<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Test adapter blackmagic-atem 0.2.9 @github]]></title><description><![CDATA[<p dir="auto">This adapter controls Blackmagic Design ATEM video mixers over the network. It uses the reverse-engineered ATEM UDP protocol via the atem-connection library, and supports 21+ model variants — from ATEM Mini through Television Studio to Constellation 4K+ — with capability-based state creation that adapts to the connected device.</p>
<p dir="auto">Features<br />
Program/Preview switching — change program and preview inputs<br />
Transitions — Cut, Auto, manual T-bar; Mix / Dip / Wipe / DVE / Sting styles with per-style rates<br />
Fade to Black — toggle and configure FTB rate<br />
Upstream Keyers (up to 4 per M/E) — on air, type, fill/key source, mask, fly<br />
Downstream Keyers (up to 4) — on air, tie, auto, rate, fill/key source<br />
Aux outputs (up to 48) — source routing<br />
Audio Mixer — master gain/balance, monitor, per-input gain/balance/mix (Classic + Fairlight)<br />
Color Generators — hue/saturation/luminance<br />
Streaming — start/stop, status, cache used (supported models)<br />
Recording — start/stop, switch disk, duration, remaining space (supported models)<br />
Media Players — source type, still/clip index, playback control<br />
Tally — program/preview tally state<br />
Macros — run, stop, continue, loop, named slots (up to 100)<br />
Input metadata — short/long names, port type<br />
Auto model detection — capabilities discovered from the connected device</p>
<p dir="auto">Requirements</p>
<p dir="auto">js-controller &gt;= 6.0.11<br />
ioBroker Admin &gt;= 7.6.20<br />
Node.js &gt;= 22<br />
Blackmagic ATEM switcher with network connectivity</p>
]]></description><link>https://forum.iobroker.net/topic/84998/test-adapter-blackmagic-atem-0.2.9-@github</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Jul 2026 03:12:02 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/84998.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jul 2026 19:09:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Test adapter blackmagic-atem 0.2.9 @github on Fri, 17 Jul 2026 21:09:25 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Der Adapter ist schon im LATEST Repository.</strong></p>
]]></description><link>https://forum.iobroker.net/post/1348477</link><guid isPermaLink="true">https://forum.iobroker.net/post/1348477</guid><dc:creator><![CDATA[mcm1957]]></dc:creator><pubDate>Fri, 17 Jul 2026 21:09:25 GMT</pubDate></item></channel></rss>
