Test lovelace 6.x
@garfonso
Hast du eine Idee weshalb der Adapter nach dem Update immer crashed?
Danke für deine Hilfe!2026-06-23 22:25:29.391 - debug: lovelace.0 (424395) Create manual binary_sensor device: binary_sensor.Fenster_Alle_Fenster_geschlossen - 0_userdata.0.Fenster.Alle_Fenster_geschlossen 2026-06-23 22:25:29.391 - debug: lovelace.0 (424395) Create manual sensor device: sensor.Fenster_Alle_Fenster_geschlossen_seit - 0_userdata.0.Fenster.Alle_Fenster_geschlossen_seit 2026-06-23 22:25:29.391 - debug: lovelace.0 (424395) Create manual input_boolean device: input_boolean.Fenster_Alle_Fenster_Status_ueberschreiben - 0_userdata.0.Fenster.Alle_Fenster_Status_überschreiben 2026-06-23 22:25:29.392 - debug: lovelace.0 (424395) Create manual alarm_control_panel device: alarm_control_panel.defaultAlarm - lovelace.0.control.alarm 2026-06-23 22:25:29.408 - debug: lovelace.0 (424395) Stored old values for next switch on: {"rgb_color":null,"color_mode":null} 2026-06-23 22:25:29.411 - debug: lovelace.0 (424395) Stored old values for next switch on: {"hs_color":null,"color_mode":null} 2026-06-23 22:25:29.540 - debug: lovelace.0 (424395) Stored old values for next switch on: {"color_mode":null} 2026-06-23 22:25:29.548 - debug: lovelace.0 (424395) Restored old values from previous switch off: {"friendly_name":"EG Flur Licht Schalter","assumed_state":false,"has_time":false,"has_date":true,"supported_color_modes":["onoff"],"color_mode":"onoff"} 2026-06-23 22:25:29.618 - debug: lovelace.0 (424395) Stored old values for next switch on: {"color_mode":null} 2026-06-23 22:25:30.527 - info: lovelace.0 (424395) Subscribing to all states (449 > 50) and filtering in the adapter. 2026-06-23 22:25:30.527 - debug: lovelace.0 (424395) entitiesUpdated for startup. 2026-06-23 22:25:30.527 - debug: lovelace.0 (424395) entities: init done 2026-06-23 22:25:30.534 - debug: lovelace.0 (424395) Initialization done. 2026-06-23 22:25:30.732 - debug: lovelace.0 (424395) HASS Auth: no_token 2026-06-23 22:25:30.739 - debug: lovelace.0 (424395) supported_features message: {"coalesce_messages":1} 2026-06-23 22:25:30.740 - debug: lovelace.0 (424395) Subscribe entities: { "type": "subscribe_entities", "id": 2 } 2026-06-23 22:25:30.745 - debug: lovelace.0 (424395) HASS Subscribe: entity_registry_updated 2026-06-23 22:25:30.746 - debug: lovelace.0 (424395) HASS Subscribe: device_registry_updated 2026-06-23 22:25:30.746 - debug: lovelace.0 (424395) HASS Subscribe: area_registry_updated 2026-06-23 22:25:30.746 - debug: lovelace.0 (424395) HASS Subscribe: floor_registry_updated 2026-06-23 22:25:30.747 - debug: lovelace.0 (424395) HASS Subscribe: component_loaded 2026-06-23 22:25:30.747 - debug: lovelace.0 (424395) HASS Subscribe: core_config_updated 2026-06-23 22:25:30.748 - debug: lovelace.0 (424395) HASS Subscribe: service_registered 2026-06-23 22:25:30.749 - debug: lovelace.0 (424395) HASS Subscribe: service_removed 2026-06-23 22:25:30.749 - debug: lovelace.0 (424395) HASS Subscribe: panels_updated 2026-06-23 22:25:30.749 - debug: lovelace.0 (424395) HASS Subscribe: themes_updated 2026-06-23 22:25:30.751 - debug: lovelace.0 (424395) HASS Subscribe: repairs_issue_registry_updated 2026-06-23 22:25:30.751 - debug: lovelace.0 (424395) HASS Subscribe: component_loaded 2026-06-23 22:25:30.752 - debug: lovelace.0 (424395) Instance 38d1d300-6668a151 connected. 