  3. Off Topic
  4. Pflege des Betriebssystems
  5. Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'
    5.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
265 Beiträge 50 Kommentatoren 73.7k Aufrufe 56 Beobachtet
  • H Offline
    Hadebe
    schrieb am zuletzt editiert von Hadebe
    #246
    Ich bin weit entfernt von einem Linux Experten und mit Hand am Arm geht es besser. Check mal den Output von iob diag, bin gespannt was ich mit KI gebastelt hab:
    ```bash
    Script v.2026-06-01
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: raspi01
           Icon name: computer
              Kernel: Linux 6.18.33+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 921 days ago (on 2023-12-05).
    Systemuptime and Load:
     00:02:10 up 7 min,  1 user,  load average: 0.79, 0.85, 0.54
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2026-06-14 00:02:10 CEST
               Universal time: Sat 2026-06-13 22:02:10 UTC
                     RTC time: Sat 2026-06-13 22:02:10
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        * lightdm.service - Light Display Manager
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:            8.5G        4.7G        2.1G         35M        1.8G        3.8G
    Swap:           209M          0B        209M
    Total:          8.7G        4.7G        2.3G
    Active iob-Instances:   36
             8062 M total memory
             4446 M used memory
             4259 M active memory
             1235 M inactive memory
             2034 M free memory
              124 M buffer memory
             1578 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 00:02:13 up 7 min,  1 user,  load average: 0.79, 0.85, 0.54
    Tasks: 225 total,   1 running, 224 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 13.6 us,  4.5 sy,  0.0 ni, 81.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8062.4 total,   2033.5 free,   4446.3 used,   1703.1 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3616.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     1.6G   16M  1.6G   1% /run
    /dev/mmcblk0p2 ext4       58G   17G   39G  30% /
    tmpfs          tmpfs     4.0G  9.4M  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    tmpfs          tmpfs     4.0G  8.8M  4.0G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    /dev/mmcblk0p1 vfat      510M   90M  421M  18% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
    tmpfs          tmpfs     807M  304K  806M   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Sat Jun 13 23:54:24 2026] EXT4-fs (mmcblk0p2): mounted filesystem 4aa56689-dcb4-4759-90e6-179beae559ac ro with ordered data mode. Quota mode: none.
    [Sat Jun 13 23:54:26 2026] EXT4-fs (mmcblk0p2): re-mounted 4aa56689-dcb4-4759-90e6-179beae559ac r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.4G    /var/
    789M    /var/log
    740M    /var/log/journal/50f983a78ca74122882bca60072380ca
    220M    /var/lib
    Archived and active journals take up 748.7M in the file system.
    /opt/iobroker/backups:
    40M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    859M    /opt/iobroker/iobroker-data/
    302M    /opt/iobroker/iobroker-data/files
    268M    /opt/iobroker/iobroker-data/history
    207M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    57M     /opt/iobroker/iobroker-data/objects.jsonl
    30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/states.jsonl
    11M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js
    9.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.f592ece1.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2227875-if00
    *** ZigBee Settings ***
    ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    zigbee.0        ..._ConBee_II_DE2227875-if00        ..._ConBee_II_DE2227875-if00        ✓ Matching
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.3
    /usr/bin/node           v22.22.3
    /usr/bin/npm            10.9.8
    /usr/bin/npx            10.9.8
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.3-1nodesource1
      Candidate: 22.22.3-1nodesource1
      Version table:
     *** 22.22.3-1nodesource1 100
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspi01             raspi01 (version: 7.1.2, hostname: raspi01       , alive, uptime: 472)
    Core adapters versions
    js-controller:  7.1.2
    admin:          7.9.1
    javascript:     9.2.4
    nodejs modules from github:     1
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi01                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspi01                                  - disabled
      system.adapter.alias-manager.0          : alias-manager         : raspi01                                  - disabled
    + system.adapter.backitup.0               : backitup              : raspi01                                  -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspi01                                  -  enabled
    + system.adapter.daswetter.0              : daswetter             : raspi01                                  -  enabled
      system.adapter.devices.0                : devices               : raspi01                                  - disabled
    + system.adapter.discovery.0              : discovery             : raspi01                                  -  enabled
    + system.adapter.enigma2.0                : enigma2               : raspi01                                  -  enabled
    + system.adapter.eusec.0                  : eusec                 : raspi01                                  -  enabled
      system.adapter.flot.0                   : flot                  : raspi01                                  - disabled
    + system.adapter.fritzdect.0              : fritzdect             : raspi01                                  -  enabled
    + system.adapter.frontier_silicon.0       : frontier_silicon      : raspi01                                  -  enabled
    + system.adapter.ham.0                    : ham                   : raspi01                                  -  enabled
    + system.adapter.hass.0                   : hass                  : raspi01                                  -  enabled, port: 8123
    + system.adapter.history.0                : history               : raspi01                                  -  enabled
      system.adapter.homekit-controller.0     : homekit-controller    : raspi01                                  - disabled
    + system.adapter.hue.0                    : hue                   : raspi01                                  -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspi01                                  -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspi01                                  -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : raspi01                                  -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : raspi01                                  -  enabled, port: 8086
      system.adapter.iot.0                    : iot                   : raspi01                                  - disabled
    + system.adapter.iqontrol.0               : iqontrol              : raspi01                                  -  enabled
    + system.adapter.javascript.0             : javascript            : raspi01                                  -  enabled
