Test Widget json template
Am besten Inhalt von m1
[{"img":"http://192.168.178.20:8082/vis-2.0/main2/graue_tonne.png","zeit":"23.07.2026 - 23.07.2026","ereignis":" Abfuhrtermin Altpapier (ROT): Abfuhrtermin Altpapier","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/present.png","zeit":"25.07.2026 - 25.07.2026","ereignis":"xxxxx Geburtstag: 1945","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/info_black.png","zeit":"25.07.2026 14:30 - 17:30","ereignis":"Pretty Woman - Das Musical","ort":"Großer Saal"},{"img":"http://192.168.178.20:8082/vis-2.0/main2/graue_tonne.png","zeit":"30.07.2026 - 30.07.2026","ereignis":" Abfuhrtermin Altpapier (ROT): Abfuhrtermin Altpapier","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/present.png","zeit":"30.07.2026 - 30.07.2026","ereignis":"xxxxxxxx: 1965","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/present.png","zeit":"01.08.2026 - 01.08.2026","ereignis":"xxxxxxxxxx: 1964","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/graue_tonne.png","zeit":"03.08.2026 - 03.08.2026","ereignis":" Abfuhrtermin Restmüll (GRAU): Abfuhrtermin Restmüll","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/graue_tonne.png","zeit":"03.08.2026 - 03.08.2026","ereignis":" Abfuhrtermin Biotonne (GRUEN): Abfuhrtermin Biotonne","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/graue_tonne.png","zeit":"06.08.2026 - 06.08.2026","ereignis":" Abfuhrtermin Altpapier (ROT): Abfuhrtermin Altpapier","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/graue_tonne.png","zeit":"13.08.2026 - 13.08.2026","ereignis":" Abfuhrtermin Altpapier (ROT): Abfuhrtermin Altpapier","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/graue_tonne.png","zeit":"17.08.2026 - 17.08.2026","ereignis":" Abfuhrtermin Restmüll (GRAU): Abfuhrtermin Restmüll","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/graue_tonne.png","zeit":"17.08.2026 - 17.08.2026","ereignis":" Abfuhrtermin Biotonne (GRUEN): Abfuhrtermin Biotonne","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/graue_tonne.png","zeit":"18.08.2026 - 18.08.2026","ereignis":" Abfuhrtermin gelber Sack: Abfuhrtermin Wertstofftonne / gelber Sack","ort":""},{"img":"http://192.168.178.20:8082/vis-2.0/main2/graue_tonne.png","zeit":"20.08.2026 - 20.08.2026","ereignis":" Abfuhrtermin Altpapier (ROT): Abfuhrtermin Altpapier","ort":""}]avascript.0 2026-07-22 20:56:02.059 info script.js.Test.Kalender: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions javascript.0 2026-07-22 20:56:02.047 info script.js.Test.Kalender: start JavaScript (Javascript/js) javascript.0 2026-07-22 20:56:02.040 info script.js.Test.Kalender: Stopping scriptEdit :
Vis neu gestartet leer:
ok fehler ist gefunden.
durch automatisierte dependabots sind aktualisierungen rein gekommen,
die mit vis2 nicht mehr kompatibel sind.
das konnte ich beheben (zumindest lokal)sobald die version auf npm verfügbar ist, gebe ich das bekannt.
dadurch gab es keine aktualisierungen im runtime mode von vis2.
allerdings hat das 2. template ein problem. da passt der code nicht zu den datenin einem item kommen folgende daten
{ "img": "http://192.168.178.20:8082/vis-2.0/main2/graue_tonne.png", "zeit": "23.07.2026 - 23.07.2026", "ereignis": " Abfuhrtermin Altpapier (ROT): Abfuhrtermin Altpapier", "ort": "" }im template
wird aber nach diesen daten gefragtvar rawName = item.name || ''; var title = rawName; var details = '';im weiteren verlauf wird dann titel und details noch speziell behandelt.
wenn item.name in den daten nicht existieren, dann wird es nichts.Ist das eine neuere Version des templates? In den bisherigen konnte ich "Keine Einträge vorhanden" nicht finden.
Neue Version 4.4.5
- paket versionen für das vis-2 widget mussten zurück gesetzt werden, da dadurch das widget nicht mehr richtig funktioniert haben.
