  4. Proxmox-Updater (Host/LXC/VM) auch ioBroker,piHole,etc
138 Beiträge 16 Kommentatoren 22.7k Aufrufe 24 Beobachtet
  • NegaleinN Negalein
    @Bass-T
    ps aux | grep -E 'apt|apt-get|dpkg'
    root@proxmox2:~# ps aux | grep -E 'apt|apt-get|dpkg'
    root      436538  0.0  0.0   6528  2376 pts/0    S+   10:47   0:00 grep -E apt|apt-get|dpkg
    root     1448924  0.0  0.0   6652  3632 ?        S    Sep06   0:01 lxc-attach -n 108 --keep-env -- bash -c apt-get -o Dpkg::Options::=--force-confdef -o Dpkg::Options::=--force-confold dist-upgrade -y
    100000   1449016  0.1  0.9  90888 71624 ?        S    Sep06   1:49 apt-get -o Dpkg::Options::=--force-confdef -o Dpkg::Options::=--force-confold dist-upgrade -y
    100000   1455020  0.0  0.0  10612  5012 ?        Ss+  Sep06   0:00 /usr/bin/dpkg --force-confdef --force-confold --status-fd 24 --configure --pending
    100000   1457403  0.0  0.2  22936 17592 ?        S+   Sep06   0:00 /usr/bin/perl /usr/share/debconf/frontend /var/lib/dpkg/info/openssh-server.postinst configure 1:10.0p1-7
    100000   1457519  0.0  0.0   2680  1880 ?        S+   Sep06   0:00 /bin/sh /var/lib/dpkg/info/openssh-server.postinst configure 1:10.0p1-7
    ps -ef --forest | grep -A20 -B5 -E 'apt|apt-get|dpkg'
    root@proxmox2:~# ps -ef --forest | grep -A20 -B5 -E 'apt|apt-get|dpkg'
    root         930       1  0 Aug25 ?        00:00:00 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
    root      414595     930  0 10:42 ?        00:00:00  \_ sshd-session: root [priv]
    root      414633  414595  0 10:42 ?        00:00:00  |   \_ sshd-session: root@pts/0
    root      414636  414633  0 10:42 pts/0    00:00:00  |       \_ -bash
    root      440215  414636  0 10:48 pts/0    00:00:00  |           \_ ps -ef --forest
    root      440216  414636  0 10:48 pts/0    00:00:00  |           \_ grep -A20 -B5 -E apt|apt-get|dpkg
    root      414600     930  0 10:42 ?        00:00:00  \_ sshd-session: root [priv]
    root      414635  414600  0 10:42 ?        00:00:00      \_ sshd-session: root@notty
    root      414637  414635  0 10:42 ?        00:00:00          \_ /usr/lib/openssh/sftp-server
    root         941       1  0 Aug25 tty1     00:00:00 /sbin/agetty -o -- \u --noreset --noclear - linux
    root        1075       1  0 Aug25 ?        00:00:03 /usr/sbin/cron -f
    root        1076       1  0 Aug25 ?        00:03:26 /usr/libexec/proxmox/proxmox-firewall start
    root        1097       1  0 Aug25 ?        01:46:56 pve-firewall
    root        1104       1  2 Aug25 ?        06:17:25 pvestatd
    root        1128       1  0 Aug25 ?        00:00:34 pvedaemon
    root     3834705    1128  0 05:37 ?        00:00:33  \_ pvedaemon worker
    root     3854893    1128  0 06:37 ?        00:00:31  \_ pvedaemon worker
    root        4479    1128  0 08:59 ?        00:00:11  \_ pvedaemon worker
    www-data    1141       1  0 Aug25 ?        00:01:05 pveproxy
    www-data  161013    1141  0 09:38 ?        00:00:04  \_ pveproxy worker
    www-data  173411    1141  0 09:42 ?        00:00:04  \_ pveproxy worker
    www-data  197959    1141  0 09:48 ?        00:00:03  \_ pveproxy worker
    www-data    1152       1  0 Aug25 ?        00:00:40 spiceproxy
    www-data 3433683    1152  0 00:04 ?        00:00:02  \_ spiceproxy worker
    root        1178       1  0 Aug25 ?        00:02:32 /usr/bin/lxc-start -F -n 108
    100000      1248    1178  0 Aug25 ?        00:04:47  \_ /usr/lib/systemd/systemd --system --deserialize=34
    root     1392096       1  0 Sep06 ?        00:02:44 /usr/bin/python3 /etc/ultimate-updater/web-ui/server.py --bind 0.0.0.0 --port 8765
    root     1408660       1  0 Sep06 ?        00:00:00 /bin/bash /etc/ultimate-updater/job-runner.sh run-global ultimate-updater-update-all-systems-20260906-153017-380501623-1408489 /etc/ultimate-updater/global-update.sh
    root     1408698 1408660  0 Sep06 ?        00:00:00  \_ /bin/bash /etc/ultimate-updater/global-update.sh
    root     1408709 1408698  0 Sep06 ?        00:00:00      \_ /bin/bash /etc/ultimate-updater/update.sh
    root     1408811 1408709  0 Sep06 ?        00:00:00          \_ tee /var/log/ultimate-updater.log
    root     1448924 1408709  0 Sep06 ?        00:00:01          \_ lxc-attach -n 108 --keep-env -- bash -c apt-get -o Dpkg::Options::=--force-confdef -o Dpkg::Options::=--force-confold dist-upgrade -y
    100000   1449016 1448924  0 Sep06 ?        00:01:49              \_ apt-get -o Dpkg::Options::=--force-confdef -o Dpkg::Options::=--force-confold dist-upgrade -y
    100000   1455020 1449016  0 Sep06 ?        00:00:00                  \_ /usr/bin/dpkg --force-confdef --force-confold --status-fd 24 --configure --pending
    100000   1457403 1455020  0 Sep06 ?        00:00:00                      \_ /usr/bin/perl /usr/share/debconf/frontend /var/lib/dpkg/info/openssh-server.postinst configure 1:10.0p1-7
    100000   1457519 1457403  0 Sep06 ?        00:00:00                          \_ /bin/sh /var/lib/dpkg/info/openssh-server.postinst configure 1:10.0p1-7
    100000   1457533 1457519  0 Sep06 ?        00:00:00                          |   \_ /bin/sh /usr/bin/ucf --three-way --debconf-ok --sum-file /usr/share/openssh/sshd_config.md5sum /tmp/tmp.wUhDAEjyQn /etc/ssh/sshd_config
    100000   1457635 1457403  0 Sep06 ?        00:00:00                          \_ whiptail --backtitle Package configuration --title Configuring openssh-server --output-fd 11 --nocancel --default-item keep the local version currently installed --menu A new version (/tmp/tmp.wUhDAEjyQn) of configuration file  /etc/ssh/sshd_config is available, but the version installed currently  has been locally modified.  What do you want to do about modified configuration file sshd_config? 19 76 7 -- install the package maintainer's version  keep the local version currently installed  show the differences between the versions  show a side-by-side difference between the versions  show a 3-way difference between available versions  do a 3-way merge between available versions  start a new shell to examine the situation
    _chrony  1429618       1  0 Sep06 ?        00:00:00 /usr/sbin/chronyd -n -F 1
    _chrony  1429623 1429618  0 Sep06 ?        00:00:00  \_ /usr/sbin/chronyd -n -F 1
    root     1431494       1  0 Sep06 ?        00:00:00 /usr/sbin/zed -F
    root     1432298       1  0 Sep06 ?        00:01:39 /usr/bin/pmxcfs
    root     1433736       1  0 Sep06 ?        00:00:00 /usr/sbin/qmeventd /var/run/qmeventd.sock
    root     1441793       1  0 Sep06 ?        00:00:00 /usr/sbin/rsyslogd -n -iNONE
    root     1441927       1  0 Sep06 ?        00:00:00 /usr/lib/postfix/sbin/master -w
    postfix  1441929 1441927  0 Sep06 ?        00:00:00  \_ qmgr -l -t unix -u
    postfix   299199 1441927  0 10:13 ?        00:00:00  \_ pickup -l -t unix -u -c
    root     1442345       1  0 Sep06 ?        00:00:16 pve-ha-lrm
    root     1442740       1  0 Sep06 ?        00:00:10 pve-ha-crm
    root     3433677       1  0 00:04 ?        00:00:10 /usr/sbin/pvefw-logger
    root      414602       1  0 10:42 ?        00:00:00 /usr/lib/systemd/systemd --user
    root      414604  414602  0 10:42 ?        00:00:00  \_ (sd-pam)
    dpkg --audit
    root@proxmox2:~# dpkg --audit
    root@proxmox2:~#
    systemctl list-units --type=service | grep ultimate-updater
    root@proxmox2:~# systemctl list-units --type=service | grep ultimate-updater
    ● ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service loaded activating start   start Ultimate Updater update for all systems
      ultimate-updater-web.service                                                  loaded active     running       Ultimate Updater web UI
    Bass-TB
    Bass-TB
    Bass-T
    #85
    @Negalein danke, damit ist jetzt ziemlich eindeutig zu sehen, wo der Job hängt. 👍
    Der Proxmox-Host selbst hängt nicht in apt/dpkg.
