  4. neue Visualisierung "webui" (alternative zu vis & vis-2)
1.2k Beiträge 23 Kommentatoren 470.4k Aufrufe 19 Beobachtet
  • Smilie108S Offline
    Smilie108S Offline
    Smilie108
    #1159
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Ubuntu 24.04.4 LTS
     Static hostname: iobroker-kramsach-live
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.8.0-111-generic
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
       Firmware Date: Tue 2014-04-01
        Firmware Age: 12y 1month 3d
    OS is similar to: debian
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:04:22 up 36 min,  2 users,  load average: 2.96, 3.23, 2.14
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-05-04 20:04:22 CEST
               Universal time: Mon 2026-05-04 18:04:22 UTC
                     RTC time: Mon 2026-05-04 18:04:22
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    smilie108
    HOME=/home/smilie108
    GROUPS=smilie108 adm cdrom sudo dip plugdev lxd iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             20G        5.4G         13G        3.8M        1.8G         15G
    Swap:           8.6G          0B        8.6G
    Total:           29G        5.4G         22G
    Active iob-Instances:   44
            19779 M total memory
             5172 M used memory
             4996 M active memory
              941 M inactive memory
            13272 M free memory
              178 M buffer memory
             1525 M swap cache
             8191 M total swap
                0 M used swap
             8191 M free swap
    top - 20:04:22 up 36 min,  2 users,  load average: 2.96, 3.23, 2.14
    Tasks: 207 total,   2 running, 205 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 34.9 us, 11.6 sy,  0.0 ni, 51.2 id,  0.0 wa,  0.0 hi,  2.3 si,  0.0 st
    MiB Mem :  19779.1 total,  13275.8 free,   5169.0 used,   1703.8 buff/cache
    MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  14610.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  2.0G  1.1M  2.0G   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    98G   58G   36G  62% /
    tmpfs                             tmpfs  9.7G     0  9.7G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   2.0G  200M  1.6G  11% /boot
    tmpfs                             tmpfs  2.0G   12K  2.0G   1% /run/user/1000
    [Mon May  4 19:28:18 2026] EXT4-fs (dm-0): mounted filesystem 8d603055-1d71-4ec7-84ad-951b1082fd39 ro with ordered data mode. Quota mode: none.
    [Mon May  4 19:28:18 2026] EXT4-fs (dm-0): re-mounted 8d603055-1d71-4ec7-84ad-951b1082fd39 r/w.
    [Mon May  4 19:28:19 2026] EXT4-fs (sda2): mounted filesystem 965f4498-2280-470d-b312-91df09b7b1f5 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE                            FSTYPE OPTIONS
    /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
    `-/boot /dev/sda2                         ext4   rw,relatime
    /var:
    2.5G    /var/
    1.4G    /var/lib
    970M    /var/lib/mysql
    942M    /var/log
    903M    /var/log/journal/18c66e219588459ea2005bc764231802
    Archived and active journals take up 902.9M in the file system.
    /opt/iobroker/backups:
    91M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    787M    /opt/iobroker/iobroker-data/
    271M    /opt/iobroker/iobroker-data/files
    195M    /opt/iobroker/iobroker-data/history
    134M    /opt/iobroker/iobroker-data/cloudless-homeconnect.0
    128M    /opt/iobroker/iobroker-data/backup-objects
    133M    /opt/iobroker/iobroker-data/cloudless-homeconnect.0/homeconnect-profile-downloader-win32-x64-1.0.1.zip
    44M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/states.jsonl
    13M     /opt/iobroker/iobroker-data/files/webui/node_modules/monaco-editor/esm/vs/editor/ts.worker.js
    8.2M    /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-Blv_5nFZ.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_cefeaafbdc82ee11b712469ec33d7414-if00-port0
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.19.1+dfsg-6ubuntu5 500
            500 http://at.archive.ubuntu.com/ubuntu noble/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker-kramsach-live iobroker-kramsach-live (version: 7.1.1, hostname: iobroker-kramsach-live, alive, uptime: 363)
    Core adapters versions
    js-controller:  7.1.1
    admin:          7.8.23
    javascript:     9.2.1
    nodejs modules from github:     1
    +-- iobroker.euhome@0.1.5 (git+ssh://git@github.com/TA2k/ioBroker.euhome.git#da498b16858260123ddad3633f344e0ef05c99de)
    Adapter State
      system.adapter.accuweather.0            : accuweather           : iobroker-kramsach-live                   - disabled
    + system.adapter.admin.0                  : admin                 : iobroker-kramsach-live                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : iobroker-kramsach-live                   - disabled
      system.adapter.apg-info.0               : apg-info              : iobroker-kramsach-live                   -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker-kramsach-live                   -  enabled
    + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker-kramsach-live                   -  enabled
      system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : iobroker-kramsach-live                   - disabled
    + system.adapter.discovery.0              : discovery             : iobroker-kramsach-live                   -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker-kramsach-live                   -  enabled
      system.adapter.email.0                  : email                 : iobroker-kramsach-live                   - disabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-kramsach-live                   -  enabled
    + system.adapter.euhome.0                 : euhome                : iobroker-kramsach-live                   -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker-kramsach-live                   -  enabled
      system.adapter.flexcharts.0             : flexcharts            : iobroker-kramsach-live                   - disabled
      system.adapter.flexcharts.1             : flexcharts            : iobroker-kramsach-live                   - disabled
      system.adapter.flot.0                   : flot                  : iobroker-kramsach-live                   - disabled
