ioBroker-Matter Adapter
Angeheftet
Gesperrt
Verschoben
ioBroker Allgemein
Kommentatoren
25.0k
Aufrufe
31
Beobachtet
0.4.15
- Added Button display and control in the UI
- Updates matter.js to optimize and add persisted subscriptions
- Fixed states-list initializations for controller states
- Fixed initialization issue when initial device connection for controller was not finished
- Adjusted connection display when reconnecting to a node to red in UI
0.5.0
- IMPORTANT: Increase Node.js requirement to at least 20.x because else BLE currently does not work
- (@Apollon77) Added info log message when device decided for a different subscription interval
- (@GermanBluefox) Added expert mode to GUI
- (@GermanBluefox) GUI optimizations
- (@Apollon77) Upgrade Matter support to 1.4
- (@Apollon77) Upgrade type detector and usage for better automatic detection results
- (@Apollon77) Included Battery state in attribute polling and changed default interval to 24h if device is battery bowered
- (@Apollon77) Shows subscription maximum interval of the node in the connection-infos
- (@Apollon77) Allows to overwrite the default subscription maximum interval send to the device in Node settings
- (@Apollon77) Considers also the BatteryAlarm state of Smoke-CO sensors when determine LOWBAT state
- (@Apollon77) Updates the connection state of Controller devices as soon as alive triggers or data updates come in
- (@Apollon77) For Lock devices the SET state is synced with ACTUAL
0.5.1
- (@Apollon77) Updated matter.js to 0.14 with many performance- and other improvements
0.5.2 (2025-08-03)
- (@Apollon77) Updated matter.js to 0.15.2 with many performance- and other improvements
- (@GermanBluefox) Corrected the checking of the licenses if they were stacked
- (Apollon77) Use attributes from cache instead of requesting them from the device
- (Apollon77) Ignoring invalid min/max for color temperature from objects
- (Apollon77) Prevents update loops for Thermostat on/off state changes
- (Apollon77) Fixes invalid color state updates when multiple attributes are adjusted together
- (Apollon77) Rounds RSSI values to prevent digits
0.5.4 (2025-10-07)
- (@Apollon77) Updated matter.js to 0.15.5
0.5.3 (2025-09-20)
- (@Apollon77) Updated matter.js to 0.15.4
0.5.5 (2025-10-16)
- (@Apollon77) Optimizes Battery drain information
- (@Apollon77) Correctly shows "in progress changes" in UI when adjusting devices to ovoid overlapping actions
- (@Apollon77) Fix HSV to RGB calculation for some cases
- (@Apollon77) Updated matter.js to 0.15.6
- (@Apollon77) Optimizes shutdown process to ensure everything is properly closed
0.5.6 (2025-10-21)
- (@Apollon77) Type detector update, should detect single states in non-device structures better
1.0.0 (2026-02-25)
- IMPORTANT: The first start of the controller with this version takes a bit longer to connect all devices because internal data are migrated
- (@Apollon77) Updated to Matter 1.4.2 (matter.js to 0.16) including many optimizations and fixes
- (@Apollon77) Also convert values for unit "mired" for Color temperatures
- (@Apollon77) Increases default color temperature range to 1.000-20.000 K
- (@Apollon77) Added support for OTA updates (checked roughly 15 mins after adapter start and then daily)
- (@Apollon77) Added Thread and Wifi topology overview with data from the devices. See Readme for details.
- (@Apollon77) Detect duplicate commands/writes and prevent them from being sent out again if the first command is still in progress
- (@GermanBluefox) Highlight the devices in GUI when hovering over the device in the device list
- (@tarikweiss) Added support for volume, volumeGroup ioBroker devices to matter
- (@Tyraenor/Apollon77) Add Off mode for Thermostats for Matter devices
1.2.0 (2026-06-27)
- (@Apollon77) Enhanced Thread/WiFi network visualization: OTBR mDNS discovery, device-type and Thread role icons, border-router details and markers, LQI link colors, hide/search options and localized labels
- (@Apollon77) Ignores invalid min/max/step settings in linked objects
- (@Apollon77) Improve state detection to respect the selected state id
- (@Apollon77) Update to matter.js 0.17.4-alpha including many optimizations and fixes
1.1.1 (2026-06-22)
- (@Apollon77) Fixes Update availability flag in UI
1.1.0 (2026-06-22)
- (@GermanBluefox) Update to Device management v3 and more dependencies
- (@Apollon77) Update to Matter 1.5.1 (matter.js 0.17.3) including many optimizations and fixes
- (@Apollon77) Parallelizing the startup of controller and devices and optimize subscription resumptions
- (@Apollon77) Fixes detection of 0_userdata.0 objects again
- (@Apollon77) Fixes handling of special attributes (e.g. startupOnOff) when null and add relevant States lists
- (@Apollon77) Fixes handling if custom attribute states
- (@Apollon77) Fixes calculation of illuminance when measurements are <=0 (aka fully dark)
- (@Apollon77) Fixes initialization of HCI IDs when using BLE
Sooo ... heute kommt die 1.3.0 mit Matter 1.6.0 support und fixes. Wenn alles passt geht die dann erstmal in Stable und die nächsten tage kommen neue Gerätetypen und features
1.3.0 (2026-07-19)
- (@Apollon77) Update to Matter 1.6.0 (matter.js 0.17.7-alpha)
- (@Apollon77) Optimized Matter data processing by caching repeated cluster/attribute lookups in hot paths
- (@Apollon77) Only register additional custom attributes when the node supports them
- (@Apollon77) Prevent errors when controlling paired devices that do not expose On/Off commands
1.2.1 (2026-06-29)
- (@Apollon77) Fix Thermostat and WindowCovering state update errors
- (@Apollon77) Update to the latest matter.js 0.17.4-alpha including MDNS/CPU usage fixes
1.3.1 (2026-07-23)
- (@Apollon77) Fix Attribute Polling
- (@Apollon77) Fix Commissioning of new nodes
