  4. Seit Controller Update viele Fehler
    6.3k
24 Beiträge 5 Kommentatoren 1.0k Aufrufe 6 Beobachtet
  • hg6806H hg6806
    Gute Frage, komme da nicht drauf.
    pi@RasPi5-iobroker:~ $ iob diag
    [sudo] password for pi:
    /usr/bin/iob: line 21: /home/iobroker/iob_diag.log: Permission denied
    @hg6806
    Dann ist da noch mehr krumm.
    iob stop
    iob fix
    iob start
    und dann nach etwas warten
    iob diag
    • hg6806H Offline
      hg6806H Offline
      hg6806
      Done:
      Script v.2026-06-06
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: RasPi5-iobroker
             Icon name: computer
                Kernel: Linux 6.18.29+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Unknown
      Kernel          : aarch64
      Userland        : 64bit
      System was installed 62 days ago (on 2026-04-21).
      Systemuptime and Load:
       21:21:09 up  8:39,  3 users,  load average: 2.11, 1.20, 1.20
      CPU threads     : 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2026-06-22 21:21:09 CEST
                 Universal time: Mon 2026-06-22 19:21:09 UTC
                       RTC time: Mon 2026-06-22 19:21:09
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         Unknown
      Display-Manager:        * lightdm.service - Light Display Manager
      Desktop:
      Session:                tty
      Boot Target:            multi-user.target
      *** MEMORY ***
      Mem:            8.5G        3.0G        4.1G         34M        1.5G        5.5G
      Swap:           2.1G        105M        2.0G
      Total:           10G        3.1G        6.2G
      Active iob-Instances:   4
               8062 M total memory
               2839 M used memory
               2445 M active memory
                768 M inactive memory
               3926 M free memory
                220 M buffer memory
               1196 M swap cache
               2047 M total swap
                100 M used swap
               1947 M free swap
      top - 21:21:10 up  8:39,  3 users,  load average: 2.11, 1.20, 1.20
      Tasks: 273 total,   2 running, 271 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 47.7 us,  4.5 sy,  0.0 ni, 47.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8062.4 total,   3917.0 free,   2848.4 used,   1417.0 buff/cache
      MiB Swap:   2048.0 total,   1947.1 free,    100.8 used.   5214.0 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     1.6G   14M  1.6G   1% /run
      /dev/nvme0n1p2 ext4      235G   22G  204G  10% /
      tmpfs          tmpfs     4.0G  400K  4.0G   1% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs     4.0G  9.6M  4.0G   1% /tmp
      /dev/nvme0n1p1 vfat      505M   79M  426M  16% /boot/firmware
      tmpfs          tmpfs     807M  256K  806M   1% /run/user/1000
      /dev/mmcblk0p1 vfat      510M   64M  447M  13% /media/pi/bootfs
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      Messages concerning filesystems in dmesg:
      [Mon Jun 22 12:41:33 2026] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
      [Mon Jun 22 12:41:34 2026] EXT4-fs (nvme0n1p2): mounted filesystem ed6c7f1b-238b-41a1-b4b6-7bcdef3270fe ro with ordered data mode. Quota mode: none.
      [Mon Jun 22 12:41:34 2026] EXT4-fs (nvme0n1p2): re-mounted ed6c7f1b-238b-41a1-b4b6-7bcdef3270fe r/w.
      Show mounted filesystems:
      TARGET             SOURCE         FSTYPE OPTIONS
      /                  /dev/nvme0n1p2 ext4   rw,noatime
      |-/boot/firmware   /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/media/pi/bootfs /dev/mmcblk0p1 vfat   rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
      /var:
      2.7G    /var/
      412M    /var/cache
      407M    /var/cache/apt
      276M    /var/cache/apt/archives
      219M    /var/lib
      Archived and active journals take up 8M in the file system.
      /opt/iobroker/backups:
      3.9G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      6.8G    /opt/iobroker/iobroker-data/
      6.0G    /opt/iobroker/iobroker-data/history
      591M    /opt/iobroker/iobroker-data/files
      156M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      41M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      13M     /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
      11M     /opt/iobroker/iobroker-data/files/vis.0/iPhone15plus/vis-views.json
      11M     /opt/iobroker/iobroker-data/files/vis-2.0/main/vis-views.json
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller_D-if00-port0
      /dev/serial/by-id/usb-SHA_CUL868-if00
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1822e12f0e86ec119a07641719c2d21c-if00-port0
      /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01304FAE-if00-port0
      *** ZigBee Settings ***
      ⚠ HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'.
      Please check your setting:
      Zigbee Network Settings on your coordinator / in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      === ZigBee Port Overview ===
      Instance        Configured Port                     Available by-id Port                Status
      zigbee.0        ...07641719c2d21c-if00-port0        ...l_Controller_D-if00-port0        ✗ Not matching
                                                          ...by-id/usb-SHA_CUL868-if00        ✗ Not matching
                                                          ...07641719c2d21c-if00-port0        ✓ Matching
                                                          ...oller_01304FAE-if00-port0        ✗ Not matching
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.22.2
      /usr/bin/node           v22.22.2
      /usr/bin/npm            10.9.7
      /usr/bin/npx            10.9.7
      ✓ Node.js installation is correct
      nodejs:
        Installed: 22.22.2-1nodesource1
        Candidate: 22.23.0-1nodesource1
        Version table:
           22.23.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
           22.22.3-1nodesource1 1001
       *** 22.22.2-1nodesource1 1001
           22.22.1-1nodesource1 1001
           22.22.0-1nodesource1 1001
           22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1+deb13u2 500
              500 http://deb.debian.org/debian trixie/main arm64 Packages
              500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      No known Vulnerabilities detected!
