  3. Off Topic
  4. Pflege des Betriebssystems
  5. Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'
    6.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
265 Beiträge 50 Kommentatoren 78.5k Aufrufe 56 Beobachtet
  • H Hadebe
    ich habe mich mit ThomasBraun Rezept an das Upgrade gewagt. sudo apt upgrade --without-new-pkgs lief noch fehlerfrei. Aber der sudo apt full-upgrade lief in den Error:
    Errors were encountered while processing:
    /tmp/apt-dpkg-install-3wpKJZ/36-pi-greeter_1.2_arm64.deb
    /usr/bin/gdbus: symbol lookup error: /usr/bin/gdbus: undefined symbol: g_string_free_and_steal
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    Nochmal apt update und apt full-upgrade liefert eine endlose Liste mit unmet dependencies und der Empfehlung
    E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
    ausgeführt, zwischendurch kommt Fehlermeldung
    86 upgraded, 96 newly installed, 41 to remove and 330 not upgraded.
    397 not fully installed or removed.
    Need to get 0 B/116 MB of archives.
    After this operation, 180 MB of additional disk space will be used.
    Do you want to continue? [Y/n] Y
    Traceback (most recent call last):
      File "/usr/lib/python3.13/tempfile.py", line 44, in <module>
        import shutil as _shutil
    ModuleNotFoundError: No module named 'shutil'
      File "/usr/bin/apt-listchanges", line 5, in <module>
        from apt_listchanges.apt_listchanges import main
      File "/usr/lib/python3/dist-packages/apt_listchanges/apt_listchanges.py", line 33, in <module>
        import tempfile
      File "/usr/lib/python3.13/tempfile.py", line 152, in <module>
        _use_fd_functions = ({os.open, os.stat, os.unlink, os.rmdir} <=
    NameError: name 'os' is not defined. Did you mean: '_os'? Or did you forget to import 'os'?
    Extracting templates from packages: 100%
    und abschließend
    Preparing to unpack .../lxpanel_0.11.1-1_arm64.deb ...
    Unpacking lxpanel (0.11.1-1) over (0.10.1-2+rpt22) ...
    dpkg: error processing archive /var/cache/apt/archives/lxpanel_0.11.1-1_arm64.deb (--unpack):
     trying to overwrite '/usr/lib/aarch64-linux-gnu/lxpanel/plugins/batt.so', which is also in package lxplug-batt (0.23)
    Ich brauche dringend Unterstützung, bin rat- und hilflos. Wie bekomme ich meinen iob wieder an den Start?
    #234
    @Hadebe sagte:
    Das kommt davon, wenn man da einen Desktop mitschleifft...
    MACHT MAN NICHT, VERDAMMTE AXT...
    Schon 1000x gesagt...
    Wo kommst du mit dem System her?
    sudo apt update
    sagt?
    • H Offline
      Hadebe
      #235
      pi@raspi01:~ $ sudo apt update
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Get:2 http://deb.debian.org/debian-security trixie-security InRelease [43.4 kB]
      Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
      Hit:4 http://deb.debian.org/debian trixie-updates InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Fetched 43.4 kB in 0s (95.9 kB/s)
      Reading package lists... Done
      366 packages can be upgraded. Run 'apt list --upgradable' to see them.
      Kann ich Desktop noch löschen damit alles läuft - wenn das der einzige Grund ist?
      • H Hadebe
            import tempfile
        und abschließend
        #236
        @Hadebe sagte:
        lxplug-batt
        Schmeiß das raus.
        sudo apt remove lxplug-batt
        • H Offline
          Hadebe
          schrieb am zuletzt editiert von Hadebe
          #237
          pi@raspi01:~ $ sudo apt remove lxplug-batt
          You might want to run 'apt --fix-broken install' to correct these.
          The following packages have unmet dependencies:
           chromium : Depends: libatk-bridge2.0-0t64 (>= 2.5.3) but it is not going to be installed
                      Depends: libatspi2.0-0t64 (>= 2.9.90) but it is not going to be installed
                      Depends: libglib2.0-0t64 (>= 2.40.0) but it is not going to be installed
           evince : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                    Depends: libgtk-3-0t64 (>= 3.22.0) but it is not going to be installed
           galculator : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                        Depends: libgtk-3-0t64 (>= 3.3.16) but it is not going to be installed
           gcr : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           gcr4 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           geany : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                   Depends: libgtk-3-0t64 (>= 3.21.5) but it is not going to be installed
           gir1.2-glib-2.0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
           gir1.2-gtk-3.0 : Depends: libgtk-3-0t64 (>= 3.24.36-2+rpt1) but it is not going to be installed
           girepository-tools : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
           gstreamer1.0-plugins-bad : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                      Depends: libgtk-3-0t64 (>= 3.15.0) but it is not going to be installed
           gstreamer1.0-plugins-base : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
           gstreamer1.0-plugins-good : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
           gtk-nop : Depends: libgtk-3-0t64 (>= 3.24) but it is not going to be installed
           gui-pkinst : Depends: libglib2.0-0t64 (>= 2.22.0) but it is not going to be installed
           gui-updater : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
           gvfs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
           gvfs-backends : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                           Recommends: wsdd but it is not installable
           gvfs-daemons : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
           gvfs-fuse : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
           gvfs-libs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
           libadwaita-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libappstream5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libatk1.0-0t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libatkmm-1.6-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
           libavahi-glib1 : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
           libavcodec61 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
           libayatana-ido3-0.4-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                   Depends: libgtk-3-0t64 (>= 3.21.4) but it is not going to be installed
           libayatana-indicator3-7 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libbabeltrace1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
           libcairo-gobject2 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
           libcamera0.5 : Depends: libcamera-ipa (= 0.5.2+rpt20250903-1~bpo12+1) but 0.7.1+rpt20260609-1 is to be installed
           libcloudproviders0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
           libevdocument3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libevview3-3t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libfm-extra4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libfm-gtk3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libfm-modules : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                           Depends: libgtk-3-0t64 (>= 3.0.0) but it is not going to be installed
           libfm4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libgck-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libgck-2-2 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
           libgcr-4-4 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
           libgcr-base-3-1 : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
           libgcr-ui-3-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libgio-2.0-dev : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
           libgio-2.0-dev-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
           libgirepository-1.0-1 : Depends: libglib2.0-0t64 (>= 2.82.0) but it is not going to be installed
           libgirepository-2.0-0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
           libglib2.0-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
           libglibmm-2.4-1t64 : Depends: libglib2.0-0t64 (>= 2.62.0) but it is not going to be installed
           libgnome-desktop-3-20t64 : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                      Depends: libgtk-3-0t64 (>= 3.9.10) but it is not going to be installed
           libgoa-1.0-0b : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
           libgraphene-1.0-0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
           libgspell-1-3 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                           Depends: libgtk-3-0t64 (>= 3.20) but it is not going to be installed
           libgstreamer-gl1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                  Recommends: gstreamer1.0-gl but it is not going to be installed
           libgstreamer-plugins-bad1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
           libgstreamer-plugins-base1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
           libgstreamer1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
           libgtk-4-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                        Recommends: libgtk-4-bin
                        Recommends: libgtk-4-media-gstreamer
           libgtk-layer-shell0 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
                                 Depends: libgtk-3-0t64 (>= 3.24.48) but it is not going to be installed
           libgtkmm-3.0-1t64 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
                               Depends: libgtk-3-0t64 (>= 3.24.0) but it is not going to be installed
           libgtksourceview-4-0 : Depends: libglib2.0-0t64 (>= 2.48.0) but it is not going to be installed
           libgxps2t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libhandy-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                          Depends: libgtk-3-0t64 (>= 3.23.1) but it is not going to be installed
           libharfbuzz-gobject0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
           libharfbuzz0b : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
           libinput-tools : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                            Depends: libgtk-3-0t64 (>= 3.19.12) but it is not going to be installed
           libinput10 : Depends: libmtdev1t64 (>= 1.1.0) but it is not going to be installed
           libjavascriptcoregtk-4.1-0 : Depends: libglib2.0-0t64 (>= 2.66.0) but it is not going to be installed
           libkeybinder-3.0-0 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
           libmate-desktop-2-17t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libmenu-cache-bin : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
           libmousepad0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
           libmsgraph-1-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libnetplan1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
           libnm0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
           libnma0 : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
           libpango-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libpangocairo-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libpangoft2-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libpangomm-1.4-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
           libpangoxft-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libpeas-1.0-0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
           libpipewire-0.3-modules : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
           libpoppler-glib8t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libproxy1v5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libqt5ct-common1.8 : Depends: libqt5core5t64 (>= 5.9~) but it is not going to be installed
                                Depends: libqt5gui5t64 (>= 5.9~) but it is not going to be installed or
                                         libqt5gui5-gles (>= 5.9~) but it is not going to be installed
           libqt6core6t64 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
           libqt6gui6 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                        Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
                        Recommends: qt6-svg-plugins but it is not going to be installed
                        Recommends: qt6-wayland but it is not going to be installed
           libqt6network6 : Depends: libglib2.0-0t64 (>= 2.46.0) but it is not going to be installed
           libqt6opengl6 : Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
           libsane1 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
           libspa-0.2-bluetooth : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
           libudev-dev : Depends: libudev1 (= 257.13-1~deb13u1) but 252.39-1~deb12u2 is to be installed
           libvolume-key1 : Depends: libglib2.0-0t64 (>= 2.18.0) but it is not going to be installed
           libvte-2.91-0 : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
           libwacom9 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
           libwebkit2gtk-4.1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                 Depends: libgtk-3-0t64 (>= 3.23.0) but it is not going to be installed
           libwnck-3-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           libxfce4ui-2-0 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
           libxfce4util7 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                           Recommends: libxfce4util-bin but it is not going to be installed
           libxfconf-0-3 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
           libxmlb2 : Depends: libglib2.0-0t64 (>= 2.54.0) but it is not going to be installed
           lightdm-gtk-greeter : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                 Recommends: gnome-themes-extra but it is not going to be installed
           lp-connection-editor : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           lxpanel : Depends: libfm-gtk4 (>= 1.3.2-1+rpt18) but it is not installable
                     Depends: lxpanel-data (= 0.10.1-2+rpt22) but 0.11.1-1 is to be installed
                     Recommends: pavucontrol but it is not going to be installed or
                                 gnome-alsamixer but it is not installable
                     Recommends: libnotify-bin but it is not going to be installed
           lxtask : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
           lxterminal : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
           mate-polkit : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                         Depends: libgtk-3-0t64 (>= 3.16.2) but it is not going to be installed
           mousepad : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
                      Depends: libgtk-3-0t64 (>= 3.13.7) but it is not going to be installed
           netplan-generator : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
           netplan.io : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                        Recommends: python3-rich but it is not going to be installed
           network-manager : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                             Recommends: network-manager-l10n but it is not going to be installed
           notification-daemon : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           obconf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
           openssh-sftp-server : Depends: openssh-client (= 1:9.2p1-2+deb12u10)
           pango1.0-tools : Depends: libglib2.0-0t64 (>= 2.80) but it is not going to be installed
           pcmanfm : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           pi-package : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           pi-package-session : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           piclone : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
           pipanel : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
           pishutdown : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
           piwiz : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
           python3-dbus : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
           python3-gi : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
           python3-pyqt5 : Depends: libqt5printsupport5 (>= 5.15)
           qt5-gtk-platformtheme : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                   Depends: libqt5core5t64 (>= 5.15.1) but it is not going to be installed
                                   Depends: libqt5dbus5t64 (>= 5.14.1) but it is not going to be installed
                                   Depends: libqt5gui5t64 (>= 5.14.1) but it is not going to be installed or
                                            libqt5gui5-gles (>= 5.14.1) but it is not going to be installed
                                   Depends: qtbase-abi-5-15-15
           qt6-gtk-platformtheme : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
           raindrop : Depends: libglib2.0-0t64 (>= 2.40.0) but it is not going to be installed
           rasputin : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
           rc-gui : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
           rp-bookshelf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
           rp-prefapps : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
           sudopwd : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
           vlc : Depends: vlc-bin (= 1:3.0.23-0+deb13u1+rpt2) but 1:3.0.23-0+deb12u1+rpt1 is to be installed
                 Depends: vlc-plugin-qt (= 1:3.0.23-0+deb13u1+rpt2) but 1:3.0.23-0+deb12u1+rpt1 is to be installed
                 Recommends: vlc-plugin-notify (= 1:3.0.23-0+deb13u1+rpt2) but 1:3.0.23-0+deb12u1+rpt1 is to be installed
           vlc-plugin-access-extra : Depends: vlc-plugin-abi-3-0-0ft64
           vlc-plugin-base : Depends: libaribb24-0t64 (>= 1.0.3) but it is not going to be installed
                             Depends: libixml11t64 (>= 1:1.14.0) but it is not going to be installed
                             Depends: liblirc-client0t64 (>= 0.10.2) but it is not going to be installed
                             Depends: libprotobuf-lite32t64 (>= 3.21.12) but it is not going to be installed
                             Depends: libspatialaudio0t64 (>= 0.3.0+git20180730+dfsg1) but it is not going to be installed
                             Depends: libupnp17t64 (>= 1:1.14.0) but it is not going to be installed
           vlc-plugin-samba : Depends: vlc-plugin-abi-3-0-0ft64
           vlc-plugin-skins2 : Depends: vlc-plugin-qt (= 1:3.0.23-0+deb13u1+rpt2) but 1:3.0.23-0+deb12u1+rpt1 is to be installed
           vlc-plugin-video-output : Depends: vlc-plugin-abi-3-0-0ft64
           vlc-plugin-video-splitter : Depends: vlc-plugin-abi-3-0-0ft64
           vlc-plugin-visualization : Depends: vlc-plugin-abi-3-0-0ft64
           wayfire : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
           wf-panel-pi : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                         Recommends: wfplug-clock but it is not going to be installed
           wfplug-batt : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
           wfplug-bluetooth : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
           wfplug-connect : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
           wfplug-cpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
           wfplug-cputemp : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
           wfplug-ejecter : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
           wfplug-gpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
           wfplug-menu : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
           wfplug-netman : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           wfplug-power : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
           wfplug-squeek : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
           wfplug-updater : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
           wfplug-volumepulse : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
           xarchiver : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                       Recommends: 7zip but it is not going to be installed
           xdg-desktop-portal-gtk : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
           xfconf : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
           zenity : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
           zenoty : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
          E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).```
          code_text
          • H Hadebe
            code_text
            #238
            @Hadebe
            Alles GUI-Gedrisse...
