  4. Test lovelace 6.x
    6.3k
Test lovelace 6.x
39 Beiträge 7 Kommentatoren 4.4k Aufrufe 9 Beobachtet
    andi2055
    @garfonso
    Hast du eine Idee weshalb der Adapter nach dem Update immer crashed?
    Danke für deine Hilfe!
    2026-06-23 22:25:29.391 - debug: lovelace.0 (424395) Create manual binary_sensor device: binary_sensor.Fenster_Alle_Fenster_geschlossen - 0_userdata.0.Fenster.Alle_Fenster_geschlossen
    2026-06-23 22:25:29.391 - debug: lovelace.0 (424395) Create manual sensor device: sensor.Fenster_Alle_Fenster_geschlossen_seit - 0_userdata.0.Fenster.Alle_Fenster_geschlossen_seit
    2026-06-23 22:25:29.391 - debug: lovelace.0 (424395) Create manual input_boolean device: input_boolean.Fenster_Alle_Fenster_Status_ueberschreiben - 0_userdata.0.Fenster.Alle_Fenster_Status_überschreiben
    2026-06-23 22:25:29.392 - debug: lovelace.0 (424395) Create manual alarm_control_panel device: alarm_control_panel.defaultAlarm - lovelace.0.control.alarm
    2026-06-23 22:25:29.408 - debug: lovelace.0 (424395) Stored old values for next switch on: {"rgb_color":null,"color_mode":null}
    2026-06-23 22:25:29.411 - debug: lovelace.0 (424395) Stored old values for next switch on: {"hs_color":null,"color_mode":null}
    2026-06-23 22:25:29.540 - debug: lovelace.0 (424395) Stored old values for next switch on: {"color_mode":null}
    2026-06-23 22:25:29.548 - debug: lovelace.0 (424395) Restored old values from previous switch off: {"friendly_name":"EG Flur Licht Schalter","assumed_state":false,"has_time":false,"has_date":true,"supported_color_modes":["onoff"],"color_mode":"onoff"}
    2026-06-23 22:25:29.618 - debug: lovelace.0 (424395) Stored old values for next switch on: {"color_mode":null}
    2026-06-23 22:25:30.527 - info: lovelace.0 (424395) Subscribing to all states (449 > 50) and filtering in the adapter.
    2026-06-23 22:25:30.527 - debug: lovelace.0 (424395) entitiesUpdated for startup.
    2026-06-23 22:25:30.527 - debug: lovelace.0 (424395) entities: init done
    2026-06-23 22:25:30.534 - debug: lovelace.0 (424395) Initialization done.
    2026-06-23 22:25:30.732 - debug: lovelace.0 (424395) HASS Auth: no_token
    2026-06-23 22:25:30.739 - debug: lovelace.0 (424395) supported_features message: {"coalesce_messages":1}
    2026-06-23 22:25:30.740 - debug: lovelace.0 (424395) Subscribe entities: {
    "type": "subscribe_entities",
    "id": 2
    2026-06-23 22:25:30.745 - debug: lovelace.0 (424395) HASS Subscribe: entity_registry_updated
    2026-06-23 22:25:30.746 - debug: lovelace.0 (424395) HASS Subscribe: device_registry_updated
    2026-06-23 22:25:30.746 - debug: lovelace.0 (424395) HASS Subscribe: area_registry_updated
    2026-06-23 22:25:30.746 - debug: lovelace.0 (424395) HASS Subscribe: floor_registry_updated
    2026-06-23 22:25:30.747 - debug: lovelace.0 (424395) HASS Subscribe: component_loaded
    2026-06-23 22:25:30.747 - debug: lovelace.0 (424395) HASS Subscribe: core_config_updated
    2026-06-23 22:25:30.748 - debug: lovelace.0 (424395) HASS Subscribe: service_registered
    2026-06-23 22:25:30.749 - debug: lovelace.0 (424395) HASS Subscribe: service_removed
    2026-06-23 22:25:30.749 - debug: lovelace.0 (424395) HASS Subscribe: panels_updated
    2026-06-23 22:25:30.749 - debug: lovelace.0 (424395) HASS Subscribe: themes_updated
    2026-06-23 22:25:30.751 - debug: lovelace.0 (424395) HASS Subscribe: repairs_issue_registry_updated
    2026-06-23 22:25:30.751 - debug: lovelace.0 (424395) HASS Subscribe: component_loaded
    2026-06-23 22:25:30.752 - debug: lovelace.0 (424395) Instance 38d1d300-6668a151 connected.