    Der Updatejob befindet sich aktuell in LXC 108 und wartet dort auf eine interaktive Frage von openssh-server:
    apt-get
    └─ dpkg
       └─ openssh-server.postinst
          └─ ucf
             └─ whiptail
    Konkret wartet dieser Dialog auf eine Entscheidung zu:
    Die Auswahl ist momentan sogar bereits auf
    voreingestellt.
    Das bestätigt genau die inzwischen gefundene Lücke:
    Der Ultimate-Updater-Job läuft korrekt serverseitig weiter, kann die interaktive whiptail-Abfrage derzeit aber noch nicht zurück an die WebUI/CLI geben.
    Bitte weiterhin nicht rebooten und auch nicht die komplette Ultimate-Updater-Service-Unit abschießen.
    Dein dpkg --audit war übrigens auf dem Proxmox-Host. Relevant ist jetzt CT 108.
    Bitte zunächst einmal prüfen:
    pct exec 108 -- dpkg --audit
    und:
    pct exec 108 -- ps -ef | grep -E 'apt|apt-get|dpkg|ucf|whiptail'
    Wenn dort weiterhin der whiptail-Prozess wartet, würde ich diesen einzelnen Dialog kontrolliert beenden und nicht apt oder dpkg selbst killen.
    Auf deinem bisherigen Prozessbaum wäre das PID 1457635, bitte die aktuelle PID vorher nochmals prüfen:
    pgrep -a whiptail
    Dann nur diesen Prozess mit TERM beenden:
    kill -TERM <WHIPTAIL-PID>
    Danach bitte kurz warten und kontrollieren:
    ps aux | grep -E 'apt|apt-get|dpkg|ucf|whiptail'
    Sobald die laufende apt/dpkg-Kette beendet ist, direkt interaktiv in den Container:
    pct enter 108
    Dort:
    dpkg --audit
    und anschließend:
    dpkg --configure -a
    Jetzt läuft die Paketkonfiguration in einem echten Terminal und die Frage zu sshd_config sollte sichtbar und beantwortbar sein.
    In deinem Fall würde ich bei einer bewusst angepassten SSH-Konfiguration in der Regel:
    wählen.
    Danach nochmals:
    dpkg --audit
    Wenn das ohne Ausgabe zurückkommt, ist der dpkg-Zustand wieder sauber.
    Bitte poste danach noch kurz die Ausgabe bzw. ob dpkg --configure -a sauber durchgelaufen ist.
    Der Fall ist für die Weiterentwicklung übrigens sehr hilfreich: Wir haben inzwischen auf dem Testcluster bereits erfolgreich nachgewiesen, dass sich genau solche Paketdialoge über einen persistenten PTY-/Reconnect-Kanal lösen lassen. Das wird jetzt sauber in den Ultimate Updater integriert.
    Proxmox Cluster
    • NUC7i5 ioBroker Server (Proxmox)
    • HP Elitedesk 800 G4 SSF (Proxmox)
    • HP Elitedesk 800 G2 DM (Proxmox)
      mein Proxmox-Updater für euch
    KNX / Broadlink / Tasmota ESPs / Zigbee
    Vis: 15" Touchmonitor mit Raspi4 / 10" Tablet (Dauerstrom umbau) / Sonoff NSPanel (alle)
    NegaleinN 2 Antworten Letzte Antwort
    • Bass-TB Bass-T
      apt-get
      └─ dpkg
            └─ ucf
               └─ whiptail
      voreingestellt.
      und:
      pgrep -a whiptail
      pct enter 108
      Dort:
      dpkg --audit
      und anschließend:
      dpkg --configure -a
      wählen.
      Danach nochmals:
      dpkg --audit
      NegaleinN
      NegaleinN
      Negalein
      #86
      @Bass-T
      root@proxmox2:~# pct exec 108 -- dpkg --audit
      Another process has locked the database for writing, and might currently be
      modifying it, some of the following problems might just be due to that.
      The following packages have been unpacked but not yet configured.
      They must be configured using dpkg --configure or the configure
      menu option in dselect for them to work:
       bind9-dnsutils       Clients provided with BIND 9
       python3.13-dev       Header files and a static library for Python (v3.13)
       ssh                  secure shell client and server (metapackage)
      The following packages are only half configured, probably due to problems
      configuring them the first time.  The configuration should be retried using
      dpkg --configure <package> or the configure menu option in dselect:
       openssh-server       secure shell (SSH) server, for secure access from remote
      The following packages have been triggered, but the trigger processing
      has not yet been done.  Trigger processing can be requested using
      dselect or dpkg --configure --pending (or dpkg --triggers-only):
       dbus                 simple interprocess messaging system (system message bus)
       debianutils          Miscellaneous utilities specific to Debian
       libc-bin             GNU C Library: Binaries
       mailcap              Debian's mailcap system, and support programs
       man-db               tools for reading manual pages
       postfix              High-performance mail transport agent
       procps               /proc file system utilities
       shared-mime-info     FreeDesktop.org shared MIME database and spec
      root@proxmox2:~# pct exec 108 -- ps -ef | grep -E 'apt|apt-get|dpkg|ucf|whiptail'
      root      157822       0  0 Sep06 ?        00:01:52 apt-get -o Dpkg::Options::=--force-confdef -o Dpkg::Options::=--force-confold dist-upgrade -y
      root      160812  157822  0 Sep06 pts/3    00:00:00 /usr/bin/dpkg --force-confdef --force-confold --status-fd 24 --configure --pending
      root      161796  160812  0 Sep06 pts/3    00:00:00 /usr/bin/perl /usr/share/debconf/frontend /var/lib/dpkg/info/openssh-server.postinst configure 1:10.0p1-7
      root      161809  161796  0 Sep06 pts/3    00:00:00 /bin/sh /var/lib/dpkg/info/openssh-server.postinst configure 1:10.0p1-7
      root      161814  161809  0 Sep06 pts/3    00:00:00 /bin/sh /usr/bin/ucf --three-way --debconf-ok --sum-file /usr/share/openssh/sshd_config.md5sum /tmp/tmp.wUhDAEjyQn /etc/ssh/sshd_config
      root      161852  161796  0 Sep06 pts/3    00:00:00 whiptail --backtitle Package configuration --title Configuring openssh-server --output-fd 11 --nocancel --default-item keep the local version currently installed --menu A new version (/tmp/tmp.wUhDAEjyQn) of configuration file  /etc/ssh/sshd_config is available, but the version installed currently  has been locally modified.  What do you want to do about modified configuration file sshd_config? 19 76 7 -- install the package maintainer's version  keep the local version currently installed  show the differences between the versions  show a side-by-side difference between the versions  show a 3-way difference between available versions  do a 3-way merge between available versions  start a new shell to examine the situation
      pgrep -a whiptail
      root@proxmox2:~# pgrep -a whiptail
      1457635 whiptail --backtitle Package configuration --title Configuring openssh-server --output-fd 11 --nocancel --default-item keep the local version currently installed --menu A new version (/tmp/tmp.wUhDAEjyQn) of configuration file  /etc/ssh/sshd_config is available, but the version installed currently  has been locally modified.  What do you want to do about modified configuration file sshd_config? 19 76 7 -- install the package maintainer's version  keep the local version currently installed  show the differences between the versions  show a side-by-side difference between the versions  show a 3-way difference between available versions  do a 3-way merge between available versions  start a new shell to examine the situation
      kill -TERM 1457635
      root@proxmox2:~# kill -TERM 1457635
      root@proxmox2:~#
      root@proxmox2:~# ps aux | grep -E 'apt|apt-get|dpkg|ucf|whiptail'
      100000    570046  0.3  0.1  17788 14536 ?        S    11:20   0:00 bash -c #!/usr/bin/env bash _CS_DEFAULT_URL="https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main" _cs_boot="${COMMUNITY_SCRIPTS_CORE_DIR:-$(dirname "${BASH_SOURCE[0]}")/../../core}/core/build.func" source "$_cs_boot" 2>/dev/null || source <(curl -fsSL "${COMMUNITY_SCRIPTS_CORE_URL:-https://raw.githubusercontent.com/community-scripts/core/main}/core/build.func") # Copyright (c) 2021-2026 tteck # Author: tteck (tteckster) # License: MIT | https://github.com/community-scripts/ProxmoxVE/raw/main/LICENSE # Source: https://www.home-assistant.io/  APP="Home Assistant" var_tags="${var_tags:-automation;smarthome;docker}" var_cpu="${var_cpu:-2}" var_ram="${var_ram:-2048}" var_disk="${var_disk:-16}" var_os="${var_os:-debian}" var_version="${var_version:-13}" var_arm64="${var_arm64:-yes}" var_unprivileged="${var_unprivileged:-1}"  header_info "$APP" variables color catch_errors  function update_script() {   header_info   check_container_storage   check_container_resources   if [[ ! -d /var/lib/docker/volumes/hass_config/_data ]]; then     msg_error "No ${APP} Installation Found!"     exit   fi   UPD=$(msg_menu "Home Assistant Update Options" \     "1" "Update ALL Containers" \     "2" "Remove ALL Unused Images" \     "3" "Install HACS" \     "4" "Install FileBrowser")    if [ "$UPD" == "1" ]; then     msg_info "Updating All Containers"     CONTAINER_LIST="${1:-$(docker ps -q)}"     for container in ${CONTAINER_LIST}; do       CONTAINER_IMAGE="$(docker inspect --format "{{.Config.Image}}" --type container "${container}")"       RUNNING_IMAGE="$(docker inspect --format "{{.Image}}" --type container "${container}")"       docker pull "${CONTAINER_IMAGE}"       LATEST_IMAGE="$(docker inspect --format "{{.Id}}" --type image "${CONTAINER_IMAGE}")"       if [[ "${RUNNING_IMAGE}" != "${LATEST_IMAGE}" ]]; then         pip install -U runlike         echo "Updating ${container} image ${CONTAINER_IMAGE}"         DOCKER_COMMAND="$(runlike --use-volume-id "${container}")"         docker rm --force "${container}"         eval "${DOCKER_COMMAND}"       fi     done     msg_ok "Updated All Containers"     exit   fi   if [ "$UPD" == "2" ]; then     msg_info "Removing ALL Unused Images"     docker image prune -af     msg_ok "Removed ALL Unused Images"     exit   fi   if [ "$UPD" == "3" ]; then     msg_info "Installing Home Assistant Community Store (HACS)"     $STD apt update     cd /var/lib/docker/volumes/hass_config/_data     $STD bash <(curl -fsSL https://get.hacs.xyz)     msg_ok "Installed Home Assistant Community Store (HACS)"     echo -e "\n Reboot Home Assistant and clear browser cache then Add HACS integration.