      system.adapter.linux-control.0          : linux-control         : raspi01                                  - disabled
    + system.adapter.logparser.0              : logparser             : raspi01                                  -  enabled
    + system.adapter.lupusec.0                : lupusec               : raspi01                                  -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspi01                                  - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.notification-manager.0   : notification-manager  : raspi01                                  -  enabled
    + system.adapter.panasonic-viera.1        : panasonic-viera       : raspi01                                  -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : raspi01                                  -  enabled
    + system.adapter.ping.0                   : ping                  : raspi01                                  -  enabled
    + system.adapter.pushover.0               : pushover              : raspi01                                  -  enabled
      system.adapter.roborock.0               : roborock              : raspi01                                  - disabled
    + system.adapter.rpi2.0                   : rpi2                  : raspi01                                  -  enabled
    + system.adapter.samsung_tizen.0          : samsung_tizen         : raspi01                                  -  enabled, port: 8002
      system.adapter.smartcontrol.0           : smartcontrol          : raspi01                                  - disabled
    + system.adapter.sonos.0                  : sonos                 : raspi01                                  -  enabled
    + system.adapter.synology.1               : synology              : raspi01                                  -  enabled, port: 45101
    + system.adapter.synology.2               : synology              : raspi01                                  -  enabled, port: 45001
      system.adapter.tr-064.0                 : tr-064                : raspi01                                  - disabled
    + system.adapter.trashschedule.0          : trashschedule         : raspi01                                  -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspi01                                  -  enabled
      system.adapter.uv-protect.0             : uv-protect            : raspi01                                  -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : raspi01                                  -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi01                                  - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi01                                  - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspi01                                  - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi01                                  - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspi01                                  - disabled
      system.adapter.vis.0                    : vis                   : raspi01                                  -  enabled
    + system.adapter.web.0                    : web                   : raspi01                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspi01                                  -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2227875-if00
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): Beta (latest)
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                    │ name                   │ version  │ upgrade policy │
    │ 0       │ 'system.adapter.admin'                │ 'admin'                │ '7.9.1'  │ 'none'         │
    │ 1       │ 'system.adapter.alexa2'               │ 'alexa2'               │ '3.28.1' │ 'none'         │
    │ 2       │ 'system.adapter.alias-manager'        │ 'alias-manager'        │ '2.1.0'  │ 'none'         │
    │ 3       │ 'system.adapter.backitup'             │ 'backitup'             │ '3.3.17' │ 'none'         │
    │ 4       │ 'system.adapter.cloud'                │ 'cloud'                │ '6.1.2'  │ 'none'         │
    │ 5       │ 'system.adapter.daswetter'            │ 'daswetter'            │ '4.5.4'  │ 'none'         │
    │ 6       │ 'system.adapter.devices'              │ 'devices'              │ '2.1.1'  │ 'none'         │
    │ 7       │ 'system.adapter.discovery'            │ 'discovery'            │ '5.0.0'  │ 'none'         │
    │ 8       │ 'system.adapter.enigma2'              │ 'enigma2'              │ '2.3.0'  │ 'none'         │
    │ 9       │ 'system.adapter.eusec'                │ 'eusec'                │ '2.0.3'  │ 'none'         │
    │ 10      │ 'system.adapter.flot'                 │ 'flot'                 │ '1.12.0' │ 'none'         │
    │ 11      │ 'system.adapter.fritzdect'            │ 'fritzdect'            │ '2.6.2'  │ 'none'         │
    │ 12      │ 'system.adapter.frontier_silicon'     │ 'frontier_silicon'     │ '0.5.1'  │ 'none'         │
    │ 13      │ 'system.adapter.ham'                  │ 'ham'                  │ '5.3.1'  │ 'none'         │
    │ 14      │ 'system.adapter.hass'                 │ 'hass'                 │ '2.1.0'  │ 'none'         │
    │ 15      │ 'system.adapter.history'              │ 'history'              │ '4.0.0'  │ 'none'         │
    │ 16      │ 'system.adapter.homekit-controller'   │ 'homekit-controller'   │ '0.5.11' │ 'none'         │
    │ 17      │ 'system.adapter.hue'                  │ 'hue'                  │ '3.16.2' │ 'none'         │
    │ 18      │ 'system.adapter.ical'                 │ 'ical'                 │ '1.20.1' │ 'none'         │
    │ 19      │ 'system.adapter.influxdb'             │ 'influxdb'             │ '4.0.2'  │ 'none'         │
    │ 20      │ 'system.adapter.iot'                  │ 'iot'                  │ '6.1.3'  │ 'none'         │
    │ 21      │ 'system.adapter.iqontrol'             │ 'iqontrol'             │ '3.0.0'  │ 'none'         │
    │ 22      │ 'system.adapter.javascript'           │ 'javascript'           │ '9.2.4'  │ 'none'         │
    │ 23      │ 'system.adapter.linux-control'        │ 'linux-control'        │ '1.1.5'  │ 'none'         │
    │ 24      │ 'system.adapter.logparser'            │ 'logparser'            │ '2.5.0'  │ 'none'         │
    │ 25      │ 'system.adapter.lupusec'              │ 'lupusec'              │ '2.0.8'  │ 'none'         │
    │ 26      │ 'system.adapter.mqtt'                 │ 'mqtt'                 │ '6.1.4'  │ 'none'         │
    │ 27      │ 'system.adapter.notification-manager' │ 'notification-manager' │ '1.3.0'  │ 'none'         │
    │ 28      │ 'system.adapter.panasonic-viera'      │ 'panasonic-viera'      │ '2.1.0'  │ 'none'         │
    │ 29      │ 'system.adapter.pi-hole'              │ 'pi-hole'              │ '2.0.0'  │ 'none'         │
    │ 30      │ 'system.adapter.ping'                 │ 'ping'                 │ '2.2.4'  │ 'none'         │
    │ 31      │ 'system.adapter.pushover'             │ 'pushover'             │ '5.0.0'  │ 'none'         │
    │ 32      │ 'system.adapter.roborock'             │ 'roborock'             │ '0.7.4'  │ 'none'         │
    │ 33      │ 'system.adapter.rpi2'                 │ 'rpi2'                 │ '3.0.2'  │ 'none'         │
    │ 34      │ 'system.adapter.samsung_tizen'        │ 'samsung_tizen'        │ '1.1.0'  │ 'none'         │