            Versuch es damit:
            sudo apt purge xserver* lightdm* raspberrypi-ui-mods vlc* lxde* chromium* desktop* gnome* gstreamer* gtk* hicolor-icon-theme* lx* mesa*
            • H Offline
              Hadebe
              #239
              sieht für mich nicht besser aus
              pi@raspi01:~ $ sudo apt purge xserver* lightdm* raspberrypi-ui-mods vlc* lxde* chromium* desktop* gnome* gstreamer* gtk* hicolor-icon-theme* lx* mesa*
              Note, selecting 'xserver-xorg-video-nouveau' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-evdev' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-fbturbo-dbgsym' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-mouse' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-evtouch' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-amdgpu' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-mach64' for glob 'xserver*'
              Note, selecting 'xserver-xorg-core' for glob 'xserver*'
              Note, selecting 'xserver-xephyr-dbgsym' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-fbturbo' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-modesetting' for glob 'xserver*'
              Note, selecting 'xserver-x2gokdrive' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-all' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-intel' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-kbd' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-r128' for glob 'xserver*'
              Note, selecting 'xserver-xorg' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-joystick' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-xwiimote' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-vesa' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-elographics' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-dummy' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-aiptek' for glob 'xserver*'
              Note, selecting 'xserver-xorg-legacy' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-nvidia-any' for glob 'xserver*'
              Note, selecting 'xserver-common' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-radeon' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-synaptics' for glob 'xserver*'
              Note, selecting 'xserver-xorg-dev' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-vmware' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-neomagic' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-mtrack' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-libinput' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-siliconmotion' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-evdev-dev' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-sisusb' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-cirrus' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-wacom' for glob 'xserver*'
              Note, selecting 'xserver' for glob 'xserver*'
              Note, selecting 'xserver-xorg-core-dbgsym' for glob 'xserver*'
              Note, selecting 'xserver-xephyr' for glob 'xserver*'
              Note, selecting 'xserver-xorg-driver-all' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-joystick-dev' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-nvidia-tesla-535' for glob 'xserver*'
              Note, selecting 'xserver-xorg-legacy-dbgsym' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-libinput-dev' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-savage' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-synaptics-dev' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-all' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-ast' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-ati' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-fbdev' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-nvidia' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-nvidia-legacy-304xx' for glob 'xserver*'
              Note, selecting 'xserver-xorg-input-multitouch' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-mga' for glob 'xserver*'
              Note, selecting 'xserver-xorg-video-qxl' for glob 'xserver*'
              Package 'xserver-xorg-video-vmware' is not installed, so not removed
              Package 'xserver-xorg-video-intel' is not installed, so not removed
              Package 'xserver-xorg-driver-all' is not installed, so not removed
              Package 'xserver-xorg-input-evtouch' is not installed, so not removed
              Note, selecting 'xserver-xorg-core' instead of 'xserver-xorg-video-modesetting'
              Package 'xserver-xorg-video-nvidia-legacy-304xx' is not installed, so not removed
              Package 'xserver-xorg-video-ast' is not installed, so not removed
              Note, selecting 'lightdm-dbgsym' for glob 'lightdm*'
              Note, selecting 'lightdm-gtk-greeter-settings' for glob 'lightdm*'
              Note, selecting 'lightdm-autologin-greeter' for glob 'lightdm*'
              Note, selecting 'lightdm-gtk-greeter' for glob 'lightdm*'
              Note, selecting 'lightdm' for glob 'lightdm*'
              Note, selecting 'lightdm-remote-session-x2go' for glob 'lightdm*'
              Note, selecting 'lightdm-greeter' for glob 'lightdm*'
              Note, selecting 'lightdm-vala' for glob 'lightdm*'
              Note, selecting 'lightdm-settings' for glob 'lightdm*'
              Note, selecting 'vlc-plugin-qt' for glob 'vlc*'
              Note, selecting 'vlc-plugin-samba-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-data' for glob 'vlc*'
              Note, selecting 'vlc-plugin-abi-3-0-0ft64' for glob 'vlc*'
              Note, selecting 'vlc-bin-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-plugin-bittorrent' for glob 'vlc*'
              Note, selecting 'vlc-plugin-jack-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc' for glob 'vlc*'
              Note, selecting 'vlc-bin' for glob 'vlc*'
              Note, selecting 'vlc-l10n' for glob 'vlc*'
              Note, selecting 'vlc-plugin-bittorent' for glob 'vlc*'
              Note, selecting 'vlc-plugin-pipewire' for glob 'vlc*'
              Note, selecting 'vlc-plugin-video-output-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-plugin-jack' for glob 'vlc*'
              Note, selecting 'vlc-plugin-samba' for glob 'vlc*'
              Note, selecting 'vlc-plugin-qt-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-plugin-access-extra-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-plugin-notify' for glob 'vlc*'
              Note, selecting 'vlc-plugin-fluidsynth' for glob 'vlc*'
              Note, selecting 'vlc-plugin-visualization-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-plugin-abi-3-0-0f' for glob 'vlc*'
              Note, selecting 'vlc-plugin-fluidsynth-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-plugin-access-extra' for glob 'vlc*'
              Note, selecting 'vlc-plugin-notify-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-plugin-skins2' for glob 'vlc*'
              Note, selecting 'vlc-plugin-svg' for glob 'vlc*'
              Note, selecting 'vlc-plugin-video-splitter' for glob 'vlc*'
              Note, selecting 'vlc-plugin-video-output' for glob 'vlc*'
              Note, selecting 'vlc-plugin-svg-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-plugin-base-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-plugin-skins2-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-plugin-video-splitter-dbgsym' for glob 'vlc*'
              Note, selecting 'vlc-plugin-base' for glob 'vlc*'
              Note, selecting 'vlc-plugin-visualization' for glob 'vlc*'
              Package 'vlc-plugin-bittorent' is not installed, so not removed
              Note, selecting 'libvlccore9' instead of 'vlc-plugin-abi-3-0-0ft64'
              Note, selecting 'lxde-settings-daemon-dbgsym' for glob 'lxde*'
              Note, selecting 'lxde-common' for glob 'lxde*'
              Note, selecting 'lxde-core' for glob 'lxde*'
              Note, selecting 'lxde' for glob 'lxde*'
              Note, selecting 'lxde-icon-theme' for glob 'lxde*'
              Note, selecting 'lxde-settings-daemon' for glob 'lxde*'
              Note, selecting 'lxde-session' for glob 'lxde*'
              Note, selecting 'openbox-lxde-session' instead of 'lxde-session'
              Note, selecting 'chromium-bsu' for glob 'chromium*'
              Note, selecting 'chromium-sandbox' for glob 'chromium*'
              Note, selecting 'chromium-codecs-ffmpeg-extra:armhf' for glob 'chromium*'
              Note, selecting 'chromium-shell-dbgsym' for glob 'chromium*'
              Note, selecting 'chromium-driver' for glob 'chromium*'
              Note, selecting 'chromium-shell' for glob 'chromium*'
              Note, selecting 'chromium-dbgsym' for glob 'chromium*'
              Note, selecting 'chromium-sandbox-dbgsym' for glob 'chromium*'
              Note, selecting 'chromium' for glob 'chromium*'
              Note, selecting 'chromium-headless-shell' for glob 'chromium*'
              Note, selecting 'chromium-data' for glob 'chromium*'
              Note, selecting 'chromium-browser' for glob 'chromium*'
              Note, selecting 'chromium-chromedriver' for glob 'chromium*'
              Note, selecting 'chromium-lwn4chrome' for glob 'chromium*'
              Note, selecting 'chromium-l10n' for glob 'chromium*'
              Note, selecting 'chromium-common' for glob 'chromium*'
              Note, selecting 'chromium-headless-shell-dbgsym' for glob 'chromium*'
              Note, selecting 'chromium-common-dbgsym' for glob 'chromium*'
              Note, selecting 'chromium-tt-rss-notifier' for glob 'chromium*'
              Note, selecting 'chromium-bsu-data' for glob 'chromium*'
              Note, selecting 'chromium-browser-l10n' for glob 'chromium*'
              Package 'chromium-tt-rss-notifier' is not installed, so not removed
              Package 'chromium-data' is not installed, so not removed
              Package 'chromium-codecs-ffmpeg-extra:armhf' is not installed, so not removed
              Note, selecting 'desktop-base' for glob 'desktop*'
              Note, selecting 'desktop-autoloader' for glob 'desktop*'
              Note, selecting 'desktop-file-utils' for glob 'desktop*'
              Note, selecting 'desktopfolder' for glob 'desktop*'
              Note, selecting 'gnome-shell-extension-dashtodock' for glob 'gnome*'
              Note, selecting 'gnome-text-editor' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-dash-to-dock' for glob 'gnome*'
              Note, selecting 'gnomekiss' for glob 'gnome*'
              Note, selecting 'gnome-kiosk-script-session' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-light-style' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-launch-new-instance' for glob 'gnome*'
              Note, selecting 'gnome-shell-pomodoro-data' for glob 'gnome*'
              Note, selecting 'gnome-user-docs' for glob 'gnome*'
              Note, selecting 'gnome-wine-icon-theme' for glob 'gnome*'
              Note, selecting 'gnome-power-manager' for glob 'gnome*'
              Note, selecting 'gnome-panel' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-hard-disk-led' for glob 'gnome*'
              Note, selecting 'gnome-video-effects-frei0r' for glob 'gnome*'
              Note, selecting 'gnome-breakout' for glob 'gnome*'
              Note, selecting 'gnome-sound-recorder' for glob 'gnome*'
              Note, selecting 'gnome-sudoku' for glob 'gnome*'
              Note, selecting 'gnome-themes-standard-data' for glob 'gnome*'
              Note, selecting 'gnome-software-plugin' for glob 'gnome*'
              Note, selecting 'gnome-font-viewer' for glob 'gnome*'
              Note, selecting 'gnome-online-accounts-gtk' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-workspace-indicator' for glob 'gnome*'
              Note, selecting 'gnome-human-icon-theme' for glob 'gnome*'
              Note, selecting 'gnome-software' for glob 'gnome*'
              Note, selecting 'gnome-alsamixer' for glob 'gnome*'
              Note, selecting 'gnome-software-plugin-fwupd' for glob 'gnome*'
              Note, selecting 'gnome-initial-setup' for glob 'gnome*'
              Note, selecting 'gnome-user-share' for glob 'gnome*'
              Note, selecting 'gnome-weather' for glob 'gnome*'
              Note, selecting 'gnome-session-flashback' for glob 'gnome*'
              Note, selecting 'gnome-klotski' for glob 'gnome*'
              Note, selecting 'gnome-software-common' for glob 'gnome*'
              Note, selecting 'gnome-commander' for glob 'gnome*'
              Note, selecting 'gnome-mplayer' for glob 'gnome*'
              Note, selecting 'gnome-video-arcade' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-taskbar' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-runcat' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-tiling-assistant' for glob 'gnome*'
              Note, selecting 'gnome-ponytail-daemon' for glob 'gnome*'
              Note, selecting 'gnome-themes-extras' for glob 'gnome*'
              Note, selecting 'gnome-bluetooth-3-common' for glob 'gnome*'
              Note, selecting 'gnome-applets-data' for glob 'gnome*'
              Note, selecting 'gnome-nibbles' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-gpaste' for glob 'gnome*'
              Note, selecting 'gnome-audio' for glob 'gnome*'
              Note, selecting 'gnome-network-displays' for glob 'gnome*'
              Note, selecting 'gnome-color-manager' for glob 'gnome*'
              Note, selecting 'gnome-connections' for glob 'gnome*'
              Note, selecting 'gnome-games-app' for glob 'gnome*'
              Note, selecting 'gnome-desktop-3-tests' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-native-window-placement' for glob 'gnome*'
              Note, selecting 'gnome-icon-theme-yasis' for glob 'gnome*'
              Note, selecting 'gnome-shell-extensions-extra' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-gsconnect-browsers' for glob 'gnome*'
              Note, selecting 'gnome-dictionary' for glob 'gnome*'
              Note, selecting 'gnome-boxes' for glob 'gnome*'
              Note, selecting 'gnome-software-plugin-deb' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-vertical-workspaces' for glob 'gnome*'
              Note, selecting 'gnome-control-center-signon' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-kimpanel' for glob 'gnome*'
              Note, selecting 'gnome-session-bin' for glob 'gnome*'
              Note, selecting 'gnome-flashback-common' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-middleclickclose' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-auto-move-windows' for glob 'gnome*'
              Note, selecting 'gnome-shell-pomodoro' for glob 'gnome*'
              Note, selecting 'gnome-tweaks' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-window-list' for glob 'gnome*'
              Note, selecting 'gnome-system-monitor' for glob 'gnome*'
              Note, selecting 'gnome-panel-data' for glob 'gnome*'
              Note, selecting 'gnome-noble-icon-theme' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-apps-menu' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-disable-workspace-switcher' for glob 'gnome*'
              Note, selecting 'gnome' for glob 'gnome*'
              Note, selecting 'gnome-cards-data' for glob 'gnome*'
              Note, selecting 'gnome-remote-desktop' for glob 'gnome*'
              Note, selecting 'gnome-tweak-tool' for glob 'gnome*'
              Note, selecting 'gnome-applets' for glob 'gnome*'
              Note, selecting 'gnome-icon-theme' for glob 'gnome*'
              Note, selecting 'gnome-colors-common' for glob 'gnome*'
              Note, selecting 'gnome-icon-theme-full' for glob 'gnome*'
              Note, selecting 'gnome-power-statistics' for glob 'gnome*'
              Note, selecting 'gnome-pass-search-provider' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-easyscreencast' for glob 'gnome*'
              Note, selecting 'gnome-kiosk' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-flypie' for glob 'gnome*'
              Note, selecting 'gnome-calendar' for glob 'gnome*'
              Note, selecting 'gnome-screensaver' for glob 'gnome*'
              Note, selecting 'gnome-shell-extensions' for glob 'gnome*'
              Note, selecting 'gnome-panel-control-dbgsym' for glob 'gnome*'
              Note, selecting 'gnome-shell' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-status-icons' for glob 'gnome*'
              Note, selecting 'gnome-mime-data' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-weather' for glob 'gnome*'
              Note, selecting 'gnome-classic' for glob 'gnome*'
              Note, selecting 'gnome-settings-daemon-common' for glob 'gnome*'
              Note, selecting 'gnome-software-dev' for glob 'gnome*'
              Note, selecting 'gnome-software-doc' for glob 'gnome*'
              Note, selecting 'gnome-feeds' for glob 'gnome*'
              Note, selecting 'gnome-session-xsession' for glob 'gnome*'
              Note, selecting 'gnome-mines' for glob 'gnome*'
              Note, selecting 'gnome-icon-theme-gartoon' for glob 'gnome*'
              Note, selecting 'gnome-usage' for glob 'gnome*'
              Note, selecting 'gnome-software-plugin-snap' for glob 'gnome*'
              Note, selecting 'gnome-logs' for glob 'gnome*'
              Note, selecting 'gnome-core-devel' for glob 'gnome*'
              Note, selecting 'gnome-themes-standard' for glob 'gnome*'
              Note, selecting 'gnome-extra-icons' for glob 'gnome*'
              Note, selecting 'gnome-snapshot' for glob 'gnome*'
              Note, selecting 'gnome-devel' for glob 'gnome*'
              Note, selecting 'gnome-metronome' for glob 'gnome*'
              Note, selecting 'gnome-robots' for glob 'gnome*'
              Note, selecting 'gnome-packagekit' for glob 'gnome*'
              Note, selecting 'gnome-mastermind' for glob 'gnome*'
              Note, selecting 'gnome-calculator' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-desktop-icons-ng' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-just-perfection' for glob 'gnome*'
              Note, selecting 'gnome-2048' for glob 'gnome*'
              Note, selecting 'gnome-themes-extra-data' for glob 'gnome*'
              Note, selecting 'gnome-video-trimmer' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-top-icons-plus' for glob 'gnome*'
              Note, selecting 'gnome-icon-theme-nuovo' for glob 'gnome*'
              Note, selecting 'gnome-extensions-app' for glob 'gnome*'
              Note, selecting 'gnome-settings-daemon' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-appindicator' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-desktop-icons' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-autohidetopbar' for glob 'gnome*'
              Note, selecting 'gnome-illustrious-icon-theme' for glob 'gnome*'
              Note, selecting 'gnome-epub-thumbnailer' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-places-menu' for glob 'gnome*'
              Note, selecting 'gnome-photos' for glob 'gnome*'
              Note, selecting 'gnome-maps' for glob 'gnome*'
              Note, selecting 'gnome-multi-writer' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-freon' for glob 'gnome*'
              Note, selecting 'gnome-package-updater' for glob 'gnome*'
              Note, selecting 'gnome-contacts' for glob 'gnome*'
              Note, selecting 'gnome-mahjongg' for glob 'gnome*'
              Note, selecting 'gnome-commander-data' for glob 'gnome*'
              Note, selecting 'gnome-packagekit-data' for glob 'gnome*'
              Note, selecting 'gnome-desktop3-data' for glob 'gnome*'
              Note, selecting 'gnome-podcasts' for glob 'gnome*'
              Note, selecting 'gnome-colors' for glob 'gnome*'
              Note, selecting 'gnome-disk-utility' for glob 'gnome*'
              Note, selecting 'gnome-firmware' for glob 'gnome*'
              Note, selecting 'gnome-notes' for glob 'gnome*'
              Note, selecting 'gnome-classic-xsession' for glob 'gnome*'
              Note, selecting 'gnome-desktop-testing' for glob 'gnome*'
              Note, selecting 'gnome-icon-theme-suede' for glob 'gnome*'
              Note, selecting 'gnome-online-accounts' for glob 'gnome*'
              Note, selecting 'gnome-backgrounds' for glob 'gnome*'
              Note, selecting 'gnome-system-tools' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-no-annoyance' for glob 'gnome*'
              Note, selecting 'gnome-settings-daemon-dev' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-screenshot-window-sizer' for glob 'gnome*'
              Note, selecting 'gnome-screensaver-flags' for glob 'gnome*'