\n"     exit   fi   if [ "$UPD" == "4" ]; then     msg_info "Installing FileBrowser"     RELEASE=$(curl -fsSL https://api.github.com/repos/filebrowser/filebrowser/releases/latest | grep -o '"tag_name": ".*"' | sed 's/"//g' | sed 's/tag_name: //g')     $STD curl -fsSL https://github.com/filebrowser/filebrowser/releases/download/v2.23.0/linux-$(arch_resolve)-filebrowser.tar.gz | tar -xzv -C /usr/local/bin     $STD filebrowser config init -a '0.0.0.0'     $STD filebrowser config set -a '0.0.0.0'     $STD filebrowser users add admin community-scripts.org --perm.admin     msg_ok "Installed FileBrowser"      msg_info "Creating Service"     service_path="/etc/systemd/system/filebrowser.service"     echo "[Unit] Description=Filebrowser After=network-online.target [Service] User=root WorkingDirectory=/root/ ExecStart=/usr/local/bin/filebrowser -r / [Install] WantedBy=default.target" >$service_path      $STD systemctl enable --now filebrowser     msg_ok "Created Service"      msg_ok "Completed successfully!\n"     echo -e "FileBrowser should be reachable by going to the following URL.          ${BL}http://$LOCAL_IP:8080${CL}   admin|community-scripts.org\n"     exit   fi }  start build_container description  msg_ok "Completed successfully!\n" echo -e "${CREATING}${GN}${APP} setup has been successfully initialized!${CL}" echo -e "${INFO}${YW}Access it using the following URL:${CL}" echo -e "${GATEWAY}${BGN}HA: http://${IP}:8123${CL}" echo -e "${GATEWAY}${BGN}Portainer: https://${IP}:9443${CL}"
      root      574939  0.0  0.0   6660  2352 pts/0    S+   11:21   0:00 grep -E apt|apt-get|dpkg|ucf|whiptail
      jetzt hier weiter?
      Copy to Clipboard
      pct enter 108
      Dort:
      Copy to Clipboard
      dpkg --audit
      und anschließend:
      Copy to Clipboard
      dpkg --configure -a
      ° Fixer ---> iob fix
      Bass-TB 1 Antwort Letzte Antwort
        @Bass-T
        pgrep -a whiptail
        kill -TERM 1457635
        root@proxmox2:~#
        jetzt hier weiter?
        Copy to Clipboard
        pct enter 108
        Dort:
        Copy to Clipboard
        dpkg --audit
        und anschließend:
        Copy to Clipboard
        dpkg --configure -a
        Bass-TB
        Bass-TB
        Bass-T
        #87
        @Negalein ja, grundsätzlich wäre dpkg --configure -a der nächste Reparaturschritt – aber bitte noch einen Moment warten und nicht direkt ausführen. 👍
        Das Beenden von whiptail hat funktioniert:
        Die vorher festhängende Kette
        apt-get
        → dpkg
        → openssh-server.postinst
        → ucf
        → whiptail
        ist jetzt nicht mehr in der Prozessliste.
        Allerdings sieht man inzwischen einen neuen Community-Scripts-Prozess. Das heißt sehr wahrscheinlich, dass der globale Ultimate-Updater-Job nach dem abgebrochenen Paketdialog bereits weitergelaufen ist.
        Bevor wir jetzt manuell dpkg --configure -a in CT 108 starten, müssen wir deshalb kurz sicherstellen, dass dort nicht erneut bzw. parallel etwas arbeitet.
        Bitte einmal:
        und:
        Zusätzlich bitte den aktuellen Ultimate-Updater-Status:
        ultimate-updater status
        und den aktuellen Stand des laufenden Jobs:
        systemctl status ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service --no-pager
        sowie die letzten Zeilen:
        journalctl -u ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service -n 80 --no-pager
        Wenn in CT 108 kein apt/dpkg mehr läuft, können wir anschließend dort sauber interaktiv fortsetzen mit:
        pct enter 108
        und dann:
        dpkg --configure -a
        Bei der Frage zu /etc/ssh/sshd_config würde ich bei einer bewusst angepassten SSH-Konfiguration weiterhin
        wählen.
        Aber erst die obigen Ausgaben – ich möchte vermeiden, dass wir jetzt einen zweiten dpkg starten, während der Ultimate Updater noch irgendwo im selben Container arbeitet.
        Proxmox Cluster
        • Bass-TB Bass-T
          apt-get
          └─ dpkg
                └─ ucf
                   └─ whiptail
          voreingestellt.
          und:
          pgrep -a whiptail
          pct enter 108
          Dort:
          dpkg --audit
          und anschließend:
          dpkg --configure -a
          wählen.
          Danach nochmals:
          dpkg --audit
          NegaleinN
          NegaleinN
          Negalein
          #88
          @Bass-T sagte:
          hmmm, wüsste nicht, dass ich da jemals was angepasst hätte
          im Config vom Updater?
          • Bass-TB Bass-T
            apt-get
            → dpkg
            → ucf
            → whiptail
            Bitte einmal:
            und:
            pct enter 108
            und dann:
            dpkg --configure -a
            wählen.
            NegaleinN
            NegaleinN
            Negalein
            #89
            @Bass-T
            root@proxmox2:~#
            root@proxmox2:~#
            root@proxmox2:~# ultimate-updater status
            Status schema 1
            Generated: 2026-09-07T09:23:33Z
            Target / friendly name   Reachable Updates Status         Last check
            proxmox2                 yes       130     updates_ava... 2026-09-06T15:29:41Z
            108 · spoolman           yes       106     updates_ava... 2026-09-06T15:29:41Z
            109 · homeassistant      yes       73      updates_ava... 2026-09-06T15:29:41Z
            110 · agentdvr           yes       96      updates_ava... 2026-09-06T15:29:41Z
            Jobs
            Type     Target / friendly name         State          Exit
            JOB      all-systems                    completed      0
            CHECK    all-systems                    completed      0
            UPDATE   all-systems                    completed      0
            JOB      selfupdate                     completed      0
            root@proxmox2:~# systemctl status ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service --no-pager
            Unit ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service could not be found.
            Sep 07 11:30:52 proxmox2 systemd[1]: ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: Failed to open /run/systemd/transient/ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: No such file or directory
            Sep 07 11:31:03 proxmox2 systemd[1]: ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: Failed to open /run/systemd/transient/ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: No such file or directory
            Sep 07 11:31:14 proxmox2 systemd[1]: ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: Failed to open /run/systemd/transient/ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: No such file or directory
            Sep 07 11:31:25 proxmox2 systemd[1]: ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: Failed to open /run/systemd/transient/ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: No such file or directory
            Sep 07 11:31:33 proxmox2 systemd[1]: ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: Failed to open /run/systemd/transient/ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: No such file or directory
            Sep 07 11:31:36 proxmox2 systemd[1]: ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: Failed to open /run/systemd/transient/ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: No such file or directory
            Sep 07 11:31:47 proxmox2 systemd[1]: ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: Failed to open /run/systemd/transient/ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: No such file or directory
            Sep 07 11:31:58 proxmox2 systemd[1]: ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: Failed to open /run/systemd/transient/ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: No such file or directory
            Sep 07 11:32:09 proxmox2 systemd[1]: ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: Failed to open /run/systemd/transient/ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: No such file or directory
            Sep 07 11:32:20 proxmox2 systemd[1]: ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: Failed to open /run/systemd/transient/ultimate-updater-update-all-systems-20260906-153017-380501623-1408489.service: No such file or directory
            root@proxmox
              @Bass-T
              root@proxmox2:~#
              root@proxmox2:~#
              Status schema 1
              Jobs
              root@proxmox
              Bass-TB
              Bass-TB
              Bass-T
              #90
              @Negalein perfekt – jetzt sieht alles wieder sauber aus. 👍
              Du musst nicht mehr mit pct enter 108 und dpkg --configure -a weitermachen.