    + system.adapter.hass.0                   : hass                  : iobroker-kramsach-live                   -  enabled, port: 8123
    + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-kramsach-live                   -  enabled
    + system.adapter.history.0                : history               : iobroker-kramsach-live                   -  enabled
    + system.adapter.history.1                : history               : iobroker-kramsach-live                   -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker-kramsach-live                   -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-kramsach-live                   -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker-kramsach-live                   -  enabled
    + system.adapter.kecontact.0              : kecontact             : iobroker-kramsach-live                   -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker-kramsach-live                   -  enabled
      system.adapter.modbus.1                 : modbus                : iobroker-kramsach-live                   - disabled
      system.adapter.modbus.2                 : modbus                : iobroker-kramsach-live                   - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-kramsach-live                   -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.nissan.0                 : nissan                : iobroker-kramsach-live                   - disabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker-kramsach-live                   -  enabled
      system.adapter.pegelalarm.0             : pegelalarm            : iobroker-kramsach-live                   -  enabled
    + system.adapter.pi-hole2.0               : pi-hole2              : iobroker-kramsach-live                   -  enabled, port: 80
    + system.adapter.proxmox.0                : proxmox               : iobroker-kramsach-live                   -  enabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : iobroker-kramsach-live                   -  enabled
    + system.adapter.s7.0                     : s7                    : iobroker-kramsach-live                   -  enabled
      system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker-kramsach-live                   - disabled, port: 8002
    + system.adapter.scenes.0                 : scenes                : iobroker-kramsach-live                   -  enabled
    + system.adapter.scheduler.0              : scheduler             : iobroker-kramsach-live                   -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker-kramsach-live                   -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.signal-cmb.0             : signal-cmb            : iobroker-kramsach-live                   - disabled
    + system.adapter.simple-api.0             : simple-api            : iobroker-kramsach-live                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.solax.0                  : solax                 : iobroker-kramsach-live                   -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-kramsach-live                   -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
    + system.adapter.sql.1                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
    + system.adapter.sql.2                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
    + system.adapter.sql.3                    : sql                   : iobroker-kramsach-live                   -  enabled
    + system.adapter.sql.4                    : sql                   : iobroker-kramsach-live                   -  enabled
    + system.adapter.sql.5                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
    + system.adapter.sql.6                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
    + system.adapter.sql.7                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
    + system.adapter.sql.8                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
    + system.adapter.sql.9                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
    + system.adapter.tuya.0                   : tuya                  : iobroker-kramsach-live                   -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : iobroker-kramsach-live                   -  enabled
    + system.adapter.web.0                    : web                   : iobroker-kramsach-live                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.webui.0                  : webui                 : iobroker-kramsach-live                   -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-kramsach-live                   -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker-kramsach-live                   -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "accuweather"  : 2.2.0    , installed 2.2.0
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "apg-info"     : 0.1.32   , installed 0.1.32
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "bosch-ebike"  : 0.1.12   , installed 0.1.12
    Adapter    "cloudless-homeconnect": 1.6.4, installed 1.6.4
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
    Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
    Adapter    "flexcharts"   : 0.7.0    , installed 0.7.0
    Adapter    "hass"         : 2.0.3    , installed 2.0.3
    Adapter    "heatingcontrol": 3.1.4   , installed 3.1.4
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "homeconnect"  : 1.5.2    , installed 1.5.2
    Adapter    "javascript"   : 9.2.1    , installed 9.2.1
    Controller "js-controller": 7.1.1    , installed 7.1.1
    Adapter    "kecontact"    : 3.6.0    , installed 3.6.0
    Adapter    "modbus"       : 8.1.3    , installed 8.1.3
    Adapter    "nissan"       : 0.1.18   , installed 0.1.18
    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
    Adapter    "pegelalarm"   : 1.4.0    , installed 1.4.0
    Adapter    "pi-hole2"     : 1.1.1    , installed 1.1.1
    Adapter    "proxmox"      : 2.5.3    , installed 2.5.3
    Adapter    "pvforecast"   : 6.1.0    , installed 6.1.0
    Adapter    "s7"           : 1.5.0    , installed 1.5.0
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "scenes"       : 4.0.4    , installed 4.0.4