    2026-06-23 22:25:30.752 - debug: lovelace.0 (424395) HASS Subscribe: lovelace_updated
    2026-06-23 22:25:30.754 - debug: lovelace.0 (424395) New notification subscription 22
    2026-06-23 22:25:30.767 - debug: lovelace.0 (424395) get config: {"type":"lovelace/config","url_path":"lovelace","force":false,"id":38}
    2026-06-23 22:25:30.768 - debug: lovelace.0 (424395) Get translations: de
    2026-06-23 22:25:30.769 - debug: lovelace.0 (424395) Get translations: de
    2026-06-23 22:25:30.774 - error: lovelace.0 (424395) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2026-06-23 22:25:30.774 - error: lovelace.0 (424395) unhandled promise rejection: Cannot read properties of undefined (reading 'undefined')
    2026-06-23 22:25:30.775 - error: lovelace.0 (424395) TypeError: Cannot read properties of undefined (reading 'undefined')
    at AreaRegistry._createEntryFromRoom (/opt/iobroker/node_modules/iobroker.lovelace/build/lib/modules/areaRegistry.js:46:59)
    at /opt/iobroker/node_modules/iobroker.lovelace/build/lib/modules/areaRegistry.js:60:59
    at Array.map ()
    at AreaRegistry._sortedEntries (/opt/iobroker/node_modules/iobroker.lovelace/build/lib/modules/areaRegistry.js:60:43)
    at AreaRegistry.processMessage (/opt/iobroker/node_modules/iobroker.lovelace/build/lib/modules/areaRegistry.js:81:46)
    at WebSocket. (/opt/iobroker/node_modules/iobroker.lovelace/build/lib/server.js:2597:82)
    at process.processTicksAndRejections (node:internal/process/task_queues:103:5)
    2026-06-23 22:25:30.775 - error: lovelace.0 (424395) Cannot read properties of undefined (reading 'undefined')
    2026-06-23 22:25:30.777 - info: lovelace.0 (424395) cleaned everything up...
    2026-06-23 22:25:30.778 - debug: lovelace.0 (424395) cleaning up entity registry
    2026-06-23 22:25:30.778 - debug: lovelace.0 (424395) cleaning up dashboards
    2026-06-23 22:25:31.278 - info: lovelace.0 (424395) terminating
    2026-06-23 22:25:31.280 - warn: lovelace.0 (424395) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2026-06-23 22:25:31.280 - info: lovelace.0 (424395) terminating
    2026-06-23 22:25:31.907 - error: host.iobroker instance system.adapter.lovelace.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2026-06-23 22:25:31.907 - info: host.iobroker Restart adapter system.adapter.lovelace.0 because enabled
    GarfonsoG 1 Antwort Letzte Antwort
    • A andi2055
      @garfonso
      "id": 2
      at Array.map ()
      GarfonsoG Offline
      GarfonsoG Offline
      Garfonso
      @andi2055
      Irgendwas an deinen Räumen gefällt ihm nicht.
      Welche Version?
      Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
      Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
      • GarfonsoG Garfonso
        @andi2055
        Welche Version?
        andi2055
        @Garfonso
        Neueste 6.0.4
        Danke für den Tipp mit den Räumen. Die nutze ich nicht wirklich.