              Note, selecting 'gnome-bluetooth-sendto' for glob 'gnome*'
              Note, selecting 'gnome-screenshot' for glob 'gnome*'
              Note, selecting 'gnome-calls' for glob 'gnome*'
              Note, selecting 'gnome-shell-common' for glob 'gnome*'
              Note, selecting 'gnome-media' for glob 'gnome*'
              Note, selecting 'gnome-control-center-data' for glob 'gnome*'
              Note, selecting 'gnome-music' for glob 'gnome*'
              Note, selecting 'gnome-tetravex' for glob 'gnome*'
              Note, selecting 'gnome-platform-devel' for glob 'gnome*'
              Note, selecting 'gnome-theme-gilouche' for glob 'gnome*'
              Note, selecting 'gnome-keyring' for glob 'gnome*'
              Note, selecting 'gnome-icon-theme-symbolic' for glob 'gnome*'
              Note, selecting 'gnome-hwp-support' for glob 'gnome*'
              Note, selecting 'gnome-authenticator' for glob 'gnome*'
              Note, selecting 'gnome-mpv' for glob 'gnome*'
              Note, selecting 'gnome-pkg-tools' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-manager' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-workspaces-to-dock' for glob 'gnome*'
              Note, selecting 'gnome-menus' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-arc-menu' for glob 'gnome*'
              Note, selecting 'gnome-wise-icon-theme' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-hibernate-status' for glob 'gnome*'
              Note, selecting 'gnome-panel-control' for glob 'gnome*'
              Note, selecting 'gnome-pie' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-windows-navigator' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-shortcuts' for glob 'gnome*'
              Note, selecting 'gnome-brave-icon-theme' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-dash-to-panel' for glob 'gnome*'
              Note, selecting 'gnome-video-effects' for glob 'gnome*'
              Note, selecting 'gnome-session' for glob 'gnome*'
              Note, selecting 'gnome-common' for glob 'gnome*'
              Note, selecting 'gnome-dust-icon-theme' for glob 'gnome*'
              Note, selecting 'gnome-control-center' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-gamemode' for glob 'gnome*'
              Note, selecting 'gnome-terminal-data' for glob 'gnome*'
              Note, selecting 'gnome-settings-daemon-schemas' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-drive-menu' for glob 'gnome*'
              Note, selecting 'gnome-www-browser' for glob 'gnome*'
              Note, selecting 'gnome-games' for glob 'gnome*'
              Note, selecting 'gnome-flashback' for glob 'gnome*'
              Note, selecting 'gnome-session-canberra' for glob 'gnome*'
              Note, selecting 'gnome-genius' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-blur-my-shell' for glob 'gnome*'
              Note, selecting 'gnome-browser-connector' for glob 'gnome*'
              Note, selecting 'gnome-video-effects-dev' for glob 'gnome*'
              Note, selecting 'gnome-core' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-system-monitor' for glob 'gnome*'
              Note, selecting 'gnome-terminal' for glob 'gnome*'
              Note, selecting 'gnome-software-plugin-flatpak' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-impatience' for glob 'gnome*'
              Note, selecting 'gnome-characters' for glob 'gnome*'
              Note, selecting 'gnome-bluetooth' for glob 'gnome*'
              Note, selecting 'gnome-packagekit-common' for glob 'gnome*'
              Note, selecting 'gnome-sushi' for glob 'gnome*'
              Note, selecting 'gnome-activity-journal' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-onboard' for glob 'gnome*'
              Note, selecting 'gnome-api-docs' for glob 'gnome*'
              Note, selecting 'gnome-accessibility-themes' for glob 'gnome*'
              Note, selecting 'gnome-keysign' for glob 'gnome*'
              Note, selecting 'gnome-model-thumbnailer' for glob 'gnome*'
              Note, selecting 'gnome-themes-extra' for glob 'gnome*'
              Note, selecting 'gnome-shell-extensions-common' for glob 'gnome*'
              Note, selecting 'gnome-mousetrap' for glob 'gnome*'
              Note, selecting 'gnome-recipes' for glob 'gnome*'
              Note, selecting 'gnome-nettool' for glob 'gnome*'
              Note, selecting 'gnome-keyring-pkcs11' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-prefs' for glob 'gnome*'
              Note, selecting 'gnome-chess' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-no-overview' for glob 'gnome*'
              Note, selecting 'gnome-taquin' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-user-theme' for glob 'gnome*'
              Note, selecting 'gnome-decoder' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-caffeine' for glob 'gnome*'
              Note, selecting 'gnome-video-effects-extra' for glob 'gnome*'
              Note, selecting 'gnome-todo' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-hamster' for glob 'gnome*'
              Note, selecting 'gnome-tour' for glob 'gnome*'
              Note, selecting 'gnome-shell-extensions-gpaste' for glob 'gnome*'
              Note, selecting 'gnome-builder' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-hide-activities' for glob 'gnome*'
              Note, selecting 'gnome-shell-extension-gsconnect' for glob 'gnome*'
              Note, selecting 'gnome-console' for glob 'gnome*'
              Note, selecting 'gnome-nds-thumbnailer' for glob 'gnome*'
              Note, selecting 'gnome-recipes-data' for glob 'gnome*'
              Note, selecting 'gnome-photos-tests' for glob 'gnome*'
              Note, selecting 'gnome-calls-doc' for glob 'gnome*'
              Note, selecting 'gnome-control-center-dev' for glob 'gnome*'
              Note, selecting 'gnome-clocks' for glob 'gnome*'
              Note, selecting 'gnome-session-common' for glob 'gnome*'
              Note, selecting 'gnome-latex' for glob 'gnome*'
              Note, selecting 'gnome-codec-install' for glob 'gnome*'
              Note, selecting 'gnome-kiosk-search-appliance' for glob 'gnome*'
              Package 'gnome-themes-standard-data' is not installed, so not removed
              Note, selecting 'adwaita-icon-theme' instead of 'gnome-icon-theme-symbolic'
              Package 'gnome-bluetooth' is not installed, so not removed
              Package 'gnome-power-statistics' is not installed, so not removed
              Package 'gnome-control-center-signon' is not installed, so not removed
              Note, selecting 'bijiben' instead of 'gnome-notes'
              Package 'gnome-mpv' is not installed, so not removed
              Package 'gnome-mime-data' is not installed, so not removed
              Package 'gnome-video-arcade' is not installed, so not removed
              Package 'gnome-dictionary' is not installed, so not removed
              Package 'gnome-mplayer' is not installed, so not removed
              Note, selecting 'endeavour' instead of 'gnome-todo'
              Note, selecting 'enter-tex' instead of 'gnome-latex'
              Package 'gnome-packagekit-data' is not installed, so not removed
              Note, selecting 'gnome-settings-daemon-common' instead of 'gnome-settings-daemon-schemas'
              Package 'gnome-shell-extension-desktop-icons' is not installed, so not removed
              Package 'gnome-shell-extension-taskbar' is not installed, so not removed
              Package 'gnome-shell-extension-top-icons-plus' is not installed, so not removed
              Package 'gnome-shell-extension-workspaces-to-dock' is not installed, so not removed
              Note, selecting 'gnome-shell-extension-prefs' instead of 'gnome-extensions-app'
              Note, selecting 'gnome-shell-extension-dashtodock' instead of 'gnome-shell-extension-dash-to-dock'
              Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-disable-workspace-switcher'
              Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-hibernate-status'
              Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-just-perfection'
              Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-middleclickclose'
              Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-no-overview'
              Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-vertical-workspaces'
              Package 'gnome-media' is not installed, so not removed
              Note, selecting 'gnome-tweaks' instead of 'gnome-tweak-tool'
              Package 'gnome-video-effects-extra' is not installed, so not removed
              Package 'gnome-shell-extensions-gpaste' is not installed, so not removed
              Package 'gnome-games-app' is not installed, so not removed
              Package 'gnome-core-devel' is not installed, so not removed
              Package 'gnome-shell-extension-onboard' is not installed, so not removed
              Package 'gnome-codec-install' is not installed, so not removed
              Package 'gnome-icon-theme-full' is not installed, so not removed
              Package 'gnome-alsamixer' is not installed, so not removed
              Package 'gnome-themes-extras' is not installed, so not removed
              Package 'gnome-themes-standard' is not installed, so not removed
              Note, selecting 'gstreamer1.0-qt5' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-qt6' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-wpe' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-ugly' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-packagekit' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-bad-apps-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-gl' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-base-apps-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-fluendo-mp3' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-clutter-3.0' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-autogain-pulseeffects' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-python-dbg-plugin-loader' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-base-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-bad-videoparsers' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-pispconvert' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-adapter-pulseeffects' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-videosource' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-tools' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-espeak' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-really-bad' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-lame' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-base-apps' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-alsa' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-pipewire-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-audiosource' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-gl-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-audiosink' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-visualization' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-x' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-gtk3' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-gtk4' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-pocketsphinx' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-rtsp' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-libcamera' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-good' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-bad-faad' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-base' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-crystalhd' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-pipewire' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-python3-plugin-loader' for glob 'gstreamer*'
              Note, selecting 'gstreamer0.10-packagekit' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-bad-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-vaapi-doc' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-videosink' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-base-doc' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-x-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-opencv-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-convolver-pulseeffects' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-pispconvert-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-python3-dbg-plugin-loader' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-bad-apps' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-opencv' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-vaapi' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-nice' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-libcamera-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-crystalizer-pulseeffects' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-bad' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-pulseaudio' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-python-plugin-loader' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-libav' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-alsa-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-plugins-rtp' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-doc' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-fdkaac' for glob 'gstreamer*'
              Note, selecting 'gstreamer1.0-wpe-dbgsym' for glob 'gstreamer*'
              Note, selecting 'gstreamer-sharp-1.0' for glob 'gstreamer*'
              Package 'gstreamer1.0-doc' is not installed, so not removed
              Package 'gstreamer1.0-plugins-base-doc' is not installed, so not removed
              Package 'gstreamer-sharp-1.0' is not installed, so not removed
              Package 'gstreamer1.0-crystalhd' is not installed, so not removed
              Note, selecting 'gstreamer1.0-plugins-bad' instead of 'gstreamer1.0-plugins-bad-faad'
              Note, selecting 'gstreamer1.0-plugins-bad' instead of 'gstreamer1.0-plugins-bad-videoparsers'
              Package 'gstreamer1.0-python-dbg-plugin-loader' is not installed, so not removed
              Package 'gstreamer1.0-python-plugin-loader' is not installed, so not removed
              Package 'gstreamer1.0-python3-dbg-plugin-loader' is not installed, so not removed
              Package 'gstreamer1.0-vaapi-doc' is not installed, so not removed
              Package 'gstreamer1.0-fluendo-mp3' is not installed, so not removed
              Package 'gstreamer0.10-packagekit' is not installed, so not removed
              Package 'gstreamer1.0-lame' is not installed, so not removed
              Package 'gstreamer1.0-plugins-really-bad' is not installed, so not removed
              Note, selecting 'gtk-3-examples-dbgsym' for glob 'gtk*'
              Note, selecting 'gtkmorph-example' for glob 'gtk*'
              Note, selecting 'gtk2-engines-clearlookspix-dbgsym' for glob 'gtk*'
              Note, selecting 'gtk-layer-shell-doc' for glob 'gtk*'
              Note, selecting 'gtk2-engines-qtcurve' for glob 'gtk*'
              Note, selecting 'gtkhash' for glob 'gtk*'
              Note, selecting 'gtk2-engines-clearlookspix' for glob 'gtk*'
              Note, selecting 'gtk4-layer-shell-examples' for glob 'gtk*'
              Note, selecting 'gtk3-binver-3.0.0' for glob 'gtk*'
              Note, selecting 'gtkatlantic' for glob 'gtk*'
              Note, selecting 'gtk-im-libthai' for glob 'gtk*'
              Note, selecting 'gtklock-userinfo-module' for glob 'gtk*'
              Note, selecting 'gtkterm' for glob 'gtk*'
              Note, selecting 'gtk2-engines-pixbuf-dbgsym' for glob 'gtk*'
              Note, selecting 'gtk2hs-buildtools' for glob 'gtk*'
              Note, selecting 'gtklock-playerctl-module' for glob 'gtk*'
              Note, selecting 'gtk-nop' for glob 'gtk*'
              Note, selecting 'gtkballs' for glob 'gtk*'
              Note, selecting 'gtk2-engines-aurora' for glob 'gtk*'
              Note, selecting 'gtkam' for glob 'gtk*'
              Note, selecting 'gtk-redshift' for glob 'gtk*'
              Note, selecting 'gtklp' for glob 'gtk*'
              Note, selecting 'gtk-meshtastic-client' for glob 'gtk*'
              Note, selecting 'gtk4-binver-4.0.0' for glob 'gtk*'
              Note, selecting 'gtkguitune' for glob 'gtk*'
              Note, selecting 'gtk2-engines-murrine' for glob 'gtk*'
              Note, selecting 'gtk4-layer-shell-doc' for glob 'gtk*'
              Note, selecting 'gtk3-nocsd' for glob 'gtk*'
              Note, selecting 'gtk-4-examples' for glob 'gtk*'
              Note, selecting 'gtkgreet' for glob 'gtk*'
              Note, selecting 'gtk-nop-dbgsym' for glob 'gtk*'
              Note, selecting 'gtkpool' for glob 'gtk*'
              Note, selecting 'gtk-session-lock-examples' for glob 'gtk*'
              Note, selecting 'gtk2-engines' for glob 'gtk*'
              Note, selecting 'gtk2-engines-sugar' for glob 'gtk*'
              Note, selecting 'gtkman' for glob 'gtk*'
              Note, selecting 'gtk-layer-shell-examples' for glob 'gtk*'
              Note, selecting 'gtkpod' for glob 'gtk*'
              Note, selecting 'gtkcrypto' for glob 'gtk*'
              Note, selecting 'gtk-theme-switch' for glob 'gtk*'
              Note, selecting 'gtkmm-documentation' for glob 'gtk*'
              Note, selecting 'gtk2-engines-pixbuf' for glob 'gtk*'
              Note, selecting 'gtk-3-examples' for glob 'gtk*'
              Note, selecting 'gtk-chtheme' for glob 'gtk*'
              Note, selecting 'gtk-update-icon-cache' for glob 'gtk*'
              Note, selecting 'gtk-doc-tools' for glob 'gtk*'
              Note, selecting 'gtkwave' for glob 'gtk*'
              Note, selecting 'gtk2-engines-pixflat' for glob 'gtk*'
              Note, selecting 'gtklick' for glob 'gtk*'
              Note, selecting 'gtkboard' for glob 'gtk*'
              Note, selecting 'gtklock' for glob 'gtk*'
              Note, selecting 'gtk3-im-libthai' for glob 'gtk*'
              Note, selecting 'gtk2-engines-pixflat-dbgsym' for glob 'gtk*'
              Note, selecting 'gtk-4-tests' for glob 'gtk*'
              Note, selecting 'gtk-recordmydesktop' for glob 'gtk*'
              Note, selecting 'gtk2.0-binver-2.10.0' for glob 'gtk*'
              Note, selecting 'gtk2-engines-gartoon' for glob 'gtk*'
              Package 'gtkboard' is not installed, so not removed
              Package 'gtkpool' is not installed, so not removed
              Package 'gtkguitune' is not installed, so not removed
              Package 'gtklick' is not installed, so not removed
              Note, selecting 'gnome-icon-theme-gartoon' instead of 'gtk2-engines-gartoon'
              Package 'gtkpod' is not installed, so not removed
              Note, selecting 'libgtk-4-1' instead of 'gtk4-binver-4.0.0'
              Package 'gtk-recordmydesktop' is not installed, so not removed
              Package 'gtk-redshift' is not installed, so not removed
              Package 'gtk2-engines-sugar' is not installed, so not removed
              Note, selecting 'hicolor-icon-theme' for glob 'hicolor-icon-theme*'
              Note, selecting 'lxplug-ejecter' for glob 'lx*'
              Note, selecting 'lxpanel-pi-dbgsym' for glob 'lx*'
              Note, selecting 'lxd-tools' for glob 'lx*'
              Note, selecting 'lxqt-powermanagement-l10n' for glob 'lx*'
              Note, selecting 'lxpanel-pi' for glob 'lx*'
              Note, selecting 'lxplug-volumepulse' for glob 'lx*'
              Note, selecting 'lximage-qt-l10n' for glob 'lx*'
              Note, selecting 'lxpanel-dev' for glob 'lx*'
              Note, selecting 'lxqt-panel' for glob 'lx*'
              Note, selecting 'lxlauncher' for glob 'lx*'
              Note, selecting 'lxpanel-data' for glob 'lx*'
              Note, selecting 'lxqt-theme-debian' for glob 'lx*'
              Note, selecting 'lxqt-archiver' for glob 'lx*'
              Note, selecting 'lxterminal' for glob 'lx*'
              Note, selecting 'lxqt-system-theme' for glob 'lx*'
              Note, selecting 'lxc' for glob 'lx*'
              Note, selecting 'lxd' for glob 'lx*'
              Note, selecting 'lxqt-admin' for glob 'lx*'
              Note, selecting 'lxi-tools' for glob 'lx*'
              Note, selecting 'lxqt-openssh-askpass-l10n' for glob 'lx*'
              Note, selecting 'lxpolkit' for glob 'lx*'
              Note, selecting 'lxqt-powermanagement' for glob 'lx*'
              Note, selecting 'lxsession' for glob 'lx*'
              Note, selecting 'lxsession-data' for glob 'lx*'
              Note, selecting 'lxde-settings-daemon-dbgsym' for glob 'lx*'
              Note, selecting 'lxde-common' for glob 'lx*'
              Note, selecting 'lxlock' for glob 'lx*'