Wer schnell testen will und der Adapter im beta repo noch nicht auftaucht
kann über den expertenmodus/katzenknopf laden
<% console.log(data) %> <style> .mini-calendar-container { display: flex; flex-direction: column; gap: 8px; font-family: Arial, sans-serif; width: 100%; box-sizing: border-box; padding: 5px; } .mini-calendar-item { display: flex; align-items: center; gap: 12px; padding: 8px 12px; border-radius: 6px; background: rgba(255, 255, 255, 0.12); box-shadow: 0 2px 4px rgba(0, 0, 0, 0.2); color: #ffffff; } .mini-calendar-img { width: 36px; height: 36px; border-radius: 50%; object-fit: cover; flex-shrink: 0; border: 1px solid rgba(255, 255, 255, 0.3); } .mini-calendar-content { display: flex; flex-direction: column; flex-grow: 1; } .mini-calendar-time { font-size: 0.8em; opacity: 0.85; font-weight: bold; color: #dddddd; } .mini-calendar-event { font-size: 0.95em; font-weight: 600; } .mini-calendar-ort { font-size: 0.8em; opacity: 0.7; font-style: italic; } </style> <div class="mini-calendar-container"> <% var items = []; var rawData = (typeof data !== 'undefined' && data) ? data : ((typeof dp1 !== 'undefined' && dp1) ? dp1 : ((typeof val !== 'undefined' && val) ? val : null)); try { if (typeof rawData === 'string') { items = JSON.parse(rawData); } else if (Array.isArray(rawData)) { items = rawData; } } catch(e) { items = []; } if (Array.isArray(items) && items.length > 0) { for (var i = 0; i < items.length; i++) { var item = items[i]; if (!item) continue; var imgUrl = item.img || ''; var zeit = item.zeit || ''; var ereignis = item.ereignis || ''; var ort = item.ort || ''; %> <div class="mini-calendar-item"> <% if (imgUrl) { %> <img class="mini-calendar-img" src="<%= imgUrl %>" alt="User"> <% } %> <div class="mini-calendar-content"> <div class="mini-calendar-time"><%= zeit %></div> <div class="mini-calendar-event"><%= ereignis %></div> <% if (ort) { %> <div class="mini-calendar-ort">📍 <%= ort %></div> <% } %> </div> </div> <% } } else { %> <div style="color: white; opacity: 0.7; padding: 5px; font-size: 0.9em;">Keine Einträge vorhanden</div> <% } %> </div> -
Neue Version 4.4.5
Die Dokumentation wurde um eine Beschreibung in Deutsch und Englisch erweitert, wie man Templates mit KI entwickeln kann.
Es enthält eine Prompt-Vorlage, inklusive Beispielprompt, welche aktuell alle Empfehlungen enthält, so das die KI, das Template entwerfen kann.
Anmerkungen, Erfahrungen, Beispiel UseCases sind hier gerne gesehen.
Neue Version 4.5.0
- Widget-Rendering korrigiert. Das vis-2 widget erhält nun initial auch wieder die datenpunkt daten.
- Such- und Vollbildfunktion zum Template Editor für das vis-2-Widget hinzugefügt
- KI-Dokumentation für Regex-Ausdrücke verbessert
- Für das vis-2 widget wurde das Theme für den Template editor für den Dark Mode optimiert.
Neue Version 4.5.0
@OliverIO
benutze das widget schon sehr lange um eine json Auswahl als Objekt zu nehmen. Das ausgewählte Element wird dann in einen anderen DP geschrieben.
Du hattest mir damals folgendes geschrieben:<% var selectid="mydropdown2"; var dp_write = "javascript.0.Sonstige.Google.Kontakte.Photo.ausgewählt"; %> <script> debugger; var selectid="<%- selectid %>"; var dp_write="<%- dp_write %>"; function writeDP(el) { if (el.selectedOptions[0].text) vis.setValue(dp_write,el.selectedOptions[0].text); } </script> <style> #mydropdown2 { color:rgb(255,255,255); width: 250px; background:black; font-size:24px; } </style> </style><select id="<%- selectid %>" name="<%- selectid %>" size="1" onchange="javascript:writeDP(this)" > <% debugger; %> <% for (var i = 0; i<data.length;i++) { %> <option <%- ((dp[dp_write]==data[i]) ? "selected":"") %>><%- data[i] %></option> <% } %> </select>Dies hatte ich dann als json Vorlage in edit eingetragen.