        Hatte dort zusätzlich eine seltsame Struktur. "enum.EG..Raum" - die 2 Punkte hintereinander war das was mir sofort aufgefallen war. Aber keine Ahnung ob es daran lag. Ich habe seltsame Räume gelöscht und nun funktioniert alles. Danke!
        Ansonsten läuft die neue Version bisher super und sieht gut aus!
        • A andi2055
          @Garfonso
          Neueste 6.0.4
          GarfonsoG Offline
          GarfonsoG Offline
          Garfonso
          @andi2055
          Danke für die Rückmeldung. Die nächste Version wird (hoffentlich) nicht mehr crashen bei sowas. Aber die zwei Punkte sind kritisch, ja. ;-)
          • nograxN Online
            nograxN Online
            nograx
            @garfonso "State-Klasse" auf einem State muss ich setzen damit das im Energie-Dashboard richtig erkannt wird?
            • nograxN nograx
              GarfonsoG Offline
              GarfonsoG Offline
              Garfonso
              schrieb am zuletzt editiert von Garfonso
              @nograx
              Nein, nicht unbedingt. Bei mir hat er alles, was mit sensor mit Geräteklasse Strom angeboten. Ich bin mir offen gestanden nicht ganz sicher, ob das Frontend dieses state Attribut überhaupt auswertet oder ob das bei HomeAssistant für das Backend benötigt wird. Jedenfalls hat er bei mir auch ohne State zu setzen was getan, was sinnvoll aussieht. schulterzuck
              //Edit: ok, hab nochmal mehr damit rumgespielt. Für einen Zähler, der zB. verbrauchte kWh hochzählt muss die Geräteklasse auf "Energie" stehen. Für einen aktuellen Wert (Watt) muss dort "Leistung" stehen. Was in "state" steht, scheint das dashboard mehr oder weniger zu ignorieren. Hm.
              //Edit 2: ich versuch das select da zu Verbessern.. das ist ja schlimm so. ;-)
              • m1k3f15hM Offline
                m1k3f15hM Offline
                m1k3f15h
                Hy,
                Frage: gibst die Möglichkeit einen "Button" anzulegen? also ich bräuchte halt eine Taster, der ein Script triggert :)
                Mike
                ioBroker Multihostsystem in Docker-Container auf Raspi's mit Redis-Sentinel als States und Objects DB
                Aktuell am Aufbau einer Lovelace Visu
                Deye SUN-12K + 10 kWp Module + 2 x 10 kWh MeritSun PowerWall
                Mammotion Yuka
                • m1k3f15hM m1k3f15h
                  Hy,
                  Mike
                  GarfonsoG Offline
                  GarfonsoG Offline
                  Garfonso
                  @m1k3f15h sagte:
                  Hy,
                  Mike
                  Ähm.. klar.. ? Was genau meinst du mit "skript triggert"?
                  Du kannst ein Skript starten/stoppen, indem du das Objekt javascript.#.scriptEnabled.ggfOrdner.skriptName auf true/false stellst. "Triggern" könnte jetzt sein, dass das Skript beim start durchläuft und wenn es fertig ist seinen eigenen State da wieder auf false ändert. Da hab ich einige Skript, die das so machen. Da könntest du dann einfach für das Objekt ein manuelles Entity anlegen. Da bietet sich dann "Automation" an, macht da jemand auf github so.
                  Weiß nicht, wo da dein Problem liegt.
                  Ansonsten werden Skripte auch oft durch state Änderungen getriggert. Die kannst du natürlich auch erzeugen. Du kannst auch einen Knopf erzeugen, der einen State immer auf einen bestimmten Wert setzt. Das könnte so aussehen:
                  - type: button
                    entity: switch.Alles_Aus
                    tap_action:
                       action: call-service
                       service: switch.turn_off
                       service_data:
                          entity_id: switch.Alles_Aus
                  Also hier immer nur false setzen (turn_off). Gibt auch services, wo man den Werte mitgeben kann (z.B. bei Lampen Helligkeit oder so). Mittlerweile lässt sich sowas auch im UI zusammen klicken.