              Note, selecting 'lxqt-sudo-l10n' for glob 'lx*'
              Note, selecting 'lxcfs' for glob 'lx*'
              Note, selecting 'lxctl' for glob 'lx*'
              Note, selecting 'lxqt-openssh-askpass' for glob 'lx*'
              Note, selecting 'lxmenu-data' for glob 'lx*'
              Note, selecting 'lxd-client' for glob 'lx*'
              Note, selecting 'lxqt-qtplugin' for glob 'lx*'
              Note, selecting 'lxde-core' for glob 'lx*'
              Note, selecting 'lxqt-qtplugin6' for glob 'lx*'
              Note, selecting 'lxplug-updater' for glob 'lx*'
              Note, selecting 'lxplug-cpu' for glob 'lx*'
              Note, selecting 'lxqt-runner-l10n' for glob 'lx*'
              Note, selecting 'lxd-migrate' for glob 'lx*'
              Note, selecting 'lxpanel' for glob 'lx*'
              Note, selecting 'lxqt-sudo' for glob 'lx*'
              Note, selecting 'lxc-dev' for glob 'lx*'
              Note, selecting 'lxqt-admin-l10n' for glob 'lx*'
              Note, selecting 'lxsession-edit' for glob 'lx*'
              Note, selecting 'lxqt-policykit-l10n' for glob 'lx*'
              Note, selecting 'lxrandr' for glob 'lx*'
              Note, selecting 'lxqt-core' for glob 'lx*'
              Note, selecting 'lxqt-archiver-l10n' for glob 'lx*'
              Note, selecting 'lxqt-theme' for glob 'lx*'
              Note, selecting 'lxplug-bluetooth' for glob 'lx*'
              Note, selecting 'lxplug-cputemp' for glob 'lx*'
              Note, selecting 'lxqt-globalkeys-l10n' for glob 'lx*'
              Note, selecting 'lxappearance-obconf' for glob 'lx*'
              Note, selecting 'lxqt-branding-debian' for glob 'lx*'
              Note, selecting 'lxde' for glob 'lx*'
              Note, selecting 'lxdm' for glob 'lx*'
              Note, selecting 'lxqt' for glob 'lx*'
              Note, selecting 'lxplug-magnifier' for glob 'lx*'
              Note, selecting 'lxinput' for glob 'lx*'
              Note, selecting 'lxshortcut' for glob 'lx*'
              Note, selecting 'lxpolkit-dbgsym' for glob 'lx*'
              Note, selecting 'lxqt-branding' for glob 'lx*'
              Note, selecting 'lxqt-qt5plugin' for glob 'lx*'
              Note, selecting 'lxtask' for glob 'lx*'
              Note, selecting 'lxqt-policykit' for glob 'lx*'
              Note, selecting 'lxplug-netman' for glob 'lx*'
              Note, selecting 'lxsession-logout' for glob 'lx*'
              Note, selecting 'lxplug-batt' for glob 'lx*'
              Note, selecting 'lxqt-panel-l10n' for glob 'lx*'
              Note, selecting 'lxpanel-pi-dev-dbgsym' for glob 'lx*'
              Note, selecting 'lx-gdb' for glob 'lx*'
              Note, selecting 'lxc-tests' for glob 'lx*'
              Note, selecting 'lxplug-menu' for glob 'lx*'
              Note, selecting 'lxhotkey-core' for glob 'lx*'
              Note, selecting 'lxqt-common' for glob 'lx*'
              Note, selecting 'lxsession-default-apps' for glob 'lx*'
              Note, selecting 'lxsession-edit-dbgsym' for glob 'lx*'
              Note, selecting 'lxqt-about' for glob 'lx*'
              Note, selecting 'lxde-icon-theme' for glob 'lx*'
              Note, selecting 'lxc-templates' for glob 'lx*'
              Note, selecting 'lxhotkey-data' for glob 'lx*'
              Note, selecting 'lxqt-session-l10n' for glob 'lx*'
              Note, selecting 'lximage-qt' for glob 'lx*'
              Note, selecting 'lxhotkey-dev' for glob 'lx*'
              Note, selecting 'lxqt-runner' for glob 'lx*'
              Note, selecting 'lxqt-build-tools-qt5' for glob 'lx*'
              Note, selecting 'lxhotkey-gtk' for glob 'lx*'
              Note, selecting 'lxhotkey-gui' for glob 'lx*'
              Note, selecting 'lxqt-menu-data' for glob 'lx*'
              Note, selecting 'lxplug-ptbatt' for glob 'lx*'
              Note, selecting 'lxsession-dbgsym' for glob 'lx*'
              Note, selecting 'lxqt-themes' for glob 'lx*'
              Note, selecting 'lxhotkey-plugin-openbox' for glob 'lx*'
              Note, selecting 'lxqt-build-tools' for glob 'lx*'
              Note, selecting 'lxqt-config' for glob 'lx*'
              Note, selecting 'lxpanel-pi-dev' for glob 'lx*'
              Note, selecting 'lxtask-dbgsym' for glob 'lx*'
              Note, selecting 'lxqt-about-l10n' for glob 'lx*'
              Note, selecting 'lxqt-session' for glob 'lx*'
              Note, selecting 'lxde-settings-daemon' for glob 'lx*'
              Note, selecting 'lxqt-config-l10n' for glob 'lx*'
              Note, selecting 'lxd-agent' for glob 'lx*'
              Note, selecting 'lxqt-globalkeys' for glob 'lx*'
              Note, selecting 'lxmusic' for glob 'lx*'
              Note, selecting 'lxde-session' for glob 'lx*'
              Note, selecting 'lxsession-logout-dbgsym' for glob 'lx*'
              Note, selecting 'lxqt-notificationd' for glob 'lx*'
              Note, selecting 'lxsession-default-apps-dbgsym' for glob 'lx*'
              Note, selecting 'lxappearance' for glob 'lx*'
              Note, selecting 'lxterminal-dbgsym' for glob 'lx*'
              Note, selecting 'lxqt-notificationd-l10n' for glob 'lx*'
              Note, selecting 'libfm-tools' instead of 'lxshortcut'
              Note, selecting 'lxhotkey-gtk' instead of 'lxhotkey-gui'
              Note, selecting 'lxqt-branding-debian' instead of 'lxqt-branding'
              Package 'lxqt-qtplugin6' is not installed, so not removed
              Package 'lxqt-common' is not installed, so not removed
              Package 'lxplug-ptbatt' is not installed, so not removed
              Package 'lxplug-menu' is not installed, so not removed
              Note, selecting 'mesa-opencl-icd' for glob 'mesa*'
              Note, selecting 'mesa-test-tools' for glob 'mesa*'
              Note, selecting 'mesa-glide2-dev' for glob 'mesa*'
              Note, selecting 'mesag-dev' for glob 'mesa*'
              Note, selecting 'mesa-common-dev' for glob 'mesa*'
              Note, selecting 'mesa-vulkan-drivers-dbgsym' for glob 'mesa*'
              Note, selecting 'mesag3+ggi-dev' for glob 'mesa*'
              Note, selecting 'mesa-libgallium' for glob 'mesa*'
              Note, selecting 'mesa-drm-shim' for glob 'mesa*'
              Note, selecting 'mesa-va-drivers' for glob 'mesa*'
              Note, selecting 'mesa-libgallium-dbgsym' for glob 'mesa*'
              Note, selecting 'mesaflash' for glob 'mesa*'
              Note, selecting 'mesa-utils-bin' for glob 'mesa*'
              Note, selecting 'mesa-vulkan-drivers' for glob 'mesa*'
              Note, selecting 'mesa-drm-shim-dbgsym' for glob 'mesa*'
              Note, selecting 'mesa-utils-extra' for glob 'mesa*'
              Note, selecting 'mesa-teflon-delegate' for glob 'mesa*'
              Note, selecting 'mesa-opencl-icd-dbgsym' for glob 'mesa*'
              Note, selecting 'mesa-teflon-delegate-dbgsym' for glob 'mesa*'
              Note, selecting 'mesag3-widgets' for glob 'mesa*'
              Note, selecting 'mesa-utils' for glob 'mesa*'
              Note, selecting 'mesag3' for glob 'mesa*'
              Note, selecting 'mesa-vdpau-drivers' for glob 'mesa*'
              Note, selecting 'mesag-widgets-dev' for glob 'mesa*'
              Package 'mesa-test-tools' is not installed, so not removed
              Note, selecting 'libglw1-mesa-dev' instead of 'mesag-widgets-dev'
              Note, selecting 'libglw1-mesa-dev' instead of 'mesag3-widgets'
              Package 'mesag3' is not installed, so not removed
              Package 'mesa-glide2-dev' is not installed, so not removed
              Package 'mesag-dev' is not installed, so not removed
              Package 'mesag3+ggi-dev' is not installed, so not removed
              Note, selecting 'mesa-utils' instead of 'mesa-utils-extra'
              Package 'xserver-xephyr' is not installed, so not removed
              Package 'xserver-xorg-input-wacom' is not installed, so not removed
              Package 'xserver-xorg-input-synaptics' is not installed, so not removed
              Package 'xserver-x2gokdrive' is not installed, so not removed
              Package 'xserver-xorg-input-mtrack' is not installed, so not removed
              Package 'xserver-xorg-input-multitouch' is not installed, so not removed
              Package 'xserver-xorg-input-xwiimote' is not installed, so not removed
              Package 'xserver-xorg-dev' is not installed, so not removed
              Package 'xserver-xorg-legacy' is not installed, so not removed
              Package 'xserver-xorg-input-aiptek' is not installed, so not removed
              Package 'xserver-xorg-input-elographics' is not installed, so not removed
              Package 'xserver-xorg-input-evdev' is not installed, so not removed
              Package 'xserver-xorg-input-evdev-dev' is not installed, so not removed
              Package 'xserver-xorg-input-joystick' is not installed, so not removed
              Package 'xserver-xorg-input-joystick-dev' is not installed, so not removed
              Package 'xserver-xorg-input-kbd' is not installed, so not removed
              Package 'xserver-xorg-input-libinput-dev' is not installed, so not removed
              Package 'xserver-xorg-input-mouse' is not installed, so not removed
              Package 'xserver-xorg-input-synaptics-dev' is not installed, so not removed
              Package 'xserver-xorg-video-r128' is not installed, so not removed
              Package 'xserver-xorg-video-mach64' is not installed, so not removed
              Package 'xserver-xorg-video-cirrus' is not installed, so not removed
              Package 'xserver-xorg-video-dummy' is not installed, so not removed
              Package 'xserver-xorg-video-mga' is not installed, so not removed
              Package 'xserver-xorg-video-neomagic' is not installed, so not removed
              Package 'xserver-xorg-video-qxl' is not installed, so not removed
              Package 'xserver-xorg-video-savage' is not installed, so not removed
              Package 'xserver-xorg-video-siliconmotion' is not installed, so not removed
              Package 'xserver-xorg-video-sisusb' is not installed, so not removed
              Package 'xserver-xorg-video-nvidia' is not installed, so not removed
              Package 'xserver-xorg-video-nvidia-tesla-535' is not installed, so not removed
              Package 'xserver-xephyr-dbgsym' is not installed, so not removed
              Package 'xserver-xorg-core-dbgsym' is not installed, so not removed
              Package 'xserver-xorg-legacy-dbgsym' is not installed, so not removed
              Package 'xserver-xorg-video-fbturbo-dbgsym' is not installed, so not removed
              Package 'lightdm-remote-session-x2go' is not installed, so not removed
              Package 'lightdm-vala' is not installed, so not removed
              Package 'lightdm-autologin-greeter' is not installed, so not removed
              Package 'lightdm-gtk-greeter-settings' is not installed, so not removed
              Package 'lightdm-settings' is not installed, so not removed
              Package 'lightdm-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-jack' is not installed, so not removed
              Package 'vlc-plugin-fluidsynth' is not installed, so not removed
              Package 'vlc-plugin-pipewire' is not installed, so not removed
              Package 'vlc-plugin-svg' is not installed, so not removed
              Package 'vlc-plugin-bittorrent' is not installed, so not removed
              Package 'vlc-bin-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-access-extra-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-base-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-fluidsynth-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-jack-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-notify-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-qt-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-samba-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-skins2-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-svg-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-video-output-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-video-splitter-dbgsym' is not installed, so not removed
              Package 'vlc-plugin-visualization-dbgsym' is not installed, so not removed
              Package 'lxde-settings-daemon' is not installed, so not removed
              Package 'lxde-settings-daemon-dbgsym' is not installed, so not removed
              Package 'chromium-lwn4chrome' is not installed, so not removed
              Package 'chromium-shell' is not installed, so not removed
              Package 'chromium-driver' is not installed, so not removed
              Package 'chromium-headless-shell' is not installed, so not removed
              Package 'chromium-bsu' is not installed, so not removed
              Package 'chromium-bsu-data' is not installed, so not removed
              Package 'chromium-browser-l10n' is not installed, so not removed
              Package 'chromium-chromedriver' is not installed, so not removed
              Package 'chromium-common-dbgsym' is not installed, so not removed
              Package 'chromium-dbgsym' is not installed, so not removed
              Package 'chromium-headless-shell-dbgsym' is not installed, so not removed
              Package 'chromium-sandbox-dbgsym' is not installed, so not removed
              Package 'chromium-shell-dbgsym' is not installed, so not removed
              Package 'desktop-autoloader' is not installed, so not removed
              Package 'desktopfolder' is not installed, so not removed
              Package 'gnome-control-center' is not installed, so not removed
              Package 'gnome-screensaver' is not installed, so not removed
              Package 'gnome-themes-extra' is not installed, so not removed
              Package 'gnome-cards-data' is not installed, so not removed
              Package 'gnome-package-updater' is not installed, so not removed
              Package 'gnome-terminal' is not installed, so not removed
              Package 'gnome-panel-data' is not installed, so not removed
              Package 'gnome-common' is not installed, so not removed
              Package 'gnome-shell-extension-appindicator' is not installed, so not removed
              Package 'gnome-session-canberra' is not installed, so not removed
              Package 'gnome-settings-daemon' is not installed, so not removed
              Package 'gnome-user-docs' is not installed, so not removed
              Package 'gnome-user-share' is not installed, so not removed
              Package 'gnome-software' is not installed, so not removed
              Package 'gnome-packagekit' is not installed, so not removed
              Package 'gnome-calculator' is not installed, so not removed
              Package 'gnome-power-manager' is not installed, so not removed
              Package 'gnome-calls' is not installed, so not removed
              Package 'gnome-video-effects' is not installed, so not removed
              Package 'gnome-video-effects-frei0r' is not installed, so not removed
              Package 'gnome-backgrounds' is not installed, so not removed
              Package 'gnome-online-accounts-gtk' is not installed, so not removed
              Package 'gnome-text-editor' is not installed, so not removed
              Package 'gnome-screenshot' is not installed, so not removed
              Package 'gnome-snapshot' is not installed, so not removed
              Package 'gnome-characters' is not installed, so not removed
              Package 'gnome-disk-utility' is not installed, so not removed
              Package 'gnome-font-viewer' is not installed, so not removed
              Package 'gnome-games' is not installed, so not removed
              Package 'gnome-logs' is not installed, so not removed
              Package 'gnome-sound-recorder' is not installed, so not removed
              Package 'gnome-system-monitor' is not installed, so not removed
              Package 'gnome-connections' is not installed, so not removed
              Package 'gnome-color-manager' is not installed, so not removed
              Package 'gnome-desktop-testing' is not installed, so not removed
              Package 'gnome-accessibility-themes' is not installed, so not removed
              Package 'gnome-builder' is not installed, so not removed
              Package 'gnome-mines' is not installed, so not removed
              Package 'gnome-mahjongg' is not installed, so not removed
              Package 'gnomekiss' is not installed, so not removed
              Package 'gnome-clocks' is not installed, so not removed
              Package 'gnome-nibbles' is not installed, so not removed
              Package 'gnome-sudoku' is not installed, so not removed
              Package 'gnome-metronome' is not installed, so not removed
              Package 'gnome-pkg-tools' is not installed, so not removed
              Package 'gnome' is not installed, so not removed
              Package 'gnome-ponytail-daemon' is not installed, so not removed
              Package 'gnome-human-icon-theme' is not installed, so not removed
              Package 'gnome-epub-thumbnailer' is not installed, so not removed
              Package 'gnome-shell-extension-gamemode' is not installed, so not removed
              Package 'gnome-icon-theme-gartoon' is not installed, so not removed
              Package 'gnome-session' is not installed, so not removed
              Package 'gnome-session-bin' is not installed, so not removed
              Package 'gnome-session-common' is not installed, so not removed
              Package 'gnome-shell' is not installed, so not removed
              Package 'gnome-genius' is not installed, so not removed
              Package 'gnome-initial-setup' is not installed, so not removed
              Package 'gnome-maps' is not installed, so not removed
              Package 'gnome-2048' is not installed, so not removed
              Package 'gnome-activity-journal' is not installed, so not removed
              Package 'gnome-applets' is not installed, so not removed
              Package 'gnome-applets-data' is not installed, so not removed
              Package 'gnome-panel' is not installed, so not removed
              Package 'gnome-flashback' is not installed, so not removed
              Package 'gnome-audio' is not installed, so not removed
              Package 'gnome-core' is not installed, so not removed
              Package 'gnome-authenticator' is not installed, so not removed
              Package 'gnome-bluetooth-3-common' is not installed, so not removed
              Package 'gnome-bluetooth-sendto' is not installed, so not removed
              Package 'gnome-boxes' is not installed, so not removed
              Package 'gnome-breakout' is not installed, so not removed
              Package 'gnome-browser-connector' is not installed, so not removed
              Package 'gnome-calendar' is not installed, so not removed
              Package 'gnome-contacts' is not installed, so not removed
              Package 'gnome-calls-doc' is not installed, so not removed
              Package 'gnome-chess' is not installed, so not removed
              Package 'gnome-brave-icon-theme' is not installed, so not removed
              Package 'gnome-colors-common' is not installed, so not removed
              Package 'gnome-colors' is not installed, so not removed
              Package 'gnome-dust-icon-theme' is not installed, so not removed
              Package 'gnome-illustrious-icon-theme' is not installed, so not removed
              Package 'gnome-noble-icon-theme' is not installed, so not removed
              Package 'gnome-wine-icon-theme' is not installed, so not removed
              Package 'gnome-wise-icon-theme' is not installed, so not removed
              Package 'gnome-commander' is not installed, so not removed
              Package 'gnome-commander-data' is not installed, so not removed
              Package 'gnome-console' is not installed, so not removed
              Package 'gnome-control-center-data' is not installed, so not removed
              Package 'gnome-online-accounts' is not installed, so not removed
              Package 'gnome-remote-desktop' is not installed, so not removed
              Package 'gnome-control-center-dev' is not installed, so not removed
              Package 'gnome-decoder' is not installed, so not removed
              Package 'gnome-desktop-3-tests' is not installed, so not removed
              Package 'gnome-extra-icons' is not installed, so not removed
              Package 'gnome-feeds' is not installed, so not removed
              Package 'gnome-firmware' is not installed, so not removed
