  4. ESP Home Fehlermeldung
    6.8k
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
86 Beiträge 7 Kommentatoren 4.1k Aufrufe 4 Beobachtet
  • D Dieter_P
    @simonf04 sagte:
    Da gibts sicher noch mehr Logmeldungen 😉
    Danke. sieht nicht so aus nach meinen Neustart und das Dashboard funktioniert nicht:
    esphome.0
    	2026-07-26 10:00:13.089	warn	ESPHome Dashboard stopped
    esphome.0
    	2026-07-26 10:00:12.923	warn	Auto Discovery disabled, new devices (or IP changes) will NOT be detected automatically!
    esphome.0
    	2026-07-26 10:00:12.919	info	Starting ESPHome Dashboard
    esphome.0
    	2026-07-26 10:00:12.323	info	Native Integration of ESPHome Dashboard enabled, making environment ready
    esphome.0
    	2026-07-26 10:00:11.548	info	ESPHome client esp32s3-flur on ip 192.168.7.174 initialized
    esphome.0
    	2026-07-26 10:00:11.548	info	esp32s3-flur announced signal_strength "Beacon5 RSSI"
    esphome.0
    	2026-07-26 10:00:11.548	info	esp32s3-flur announced signal_strength "Beacon4 RSSI"
    esphome.0
    	2026-07-26 10:00:11.547	info	esp32s3-flur announced signal_strength "Beacon3 RSSI"
    esphome.0
    	2026-07-26 10:00:11.547	info	esp32s3-flur announced Light "Led"
    esphome.0
    	2026-07-26 10:00:11.546	info	esp32s3-flur announced BinarySensor "Beacon5 Praesenz"
    esphome.0
    	2026-07-26 10:00:11.546	info	esp32s3-flur announced BinarySensor "Beacon4 Praesenz"
    esphome.0
    	2026-07-26 10:00:11.545	info	esp32s3-flur announced BinarySensor "Beacon3 Praesenz"
    esphome.0
    	2026-07-26 10:00:11.544	info	esp32s3-flur announced BinarySensor "Button"
    esphome.0
    	2026-07-26 10:00:11.434	info	ESPHome client 192.168.7.174 connected
    esphome.0
    	2026-07-26 10:00:11.431	info	ESPHome Device info received for esp32s3-flur
    esphome.0
    	2026-07-26 10:00:11.341	info	Try to connect to 192.168.7.174
    esphome.0
    	2026-07-26 10:00:11.244	info	starting. Version 0.7.0 (non-npm: DrozmotiX/ioBroker.esphome#65ee24885cc3bb66cfec885242e31432e3539196) in /opt/iobroker/node_modules/iobroker.esphome, node: v22.23.1, js-controller: 7.2.2
    esphome.0
    	2026-07-26 10:00:06.647	info	terminating
    esphome.0
    	2026-07-26 10:00:06.646	info	terminating
    esphome.0
    	2026-07-26 10:00:06.221	warn	ESPHome client esp32s3-flur | DC5475C8ED08 | on 192.168.7.174 disconnected
    esphome.0
    	2026-07-26 10:00:06.146	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    esphome.0
    	2026-07-26 10:00:06.144	info	terminating
    esphome.0
    	2026-07-26 10:00:06.142	info	Got terminate signal TERMINATE_YOURSELF
    simonf04S Offline
    simonf04S Offline
    simonf04
    @Dieter_P sagte:
    esphome.0
    Mal kurz warten, der installiert dashboard erst beim start. Wenn es eine neue Version gibt kann das beim 1. Start etwas dauern.
    Ansonsten nochmal im log schauen ob was kommt.
    • simonf04S simonf04
      @Dieter_P sagte:
      0.7.0
      gibts auch ganz normal im beta repo mittlerweile.