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      RasPi5-iobroker     RasPi5-iobroker (version: 7.2.2, hostname: RasPi5-iobroker, alive, uptime: 48)
      Core adapters versions
      js-controller:  7.2.2
      admin:          7.8.23
      javascript:     9.0.18
      nodejs modules from github:     6
      +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
      +-- iobroker.meteoblue@0.1.0-beta.10 (git+ssh://git@github.com/ice987987/ioBroker.meteoblue.git#93968ce469dc3ef3833a82ade2cad47c508f9e3c)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#deb2bf5210576700734b590215a5f27bb8b72d7d)
      +-- iobroker.ve@0.3.1 (git+ssh://git@github.com/derAlff/ioBroker.ve.git#584088cddf3318ede48554ed97414f5ff79f460e)
      +-- iobroker.vr200@1.1.0 (git+ssh://git@github.com/Eisbaeeer/ioBroker.vr200.git#e55ff645b6a6d6b12e23535b15b81a0de68ee676)
      +-- iobroker.vw-connect@0.9.3 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#277b7dfc71177867175e06474105a695af63a4c9)
      Adapter State
      + system.adapter.admin.0                  : admin                 : RasPi5-iobroker                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : RasPi5-iobroker                          - disabled
        system.adapter.alias-manager.0          : alias-manager         : RasPi5-iobroker                          - disabled
      + system.adapter.backitup.0               : backitup              : RasPi5-iobroker                          -  enabled
        system.adapter.ble.0                    : ble                   : RasPi5-iobroker                          -  enabled
        system.adapter.broadlink2.0             : broadlink2            : RasPi5-iobroker                          - disabled
        system.adapter.canbus.0                 : canbus                : RasPi5-iobroker                          -  enabled
      + system.adapter.cloud.0                  : cloud                 : RasPi5-iobroker                          -  enabled
        system.adapter.daswetter.0              : daswetter             : RasPi5-iobroker                          -  enabled
        system.adapter.denon.0                  : denon                 : RasPi5-iobroker                          -  enabled
        system.adapter.device-watcher.0         : device-watcher        : RasPi5-iobroker                          -  enabled
        system.adapter.devices.0                : devices               : RasPi5-iobroker                          - disabled
        system.adapter.discovery.0              : discovery             : RasPi5-iobroker                          - disabled
      + system.adapter.email.0                  : email                 : RasPi5-iobroker                          -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: RasPi5-iobroker                          -  enabled
        system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: RasPi5-iobroker                          -  enabled
        system.adapter.enigma2.0                : enigma2               : RasPi5-iobroker                          -  enabled
        system.adapter.eventlist.0              : eventlist             : RasPi5-iobroker                          -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : RasPi5-iobroker                          -  enabled
        system.adapter.heos.0                   : heos                  : RasPi5-iobroker                          -  enabled
      + system.adapter.history.0                : history               : RasPi5-iobroker                          -  enabled
        system.adapter.hm-rega.0                : hm-rega               : RasPi5-iobroker                          -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : RasPi5-iobroker                          -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : RasPi5-iobroker                          -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : RasPi5-iobroker                          - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : RasPi5-iobroker                          - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : RasPi5-iobroker                          - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : RasPi5-iobroker                          - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RasPi5-iobroker                          - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: RasPi5-iobroker                          - disabled
        system.adapter.iot.0                    : iot                   : RasPi5-iobroker                          - disabled
      + system.adapter.javascript.0             : javascript            : RasPi5-iobroker                          -  enabled
        system.adapter.meteoblue.0              : meteoblue             : RasPi5-iobroker                          - disabled
        system.adapter.modbus.0                 : modbus                : RasPi5-iobroker                          -  enabled
        system.adapter.modbus.1                 : modbus                : RasPi5-iobroker                          -  enabled
        system.adapter.modbus.2                 : modbus                : RasPi5-iobroker                          -  enabled
        system.adapter.modbus.3                 : modbus                : RasPi5-iobroker                          -  enabled
        system.adapter.modbus.4                 : modbus                : RasPi5-iobroker                          -  enabled
        system.adapter.modbus.5                 : modbus                : RasPi5-iobroker                          - disabled
        system.adapter.modbus.6                 : modbus                : RasPi5-iobroker                          -  enabled
        system.adapter.mqtt.0                   : mqtt                  : RasPi5-iobroker                          -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : RasPi5-iobroker                          -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.mqtt.2                   : mqtt                  : RasPi5-iobroker                          - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.niu.0                    : niu                   : RasPi5-iobroker                          - disabled
        system.adapter.onvif.0                  : onvif                 : RasPi5-iobroker                          -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899, 554, 2020
        system.adapter.oxxify-fan-control.0     : oxxify-fan-control    : RasPi5-iobroker                          -  enabled