              Die wichtigen Punkte sind:
              pct exec 108 -- ps ...
              liefert keinen laufenden apt-/dpkg-/ucf-/whiptail-Prozess mehr.
              Und:
              liefert ebenfalls keine Ausgabe.
              Damit ist der Paketstatus in CT 108 wieder sauber. ✅
              Auch der Ultimate Updater selbst hat den Lauf inzwischen beendet:
              Der Job ist also nicht mehr aktiv und hat Exitcode 0.
              Dass
              Unit ultimate-updater-update-all-systems-....service could not be found
              kommt, ist an dieser Stelle ebenfalls normal:
              Ultimate Updater verwendet dafür eine transiente systemd-Unit. Sobald der Job beendet und aufgeräumt wurde, existiert diese Unit unter /run/systemd/transient/ nicht mehr.
              Die nachfolgenden Meldungen im Journal
              Failed to open /run/systemd/transient/...
              entstehen nur dadurch, dass nachträglich nach dieser bereits entfernten Unit gefragt wurde. Das ist jetzt kein weiterer Fehler des Updates.
              Was jetzt noch sinnvoll ist
              Die Updatezahlen in
              stammen noch vom vorherigen Check:
              Last check: 2026-09-06T15:29:41Z
              Deshalb würde ich jetzt einfach nochmal einen normalen Check aller Systeme über die WebUI starten.
              Noch kein weiteres Update, nur Check.
              Dann sollten die Updatezahlen und Statuswerte wieder auf dem aktuellen Stand sein.
              Der Fall war übrigens sehr hilfreich. 🙂
              Damit ist jetzt eindeutig bestätigt, dass der lange Lauf durch den interaktiven openssh-server-/sshd_config-Dialog in LXC 108 verursacht wurde und nicht durch einen Defekt der Jobverwaltung.
              Genau diese Lücke – interaktive Paketabfragen bei serverseitig weiterlaufenden Jobs – wird gerade auf develop bearbeitet.
              Auf dem Testcluster konnte bereits erfolgreich nachgewiesen werden, dass ein solcher dpkg-/whiptail-Prompt auch nach Disconnect über einen persistenten PTY-Kanal wieder verbunden und beantwortet werden kann.
              Danke fürs Durchhalten und für die ganzen Ausgaben. 👍
              Proxmox Cluster
              • Bass-TB Bass-T
                Und:
                Dass
                Die Updatezahlen in
                NegaleinN
                NegaleinN
                Negalein
                #91
                @Bass-T
                gerne! nur gemeinsam kommt man ans Ziel :)
                den Host kann ich jetzt rebooten?
                  @Bass-T
                  Bass-TB
                  Bass-TB
                  Bass-T
                  #92
                  @Negalein jetzt spricht aus Sicht des Ultimate Updaters nichts mehr gegen einen Reboot. 👍
                  Der problematische Paketlauf ist beendet:
                  • kein apt/dpkg mehr aktiv
                  • dpkg --audit sauber
                  • Ultimate-Updater-Job completed 0
                  • abschließender Check ebenfalls erfolgreich
                  Damit besteht keine Gefahr mehr, dass du durch den Reboot einen laufenden Paketmanager abschießt.
                  Die pveproxy-/pve-ssl.key-Meldungen sind ein separates Proxmox-Thema. Bevor du rebootest, würde ich deshalb nur noch kurz prüfen:
                  systemctl --failed
                  und:
                  systemctl is-active pveproxy pvedaemon pvestatd
                  Falls der Host Teil eines Clusters ist zusätzlich:
                  pvecm status
                  Wenn da nichts Kritisches auffällt, kannst du den Host rebooten.
                  Vielen Dank nochmal - gefällt mir deine Einstellung 😎
                  Proxmox Cluster
                  • Bass-TB Bass-T
                    systemctl --failed
                    und:
                    pvecm status
                    NegaleinN
                    NegaleinN
                    Negalein
                    #93
                    @Bass-T
                    systemctl --failed
                    root@proxmox2:~# systemctl --failed
                    0 loaded units listed.
                    root@proxmox2:~# systemctl is-active pveproxy pvedaemon pvestatd
                    active
                    active
                    active
                    schaut alles gut aus.
                    Dann reboote ich mal.
                    • T
                      T
                      TT-Tom
                      #94
                      @bass-t
                      das gleiche Problem habe ich auch mit meinem MySql-Server gehabt. Dort wurde auch bei
                      dist-upgrade ein Auswahlfenster geöffnet. Habe das Ganze dann genau abgeschlossen, wie du es hier beschrieben hast. Habe den LXC erstmal ausgeklammert.
                      Gruß Tom
                      Public Transport
                      NSPanel Adapter Dokumentation
                      https://ticaki.github.io/ioBroker.nspanel-lovelace-ui/
                      • T TT-Tom
                        @bass-t
                        Bass-TB
                        Bass-TB
                        Bass-T
                        #95
                        @TT-Tom ja, genau derselbe Grund.
                        Das Problem ist inzwischen eindeutig identifiziert und der technische Fix ist auf develop bereits weitgehend umgesetzt.
                        Interaktive Paketdialoge laufen jetzt über einen persistenten PTY-Kanal, sodass sich der Benutzer nach einem Disconnect wieder an den laufenden Job hängen und die Abfrage beantworten kann.
                        Der CLI-Teil funktioniert bereits:
                        ultimate-updater job attach <JOB_ID>
                        Damit wurden auf dem Testcluster echte dpkg-/whiptail-Prompts inklusive Disconnect/Reconnect erfolgreich getestet.
                        Was aktuell noch fehlt, ist die direkte Eingabe über die WebUI. Das ist der nächste Schritt.
                        Für v5.1.2 bleibt dein Workaround daher momentan sinnvoll:
                        den betroffenen LXC entweder vorübergehend ausklammern oder bei einem interaktiven Prompt wie beschrieben manuell sauber zu Ende konfigurieren.
                        Der vollständige Fix wird dann mit einem kommenden Release aus develop übernommen.
                        Proxmox Cluster
                        • NegaleinN
                          NegaleinN
                          Negalein
                          #96
                          @bass-t
                          wie verhält es sich, wenn der Host noch auf 7.4-20 ist?
                          Vorher selber auf 9.x updaten?
                          Oder schafft das der Updater?
                          • Bass-TB
                            Bass-TB
                            Bass-T
                            schrieb am zuletzt editiert von Bass-T
                            #97
                            @negalein es könnte funktionieren, ich habe es aber nie produktiv gestestet.
                            Lediglich von 8 auf 9. Dass hatte funktioniert.
                            Persöhnlich würde ich einen sprung von 2 Maintain Versionen glaub nicht automatisiert laufen lassen - persönliche einschätzung.
                            Natürlich zum Updaten innerhalb der Version - sollte kein Thema sein und wunderprächtig funktionieren
                            Ich muss mich revidieren. Ein Versionssprung macht mein Updater NICHT - sry
                            Proxmox Cluster
                            • David G.D
                              David G.D
                              David G.
                              #98
                              Hey,
                              ich hatte @Nagelein ja gefragt wo die Daten aus seiner mal her sind - leider automatisch aus dem Script.
                              Ich habe mit gestern mit Claude ein Script geschrieben, was mir alles in den iobroker holt.
                              Status & Datenpunkte
                              • Kompletter Status aller Targets (Host, VMs, CTs) als Datenpunkte, automatisch je
                                Ziel angelegt (inkl. Betriebssystem, erreichbar/offline, Anzahl offener Updates,
                                Security- vs. normale Updates, Reboot-noetig-Flag, letzter Check/Update, u.v.m.)
                              • Health-Zusammenfassung auf einen Blick: Summe offener Security-/Normal-Updates,
                                Liste der Targets mit offenen Updates, nicht erreichbare Targets, Targets mit
                                ausstehendem Reboot
                              • Job-Historie (laufende & vergangene Check-/Update-Jobs je Target) inkl.