Nun wollte ich dies so ändern, dass beim Aufruf der view das widget einen bestimmten Wert (z.B. der Wert 10 vom json) einträgt und sichtbar darstellt.
Alle Versuche mit chatgpt haben nicht geklappt. Es wird mir immer der 1.Wert des json angezeigt.Hast du dafür eine Idee ?
@OliverIO
ich habe deinen post mal bei mir in chatgpt hineingeworfen.
Das Ergebnis habe ich jetzt aktuell nicht getestet. Probier malAusserdem habe ich mittlerweile eine KI Promptvorlage entwickelt, die man für solche sachen verwenden kann
https://github.com/oweitman/ioBroker.vis-jsontemplate/blob/main/documentation/KI-DE.md
Hier der chatgpt output
Ja. Der entscheidende Punkt ist: Du musst beim Erzeugen der
<option>-Elemente das gewünschte Element mitselectedmarkieren. Ein späteres JavaScript-Setzen funktioniert im JSON-Template oft nicht zuverlässig, weil das Widget beim Rendern den HTML-Inhalt vollständig neu erzeugt.Hier eine direkt einsetzbare Variante, die beim ersten Aufruf den JSON-Eintrag mit dem Index 10 auswählt und dessen Wert in den Datenpunkt schreibt:
<% var selectid = "mydropdown2"; var dp_write = "javascript.0.Sonstige.Google.Kontakte.Photo.ausgewählt"; /* * Gewünschter Eintrag im JSON-Array. * * Achtung: * Arrays beginnen bei Index 0. * * Index 10 bedeutet somit das 11. Element. * Für das 10. Element wäre der Index 9. */ var defaultIndex = 10; var currentValue = dp && dp[dp_write] !== undefined ? String(dp[dp_write]) : ""; var defaultValue = ""; if (Array.isArray(data) && data.length > defaultIndex) { defaultValue = String(data[defaultIndex]); } /* * Wenn im Ziel-Datenpunkt bereits ein gültiger Wert steht, * wird dieser angezeigt. * * Andernfalls wird der gewünschte Standardwert verwendet. */ var selectedValue = currentValue; if ( !selectedValue || !Array.isArray(data) || data.map(String).indexOf(selectedValue) === -1 ) { selectedValue = defaultValue; } %> <script> var jsontemplateSelectId_<%- widgetid %> = "<%- selectid %>"; var jsontemplateWriteDp_<%- widgetid %> = "<%- dp_write %>"; var jsontemplateInitialValue_<%- widgetid %> = "<%- selectedValue %>"; function jsontemplateWriteSelection_<%- widgetid %>(element) { if (!element || element.selectedIndex < 0) { return; } var selectedOption = element.options[element.selectedIndex]; if (!selectedOption) { return; } vis.setValue( jsontemplateWriteDp_<%- widgetid %>, selectedOption.value ); } setTimeout(function () { var element = document.getElementById( jsontemplateSelectId_<%- widgetid %> ); if (!element) { return; } element.value = jsontemplateInitialValue_<%- widgetid %>; /* * Nur schreiben, wenn der DP noch nicht den angezeigten Wert enthält. */ var currentDpValue = "<%- currentValue %>"; if ( element.value && String(currentDpValue) !== String(element.value) ) { vis.setValue( jsontemplateWriteDp_<%- widgetid %>, element.value ); } }, 0); </script> <style> #<%- widgetid %> #<%- selectid %> { color: rgb(255, 255, 255); width: 250px; background: black; font-size: 24px; } </style> <select id="<%- selectid %>" name="<%- selectid %>" size="1" onchange="jsontemplateWriteSelection_<%- widgetid %>(this)" > <% if (Array.isArray(data)) { %> <% for (var i = 0; i < data.length; i++) { %> <% var optionValue = String(data[i]); var isSelected = optionValue === selectedValue; %> <option value="<%- optionValue %>" <%- isSelected ? "selected" : "" %> ><%- optionValue %></option> <% } %> <% } %> </select>Wichtig: Index oder Wert?