              Package 'gnome-flashback-common' is not installed, so not removed
              Package 'gnome-session-flashback' is not installed, so not removed
              Package 'gnome-hwp-support' is not installed, so not removed
              Package 'gnome-icon-theme-nuovo' is not installed, so not removed
              Package 'gnome-icon-theme-yasis' is not installed, so not removed
              Package 'gnome-keyring-pkcs11' is not installed, so not removed
              Package 'gnome-keysign' is not installed, so not removed
              Package 'gnome-kiosk' is not installed, so not removed
              Package 'gnome-kiosk-search-appliance' is not installed, so not removed
              Package 'gnome-kiosk-script-session' is not installed, so not removed
              Package 'gnome-klotski' is not installed, so not removed
              Package 'gnome-mastermind' is not installed, so not removed
              Package 'gnome-model-thumbnailer' is not installed, so not removed
              Package 'gnome-mousetrap' is not installed, so not removed
              Package 'gnome-multi-writer' is not installed, so not removed
              Package 'gnome-music' is not installed, so not removed
              Package 'gnome-nds-thumbnailer' is not installed, so not removed
              Package 'gnome-nettool' is not installed, so not removed
              Package 'gnome-network-displays' is not installed, so not removed
              Package 'gnome-packagekit-common' is not installed, so not removed
              Package 'gnome-pass-search-provider' is not installed, so not removed
              Package 'gnome-photos' is not installed, so not removed
              Package 'gnome-photos-tests' is not installed, so not removed
              Package 'gnome-pie' is not installed, so not removed
              Package 'gnome-podcasts' is not installed, so not removed
              Package 'gnome-settings-daemon-common' is not installed, so not removed
              Package 'gnome-recipes' is not installed, so not removed
              Package 'gnome-recipes-data' is not installed, so not removed
              Package 'gnome-robots' is not installed, so not removed
              Package 'gnome-screensaver-flags' is not installed, so not removed
              Package 'gnome-session-xsession' is not installed, so not removed
              Package 'gnome-settings-daemon-dev' is not installed, so not removed
              Package 'gnome-shell-common' is not installed, so not removed
              Package 'gnome-shell-extension-dash-to-panel' is not installed, so not removed
              Package 'gnome-shell-extension-dashtodock' is not installed, so not removed
              Package 'gnome-shell-extension-desktop-icons-ng' is not installed, so not removed
              Package 'gnome-shell-extensions' is not installed, so not removed
              Package 'gnome-shell-extension-prefs' is not installed, so not removed
              Package 'gnome-shell-extension-arc-menu' is not installed, so not removed
              Package 'gnome-shell-extension-autohidetopbar' is not installed, so not removed
              Package 'gnome-shell-extension-blur-my-shell' is not installed, so not removed
              Package 'gnome-shell-extension-caffeine' is not installed, so not removed
              Package 'gnome-shell-extension-manager' is not installed, so not removed
              Package 'gnome-shell-extension-easyscreencast' is not installed, so not removed
              Package 'gnome-shell-extension-flypie' is not installed, so not removed
              Package 'gnome-shell-extension-freon' is not installed, so not removed
              Package 'gnome-shell-extension-gsconnect' is not installed, so not removed
              Package 'gnome-shell-extension-gsconnect-browsers' is not installed, so not removed
              Package 'gnome-shell-extension-hamster' is not installed, so not removed
              Package 'gnome-shell-extension-hard-disk-led' is not installed, so not removed
              Package 'gnome-shell-extension-hide-activities' is not installed, so not removed
              Package 'gnome-shell-extension-impatience' is not installed, so not removed
              Package 'gnome-shell-extension-kimpanel' is not installed, so not removed
              Package 'gnome-shell-extension-no-annoyance' is not installed, so not removed
              Package 'gnome-shell-extension-runcat' is not installed, so not removed
              Package 'gnome-shell-extension-shortcuts' is not installed, so not removed
              Package 'gnome-shell-extension-tiling-assistant' is not installed, so not removed
              Package 'gnome-shell-extension-weather' is not installed, so not removed
              Package 'gnome-classic' is not installed, so not removed
              Package 'gnome-shell-extension-apps-menu' is not installed, so not removed
              Package 'gnome-shell-extension-places-menu' is not installed, so not removed
              Package 'gnome-shell-extension-launch-new-instance' is not installed, so not removed
              Package 'gnome-shell-extension-window-list' is not installed, so not removed
              Package 'gnome-classic-xsession' is not installed, so not removed
              Package 'gnome-shell-extensions-common' is not installed, so not removed
              Package 'gnome-shell-extension-auto-move-windows' is not installed, so not removed
              Package 'gnome-shell-extension-drive-menu' is not installed, so not removed
              Package 'gnome-shell-extension-light-style' is not installed, so not removed
              Package 'gnome-shell-extension-native-window-placement' is not installed, so not removed
              Package 'gnome-shell-extension-screenshot-window-sizer' is not installed, so not removed
              Package 'gnome-shell-extension-status-icons' is not installed, so not removed
              Package 'gnome-shell-extension-system-monitor' is not installed, so not removed
              Package 'gnome-shell-extension-user-theme' is not installed, so not removed
              Package 'gnome-shell-extension-windows-navigator' is not installed, so not removed
              Package 'gnome-shell-extension-workspace-indicator' is not installed, so not removed
              Package 'gnome-shell-extensions-extra' is not installed, so not removed
              Package 'gnome-tweaks' is not installed, so not removed
              Package 'gnome-shell-pomodoro' is not installed, so not removed
              Package 'gnome-shell-pomodoro-data' is not installed, so not removed
              Package 'gnome-software-plugin-deb' is not installed, so not removed
              Package 'gnome-software-common' is not installed, so not removed
              Package 'gnome-software-plugin-fwupd' is not installed, so not removed
              Package 'gnome-software-plugin-flatpak' is not installed, so not removed
              Package 'gnome-software-plugin-snap' is not installed, so not removed
              Package 'gnome-software-dev' is not installed, so not removed
              Package 'gnome-software-doc' is not installed, so not removed
              Package 'gnome-sushi' is not installed, so not removed
              Package 'gnome-system-tools' is not installed, so not removed
              Package 'gnome-taquin' is not installed, so not removed
              Package 'gnome-terminal-data' is not installed, so not removed
              Package 'gnome-tetravex' is not installed, so not removed
              Package 'gnome-tour' is not installed, so not removed
              Package 'gnome-usage' is not installed, so not removed
              Package 'gnome-video-effects-dev' is not installed, so not removed
              Package 'gnome-video-trimmer' is not installed, so not removed
              Package 'gnome-weather' is not installed, so not removed
              Package 'gnome-shell-extension-gpaste' is not installed, so not removed
              Package 'gnome-api-docs' is not installed, so not removed
              Package 'gnome-devel' is not installed, so not removed
              Package 'gnome-platform-devel' is not installed, so not removed
              Package 'gnome-theme-gilouche' is not installed, so not removed
              Package 'gnome-panel-control' is not installed, so not removed
              Package 'gnome-icon-theme-suede' is not installed, so not removed
              Package 'gnome-panel-control-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-plugins-ugly' is not installed, so not removed
              Package 'gstreamer1.0-pipewire' is not installed, so not removed
              Package 'gstreamer1.0-pulseaudio' is not installed, so not removed
              Package 'gstreamer1.0-tools' is not installed, so not removed
              Package 'gstreamer1.0-clutter-3.0' is not installed, so not removed
              Package 'gstreamer1.0-nice' is not installed, so not removed
              Package 'gstreamer1.0-gl' is not installed, so not removed
              Package 'gstreamer1.0-gtk3' is not installed, so not removed
              Package 'gstreamer1.0-gtk4' is not installed, so not removed
              Package 'gstreamer1.0-libcamera' is not installed, so not removed
              Package 'gstreamer1.0-opencv' is not installed, so not removed
              Package 'gstreamer1.0-plugins-bad-apps' is not installed, so not removed
              Package 'gstreamer1.0-wpe' is not installed, so not removed
              Package 'gstreamer1.0-plugins-base-apps' is not installed, so not removed
              Package 'gstreamer1.0-espeak' is not installed, so not removed
              Package 'gstreamer1.0-qt5' is not installed, so not removed
              Package 'gstreamer1.0-qt6' is not installed, so not removed
              Package 'gstreamer1.0-plugins-rtp' is not installed, so not removed
              Package 'gstreamer1.0-python3-plugin-loader' is not installed, so not removed
              Package 'gstreamer1.0-rtsp' is not installed, so not removed
              Package 'gstreamer1.0-vaapi' is not installed, so not removed
              Package 'gstreamer1.0-packagekit' is not installed, so not removed
              Package 'gstreamer1.0-pocketsphinx' is not installed, so not removed
              Package 'gstreamer1.0-adapter-pulseeffects' is not installed, so not removed
              Package 'gstreamer1.0-autogain-pulseeffects' is not installed, so not removed
              Package 'gstreamer1.0-convolver-pulseeffects' is not installed, so not removed
              Package 'gstreamer1.0-crystalizer-pulseeffects' is not installed, so not removed
              Package 'gstreamer1.0-fdkaac' is not installed, so not removed
              Package 'gstreamer1.0-alsa-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-gl-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-libcamera-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-opencv-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-pipewire-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-pispconvert' is not installed, so not removed
              Package 'gstreamer1.0-pispconvert-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-plugins-bad-apps-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-plugins-bad-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-plugins-base-apps-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-plugins-base-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-wpe-dbgsym' is not installed, so not removed
              Package 'gstreamer1.0-x-dbgsym' is not installed, so not removed
              Package 'gtk2-engines-murrine' is not installed, so not removed
              Package 'gtkmm-documentation' is not installed, so not removed
              Package 'gtkwave' is not installed, so not removed
              Package 'gtkatlantic' is not installed, so not removed
              Package 'gtkballs' is not installed, so not removed
              Package 'gtklp' is not installed, so not removed
              Package 'gtk-3-examples' is not installed, so not removed
              Package 'gtk-chtheme' is not installed, so not removed
              Package 'gtk-doc-tools' is not installed, so not removed
              Package 'gtk-im-libthai' is not installed, so not removed
              Package 'gtk3-im-libthai' is not installed, so not removed
              Package 'gtk-layer-shell-doc' is not installed, so not removed
              Package 'gtk-layer-shell-examples' is not installed, so not removed
              Package 'gtk-meshtastic-client' is not installed, so not removed
              Package 'gtk-session-lock-examples' is not installed, so not removed
              Package 'gtk-theme-switch' is not installed, so not removed
              Package 'gtk2-engines-aurora' is not installed, so not removed
              Package 'gtk2hs-buildtools' is not installed, so not removed
              Package 'gtk3-nocsd' is not installed, so not removed
              Package 'gtk-4-examples' is not installed, so not removed
              Package 'gtk-4-tests' is not installed, so not removed
              Package 'gtk4-layer-shell-doc' is not installed, so not removed
              Package 'gtk4-layer-shell-examples' is not installed, so not removed
              Package 'gtkam' is not installed, so not removed
              Package 'gtkcrypto' is not installed, so not removed
              Package 'gtkgreet' is not installed, so not removed
              Package 'gtkhash' is not installed, so not removed
              Package 'gtklock' is not installed, so not removed
              Package 'gtklock-playerctl-module' is not installed, so not removed
              Package 'gtklock-userinfo-module' is not installed, so not removed
              Package 'gtkman' is not installed, so not removed
              Package 'gtkterm' is not installed, so not removed
              Package 'gtk2-engines-qtcurve' is not installed, so not removed
              Package 'gtkmorph-example' is not installed, so not removed
              Package 'gtk-3-examples-dbgsym' is not installed, so not removed
              Package 'gtk-nop-dbgsym' is not installed, so not removed
              Package 'gtk2-engines-clearlookspix' is not installed, so not removed
              Package 'gtk2-engines-clearlookspix-dbgsym' is not installed, so not removed
              Package 'gtk2-engines-pixbuf-dbgsym' is not installed, so not removed
              Package 'gtk2-engines-pixflat-dbgsym' is not installed, so not removed
              Package 'lxc' is not installed, so not removed
              Package 'lxd' is not installed, so not removed
              Package 'lxqt-policykit' is not installed, so not removed
              Package 'lxi-tools' is not installed, so not removed
              Package 'lxc-dev' is not installed, so not removed
              Package 'lxqt-menu-data' is not installed, so not removed
              Package 'lxcfs' is not installed, so not removed
              Package 'lxd-tools' is not installed, so not removed
              Package 'lxqt-build-tools' is not installed, so not removed
              Package 'lx-gdb' is not installed, so not removed
              Package 'lxc-templates' is not installed, so not removed
              Package 'lxc-tests' is not installed, so not removed
              Package 'lxctl' is not installed, so not removed
              Package 'lxd-client' is not installed, so not removed
              Package 'lxd-agent' is not installed, so not removed
              Package 'lxd-migrate' is not installed, so not removed
              Package 'lxlock' is not installed, so not removed
              Package 'lxlauncher' is not installed, so not removed
              Package 'lxinput' is not installed, so not removed
              Package 'lxmusic' is not installed, so not removed
              Package 'lxdm' is not installed, so not removed
              Package 'lxhotkey-plugin-openbox' is not installed, so not removed
              Package 'lxhotkey-data' is not installed, so not removed
              Package 'lxhotkey-dev' is not installed, so not removed
              Package 'lximage-qt' is not installed, so not removed
              Package 'lximage-qt-l10n' is not installed, so not removed
              Package 'lxpanel-dev' is not installed, so not removed
              Package 'lxqt-about' is not installed, so not removed
              Package 'lxqt-about-l10n' is not installed, so not removed
              Package 'lxqt-qtplugin' is not installed, so not removed
              Package 'lxqt-admin' is not installed, so not removed
              Package 'lxqt-admin-l10n' is not installed, so not removed
              Package 'lxqt-archiver' is not installed, so not removed
              Package 'lxqt-archiver-l10n' is not installed, so not removed
              Package 'lxqt-branding-debian' is not installed, so not removed
              Package 'lxqt-theme-debian' is not installed, so not removed
              Package 'lxqt-system-theme' is not installed, so not removed
              Package 'lxqt-build-tools-qt5' is not installed, so not removed
              Package 'lxqt-config' is not installed, so not removed
              Package 'lxqt-config-l10n' is not installed, so not removed
              Package 'lxqt-powermanagement' is not installed, so not removed
              Package 'lxqt-session' is not installed, so not removed
              Package 'lxqt' is not installed, so not removed
              Package 'lxqt-core' is not installed, so not removed
              Package 'lxqt-globalkeys' is not installed, so not removed
              Package 'lxqt-globalkeys-l10n' is not installed, so not removed
              Package 'lxqt-panel' is not installed, so not removed
              Package 'lxqt-openssh-askpass' is not installed, so not removed
              Package 'lxqt-sudo' is not installed, so not removed
              Package 'lxqt-themes' is not installed, so not removed
              Package 'lxqt-notificationd' is not installed, so not removed
              Package 'lxqt-runner' is not installed, so not removed
              Package 'lxqt-notificationd-l10n' is not installed, so not removed
              Package 'lxqt-openssh-askpass-l10n' is not installed, so not removed
              Package 'lxqt-panel-l10n' is not installed, so not removed
              Package 'lxqt-policykit-l10n' is not installed, so not removed
              Package 'lxqt-powermanagement-l10n' is not installed, so not removed
              Package 'lxqt-qt5plugin' is not installed, so not removed
              Package 'lxqt-runner-l10n' is not installed, so not removed
              Package 'lxqt-session-l10n' is not installed, so not removed
              Package 'lxqt-sudo-l10n' is not installed, so not removed
              Package 'lxsession-default-apps' is not installed, so not removed
              Package 'lxpanel-pi' is not installed, so not removed
              Package 'lxpanel-pi-dbgsym' is not installed, so not removed
              Package 'lxpanel-pi-dev' is not installed, so not removed
              Package 'lxpanel-pi-dev-dbgsym' is not installed, so not removed
              Package 'lxpolkit-dbgsym' is not installed, so not removed
              Package 'lxsession-dbgsym' is not installed, so not removed
              Package 'lxsession-default-apps-dbgsym' is not installed, so not removed
              Package 'lxsession-edit-dbgsym' is not installed, so not removed
              Package 'lxsession-logout-dbgsym' is not installed, so not removed
              Package 'lxtask-dbgsym' is not installed, so not removed
              Package 'lxterminal-dbgsym' is not installed, so not removed
              Package 'mesa-utils' is not installed, so not removed
              Package 'mesa-common-dev' is not installed, so not removed
              Package 'mesa-opencl-icd' is not installed, so not removed
              Package 'mesa-va-drivers' is not installed, so not removed
              Package 'mesaflash' is not installed, so not removed
              Package 'mesa-drm-shim' is not installed, so not removed
              Package 'mesa-teflon-delegate' is not installed, so not removed
              Package 'mesa-vulkan-drivers' is not installed, so not removed
              Package 'mesa-utils-bin' is not installed, so not removed
              Package 'mesa-drm-shim-dbgsym' is not installed, so not removed
              Package 'mesa-libgallium-dbgsym' is not installed, so not removed
              Package 'mesa-opencl-icd-dbgsym' is not installed, so not removed
              Package 'mesa-teflon-delegate-dbgsym' is not installed, so not removed
              Package 'mesa-vulkan-drivers-dbgsym' is not installed, so not removed
              You might want to run 'apt --fix-broken install' to correct these.