                                automatischem Nachladen der Logzeilen bei fehlgeschlagenen/abgebrochenen Jobs
                              • Live-Indikator "laeuft gerade ein Job" mit adaptivem Poll-Takt (schnell waehrend
                                etwas laeuft, langsam wenn nichts ansteht - erkennt auch kurze Jobs von nur
                                wenigen Sekunden zuverlaessig)
                              • Automatisches Aufraeumen: nicht mehr existierende Targets verschwinden auch aus
                                ioBroker wieder
                              Aktionen per Knopfdruck (aus ioBroker/VIS)
                              • Update einzeln je Host/VM/CT
                              • Update Sammel-Button: alle VMs/CTs auf einmal (Host bewusst ausgenommen)
                              • Update Sammel-Button: nur Targets mit Security-relevanten Updates
                              • Check einzeln je Host/VM/CT (nur Status aktualisieren, kein Update)
                              • Check Sammel-Button: alle sofort auf einmal (schnell, kurzzeitig hoehere Last)
                              • Schutz gegen Doppelausloesung: neue Aktion wird blockiert, solange bereits ein
                                Job laeuft
                              Automatisierung
                              • Stuendlicher voller Status-Refresh
                              • Naechtlicher gestaffelter Check aller Targets: geht nacheinander mit mehreren
                                Minuten Abstand durch (statt alle gleichzeitig) - schont Host und Netzwerk
                              • Alle Zeiten/Intervalle zentral als Variablen im Skriptkopf einstellbar
                              Sicherheit
                              • Zugangsdaten nur lokal im Skript, Session-Cookie + CSRF-Token werden bei jedem
                                Login frisch geholt und nicht dauerhaft gespeichert
                              // ioBroker JavaScript-Adapter Script
                              // Liest den Status aller Proxmox-Hosts/VMs/CTs aus der "Ultimate Updater"-Web-API
                              // (https://github.com/BassT23/Proxmox) und legt fuer jedes Target alle verfuegbaren
                              // Felder als Datenpunkte an. Zusaetzlich Buttons zum Aktualisieren - einzeln pro
                              // VM/CT, einzeln fuer den Host, und ein Sammel-Button fuer alle VMs/CTs (ohne Host).
                              // Aktualisiert sich automatisch stuendlich.
                              // WICHTIG: Benutzername/Passwort direkt hier im Script-Editor eintragen - NICHT in
                              // einem Chat/einer KI-Anfrage teilen. Die Web-API nutzt Session-Cookie + CSRF-Token,
                              // beides wird bei jedem Login frisch geholt und nicht dauerhaft gespeichert.
                              const UU_BASE = "https://192.168.99.58:8765";
                              const UU_USERNAME = "root";
                              const UU_PASSWORD = "xxxxxxxx";
                              const ROOT = "0_userdata.0.proxmoxUpdater";
                              // ---- Alle Zeit-/Intervall-Einstellungen zentral an einem Ort ----
                              const REFRESH_CRON = "0 * * * *"; // voller Status-Refresh (alle Targets, Cleanup, Zusammenfassung, ...)
                              const POLL_INTERVAL_BUSY_MS = 2000; // Job-Status-Poll-Takt, solange ein Check/Update-Job laeuft
                              const POLL_INTERVAL_IDLE_MS = 30000; // Job-Status-Poll-Takt, wenn nichts laeuft
                              const STAGGERED_CHECK_CRON = "0 4 * * *"; // Start des naechtlichen gestaffelten Checks aller Targets
                              const STAGGERED_CHECK_DELAY_MINUTES = 3; // Abstand zwischen den einzelnen Targets beim gestaffelten Check
                              const STAGGERED_CHECK_DELAY_MS = STAGGERED_CHECK_DELAY_MINUTES * 60 * 1000;
                              function sanitize(s) {
                                  return String(s).replace(/[^a-zA-Z0-9_]/g, "_");
                              // Reiner Name reicht nicht als Ordner-Key - mehrere Targets koennen denselben Namen
                              // tragen (z.B. mehrere CTs heissen "AgentDVR"), dann wuerden sie sich sonst beim
                              // Anlegen der Datenpunkte gegenseitig ueberschreiben. Die ID ist dagegen garantiert
                              // eindeutig, wird also immer mit angehaengt; der Name bleibt trotzdem lesbar im Key
                              // und zusaetzlich als common.name des Channels sichtbar.
                              function targetKey(t) {
                                  return `${sanitize(t.name || t.id)}_${sanitize(t.id)}`;
                              function createChannelP(id, name) {
                                  return setObjectAsync(id, { type: "channel", common: { name }, native: {} });
                              // read-only per Default (reine Anzeigewerte); Buttons ueberschreiben write:true selbst.
                              function createStateP(id, common, val) {
                                  return createStateAsync(id, val, { read: true, write: false, ...common });
                              // httpGetAsync/httpPostAsync liefern per Default responseType "text", nicht "json"
                              // (siehe getHttpRequestConfig in ioBroker.javascript) - ohne explizites responseType:"json"
                              // kommt ein roher String zurueck und z.B. "status.targets" ist dann still undefined statt
                              // eines Fehlers. Zusaetzlich JSON.parse-Fallback, falls trotzdem ein String zurueckkommt.
                              function parseJson(data) {
                                  return typeof data === "string" ? JSON.parse(data) : data;
                              async function uuLogin() {
                                  const res = await httpPostAsync(
                                      `${UU_BASE}/api/login`,
                                      { username: UU_USERNAME, password: UU_PASSWORD },
                                      { validateCertificate: false, timeout: 15000, responseType: "json" },
                                  if (res.statusCode !== 200) {
                                      throw new Error(`Login fehlgeschlagen: HTTP ${res.statusCode}`);
                                  const setCookie = res.headers["set-cookie"];
                                  const cookie = Array.isArray(setCookie)
                                      ? setCookie.map(c => c.split(";")[0]).join("; ")
                                      : String(setCookie || "").split(";")[0];
                                  const data = parseJson(res.data);
                                  return { cookie, csrf: data && data.csrf };
                              async function uuGet(path, session) {
                                  const res = await httpGetAsync(`${UU_BASE}${path}`, {
                                      headers: { Cookie: session.cookie },
                                      timeout: 15000,
                                      responseType: "json",
                                      throw new Error(`${path} -> HTTP ${res.statusCode}`);
                                  return parseJson(res.data);
                              async function uuPost(path, session, body) {
                                  const res = await httpPostAsync(`${UU_BASE}${path}`, body || {}, {
                                      headers: { Cookie: session.cookie, "X-CSRF-Token": session.csrf },
                                      timeout: 15000,
                              async function uuLogout(session) {
                                  try {
                                      await uuPost("/api/logout", session, {});
                                  } catch (e) {
                                      // egal - Session laeuft sonst einfach serverseitig aus
                              // Server-seitige Definition von "beschaeftigt" (server.py: state in {running, pending, starting}) -
                              // nicht nur "running", damit ein gerade erst gestarteter Job nicht uebersehen wird.
                              const BUSY_STATES = ["running", "pending", "starting"];
                              // Bei diesen Endzustaenden lohnt es sich, das Log nachzuladen (bei "completed" nicht
                              // noetig - da ist eh alles gut gegangen).
                              const FAILURE_STATES = ["failed", "interrupted"];
                              async function isAnyJobRunning(session) {
                                  const jobsResp = await uuGet("/api/jobs", session);
                                  const jobs = jobsResp.jobs || [];
                                  return jobs.some(j => BUSY_STATES.includes(j.state));
                              // Legt rekursiv alle Felder eines Targets (auch verschachtelte wie "updates") als
                              // Datenpunkte an. Arrays werden als JSON-String gespeichert.
                              async function flattenAndSet(prefix, obj) {
                                  for (const [key, val] of Object.entries(obj)) {
                                      const id = `${prefix}.${sanitize(key)}`;
                                      if (val !== null && typeof val === "object" && !Array.isArray(val)) {
                                          await createChannelP(id, key);
                                          await flattenAndSet(id, val);
                                      } else if (Array.isArray(val)) {
                                          await createStateP(id, { name: key, type: "string", role: "json" }, JSON.stringify(val));
                                      } else {
                                          const type = typeof val === "boolean" ? "boolean" : typeof val === "number" ? "number" : "string";
                                          const safeVal = val === undefined || val === null ? (type === "string" ? "" : null) : val;
                                          await createStateP(id, { name: key, type, role: "value" }, safeVal);
                              // Entfernt Target-Ordner, die beim letzten Refresh noch da waren, aber jetzt nicht mehr
                              // von der API geliefert werden (VM/CT geloescht, oder - einmalig - Umstellung von
                              // ID- auf Name-basierte Ordner). Vergleicht ueber das ".id"-Feld jedes Ordners.
                              async function cleanupStaleTargets(currentTargets) {
                                  const currentPrefixes = new Set(currentTargets.map(targetKey));
                                  const existingPrefixes = new Set();
                                  $(`${ROOT}.targets.*.id`).each(id => {
                                      const prefix = id.replace(`${ROOT}.targets.`, "").replace(/\.id$/, "");
                                      if (!prefix.includes(".")) {
                                          existingPrefixes.add(prefix);
                                  for (const prefix of existingPrefixes) {
                                      if (!currentPrefixes.has(prefix)) {
                                          const fullId = `${ROOT}.targets.${prefix}`;
                                          await deleteObjectAsync(fullId, true);
                                          log(`[proxmoxUpdater] Nicht mehr gelieferter Target-Ordner entfernt: ${fullId}`);
                              // Leichtgewichtiger Check (nur /api/jobs, kein voller Status) - dafuer viel oefter
                              // aufgerufen als der schwere refreshStatus(), damit "laeuft gerade was" auch bei
                              // kurzen Update-Jobs (oft nur Sekunden bis wenige Minuten) nicht zwischen zwei
                              // stuendlichen Refreshs verpasst wird. session wird wiederverwendet, falls schon
                              // eine besteht (z.B. direkt nach einem Button-Klick), sonst wird selbst eingeloggt.