    Adapter    "scheduler"    : 1.5.0    , installed 1.5.0
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "solax"        : 0.9.23   , installed 0.9.23
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "viessmannapi" : 2.4.5    , installed 2.4.5
    Adapter    "web"          : 8.1.0    , installed 8.1.0
    Adapter    "webui"        : 1.44.0   , installed 1.44.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Adapter    "zigbee"       : 3.4.1    , installed 3.4.1
    Objects and States
    Objects:        32009
    States:         26991
    Hit:1 http://at.archive.ubuntu.com/ubuntu noble InRelease
    Hit:2 http://at.archive.ubuntu.com/ubuntu noble-updates InRelease
    Hit:3 http://at.archive.ubuntu.com/ubuntu noble-backports InRelease
    Hit:4 https://apt.grafana.com stable InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Ign:6 http://security.ubuntu.com/ubuntu noble-security InRelease
    Hit:6 http://security.ubuntu.com/ubuntu noble-security InRelease
    Reading package lists...
    Pending systemupdates: 4
    *** Listening Ports ***
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      992        5876       652/systemd-resolve
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6881       1/init
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4317       1/init
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       240773     67908/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       241563     68467/io.shelly.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       225677     64683/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       226354     64683/iobroker.js-c
    tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      992        5878       652/systemd-resolve
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      111        9236       973/mariadbd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       249631     69865/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       226581     64811/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       248213     69643/io.simple-api
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6883       1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          2875       1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      0          10440      1139/apache2
    tcp6       0      0 :::3000                 :::*                    LISTEN      114        11519      1109/grafana
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       245806     68717/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       245807     68717/io.tuya.0
    udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       236456     67747/io.kecontact.
    udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       236457     67747/io.kecontact.
    udp        0      0 0.0.0.0:46834           0.0.0.0:*                           1001       235441     67747/io.kecontact.
    udp        0      0 127.0.0.54:53           0.0.0.0:*                           992        5877       652/systemd-resolve
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           992        5875       652/systemd-resolve
    udp        0      0 192.168.2.30:68         0.0.0.0:*                           998        8716       787/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4318       1/init
    udp6       0      0 :::111                  :::*                                0          3864       1/init
    udp6       0      0 fe80::be24:11ff:fec:546 :::*                                998        9399       787/systemd-network
    2026-05-04 20:05:58.425  - warn: modbus.0 (67832) Error: undefined
    2026-05-04 20:05:58.425  - error: modbus.0 (67832) Request timed out.
    2026-05-04 20:05:58.425  - error: modbus.0 (67832) Client in error state.
    2026-05-04 20:05:58.425  - warn: modbus.0 (67832) [DevID_1/holdingRegs] Block 1047-1073: {}
    2026-05-04 20:05:59.426  - info: modbus.0 (67832) Disconnected from slave 192.168.2.43
    2026-05-04 20:06:07.390  - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186
    2026-05-04 20:06:08.026  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
    2026-05-04 20:06:08.029  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
    2026-05-04 20:06:08.040  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
    2026-05-04 20:06:08.062  - info: webui.0 (69983) runCommand: uiConnected, parameter:
    2026-05-04 20:06:08.100  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
    2026-05-04 20:06:08.130  - info: webui.0 (69983) runCommand: uiChangedView, parameter: start
    2026-05-04 20:06:08.156  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/anchored-region: EISDIR: illegal operation on a directory, read
    2026-05-04 20:06:08.203  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb: EISDIR: illegal operation on a directory, read
    2026-05-04 20:06:08.206  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb-item: EISDIR: illegal operation on a directory, read
    2026-05-04 20:06:08.219  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/data-grid: EISDIR: illegal operation on a directory, read
    2026-05-04 20:06:08.230  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox: EISDIR: illegal operation on a directory, read
    2026-05-04 20:06:08.234  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox-option: EISDIR: illegal operation on a directory, read
    2026-05-04 20:06:08.249  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/select: EISDIR: illegal operation on a directory, read
    2026-05-04 20:06:08.263  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/toolbar: EISDIR: illegal operation on a directory, read
    2026-05-04 20:06:08.264  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/tooltip: EISDIR: illegal operation on a directory, read
    2026-05-04 20:06:08.271  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/styles: EISDIR: illegal operation on a directory, read
    2026-05-04 20:06:08.452  - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186
    2026-05-04 20:06:09.429  - info: modbus.0 (67832) Connected to slave 192.168.2.43
    2026-05-04 20:06:28.960  - info: solax.0 (68592) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
    iob diag has finished.