              The following packages have unmet dependencies:
               adwaita-icon-theme : Depends: gtk-update-icon-cache
                                    Depends: hicolor-icon-theme but it is not going to be installed
               alacarte : Depends: gnome-menus (>= 3.5.3) but it is not going to be installed
               evince : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                        Depends: libgtk-3-0t64 (>= 3.22.0) but it is not going to be installed
               galculator : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                            Depends: libgtk-3-0t64 (>= 3.3.16) but it is not going to be installed
               gcr : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               gcr4 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               geany : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                       Depends: libgtk-3-0t64 (>= 3.21.5) but it is not going to be installed
               gir1.2-glib-2.0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
               gir1.2-gtk-3.0 : Depends: libgtk-3-0t64 (>= 3.24.36-2+rpt1) but it is not going to be installed
               girepository-tools : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
               gui-pkinst : Depends: libglib2.0-0t64 (>= 2.22.0) but it is not going to be installed
                            Depends: libgtk-3-0t64 (>= 3.24) but it is not going to be installed
               gui-updater : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
               gvfs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
               gvfs-backends : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                               Recommends: gnome-keyring or
                                           kwalletmanager but it is not going to be installed
                               Recommends: wsdd but it is not installable
               gvfs-common : Depends: desktop-file-utils
               gvfs-daemons : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
               gvfs-fuse : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
               gvfs-libs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
               libadwaita-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libappstream5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libatk1.0-0t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libatkmm-1.6-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
               libavahi-glib1 : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
               libavcodec61 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
               libayatana-ido3-0.4-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                       Depends: libgtk-3-0t64 (>= 3.21.4) but it is not going to be installed
               libayatana-indicator3-7 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libbabeltrace1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
               libcairo-gobject2 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
               libcamera0.5 : Depends: libcamera-ipa (= 0.5.2+rpt20250903-1~bpo12+1) but 0.7.1+rpt20260609-1 is to be installed
               libcloudproviders0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
               libegl-mesa0 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
               libevdocument3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libevview3-3t64 : Depends: gstreamer1.0-plugins-base but it is not going to be installed
               libfm-extra4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libfm-gtk3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libfm-modules : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                               Depends: libgtk-3-0t64 (>= 3.0.0) but it is not going to be installed
               libfm4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                           Depends: lxmenu-data but it is not going to be installed
               libgbm1 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
               libgck-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libgck-2-2 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
               libgcr-4-4 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
               libgcr-base-3-1 : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
               libgcr-ui-3-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libgio-2.0-dev : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
               libgio-2.0-dev-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
               libgirepository-1.0-1 : Depends: libglib2.0-0t64 (>= 2.82.0) but it is not going to be installed
               libgirepository-2.0-0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
               libglib2.0-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
               libglibmm-2.4-1t64 : Depends: libglib2.0-0t64 (>= 2.62.0) but it is not going to be installed
               libglx-mesa0 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
               libgnome-desktop-3-20t64 : Depends: gnome-desktop3-data (>= 44.3-3) but it is not going to be installed
                                          Depends: gnome-desktop3-data (< 45~) but it is not going to be installed
                                          Depends: libgtk-3-0t64 (>= 3.9.10) but it is not going to be installed
               libgoa-1.0-0b : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
               libgraphene-1.0-0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
               libgspell-1-3 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                               Depends: libgtk-3-0t64 (>= 3.20) but it is not going to be installed
               libgstreamer-gl1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                      Recommends: gstreamer1.0-gl but it is not going to be installed
               libgstreamer-plugins-bad1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
               libgstreamer-plugins-base1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                                                Recommends: gstreamer1.0-plugins-base but it is not going to be installed
               libgstreamer1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
               libgtk-3-0 : Depends: hicolor-icon-theme but it is not going to be installed
                            Recommends: libgtk-3-bin
               libgtk-4-1 : Depends: hicolor-icon-theme but it is not going to be installed
                            Recommends: libgtk-4-bin
                            Recommends: libgtk-4-media-gstreamer
               libgtk-layer-shell0 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
                                     Depends: libgtk-3-0t64 (>= 3.24.48) but it is not going to be installed
               libgtk2.0-0 : Depends: hicolor-icon-theme but it is not going to be installed
                             Recommends: libgail-common but it is not going to be installed
               libgtk2.0-bin : Depends: gtk-update-icon-cache
               libgtkmm-3.0-1t64 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
                                   Depends: libgtk-3-0t64 (>= 3.24.0) but it is not going to be installed
               libgtksourceview-4-0 : Depends: libglib2.0-0t64 (>= 2.48.0) but it is not going to be installed
               libgxps2t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libhandy-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                              Depends: libgtk-3-0t64 (>= 3.23.1) but it is not going to be installed
               libharfbuzz-gobject0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
               libharfbuzz0b : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
               libinput-tools : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                                Depends: libgtk-3-0t64 (>= 3.19.12) but it is not going to be installed
               libinput10 : Depends: libmtdev1t64 (>= 1.1.0) but it is not going to be installed
               libjavascriptcoregtk-4.1-0 : Depends: libglib2.0-0t64 (>= 2.66.0) but it is not going to be installed
               libkeybinder-3.0-0 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
               libmate-desktop-2-17t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libmenu-cache-bin : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
               libmousepad0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
               libmsgraph-1-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libnetplan1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
               libnm0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
               libnma0 : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
               libpango-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libpangocairo-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libpangoft2-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libpangomm-1.4-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
               libpangoxft-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libpeas-1.0-0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
               libpipewire-0.3-modules : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
               libpoppler-glib8t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libproxy1v5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libqt5ct-common1.8 : Depends: libqt5core5t64 (>= 5.9~) but it is not going to be installed
                                    Depends: libqt5gui5t64 (>= 5.9~) but it is not going to be installed or
                                             libqt5gui5-gles (>= 5.9~) but it is not going to be installed
               libqt6core6t64 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
               libqt6gui6 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                            Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
                            Recommends: qt6-svg-plugins but it is not going to be installed
                            Recommends: qt6-wayland but it is not going to be installed
               libqt6network6 : Depends: libglib2.0-0t64 (>= 2.46.0) but it is not going to be installed
               libqt6opengl6 : Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
               libsane1 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
               libspa-0.2-bluetooth : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
               libudev-dev : Depends: libudev1 (= 257.13-1~deb13u1) but 252.39-1~deb12u2 is to be installed
               libvolume-key1 : Depends: libglib2.0-0t64 (>= 2.18.0) but it is not going to be installed
               libvte-2.91-0 : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
               libwacom9 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
               libwebkit2gtk-4.1-0 : Depends: gstreamer1.0-plugins-base but it is not going to be installed
                                     Depends: gstreamer1.0-plugins-good but it is not going to be installed
                                     Depends: libgtk-3-0t64 (>= 3.23.0) but it is not going to be installed
                                     Recommends: gstreamer1.0-libav but it is not going to be installed
                                     Recommends: gstreamer1.0-plugins-bad but it is not going to be installed
               libwnck-3-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               libxfce4ui-2-0 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
               libxfce4util7 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                               Recommends: libxfce4util-bin but it is not going to be installed
               libxfconf-0-3 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
               libxmlb2 : Depends: libglib2.0-0t64 (>= 2.54.0) but it is not going to be installed
               lp-connection-editor : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               mate-polkit : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                             Depends: libgtk-3-0t64 (>= 3.16.2) but it is not going to be installed
               mousepad : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
                          Depends: libgtk-3-0t64 (>= 3.13.7) but it is not going to be installed
               netplan-generator : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
               netplan.io : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                            Recommends: python3-rich but it is not going to be installed
               network-manager : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                                 Recommends: network-manager-l10n but it is not going to be installed
               notification-daemon : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               obconf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
               openbox-lxde-session : Depends: lxde-common but it is not going to be installed
                                      Depends: lxsession but it is not going to be installed
               openssh-sftp-server : Depends: openssh-client (= 1:9.2p1-2+deb12u10)
               pango1.0-tools : Depends: libglib2.0-0t64 (>= 2.80) but it is not going to be installed
               pcmanfm : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                         Recommends: lxde-icon-theme but it is not going to be installed or
                                     gnome-icon-theme but it is not going to be installed or
                                     oxygen-icon-theme but it is not going to be installed or
                                     tango-icon-theme but it is not going to be installed
               pi-package : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               pi-package-session : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               piclone : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
               pipanel : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
               pishutdown : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
               piwiz : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
               pixflat-theme : Depends: gtk2-engines-pixbuf but it is not going to be installed
                               Depends: gtk2-engines-pixflat but it is not going to be installed
               pplug-ejecter-data : Depends: gtk-update-icon-cache
               pplug-power-data : Depends: gtk-update-icon-cache
               pplug-updater-data : Depends: gtk-update-icon-cache
               python3-dbus : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
               python3-gi : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
               python3-pyqt5 : Depends: libqt5printsupport5 (>= 5.15)
               qt5-gtk-platformtheme : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                       Depends: libqt5core5t64 (>= 5.15.1) but it is not going to be installed
                                       Depends: libqt5dbus5t64 (>= 5.14.1) but it is not going to be installed
                                       Depends: libqt5gui5t64 (>= 5.14.1) but it is not going to be installed or
                                                libqt5gui5-gles (>= 5.14.1) but it is not going to be installed
                                       Depends: qtbase-abi-5-15-15
               qt6-gtk-platformtheme : Depends: gnome-themes-extra-data but it is not going to be installed
               raindrop : Depends: libglib2.0-0t64 (>= 2.40.0) but it is not going to be installed
                          Depends: lightdm but it is not going to be installed
               rasputin : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
               rc-gui : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
               rp-bookshelf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
               rp-prefapps : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
               rpi-chromium-mods : Depends: chromium (>= 92) but it is not going to be installed
               sudopwd : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
               vdpau-driver-all : Depends: mesa-vdpau-drivers but it is not going to be installed
               wayfire : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
               wf-panel-pi : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                             Recommends: wfplug-clock but it is not going to be installed
               wfplug-batt : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
               wfplug-bluetooth : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
               wfplug-connect : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
               wfplug-cpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
               wfplug-cputemp : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
               wfplug-ejecter : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
               wfplug-gpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
               wfplug-menu : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
               wfplug-netman : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               wfplug-power : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
               wfplug-squeek : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
               wfplug-updater : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
               wfplug-volumepulse : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
               xarchiver : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                           Recommends: 7zip but it is not going to be installed
               xdg-desktop-portal-gtk : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
               xfconf : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
               xorg : Depends: xserver-xorg (>= 1:7.7+24+deb13u1) but it is not going to be installed
                      Depends: xterm or
                               x-terminal-emulator
               xorgxrdp : Depends: xorg-input-abi-24
                          Depends: xorg-video-abi-25
                          Depends: xserver-xorg-core (>= 2:21.1.1) but it is not going to be installed
               xwayland : Depends: xserver-common but it is not going to be installed
               zenity : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
               zenoty : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
              E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
              • H Hadebe
                sieht für mich nicht besser aus
                pi@raspi01:~ $ sudo apt purge xserver* lightdm* raspberrypi-ui-mods vlc* lxde* chromium* desktop* gnome* gstreamer* gtk* hicolor-icon-theme* lx* mesa*
                Reading package lists... Done
                Note, selecting 'xserver-xorg-video-nouveau' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-evdev' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-fbturbo-dbgsym' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-mouse' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-evtouch' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-amdgpu' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-mach64' for glob 'xserver*'
                Note, selecting 'xserver-xorg-core' for glob 'xserver*'
                Note, selecting 'xserver-xephyr-dbgsym' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-fbturbo' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-modesetting' for glob 'xserver*'
                Note, selecting 'xserver-x2gokdrive' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-all' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-intel' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-kbd' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-r128' for glob 'xserver*'
                Note, selecting 'xserver-xorg' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-joystick' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-xwiimote' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-vesa' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-elographics' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-dummy' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-aiptek' for glob 'xserver*'
                Note, selecting 'xserver-xorg-legacy' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-nvidia-any' for glob 'xserver*'
                Note, selecting 'xserver-common' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-radeon' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-synaptics' for glob 'xserver*'
                Note, selecting 'xserver-xorg-dev' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-vmware' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-neomagic' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-mtrack' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-libinput' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-siliconmotion' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-evdev-dev' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-sisusb' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-cirrus' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-wacom' for glob 'xserver*'
                Note, selecting 'xserver' for glob 'xserver*'
                Note, selecting 'xserver-xorg-core-dbgsym' for glob 'xserver*'
                Note, selecting 'xserver-xephyr' for glob 'xserver*'
                Note, selecting 'xserver-xorg-driver-all' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-joystick-dev' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-nvidia-tesla-535' for glob 'xserver*'
                Note, selecting 'xserver-xorg-legacy-dbgsym' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-libinput-dev' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-savage' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-synaptics-dev' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-all' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-ast' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-ati' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-fbdev' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-nvidia' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-nvidia-legacy-304xx' for glob 'xserver*'
                Note, selecting 'xserver-xorg-input-multitouch' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-mga' for glob 'xserver*'
                Note, selecting 'xserver-xorg-video-qxl' for glob 'xserver*'
                Package 'xserver-xorg-video-vmware' is not installed, so not removed
                Package 'xserver-xorg-video-intel' is not installed, so not removed
                Package 'xserver-xorg-driver-all' is not installed, so not removed
                Package 'xserver-xorg-input-evtouch' is not installed, so not removed
                Note, selecting 'xserver-xorg-core' instead of 'xserver-xorg-video-modesetting'
                Package 'xserver-xorg-video-nvidia-legacy-304xx' is not installed, so not removed
                Package 'xserver-xorg-video-ast' is not installed, so not removed
                Note, selecting 'lightdm-dbgsym' for glob 'lightdm*'
                Note, selecting 'lightdm-gtk-greeter-settings' for glob 'lightdm*'
                Note, selecting 'lightdm-autologin-greeter' for glob 'lightdm*'
                Note, selecting 'lightdm-gtk-greeter' for glob 'lightdm*'
                Note, selecting 'lightdm' for glob 'lightdm*'
                Note, selecting 'lightdm-remote-session-x2go' for glob 'lightdm*'
                Note, selecting 'lightdm-greeter' for glob 'lightdm*'
                Note, selecting 'lightdm-vala' for glob 'lightdm*'
                Note, selecting 'lightdm-settings' for glob 'lightdm*'
                Note, selecting 'vlc-plugin-qt' for glob 'vlc*'
                Note, selecting 'vlc-plugin-samba-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-data' for glob 'vlc*'
                Note, selecting 'vlc-plugin-abi-3-0-0ft64' for glob 'vlc*'
                Note, selecting 'vlc-bin-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-plugin-bittorrent' for glob 'vlc*'
                Note, selecting 'vlc-plugin-jack-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc' for glob 'vlc*'
                Note, selecting 'vlc-bin' for glob 'vlc*'
                Note, selecting 'vlc-l10n' for glob 'vlc*'