                              async function refreshJobStatus(session) {
                                  const jobRunning = jobs.some(j => BUSY_STATES.includes(j.state));
                                  await createStateP(`${ROOT}.jobRunning`, { name: "Läuft gerade ein Check/Update-Job?", type: "boolean", role: "indicator.working" }, jobRunning);
                                  // Job-Historie: letzte Checks/Updates pro Target (unit, target, state, exit_code, Zeiten ...)
                                  await createChannelP(`${ROOT}.jobs`, "Job-Historie");
                                  await createStateP(`${ROOT}.jobs.count`, { name: "Anzahl Jobs (laufend + Historie)", type: "number", role: "value" }, jobs.length);
                                  for (const j of jobs) {
                                      const jobPrefix = `${ROOT}.jobs.${sanitize(j.unit)}`;
                                      await createChannelP(jobPrefix, `${j.target || j.unit} (${j.state})`);
                                      await flattenAndSet(jobPrefix, j);
                                      if (FAILURE_STATES.includes(j.state)) {
                                          await fetchJobLogIfMissing(jobPrefix, j.unit, session);
                                  return jobRunning;
                              // Holt die letzten Logzeilen eines fehlgeschlagenen/abgebrochenen Jobs nach
                              // (GET /api/jobs/<unit>/log - liefert die letzten 200 Zeilen aus journalctl).
                              // Nur einmal pro Job noetig, daher Ueberspringen falls schon vorhanden.
                              async function fetchJobLogIfMissing(jobPrefix, unit, session) {
                                  const logId = `${jobPrefix}.log`;
                                  const existing = await getStateAsync(logId);
                                  if (existing && existing.val) {
                                      return;
                                  try {
                                      const logResp = await uuGet(`/api/jobs/${encodeURIComponent(unit)}/log`, session);
                                      await createStateP(logId, { name: "Log (letzte Zeilen bei Fehlschlag)", type: "string", role: "text" }, String(logResp.log || ""));
                                  } catch (e) {
                                      log(`[proxmoxUpdater] Log fuer Job ${unit} konnte nicht geholt werden: ${e.message}`, "warn");
                              // Selbstjustierender Poll-Takt, wie ihn auch die Original-Web-GUI von Ultimate
                              // Updater selbst verwendet (server.py: loadJobs() pollt alle 2s solange ein Job
                              // "running" ist, sonst alle 10s - wir nehmen 2s/30s, damit unser normaler Takt
                              // erhalten bleibt): solange ein Job laeuft, alle 2s pruefen, damit auch kurze
                              // Jobs von nur 10-15s sicher erfasst werden; sonst normaler 30s-Rhythmus.
                              // pollTimer wird bei jedem Tick neu gesetzt (nie parallel mehrere Timer aktiv).
                              let pollTimer = null;
                              async function pollJobStatusOnce() {
                                  let session;
                                  let jobRunning = false;
                                  try {
                                      session = await uuLogin();
                                      jobRunning = await refreshJobStatus(session);
                                  } catch (e) {
                                      log(`[proxmoxUpdater] Job-Status-Check fehlgeschlagen: ${e.message}`, "error");
                                  } finally {
                                      if (session) {
                                          await uuLogout(session);
                                  pollTimer = setTimeout(
                                      () => { pollJobStatusOnce().catch(e => log(`[proxmoxUpdater] Job-Status-Poll fehlgeschlagen: ${e.message}`, "error")); },
                                      jobRunning ? POLL_INTERVAL_BUSY_MS : POLL_INTERVAL_IDLE_MS,
                              // Fuer den sofortigen Check direkt nach einem Button-Klick: laufenden Timer verwerfen
                              // und sofort neu pruefen (nicht awaiten - der Button-Handler soll nicht darauf warten).
                              function kickJobStatusPoll() {
                                  clearTimeout(pollTimer);
                              async function refreshStatus() {
                                  let session;
                                  try {
                                  } catch (e) {
                                      log(`[proxmoxUpdater] Login fehlgeschlagen: ${e.message}`, "error");
                                      return;
                                  try {
                                      const status = await uuGet("/api/status", session);
                                      const targets = status.targets || [];
                                      await createChannelP(ROOT, "Proxmox Ultimate Updater");
                                      await createStateP(`${ROOT}.lastRefresh`, { name: "Letzte Aktualisierung", type: "number", role: "value.time" }, Date.now());
                                      await createStateP(`${ROOT}.schemaVersion`, { name: "Schema-Version", type: "string", role: "text" }, String(status.schema_version || ""));
                                      await createStateP(`${ROOT}.generatedAt`, { name: "Generiert am (Server)", type: "string", role: "text" }, String(status.generated_at || ""));
                                      await createStateP(`${ROOT}.targetCount`, { name: "Anzahl Targets", type: "number", role: "value" }, targets.length);
                                      // Zusammenfassung ueber alle Targets - erspart das Durchklicken aller Ordner,
                                      // um zu sehen ob/wo/wie viel gerade ansteht.
                                      const targetsWithUpdates = targets.filter(t => (t.security_updates || 0) > 0 || (t.normal_updates || 0) > 0);
                                      const targetsUnreachable = targets.filter(t => t.reachable === false);
                                      const targetsRebootRequired = targets.filter(t => t.reboot_required === true);
                                      await createChannelP(`${ROOT}.summary`, "Zusammenfassung");
                                      await createStateP(`${ROOT}.summary.securityUpdatesTotal`, { name: "Offene Security-Updates (Summe ueber alle Targets)", type: "number", role: "value" }, targets.reduce((sum, t) => sum + (t.security_updates || 0), 0));
                                      await createStateP(`${ROOT}.summary.normalUpdatesTotal`, { name: "Offene normale Updates (Summe ueber alle Targets)", type: "number", role: "value" }, targets.reduce((sum, t) => sum + (t.normal_updates || 0), 0));
                                      await createStateP(`${ROOT}.summary.targetsWithUpdatesCount`, { name: "Anzahl Targets mit offenen Updates", type: "number", role: "value" }, targetsWithUpdates.length);
                                      await createStateP(`${ROOT}.summary.targetsWithUpdatesList`, { name: "Targets mit offenen Updates", type: "string", role: "json" }, JSON.stringify(targetsWithUpdates.map(t => t.name || t.id)));
                                      await createStateP(`${ROOT}.summary.unreachableCount`, { name: "Anzahl nicht erreichbarer Targets (gestoppte VMs/CTs zaehlen nicht mit)", type: "number", role: "value" }, targetsUnreachable.length);
                                      await createStateP(`${ROOT}.summary.unreachableList`, { name: "Nicht erreichbare Targets", type: "string", role: "json" }, JSON.stringify(targetsUnreachable.map(t => t.name || t.id)));
                                      await createStateP(`${ROOT}.summary.rebootRequiredCount`, { name: "Anzahl Targets mit ausstehendem Reboot", type: "number", role: "value" }, targetsRebootRequired.length);
                                      await createStateP(`${ROOT}.summary.rebootRequiredList`, { name: "Targets mit ausstehendem Reboot", type: "string", role: "json" }, JSON.stringify(targetsRebootRequired.map(t => t.name || t.id)));
                                      // Sammel-Buttons
                                      await createStateAsync(`${ROOT}.updateAllVmsCtsNow`, false, {
                                          name: "Alle VMs/CTs aktualisieren (ohne Host)",
                                          type: "boolean",
                                          role: "button",
                                          read: true,
                                          write: true,
                                      await createStateAsync(`${ROOT}.updateSecurityOnlyNow`, false, {
                                          name: "Nur Security-Updates aktualisieren (VMs/CTs, ohne Host)",
                                          type: "boolean",
                                          role: "button",
                                          read: true,
                                          write: true,
                                      await createStateAsync(`${ROOT}.checkAllNow`, false, {
                                          name: "Alle pruefen, inkl. Host (nur Status, kein Update)",
                                          type: "boolean",
                                          role: "button",
                                          read: true,
                                          write: true,
                                      await createChannelP(`${ROOT}.targets`, "Targets");
                                      await cleanupStaleTargets(targets);
                                      for (const t of targets) {
                                          const isHost = t.type === "host";
                                          const prefix = `${ROOT}.targets.${targetKey(t)}`;
                                          await createChannelP(prefix, `${t.name || t.id} (${t.type})`);
                                          await flattenAndSet(prefix, t);
                                          await createStateAsync(`${prefix}.updateNow`, false, {
                                              name: isHost ? "Diesen Host aktualisieren" : "Dieses VM/CT aktualisieren",
                                              type: "boolean",
                                              role: "button",
                                              read: true,
                                              write: true,
                                          await createStateAsync(`${prefix}.checkNow`, false, {
                                              name: isHost ? "Diesen Host pruefen (kein Update)" : "Dieses VM/CT pruefen (kein Update)",
                                              type: "boolean",
                                              role: "button",
                                              read: true,
                                              write: true,
