  4. Test adapter blackmagic-atem 0.2.9 @github
    6.8k
2 Beiträge 2 Kommentatoren 85 Aufrufe 2 Beobachtet
    AlanSRU
    This adapter controls Blackmagic Design ATEM video mixers over the network. It uses the reverse-engineered ATEM UDP protocol via the atem-connection library, and supports 21+ model variants — from ATEM Mini through Television Studio to Constellation 4K+ — with capability-based state creation that adapts to the connected device.
    Features
    Program/Preview switching — change program and preview inputs
    Transitions — Cut, Auto, manual T-bar; Mix / Dip / Wipe / DVE / Sting styles with per-style rates
    Fade to Black — toggle and configure FTB rate
    Upstream Keyers (up to 4 per M/E) — on air, type, fill/key source, mask, fly
    Downstream Keyers (up to 4) — on air, tie, auto, rate, fill/key source
    Aux outputs (up to 48) — source routing
    Audio Mixer — master gain/balance, monitor, per-input gain/balance/mix (Classic + Fairlight)
    Color Generators — hue/saturation/luminance
    Streaming — start/stop, status, cache used (supported models)
    Recording — start/stop, switch disk, duration, remaining space (supported models)
    Media Players — source type, still/clip index, playback control
    Tally — program/preview tally state
    Macros — run, stop, continue, loop, named slots (up to 100)
    Input metadata — short/long names, port type
    Auto model detection — capabilities discovered from the connected device
    Requirements
    js-controller >= 6.0.11
    ioBroker Admin >= 7.6.20
    Node.js >= 22
    Blackmagic ATEM switcher with network connectivity
    • mcm1957M Offline
      mcm1957M Offline
      mcm1957
      Der Adapter ist schon im LATEST Repository.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • Samson71S Samson71 verschob dieses Thema von ...nicht in offiziellem Repo am