                  • m1k3f15hM Offline
                    m1k3f15hM Offline
                    m1k3f15h
                    schrieb am zuletzt editiert von m1k3f15h
                    Ja da hab ich mich unklar ausgedrückt.. sorry dafür..
                    Ich habe Objekte die als Button definiert sind (z.B. zum setzten von Presets,... diese Buttons werden in Scripts verwendet.. daher auch meine schlechte Wortwahl...)
                    Diese hätte ich gerne in Lovelace..
                    Ähnlich wie das aber ohne die "Schiebeschalter" sondern eben nur Buttons :)
                    EDIT:
                    Der tipp mit dem button war aber hilfreich:
                    habs mal so hinbekommen :)
                    Mike
                    Mammotion Yuka
                      EDIT:
                      Mike
                      GarfonsoG Offline
                      GarfonsoG Offline
                      Garfonso
                      @m1k3f15h
                      Das geht auch in einer entities Karte, so z.B.:
                      (geht wohl mittlerweile sogar über den UI-Editor). -> also type button in entities. Dann kriegt man da so nen Knopf ans Ende. :-)
                      Aber die buttons kann man mit den Stacks ja auch gut sortieren.
                      • m1k3f15hM Offline
                        m1k3f15hM Offline
                        m1k3f15h
                        Hab mich mal etwas mit den Notifications gespielt.. leider Legt er mir immer zwei gleiche an wenn ich den DP lovelace.0.notifications.add beschreibe... hab das problem nur ich?
                        v6.1.1
                        mike
                        Mammotion Yuka
                          andi2055
                          schrieb am zuletzt editiert von andi2055
                          Mi Chrome erhalte ich nun auf einmal viele Warungen. Bei jedem Zugriff.
                          Nicht mit Mozilla & Safari
                          LL 6.1.1
                          Cookies etc bereits gelöscht. Chrome neu gestartet.
                          Auch Ordner lovelace.0.instances.[object Object] gelöscht -> wird wieder angelegt
                          2026-07-14 09:40:48.687 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object] changed to lovelace.0.instances._object Object_
                          2026-07-14 09:40:48.689 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].path changed to lovelace.0.instances._object Object_.path
                          2026-07-14 09:40:48.690 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].visible changed to lovelace.0.instances._object Object_.visible
                          2026-07-14 09:40:48.691 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].activity changed to lovelace.0.instances._object Object_.activity
                          2026-07-14 09:40:48.692 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].more_info changed to lovelace.0.instances._object Object_.more_info
                          2026-07-14 09:40:48.693 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].toast changed to lovelace.0.instances._object Object_.toast
                          2026-07-14 09:40:48.694 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].popup changed to lovelace.0.instances._object Object_.popup
                          2026-07-14 09:40:48.695 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].popup_close changed to lovelace.0.instances._object Object_.popup_close
                          2026-07-14 09:40:48.696 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].refresh changed to lovelace.0.instances._object Object_.refresh
                          2026-07-14 09:40:48.696 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].blackout changed to lovelace.0.instances._object Object_.blackout
                          2026-07-14 09:40:48.697 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].set_theme changed to lovelace.0.instances._object Object_.set_theme
                          2026-07-14 09:40:48.698 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].console changed to lovelace.0.instances._object Object_.console
                          2026-07-14 09:40:48.699 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].change_browser_id changed to lovelace.0.instances._object Object_.change_browser_id
                          2026-07-14 09:40:48.701 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].change_browser_id" has no existing object, this might lead to an error in future versions
                          2026-07-14 09:40:48.703 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].online changed to lovelace.0.instances._object Object_.online
                          2026-07-14 09:40:48.704 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].hideHeader changed to lovelace.0.instances._object Object_.hideHeader
                          2026-07-14 09:40:48.705 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].hideSidebar changed to lovelace.0.instances._object Object_.hideSidebar
                          2026-07-14 09:40:48.707 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].path" has no existing object, this might lead to an error in future versions
