoch (Spreizung bis zu 6,2 K). Da die Wärme bei den milden Außentemperaturen nicht abgenommen werden konnte, lief die Wärmepumpe vorzeitig in die Taktsperre (SSP), bevor die Warmwasserbereitung überhaupt startete.
• Ergebnis: Statt eines durchgehenden Taktes entstanden 7 kurze Fehlstarts in gut 2 Stunden (Laufzeiten von nur 5 bis 19 Minuten, unterbrochen durch Zwangspausen von 7 bis 16 Minuten), und die Arbeitszahl brach von ~4,0 auf 2,70 ein.
Konkreter Verbesserungsvorschlag für den Adapter:
Könnte man im Reiter „Takt-Optimierung“ anstelle des fest einprogrammierten Sprungs (+10 K / 35 °C) eine konfigurierbare, relative Anhebung (z. B. ein Eingabefeld „Rücklauf-Anhebung in K“ mit einem Einstellbereich von +2,0 K bis +10,0 K) einbauen?
Im SHI-Modus ließe sich dieser konfigurierte Wert direkt als flüchtiger Offset auf Register 10002 schreiben (z. B. +3,0 K statt pauschal +10,0 K). Damit würde der Verdichter sanft auf Betriebstemperatur gehalten, ohne den Heizkreis in der Übergangszeit thermisch zu überfahren – und die Takt-Kopplung wäre auch in Passiv- und Niedrigenergiehäusern ganzjährig nutzbar, ohne sie im Frühjahr/Herbst manuell deaktivieren zu müssen.
Viele Grüße
Jürgen -
@juergenh
Hallo Jürgen,vielen Dank für die geniale DTA-Auswertung – die Messwerte sprechen wirklich für sich! Mein Haus liegt mit 15,9 kWh/(m²·a) ebenfalls sehr nah am Passivhaus-Standard, daher ist dein Feedback für mich ein super Parallelvergleich :)
Deine Idee mit einer dynamischen bzw. konfigurierbaren Anhebung statt der starren 35 °C / +10 K ist richtig gut – da mache ich mir definitiv ein paar Gedanken zu einer sauberen Umsetzung. Eine dynamische Kopplung direkt an das aktuelle RL-Soll (also relativ in K statt fix 35 °C) schlägt sogar zwei Fliegen mit einer Klappe: In gut gedämmten Häusern überfährt man in der Übergangszeit den Estrich nicht mehr, und umgekehrt löst es das Problem bei weniger gut gedämmten Gebäuden oder Heizkörper-Anlagen, bei denen ein RL-Soll von 35 °C im Normalbetrieb eventuell ohnehin schon anliegt.
Mal eine Frage rein aus Interesse (für die meisten hier vermutlich leicht Offtopic 🙈):
Wie sieht deine Heizkurve aktuell aus? Meine liegt bei 21,7 °C Fußpunkt zu 23,0 °C Endpunkt – also extrem flach. Damit komme ich bei einer Mitteltemperatur unter 5 °C auf knapp 22–23 °C Raumtemperatur. In den Übergangsmonaten gebe ich dann einfach eine Parallelverschiebung von +1 K drauf.
Hast du bei dir noch Einzelraumthermostate verbaut oder sind alle Heizkreise komplett offen (so läuft es bei mir)?Kleiner Tipp am Rande (ich glaube, das Feature habe ich hier im Thread noch gar nicht richtig erwähnt): Im Adapter kannst du unter dem Reiter Vorgaben direkt prüfen, wie deine Heizkurve verläuft – das Diagramm dort wird gemäß deinen Vorgaben live und dynamisch dargestellt.
Viele Grüße
Tobi -
@juergenh
Viele Grüße
TobiHallo Tobi,
anbei meine Heizkurve. Sieht ziemlich gleich aus.
Meine Heizkurve ist nicht optimal , da unsere Zimmertemperatur aktuell noch zu hoch ist (24° bei 7°). Ich habe Einzelraumthermostate verbaut, welche aber bis aufs Schlafzimmer komplett offen sind. Dein neues Release ist installiert und bisher sind keine EEPROM Schreibzyklen erkennbar. Sieht sauber aus.
P.S. Habe gerade die Einstellung geändert. Jetzt muss ich mal 2 Tage warten.
Viele Grüße
Jürgen -