    │ 35      │ 'system.adapter.simple-api'           │ 'simple-api'           │ '3.0.7'  │ 'none'         │
    │ 36      │ 'system.adapter.smartcontrol'         │ 'smartcontrol'         │ '2.0.1'  │ 'none'         │
    │ 37      │ 'system.adapter.socketio'             │ 'socketio'             │ '7.1.3'  │ 'none'         │
    │ 38      │ 'system.adapter.sonos'                │ 'sonos'                │ '3.0.0'  │ 'none'         │
    │ 39      │ 'system.adapter.synology'             │ 'synology'             │ '3.1.0'  │ 'none'         │
    │ 40      │ 'system.adapter.tr-064'               │ 'tr-064'               │ '4.3.0'  │ 'none'         │
    │ 41      │ 'system.adapter.trashschedule'        │ 'trashschedule'        │ '5.3.0'  │ 'none'         │
    │ 42      │ 'system.adapter.tuya'                 │ 'tuya'                 │ '3.17.0' │ 'none'         │
    │ 43      │ 'system.adapter.uv-protect'           │ 'uv-protect'           │ '0.6.12' │ 'none'         │
    │ 44      │ 'system.adapter.viessmannapi'         │ 'viessmannapi'         │ '2.4.5'  │ 'none'         │
    │ 45      │ 'system.adapter.vis'                  │ 'vis'                  │ '1.5.6'  │ 'none'         │
    │ 46      │ 'system.adapter.vis-colorpicker'      │ 'vis-colorpicker'      │ '2.1.0'  │ 'none'         │
    │ 47      │ 'system.adapter.vis-jqui-mfd'         │ 'vis-jqui-mfd'         │ '1.1.3'  │ 'none'         │
    │ 48      │ 'system.adapter.vis-metro'            │ 'vis-metro'            │ '1.2.0'  │ 'none'         │
    │ 49      │ 'system.adapter.vis-timeandweather'   │ 'vis-timeandweather'   │ '1.2.2'  │ 'none'         │
    │ 50      │ 'system.adapter.vis-weather'          │ 'vis-weather'          │ '2.5.13' │ 'none'         │
    │ 51      │ 'system.adapter.web'                  │ 'web'                  │ '8.3.0'  │ 'none'         │
    │ 52      │ 'system.adapter.ws'                   │ 'ws'                   │ '4.1.0'  │ 'none'         │
    │ 53      │ 'system.adapter.zigbee'               │ 'zigbee'               │ '3.4.6'  │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: Beta (latest)
    Adapter    "admin"        : 7.9.1    , installed 7.9.1
    Adapter    "alexa2"       : 3.28.1   , installed 3.28.1
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "cloud"        : 6.1.2    , installed 6.1.2
    Adapter    "daswetter"    : 4.5.4    , installed 4.5.4
    Adapter    "devices"      : 2.1.1    , installed 2.1.1
    Adapter    "enigma2"      : 2.3.0    , installed 2.3.0
    Adapter    "eusec"        : 2.0.3    , installed 2.0.3
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "frontier_silicon": 0.5.1 , installed 0.5.1
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hass"         : 2.1.0    , installed 2.1.0
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.20.1   , installed 1.20.1
    Adapter    "iot"          : 6.1.3    , installed 6.1.3
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.2.4    , installed 9.2.4
    Controller "js-controller": 7.1.2    , installed 7.1.2
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.5.0    , installed 2.5.0
    Adapter    "lupusec"      : 2.0.8    , installed 2.0.8
    Adapter    "mcp"          : 1.0.0    , installed 1.0.0
    Adapter    "notification-manager": 1.3.0, installed 1.3.0
    Adapter    "panasonic-viera": 2.1.0  , installed 2.1.0
    Adapter    "pi-hole"      : 2.0.0    , installed 2.0.0
    Adapter    "ping"         : 2.2.4    , installed 2.2.4
    Adapter    "pushover"     : 5.0.0    , installed 5.0.0
    Adapter    "roborock"     : 0.7.4    , installed 0.7.4
    Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "trashschedule": 5.3.0    , installed 5.3.0
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "uv-protect"   : 0.6.12   , installed 0.6.12
    Adapter    "viessmannapi" : 2.4.5    , installed 2.4.5
    Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "web"          : 8.3.0    , installed 8.3.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Adapter    "zigbee"       : 3.4.6    , installed 3.4.6
    Objects and States
    Objects:        22012
    States:         15487
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q               Local Address:Port          Peer Address:PortProcess
    udp   UNCONN 0      0                          0.0.0.0:6666               0.0.0.0:*    users:(("io.tuya.0",pid=2010,fd=38))
    udp   UNCONN 0      0                          0.0.0.0:6667               0.0.0.0:*    users:(("io.tuya.0",pid=2010,fd=39))
    udp   UNCONN 0      0                          0.0.0.0:domain             0.0.0.0:*    users:(("pihole-FTL",pid=1051,fd=20))
    udp   UNCONN 0      0                          0.0.0.0:ntp                0.0.0.0:*    users:(("pihole-FTL",pid=1051,fd=39))
    udp   UNCONN 0      0                          0.0.0.0:49585              0.0.0.0:*    users:(("io.eusec.0",pid=2061,fd=37))
    udp   UNCONN 0      0                          0.0.0.0:37441              0.0.0.0:*    users:(("io.eusec.0",pid=2061,fd=38))
    udp   UNCONN 0      0                          0.0.0.0:58123              0.0.0.0:*    users:(("avahi-daemon",pid=701,fd=14))
    udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=701,fd=12))
    udp   UNCONN 0      0                                *:55203                    *:*    users:(("avahi-daemon",pid=701,fd=15))
    udp   UNCONN 0      0                                *:domain                   *:*    users:(("pihole-FTL",pid=1051,fd=22))
    udp   UNCONN 0      0                                *:ntp                      *:*    users:(("pihole-FTL",pid=1051,fd=41))
    udp   UNCONN 0      0                                *:8555                     *:*    users:(("go2rtc",pid=2125,fd=8))
    udp   UNCONN 0      0      [fe80::545f:85e5:cea0:b736]:dhcpv6-client            *:*    users:(("NetworkManager",pid=851,fd=28))
    udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=701,fd=13))
    tcp   LISTEN 0      20                       127.0.0.1:smtp               0.0.0.0:*    users:(("exim4",pid=1322,fd=5))
    tcp   LISTEN 0      4096                     127.0.0.1:ipp                0.0.0.0:*    users:(("cupsd",pid=940,fd=7))
    tcp   LISTEN 0      200                        0.0.0.0:http               0.0.0.0:*    users:(("pihole-FTL",pid=1051,fd=35))
    tcp   LISTEN 0      32                         0.0.0.0:domain             0.0.0.0:*    users:(("pihole-FTL",pid=1051,fd=21))
    tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=978,fd=6))
    tcp   LISTEN 0      200                        0.0.0.0:https              0.0.0.0:*    users:(("pihole-FTL",pid=1051,fd=36))
    tcp   LISTEN 0      511                      127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=941,fd=23))
    tcp   LISTEN 0      511                      127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=941,fd=29))
    tcp   LISTEN 0      511                        0.0.0.0:bbs                0.0.0.0:*    users:(("io.lupusec.0",pid=2293,fd=36))
    tcp   LISTEN 0      200                           [::]:http                  [::]:*    users:(("pihole-FTL",pid=1051,fd=37))
    tcp   LISTEN 0      32                            [::]:domain                [::]:*    users:(("pihole-FTL",pid=1051,fd=23))
    tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=978,fd=7))