        system.adapter.parser.0                 : parser                : RasPi5-iobroker                          -  enabled
        system.adapter.ping.0                   : ping                  : RasPi5-iobroker                          -  enabled
        system.adapter.pvforecast.0             : pvforecast            : RasPi5-iobroker                          - disabled
        system.adapter.pylontech.0              : pylontech             : RasPi5-iobroker                          -  enabled, port: 23
        system.adapter.rpi2.0                   : rpi2                  : RasPi5-iobroker                          -  enabled
      + system.adapter.scenes.0                 : scenes                : RasPi5-iobroker                          -  enabled
        system.adapter.shelly.0                 : shelly                : RasPi5-iobroker                          -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shelly.1                 : shelly                : RasPi5-iobroker                          -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : RasPi5-iobroker                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.sma-em.0                 : sma-em                : RasPi5-iobroker                          -  enabled
        system.adapter.smartmeter.0             : smartmeter            : RasPi5-iobroker                          -  enabled
        system.adapter.sonoff.0                 : sonoff                : RasPi5-iobroker                          - disabled, port: 1885, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : RasPi5-iobroker                          -  enabled
        system.adapter.statistics.0             : statistics            : RasPi5-iobroker                          -  enabled
        system.adapter.sunnyportal.0            : sunnyportal           : RasPi5-iobroker                          -  enabled
        system.adapter.tankerkoenig.0           : tankerkoenig          : RasPi5-iobroker                          -  enabled
      + system.adapter.telegram.0               : telegram              : RasPi5-iobroker                          -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : RasPi5-iobroker                          - disabled
        system.adapter.tronity.0                : tronity               : RasPi5-iobroker                          - disabled
        system.adapter.tuya.0                   : tuya                  : RasPi5-iobroker                          -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : RasPi5-iobroker                          -  enabled
        system.adapter.ve.0                     : ve                    : RasPi5-iobroker                          - disabled
        system.adapter.vis-2.0                  : vis-2                 : RasPi5-iobroker                          -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : RasPi5-iobroker                          -  enabled
        system.adapter.vis-history.0            : vis-history           : RasPi5-iobroker                          - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : RasPi5-iobroker                          - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : RasPi5-iobroker                          - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : RasPi5-iobroker                          -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RasPi5-iobroker                          - disabled
        system.adapter.vis-map.0                : vis-map               : RasPi5-iobroker                          - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi5-iobroker                          - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : RasPi5-iobroker                          - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : RasPi5-iobroker                          - disabled
        system.adapter.vis.0                    : vis                   : RasPi5-iobroker                          -  enabled
        system.adapter.vr200.0                  : vr200                 : RasPi5-iobroker                          - disabled
        system.adapter.vw-connect.0             : vw-connect            : RasPi5-iobroker                          -  enabled
        system.adapter.web.0                    : web                   : RasPi5-iobroker                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wireless-mbus.0          : wireless-mbus         : RasPi5-iobroker                          -  enabled
        system.adapter.wlanthermo-nano.0        : wlanthermo-nano       : RasPi5-iobroker                          - disabled
        system.adapter.wled.0                   : wled                  : RasPi5-iobroker                          -  enabled
        system.adapter.worx.0                   : worx                  : RasPi5-iobroker                          - disabled
        system.adapter.yahoo-stock-market.0     : yahoo-stock-market    : RasPi5-iobroker                          - disabled
        system.adapter.zigbee.0                 : zigbee                : RasPi5-iobroker                          -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1822e12f0e86ec119a07641719c2d21c-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      │ (index) │ id                                           │ name                          │ version          │ upgrade policy │
      │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '7.8.23'         │ 'none'         │
      │ 1       │ 'system.adapter.alarm'                       │ 'alarm'                       │ '3.7.6'          │ 'none'         │
      │ 2       │ 'system.adapter.alias-manager'               │ 'alias-manager'               │ '2.1.0'          │ 'none'         │
      │ 3       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '3.3.17'         │ 'none'         │
      │ 4       │ 'system.adapter.ble'                         │ 'ble'                         │ '0.14.0'         │ 'none'         │
      │ 5       │ 'system.adapter.broadlink2'                  │ 'broadlink2'                  │ '2.3.0'          │ 'none'         │
      │ 6       │ 'system.adapter.canbus'                      │ 'canbus'                      │ '2.3.1'          │ 'none'         │
      │ 7       │ 'system.adapter.cloud'                       │ 'cloud'                       │ '6.0.1'          │ 'none'         │
      │ 8       │ 'system.adapter.daswetter'                   │ 'daswetter'                   │ '4.5.3'          │ 'none'         │
      │ 9       │ 'system.adapter.denon'                       │ 'denon'                       │ '1.15.12'        │ 'none'         │
      │ 10      │ 'system.adapter.device-watcher'              │ 'device-watcher'              │ '2.15.5'         │ 'none'         │
      │ 11      │ 'system.adapter.devices'                     │ 'devices'                     │ '1.2.14'         │ 'none'         │
      │ 12      │ 'system.adapter.discovery'                   │ 'discovery'                   │ '5.0.0'          │ 'none'         │
      │ 13      │ 'system.adapter.email'                       │ 'email'                       │ '2.0.4'          │ 'none'         │
      │ 14      │ 'system.adapter.energiefluss-erweitert'      │ 'energiefluss-erweitert'      │ '0.8.1'          │ 'none'         │
      │ 15      │ 'system.adapter.enigma2'                     │ 'enigma2'                     │ '2.3.0'          │ 'none'         │
      │ 16      │ 'system.adapter.eventlist'                   │ 'eventlist'                   │ '2.1.0'          │ 'none'         │
      │ 17      │ 'system.adapter.fullybrowser'                │ 'fullybrowser'                │ '3.1.2'          │ 'none'         │
      │ 18      │ 'system.adapter.heos'                        │ 'heos'                        │ '3.0.4'          │ 'none'         │
      │ 19      │ 'system.adapter.history'                     │ 'history'                     │ '4.0.0'          │ 'none'         │
      │ 20      │ 'system.adapter.hm-rega'                     │ 'hm-rega'                     │ '5.1.0'          │ 'none'         │
      │ 21      │ 'system.adapter.hm-rpc'                      │ 'hm-rpc'                      │ '3.0.1'          │ 'none'         │
      │ 22      │ 'system.adapter.ical'                        │ 'ical'                        │ '1.20.1'         │ 'none'         │
      │ 23      │ 'system.adapter.icons-icons8'                │ 'icons-icons8'                │ '0.0.1'          │ 'none'         │
      │ 24      │ 'system.adapter.icons-material-png'          │ 'icons-material-png'          │ '0.1.0'          │ 'none'         │
      │ 25      │ 'system.adapter.icons-material-svg'          │ 'icons-material-svg'          │ '0.1.0'          │ 'none'         │
      │ 26      │ 'system.adapter.icons-mfd-png'               │ 'icons-mfd-png'               │ '1.2.1'          │ 'none'         │
      │ 27      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'          │ 'none'         │
      │ 28      │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.3'          │ 'none'         │
      │ 29      │ 'system.adapter.iot'                         │ 'iot'                         │ '6.0.3'          │ 'none'         │
      │ 30      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '9.0.18'         │ 'none'         │
      │ 31      │ 'system.adapter.meteoblue'                   │ 'meteoblue'                   │ '0.1.0-beta.10'  │ 'none'         │
      │ 32      │ 'system.adapter.modbus'                      │ 'modbus'                      │ '8.0.3'          │ 'none'         │
      │ 33      │ 'system.adapter.mqtt'                        │ 'mqtt'                        │ '6.1.4'          │ 'none'         │
      │ 34      │ 'system.adapter.niu'                         │ 'niu'                         │ '0.0.3'          │ 'none'         │
      │ 35      │ 'system.adapter.onvif'                       │ 'onvif'                       │ '1.1.4'          │ 'none'         │
      │ 36      │ 'system.adapter.oxxify-fan-control'          │ 'oxxify-fan-control'          │ '0.0.16'         │ 'none'         │
      │ 37      │ 'system.adapter.parser'                      │ 'parser'                      │ '3.1.0'          │ 'none'         │
      │ 38      │ 'system.adapter.ping'                        │ 'ping'                        │ '1.7.9'          │ 'none'         │
      │ 39      │ 'system.adapter.pvforecast'                  │ 'pvforecast'                  │ '6.1.0'          │ 'none'         │
      │ 40      │ 'system.adapter.pylontech'                   │ 'pylontech'                   │ '0.0.10'         │ 'none'         │
      │ 41      │ 'system.adapter.rpi2'                        │ 'rpi2'                        │ '3.0.2'          │ 'none'         │
      │ 42      │ 'system.adapter.scenes'                      │ 'scenes'                      │ '4.0.4'          │ 'none'         │
      │ 43      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '10.6.1'         │ 'none'         │
      │ 44      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'          │ 'none'         │
      │ 45      │ 'system.adapter.sma-em'                      │ 'sma-em'                      │ '1.3.1'          │ 'none'         │
      │ 46      │ 'system.adapter.smartmeter'                  │ 'smartmeter'                  │ '3.4.0'          │ 'none'         │
      │ 47      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'          │ 'none'         │
      │ 48      │ 'system.adapter.sonoff'                      │ 'sonoff'                      │ '3.3.0'          │ 'none'         │
      │ 49      │ 'system.adapter.sourceanalytix'              │ 'sourceanalytix'              │ '0.4.15-alpha.1' │ 'none'         │
      │ 50      │ 'system.adapter.statistics'                  │ 'statistics'                  │ '4.0.0'          │ 'none'         │
      │ 51      │ 'system.adapter.tankerkoenig'                │ 'tankerkoenig'                │ '3.4.0'          │ 'none'         │
      │ 52      │ 'system.adapter.telegram'                    │ 'telegram'                    │ '4.1.0'          │ 'none'         │
      │ 53      │ 'system.adapter.tr-064'                      │ 'tr-064'                      │ '4.3.0'          │ 'none'         │
      │ 54      │ 'system.adapter.tronity'                     │ 'tronity'                     │ '1.1.1'          │ 'none'         │
      │ 55      │ 'system.adapter.tuya'                        │ 'tuya'                        │ '3.17.0'         │ 'none'         │
      │ 56      │ 'system.adapter.tvspielfilm'                 │ 'tvspielfilm'                 │ '2.1.0'          │ 'none'         │
      │ 57      │ 'system.adapter.ve'                          │ 've'                          │ '0.3.1'          │ 'none'         │