                Note, selecting 'vlc-plugin-bittorent' for glob 'vlc*'
                Note, selecting 'vlc-plugin-pipewire' for glob 'vlc*'
                Note, selecting 'vlc-plugin-video-output-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-plugin-jack' for glob 'vlc*'
                Note, selecting 'vlc-plugin-samba' for glob 'vlc*'
                Note, selecting 'vlc-plugin-qt-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-plugin-access-extra-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-plugin-notify' for glob 'vlc*'
                Note, selecting 'vlc-plugin-fluidsynth' for glob 'vlc*'
                Note, selecting 'vlc-plugin-visualization-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-plugin-abi-3-0-0f' for glob 'vlc*'
                Note, selecting 'vlc-plugin-fluidsynth-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-plugin-access-extra' for glob 'vlc*'
                Note, selecting 'vlc-plugin-notify-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-plugin-skins2' for glob 'vlc*'
                Note, selecting 'vlc-plugin-svg' for glob 'vlc*'
                Note, selecting 'vlc-plugin-video-splitter' for glob 'vlc*'
                Note, selecting 'vlc-plugin-video-output' for glob 'vlc*'
                Note, selecting 'vlc-plugin-svg-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-plugin-base-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-plugin-skins2-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-plugin-video-splitter-dbgsym' for glob 'vlc*'
                Note, selecting 'vlc-plugin-base' for glob 'vlc*'
                Note, selecting 'vlc-plugin-visualization' for glob 'vlc*'
                Package 'vlc-plugin-bittorent' is not installed, so not removed
                Note, selecting 'libvlccore9' instead of 'vlc-plugin-abi-3-0-0ft64'
                Note, selecting 'lxde-settings-daemon-dbgsym' for glob 'lxde*'
                Note, selecting 'lxde-common' for glob 'lxde*'
                Note, selecting 'lxde-core' for glob 'lxde*'
                Note, selecting 'lxde' for glob 'lxde*'
                Note, selecting 'lxde-icon-theme' for glob 'lxde*'
                Note, selecting 'lxde-settings-daemon' for glob 'lxde*'
                Note, selecting 'lxde-session' for glob 'lxde*'
                Note, selecting 'openbox-lxde-session' instead of 'lxde-session'
                Note, selecting 'chromium-bsu' for glob 'chromium*'
                Note, selecting 'chromium-sandbox' for glob 'chromium*'
                Note, selecting 'chromium-codecs-ffmpeg-extra:armhf' for glob 'chromium*'
                Note, selecting 'chromium-shell-dbgsym' for glob 'chromium*'
                Note, selecting 'chromium-driver' for glob 'chromium*'
                Note, selecting 'chromium-shell' for glob 'chromium*'
                Note, selecting 'chromium-dbgsym' for glob 'chromium*'
                Note, selecting 'chromium-sandbox-dbgsym' for glob 'chromium*'
                Note, selecting 'chromium' for glob 'chromium*'
                Note, selecting 'chromium-headless-shell' for glob 'chromium*'
                Note, selecting 'chromium-data' for glob 'chromium*'
                Note, selecting 'chromium-browser' for glob 'chromium*'
                Note, selecting 'chromium-chromedriver' for glob 'chromium*'
                Note, selecting 'chromium-lwn4chrome' for glob 'chromium*'
                Note, selecting 'chromium-l10n' for glob 'chromium*'
                Note, selecting 'chromium-common' for glob 'chromium*'
                Note, selecting 'chromium-headless-shell-dbgsym' for glob 'chromium*'
                Note, selecting 'chromium-common-dbgsym' for glob 'chromium*'
                Note, selecting 'chromium-tt-rss-notifier' for glob 'chromium*'
                Note, selecting 'chromium-bsu-data' for glob 'chromium*'
                Note, selecting 'chromium-browser-l10n' for glob 'chromium*'
                Package 'chromium-tt-rss-notifier' is not installed, so not removed
                Package 'chromium-data' is not installed, so not removed
                Package 'chromium-codecs-ffmpeg-extra:armhf' is not installed, so not removed
                Note, selecting 'desktop-base' for glob 'desktop*'
                Note, selecting 'desktop-autoloader' for glob 'desktop*'
                Note, selecting 'desktop-file-utils' for glob 'desktop*'
                Note, selecting 'desktopfolder' for glob 'desktop*'
                Note, selecting 'gnome-shell-extension-dashtodock' for glob 'gnome*'
                Note, selecting 'gnome-text-editor' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-dash-to-dock' for glob 'gnome*'
                Note, selecting 'gnomekiss' for glob 'gnome*'
                Note, selecting 'gnome-kiosk-script-session' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-light-style' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-launch-new-instance' for glob 'gnome*'
                Note, selecting 'gnome-shell-pomodoro-data' for glob 'gnome*'
                Note, selecting 'gnome-user-docs' for glob 'gnome*'
                Note, selecting 'gnome-wine-icon-theme' for glob 'gnome*'
                Note, selecting 'gnome-power-manager' for glob 'gnome*'
                Note, selecting 'gnome-panel' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-hard-disk-led' for glob 'gnome*'
                Note, selecting 'gnome-video-effects-frei0r' for glob 'gnome*'
                Note, selecting 'gnome-breakout' for glob 'gnome*'
                Note, selecting 'gnome-sound-recorder' for glob 'gnome*'
                Note, selecting 'gnome-sudoku' for glob 'gnome*'
                Note, selecting 'gnome-themes-standard-data' for glob 'gnome*'
                Note, selecting 'gnome-software-plugin' for glob 'gnome*'
                Note, selecting 'gnome-font-viewer' for glob 'gnome*'
                Note, selecting 'gnome-online-accounts-gtk' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-workspace-indicator' for glob 'gnome*'
                Note, selecting 'gnome-human-icon-theme' for glob 'gnome*'
                Note, selecting 'gnome-software' for glob 'gnome*'
                Note, selecting 'gnome-alsamixer' for glob 'gnome*'
                Note, selecting 'gnome-software-plugin-fwupd' for glob 'gnome*'
                Note, selecting 'gnome-initial-setup' for glob 'gnome*'
                Note, selecting 'gnome-user-share' for glob 'gnome*'
                Note, selecting 'gnome-weather' for glob 'gnome*'
                Note, selecting 'gnome-session-flashback' for glob 'gnome*'
                Note, selecting 'gnome-klotski' for glob 'gnome*'
                Note, selecting 'gnome-software-common' for glob 'gnome*'
                Note, selecting 'gnome-commander' for glob 'gnome*'
                Note, selecting 'gnome-mplayer' for glob 'gnome*'
                Note, selecting 'gnome-video-arcade' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-taskbar' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-runcat' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-tiling-assistant' for glob 'gnome*'
                Note, selecting 'gnome-ponytail-daemon' for glob 'gnome*'
                Note, selecting 'gnome-themes-extras' for glob 'gnome*'
                Note, selecting 'gnome-bluetooth-3-common' for glob 'gnome*'
                Note, selecting 'gnome-applets-data' for glob 'gnome*'
                Note, selecting 'gnome-nibbles' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-gpaste' for glob 'gnome*'
                Note, selecting 'gnome-audio' for glob 'gnome*'
                Note, selecting 'gnome-network-displays' for glob 'gnome*'
                Note, selecting 'gnome-color-manager' for glob 'gnome*'
                Note, selecting 'gnome-connections' for glob 'gnome*'
                Note, selecting 'gnome-games-app' for glob 'gnome*'
                Note, selecting 'gnome-desktop-3-tests' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-native-window-placement' for glob 'gnome*'
                Note, selecting 'gnome-icon-theme-yasis' for glob 'gnome*'
                Note, selecting 'gnome-shell-extensions-extra' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-gsconnect-browsers' for glob 'gnome*'
                Note, selecting 'gnome-dictionary' for glob 'gnome*'
                Note, selecting 'gnome-boxes' for glob 'gnome*'
                Note, selecting 'gnome-software-plugin-deb' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-vertical-workspaces' for glob 'gnome*'
                Note, selecting 'gnome-control-center-signon' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-kimpanel' for glob 'gnome*'
                Note, selecting 'gnome-session-bin' for glob 'gnome*'
                Note, selecting 'gnome-flashback-common' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-middleclickclose' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-auto-move-windows' for glob 'gnome*'
                Note, selecting 'gnome-shell-pomodoro' for glob 'gnome*'
                Note, selecting 'gnome-tweaks' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-window-list' for glob 'gnome*'
                Note, selecting 'gnome-system-monitor' for glob 'gnome*'
                Note, selecting 'gnome-panel-data' for glob 'gnome*'
                Note, selecting 'gnome-noble-icon-theme' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-apps-menu' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-disable-workspace-switcher' for glob 'gnome*'
                Note, selecting 'gnome' for glob 'gnome*'
                Note, selecting 'gnome-cards-data' for glob 'gnome*'
                Note, selecting 'gnome-remote-desktop' for glob 'gnome*'
                Note, selecting 'gnome-tweak-tool' for glob 'gnome*'
                Note, selecting 'gnome-applets' for glob 'gnome*'
                Note, selecting 'gnome-icon-theme' for glob 'gnome*'
                Note, selecting 'gnome-colors-common' for glob 'gnome*'
                Note, selecting 'gnome-icon-theme-full' for glob 'gnome*'
                Note, selecting 'gnome-power-statistics' for glob 'gnome*'
                Note, selecting 'gnome-pass-search-provider' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-easyscreencast' for glob 'gnome*'
                Note, selecting 'gnome-kiosk' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-flypie' for glob 'gnome*'
                Note, selecting 'gnome-calendar' for glob 'gnome*'
                Note, selecting 'gnome-screensaver' for glob 'gnome*'
                Note, selecting 'gnome-shell-extensions' for glob 'gnome*'
                Note, selecting 'gnome-panel-control-dbgsym' for glob 'gnome*'
                Note, selecting 'gnome-shell' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-status-icons' for glob 'gnome*'
                Note, selecting 'gnome-mime-data' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-weather' for glob 'gnome*'
                Note, selecting 'gnome-classic' for glob 'gnome*'
                Note, selecting 'gnome-settings-daemon-common' for glob 'gnome*'
                Note, selecting 'gnome-software-dev' for glob 'gnome*'
                Note, selecting 'gnome-software-doc' for glob 'gnome*'
                Note, selecting 'gnome-feeds' for glob 'gnome*'
                Note, selecting 'gnome-session-xsession' for glob 'gnome*'
                Note, selecting 'gnome-mines' for glob 'gnome*'
                Note, selecting 'gnome-icon-theme-gartoon' for glob 'gnome*'
                Note, selecting 'gnome-usage' for glob 'gnome*'
                Note, selecting 'gnome-software-plugin-snap' for glob 'gnome*'
                Note, selecting 'gnome-logs' for glob 'gnome*'
                Note, selecting 'gnome-core-devel' for glob 'gnome*'
                Note, selecting 'gnome-themes-standard' for glob 'gnome*'
                Note, selecting 'gnome-extra-icons' for glob 'gnome*'
                Note, selecting 'gnome-snapshot' for glob 'gnome*'
                Note, selecting 'gnome-devel' for glob 'gnome*'
                Note, selecting 'gnome-metronome' for glob 'gnome*'
                Note, selecting 'gnome-robots' for glob 'gnome*'
                Note, selecting 'gnome-packagekit' for glob 'gnome*'
                Note, selecting 'gnome-mastermind' for glob 'gnome*'
                Note, selecting 'gnome-calculator' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-desktop-icons-ng' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-just-perfection' for glob 'gnome*'
                Note, selecting 'gnome-2048' for glob 'gnome*'
                Note, selecting 'gnome-themes-extra-data' for glob 'gnome*'
                Note, selecting 'gnome-video-trimmer' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-top-icons-plus' for glob 'gnome*'
                Note, selecting 'gnome-icon-theme-nuovo' for glob 'gnome*'
                Note, selecting 'gnome-extensions-app' for glob 'gnome*'
                Note, selecting 'gnome-settings-daemon' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-appindicator' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-desktop-icons' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-autohidetopbar' for glob 'gnome*'
                Note, selecting 'gnome-illustrious-icon-theme' for glob 'gnome*'
                Note, selecting 'gnome-epub-thumbnailer' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-places-menu' for glob 'gnome*'
                Note, selecting 'gnome-photos' for glob 'gnome*'
                Note, selecting 'gnome-maps' for glob 'gnome*'
                Note, selecting 'gnome-multi-writer' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-freon' for glob 'gnome*'
                Note, selecting 'gnome-package-updater' for glob 'gnome*'
                Note, selecting 'gnome-contacts' for glob 'gnome*'
                Note, selecting 'gnome-mahjongg' for glob 'gnome*'
                Note, selecting 'gnome-commander-data' for glob 'gnome*'
                Note, selecting 'gnome-packagekit-data' for glob 'gnome*'
                Note, selecting 'gnome-desktop3-data' for glob 'gnome*'
                Note, selecting 'gnome-podcasts' for glob 'gnome*'
                Note, selecting 'gnome-colors' for glob 'gnome*'
                Note, selecting 'gnome-disk-utility' for glob 'gnome*'
                Note, selecting 'gnome-firmware' for glob 'gnome*'
                Note, selecting 'gnome-notes' for glob 'gnome*'
                Note, selecting 'gnome-classic-xsession' for glob 'gnome*'
                Note, selecting 'gnome-desktop-testing' for glob 'gnome*'
                Note, selecting 'gnome-icon-theme-suede' for glob 'gnome*'
                Note, selecting 'gnome-online-accounts' for glob 'gnome*'
                Note, selecting 'gnome-backgrounds' for glob 'gnome*'
                Note, selecting 'gnome-system-tools' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-no-annoyance' for glob 'gnome*'
                Note, selecting 'gnome-settings-daemon-dev' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-screenshot-window-sizer' for glob 'gnome*'
                Note, selecting 'gnome-screensaver-flags' for glob 'gnome*'
                Note, selecting 'gnome-bluetooth-sendto' for glob 'gnome*'
                Note, selecting 'gnome-screenshot' for glob 'gnome*'
                Note, selecting 'gnome-calls' for glob 'gnome*'
                Note, selecting 'gnome-shell-common' for glob 'gnome*'
                Note, selecting 'gnome-media' for glob 'gnome*'
                Note, selecting 'gnome-control-center-data' for glob 'gnome*'
                Note, selecting 'gnome-music' for glob 'gnome*'
                Note, selecting 'gnome-tetravex' for glob 'gnome*'
                Note, selecting 'gnome-platform-devel' for glob 'gnome*'
                Note, selecting 'gnome-theme-gilouche' for glob 'gnome*'
                Note, selecting 'gnome-keyring' for glob 'gnome*'
                Note, selecting 'gnome-icon-theme-symbolic' for glob 'gnome*'
                Note, selecting 'gnome-hwp-support' for glob 'gnome*'
                Note, selecting 'gnome-authenticator' for glob 'gnome*'
                Note, selecting 'gnome-mpv' for glob 'gnome*'
                Note, selecting 'gnome-pkg-tools' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-manager' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-workspaces-to-dock' for glob 'gnome*'
                Note, selecting 'gnome-menus' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-arc-menu' for glob 'gnome*'
                Note, selecting 'gnome-wise-icon-theme' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-hibernate-status' for glob 'gnome*'
                Note, selecting 'gnome-panel-control' for glob 'gnome*'
                Note, selecting 'gnome-pie' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-windows-navigator' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-shortcuts' for glob 'gnome*'
                Note, selecting 'gnome-brave-icon-theme' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-dash-to-panel' for glob 'gnome*'
                Note, selecting 'gnome-video-effects' for glob 'gnome*'
                Note, selecting 'gnome-session' for glob 'gnome*'
                Note, selecting 'gnome-common' for glob 'gnome*'
                Note, selecting 'gnome-dust-icon-theme' for glob 'gnome*'
                Note, selecting 'gnome-control-center' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-gamemode' for glob 'gnome*'
                Note, selecting 'gnome-terminal-data' for glob 'gnome*'
                Note, selecting 'gnome-settings-daemon-schemas' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-drive-menu' for glob 'gnome*'
                Note, selecting 'gnome-www-browser' for glob 'gnome*'
                Note, selecting 'gnome-games' for glob 'gnome*'
                Note, selecting 'gnome-flashback' for glob 'gnome*'
                Note, selecting 'gnome-session-canberra' for glob 'gnome*'
                Note, selecting 'gnome-genius' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-blur-my-shell' for glob 'gnome*'
                Note, selecting 'gnome-browser-connector' for glob 'gnome*'
                Note, selecting 'gnome-video-effects-dev' for glob 'gnome*'
                Note, selecting 'gnome-core' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-system-monitor' for glob 'gnome*'
                Note, selecting 'gnome-terminal' for glob 'gnome*'
                Note, selecting 'gnome-software-plugin-flatpak' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-impatience' for glob 'gnome*'
                Note, selecting 'gnome-characters' for glob 'gnome*'
                Note, selecting 'gnome-bluetooth' for glob 'gnome*'
                Note, selecting 'gnome-packagekit-common' for glob 'gnome*'
                Note, selecting 'gnome-sushi' for glob 'gnome*'
                Note, selecting 'gnome-activity-journal' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-onboard' for glob 'gnome*'
                Note, selecting 'gnome-api-docs' for glob 'gnome*'
                Note, selecting 'gnome-accessibility-themes' for glob 'gnome*'
                Note, selecting 'gnome-keysign' for glob 'gnome*'
                Note, selecting 'gnome-model-thumbnailer' for glob 'gnome*'
                Note, selecting 'gnome-themes-extra' for glob 'gnome*'
                Note, selecting 'gnome-shell-extensions-common' for glob 'gnome*'
                Note, selecting 'gnome-mousetrap' for glob 'gnome*'
                Note, selecting 'gnome-recipes' for glob 'gnome*'
                Note, selecting 'gnome-nettool' for glob 'gnome*'
                Note, selecting 'gnome-keyring-pkcs11' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-prefs' for glob 'gnome*'
                Note, selecting 'gnome-chess' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-no-overview' for glob 'gnome*'
                Note, selecting 'gnome-taquin' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-user-theme' for glob 'gnome*'
                Note, selecting 'gnome-decoder' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-caffeine' for glob 'gnome*'
                Note, selecting 'gnome-video-effects-extra' for glob 'gnome*'
                Note, selecting 'gnome-todo' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-hamster' for glob 'gnome*'
                Note, selecting 'gnome-tour' for glob 'gnome*'
                Note, selecting 'gnome-shell-extensions-gpaste' for glob 'gnome*'
                Note, selecting 'gnome-builder' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-hide-activities' for glob 'gnome*'
                Note, selecting 'gnome-shell-extension-gsconnect' for glob 'gnome*'
                Note, selecting 'gnome-console' for glob 'gnome*'
                Note, selecting 'gnome-nds-thumbnailer' for glob 'gnome*'
                Note, selecting 'gnome-recipes-data' for glob 'gnome*'
                Note, selecting 'gnome-photos-tests' for glob 'gnome*'
                Note, selecting 'gnome-calls-doc' for glob 'gnome*'
                Note, selecting 'gnome-control-center-dev' for glob 'gnome*'
                Note, selecting 'gnome-clocks' for glob 'gnome*'
                Note, selecting 'gnome-session-common' for glob 'gnome*'
                Note, selecting 'gnome-latex' for glob 'gnome*'
                Note, selecting 'gnome-codec-install' for glob 'gnome*'
                Note, selecting 'gnome-kiosk-search-appliance' for glob 'gnome*'
                Package 'gnome-themes-standard-data' is not installed, so not removed
                Note, selecting 'adwaita-icon-theme' instead of 'gnome-icon-theme-symbolic'
                Package 'gnome-bluetooth' is not installed, so not removed
                Package 'gnome-power-statistics' is not installed, so not removed
                Package 'gnome-control-center-signon' is not installed, so not removed
                Note, selecting 'bijiben' instead of 'gnome-notes'
                Package 'gnome-mpv' is not installed, so not removed
                Package 'gnome-mime-data' is not installed, so not removed
                Package 'gnome-video-arcade' is not installed, so not removed
                Package 'gnome-dictionary' is not installed, so not removed
                Package 'gnome-mplayer' is not installed, so not removed
                Note, selecting 'endeavour' instead of 'gnome-todo'
                Note, selecting 'enter-tex' instead of 'gnome-latex'
                Package 'gnome-packagekit-data' is not installed, so not removed
                Note, selecting 'gnome-settings-daemon-common' instead of 'gnome-settings-daemon-schemas'
                Package 'gnome-shell-extension-desktop-icons' is not installed, so not removed
                Package 'gnome-shell-extension-taskbar' is not installed, so not removed
                Package 'gnome-shell-extension-top-icons-plus' is not installed, so not removed
                Package 'gnome-shell-extension-workspaces-to-dock' is not installed, so not removed
                Note, selecting 'gnome-shell-extension-prefs' instead of 'gnome-extensions-app'
                Note, selecting 'gnome-shell-extension-dashtodock' instead of 'gnome-shell-extension-dash-to-dock'
                Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-disable-workspace-switcher'
                Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-hibernate-status'
                Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-just-perfection'
                Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-middleclickclose'
                Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-no-overview'
                Note, selecting 'gnome-shell-extensions-extra' instead of 'gnome-shell-extension-vertical-workspaces'
                Package 'gnome-media' is not installed, so not removed
                Note, selecting 'gnome-tweaks' instead of 'gnome-tweak-tool'
                Package 'gnome-video-effects-extra' is not installed, so not removed
                Package 'gnome-shell-extensions-gpaste' is not installed, so not removed
                Package 'gnome-games-app' is not installed, so not removed
                Package 'gnome-core-devel' is not installed, so not removed
                Package 'gnome-shell-extension-onboard' is not installed, so not removed
                Package 'gnome-codec-install' is not installed, so not removed
                Package 'gnome-icon-theme-full' is not installed, so not removed