      Dieter_P
      @simonf04 sagte:
      @Dieter_P sagte:
      0.7.0
      dort als 0.6.3 ? Ist das korrekt? 056d8c72-3ef5-4fb5-8945-191d13423312-image.jpeg
      simonf04S 1 Antwort Letzte Antwort
      • D Dieter_P
        @simonf04 sagte:
        @Dieter_P sagte:
        0.7.0
        simonf04S Offline
        simonf04S Offline
        simonf04
        @Dieter_P sagte:
        @simonf04 sagte:
        @Dieter_P sagte:
        0.7.0
        Wenn du Stable als Standard repo hast dann schon im expert Modus, aber per NPM
        HomoranH D 2 Antworten Letzte Antwort
          @Dieter_P sagte:
          @simonf04 sagte:
          @Dieter_P sagte:
          0.7.0
          @simonf04 sagte:
          @dieter_p
          Wenn du gerade erst dein Repo auf latest/beta gestellt hast musst du es neu einlesen
            @Dieter_P sagte:
            @simonf04 sagte:
            @Dieter_P sagte:
            0.7.0
            Dieter_P
            @simonf04 sagte:
            @simonf04 sagte:
            Ok Danke. Hab darum temporär aufs beta repo umgestellt statt stable.
            Ziehe das jetzt mal gerade. Aber die Logs deuten wieder aufs gleiches Problem ohne Logs:
            esphome.0
            2026-07-26 10:21:45.476	warn	ESPHome Dashboard stopped
            esphome.0
            2026-07-26 10:21:45.306	info	Starting ESPHome Dashboard
            esphome.0
            2026-07-26 10:21:44.982	warn	Object DC5475C8ED08.info.area is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, json This will throw an error up from js-controller version 7.0.0!
            esphome.0
            2026-07-26 10:21:44.778	info	Native Integration of ESPHome Dashboard enabled, making environment ready
            esphome.0
            2026-07-26 10:21:44.465	info	ESPHome client esp32s3-flur on ip 192.168.7.174 initialized
            esphome.0
            2026-07-26 10:21:44.464	info	esp32s3-flur announced signal_strength "Beacon5 RSSI"
            esphome.0
            2026-07-26 10:21:44.464	info	esp32s3-flur announced signal_strength "Beacon4 RSSI"
            esphome.0
            2026-07-26 10:21:44.463	info	esp32s3-flur announced signal_strength "Beacon3 RSSI"
            esphome.0
            2026-07-26 10:21:44.462	info	esp32s3-flur announced Light "Led"
            esphome.0
            2026-07-26 10:21:44.460	info	esp32s3-flur announced BinarySensor "Beacon5 Praesenz"
            esphome.0
            2026-07-26 10:21:44.459	info	esp32s3-flur announced BinarySensor "Beacon4 Praesenz"
            esphome.0
            2026-07-26 10:21:44.458	info	esp32s3-flur announced BinarySensor "Beacon3 Praesenz"
            esphome.0
            2026-07-26 10:21:44.457	info	esp32s3-flur announced BinarySensor "Button"
            esphome.0
            2026-07-26 10:21:44.414	info	ESPHome client 192.168.7.174 connected
            esphome.0
            esphome.0
            esphome.0
            esphome.0
            esphome.0
            esphome.0
            esphome.0
            esphome.0
            esphome.0
            esphome.0
            esphome.0
            2026-07-26 10:21:44.342	info	ESPHome Device info received for esp32s3-flur
            esphome.0
            2026-07-26 10:21:44.308	info	Try to connect to 192.168.7.174
            esphome.0
            2026-07-26 10:21:44.203	info	starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.esphome, node: v22.23.1, js-controller: 7.2.2
            esphome.0
            2026-07-26 10:21:39.618	info	terminating
            esphome.0
            2026-07-26 10:21:39.617	info	terminating
            esphome.0
            2026-07-26 10:21:39.183	warn	ESPHome client esp32s3-flur | DC5475C8ED08 | on 192.168.7.174 disconnected
            esphome.0
            2026-07-26 10:21:39.117	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            esphome.0
            2026-07-26 10:21:39.115	info	terminating
            esphome.0
            2026-07-26 10:21:39.112	info	Got terminate signal TERMINATE_YOURSELF
            Hat das mit Rechten zu tun? Erscheint jetzt statt dem Dashboard:
            simonf04S 2 Antworten Letzte Antwort
              @simonf04 sagte:
              @dieter_p
              simonf04S Offline
              simonf04S Offline
              simonf04
              @homoran ich vermute mal er hatte Stable.
              Daher auch der Weg per expert Modus nur diesen einen spezifischen Adapter direkt von npm zu installieren.