    tcp   LISTEN 0      200                           [::]:https                 [::]:*    users:(("pihole-FTL",pid=1051,fd=38))
    tcp   LISTEN 0      4096                             *:8555                     *:*    users:(("go2rtc",pid=2125,fd=7))
    tcp   LISTEN 0      4096                             *:1984                     *:*    users:(("go2rtc",pid=2125,fd=6))
    tcp   LISTEN 0      4096                         [::1]:ipp                   [::]:*    users:(("cupsd",pid=940,fd=6))
    tcp   LISTEN 0      16                               *:5900                     *:*    users:(("wayvnc",pid=969,fd=9))
    tcp   LISTEN 0      20                           [::1]:smtp                  [::]:*    users:(("exim4",pid=1322,fd=6))
    tcp   LISTEN 0      511                              *:tproxy                   *:*    users:(("io.admin.0",pid=1311,fd=39))
    tcp   LISTEN 0      511                              *:8082                     *:*    users:(("io.web.0",pid=2286,fd=36))
    tcp   LISTEN 0      511                              *:3500                     *:*    users:(("io.sonos.0",pid=1956,fd=31))
    tcp   LISTEN 0      2                                *:ms-wbt-server            *:*    users:(("xrdp",pid=1028,fd=13))
    2026-06-14 00:01:21.120  - warn: javascript.0 (1466)     at JavaScript.emit (node:events:519:28)
    2026-06-14 00:01:21.120  - warn: javascript.0 (1466)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11135:57)
    2026-06-14 00:01:21.120  - warn: javascript.0 (1466)     at processImmediate (node:internal/timers:484:21)
    2026-06-14 00:01:21.120  - warn: javascript.0 (1466)     at process.callbackTrampoline (node:internal/async_hooks:130:17)
    2026-06-14 00:01:21.120  - warn: javascript.0 (1466) getState "alias.0.Sensor.Th_Seitenbalkon.UNREACH" not found (3)
    2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at BatterieCheck (script.js.common.91-Infrastruktur.9101-Batteriestatus:41:11)
    2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at Object.<anonymous> (script.js.common.91-Infrastruktur.9101-Batteriestatus:83:9)
    2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1846:38)
    2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:839:29)
    2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at JavaScript.emit (node:events:519:28)
    2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11135:57)
    2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at processImmediate (node:internal/timers:484:21)
    2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at process.callbackTrampoline (node:internal/async_hooks:130:17)
    2026-06-14 00:01:21.122  - warn: javascript.0 (1466) getState "alias.0.Sensor.Th_WG.UNREACH" not found (3)
    2026-06-14 00:01:21.122  - warn: javascript.0 (1466)     at BatterieCheck (script.js.common.91-Infrastruktur.9101-Batteriestatus:41:11)
    2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at Object.<anonymous> (script.js.common.91-Infrastruktur.9101-Batteriestatus:83:9)
    2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1846:38)
    2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:839:29)
    2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at JavaScript.emit (node:events:519:28)
    2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11135:57)
    2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at processImmediate (node:internal/timers:484:21)
    2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at process.callbackTrampoline (node:internal/async_hooks:130:17)
    2026-06-14 00:01:21.120  - info: iqontrol.0 (2167) COUNTER UNREACH erreichbar: 52 of 60
    2026-06-14 00:01:21.176  - info: iqontrol.0 (2167) COUNTER UNREACH unerreichbar: 7 of 60
    2026-06-14 00:01:21.400  - info: iqontrol.0 (2167) CALCULATION UNREACH (Nicht-)Erreichbarkeit has changed
    ============= Mark until here for C&P =============
    • H Hadebe
      ```bash
      Script v.2026-06-01
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64bit
      CPU threads     : 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           209M          0B        209M
               8062 M total memory
               4446 M used memory
               2034 M free memory
                124 M buffer memory
               1578 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** FILESYSTEM ***
      /var:
      1.4G    /var/
      789M    /var/log
      220M    /var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.8
      /usr/bin/npx            10.9.8
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.9.1
      javascript:     9.2.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        22012
      States:         15487
      #247
      @Hadebe sagte:
      pi
      MIttlerweile wird der user 'pi' nicht mehr vorgesehen. Wäre bei einer Neuinstallation behoben.
      Da ist immer noch GUI-Krempel installiert. Wäre bei einer Neuinstallation der Lite-Version nicht der Fall.
      Swap: 209M
      Wird mittlerweile anders angelegt. Wäre bei einer Neuinstallation behoben.
      Das nodejs-Repo ist nicht richtig installiert. Hol das per
      iob nodejs-update 22
      nach. Rückfragen sind zu bejahen. Wäre bei einer Neuinstallation auch nicht passiert.
      Insgesamt bleibe ich dabei: Das wird dir mit hoher Wahrscheinlichkeit in der ein oder anderen Form wieder auf die Füße fallen.
      • H Hadebe
        Also komplette Neuinstallation - gar nicht schön, aber wenn es nicht anders geht.
        Dann darf die Anleitung nur für Installationen ohne Desktop genutzt werden?
        fuzzy1955F Offline
        fuzzy1955F Offline
        fuzzy1955
        #248
        @Hadebe sagte:
        @Thomas-Braun
        Hi, Hadebe!
        Also - dank Thomas mache ich periodisch (alle 3 -4 Monate) eine Neuinstallation meines Testsystems inkl. Einspielen der aktuellen Backups vom Produktivsystem nur zum Zweck der Linux-Übung (ich kannte das Ding vor 2 Jahre nicht einmal ansatzweise) und dem Vorbeugen eines Totalausfalls meines Smart-Home-Systems mit IOB. An dem hängt meine 10 kWp-PV-Anlage samt 2 x WR und 3 x 10 kWh Speicher, 2 Wallboxen, die Pellets-Heizungsregelung, die Warmwasserbereitung, die Gartenbewässerung, die Garagentorsteuerung, das Brandmeldesystem usw. Also das gesamte Haus!
        Ich möchte nicht riskieren, dass ich plötzlich "nackt" dastehe ....
        Inzwischen macht es mir schon Spaß, das ganze System in 2-3 Stunden neu aufzusetzen. Und ich habe die Sicherheit, dass ich eben NICHT " plötzlich "nackt" dastehe!
        Gruß, Fuzzy
        Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
        Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
        Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
        Großes Danke an alle tatkräftigen Helfer im Forum!
        • H Hadebe
          Statt Neuinstallation - KI fragen, schrottiger als Schrott ging ja nicht
          Vielleicht hilft es dem einen oder anderen weiter...
          Ich habe natürlich eine Neuinstallation gescheut und als letzten Versuch die KI befragt. Mit dem Input meiner Posts und den Antworten von ThomasBraun habe ich jetzt gut eine Stunde mit der KI gechattet. Meine halb Bookworm halb Trixie Installation konnte tatsächlich repariert werden - unter konsequenter Löschung aller Pakete aus dem Desktop - iobroker läuft wieder, aber nun auf Trixie.