2026-06-23 22:25:30.752 - debug: lovelace.0 (424395) HASS Subscribe: lovelace_updated 2026-06-23 22:25:30.754 - debug: lovelace.0 (424395) New notification subscription 22 2026-06-23 22:25:30.767 - debug: lovelace.0 (424395) get config: {"type":"lovelace/config","url_path":"lovelace","force":false,"id":38} 2026-06-23 22:25:30.768 - debug: lovelace.0 (424395) Get translations: de 2026-06-23 22:25:30.769 - debug: lovelace.0 (424395) Get translations: de 2026-06-23 22:25:30.774 - error: lovelace.0 (424395) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2026-06-23 22:25:30.774 - error: lovelace.0 (424395) unhandled promise rejection: Cannot read properties of undefined (reading 'undefined') 2026-06-23 22:25:30.775 - error: lovelace.0 (424395) TypeError: Cannot read properties of undefined (reading 'undefined') at AreaRegistry._createEntryFromRoom (/opt/iobroker/node_modules/iobroker.lovelace/build/lib/modules/areaRegistry.js:46:59) at /opt/iobroker/node_modules/iobroker.lovelace/build/lib/modules/areaRegistry.js:60:59 at Array.map () at AreaRegistry._sortedEntries (/opt/iobroker/node_modules/iobroker.lovelace/build/lib/modules/areaRegistry.js:60:43) at AreaRegistry.processMessage (/opt/iobroker/node_modules/iobroker.lovelace/build/lib/modules/areaRegistry.js:81:46) at WebSocket. (/opt/iobroker/node_modules/iobroker.lovelace/build/lib/server.js:2597:82) at process.processTicksAndRejections (node:internal/process/task_queues:103:5) 2026-06-23 22:25:30.775 - error: lovelace.0 (424395) Cannot read properties of undefined (reading 'undefined') 2026-06-23 22:25:30.777 - info: lovelace.0 (424395) cleaned everything up... 2026-06-23 22:25:30.778 - debug: lovelace.0 (424395) cleaning up entity registry 2026-06-23 22:25:30.778 - debug: lovelace.0 (424395) cleaning up dashboards 2026-06-23 22:25:31.278 - info: lovelace.0 (424395) terminating 2026-06-23 22:25:31.280 - warn: lovelace.0 (424395) Terminated (UNCAUGHT_EXCEPTION): Without reason 2026-06-23 22:25:31.280 - info: lovelace.0 (424395) terminating 2026-06-23 22:25:31.907 - error: host.iobroker instance system.adapter.lovelace.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2026-06-23 22:25:31.907 - info: host.iobroker Restart adapter system.adapter.lovelace.0 because enabled -
@Garfonso
Neueste 6.0.4
Danke für den Tipp mit den Räumen. Die nutze ich nicht wirklich.
Hatte dort zusätzlich eine seltsame Struktur. "enum.EG..Raum" - die 2 Punkte hintereinander war das was mir sofort aufgefallen war. Aber keine Ahnung ob es daran lag. Ich habe seltsame Räume gelöscht und nun funktioniert alles. Danke!
Ansonsten läuft die neue Version bisher super und sieht gut aus! -
@Garfonso
Neueste 6.0.4
@garfonso "State-Klasse" auf einem State muss ich setzen damit das im Energie-Dashboard richtig erkannt wird?
Nein, nicht unbedingt. Bei mir hat er alles, was mit
sensormit Geräteklasse Strom angeboten. Ich bin mir offen gestanden nicht ganz sicher, ob das Frontend diesesstateAttribut überhaupt auswertet oder ob das bei HomeAssistant für das Backend benötigt wird. Jedenfalls hat er bei mir auch ohne State zu setzen was getan, was sinnvoll aussieht. schulterzuck//Edit: ok, hab nochmal mehr damit rumgespielt. Für einen Zähler, der zB. verbrauchte kWh hochzählt muss die Geräteklasse auf "Energie" stehen. Für einen aktuellen Wert (Watt) muss dort "Leistung" stehen. Was in "state" steht, scheint das dashboard mehr oder weniger zu ignorieren. Hm.
//Edit 2: ich versuch das select da zu Verbessern.. das ist ja schlimm so. ;-)
Hy,
Frage: gibst die Möglichkeit einen "Button" anzulegen? also ich bräuchte halt eine Taster, der ein Script triggert :)
MikeHy,
MikeÄhm.. klar.. ? Was genau meinst du mit "skript triggert"?
Du kannst ein Skript starten/stoppen, indem du das Objektjavascript.#.scriptEnabled.ggfOrdner.skriptNameauftrue/falsestellst. "Triggern" könnte jetzt sein, dass das Skript beim start durchläuft und wenn es fertig ist seinen eigenen State da wieder auffalseändert. Da hab ich einige Skript, die das so machen. Da könntest du dann einfach für das Objekt ein manuelles Entity anlegen. Da bietet sich dann "Automation" an, macht da jemand auf github so.Weiß nicht, wo da dein Problem liegt.