Bei:
var defaultIndex = 10;wird wegen der nullbasierten Array-Indizierung das 11. Element gewählt:
data[0] = erstes Element data[9] = zehntes Element data[10] = elftes ElementSoll tatsächlich das zehnte Element vorausgewählt werden, muss es heißen:
var defaultIndex = 9;Einen bestimmten Wert auswählen
Falls mit „Wert 10“ nicht der Index, sondern tatsächlich der JSON-Wert
10gemeint ist, ist diese Variante besser:<% var selectid = "mydropdown2"; var dp_write = "javascript.0.Sonstige.Google.Kontakte.Photo.ausgewählt"; var defaultValue = "10"; var currentValue = dp && dp[dp_write] !== undefined ? String(dp[dp_write]) : ""; var availableValues = Array.isArray(data) ? data.map(String) : []; var selectedValue = availableValues.indexOf(currentValue) !== -1 ? currentValue : defaultValue; %>Der restliche Code kann gleich bleiben.
Warum bisher immer der erste Eintrag erschien
Im alten Template wurde
selectednur gesetzt, wenn diese Bedingung wahr war:dp[dp_write] == data[i]War der Datenpunkt leer, noch nicht geladen oder enthielt keinen Wert aus dem JSON-Array, bekam keine Option das Attribut
selected. HTML zeigt dann automatisch das erste Element an.Die obige Lösung bestimmt den ausgewählten Wert deshalb bereits im EJS-Teil und erzeugt beispielsweise:
<option value="10" selected>10</option>Das ist beim ersten sichtbaren Rendern zuverlässiger als eine ausschließlich nachgelagerte JavaScript-Auswahl. Die Lösung berücksichtigt außerdem die dokumentierten Besonderheiten des Widgets:
dataenthält die JSON-Daten, zusätzliche Datenpunkte stehen indp, CSS ist überwidgetidbegrenzt, und die Initialisierung nutztsetTimeout()stattsetInterval(). -
Ich habe mal die wichtigsten KIs das Beispielprompt
aus der KI Dokumentation erstellen lassen
Deutsch
Englisch
Die ersten beiden waren OneShots. Also die KI hat aufgrund der Angaben alles korrekt beim ersten mal erstellt.
ChatGPT hat einen kleinen Syntax Fehler gemacht, der nach dem posten der Fehlermeldung korrigiert wurde. Das hatte was mit dem EJS Template-System und deren Syntaxprüfung zu tun. -
Bei:
dataenthält die JSON-Daten, zusätzliche Datenpunkte stehen indp, CSS ist überwidgetidbegrenzt, und die Initialisierung nutztsetTimeout()stattsetInterval().@OliverIO
Danke für die ausführliche Darstellung.Habe den Code mal genommen mit einem festen Wert.
<% var selectid = "mydropdown2"; var dp_write = "javascript.0.Sonstige.Google.Kontakte.Photo.ausgewählt"; var defaultValue = "Dieter"; var currentValue = dp && dp[dp_write] !== undefined ? String(dp[dp_write]) : ""; var availableValues = Array.isArray(data) ? data.map(String) : []; var selectedValue = availableValues.indexOf(currentValue) !== -1 ? currentValue : defaultValue; %> <script> var jsontemplateSelectId_<%- widgetid %> = "<%- selectid %>"; var jsontemplateWriteDp_<%- widgetid %> = "<%- dp_write %>"; var jsontemplateInitialValue_<%- widgetid %> = "<%- selectedValue %>"; function jsontemplateWriteSelection_<%- widgetid %>(element) { if (!element || element.selectedIndex < 0) { return; } var selectedOption = element.options[element.selectedIndex]; if (!selectedOption) { return; } vis.setValue( jsontemplateWriteDp_<%- widgetid %>, selectedOption.value ); } setTimeout(function () { var element = document.getElementById( jsontemplateSelectId_<%- widgetid %> ); if (!element) { return; } element.value = jsontemplateInitialValue_<%- widgetid %>; /* * Nur schreiben, wenn der DP noch nicht den angezeigten Wert enthält. */ var currentDpValue = "<%- currentValue %>"; if ( element.value && String(currentDpValue) !== String(element.value) ) { vis.setValue( jsontemplateWriteDp_<%- widgetid %>, element.value ); } }, 0); </script> <style> #<%- widgetid %> #<%- selectid %> { color: rgb(255, 255, 255); width: 250px; background: black; font-size: 24px; } </style> <select id="<%- selectid %>" name="<%- selectid %>" size="1" onchange="jsontemplateWriteSelection_<%- widgetid %>(this)" > <% if (Array.isArray(data)) { %> <% for (var i = 0; i < data.length; i++) { %> <% var optionValue = String(data[i]); var isSelected = optionValue === selectedValue; %> <option value="<%- optionValue %>" <%- isSelected ? "selected" : "" %> ><%- optionValue %></option> <% } %> <% } %> </select>Klappt aber nicht. Es wird nur ein Fehler angezeigt.
