  3. Off Topic
  4. Microcontroller
  5. Tasmota Sensoren Problem?
    apollon77A
Geplant Angeheftet Gesperrt Verschoben Microcontroller
4 Beiträge 2 Kommentatoren 211 Aufrufe 2 Beobachtet
  • W
    W
    Wichtelmann
    Ich nutze einen Wemos Di mini für Heizungsüberwachung. Mittels Sonoff Adapter binde ich diese in ioBroker ein.
    Nun hatte ich einige male Warnmeldungen, die wie folg aussehen:
    sonoff.0
    	2026-08-20 14:35:07.774	warn	Client [Tasmota_HZG] cannot parse data"SENSOR": _{"Time":"2026-08-20T13:34:47","DS18B20-1":{"Id":"082211090FEB","Temperature":25.0},"DS18B20-2":{"Id":"0822112C8A94","Temperature":26.0},"DS18B20-3":{"Id":"0822113BE65C","Temperature":24.5},"DS18B20-4":{"Id":"0822113FABA1","Temperature":54.2},"DS18B20-5":{"Id":"30�tele/tasmota_hzg/STATE{"Time":"2026-08-20T13:35:06","Uptime":"20T19:01:48","UptimeSec":1796508,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":2_ - SyntaxError: Bad control character in string literal in JSON at position 264 (line 1 column 265)
    sonoff.0
    	2026-08-20 13:31:52.152	warn	Client [Tasmota_HZG] cannot parse data"SENSOR": _{"Time":"2026-08-20T12:30:44","DS18B20-1":{"Id":"082211090FEB","Temperature":24.9},"DS18B20-2":{"Id":"0822112C8A94","Temperature":26.1},"DS18B20-3":{"Id":"0822113BE65C","Temperature":23.4},"DS18B20-4":{"Id":"0822113FABA1","Temperature":55.8},"DS18B20-5":{"Id":"30�tele/tasmota_hzg/STATE{"Time":"2026-08-20T12:31:04","Uptime":"20T17:57:46","UptimeSec":1792666,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":1_ - SyntaxError: Bad control character in string literal in JSON at position 264 (line 1 column 265)
    sonoff.0
    	2026-08-20 09:05:41.289	warn	Client [Tasmota_HZG] cannot parse data"SENSOR": _{"Time":"2026-08-20T08:02:04","DS18B20-1":{"Id":"082211090FEB","Temperature":22.3},"DS18B20-2":{"Id":"0822112C8A94","Temperature":22.4},"DS18B20-3":{"Id":"0822113BE65C","Temperature":24.9},"DS18B20-4":{"Id":"0822113FABA1","Temperature":28.9},"DS18B20-5":{"Id":"30�tele/tasmota_hzg/STATE{"Time":"2026-08-20T08:02:24","Uptime":"20T13:29:06","UptimeSec":1776546,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":1_ - SyntaxError: Bad control character in string literal in JSON at position 264 (line 1 column 265)
    Kann sich das jemand erklären? Ggf Sensit defekt? Die Werte, die in io übertragen werden sind plausibel, aber die Warnungen stören mich...
    Sensor 5 hat irgendwie Datenmüll, kann ich da ggf was prüfen?
    • Meister MopperM
      Meister MopperM
      Meister Mopper
      Der Datenmüll liegt wahrscheinlich im Speicher. Es kann eine veraltete Firmware oder übertriebene Abfrage (Standard = teleperiod 300) sein.
      Ich würde den ESP einfach mal neu starten (Restart 1).
      Proxmox und HA ...
      • W
        W
        Wichtelmann
        Tasmota 13.2.0 von Theo Arends
        Wenn nicht aktuell soll ich das echt dann updaten? Hab angst, dass nachher nix mehr geht und das war ein verdammt harter weg für mich das überhaupt zum laufen zu bringen...
        Habe mal Restart 1 gemacht, Die Daten im Tasmota sehen jetzt so aus:
        17:03:47.240 MQT: tele/tasmota_hzg/SENSOR = {"Time":"2026-08-20T17:03:47","DS18B20-1":{"Id":"082211090FEB","Temperature":24.7},"DS18B20-2":{"Id":"0822112C8A94","Temperature":25.5},"DS18B20-3":{"Id":"0822113BE65C","Temperature":24.2},"DS18B20-4":{"Id":"0822113FABA1","Temperature":49.9},"DS18B20-5":{"Id":"3DE1D4432441","Temperature":25.1},"DS18B20-6":{"Id":"3DE1D44363A5","Temperature":35.1},"DS18B20-7":{"Id":"3DE1D443E76C","Temperature":24.3},"TempUnit":"C"}
        Ich beobachte mal io, obs da noch hakt
        Danke schonmal!
        • W Wichtelmann
          Danke schonmal!
          Meister MopperM
          Meister MopperM
          Meister Mopper
          schrieb am zuletzt editiert von Meister Mopper
          @Wichtelmann sagte:
          Auch wenn jetzt wahrscheinlich wieder ein shitstorm startet, weil einige User der Meinung sind, dass abgeschottete Systeme nicht immer auf dem aktuellen Stand sein müssen, bleibe ich dabei:
          Halte dein System aktuell, sonst vergisst du vielleicht irgendwann, dass das System ja früher mal abgeschottet war, durch eine Änderung jetzt aber nicht mehr ist. Dann ist das Scheunentor offen.
          Halte dein System aktuell! v13.x ist nicht aktuell. Hier läuft Tasmota v15.2.0.
          Proxmox und HA ...
          84.0k