          Für mich bestimmt deutlich schneller als eine Neuinstallation.
          #249
          @Hadebe sagte:
          Da solltest du aber mit
          @Hadebe sagte:
          gut eine Stunde
          Hand on Time bequem auskommen!
          Wenn man "genau" ist und die Zeit für den Neubau der Pakete nach dem Restore noch hinzunimmt, sollte es trotzdem nicht länger als "gut eine Stunde" dauern
          • fuzzy1955F fuzzy1955
            @Hadebe sagte:
            @Thomas-Braun
            Hi, Hadebe!
            Gruß, Fuzzy
            #250
            @fuzzy1955 sagte:
            LOL - kann mich nicht daran erinnern das in der Form mal empfohlen zu haben. Aber wenn es dir als 'Trainigslager' dient, okay.
            fuzzy1955F 1 Antwort Letzte Antwort
            • H Offline
              Hadebe
              #251
              Dass es noch Displayreste gibt, hätte ich selbst sehen können. Aber dass nodejs-repo nicht korrekt ist, erschließt sich mir nicht. Jedenfalls habe ich das nachgezogen. Danke dafür.
              Das Ganze zeigt aber, das du Recht hast, die Neuinstallation ist sinnvoller.
              • H Hadebe
                #252
                @Hadebe
                Das fehlende nodesource-Repo sieht man hier (bzw. sieht man eben nicht):
                sowie in der Ausgabe von
                nodejs:
                  Version table:
                • H Offline
                  Hadebe
                  #253
                  ja, der Abschnitt sieht jetzt so aus
                  Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                  ist nur schwer, etwas zu sehen was nicht da ist
                  • H Hadebe
                    #254
                    @Hadebe sagte:
                    Das ist richtig, da braucht es ein wenig Erfahrung wie das ganze Paketmanagement bei Debian-artigen Distributionen funktioniert.
                    • da_WoodyD Offline
                      da_WoodyD Offline
                      #255
                      hab vor paar tagen iob VM auf trixie mit deiner anleitung gemacht. tropsdem dürfte da was nicht so ganz stimmen...
                      entweder hab ich was übersehn, oder ein anderes problem.
                      Script v.2026-06-01
                      *** BASE SYSTEM ***
                       Static hostname: ioBroker
                             Icon name: computer-vm
                               Chassis: vm 🖴
                        Virtualization: kvm
                                Kernel: Linux 6.12.90+deb13.1-amd64
                          Architecture: x86-64
                       Hardware Vendor: QEMU
                        Hardware Model: Standard PC _i440FX + PIIX, 1996_
                      Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
                         Firmware Date: Tue 2014-04-01
                          Firmware Age: 12y 2month 1w 6d
                      OS is similar to:
                      model name      : Common KVM processor
                      Docker          : false
                      Virtualization  : kvm
                      Kernel          : x86_64
                      Userland        : 64bit
                      System was installed 1578 days ago (on 2022-02-17).
                       12:39:55 up  8:39,  2 users,  load average: 1.83, 1.41, 1.31
                      CPU threads     : 4
                                     Local time: Sun 2026-06-14 12:39:55 CEST
                                 Universal time: Sun 2026-06-14 10:39:55 UTC
                                       RTC time: Sun 2026-06-14 10:39:55
                                      Time zone: Europe/Vienna (CEST, +0200)
                                    NTP service: active
                                RTC in local TZ: no
                      woody
                      HOME=/home/woody
                      GROUPS=woody adm cdrom floppy sudo audio dip video plugdev netdev iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev
                      Display-Server:         X11
                      Display-Manager:        Not found
                      Desktop:
                      Session:                tty
                      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'.
                      Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                      *** MEMORY ***
                      Mem:            6.2G        4.9G        606M        3.8M        946M        1.3G
                      Swap:           1.0G         12K        1.0G
                      Total:          7.2G        4.9G        1.6G
                               5931 M total memory
                               4697 M used memory
                               4379 M active memory
                                662 M inactive memory
                                577 M free memory
                                 99 M buffer memory
                                803 M swap cache
                                974 M total swap
                                  0 M used swap
                                974 M free swap
                      top - 12:39:56 up  8:39,  2 users,  load average: 1.83, 1.41, 1.31
                      Tasks: 158 total,   2 running, 156 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  4.8 us,  0.0 sy,  0.0 ni, 95.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   5931.8 total,    577.1 free,   4698.6 used,    903.4 buff/cache
                      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   1233.3 avail Mem
                      *** FILESYSTEM ***
                      udev           devtmpfs  2.9G     0  2.9G   0% /dev
                      tmpfs          tmpfs     594M  516K  593M   1% /run
                      /dev/sda1      ext4       97G   29G   64G  31% /
                      tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
                      tmpfs          tmpfs     2.9G  3.2M  2.9G   1% /tmp
                      tmpfs          tmpfs     594M  8.0K  594M   1% /run/user/1000
                      [Sun Jun 14 04:00:25 2026] EXT4-fs (sda1): mounted filesystem 2b1b283d-3212-4438-a10b-e527d5d65141 ro with ordered data mode. Quota mode: none.
                      [Sun Jun 14 04:00:26 2026] EXT4-fs (sda1): re-mounted 2b1b283d-3212-4438-a10b-e527d5d65141 r/w.
                      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                      /var:
                      6.4G    /var/
                      3.8G    /var/cache/apt
                      3.8G    /var/cache
                      3.7G    /var/cache/apt/archives
                      2.5G    /var/log
                      Archived and active journals take up 2.3G in the file system.
                      937M    /opt/iobroker/backups/
                      798M    /opt/iobroker/iobroker-data/
                      349M    /opt/iobroker/iobroker-data/files
                      303M    /opt/iobroker/iobroker-data/backup-objects
                      51M     /opt/iobroker/iobroker-data/files/iqontrol.meta/userimages
                      67M     /opt/iobroker/iobroker-data/objects.jsonl
                      33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
                      20M     /opt/iobroker/iobroker-data/objects.json.bak
                      19M     /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      No nvbackup.json found.
                      /usr/bin/npm            10.9.8
                      /usr/bin/npx            10.9.8
                      nodejs:
                        Version table:
                       *** 22.22.3-1nodesource1 1001
                           22.22.2-1nodesource1 1001
                           22.22.1-1nodesource1 1001
                           22.22.0-1nodesource1 1001
                           22.21.0-1nodesource1 1001
                           22.20.0-1nodesource1 1001
                           22.19.0-1nodesource1 1001
                           22.18.0-1nodesource1 1001
                           22.17.1-1nodesource1 1001
                           22.17.0-1nodesource1 1001
                           22.16.0-1nodesource1 1001
                           22.15.1-1nodesource1 1001
                           22.15.0-1nodesource1 1001
                           22.14.0-1nodesource1 1001
                           22.13.1-1nodesource1 1001
                           22.13.0-1nodesource1 1001
                           22.12.0-1nodesource1 1001
                           22.11.0-1nodesource1 1001
                           22.10.0-1nodesource1 1001
                           22.9.0-1nodesource1 1001
                           22.8.0-1nodesource1 1001
                           22.7.0-1nodesource1 1001
                           22.6.0-1nodesource1 1001
                           22.5.1-1nodesource1 1001
                           22.5.0-1nodesource1 1001
                           22.4.1-1nodesource1 1001
                           22.4.0-1nodesource1 1001
                           22.3.0-1nodesource1 1001
                           22.2.0-1nodesource1 1001
                           22.1.0-1nodesource1 1001
                           22.0.0-1nodesource1 1001
                              500 http://deb.debian.org/debian trixie/main amd64 Packages
                              500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 31164)
                      admin:          7.9.1
                      javascript:     9.2.4
                      nodejs modules from github:     3
                      +-- iobroker.f1@0.1.6 (git+ssh://git@github.com/bloop16/ioBroker.f1.git#0a3539fe0556aaf4dc1ffe47002ce74aa3664e45)
                      +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#375dc3d6d53d8322071e7d172137fef1f5849370)
                      | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                        system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
                      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                        system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                      + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
                        system.adapter.daswetter.0              : daswetter             : ioBroker                                 - disabled
                      + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                      + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
                      + system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                      + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
                      + system.adapter.f1.0                     : f1                    : ioBroker                                 -  enabled
                      + system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
                      + system.adapter.gruenbeck.0              : gruenbeck             : ioBroker                                 -  enabled
                        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                        system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                        system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
                        system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
                      + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                      + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                      + system.adapter.iqontrol.0               : iqontrol              : ioBroker                                 -  enabled
                      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                        system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 -  enabled
                        system.adapter.meteoalarm.1             : meteoalarm            : ioBroker                                 -  enabled
                        system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
                      + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                      + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                      + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: woody
                      + system.adapter.roborock.0               : roborock              : ioBroker                                 -  enabled
                      + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
                      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, bind: 0.0.0.0
                      + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
                      + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 -  enabled
                      + system.adapter.smartthings.0            : smartthings           : ioBroker                                 -  enabled
                      + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 192.168.0.250
                      + system.adapter.srm.0                    : srm                   : ioBroker                                 -  enabled, port: 8001
                      + system.adapter.switchbot-hub.0          : switchbot-hub         : ioBroker                                 -  enabled
                      + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
                      + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 4001
                      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ true         │
                      Upgrade policy: patch
                      │ 4       │ 'system.adapter.birthdays'              │ 'birthdays'              │ '6.1.0'   │ 'none'         │
                      │ 5       │ 'system.adapter.cloud'                  │ 'cloud'                  │ '6.1.1'   │ 'none'         │
                      │ 6       │ 'system.adapter.daswetter'              │ 'daswetter'              │ '4.5.4'   │ 'none'         │
                      │ 7       │ 'system.adapter.device-reminder'        │ 'device-reminder'        │ '3.1.2'   │ 'none'         │
                      │ 8       │ 'system.adapter.device-watcher'         │ 'device-watcher'         │ '2.15.15' │ 'none'         │
                      │ 9       │ 'system.adapter.devices'                │ 'devices'                │ '2.1.1'   │ 'none'         │
                      │ 10      │ 'system.adapter.energiefluss'           │ 'energiefluss'           │ '3.6.2'   │ 'none'         │
                      │ 11      │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.2'   │ 'none'         │
                      │ 12      │ 'system.adapter.f1'                     │ 'f1'                     │ '0.1.6'   │ 'none'         │
                      │ 13      │ 'system.adapter.fronius'                │ 'fronius'                │ '2.2.0'   │ 'none'         │
                      │ 14      │ 'system.adapter.gruenbeck'              │ 'gruenbeck'              │ '0.0.46'  │ 'none'         │
                      │ 15      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.20.1'  │ 'none'         │
                      │ 16      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '4.0.2'   │ 'none'         │
                      │ 17      │ 'system.adapter.iot'                    │ 'iot'                    │ '6.1.3'   │ 'none'         │
                      │ 18      │ 'system.adapter.iqontrol'               │ 'iqontrol'               │ '3.0.0'   │ 'none'         │
                      │ 19      │ 'system.adapter.javascript'             │ 'javascript'             │ '9.2.4'   │ 'none'         │
                      │ 20      │ 'system.adapter.meteoalarm'             │ 'meteoalarm'             │ '4.0.1'   │ 'none'         │
                      │ 21      │ 'system.adapter.openweathermap'         │ 'openweathermap'         │ '1.4.0'   │ 'none'         │
                      │ 22      │ 'system.adapter.ping'                   │ 'ping'                   │ '2.2.4'   │ 'none'         │
                      │ 23      │ 'system.adapter.proxmox'                │ 'proxmox'                │ '2.6.1'   │ 'none'         │
                      │ 24      │ 'system.adapter.rest-api'               │ 'rest-api'               │ '4.0.1'   │ 'none'         │
                      │ 25      │ 'system.adapter.roborock'               │ 'roborock'               │ '0.7.4'   │ 'none'         │
                      │ 26      │ 'system.adapter.scenes'                 │ 'scenes'                 │ '4.0.4'   │ 'none'         │
                      │ 27      │ 'system.adapter.shelly'                 │ 'shelly'                 │ '10.6.1'  │ 'none'         │
                      │ 28      │ 'system.adapter.shuttercontrol'         │ 'shuttercontrol'         │ '2.0.12'  │ 'none'         │
                      │ 29      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'   │ 'none'         │
                      │ 30      │ 'system.adapter.smartcontrol'           │ 'smartcontrol'           │ '2.0.1'   │ 'none'         │
                      │ 31      │ 'system.adapter.smartthings'            │ 'smartthings'            │ '0.3.0'   │ 'none'         │
                      │ 32      │ 'system.adapter.socketio'               │ 'socketio'               │ '7.1.3'   │ 'none'         │
                      │ 33      │ 'system.adapter.sonoff'                 │ 'sonoff'                 │ '3.3.0'   │ 'none'         │
                      │ 34      │ 'system.adapter.srm'                    │ 'srm'                    │ '1.0.0'   │ 'none'         │
                      │ 35      │ 'system.adapter.switchbot-hub'          │ 'switchbot-hub'          │ '0.1.2'   │ 'none'         │
                      │ 36      │ 'system.adapter.synology'               │ 'synology'               │ '3.1.0'   │ 'none'         │
                      │ 37      │ 'system.adapter.trashschedule'          │ 'trashschedule'          │ '5.3.0'   │ 'none'         │
                      │ 38      │ 'system.adapter.web'                    │ 'web'                    │ '8.3.0'   │ 'none'         │
                      │ 39      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'   │ 'none'         │
                      Adapter    "birthdays"    : 6.1.0    , installed 6.1.0
                      Adapter    "cloud"        : 6.1.2    , installed 6.1.1  [Updatable]
                      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                      Adapter    "device-watcher": 2.15.15 , installed 2.15.15
                      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                      Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
                      Adapter    "fronius"      : 2.2.0    , installed 2.2.0
                      Adapter    "gruenbeck"    : 0.0.46   , installed 0.0.46
                      Adapter    "meteoalarm"   : 4.0.1    , installed 4.0.1
                      Adapter    "openweathermap": 1.4.0   , installed 1.4.0
                      Adapter    "proxmox"      : 2.6.1    , installed 2.6.1
                      Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
                      Adapter    "scenes"       : 4.0.4    , installed 4.0.4
                      Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                      Adapter    "shuttercontrol": 2.0.12  , installed 2.0.12
                      Adapter    "smartthings"  : 0.3.0    , installed 0.3.0
                      Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
                      Adapter    "srm"          : 1.0.0    , installed 1.0.0
                      Objects and States
                      Objects:        19242
                      States:         14467
                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-06-11T18:59:48Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                      W: Failed to fetch https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-06-11T18:59:48Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                      W: Some index files failed to download. They have been ignored, or old ones used instead.