Würdest du mal drüber schauen.
Danke. -
@OliverIO
Danke. -
dann musst du mir testdaten aus dem datenpunkt bereitstellen
und ein export deines jsontemplate widgets@OliverIO
na klar mach ich das.
anbei
Dies ist der json DP in gekürzter Form:
javascript.0.Sonstige.Google.Kontakte.Photo.Auswahl[ "Ahlbach", "Aissa", "Bender", "Dieter", "Jung", "Küchler", "Wunsch" ]und dies das Widget
[{"tpl":"tplJSONTemplate4","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","json_dpCount":"1","json_scriptCount":"1","json_cssCount":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"json_oid":"javascript.0.Sonstige.Google.Kontakte.Photo.Auswahl","json_template":"<%\n var selectid = \"mydropdown2\";\n var dp_write = \"javascript.0.Sonstige.Google.Kontakte.Photo.ausgewählt\";\n \n /*\n * Gewünschter Eintrag im JSON-Array.\n *\n * Achtung:\n * Arrays beginnen bei Index 0.\n *\n * Index 10 bedeutet somit das 11. Element.\n * Für das 10. Element wäre der Index 9.\n */\n var defaultIndex = 10;\n \n var currentValue = dp && dp[dp_write] !== undefined\n ? String(dp[dp_write])\n : \"\";\n \n var defaultValue = \"\";\n \n if (Array.isArray(data) && data.length > defaultIndex) {\n defaultValue = String(data[defaultIndex]);\n }\n \n /*\n * Wenn im Ziel-Datenpunkt bereits ein gültiger Wert steht,\n * wird dieser angezeigt.\n *\n * Andernfalls wird der gewünschte Standardwert verwendet.\n */\n var selectedValue = currentValue;\n \n if (\n !selectedValue ||\n !Array.isArray(data) ||\n data.map(String).indexOf(selectedValue) === -1\n ) {\n selectedValue = defaultValue;\n }\n%>\n \n<script>\n var jsontemplateSelectId_<%- widgetid %> = \"<%- selectid %>\";\n var jsontemplateWriteDp_<%- widgetid %> = \"<%- dp_write %>\";\n var jsontemplateInitialValue_<%- widgetid %> = \"<%- selectedValue %>\";\n \n function jsontemplateWriteSelection_<%- widgetid %>(element) {\n if (!element || element.selectedIndex < 0) {\n return;\n }\n \n var selectedOption = element.options[element.selectedIndex];\n \n if (!selectedOption) {\n return;\n }\n \n vis.setValue(\n jsontemplateWriteDp_<%- widgetid %>,\n selectedOption.value\n );\n }\n \n setTimeout(function () {\n var element = document.getElementById(\n jsontemplateSelectId_<%- widgetid %>\n );\n \n if (!element) {\n return;\n }\n \n element.value = jsontemplateInitialValue_<%- widgetid %>;\n \n /*\n * Nur schreiben, wenn der DP noch nicht den angezeigten Wert enthält.\n */\n var currentDpValue = \"<%- currentValue %>\";\n \n if (\n element.value &&\n String(currentDpValue) !== String(element.value)\n ) {\n vis.setValue(\n jsontemplateWriteDp_<%- widgetid %>,\n element.value\n );\n }\n }, 0);\n</script>\n \n<style>\n #<%- widgetid %> #<%- selectid %> {\n color: rgb(255, 255, 255);\n width: 250px;\n background: black;\n font-size: 24px;\n }\n</style>\n \n<select\n id=\"<%- selectid %>\"\n name=\"<%- selectid %>\"\n size=\"1\"\n onchange=\"jsontemplateWriteSelection_<%- widgetid %>(this)\"\n>\n <% if (Array.isArray(data)) { %>\n <% for (var i = 0; i < data.length; i++) { %>\n <%\n var optionValue = String(data[i]);\n var isSelected = optionValue === selectedValue;\n %>\n \n <option\n value=\"<%- optionValue %>\"\n <%- isSelected ? \"selected\" : \"\" %>\n ><%- optionValue %></option>\n <% } %>\n <% } %>\n</select>\n","json_dp1":"javascript.0.Sonstige.Google.Kontakte.Photo.ausgewählt"},"style":{"left":"715px","top":"128px","z-index":"2","width":"350px","height":"35px"},"widgetSet":"vis-jsontemplate"}] -