      Smilie108S Offline
      Smilie108
      #1160
      das ist jetzt wärend dem laufenden betrieb
      • Smilie108S Smilie108
        Script v.2026-01-31
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        smilie108
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           8.6G          0B        8.6G
        Total:           29G        5.4G         22G
                 5172 M used memory
                13272 M free memory
                  178 M buffer memory
                 1525 M swap cache
                 8191 M total swap
                    0 M used swap
                 8191 M free swap
        *** FILESYSTEM ***
        /var:
        2.5G    /var/
        1.4G    /var/lib
        970M    /var/lib/mysql
        942M    /var/log
        USB-Devices by-id:
        ⚠ HINT:
        /dev/ttyUSB0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.7
        /usr/bin/npx            10.9.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.8.23
        javascript:     9.2.1
        Adapter State
        + instance is alive
        Objects and States
        Objects:        32009
        States:         26991
        #1161
        @Smilie108 sagte:
        ⚠ HINT:
        /dev/ttyUSB0
        Hat mit deinem Problem zwar nichts zu tun, aber trag in zigbee.0 statt /dev/ttyUSB0 besser:
        ein.
        ZEHN sql-Instanzen? Was treibst du da?
        Spiel die ein.
        Zu
        fällt mir aber auch nix ein. Nur das ich auf meinem Testsystem mit
        Adapter "webui" : 1.39.0 , installed 1.39.0
        gar nichts mit @fluentui installiert habe.
          Smilie108S Offline
          Smilie108
          #1162
          ;) naja ich habe gerne gewerke getrennt und das einfachste und übersichtlichste ist es auf instanzbasis wenn sich die hw mal wieder ändert und du eine neue heizung hast aber die daten der alten für vergleichswecke zb noch etwas behalten wilst dann mach ich eine neue db und schreib das neu darein kann aber die alte zum vergleichen beutzen und bei bedarf auch einfach mal elleminieren
            Smilie108S Offline
            Smilie108
            #1163
            @thomas-braun aber danke fürs nachschauen ich hab das mal deinstalliert und werde sehen was nicht mher geht ;)
            • jogibear9988J Offline
              jogibear9988
              #1164
              du kannst in webui ja auch pakete installieren:
              Check my ioBroker webui - a vis alternative
              see: https://github.com/iobroker-community-adapters/ioBroker.webui
                Smilie108S Offline
                Smilie108
                #1165
                @jogibear9988 ja da hab ich das flue ja schon mal neu instalierne probiert und hatte trotzdem die verzeichniss fehler nur so als hinweis ;)
                  jogibear9988
                  #1166
                  ja, das liegt eben an den npm paketen....
                  da ist nicht alles standardisiert, manche gehen, manche nicht, manche gingen mal....
                  bsp fluent ui, hat ne fehlerhafte webcomponent mainifest json...
                    Kamikaze
                    #1167
                    Hallo jogibear,
                    ich weiss nicht, wo du als erstes nachschaust, abewr ich habe auf Github einen Issue eröffnet, da ich meine Controls nicht exportiert bekomme.
                    Wäre schön, wenn du dir das einmal ansehen könntest.
                      jogibear9988
                      #1168
                      schau ich mir an
                        jogibear9988
                        #1169
                        ist gelöst
                          jogibear9988
                          #1170
                          Gibt auch ein paar neue feature:
                          • Simple scripts gibts nun ein "if" und ne hilfe:
                          • Man kann das script als code anschauen und bearbeiten:
                          • Bindings editor hat copy & delete funktionen:
