  4. ESP Home Fehlermeldung
    6.8k
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
86 Beiträge 7 Kommentatoren 4.1k Aufrufe 4 Beobachtet
  • simonf04S simonf04
    @Dieter_P sagte:
    Copy to Clipboard
    esphome.0
    2026-07-26 09:16:33.628 warn ESPHome Dashboard stopped
    Mal nach esphome filtern, eventuell auf debug stellen und dann etwas nach oben / unten scrollen. Da gibts sicher noch mehr Logmeldungen 😉
    Dieter_P
    @simonf04 sagte:
    Danke. sieht nicht so aus nach meinen Neustart und das Dashboard funktioniert nicht:
    esphome.0
    	2026-07-26 10:00:13.089	warn	ESPHome Dashboard stopped
    esphome.0
    	2026-07-26 10:00:12.923	warn	Auto Discovery disabled, new devices (or IP changes) will NOT be detected automatically!
    esphome.0
    	2026-07-26 10:00:12.919	info	Starting ESPHome Dashboard
    esphome.0
    	2026-07-26 10:00:12.323	info	Native Integration of ESPHome Dashboard enabled, making environment ready
    esphome.0
    	2026-07-26 10:00:11.548	info	ESPHome client esp32s3-flur on ip 192.168.7.174 initialized
    esphome.0
    	2026-07-26 10:00:11.548	info	esp32s3-flur announced signal_strength "Beacon5 RSSI"
    esphome.0
    	2026-07-26 10:00:11.548	info	esp32s3-flur announced signal_strength "Beacon4 RSSI"
    esphome.0
    	2026-07-26 10:00:11.547	info	esp32s3-flur announced signal_strength "Beacon3 RSSI"
    esphome.0
    	2026-07-26 10:00:11.547	info	esp32s3-flur announced Light "Led"
    esphome.0
    	2026-07-26 10:00:11.546	info	esp32s3-flur announced BinarySensor "Beacon5 Praesenz"
    esphome.0
    	2026-07-26 10:00:11.546	info	esp32s3-flur announced BinarySensor "Beacon4 Praesenz"
    esphome.0
    	2026-07-26 10:00:11.545	info	esp32s3-flur announced BinarySensor "Beacon3 Praesenz"
    esphome.0
    	2026-07-26 10:00:11.544	info	esp32s3-flur announced BinarySensor "Button"
    esphome.0
    	2026-07-26 10:00:11.434	info	ESPHome client 192.168.7.174 connected
    esphome.0
    	2026-07-26 10:00:11.431	info	ESPHome Device info received for esp32s3-flur
    esphome.0
    	2026-07-26 10:00:11.341	info	Try to connect to 192.168.7.174
    esphome.0
    	2026-07-26 10:00:11.244	info	starting. Version 0.7.0 (non-npm: DrozmotiX/ioBroker.esphome#65ee24885cc3bb66cfec885242e31432e3539196) in /opt/iobroker/node_modules/iobroker.esphome, node: v22.23.1, js-controller: 7.2.2
    esphome.0
    	2026-07-26 10:00:06.647	info	terminating
    esphome.0
    	2026-07-26 10:00:06.646	info	terminating
    esphome.0
    	2026-07-26 10:00:06.221	warn	ESPHome client esp32s3-flur | DC5475C8ED08 | on 192.168.7.174 disconnected
    esphome.0
    	2026-07-26 10:00:06.146	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    esphome.0
    	2026-07-26 10:00:06.144	info	terminating
    esphome.0
    	2026-07-26 10:00:06.142	info	Got terminate signal TERMINATE_YOURSELF
    simonf04S 1 Antwort Letzte Antwort
      @Dieter_P sagte:
      Hat mit dem Problem zwar nix zu tun, aber setz den user 'pi' (Warum eigentlich pi?) in die Gruppe adm.
      Ändere den Link auf den Zigbee-Stick auf
      /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
      Zum Problem:
      +-- iobroker.esphome@0.7.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#65ee24885cc3bb66cfec885242e31432e3539196)
      Installier da nix aus dem GitHub gefischtes, sondern eine ordentlich veröffentlichte Version. Gleiches gilt für sourceanalytix. Oder testest du gerade konkret in Absprache mit dem Maintainer brandheißen Code aus diesen Commits? Vermutlich eher nicht.
      Dieter_P
      @Thomas-Braun sagte:
      Zum Problem:
      Hast Du bitte einen Vorschlag. sowohl die vorherige 0.7.0beta4 stammt aus Empfehlung durch @simonf04 der mir sehr nett geholfen hat und glaube ich auch eine Menge dareinsteckt damit der Adapter wieder nutzbar wurde.