Ansonsten werden Skripte auch oft durch state Änderungen getriggert. Die kannst du natürlich auch erzeugen. Du kannst auch einen Knopf erzeugen, der einen State immer auf einen bestimmten Wert setzt. Das könnte so aussehen:
- type: button name: Alles aus entity: switch.Alles_Aus tap_action: action: call-service service: switch.turn_off service_data: entity_id: switch.Alles_AusAlso hier immer nur
falsesetzen (turn_off). Gibt auch services, wo man den Werte mitgeben kann (z.B. bei Lampen Helligkeit oder so). Mittlerweile lässt sich sowas auch im UI zusammen klicken. -
Ja da hab ich mich unklar ausgedrückt.. sorry dafür..
Ich habe Objekte die als Button definiert sind (z.B. zum setzten von Presets,... diese Buttons werden in Scripts verwendet.. daher auch meine schlechte Wortwahl...)
Diese hätte ich gerne in Lovelace..
Ähnlich wie das aber ohne die "Schiebeschalter" sondern eben nur Buttons :)
EDIT:
Der tipp mit dem button war aber hilfreich:
habs mal so hinbekommen :)
Mike
EDIT:
Mike
Das geht auch in einer entities Karte, so z.B.:
(geht wohl mittlerweile sogar über den UI-Editor). -> also type button in entities. Dann kriegt man da so nen Knopf ans Ende. :-)
Aber die buttons kann man mit den Stacks ja auch gut sortieren. -
Mi Chrome erhalte ich nun auf einmal viele Warungen. Bei jedem Zugriff.
Nicht mit Mozilla & Safari
LL 6.1.1Cookies etc bereits gelöscht. Chrome neu gestartet.
Auch Ordner lovelace.0.instances.[object Object] gelöscht -> wird wieder angelegt2026-07-14 09:40:48.687 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object] changed to lovelace.0.instances._object Object_ 2026-07-14 09:40:48.689 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].path changed to lovelace.0.instances._object Object_.path 2026-07-14 09:40:48.690 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].visible changed to lovelace.0.instances._object Object_.visible 2026-07-14 09:40:48.691 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].activity changed to lovelace.0.instances._object Object_.activity 2026-07-14 09:40:48.692 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].more_info changed to lovelace.0.instances._object Object_.more_info 2026-07-14 09:40:48.693 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].toast changed to lovelace.0.instances._object Object_.toast 2026-07-14 09:40:48.694 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].popup changed to lovelace.0.instances._object Object_.popup 2026-07-14 09:40:48.695 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].popup_close changed to lovelace.0.instances._object Object_.popup_close 2026-07-14 09:40:48.696 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].refresh changed to lovelace.0.instances._object Object_.refresh 2026-07-14 09:40:48.696 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].blackout changed to lovelace.0.instances._object Object_.blackout 2026-07-14 09:40:48.697 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].set_theme changed to lovelace.0.instances._object Object_.set_theme 2026-07-14 09:40:48.698 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].console changed to lovelace.0.instances._object Object_.console 2026-07-14 09:40:48.699 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].change_browser_id changed to lovelace.0.instances._object Object_.change_browser_id 2026-07-14 09:40:48.701 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].change_browser_id" has no existing object, this might lead to an error in future versions 2026-07-14 09:40:48.703 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].online changed to lovelace.0.instances._object Object_.online 2026-07-14 09:40:48.704 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].hideHeader changed to lovelace.0.instances._object Object_.hideHeader 2026-07-14 09:40:48.705 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].hideSidebar changed to lovelace.0.instances._object Object_.hideSidebar 2026-07-14 09:40:48.707 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].path" has no existing object, this might lead to an error in future versions 2026-07-14 09:40:48.710 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].visible" has no existing object, this might lead to an error in future versions 2026-07-14 09:40:49.953 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object] changed to lovelace.0.instances._object Object_ 2026-07-14 09:40:49.954 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].path changed to lovelace.0.instances._object Object_.path 2026-07-14 09:40:49.955 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].visible changed to lovelace.0.instances._object Object_.visible 2026-07-14 09:40:49.956 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].activity changed to lovelace.0.instances._object Object_.activity 2026-07-14 09:40:49.957 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].more_info changed to lovelace.0.instances._object Object_.more_info 2026-07-14 09:40:49.958 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].toast changed to lovelace.0.instances._object Object_.toast 2026-07-14 09:40:49.959 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].popup changed to lovelace.0.instances._object Object_.popup 2026-07-14 09:40:49.960 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].popup_close changed to lovelace.0.instances._object Object_.popup_close 2026-07-14 09:40:49.962 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].refresh changed to lovelace.0.instances._object Object_.refresh 2026-07-14 09:40:49.963 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].blackout changed to lovelace.0.instances._object Object_.blackout 2026-07-14 09:40:49.964 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].set_theme changed to lovelace.0.instances._object Object_.set_theme 2026-07-14 09:40:49.965 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].console changed to lovelace.0.instances._object Object_.console 2026-07-14 09:40:49.965 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].change_browser_id changed to lovelace.0.instances._object Object_.change_browser_id 2026-07-14 09:40:49.968 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].change_browser_id" has no existing object, this might lead to an error in future versions 2026-07-14 09:40:49.970 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].online changed to lovelace.0.instances._object Object_.online 2026-07-14 09:40:49.971 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].hideHeader changed to lovelace.0.instances._object Object_.hideHeader 2026-07-14 09:40:49.972 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].hideSidebar changed to lovelace.0.instances._object Object_.hideSidebar 2026-07-14 09:40:49.974 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].path" has no existing object, this might lead to an error in future versions 2026-07-14 09:40:49.977 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].visible" has no existing object, this might lead to an error in future versionsHaben auch andere das Problem? Bug oder liegt das an mir?