                          2026-07-14 09:40:48.710 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].visible" has no existing object, this might lead to an error in future versions
                          2026-07-14 09:40:49.953 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object] changed to lovelace.0.instances._object Object_
                          2026-07-14 09:40:49.954 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].path changed to lovelace.0.instances._object Object_.path
                          2026-07-14 09:40:49.955 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].visible changed to lovelace.0.instances._object Object_.visible
                          2026-07-14 09:40:49.956 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].activity changed to lovelace.0.instances._object Object_.activity
                          2026-07-14 09:40:49.957 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].more_info changed to lovelace.0.instances._object Object_.more_info
                          2026-07-14 09:40:49.958 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].toast changed to lovelace.0.instances._object Object_.toast
                          2026-07-14 09:40:49.959 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].popup changed to lovelace.0.instances._object Object_.popup
                          2026-07-14 09:40:49.960 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].popup_close changed to lovelace.0.instances._object Object_.popup_close
                          2026-07-14 09:40:49.962 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].refresh changed to lovelace.0.instances._object Object_.refresh
                          2026-07-14 09:40:49.963 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].blackout changed to lovelace.0.instances._object Object_.blackout
                          2026-07-14 09:40:49.964 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].set_theme changed to lovelace.0.instances._object Object_.set_theme
                          2026-07-14 09:40:49.965 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].console changed to lovelace.0.instances._object Object_.console
                          2026-07-14 09:40:49.965 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].change_browser_id changed to lovelace.0.instances._object Object_.change_browser_id
                          2026-07-14 09:40:49.968 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].change_browser_id" has no existing object, this might lead to an error in future versions
                          2026-07-14 09:40:49.970 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].online changed to lovelace.0.instances._object Object_.online
                          2026-07-14 09:40:49.971 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].hideHeader changed to lovelace.0.instances._object Object_.hideHeader
                          2026-07-14 09:40:49.972 - warn: lovelace.0 (268814) Used invalid characters: lovelace.0.instances.[object Object].hideSidebar changed to lovelace.0.instances._object Object_.hideSidebar
                          2026-07-14 09:40:49.974 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].path" has no existing object, this might lead to an error in future versions
                          2026-07-14 09:40:49.977 - warn: lovelace.0 (268814) State "lovelace.0.instances.[object Object].visible" has no existing object, this might lead to an error in future versions
                          Haben auch andere das Problem? Bug oder liegt das an mir?
                            @nograx
                            Supernils
                            @Garfonso Bei mir funktioniert die aktuelle Leistung nicht. Was mache ich falsch?
                            GarfonsoG 2 Antworten Letzte Antwort
                              StephanH
                              schrieb am zuletzt editiert von StephanH
                              Hallo, hab da eine Frage in die Runde:
                              Bei dem Graph, wo kommen die Daten her, aus der History oder der Influxdatenbank?.
                              In der Version 5.xx war es ein History Graph gewesen.
                              Danke schon mal.
                              • S Supernils
                                GarfonsoG Offline
                                GarfonsoG Offline
                                Garfonso
                                @Supernils
                                zeigt dir das Frontend denn grundsätzlich eine Historie für den Datenpunkt an?
                                @StephanH sagte:
                                Aus das was du in den Instanzeinstellungen eingestellt hast. :-)
                                @StephanH sagte:
                                Das hat nichts mit influx <-> history zu tun. Der Adapter kann bisher nur mit einer einzelnen Datenquelle für historische Werte sprechen und die gibt man in den Instanzeinstellungen an.
                                Bei HomeAssistant / Lovelace selber hat sich an der Stelle allerdings einiges getan. Das Frontend fordert jetzt viele Berechnungen direkt beim Backend an, was sicherlich sinnvoll ist, aber da kann durchaus noch etwas krumm sein.