                      Hit:1 http://security.debian.org/debian-security trixie-security InRelease
                      Hit:2 http://deb.debian.org/debian trixie InRelease
                      Get:4 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
                      Err:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                      udp   UNCONN 0      0            0.0.0.0:bootpc      0.0.0.0:*    users:(("dhclient",pid=576,fd=7))
                      udp   UNCONN 0      0            0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=626,fd=5),("systemd",pid=1,fd=45))
                      udp   UNCONN 0      0            0.0.0.0:58866       0.0.0.0:*    users:(("io.roborock.0",pid=1066,fd=36))
                      udp   UNCONN 0      0            0.0.0.0:coap        0.0.0.0:*    users:(("io.shelly.0",pid=1792,fd=52))
                      udp   UNCONN 0      0               [::]:sunrpc         [::]:*    users:(("rpcbind",pid=626,fd=7),("systemd",pid=1,fd=47))
                      tcp   LISTEN 0      20         127.0.0.1:smtp        0.0.0.0:*    users:(("exim4",pid=935,fd=5))
                      tcp   LISTEN 0      4096         0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=626,fd=4),("systemd",pid=1,fd=44))
                      tcp   LISTEN 0      128          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=693,fd=6))
                      tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=632,fd=23))
                      tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=632,fd=29))
                      tcp   LISTEN 0      511          0.0.0.0:1882        0.0.0.0:*    users:(("io.shelly.1",pid=1894,fd=45))
                      tcp   LISTEN 0      128        127.0.0.1:6010        0.0.0.0:*    users:(("sshd-session",pid=35960,fd=11))
                      tcp   LISTEN 0      1            0.0.0.0:6969        0.0.0.0:*    users:(("nc",pid=36584,fd=3))
                      tcp   LISTEN 0      511    192.168.0.250:1883        0.0.0.0:*    users:(("io.sonoff.0",pid=1848,fd=40))
                      tcp   LISTEN 0      4096            [::]:sunrpc         [::]:*    users:(("rpcbind",pid=626,fd=6),("systemd",pid=1,fd=46))
                      tcp   LISTEN 0      128             [::]:ssh            [::]:*    users:(("sshd",pid=693,fd=7))
                      tcp   LISTEN 0      128            [::1]:6010           [::]:*    users:(("sshd-session",pid=35960,fd=10))
                      tcp   LISTEN 0      20             [::1]:smtp           [::]:*    users:(("exim4",pid=935,fd=6))
                      tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.admin.0",pid=8397,fd=39))
                      tcp   LISTEN 0      511                *:8082              *:*    users:(("io.web.0",pid=8173,fd=35))
                      tcp   LISTEN 0      511                *:8084              *:*    users:(("io.socketio.0",pid=2104,fd=34))
                      tcp   LISTEN 0      511                *:8087              *:*    users:(("io.simple-api.0",pid=2070,fd=35))
                      tcp   LISTEN 0      511                *:8093              *:*    users:(("io.rest-api.0",pid=2164,fd=34))
                      2026-06-14 12:30:04.051  - info: host.ioBroker instance system.adapter.ical.2 in version "1.20.1" started with pid 35300
                      2026-06-14 12:30:05.361  - info: ical.2 (35300) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.3, js-controller: 7.1.2
                      2026-06-14 12:30:06.084  - info: ical.2 (35300) processing URL: Haus https://calendar.google.com/calendar/ical/amtc1uteokodeg9co0oo5q7p38%40group.calendar.google.com/private-947d1d0e17a9ba06719e88324dd68c8a/basic.ics
                      2026-06-14 12:30:08.058  - info: host.ioBroker instance system.adapter.ical.1 in version "1.20.1" started with pid 35319
                      2026-06-14 12:30:08.376  - info: ical.3 (35284) Terminated (NO_ERROR): Without reason
                      2026-06-14 12:30:08.908  - info: host.ioBroker instance system.adapter.ical.3 having pid 35284 terminated with code 0 (NO_ERROR)
                      2026-06-14 12:30:09.104  - info: ical.1 (35319) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.3, js-controller: 7.1.2
                      2026-06-14 12:30:09.612  - info: ical.1 (35319) processing URL: Karin https://calendar.google.com/calendar/ical/karin.woechtl%40gmail.com/private-87598d02e239b73b66219a6ec217b62c/basic.ics
                      2026-06-14 12:30:11.221  - info: ical.2 (35300) Terminated (NO_ERROR): Without reason
                      2026-06-14 12:30:11.741  - info: host.ioBroker instance system.adapter.ical.2 having pid 35300 terminated with code 0 (NO_ERROR)
                      2026-06-14 12:30:12.063  - info: host.ioBroker instance system.adapter.ical.0 in version "1.20.1" started with pid 35336
                      2026-06-14 12:30:13.515  - info: ical.0 (35336) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.3, js-controller: 7.1.2
                      2026-06-14 12:30:14.083  - info: ical.0 (35336) processing URL: Simon https://calendar.google.com/calendar/ical/simon.mueck%40gmail.com/private-37a8e46442c21ff64e4b4130cd132090/basic.ics
                      2026-06-14 12:30:14.774  - info: ical.1 (35319) Terminated (NO_ERROR): Without reason
                      2026-06-14 12:30:15.286  - info: host.ioBroker instance system.adapter.ical.1 having pid 35319 terminated with code 0 (NO_ERROR)
                      2026-06-14 12:30:16.068  - info: host.ioBroker instance system.adapter.meteoalarm.1 in version "4.0.1" started with pid 35355
                      2026-06-14 12:30:18.963  - info: host.ioBroker instance system.adapter.meteoalarm.1 having pid 35355 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2026-06-14 12:30:19.318  - info: ical.0 (35336) Terminated (NO_ERROR): Without reason
                      2026-06-14 12:30:19.831  - info: host.ioBroker instance system.adapter.ical.0 having pid 35336 terminated with code 0 (NO_ERROR)
                      2026-06-14 12:30:20.072  - info: host.ioBroker instance system.adapter.meteoalarm.0 in version "4.0.1" started with pid 35375
                      2026-06-14 12:30:24.364  - info: host.ioBroker instance system.adapter.meteoalarm.0 having pid 35375 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2026-06-14 12:40:04.013  - info: host.ioBroker instance system.adapter.meteoalarm.1 in version "4.0.1" started with pid 36324
                      2026-06-14 12:40:07.919  - info: host.ioBroker instance system.adapter.meteoalarm.1 having pid 36324 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2026-06-14 12:40:12.011  - info: host.ioBroker instance system.adapter.meteoalarm.0 in version "4.0.1" started with pid 36418