      │ 58      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'          │ 'none'         │
      │ 59      │ 'system.adapter.vis-2'                       │ 'vis-2'                       │ '2.13.8'         │ 'none'         │
      │ 60      │ 'system.adapter.vis-google-fonts'            │ 'vis-google-fonts'            │ '1.0.4'          │ 'none'         │
      │ 61      │ 'system.adapter.vis-history'                 │ 'vis-history'                 │ '1.0.0'          │ 'none'         │
      │ 62      │ 'system.adapter.vis-hqwidgets'               │ 'vis-hqwidgets'               │ '1.6.1'          │ 'none'         │
      │ 63      │ 'system.adapter.vis-icontwo'                 │ 'vis-icontwo'                 │ '2.11.3'         │ 'none'         │
      │ 64      │ 'system.adapter.vis-inventwo'                │ 'vis-inventwo'                │ '4.1.1'          │ 'none'         │
      │ 65      │ 'system.adapter.vis-jqui-mfd'                │ 'vis-jqui-mfd'                │ '1.1.3'          │ 'none'         │
      │ 66      │ 'system.adapter.vis-map'                     │ 'vis-map'                     │ '1.1.2'          │ 'none'         │
      │ 67      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.9'          │ 'none'         │
      │ 68      │ 'system.adapter.vis-rgraph'                  │ 'vis-rgraph'                  │ '0.0.2'          │ 'none'         │
      │ 69      │ 'system.adapter.vis-timeandweather'          │ 'vis-timeandweather'          │ '1.2.2'          │ 'none'         │
      │ 70      │ 'system.adapter.vr200'                       │ 'vr200'                       │ '1.1.0'          │ 'none'         │
      │ 71      │ 'system.adapter.vw-connect'                  │ 'vw-connect'                  │ '0.9.3'          │ 'none'         │
      │ 72      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'          │ 'none'         │
      │ 73      │ 'system.adapter.wireless-mbus'               │ 'wireless-mbus'               │ '0.10.2'         │ 'none'         │
      │ 74      │ 'system.adapter.wlanthermo-nano'             │ 'wlanthermo-nano'             │ '0.2.1'          │ 'none'         │
      │ 75      │ 'system.adapter.wled'                        │ 'wled'                        │ '0.7.3'          │ 'none'         │
      │ 76      │ 'system.adapter.worx'                        │ 'worx'                        │ '3.3.0'          │ 'none'         │
      │ 77      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.1.0'          │ 'none'         │
      │ 78      │ 'system.adapter.yahoo-stock-market'          │ 'yahoo-stock-market'          │ '0.0.7'          │ 'none'         │
      │ 79      │ 'system.adapter.zigbee'                      │ 'zigbee'                      │ '3.3.5'          │ 'none'         │
      ioBroker-Adapter Versions and update status
      Used repository: stable
      Adapter    "admin"        : 7.8.23   , installed 7.8.23
      Adapter    "alarm"        : 3.7.6    , installed 3.7.6
      Adapter    "alias-manager": 2.1.0    , installed 2.1.0
      Adapter    "backitup"     : 3.3.17   , installed 3.3.17
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "canbus"       : 2.3.1    , installed 2.3.1
      Adapter    "cloud"        : 6.0.1    , installed 6.0.1
      Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "device-watcher": 2.15.5  , installed 2.15.5
      Adapter    "devices"      : 1.2.14   , installed 1.2.14
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
      Adapter    "enigma2"      : 2.3.0    , installed 2.3.0
      Adapter    "eventlist"    : 2.1.0    , installed 2.1.0
      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
      Adapter    "heos"         : 3.0.4    , installed 3.0.4
      Adapter    "history"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
      Adapter    "ical"         : 1.20.1   , installed 1.20.1
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "iot"          : 6.0.3    , installed 6.0.3
      Adapter    "javascript"   : 9.0.18   , installed 9.0.18
      Controller "js-controller": 7.2.2    , installed 7.2.2
      Adapter    "modbus"       : 8.0.3    , installed 8.0.3
      Adapter    "niu"          : 0.0.3    , installed 0.0.3
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "oxxify-fan-control": 0.0.16, installed 0.0.16
      Adapter    "parser"       : 3.1.0    , installed 3.1.0
      Adapter    "ping"         : 1.7.9    , installed 1.7.9
      Adapter    "pvforecast"   : 6.1.0    , installed 6.1.0
      Adapter    "pylontech"    : 0.0.10   , installed 0.0.10
      Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
      Adapter    "scenes"       : 4.0.4    , installed 4.0.4
      Adapter    "shelly"       : 10.6.1   , installed 10.6.1
      Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
      Adapter    "sma-em"       : 1.3.1    , installed 1.3.1
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 7.1.3    , installed 7.1.3
      Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
      Adapter    "statistics"   : 4.0.0    , installed 4.0.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "tuya"         : 3.17.0   , installed 3.17.0
      Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
      Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
      Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
      Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
      Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
      Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vr200"        : 1.0.0    , installed 1.1.0
      Adapter    "web"          : 8.0.0    , installed 8.0.0
      Adapter    "wireless-mbus": 0.10.2   , installed 0.10.2
      Adapter    "wlanthermo-nano": 0.2.1  , installed 0.2.1
      Adapter    "wled"         : 0.7.3    , installed 0.7.3
      Adapter    "worx"         : 3.3.0    , installed 3.3.0
      Adapter    "ws"           : 4.1.0    , installed 4.1.0
      Adapter    "yahoo-stock-market": 0.0.7, installed 0.0.7
      Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
      Objects and States
      Objects:        45170
      States:         38045
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
      Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending systemupdates: 236
      *** Listening Ports ***
      Netid State  Recv-Q Send-Q               Local Address:Port          Peer Address:PortProcess
      udp   UNCONN 0      0                          0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=709,fd=5),("systemd",pid=1,fd=173))
      udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=772,fd=12))
      udp   UNCONN 0      0                          0.0.0.0:54772              0.0.0.0:*    users:(("io.heos.0",pid=129814,fd=30))
      udp   UNCONN 0      0                          0.0.0.0:51590              0.0.0.0:*    users:(("avahi-daemon",pid=772,fd=14))
      udp   UNCONN 0      0                          0.0.0.0:35673              0.0.0.0:*    users:(("io.heos.0",pid=129814,fd=31))
      udp   UNCONN 0      0                                *:sunrpc                   *:*    users:(("rpcbind",pid=709,fd=7),("systemd",pid=1,fd=175))
      udp   UNCONN 0      0                                *:49380                    *:*    users:(("avahi-daemon",pid=772,fd=15))
      udp   UNCONN 0      0      [fe80::da3a:ddff:fea4:71a5]:dhcpv6-client            *:*    users:(("NetworkManager",pid=853,fd=35))
      udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=772,fd=13))
      tcp   LISTEN 0      511                        0.0.0.0:1883               0.0.0.0:*    users:(("io.mqtt.0",pid=130174,fd=35))
      tcp   LISTEN 0      4096                       0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=709,fd=4),("systemd",pid=1,fd=172))
      tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=1321,fd=6))
      tcp   LISTEN 0      511                 192.168.178.18:2001               0.0.0.0:*    users:(("io.hm-rpc.0",pid=129903,fd=35))
      tcp   LISTEN 0      511                      127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=128983,fd=29))
      tcp   LISTEN 0      511                      127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=128983,fd=23))
      tcp   LISTEN 0      4096                          [::]:sunrpc                [::]:*    users:(("rpcbind",pid=709,fd=6),("systemd",pid=1,fd=174))
      tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=1321,fd=7))
      tcp   LISTEN 0      511                              *:tproxy                   *:*    users:(("io.admin.0",pid=129011,fd=38))
      2026-06-22 21:22:07.797  - info: modbus.6 (130125) starting. Version 8.0.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v22.22.2, js-controller: 7.2.2
      2026-06-22 21:22:08.159  - info: modbus.6 (130125) Connected to slave 192.168.178.93
      2026-06-22 21:22:08.952  - info: host.RasPi5-iobroker instance system.adapter.mqtt.0 in version "6.1.4" started with pid 130174
      2026-06-22 21:22:11.253  - info: mqtt.0 (130174) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v22.22.2, js-controller: 7.2.2
      2026-06-22 21:22:11.425  - info: mqtt.0 (130174) Starting MQTT authenticated server on 0.0.0.0:1883
      2026-06-22 21:22:12.354  - info: cloud.0 (129356) Trying to connect as system.user.admin to cloud
      2026-06-22 21:22:12.421  - info: cloud.0 (129356) Connection changed: connect
      2026-06-22 21:22:12.992  - info: host.RasPi5-iobroker instance system.adapter.mqtt.1 in version "6.1.4" started with pid 130229
      2026-06-22 21:22:15.445  - info: mqtt.1 (130229) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v22.22.2, js-controller: 7.2.2
      2026-06-22 21:22:15.694  - info: mqtt.1 (130229) Try to connect to mqtt://192.168.178.12:1883 with clientId=RasPi5-iobroker.mqtt.1
      2026-06-22 21:22:15.769  - info: mqtt.1 (130229) Connected to 192.168.178.12
      2026-06-22 21:22:15.770  - info: mqtt.1 (130229) Subscribe on "openWB/simpleAPI/#"
      2026-06-22 21:22:17.058  - info: host.RasPi5-iobroker instance system.adapter.ping.0 in version "1.7.9" started with pid 130247
      2026-06-22 21:22:19.403  - info: ping.0 (130247) starting. Version 1.7.9 in /opt/iobroker/node_modules/iobroker.ping, node: v22.22.2, js-controller: 7.2.2
      2026-06-22 21:22:20.327  - info: mqtt.0 (130174) Client [ESP06-Brunnen_6] connected with secret 1782156140324_3136
      2026-06-22 21:22:20.380  - info: mqtt.0 (130174) Client [ESP06-Brunnen_6] subscribes on "/ESP06-Brunnen/#" with regex /^ESP06-Brunnen\..*/
      2026-06-22 21:22:20.380  - info: mqtt.0 (130174) Client [ESP06-Brunnen_6] subscribes on "/ESP06-Brunnen/#"  with regex /^mqtt\.0\.ESP06-Brunnen\..*/
      2026-06-22 21:22:20.595  - info: mqtt.0 (130174) Client [ESP06-Brunnen_6] publishOnSubscribe send all known states
      2026-06-22 21:22:21.095  - info: host.RasPi5-iobroker instance system.adapter.rpi2.0 in version "3.0.2" started with pid 130268
      2026-06-22 21:22:21.916  - info: mqtt.0 (130174) Client [ESP05-Solar+Heizung_5] connected with secret 1782156141916_5857
      2026-06-22 21:22:21.948  - info: mqtt.0 (130174) Client [ESP05-Solar+Heizung_5] subscribes on "/ESP05-Solar+Heizung/#" with regex /^ESP05-Solar[^.]*Heizung\..*/
      2026-06-22 21:22:21.949  - info: mqtt.0 (130174) Client [ESP05-Solar+Heizung_5] subscribes on "/ESP05-Solar+Heizung/#"  with regex /^mqtt\.0\.ESP05-Solar[^.]*Heizung\..*/
      2026-06-22 21:22:22.150  - info: mqtt.0 (130174) Client [ESP05-Solar+Heizung_5] publishOnSubscribe send all known states
      2026-06-22 21:22:22.749  - info: rpi2.0 (130268) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v22.22.2, js-controller: 7.2.2
      2026-06-22 21:22:23.471  - info: rpi2.0 (130268) GPIO ports are not configured
      ============= Mark until here for C&P =============
      • hg6806H hg6806
        Done:
        Script v.2026-06-06
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Unknown
        Kernel          : aarch64
        Userland        : 64bit
        CPU threads     : 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Session:                tty
        *** MEMORY ***
                 8062 M total memory
                 2839 M used memory
                 3926 M free memory
                  220 M buffer memory
                 1196 M swap cache
                 2047 M total swap
                  100 M used swap
                 1947 M free swap
        *** FILESYSTEM ***
        /var:
        2.7G    /var/
        412M    /var/cache
        407M    /var/cache/apt
        219M    /var/lib
        USB-Devices by-id:
        ⚠ HINT:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.7
        /usr/bin/npx            10.9.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.8.23
        javascript:     9.0.18
        Adapter State
        + instance is alive
        Objects and States
        Objects:        45170
        States:         38045
        @hg6806 sagte:
        Updaten.