@Supernils
zeigt dir das Frontend denn grundsätzlich eine Historie für den Datenpunkt an?aus der History oder der Influxdatenbank
Aus das was du in den Instanzeinstellungen eingestellt hast. :-)
In der Version 5.xx war es ein History Graph gewesen.
Das hat nichts mit influx <-> history zu tun. Der Adapter kann bisher nur mit einer einzelnen Datenquelle für historische Werte sprechen und die gibt man in den Instanzeinstellungen an.
Bei HomeAssistant / Lovelace selber hat sich an der Stelle allerdings einiges getan. Das Frontend fordert jetzt viele Berechnungen direkt beim Backend an, was sicherlich sinnvoll ist, aber da kann durchaus noch etwas krumm sein.
Grundsätzlich Chrome oder nur der eine Chrome? Guck mal, ob du in nem Privaten Window auch das Problem hast...
Sonst liegt da im Browser-Store eine kaputte ID.
Ich hab lovelace gepatcht, so dass sie die ID repariert, in Zukunft.
Vermutlich werden die Instanz-Objekte jetzt nicht gehen für den Browser. Du kannst im Browser die Browser-Mod-Settings aufrufen und da die ID ändern (mal global hideSidebar ausmachen). Dann sollte es hoffentlich wieder gehen. (Alternativen: chrome zeug löschen lassen, von Hand über die entwikler-optionen den localStorage bearbeiten und da browser_mod sachen löschen).//Edit: hab meinen Chrome gefunden. Hab das Problem hier nicht.
@Supernils
@garfonso
Ja.
{ "_id": "alias.0.Energie.Stromzaehler.ISTLEISTUNG", "common": { "name": "ISTLEISTUNG", "role": "value.power", "type": "number", "unit": "W", "read": true, "write": false, "alias": { "id": "mqtt.1.tele.tasmota_89B8D8.SENSOR", "read": "JSON.parse(val).SGM.Power" }, "custom": { "lovelace.0": { "enabled": true, "attr_has_time": false, "attr_has_date": true, "entity": "sensor", "name": "Energie_Stromzaehler_ISTLEISTUNG", "attr_unit_of_measurement": "W", "attr_device_class": "power", "attr_state_class": "measurement" }, "sql.0": { "enabled": true, "storageType": "", "counter": false, "aliasId": "", "debounceTime": 0, "blockTime": 0, "changesOnly": true, "changesRelogInterval": "0", "changesMinDelta": "0", "ignoreBelowNumber": "", "disableSkippedValueLogging": false, "retention": 31536000, "customRetentionDuration": 365, "maxLength": 50, "enableDebugLogs": false, "debounce": "1000", "ignoreZero": false } } }, "type": "state", "native": {}, "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" }, "from": "system.adapter.admin.0", "user": "system.user.admin", "ts": 1784053453110 } -
@Garfonso
über Browser Mods eine andere ID gewählt funktioniert nun wieder.die 2 anderen konnte ich aber nicht löschen. Da erscheint nur ein leeres Popup.
"entwikler-optionen den localStorage bearbeiten" -> das habe ich nicht gefundenDanke dir!
@Supernils
Kurze Frage, ich musste erstmal auf V5 zurückrollen, da bei den Lichtern der Status nicht mehr geändert wurde bei Betätigung der Lichtschalter, Actuals wird scheinbar ignoriert. Ich habe auch schon versucht den Actuals Datenpunkt zu löschen und neu anzulegen, hat aber nichts geändert. Würde mich freuen wenn das in einer der nächsten Versionen noch behoben wird. Oder ich einen Tip bekomme wie ich es lösen kann :-)