              Da sollte dann doch die letzte genommen werden und nicht die aus stable repo oder?
              • D Dieter_P
                @simonf04 sagte:
                @simonf04 sagte:
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                esphome.0
                simonf04S Offline
                simonf04S Offline
                simonf04
                @Dieter_P sagte:
                Wenn du temporär auf beta umstellst, musst aktualisieren wie @homoran meinte.
                Irgendwie hat er immer noch 0.6.3 hier bei dir.
                • D Dieter_P
                  @simonf04 sagte:
                  @simonf04 sagte:
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  esphome.0
                  simonf04S Offline
                  simonf04S Offline
                  simonf04
                  @Dieter_P sagte:
                  Nein, kommt einfach weil das dashboard noch nicht gestartet ist.
                  Siehe log:
                  Wenn er gestartet ist, sollte da auch noch eine weitere logmeldung kommen.
                  Schau dass du 0.7.0 hast und gib dem dann bitte einfach mal paar Minuten Zeit.
                    @Dieter_P sagte:
                    @simonf04
                    Aus npm kann man nur eine Version ziehen, die auch ein stable-Release hat. Ist aber beim esphome nicht der Fall:
                    github:	0.7.0
                    latest:	0.7.0 for 69 days
                    stable:	-.-.-
                    Also temporär auf Beta-Repo stellen, Repo neuladen, Adapter installieren, Stable-Repo wieder aktivieren, Repo neuladen.
                      @simonf04
                      github:	0.7.0
                      stable:	-.-.-
                      simonf04S Offline
                      simonf04S Offline
                      simonf04
                      @Thomas-Braun sagte:
                      Ok, dann sorry wusst ich nicht. Dachte er nimmt da immer die aktuelle dann.
                      PS: Stable ist eh gerade in Arbeit 😉
                        @simonf04 sagte:
                        Ja!
                        Ich hab`s nur vorsorglich erwähnt, da es nicht jedem bewusst ist, dass das repo nicht automatisch sofort neu geladen wird
                        EDIT:
                        @thomas-braun hat's natürlich vollkommen korrekt beschrieben
                          Dieter_P
                          @simonf04 sagte:
                          🎉 WOW, Danke!. Das heißt es geht in einen offiziellen Support über?
                          Zum Problem:
                          Hab die 0.6.3 deeinstalliert. Repo wieder auf stable und über NPM die 0.7.0 installiert. Soweit unauffällig.
                          Aber das Fehlerbild identisch:
                          Log unauffällig bis auf Dashboard stopped:
                          esphome.0
                          2026-07-26 10:36:47.985	warn	ESPHome Dashboard stopped
                          esphome.0
                          2026-07-26 10:36:47.821	info	Starting ESPHome Dashboard
                          esphome.0
                          2026-07-26 10:36:47.239	info	Native Integration of ESPHome Dashboard enabled, making environment ready
                          esphome.0
                          2026-07-26 10:36:46.819	info	ESPHome client esp32s3-flur on ip 192.168.7.174 initialized
                          esphome.0
                          2026-07-26 10:36:46.818	info	esp32s3-flur announced signal_strength "Beacon5 RSSI"
                          esphome.0
                          2026-07-26 10:36:46.817	info	esp32s3-flur announced signal_strength "Beacon4 RSSI"
                          esphome.0
                          2026-07-26 10:36:46.816	info	esp32s3-flur announced signal_strength "Beacon3 RSSI"
                          esphome.0
                          2026-07-26 10:36:46.814	info	esp32s3-flur announced Light "Led"
                          esphome.0
                          2026-07-26 10:36:46.812	info	esp32s3-flur announced BinarySensor "Beacon5 Praesenz"
                          esphome.0
                          2026-07-26 10:36:46.811	info	esp32s3-flur announced BinarySensor "Beacon4 Praesenz"
                          esphome.0
                          2026-07-26 10:36:46.811	info	esp32s3-flur announced BinarySensor "Beacon3 Praesenz"
                          esphome.0
                          2026-07-26 10:36:46.811	info	esp32s3-flur announced BinarySensor "Button"
                          esphome.0
                          2026-07-26 10:36:46.700	info	ESPHome client 192.168.7.174 connected
                          esphome.0
                          2026-07-26 10:36:46.697	info	ESPHome Device info received for esp32s3-flur
                          esphome.0
                          2026-07-26 10:36:46.576	info	Try to connect to 192.168.7.174
                          esphome.0
                          2026-07-26 10:36:46.474	info	starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.esphome, node: v22.23.1, js-controller: 7.2.2
                          esphome.0
                          2026-07-26 10:36:41.854	info	terminating
                          esphome.0
                          2026-07-26 10:36:41.853	info	terminating
                          esphome.0
                          2026-07-26 10:36:41.429	warn	ESPHome client esp32s3-flur | DC5475C8ED08 | on 192.168.7.174 disconnected
                          esphome.0
                          2026-07-26 10:36:41.353	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          und das Dashboard mit der Meldung (192.168.7.20 ist mein IOB):
                          Es erscheint kurz das ESPHome Logo und wird dann ersetzt:
                          simonf04S HomoranH 2 Antworten Letzte Antwort
                          • D Dieter_P
                            @simonf04 sagte:
                            Zum Problem:
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            esphome.0
                            simonf04S Offline
                            simonf04S Offline
                            simonf04
                            @Dieter_P sagte:
                            Naja was heißt hier "offiziellen Support".