        iob stop
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        • hg6806H hg6806
          hatte wie erfordert js.controlelr Update auf 7.18(?) gemacht, daraufhin hatte ich etxrem hohe Prozessorlast und zig Fehlermeldungen von Homematic, dann Update auf 7.22, jetzt kommen viele Javascript Meldunmgen wie diese hier:
          avascript.0
          2026-06-22 20:56:00.553	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.553	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.553	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.553	warn	at Object.<anonymous> (script.js.common.BattSpeicher.Speicher-Ladestrom_begrenzen:3:3)
          javascript.0
          2026-06-22 20:56:00.553	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.553	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.553	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.553	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.552	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.550	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.550	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.550	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.550	warn	at Object.<anonymous> (script.js.common.Pool.Pool_Steuerung:3:3)
          javascript.0
          2026-06-22 20:56:00.550	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.550	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.550	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.550	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.550	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.548	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.548	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.548	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.548	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.548	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.548	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.548	warn	at Object.<anonymous> (script.js.common.System.Alarmanzeige.Alarmanzeige_Fuerte_Repeater_offline:3:3)
          javascript.0
          2026-06-22 20:56:00.548	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.547	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.541	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.541	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.541	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.541	warn	at Object.<anonymous> (script.js.common.Klima.Vermeidung_von_Erwärmung_durch_Lüftung:3:3)
          javascript.0
          2026-06-22 20:56:00.541	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.541	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.541	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.541	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.541	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.537	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.537	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.537	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.537	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.537	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.536	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.536	warn	at Object.<anonymous> (script.js.common.Wasser.Wasserverbrauchs-Alarm:3:3)
          javascript.0
          2026-06-22 20:56:00.536	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.536	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.529	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.529	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.529	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.529	warn	at Object.<anonymous> (script.js.common.Wasser.Wasseruhr_Check:3:3)
          javascript.0
          2026-06-22 20:56:00.529	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.529	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.529	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.529	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.528	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.526	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.526	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.526	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.526	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.526	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.526	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.526	warn	at Object.<anonymous> (script.js.common.Wasser.Sprinkler_nach_x_Minuten_wieder_ausschalten:3:3)
          javascript.0
          2026-06-22 20:56:00.526	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.525	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.519	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.519	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.519	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.519	warn	at Object.<anonymous> (script.js.common.Wasser.Brunnenpumpe_ausschalten_wenn_Zisterne_voll:3:3)
          javascript.0
          2026-06-22 20:56:00.519	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.519	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.519	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.519	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.518	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.516	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.516	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.516	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.516	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.516	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.516	warn	at Object.<anonymous> (script.js.common.Wasser.Brunnenpumpe_Automatikprogramme:3:3)
          javascript.0
          2026-06-22 20:56:00.516	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.516	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.516	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.514	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.514	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.514	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.514	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.514	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.514	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.514	warn	at Object.<anonymous> (script.js.common.Temp.OpenWB_Verbrauch_Alias:3:3)
          javascript.0
          2026-06-22 20:56:00.513	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.513	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.510	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.510	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.510	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.510	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.510	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.510	warn	at Object.<anonymous> (script.js.common.Taupunkte.Wohnzimmer:3:3)
          javascript.0
          2026-06-22 20:56:00.510	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.510	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.510	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.508	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.508	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.508	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.508	warn	at Object.<anonymous> (script.js.common.Taupunkte.Wintergarten:3:3)
          javascript.0
          2026-06-22 20:56:00.508	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.508	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.508	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.508	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.507	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.506	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.506	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.506	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.506	warn	at Object.<anonymous> (script.js.common.Taupunkte.Schlafzimmer:3:3)
          javascript.0
          2026-06-22 20:56:00.506	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.506	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.506	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.505	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.505	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.503	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.503	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.503	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.503	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.503	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.503	warn	at Object.<anonymous> (script.js.common.Taupunkte.OberesBad:3:3)
          javascript.0
          2026-06-22 20:56:00.503	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.503	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.503	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.501	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.501	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.501	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.501	warn	at Object.<anonymous> (script.js.common.Taupunkte.Lueften:3:3)
          javascript.0
          2026-06-22 20:56:00.501	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.501	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.501	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.501	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.501	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.499	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.499	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.499	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.499	warn	at Object.<anonymous> (script.js.common.Taupunkte.Keller:3:3)
          javascript.0
          2026-06-22 20:56:00.499	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.499	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.499	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.499	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.498	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.496	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.496	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.496	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.496	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.496	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.496	warn	at Object.<anonymous> (script.js.common.Taupunkte.Gästezimmer:3:3)
          javascript.0
          2026-06-22 20:56:00.496	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.496	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.496	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.494	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.494	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.494	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.494	warn	at Object.<anonymous> (script.js.common.Taupunkte.Dachboden:3:3)
          javascript.0
          2026-06-22 20:56:00.494	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.494	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.494	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.494	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.493	warn	State "upnp.0.WANDevice_-_FRITZ!Box_7590_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
          javascript.0
          2026-06-22 20:56:00.492	warn	at processTimers (node:internal/timers:521:7)
          javascript.0
          2026-06-22 20:56:00.492	warn	at listOnTimeout (node:internal/timers:585:17)
          javascript.0
          2026-06-22 20:56:00.492	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          javascript.0
          2026-06-22 20:56:00.492	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          javascript.0
          2026-06-22 20:56:00.492	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          javascript.0
          2026-06-22 20:56:00.492	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
          javascript.0
          2026-06-22 20:56:00.492	warn	at Object.<anonymous> (script.js.common.Taupunkte.Aussen:3:3)
          javascript.0
          2026-06-22 20:56:00.492	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          javascript.0
          2026-06-22 20:56:00.491
          Und Sourceanalytix meldet auf einem ein Limit auf 5000.
          Gibt es da noch eine Fehlerbehebung?
          CodierknechtC Offline
          Codierknecht
          @hg6806 sagte:
          Dann solltest Du überprüfen, ob mehr als 5.000 Datenpunkte tatsächlich nötig sind.