                                S S 2 Antworten Letzte Antwort
                                • A andi2055
                                  LL 6.1.1
                                  GarfonsoG Offline
                                  GarfonsoG Offline
                                  Garfonso
                                  @andi2055 sagte:
                                  LL 6.1.1
                                  Grundsätzlich Chrome oder nur der eine Chrome? Guck mal, ob du in nem Privaten Window auch das Problem hast...
                                  Sonst liegt da im Browser-Store eine kaputte ID.
                                  Ich hab lovelace gepatcht, so dass sie die ID repariert, in Zukunft.
                                  Vermutlich werden die Instanz-Objekte jetzt nicht gehen für den Browser. Du kannst im Browser die Browser-Mod-Settings aufrufen und da die ID ändern (mal global hideSidebar ausmachen). Dann sollte es hoffentlich wieder gehen. (Alternativen: chrome zeug löschen lassen, von Hand über die entwikler-optionen den localStorage bearbeiten und da browser_mod sachen löschen).
                                  //Edit: hab meinen Chrome gefunden. Hab das Problem hier nicht.
                                    @Supernils
                                    @StephanH sagte:
                                    @StephanH sagte:
                                    Supernils
                                    schrieb am zuletzt editiert von Supernils
                                    @Garfonso sagte:
                                    @garfonso
                                    Ja.
                                      "_id": "alias.0.Energie.Stromzaehler.ISTLEISTUNG",
                                      "common": {
                                        "name": "ISTLEISTUNG",
                                        "role": "value.power",
                                        "type": "number",
                                        "unit": "W",
                                        "read": true,
                                        "write": false,
                                        "alias": {
                                          "id": "mqtt.1.tele.tasmota_89B8D8.SENSOR",
                                          "read": "JSON.parse(val).SGM.Power"
                                        "custom": {
                                          "lovelace.0": {
                                            "enabled": true,
                                            "attr_has_time": false,
                                            "attr_has_date": true,
                                            "entity": "sensor",
                                            "name": "Energie_Stromzaehler_ISTLEISTUNG",
                                            "attr_unit_of_measurement": "W",
                                            "attr_device_class": "power",
                                            "attr_state_class": "measurement"
                                          "sql.0": {
                                            "enabled": true,
                                            "storageType": "",
                                            "counter": false,
                                            "aliasId": "",
                                            "debounceTime": 0,
                                            "blockTime": 0,
                                            "changesOnly": true,
                                            "changesRelogInterval": "0",
                                            "changesMinDelta": "0",
                                            "ignoreBelowNumber": "",
                                            "disableSkippedValueLogging": false,
                                            "retention": 31536000,
                                            "customRetentionDuration": 365,
                                            "maxLength": 50,
                                            "enableDebugLogs": false,
                                            "debounce": "1000",
                                            "ignoreZero": false
                                      "type": "state",
                                      "native": {},
                                      "acl": {
                                        "object": 1636,
                                        "state": 1636,
                                        "owner": "system.user.admin",
                                      "user": "system.user.admin",
                                      "ts": 1784053453110
                                      @andi2055 sagte:
                                      LL 6.1.1
                                      andi2055
                                      @Garfonso
                                      über Browser Mods eine andere ID gewählt funktioniert nun wieder.
                                      die 2 anderen konnte ich aber nicht löschen. Da erscheint nur ein leeres Popup.
                                      "entwikler-optionen den localStorage bearbeiten" -> das habe ich nicht gefunden
                                      Danke dir!
                                        @Supernils
                                        @StephanH sagte:
                                        @StephanH sagte:
                                        StephanH
                                        @Garfonso sagte:
                                        Hi, ja das Frontend zeigt mir die Daten an. Hab als DB die Influx eingetragen. Fange ab pro Entität noch die Daten in der History mit ab. Ging mir drum was perfomanter ist.
                                        • S StephanH
                                          @Garfonso sagte:
                                          GarfonsoG Offline
                                          GarfonsoG Offline
                                          Garfonso
                                          @StephanH
                                          Das ist für den lovelace-Adapter völlig egal.