                            99% der iobroker Adapter sind noch immer community erstellt und maintained. Gibt quasi keinen "offiziellen Support".
                            Heist nur das eine Version schon bei genügend Leuten läuft und als somit stabil angesehen wird.
                            Damit auch installierbar ohne auf beta umzustellen.
                            Neue Funktionen werden in Zukunft immer dann voher im beta landen zum testen und wenn keine Probleme gemeldet, nach einiger Zeit auch "stable".
                            • D Dieter_P
                              @simonf04 sagte:
                              Zum Problem:
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              esphome.0
                              @Dieter_P sagte:
                              Auch latest/Beta ist im offiziellen Support.
                              Falls du die Meldung "nicht gewartet" meinst, bezieht die sich bei dir auf deine stable Einstellung im Repo.
                              Dort ist es "nicht gewartet"
                                @Dieter_P sagte:
                                Dieter_P
                                @simonf04 sagte:
                                Keine Ahnung, aber mein subjektiver Eindruck war in den letzten Jahren eher das der Adapter praktisch stirbt. Er existiert auf Github und wenn es massiv brennt, hast zB Du dich drumgekümmert. Wenn etwas im stable Repo steht gehört das für mich schon zum Standardporfolio und man darf auch mal wieder eine Frage stellen ohne sofort Gegängelt zu werden was man da für ein wildes Zeug installiert hat. Aber das ist mein subjektiver Eindruck.
                                  @Dieter_P sagte:
                                  simonf04S Offline
                                  simonf04S Offline
                                  simonf04
                                  @Homoran sagte:
                                  Im Sinne von vom Adapter Entwickler "offiziell" Supportet ist auch beta/latest.
                                  Meinte nur / wollte klarstellen das stable nicht heißt "iobroker core team" (wenn man es so nenen kann) kümmert sich drum.
                                  Verantwortung für Wartung liegt weiterhin ganz normal beim Adapter Entwickler.
                                  • simonf04S Offline
                                    simonf04S Offline
                                    simonf04
                                    schrieb am zuletzt editiert von simonf04
                                    @dieter_p bitte mal in den Adapter Einstellungen erstmal auf Dashboard version 2026.6.5 und pillow 12.3.0 gehen, scheint so als hätte esphome mal wieder was kaputt gemacht ...
                                    PS: wenn die Stable dann drausen ist, ist ein größeres Update / Umbau geplant. In dem Zuge ist auch was geplant um das Problem in Zukunft endlich hoffentlich etwas zu verbessern.
                                      Dieter_P
                                      @simonf04 sagte:
                                      Danke. Gemäß log taucht nun kein Dashboard stopped mehr auf und er scheint auch was installiert initialisiert zu haben. Aber die Verbindung wird weiterhin das abgelehnt.
                                      esphome.0
                                      2026-07-26 11:00:45.588	info	[ESPHome - Console] 2026-07-26 11:00:45,587 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /opt/iobroker/iobroker-data/esphome.0...