          Wenn da keine Leichen im Objektbaum liegen und diese DP benötigt werden, kannst Du den Wert (im Expertenmodus) unter system.adapter.sourceanalytics.0.objectsWarnLimit ändern.
          Macht es vielleicht Sinn, die Anzahl DP je Instanz in das diag mit aufzunehmen?
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          • CodierknechtC Codierknecht
            @hg6806 sagte:
            @Codierknecht sagte:
            Von 'außen' ist das wohl schwer zu zählen. Oder fällt dir da was über die Kommandozeile ein?
            CodierknechtC mcm1957M 2 Antworten Letzte Antwort
              Codierknecht
              @Thomas-Braun sagte:
              Nicht dass ich wüsste 😕
                mcm1957M Online
                mcm1957M Online
                mcm1957
                Ev. würde eine Asuwertung von ìob object list * gehen. Keine Ahnung ob das bei >5000 * Adapter dann zu einem Speicherüberlauf oder 3h Runtime führt ...
                EDIT:
                Also z.B. 'iob object shelly.0.*' und dann Zeilen zählen (ggF nach Filterunge header und so)
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                • mcm1957M mcm1957
                  EDIT:
                  @mcm1957
                  Das läuft dann aber bei X Instanzen aber 'ewig'. Das wird 'zu teuer'.
                  Hab gestern mal damit herumgespielt und selbst auf meinem Testsystem mit nur 10k Objekten und 5 Instanzen oder so lief das entweder gar nicht oder sehr langsam.
                    @mcm1957
                    Codierknecht
                    @Thomas-Braun
                    Hab's gerade mal in der Shell so versucht:
                    iob object list alias.0.* | grep -c admin
                    Das geht recht fix.
                      @Thomas-Braun
                      Das geht recht fix.
                      Das geht recht fix.
                      Ja, für einen Adapter. Du musst aber ja x Instanzen da durchschleifen.
                      • mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        Ja, kann mir vorstellen.
                        Ev. kann man ein iob diag --extended (oder --detail oder so was) erfinden wenn wir die Info brauchen. Aber ob sie bisher abgegangen ist? Keine Ahnung ...
                        • mcm1957M mcm1957
                          Codierknecht
                          @mcm1957 sagte:
                          Wenn's zu viel Zeit braucht, macht das wenig Sinn.
                          Vielleicht kann man dem Controller ja in Zukunft eine Möglichkeit spendieren, das elegant zu ermitteln.
                          @thomas-braun Bis dahin würde ich da jetzt keinen Aufwand investieren. War nur 'ne Idee.
                            @mcm1957 sagte:
                            Ich hatte auch schon überlegt, die bisherige Zählung der Gesamtzahl an States und Objects aus 'iob diag' rauszuwerfen.
                            Das läuft schon in der einfachen Version ggfls. etwas länger und die Aussagekraft ist dann ja auch nur sehr begrenzt.
                            • hg6806H Offline
                              hg6806H Offline
                              hg6806
                              Ja, die Ü5000 DP brauche ich schon.
                              Aber egal, die ganzen Fehlermeldungen sind noch immer da.
                              Ich verstehe auch nicht woher der alte Kram kommt:
                              State "upnp.0.WANDevice_-FRITZ!Box_7590(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
                              Wenn ich in Javascript nach dem State suche, wird nichts gefunden.
                              • hg6806H Offline
                                hg6806H Offline
                                hg6806
                                Also, nochmal.
                                Seit js controller update
                                Ich bekomme jede Minute 99+ Warnings von der javascript Instanz.
                                Erster Waring Eintrag ist:
                                javascript.0
                                2026-06-24 07:42:00.004 warn State "upnp.0.WANDevice_-FRITZ!Box_7590(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request" not found
                                Wenn ich in Javascript nach diesem Fritzbox Eintrag durchsuche, finde ich aber nichts. Sprich, es gibt kein Programm.
                                Das Limit habe ich angepasst. Sourceanalytix erzeugt nun mal sehr viele Datenpunkte und bei ca. 40 beobachten Werte kommt halt einiges zusammen.
                                fuzzy1955F 1 Antwort Letzte Antwort
                                • hg6806H hg6806
                                  Also, nochmal.
                                  javascript.0
                                  fuzzy1955F Offline
                                  fuzzy1955F Offline
                                  fuzzy1955
                                  @hg6806 sagte:
                                  Exportiere mal alle Scripts und suche dann in der Exportdatei. Vielleicht ist es versteckt.
                                  Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
                                  Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
                                  Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
                                  Großes Danke an alle tatkräftigen Helfer im Forum!
                                  • hg6806H Offline
                                    hg6806H Offline
                                    hg6806
                                    Danke für den Tipp, habe es gefunden!
                                    Das ware in Global versteckt was im Normal-Modus ausgeblendet ist.
                                    Script ist gestoppt und wird gelöscht.
                                    Beim Neustart hagelt es aber nach wie vor hunderte oder tausende (?) Fehlermeldungen von Homatic hm-rpc und läßt das System auslasten.
                                    • hg6806H hg6806
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      @hg6806 sagte:
                                      Sorry, falls ichs beim zurückblättern übersehen habe - aber ich kann hier keine solche Fehelrmeldung finden.
                                      Kanst du bitte mal zeigen was da gelogged wird?
                                      • hg6806H Offline
                                        hg6806H Offline
                                        hg6806
                                        Nein, das hatte ich nicht gepostet. Hier ist es
                                        • hg6806H Offline
                                          hg6806H Offline
                                          hg6806
                                          Irgendwann "beruhigt" es sich.