                                      log(`[proxmoxUpdater] Status aktualisiert: ${targets.length} Targets`);
                                  } catch (e) {
                                      log(`[proxmoxUpdater] Status-Abruf fehlgeschlagen: ${e.message}`, "error");
                                  } finally {
                              // ---- Einzel-Update-Button je Target ----
                              on({ id: new RegExp("^0_userdata\\.0\\.proxmoxUpdater\\.targets\\.[^.]+\\.updateNow$"), change: "ne" }, async obj => {
                                  if (!obj.state || obj.state.val !== true || obj.state.ack) {
                                      return;
                                  setState(obj.id, false, true);
                                  const prefix = obj.id.replace(/\.updateNow$/, "");
                                  const typeState = await getStateAsync(`${prefix}.type`);
                                  const isHost = typeState && typeState.val === "host";
                                  let session;
                                  try {
                                      if (await isAnyJobRunning(session)) {
                                          log("[proxmoxUpdater] Läuft bereits ein Check/Update-Job - Aktion nicht ausgelöst.", "warn");
                                          return;
                                      if (isHost) {
                                          const nodeState = await getStateAsync(`${prefix}.node`);
                                          const node = nodeState && nodeState.val;
                                          const res = await uuPost(`/api/update-node/${encodeURIComponent(node)}`, session, {});
                                          log(`[proxmoxUpdater] Host-Update gestartet (${node}): ${res.message || "OK"}`);
                                      } else {
                                          const idState = await getStateAsync(`${prefix}.id`);
                                          const id = idState && idState.val;
                                          const res = await uuPost(`/api/update/${encodeURIComponent(id)}`, session, {});
                                          log(`[proxmoxUpdater] Update gestartet (${id}): ${res.message || "OK"}`);
                                      // sofort neu pruefen und danach automatisch in den schnellen 2s-Takt wechseln,
                                      // solange der Job laeuft - siehe kickJobStatusPoll()/pollJobStatusOnce()
                                      kickJobStatusPoll();
                                  } catch (e) {
                                      log(`[proxmoxUpdater] Update fehlgeschlagen: ${e.message}`, "error");
                                  } finally {
                                      if (session) {
                              // ---- Sammel-Button: alle VMs/CTs (ohne Host) ----
                              on({ id: `${ROOT}.updateAllVmsCtsNow`, change: "ne" }, async obj => {
                                      return;
                                  let session;
                                  try {
                                          log("[proxmoxUpdater] Läuft bereits ein Check/Update-Job - Sammel-Update nicht ausgelöst.", "warn");
                                          return;
                                      const targets = (status.targets || []).filter(t => t.type !== "host");
                                      log(`[proxmoxUpdater] Starte Update fuer ${targets.length} VMs/CTs (Host ausgenommen)`);
                                          try {
                                              await uuPost(`/api/update/${encodeURIComponent(t.id)}`, session, {});
                                          } catch (e) {
                                              log(`[proxmoxUpdater] Update fuer ${t.id} fehlgeschlagen: ${e.message}`, "warn");
                                  } catch (e) {
                                      log(`[proxmoxUpdater] Sammel-Update fehlgeschlagen: ${e.message}`, "error");
                                  } finally {
                                      if (session) {
                              // ---- Einzel-Check-Button je Target (nur pruefen, kein Update) ----
                              on({ id: new RegExp("^0_userdata\\.0\\.proxmoxUpdater\\.targets\\.[^.]+\\.checkNow$"), change: "ne" }, async obj => {
                                      return;
                                  const prefix = obj.id.replace(/\.checkNow$/, "");
                                  let session;
                                  try {
                                          log("[proxmoxUpdater] Läuft bereits ein Check/Update-Job - Check nicht ausgelöst.", "warn");
                                          return;
                                      if (isHost) {
                                          const res = await uuPost(`/api/check-node/${encodeURIComponent(node)}`, session, {});
                                          log(`[proxmoxUpdater] Host-Check gestartet (${node}): ${res.message || "OK"}`);
                                      } else {
                                          const res = await uuPost(`/api/check/${encodeURIComponent(id)}`, session, {});
                                          log(`[proxmoxUpdater] Check gestartet (${id}): ${res.message || "OK"}`);
                                  } catch (e) {
                                      log(`[proxmoxUpdater] Check fehlgeschlagen: ${e.message}`, "error");
                                  } finally {
                                      if (session) {
                              // ---- Sammel-Button: alle pruefen, inkl. Host (read-only, daher unbedenklich) ----
                              on({ id: `${ROOT}.checkAllNow`, change: "ne" }, async obj => {
                                      return;
                                  let session;
                                  try {
                                          log("[proxmoxUpdater] Läuft bereits ein Check/Update-Job - Sammel-Check nicht ausgelöst.", "warn");
                                          return;
                                      const res = await uuPost("/api/check-all", session, {});
                                      log(`[proxmoxUpdater] Sammel-Check gestartet: ${res.message || "OK"}`);
                                  } catch (e) {
                                      log(`[proxmoxUpdater] Sammel-Check fehlgeschlagen: ${e.message}`, "error");
                                  } finally {
                                      if (session) {
                              // ---- Sammel-Button: nur Targets mit Security-Updates aktualisieren (ohne Host) ----
                              on({ id: `${ROOT}.updateSecurityOnlyNow`, change: "ne" }, async obj => {
                                      return;
                                  let session;
                                  try {
                                          log("[proxmoxUpdater] Läuft bereits ein Check/Update-Job - Security-Update nicht ausgelöst.", "warn");
                                          return;
                                      const targets = (status.targets || []).filter(t => t.type !== "host" && (t.security_updates || 0) > 0);
                                      log(`[proxmoxUpdater] Starte Security-Update fuer ${targets.length} VMs/CTs`);
                                          try {
                                          } catch (e) {
                                              log(`[proxmoxUpdater] Security-Update fuer ${t.id} fehlgeschlagen: ${e.message}`, "warn");
                                  } catch (e) {
                                      log(`[proxmoxUpdater] Security-Update fehlgeschlagen: ${e.message}`, "error");
                                  } finally {
                                      if (session) {
                              function delay(ms) {
                                  return new Promise(resolve => setTimeout(resolve, ms));
                              // Gestaffelter Check aller Targets nacheinander (statt alle gleichzeitig wie
                              // checkAllNow) - schont Host/Netzwerk, dauert dafuer entsprechend laenger
                              // (28 Targets * STAGGERED_CHECK_DELAY_MINUTES ≈ 1,5h). Fuer den schnellen,
                              // manuellen "jetzt sofort alle" mit kurzer hoher Last gibt es weiterhin den
                              // checkAllNow-Datenpunkt/Button.
                              async function staggeredCheckAll() {
                                  let targets;
                                  try {
                                      const session = await uuLogin();
                                      try {
                                      } finally {
                                  } catch (e) {
                                      log(`[proxmoxUpdater] Gestaffelter Check: Target-Liste konnte nicht geholt werden: ${e.message}`, "error");
                                      return;
                                  log(`[proxmoxUpdater] Gestaffelter Check gestartet (${targets.length} Targets, ${STAGGERED_CHECK_DELAY_MINUTES} min Abstand)`);
                                  for (let i = 0; i < targets.length; i++) {
                                      const t = targets[i];
                                      const label = t.name || t.id;
                                      let session;
                                      try {
                                              log(`[proxmoxUpdater] Gestaffelter Check: ${label} übersprungen - es läuft bereits ein anderer Job.`, "warn");
                                          } else if (t.type === "host") {
                                              await uuPost(`/api/check-node/${encodeURIComponent(t.node)}`, session, {});
                                              log(`[proxmoxUpdater] Gestaffelter Check ${i + 1}/${targets.length}: Host ${label} gestartet`);
                                          } else {
                                              await uuPost(`/api/check/${encodeURIComponent(t.id)}`, session, {});
                                              log(`[proxmoxUpdater] Gestaffelter Check ${i + 1}/${targets.length}: ${label} gestartet`);
                                      } catch (e) {
                                          log(`[proxmoxUpdater] Gestaffelter Check: ${label} fehlgeschlagen: ${e.message}`, "warn");
                                      } finally {
                                          if (session) {
                                      if (i < targets.length - 1) {
                                          await delay(STAGGERED_CHECK_DELAY_MS);
                                  log(`[proxmoxUpdater] Gestaffelter Check abgeschlossen (${targets.length} Targets)`);
                              refreshStatus().catch(e => log(`[proxmoxUpdater] Abbruch: ${e.message}`, "error"));
                              // stuendlich der volle, schwere Refresh (alle Targets, Cleanup, ...)