                                      esphome.0
                                      2026-07-26 11:00:45.250	info	Starting ESPHome Dashboard
                                      esphome.0
                                      2026-07-26 10:59:33.882	info	Native Integration of ESPHome Dashboard enabled, making environment ready
                                      esphome.0
                                      2026-07-26 10:59:33.480	info	ESPHome client esp32s3-flur on ip 192.168.7.174 initialized
                                      esphome.0
                                      2026-07-26 10:59:33.480	info	esp32s3-flur announced signal_strength "Beacon5 RSSI"
                                      esphome.0
                                      2026-07-26 10:59:33.479	info	esp32s3-flur announced signal_strength "Beacon4 RSSI"
                                      esphome.0
                                      2026-07-26 10:59:33.479	info	esp32s3-flur announced signal_strength "Beacon3 RSSI"
                                      esphome.0
                                      2026-07-26 10:59:33.478	info	esp32s3-flur announced Light "Led"
                                      esphome.0
                                      2026-07-26 10:59:33.477	info	esp32s3-flur announced BinarySensor "Beacon5 Praesenz"
                                      esphome.0
                                      2026-07-26 10:59:33.477	info	esp32s3-flur announced BinarySensor "Beacon4 Praesenz"
                                      esphome.0
                                      2026-07-26 10:59:33.476	info	esp32s3-flur announced BinarySensor "Beacon3 Praesenz"
                                      esphome.0
                                      2026-07-26 10:59:33.475	info	esp32s3-flur announced BinarySensor "Button"
                                      esphome.0
                                      2026-07-26 10:59:33.359	info	ESPHome Device info received for esp32s3-flur
                                      esphome.0
                                      2026-07-26 10:59:33.352	info	ESPHome client 192.168.7.174 connected
                                      esphome.0
                                      2026-07-26 10:59:33.231	info	Try to connect to 192.168.7.174
                                      esphome.0
                                      2026-07-26 10:59:33.133	info	starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.esphome, node: v22.23.1, js-controller: 7.2.2
                                      esphome.0
                                      2026-07-26 10:59:28.434	info	terminating
                                      esphome.0
                                      2026-07-26 10:59:28.433	info	terminating
                                      esphome.0
                                      2026-07-26 10:59:28.002	warn	ESPHome client esp32s3-flur | DC5475C8ED08 | on 192.168.7.174 disconnected
                                      esphome.0
                                      2026-07-26 10:59:27.932	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      esphome.0
                                      2026-07-26 10:59:27.930	info	terminating
                                      esphome.0
                                      2026-07-26 10:59:27.928	info	Got terminate signal TERMINATE_YOURSELF
                                      @simonf04 sagte:
                                      Danke. Das sind gute Neuigkeiten für mich. Nach den wiederholten Problemen jetzt, war ich heute Morgen schon dabei 2,3 Rasperry Zero zu ordern und ESPHome endgültig rauszuwerfen. Das war so einfach nicht pragmatisch für mich.
                                      • D Dieter_P
                                        @simonf04 sagte:
                                        @Dieter_P sagte:
                                        Du wirst nicht gegängelt, du wirst darauf verwiesen, dass GitHub NIICHT die erste Adresse für Installationen ist. Man nimmt die Installationen in der Reihenfolge STABLE -> BETA/LATEST -> GitHub vor.
                                        Weil nämlich im GitHub 'irgendein Stand' vorhanden sein kann und nur der Committer weiß, was da drin liegt. (Oder du liest die Commits/den Code, aber das wird vermutlich in den seltensten Fällen getan).
                                        • D Dieter_P
                                          @simonf04 sagte:
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          esphome.0
                                          @simonf04 sagte:
                                          simonf04S Offline
                                          simonf04S Offline
                                          simonf04
                                          @Dieter_P sagte:
                                          Naja, die Verbindung war ja meist nicht das Problem.
                                          Nur das dashboard ist etwas mühselig. "Always latest" ist etwas gefährlich hier. Am besten einfach eine fixe Version setzten, dann sollte es auch weniger Probleme geben.
                                          Solang du die neuen Funktionen der neuen Versionen nicht brauchst (und keine security Probleme in esphome gefunden werden - was auch SEHR selten nur passiert) musst man auch nicht immer auf der neusten Version sein.