@OliverIO
anbei
[{"tpl":"tplJSONTemplate4","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","json_dpCount":"1","json_scriptCount":"1","json_cssCount":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"json_oid":"javascript.0.Sonstige.Google.Kontakte.Photo.Auswahl","json_template":"<%\n var selectid = \"mydropdown2\";\n var dp_write = \"javascript.0.Sonstige.Google.Kontakte.Photo.ausgewählt\";\n \n /*\n * Gewünschter Eintrag im JSON-Array.\n *\n * Achtung:\n * Arrays beginnen bei Index 0.\n *\n * Index 10 bedeutet somit das 11. Element.\n * Für das 10. Element wäre der Index 9.\n */\n var defaultIndex = 10;\n \n var currentValue = dp && dp[dp_write] !== undefined\n ? String(dp[dp_write])\n : \"\";\n \n var defaultValue = \"\";\n \n if (Array.isArray(data) && data.length > defaultIndex) {\n defaultValue = String(data[defaultIndex]);\n }\n \n /*\n * Wenn im Ziel-Datenpunkt bereits ein gültiger Wert steht,\n * wird dieser angezeigt.\n *\n * Andernfalls wird der gewünschte Standardwert verwendet.\n */\n var selectedValue = currentValue;\n \n if (\n !selectedValue ||\n !Array.isArray(data) ||\n data.map(String).indexOf(selectedValue) === -1\n ) {\n selectedValue = defaultValue;\n }\n%>\n \n<script>\n var jsontemplateSelectId_<%- widgetid %> = \"<%- selectid %>\";\n var jsontemplateWriteDp_<%- widgetid %> = \"<%- dp_write %>\";\n var jsontemplateInitialValue_<%- widgetid %> = \"<%- selectedValue %>\";\n \n function jsontemplateWriteSelection_<%- widgetid %>(element) {\n if (!element || element.selectedIndex < 0) {\n return;\n }\n \n var selectedOption = element.options[element.selectedIndex];\n \n if (!selectedOption) {\n return;\n }\n \n vis.setValue(\n jsontemplateWriteDp_<%- widgetid %>,\n selectedOption.value\n );\n }\n \n setTimeout(function () {\n var element = document.getElementById(\n jsontemplateSelectId_<%- widgetid %>\n );\n \n if (!element) {\n return;\n }\n \n element.value = jsontemplateInitialValue_<%- widgetid %>;\n \n /*\n * Nur schreiben, wenn der DP noch nicht den angezeigten Wert enthält.\n */\n var currentDpValue = \"<%- currentValue %>\";\n \n if (\n element.value &&\n String(currentDpValue) !== String(element.value)\n ) {\n vis.setValue(\n jsontemplateWriteDp_<%- widgetid %>,\n element.value\n );\n }\n }, 0);\n</script>\n \n<style>\n #<%- widgetid %> #<%- selectid %> {\n color: rgb(255, 255, 255);\n width: 250px;\n background: black;\n font-size: 24px;\n }\n</style>\n \n<select\n id=\"<%- selectid %>\"\n name=\"<%- selectid %>\"\n size=\"1\"\n onchange=\"jsontemplateWriteSelection_<%- widgetid %>(this)\"\n>\n <% if (Array.isArray(data)) { %>\n <% for (var i = 0; i < data.length; i++) { %>\n <%\n var optionValue = String(data[i]);\n var isSelected = optionValue === selectedValue;\n %>\n \n <option\n value=\"<%- optionValue %>\"\n <%- isSelected ? \"selected\" : \"\" %>\n ><%- optionValue %></option>\n <% } %>\n <% } %>\n</select>\n","json_dp1":"javascript.0.Sonstige.Google.Kontakte.Photo.ausgewählt"},"style":{"left":"715px","top":"128px","z-index":"2","width":"350px","height":"35px"},"widgetSet":"vis-jsontemplate"}]der widgetexport von dir war leider leer.