                      2026-06-14 12:40:16.789  - info: host.ioBroker instance system.adapter.meteoalarm.0 having pid 36418 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      • da_WoodyD da_Woody
                        Script v.2026-06-01
                        *** BASE SYSTEM ***
                                 Chassis: vm 🖴
                          Virtualization: kvm
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64bit
                        CPU threads     : 4
                                      NTP service: active
                                  RTC in local TZ: no
                        woody
                        HOME=/home/woody
                        iobroker
                        HOME=/home/iobroker
                        Display-Server:         X11
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Swap:           1.0G         12K        1.0G
                                 5931 M total memory
                                 4697 M used memory
                                  577 M free memory
                                   99 M buffer memory
                                  803 M swap cache
                                  974 M total swap
                                    0 M used swap
                                  974 M free swap
                        *** FILESYSTEM ***
                        /var:
                        6.4G    /var/
                        3.8G    /var/cache/apt
                        3.8G    /var/cache
                        2.5G    /var/log
                        USB-Devices by-id:
                        /usr/bin/npm            10.9.8
                        /usr/bin/npx            10.9.8
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.9.1
                        javascript:     9.2.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        19242
                        States:         14467
                        #256
                        @da_Woody sagte:
                        Display-Server: X11
                        Das stimmt schon nicht. Auf einem Server läuft KEIN Display-Server...
                        Das nodesource-Repo nochmal neuanlegen:
                          @da_Woody sagte:
                          Display-Server: X11
                          da_WoodyD Offline
                          da_WoodyD Offline
                          #257
                          @Thomas-Braun sagte:
                          das hat anscheinend geklappert! thnx!
                          Display-Server: X11
                          woher das kommt ist mir ein rätsel... wie kann ich das fixen?
                            Display-Server: X11
                            #258
                            @da_Woody
                              @fuzzy1955 sagte:
                              fuzzy1955F Offline
                              fuzzy1955F Offline
                              fuzzy1955
                              #259
                              Stimmt - empfohlen hast du es nicht. Es ist tatsächlich mein "Trainingslager", damit ich mit Linux und IOB einigermaßen fit bleibe ;-)
                                @da_Woody
                                da_WoodyD Offline
                                da_WoodyD Offline
                                #260
                                @Thomas-Braun
                                kann es sein, daß das an mobaxterm liegt?
                                iob fix 2x drübergelassen...
                                  @Thomas-Braun
                                  #261
                                  @da_Woody
                                  Möglich. Jedenfall schleppt das Ding wohl aus irgendwelchen Gründen X11-forwarding an.
                                  Kannst du das boot target nicht per
                                  sudo systemctl set-default multi-user.target
                                  setzen?
                                    @da_Woody
                                    setzen?
                                    da_WoodyD Offline
                                    da_WoodyD Offline
                                    #262
                                    hatte ich ja schon per iob fix gemacht. jetzt nochmal damit.
                                    reboot vom iob, selbe meldung. ich tipp da echt auf moba.
                                    und weils so witzig ist, nach dem reboot hat sich alexa adapter wieder auf gelb gestellt...
                                    https://forum.iobroker.net/topic/84716/gelöst-schwierigkeiten-mit-alexa-adapter/107?_=1781265403827
                                    gerade über putty rein, da sieht man halt nix. wesweil ich da auf moba tippe, das da was reinhaut.
                                    die vm wurde nie mit gfx aufgesetzt...
                                    login as: woody
                                    woody@192.168.0.250's password:
                                    Linux ioBroker 6.12.90+deb13.1-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.90-2 (2026-05-27) x86_64
                                    permitted by applicable law.
                                    Last login: Tue Jun 16 12:30:49 2026 from 192.168.7.208
                                    woody@ioBroker:~$
                                      login as: woody
                                      woody@ioBroker:~$
                                      #263
                                      @da_Woody
                                      Und über puTTY sagt
                                      systemctl get-default
                                      dann was?
                                        @da_Woody
                                        Und über puTTY sagt
                                        dann was?
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        #264
                                        @Thomas-Braun
                                        tja,
                                        login as: woody
                                        Last login: Tue Jun 16 12:38:37 2026 from 192.168.7.208
                                        woody@ioBroker:~$ systemctl get-default
                                        multi-user.target
                                        woody@ioBroker:~$
                                          @Thomas-Braun
                                          tja,
                                          login as: woody
                                          multi-user.target
                                          woody@ioBroker:~$
                                          #265
                                          @da_Woody
                                          Dann schleppt mobaxterm da wohl einen vollen X-Server mit an. Warum auch immer.
                                          Offenbar tunneln die da eine X-Session über SSH.