                              schedule(REFRESH_CRON, refreshStatus);
                              // naechtlich der gestaffelte Check aller Targets (siehe staggeredCheckAll())
                              schedule(STAGGERED_CHECK_CRON, () => {
                                  staggeredCheckAll().catch(e => log(`[proxmoxUpdater] Gestaffelter Check abgebrochen: ${e.message}`, "error"));
                              // leichter Job-Status-Check startet selbstjustierend (busy/idle-Takt s.o.) -
                              // schedule() kann keine Sub-Minuten-Intervalle, daher die eigene setTimeout-Kette
                              // in pollJobStatusOnce()/kickJobStatusPoll() weiter oben.
                              pollTimer = setTimeout(() => {
                              }, POLL_INTERVAL_IDLE_MS);
                              • Bass-TB
                                Bass-TB
                                Bass-T
                                #99
                                @david-g. Schick, damit ist der Updater ja praktisch voll in die Visu integrierbar – top. 👌🏻
                                Wenn ich mal wieder dafür Zeit finde, muss ich bei mir auch wieder ran.
                                Umzug ist voll doof für Visu bauen. 😀
                                Proxmox Cluster
                                • David G.D David G.
                                  Hey,
                                    ausstehendem Reboot
                                    ioBroker wieder
                                    Job laeuft
                                  Automatisierung
                                  Sicherheit
                                          timeout: 15000,
                                          timeout: 15000,
                                      try {
                                      } catch (e) {
                                          } else {
                                      return jobRunning;
                                          return;
                                      try {
                                      } catch (e) {
                                      let session;
                                      try {
                                      } catch (e) {
                                      } finally {
                                          if (session) {
                                      let session;
                                      try {
                                      } catch (e) {
                                          return;
                                      try {
                                          // Sammel-Buttons
                                              type: "boolean",
                                              role: "button",
                                              read: true,
                                              write: true,
                                              type: "boolean",
                                              role: "button",
                                              read: true,
                                              write: true,
                                              type: "boolean",
                                              role: "button",
                                              read: true,
                                              write: true,
                                                  type: "boolean",
                                                  role: "button",
                                                  read: true,
                                                  write: true,
                                                  type: "boolean",
                                                  role: "button",
                                                  read: true,
                                                  write: true,
                                      } catch (e) {
                                      } finally {
                                          return;
                                      let session;
                                      try {
                                              return;
                                          if (isHost) {
                                          } else {
                                      } catch (e) {
                                      } finally {
                                          if (session) {
                                          return;
                                      let session;
                                      try {
                                              return;
                                              try {
                                              } catch (e) {
                                      } catch (e) {
                                      } finally {
                                          if (session) {
                                          return;
                                      let session;
                                      try {
                                              return;
                                          if (isHost) {
                                          } else {
                                      } catch (e) {
                                      } finally {
                                          if (session) {
                                          return;
                                      let session;
                                      try {
                                              return;
                                      } catch (e) {
                                      } finally {
                                          if (session) {
                                          return;
                                      let session;
                                      try {
                                              return;
                                              try {
                                              } catch (e) {
                                      } catch (e) {
                                      } finally {
                                          if (session) {
                                      let targets;
                                      try {
                                          try {
                                          } finally {
                                      } catch (e) {
                                          return;
                                          let session;
                                          try {
                                              } else {
                                          } catch (e) {
                                          } finally {
                                              if (session) {
                                  NegaleinN
                                  NegaleinN
                                  Negalein
                                  #100
                                  @David-G. sagte:
                                  Hi David!
                                  Ist das Script in Kombination mit dem Proxmox-Updater, oder läuft es auch ohne installiertem Proxmox-Updater?
                                  Hast du dir dafür schon eine VIS gebastelt? ;)
                                    @David-G. sagte:
                                    Hi David!
                                    David G.D
                                    David G.D
                                    David G.
                                    #101
                                    @Negalein
                                    Baut auf dem Update auf.
                                    Nutzt die Endpunkte der gui vom Updater.
                                    Nein, noch nicht.
                                    • Bass-TB
                                      Bass-TB
                                      Bass-T
                                      #102
                                      Kurzer Zwischenstand von meiner Seite 👌🏻
                                      Aus den letzten Rückmeldungen hier sind inzwischen einige Punkte direkt in develop gelandet:
                                      • der Fehler beim Kopieren des Welcome-Screens nach der Installation ist behoben
                                      • die Live-Ausgabe bei Checks und Updates wurde verbessert, sodass Fehler wie apt-get update jetzt direkt sichtbar sind
                                      • Einzelchecks zeigen keine irreführende globale Filterauswahl mehr
                                      • fehlgeschlagene Checks blockieren ein Update nicht mehr komplett – es gibt jetzt stattdessen eine Warnung und man kann bewusst trotzdem fortfahren
                                      • die Status-Mail ist übersichtlicher geworden und trennt Security-/Normal-Updates klarer
                                      • interaktive Updatejobs laufen serverseitig unabhängig vom Browser weiter und können grundsätzlich Eingaben an den laufenden Prozess zurückgeben
                                      • ein Frontend-Freeze bei laufenden interaktiven Jobs wurde gefunden und behoben
                                      • zusätzlich wurde der Interactive-Job-Lookup in der WebUI beschleunigt, damit Attach/Input nicht mehr durch die globale Jobliste ausgebremst werden
                                      Gerade die interaktiven Tests haben aber auch gezeigt, dass die aktuelle Terminal-/Live-Log-Lösung in der WebUI zwar technisch funktioniert, sich bei echten Rückfragen von apt/dpkg/Whiptail aber noch nicht gut bedienen lässt.
                                      Aktuell wird die Ausgabe noch per Polling nachgeladen. Dadurch springt die Ansicht beim Aktualisieren, Terminal-Steuerzeichen werden nicht sauber dargestellt und eine Rückmeldung ist zwar möglich, aber ziemlich unintuitiv.
                                      Deshalb steht jetzt zusätzlich auf meiner Todo-Liste, die Terminalfunktion später auf eine echte Live-Terminal-Lösung umzubauen. Die bestehende Job-/PTY-Struktur ist dafür bereits gut vorbereitet. Ziel wäre eine direkte, flüssige Terminalansicht im Browser mit sauberer Ein-/Ausgabe und Reconnect, ohne dass der eigentliche Updatejob vom Browser abhängig wird.
                                      Für den Moment bleibt aber erstmal die aktuelle Polling-Lösung bestehen. Die grundlegende Funktion ist da – ich möchte nur nicht viel Kosmetik in einen Ansatz stecken, den ich später ohnehin durch eine richtige Terminallösung ersetzen möchte.
                                      Danke weiterhin für die Rückmeldungen und Tests hier. Die haben in den letzten Tagen tatsächlich einige Stellen aufgedeckt, die ich selbst so wahrscheinlich nicht erwischt hätte. 👍🏻
                                      Proxmox Cluster
                                      • Bass-TB Bass-T
                                        T
                                        T
                                        TT-Tom
                                        #103
                                        @Bass-T
                                        kannst du in der webUI beim Schedule auch die Auswahl von Tagen verfügbar machen, ich lasse gerne am 1. und 15. des Monats einen Check machen. Das ist für mich ausreichend.
                                        Alternativ wäre auch der Mail-Versand nur an den Tagen.
                                        Gruß Tom
                                        Public Transport
                                        • Bass-TB
                                          Bass-TB
                                          Bass-T
                                          #104
                                          Kurzer Zwischenstand 👌🏻
                                          Die letzten Rückmeldungen sind inzwischen in develop eingeflossen und der Stand ist jetzt auch als 5.1.3 Beta 1 auf beta verfügbar.
                                          Dabei wurden u. a. Live-Ausgabe, Soft-Gate nach fehlgeschlagenem Check, Mail-Übersicht, Node-Checks und die interaktiven Jobs weiter verbessert. Auch der Fall mit aktiviertem QEMU Guest Agent, aber gesperrtem guest-exec, wird jetzt sauber erkannt.
                                          Die interaktive Rückmeldung in der WebUI funktioniert technisch inzwischen auch. Allerdings hat der Test sehr deutlich gezeigt, dass die aktuelle Polling-/Logdarstellung dafür einfach zu unintuitiv ist – gerade bei apt/dpkg/Whiptail-Rückfragen.
                                          Deshalb steht als nächster größerer Punkt ein Umbau auf eine echte Live-Terminal-Lösung auf der Todo-Liste. Bis dahin bleibt die aktuelle Lösung erstmal bestehen.
                                          Wer testen möchte:
                                          update beta -up
                                          Danke euch weiterhin fürs Testen und die Rückmeldungen. 👍🏻
                                          @tt-tom kein ding bau ich in dem nächsten develop block mit ein ;)
                                          Email versand erfolgt sowieso nur nach einem Run. Nie einfach so ;)
                                          EDIT:
                                          EDIT2:
                                          ist in beta integriert ;)
                                          Beta werde ich jetzt erstmal stabil halten und den terminal umbau unter develop machen.
                                          Beta kann gerne getestet werden :)
                                          Proxmox Cluster
                                          84.2k