kein datenpunkt
kein templatehier nun das getestete template
ich habe die datenpunkte allerdings auf
0_userdata.0.select
und
0_userdata.0.selectwrite
angepasstchatgpt hat auch ein bisschen mehr design und sicherheitsfunktionen dazugemacht
<% var dp_write = "0_userdata.0.selectwrite"; var default_value = "Dieter"; var select_id = widgetid + "_select"; var options = []; var stored_value = ""; var selected_value = ""; function escapeHtml(value) { return String(value) .replace(/&/g, "&") .replace(/</g, "<") .replace(/>/g, ">") .replace(/"/g, """) .replace(/'/g, "'"); } if (Array.isArray(data)) { options = data; } if ( typeof dp !== "undefined" && dp !== null && typeof dp_write === "string" && dp_write !== "" && typeof dp[dp_write] !== "undefined" && dp[dp_write] !== null ) { stored_value = String(dp[dp_write]); } if (stored_value !== "") { selected_value = stored_value; } else { selected_value = String(default_value); } %> <style> #<%- widgetid %> { width: 100%; height: 100%; } #<%- widgetid %> #<%- select_id %> { display: block; box-sizing: border-box; width: 100%; height: 100%; min-height: 36px; margin: 0; padding: 6px 32px 6px 10px; color: #ffffff; background-color: #000000; border: 1px solid #666666; border-radius: 4px; font-family: inherit; font-size: 18px; cursor: pointer; } #<%- widgetid %> #<%- select_id %>:focus { border-color: #ffffff; outline: none; } </style> <select id="<%- select_id %>" data-dp-write="<%- escapeHtml(dp_write) %>" onchange="window['visJsonTemplateSelect_<%- widgetid %>'].writeValue(this)" > <% for (var i = 0; i < options.length; i++) { if ( typeof options[i] !== "undefined" && options[i] !== null ) { var option_value = String(options[i]); %> <option value="<%- escapeHtml(option_value) %>" <% if (option_value === selected_value) { %> selected <% } %> ><%- escapeHtml(option_value) %></option> <% } } %> </select> <script> (function () { var namespace = "visJsonTemplateSelect_<%- widgetid %>"; var selectElement = document.getElementById("<%- select_id %>"); window[namespace] = window[namespace] || {}; if (selectElement) { window[namespace].dpWrite = selectElement.getAttribute("data-dp-write"); } window[namespace].writeValue = function (element) { var targetDp = window[namespace].dpWrite; if ( !element || typeof targetDp !== "string" || targetDp === "" ) { return; } if ( window.vis && typeof window.vis.setValue === "function" ) { window.vis.setValue(targetDp, element.value); } }; })(); </script>hier mein widgetexport
kein datenpunkt
0_userdata.0.select
und
@OliverIO
Warum hat mein Export nicht funktioniert?
Und die DP sind doch immer noch javascript.....
Hast du was falsche eingefügt.Wenn ich dies im edit einfüge kommt:
Im edit und im run funktioniert dies nicht.
Habe ich eine alte Adapter version.
meine ist: 4.4.3mfg
kein datenpunkt
0_userdata.0.select
und
@OliverIO
Habe nun upgedatet auf 4.5.0
Keine Veränderung. -
@bahnuhr
Starte mal dein vis neu,
Mach im Browser Strg + F5Zur Not auf der Kommandozeile
iobroker upload all
Geh doch mal die Sachen von obenDas Widget ID Problem wurde in der vorletzten Version behoben.
Prüfe, ob die Version auch wirklich installiert wurde. Wenn ja, dann liegt es daran, dass vis die Komponente noch nicht aktualisiert hat. -
Probier ich heute mittag aus -
upload all hat geklappt.
Aber müsste sowas nicht beim upload korrekt funktionieren?So, jetzt muss ich das ganze mal beobachten.
Danke erst einmal.
Dieter -
@OliverIO
meine ist: 4.4.3mfg
Scheint soweit zu klappen, super !
noch ne kleine Ergänzungsfrage:
Wenn das template den ausgewählten json DP auf "Dieter" setzt, kann man dann gleichzeigt im DP.write auch "Dieter" reinschreiben.Momentan wird ja nur das json auf "Dieter" gesetzt und angezeigt. Im dp.write passiert ja nix.