      Aus gleichem Weg stammt nun 0.7.0 aber wenn es was neues gibt.
      • D Dieter_P
        Zum Problem:
        simonf04S Offline
        simonf04S Offline
        simonf04
        @Dieter_P sagte:
        0.7.0
        gibts auch ganz normal im beta repo mittlerweile.
        • D Dieter_P
          @simonf04 sagte:
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          esphome.0
          simonf04S Offline
          simonf04S Offline
          simonf04
          @Dieter_P sagte:
          esphome.0
          Mal kurz warten, der installiert dashboard erst beim start. Wenn es eine neue Version gibt kann das beim 1. Start etwas dauern.
          Ansonsten nochmal im log schauen ob was kommt.
            @Dieter_P sagte:
            0.7.0
            Dieter_P
            @simonf04 sagte:
            @Dieter_P sagte:
            0.7.0
            dort als 0.6.3 ? Ist das korrekt? 056d8c72-3ef5-4fb5-8945-191d13423312-image.jpeg
            • D Dieter_P
              @simonf04 sagte:
              @Dieter_P sagte:
              0.7.0
              simonf04S Offline
              simonf04S Offline
              simonf04
              @Dieter_P sagte:
              @simonf04 sagte:
              @Dieter_P sagte:
              0.7.0
              Wenn du Stable als Standard repo hast dann schon im expert Modus, aber per NPM
              HomoranH D 2 Antworten Letzte Antwort
                @Dieter_P sagte:
                @simonf04 sagte:
                @Dieter_P sagte:
                0.7.0
                @simonf04 sagte:
                @dieter_p
                Wenn du gerade erst dein Repo auf latest/beta gestellt hast musst du es neu einlesen
                  @Dieter_P sagte:
                  @simonf04 sagte:
                  @Dieter_P sagte:
                  0.7.0
                  Dieter_P
                  @simonf04 sagte:
                  @simonf04 sagte:
                  Ok Danke. Hab darum temporär aufs beta repo umgestellt statt stable.
                  Ziehe das jetzt mal gerade. Aber die Logs deuten wieder aufs gleiches Problem ohne Logs:
                  esphome.0
                  2026-07-26 10:21:45.476	warn	ESPHome Dashboard stopped
                  esphome.0
                  2026-07-26 10:21:45.306	info	Starting ESPHome Dashboard
                  esphome.0
                  2026-07-26 10:21:44.982	warn	Object DC5475C8ED08.info.area is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, json This will throw an error up from js-controller version 7.0.0!
                  esphome.0
                  2026-07-26 10:21:44.778	info	Native Integration of ESPHome Dashboard enabled, making environment ready
                  esphome.0
                  2026-07-26 10:21:44.465	info	ESPHome client esp32s3-flur on ip 192.168.7.174 initialized
                  esphome.0
                  2026-07-26 10:21:44.464	info	esp32s3-flur announced signal_strength "Beacon5 RSSI"
                  esphome.0
                  2026-07-26 10:21:44.464	info	esp32s3-flur announced signal_strength "Beacon4 RSSI"
                  esphome.0
                  2026-07-26 10:21:44.463	info	esp32s3-flur announced signal_strength "Beacon3 RSSI"
                  esphome.0
                  2026-07-26 10:21:44.462	info	esp32s3-flur announced Light "Led"
                  esphome.0
                  2026-07-26 10:21:44.460	info	esp32s3-flur announced BinarySensor "Beacon5 Praesenz"
                  esphome.0
                  2026-07-26 10:21:44.459	info	esp32s3-flur announced BinarySensor "Beacon4 Praesenz"
                  esphome.0
                  2026-07-26 10:21:44.458	info	esp32s3-flur announced BinarySensor "Beacon3 Praesenz"
                  esphome.0
                  2026-07-26 10:21:44.457	info	esp32s3-flur announced BinarySensor "Button"
                  esphome.0
                  2026-07-26 10:21:44.414	info	ESPHome client 192.168.7.174 connected
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  2026-07-26 10:21:44.342	info	ESPHome Device info received for esp32s3-flur
                  esphome.0
                  2026-07-26 10:21:44.308	info	Try to connect to 192.168.7.174
                  esphome.0
                  2026-07-26 10:21:44.203	info	starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.esphome, node: v22.23.1, js-controller: 7.2.2
                  esphome.0
                  2026-07-26 10:21:39.618	info	terminating
                  esphome.0
                  2026-07-26 10:21:39.617	info	terminating
                  esphome.0
                  2026-07-26 10:21:39.183	warn	ESPHome client esp32s3-flur | DC5475C8ED08 | on 192.168.7.174 disconnected
                  esphome.0
                  2026-07-26 10:21:39.117	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  esphome.0
                  2026-07-26 10:21:39.115	info	terminating
                  esphome.0
                  2026-07-26 10:21:39.112	info	Got terminate signal TERMINATE_YOURSELF
                  Hat das mit Rechten zu tun? Erscheint jetzt statt dem Dashboard:
                  simonf04S 2 Antworten Letzte Antwort
                    @simonf04 sagte:
                    @dieter_p
                    simonf04S Offline
                    simonf04S Offline
                    simonf04
                    @homoran ich vermute mal er hatte Stable.
                    Daher auch der Weg per expert Modus nur diesen einen spezifischen Adapter direkt von npm zu installieren.
                    Da sollte dann doch die letzte genommen werden und nicht die aus stable repo oder?
                    • D Dieter_P
                      @simonf04 sagte:
                      @simonf04 sagte:
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      esphome.0
                      simonf04S Offline
                      simonf04S Offline
                      simonf04
                      @Dieter_P sagte:
                      Wenn du temporär auf beta umstellst, musst aktualisieren wie @homoran meinte.
                      Irgendwie hat er immer noch 0.6.3 hier bei dir.
                      • D Dieter_P
                        @simonf04 sagte:
                        @simonf04 sagte:
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        esphome.0
                        simonf04S Offline
                        simonf04S Offline
                        simonf04
                        @Dieter_P sagte:
                        Nein, kommt einfach weil das dashboard noch nicht gestartet ist.
                        Siehe log:
                        Wenn er gestartet ist, sollte da auch noch eine weitere logmeldung kommen.
                        Schau dass du 0.7.0 hast und gib dem dann bitte einfach mal paar Minuten Zeit.
                          @Dieter_P sagte:
                          @simonf04
                          Aus npm kann man nur eine Version ziehen, die auch ein stable-Release hat. Ist aber beim esphome nicht der Fall:
                          github:	0.7.0
                          latest:	0.7.0 for 69 days
                          stable:	-.-.-
                          Also temporär auf Beta-Repo stellen, Repo neuladen, Adapter installieren, Stable-Repo wieder aktivieren, Repo neuladen.
                            @simonf04
                            github:	0.7.0
                            stable:	-.-.-
                            simonf04S Offline
                            simonf04S Offline
                            simonf04
                            Ok, dann sorry wusst ich nicht. Dachte er nimmt da immer die aktuelle dann.
                            PS: Stable ist eh gerade in Arbeit 😉
                              @simonf04 sagte:
                              Ja!
                              Ich hab`s nur vorsorglich erwähnt, da es nicht jedem bewusst ist, dass das repo nicht automatisch sofort neu geladen wird
                              EDIT:
                              @thomas-braun hat's natürlich vollkommen korrekt beschrieben
                                Dieter_P
                                @simonf04 sagte:
                                🎉 WOW, Danke!. Das heißt es geht in einen offiziellen Support über?
                                Zum Problem:
                                Hab die 0.6.3 deeinstalliert. Repo wieder auf stable und über NPM die 0.7.0 installiert. Soweit unauffällig.
                                Aber das Fehlerbild identisch:
                                Log unauffällig bis auf Dashboard stopped:
                                esphome.0
                                2026-07-26 10:36:47.985	warn	ESPHome Dashboard stopped
                                esphome.0
                                2026-07-26 10:36:47.821	info	Starting ESPHome Dashboard
                                esphome.0
                                2026-07-26 10:36:47.239	info	Native Integration of ESPHome Dashboard enabled, making environment ready
                                esphome.0
                                2026-07-26 10:36:46.819	info	ESPHome client esp32s3-flur on ip 192.168.7.174 initialized
                                esphome.0
                                2026-07-26 10:36:46.818	info	esp32s3-flur announced signal_strength "Beacon5 RSSI"
                                esphome.0
                                2026-07-26 10:36:46.817	info	esp32s3-flur announced signal_strength "Beacon4 RSSI"
                                esphome.0
                                2026-07-26 10:36:46.816	info	esp32s3-flur announced signal_strength "Beacon3 RSSI"
                                esphome.0
                                2026-07-26 10:36:46.814	info	esp32s3-flur announced Light "Led"
                                esphome.0
                                2026-07-26 10:36:46.812	info	esp32s3-flur announced BinarySensor "Beacon5 Praesenz"
                                esphome.0
                                2026-07-26 10:36:46.811	info	esp32s3-flur announced BinarySensor "Beacon4 Praesenz"
                                esphome.0
                                2026-07-26 10:36:46.811	info	esp32s3-flur announced BinarySensor "Beacon3 Praesenz"
                                esphome.0
                                2026-07-26 10:36:46.811	info	esp32s3-flur announced BinarySensor "Button"
                                esphome.0
                                2026-07-26 10:36:46.700	info	ESPHome client 192.168.7.174 connected
                                esphome.0
                                2026-07-26 10:36:46.697	info	ESPHome Device info received for esp32s3-flur
                                esphome.0
                                2026-07-26 10:36:46.576	info	Try to connect to 192.168.7.174
                                esphome.0
                                2026-07-26 10:36:46.474	info	starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.esphome, node: v22.23.1, js-controller: 7.2.2
                                esphome.0
                                2026-07-26 10:36:41.854	info	terminating
                                esphome.0
                                2026-07-26 10:36:41.853	info	terminating
                                esphome.0
                                2026-07-26 10:36:41.429	warn	ESPHome client esp32s3-flur | DC5475C8ED08 | on 192.168.7.174 disconnected
                                esphome.0
                                2026-07-26 10:36:41.353	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                und das Dashboard mit der Meldung (192.168.7.20 ist mein IOB):
                                Es erscheint kurz das ESPHome Logo und wird dann ersetzt:
                                simonf04S HomoranH 2 Antworten Letzte Antwort
                                • D Dieter_P
                                  @simonf04 sagte:
                                  Zum Problem:
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  esphome.0
                                  simonf04S Offline
                                  simonf04S Offline
                                  simonf04
                                  @Dieter_P sagte:
                                  Naja was heißt hier "offiziellen Support".
                                  99% der iobroker Adapter sind noch immer community erstellt und maintained. Gibt quasi keinen "offiziellen Support".
                                  Heist nur das eine Version schon bei genügend Leuten läuft und als somit stabil angesehen wird.
                                  Damit auch installierbar ohne auf beta umzustellen.
                                  Neue Funktionen werden in Zukunft immer dann voher im beta landen zum testen und wenn keine Probleme gemeldet, nach einiger Zeit auch "stable".
                                  • D Dieter_P
                                    @simonf04 sagte:
                                    Zum Problem:
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    esphome.0
                                    @Dieter_P sagte:
                                    Auch latest/Beta ist im offiziellen Support.
                                    Falls du die Meldung "nicht gewartet" meinst, bezieht die sich bei dir auf deine stable Einstellung im Repo.
                                    Dort ist es "nicht gewartet"
                                      @Dieter_P sagte:
                                      Dieter_P
                                      @simonf04 sagte:
                                      Keine Ahnung, aber mein subjektiver Eindruck war in den letzten Jahren eher das der Adapter praktisch stirbt. Er existiert auf Github und wenn es massiv brennt, hast zB Du dich drumgekümmert. Wenn etwas im stable Repo steht gehört das für mich schon zum Standardporfolio und man darf auch mal wieder eine Frage stellen ohne sofort Gegängelt zu werden was man da für ein wildes Zeug installiert hat. Aber das ist mein subjektiver Eindruck.
                                        @Dieter_P sagte:
                                        simonf04S Offline
                                        simonf04S Offline
                                        simonf04
                                        @Homoran sagte:
                                        Im Sinne von vom Adapter Entwickler "offiziell" Supportet ist auch beta/latest.
                                        Meinte nur / wollte klarstellen das stable nicht heißt "iobroker core team" (wenn man es so nenen kann) kümmert sich drum.
                                        Verantwortung für Wartung liegt weiterhin ganz normal beim Adapter Entwickler.
                                        • simonf04S Offline
                                          simonf04S Offline
                                          simonf04
                                          schrieb am zuletzt editiert von simonf04
                                          @dieter_p bitte mal in den Adapter Einstellungen erstmal auf Dashboard version 2026.6.5 und pillow 12.3.0 gehen, scheint so als hätte esphome mal wieder was kaputt gemacht ...
                                          PS: wenn die Stable dann drausen ist, ist ein größeres Update / Umbau geplant. In dem Zuge ist auch was geplant um das Problem in Zukunft endlich hoffentlich etwas zu verbessern.