                Package 'gnome-alsamixer' is not installed, so not removed
                Package 'gnome-themes-extras' is not installed, so not removed
                Package 'gnome-themes-standard' is not installed, so not removed
                Note, selecting 'gstreamer1.0-qt5' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-qt6' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-wpe' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-ugly' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-packagekit' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-bad-apps-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-gl' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-base-apps-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-fluendo-mp3' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-clutter-3.0' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-autogain-pulseeffects' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-python-dbg-plugin-loader' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-base-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-bad-videoparsers' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-pispconvert' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-adapter-pulseeffects' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-videosource' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-tools' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-espeak' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-really-bad' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-lame' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-base-apps' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-alsa' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-pipewire-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-audiosource' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-gl-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-audiosink' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-visualization' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-x' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-gtk3' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-gtk4' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-pocketsphinx' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-rtsp' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-libcamera' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-good' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-bad-faad' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-base' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-crystalhd' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-pipewire' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-python3-plugin-loader' for glob 'gstreamer*'
                Note, selecting 'gstreamer0.10-packagekit' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-bad-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-vaapi-doc' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-videosink' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-base-doc' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-x-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-opencv-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-convolver-pulseeffects' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-pispconvert-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-python3-dbg-plugin-loader' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-bad-apps' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-opencv' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-vaapi' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-nice' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-libcamera-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-crystalizer-pulseeffects' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-bad' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-pulseaudio' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-python-plugin-loader' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-libav' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-alsa-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-plugins-rtp' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-doc' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-fdkaac' for glob 'gstreamer*'
                Note, selecting 'gstreamer1.0-wpe-dbgsym' for glob 'gstreamer*'
                Note, selecting 'gstreamer-sharp-1.0' for glob 'gstreamer*'
                Package 'gstreamer1.0-doc' is not installed, so not removed
                Package 'gstreamer1.0-plugins-base-doc' is not installed, so not removed
                Package 'gstreamer-sharp-1.0' is not installed, so not removed
                Package 'gstreamer1.0-crystalhd' is not installed, so not removed
                Note, selecting 'gstreamer1.0-plugins-bad' instead of 'gstreamer1.0-plugins-bad-faad'
                Note, selecting 'gstreamer1.0-plugins-bad' instead of 'gstreamer1.0-plugins-bad-videoparsers'
                Package 'gstreamer1.0-python-dbg-plugin-loader' is not installed, so not removed
                Package 'gstreamer1.0-python-plugin-loader' is not installed, so not removed
                Package 'gstreamer1.0-python3-dbg-plugin-loader' is not installed, so not removed
                Package 'gstreamer1.0-vaapi-doc' is not installed, so not removed
                Package 'gstreamer1.0-fluendo-mp3' is not installed, so not removed
                Package 'gstreamer0.10-packagekit' is not installed, so not removed
                Package 'gstreamer1.0-lame' is not installed, so not removed
                Package 'gstreamer1.0-plugins-really-bad' is not installed, so not removed
                Note, selecting 'gtk-3-examples-dbgsym' for glob 'gtk*'
                Note, selecting 'gtkmorph-example' for glob 'gtk*'
                Note, selecting 'gtk2-engines-clearlookspix-dbgsym' for glob 'gtk*'
                Note, selecting 'gtk-layer-shell-doc' for glob 'gtk*'
                Note, selecting 'gtk2-engines-qtcurve' for glob 'gtk*'
                Note, selecting 'gtkhash' for glob 'gtk*'
                Note, selecting 'gtk2-engines-clearlookspix' for glob 'gtk*'
                Note, selecting 'gtk4-layer-shell-examples' for glob 'gtk*'
                Note, selecting 'gtk3-binver-3.0.0' for glob 'gtk*'
                Note, selecting 'gtkatlantic' for glob 'gtk*'
                Note, selecting 'gtk-im-libthai' for glob 'gtk*'
                Note, selecting 'gtklock-userinfo-module' for glob 'gtk*'
                Note, selecting 'gtkterm' for glob 'gtk*'
                Note, selecting 'gtk2-engines-pixbuf-dbgsym' for glob 'gtk*'
                Note, selecting 'gtk2hs-buildtools' for glob 'gtk*'
                Note, selecting 'gtklock-playerctl-module' for glob 'gtk*'
                Note, selecting 'gtk-nop' for glob 'gtk*'
                Note, selecting 'gtkballs' for glob 'gtk*'
                Note, selecting 'gtk2-engines-aurora' for glob 'gtk*'
                Note, selecting 'gtkam' for glob 'gtk*'
                Note, selecting 'gtk-redshift' for glob 'gtk*'
                Note, selecting 'gtklp' for glob 'gtk*'
                Note, selecting 'gtk-meshtastic-client' for glob 'gtk*'
                Note, selecting 'gtk4-binver-4.0.0' for glob 'gtk*'
                Note, selecting 'gtkguitune' for glob 'gtk*'
                Note, selecting 'gtk2-engines-murrine' for glob 'gtk*'
                Note, selecting 'gtk4-layer-shell-doc' for glob 'gtk*'
                Note, selecting 'gtk3-nocsd' for glob 'gtk*'
                Note, selecting 'gtk-4-examples' for glob 'gtk*'
                Note, selecting 'gtkgreet' for glob 'gtk*'
                Note, selecting 'gtk-nop-dbgsym' for glob 'gtk*'
                Note, selecting 'gtkpool' for glob 'gtk*'
                Note, selecting 'gtk-session-lock-examples' for glob 'gtk*'
                Note, selecting 'gtk2-engines' for glob 'gtk*'
                Note, selecting 'gtk2-engines-sugar' for glob 'gtk*'
                Note, selecting 'gtkman' for glob 'gtk*'
                Note, selecting 'gtk-layer-shell-examples' for glob 'gtk*'
                Note, selecting 'gtkpod' for glob 'gtk*'
                Note, selecting 'gtkcrypto' for glob 'gtk*'
                Note, selecting 'gtk-theme-switch' for glob 'gtk*'
                Note, selecting 'gtkmm-documentation' for glob 'gtk*'
                Note, selecting 'gtk2-engines-pixbuf' for glob 'gtk*'
                Note, selecting 'gtk-3-examples' for glob 'gtk*'
                Note, selecting 'gtk-chtheme' for glob 'gtk*'
                Note, selecting 'gtk-update-icon-cache' for glob 'gtk*'
                Note, selecting 'gtk-doc-tools' for glob 'gtk*'
                Note, selecting 'gtkwave' for glob 'gtk*'
                Note, selecting 'gtk2-engines-pixflat' for glob 'gtk*'
                Note, selecting 'gtklick' for glob 'gtk*'
                Note, selecting 'gtkboard' for glob 'gtk*'
                Note, selecting 'gtklock' for glob 'gtk*'
                Note, selecting 'gtk3-im-libthai' for glob 'gtk*'
                Note, selecting 'gtk2-engines-pixflat-dbgsym' for glob 'gtk*'
                Note, selecting 'gtk-4-tests' for glob 'gtk*'
                Note, selecting 'gtk-recordmydesktop' for glob 'gtk*'
                Note, selecting 'gtk2.0-binver-2.10.0' for glob 'gtk*'
                Note, selecting 'gtk2-engines-gartoon' for glob 'gtk*'
                Package 'gtkboard' is not installed, so not removed
                Package 'gtkpool' is not installed, so not removed
                Package 'gtkguitune' is not installed, so not removed
                Package 'gtklick' is not installed, so not removed
                Note, selecting 'gnome-icon-theme-gartoon' instead of 'gtk2-engines-gartoon'
                Package 'gtkpod' is not installed, so not removed
                Note, selecting 'libgtk-4-1' instead of 'gtk4-binver-4.0.0'
                Package 'gtk-recordmydesktop' is not installed, so not removed
                Package 'gtk-redshift' is not installed, so not removed
                Package 'gtk2-engines-sugar' is not installed, so not removed
                Note, selecting 'hicolor-icon-theme' for glob 'hicolor-icon-theme*'
                Note, selecting 'lxplug-ejecter' for glob 'lx*'
                Note, selecting 'lxpanel-pi-dbgsym' for glob 'lx*'
                Note, selecting 'lxd-tools' for glob 'lx*'
                Note, selecting 'lxqt-powermanagement-l10n' for glob 'lx*'
                Note, selecting 'lxpanel-pi' for glob 'lx*'
                Note, selecting 'lxplug-volumepulse' for glob 'lx*'
                Note, selecting 'lximage-qt-l10n' for glob 'lx*'
                Note, selecting 'lxpanel-dev' for glob 'lx*'
                Note, selecting 'lxqt-panel' for glob 'lx*'
                Note, selecting 'lxlauncher' for glob 'lx*'
                Note, selecting 'lxpanel-data' for glob 'lx*'
                Note, selecting 'lxqt-theme-debian' for glob 'lx*'
                Note, selecting 'lxqt-archiver' for glob 'lx*'
                Note, selecting 'lxterminal' for glob 'lx*'
                Note, selecting 'lxqt-system-theme' for glob 'lx*'
                Note, selecting 'lxc' for glob 'lx*'
                Note, selecting 'lxd' for glob 'lx*'
                Note, selecting 'lxqt-admin' for glob 'lx*'
                Note, selecting 'lxi-tools' for glob 'lx*'
                Note, selecting 'lxqt-openssh-askpass-l10n' for glob 'lx*'
                Note, selecting 'lxpolkit' for glob 'lx*'
                Note, selecting 'lxqt-powermanagement' for glob 'lx*'
                Note, selecting 'lxsession' for glob 'lx*'
                Note, selecting 'lxsession-data' for glob 'lx*'
                Note, selecting 'lxde-settings-daemon-dbgsym' for glob 'lx*'
                Note, selecting 'lxde-common' for glob 'lx*'
                Note, selecting 'lxlock' for glob 'lx*'
                Note, selecting 'lxqt-sudo-l10n' for glob 'lx*'
                Note, selecting 'lxcfs' for glob 'lx*'
                Note, selecting 'lxctl' for glob 'lx*'
                Note, selecting 'lxqt-openssh-askpass' for glob 'lx*'
                Note, selecting 'lxmenu-data' for glob 'lx*'
                Note, selecting 'lxd-client' for glob 'lx*'
                Note, selecting 'lxqt-qtplugin' for glob 'lx*'
                Note, selecting 'lxde-core' for glob 'lx*'
                Note, selecting 'lxqt-qtplugin6' for glob 'lx*'
                Note, selecting 'lxplug-updater' for glob 'lx*'
                Note, selecting 'lxplug-cpu' for glob 'lx*'
                Note, selecting 'lxqt-runner-l10n' for glob 'lx*'
                Note, selecting 'lxd-migrate' for glob 'lx*'
                Note, selecting 'lxpanel' for glob 'lx*'
                Note, selecting 'lxqt-sudo' for glob 'lx*'
                Note, selecting 'lxc-dev' for glob 'lx*'
                Note, selecting 'lxqt-admin-l10n' for glob 'lx*'
                Note, selecting 'lxsession-edit' for glob 'lx*'
                Note, selecting 'lxqt-policykit-l10n' for glob 'lx*'
                Note, selecting 'lxrandr' for glob 'lx*'
                Note, selecting 'lxqt-core' for glob 'lx*'
                Note, selecting 'lxqt-archiver-l10n' for glob 'lx*'
                Note, selecting 'lxqt-theme' for glob 'lx*'
                Note, selecting 'lxplug-bluetooth' for glob 'lx*'
                Note, selecting 'lxplug-cputemp' for glob 'lx*'
                Note, selecting 'lxqt-globalkeys-l10n' for glob 'lx*'
                Note, selecting 'lxappearance-obconf' for glob 'lx*'
                Note, selecting 'lxqt-branding-debian' for glob 'lx*'
                Note, selecting 'lxde' for glob 'lx*'
                Note, selecting 'lxdm' for glob 'lx*'
                Note, selecting 'lxqt' for glob 'lx*'
                Note, selecting 'lxplug-magnifier' for glob 'lx*'
                Note, selecting 'lxinput' for glob 'lx*'
                Note, selecting 'lxshortcut' for glob 'lx*'
                Note, selecting 'lxpolkit-dbgsym' for glob 'lx*'
                Note, selecting 'lxqt-branding' for glob 'lx*'
                Note, selecting 'lxqt-qt5plugin' for glob 'lx*'
                Note, selecting 'lxtask' for glob 'lx*'
                Note, selecting 'lxqt-policykit' for glob 'lx*'
                Note, selecting 'lxplug-netman' for glob 'lx*'
                Note, selecting 'lxsession-logout' for glob 'lx*'
                Note, selecting 'lxplug-batt' for glob 'lx*'
                Note, selecting 'lxqt-panel-l10n' for glob 'lx*'
                Note, selecting 'lxpanel-pi-dev-dbgsym' for glob 'lx*'
                Note, selecting 'lx-gdb' for glob 'lx*'
                Note, selecting 'lxc-tests' for glob 'lx*'
                Note, selecting 'lxplug-menu' for glob 'lx*'
                Note, selecting 'lxhotkey-core' for glob 'lx*'
                Note, selecting 'lxqt-common' for glob 'lx*'
                Note, selecting 'lxsession-default-apps' for glob 'lx*'
                Note, selecting 'lxsession-edit-dbgsym' for glob 'lx*'
                Note, selecting 'lxqt-about' for glob 'lx*'
                Note, selecting 'lxde-icon-theme' for glob 'lx*'
                Note, selecting 'lxc-templates' for glob 'lx*'
                Note, selecting 'lxhotkey-data' for glob 'lx*'
                Note, selecting 'lxqt-session-l10n' for glob 'lx*'
                Note, selecting 'lximage-qt' for glob 'lx*'
                Note, selecting 'lxhotkey-dev' for glob 'lx*'
                Note, selecting 'lxqt-runner' for glob 'lx*'
                Note, selecting 'lxqt-build-tools-qt5' for glob 'lx*'
                Note, selecting 'lxhotkey-gtk' for glob 'lx*'
                Note, selecting 'lxhotkey-gui' for glob 'lx*'
                Note, selecting 'lxqt-menu-data' for glob 'lx*'
                Note, selecting 'lxplug-ptbatt' for glob 'lx*'
                Note, selecting 'lxsession-dbgsym' for glob 'lx*'
                Note, selecting 'lxqt-themes' for glob 'lx*'
                Note, selecting 'lxhotkey-plugin-openbox' for glob 'lx*'
                Note, selecting 'lxqt-build-tools' for glob 'lx*'
                Note, selecting 'lxqt-config' for glob 'lx*'
                Note, selecting 'lxpanel-pi-dev' for glob 'lx*'
                Note, selecting 'lxtask-dbgsym' for glob 'lx*'
                Note, selecting 'lxqt-about-l10n' for glob 'lx*'
                Note, selecting 'lxqt-session' for glob 'lx*'
                Note, selecting 'lxde-settings-daemon' for glob 'lx*'
                Note, selecting 'lxqt-config-l10n' for glob 'lx*'
                Note, selecting 'lxd-agent' for glob 'lx*'
                Note, selecting 'lxqt-globalkeys' for glob 'lx*'
                Note, selecting 'lxmusic' for glob 'lx*'
                Note, selecting 'lxde-session' for glob 'lx*'
                Note, selecting 'lxsession-logout-dbgsym' for glob 'lx*'
                Note, selecting 'lxqt-notificationd' for glob 'lx*'
                Note, selecting 'lxsession-default-apps-dbgsym' for glob 'lx*'
                Note, selecting 'lxappearance' for glob 'lx*'
                Note, selecting 'lxterminal-dbgsym' for glob 'lx*'
                Note, selecting 'lxqt-notificationd-l10n' for glob 'lx*'
                Note, selecting 'libfm-tools' instead of 'lxshortcut'
                Note, selecting 'lxhotkey-gtk' instead of 'lxhotkey-gui'
                Note, selecting 'lxqt-branding-debian' instead of 'lxqt-branding'
                Package 'lxqt-qtplugin6' is not installed, so not removed
                Package 'lxqt-common' is not installed, so not removed
                Package 'lxplug-ptbatt' is not installed, so not removed
                Package 'lxplug-menu' is not installed, so not removed
                Note, selecting 'mesa-opencl-icd' for glob 'mesa*'
                Note, selecting 'mesa-test-tools' for glob 'mesa*'
                Note, selecting 'mesa-glide2-dev' for glob 'mesa*'
                Note, selecting 'mesag-dev' for glob 'mesa*'
                Note, selecting 'mesa-common-dev' for glob 'mesa*'
                Note, selecting 'mesa-vulkan-drivers-dbgsym' for glob 'mesa*'
                Note, selecting 'mesag3+ggi-dev' for glob 'mesa*'
                Note, selecting 'mesa-libgallium' for glob 'mesa*'
                Note, selecting 'mesa-drm-shim' for glob 'mesa*'
                Note, selecting 'mesa-va-drivers' for glob 'mesa*'
                Note, selecting 'mesa-libgallium-dbgsym' for glob 'mesa*'
                Note, selecting 'mesaflash' for glob 'mesa*'
                Note, selecting 'mesa-utils-bin' for glob 'mesa*'
                Note, selecting 'mesa-vulkan-drivers' for glob 'mesa*'
                Note, selecting 'mesa-drm-shim-dbgsym' for glob 'mesa*'
                Note, selecting 'mesa-utils-extra' for glob 'mesa*'
                Note, selecting 'mesa-teflon-delegate' for glob 'mesa*'
                Note, selecting 'mesa-opencl-icd-dbgsym' for glob 'mesa*'
                Note, selecting 'mesa-teflon-delegate-dbgsym' for glob 'mesa*'
                Note, selecting 'mesag3-widgets' for glob 'mesa*'
                Note, selecting 'mesa-utils' for glob 'mesa*'
                Note, selecting 'mesag3' for glob 'mesa*'
                Note, selecting 'mesa-vdpau-drivers' for glob 'mesa*'
                Note, selecting 'mesag-widgets-dev' for glob 'mesa*'
                Package 'mesa-test-tools' is not installed, so not removed
                Note, selecting 'libglw1-mesa-dev' instead of 'mesag-widgets-dev'
                Note, selecting 'libglw1-mesa-dev' instead of 'mesag3-widgets'
                Package 'mesag3' is not installed, so not removed
                Package 'mesa-glide2-dev' is not installed, so not removed
                Package 'mesag-dev' is not installed, so not removed
                Package 'mesag3+ggi-dev' is not installed, so not removed
                Note, selecting 'mesa-utils' instead of 'mesa-utils-extra'
                Package 'xserver-xephyr' is not installed, so not removed
                Package 'xserver-xorg-input-wacom' is not installed, so not removed
                Package 'xserver-xorg-input-synaptics' is not installed, so not removed
                Package 'xserver-x2gokdrive' is not installed, so not removed
                Package 'xserver-xorg-input-mtrack' is not installed, so not removed
                Package 'xserver-xorg-input-multitouch' is not installed, so not removed
                Package 'xserver-xorg-input-xwiimote' is not installed, so not removed
                Package 'xserver-xorg-dev' is not installed, so not removed
                Package 'xserver-xorg-legacy' is not installed, so not removed
                Package 'xserver-xorg-input-aiptek' is not installed, so not removed
                Package 'xserver-xorg-input-elographics' is not installed, so not removed
                Package 'xserver-xorg-input-evdev' is not installed, so not removed
                Package 'xserver-xorg-input-evdev-dev' is not installed, so not removed
                Package 'xserver-xorg-input-joystick' is not installed, so not removed
                Package 'xserver-xorg-input-joystick-dev' is not installed, so not removed
                Package 'xserver-xorg-input-kbd' is not installed, so not removed
                Package 'xserver-xorg-input-libinput-dev' is not installed, so not removed
                Package 'xserver-xorg-input-mouse' is not installed, so not removed
                Package 'xserver-xorg-input-synaptics-dev' is not installed, so not removed
                Package 'xserver-xorg-video-r128' is not installed, so not removed
                Package 'xserver-xorg-video-mach64' is not installed, so not removed
                Package 'xserver-xorg-video-cirrus' is not installed, so not removed
                Package 'xserver-xorg-video-dummy' is not installed, so not removed
                Package 'xserver-xorg-video-mga' is not installed, so not removed
                Package 'xserver-xorg-video-neomagic' is not installed, so not removed
                Package 'xserver-xorg-video-qxl' is not installed, so not removed
                Package 'xserver-xorg-video-savage' is not installed, so not removed
                Package 'xserver-xorg-video-siliconmotion' is not installed, so not removed
                Package 'xserver-xorg-video-sisusb' is not installed, so not removed
                Package 'xserver-xorg-video-nvidia' is not installed, so not removed
                Package 'xserver-xorg-video-nvidia-tesla-535' is not installed, so not removed
                Package 'xserver-xephyr-dbgsym' is not installed, so not removed
                Package 'xserver-xorg-core-dbgsym' is not installed, so not removed
                Package 'xserver-xorg-legacy-dbgsym' is not installed, so not removed
                Package 'xserver-xorg-video-fbturbo-dbgsym' is not installed, so not removed
                Package 'lightdm-remote-session-x2go' is not installed, so not removed
                Package 'lightdm-vala' is not installed, so not removed
                Package 'lightdm-autologin-greeter' is not installed, so not removed
                Package 'lightdm-gtk-greeter-settings' is not installed, so not removed
                Package 'lightdm-settings' is not installed, so not removed
                Package 'lightdm-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-jack' is not installed, so not removed
                Package 'vlc-plugin-fluidsynth' is not installed, so not removed
                Package 'vlc-plugin-pipewire' is not installed, so not removed
                Package 'vlc-plugin-svg' is not installed, so not removed
                Package 'vlc-plugin-bittorrent' is not installed, so not removed
                Package 'vlc-bin-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-access-extra-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-base-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-fluidsynth-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-jack-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-notify-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-qt-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-samba-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-skins2-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-svg-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-video-output-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-video-splitter-dbgsym' is not installed, so not removed
                Package 'vlc-plugin-visualization-dbgsym' is not installed, so not removed
                Package 'lxde-settings-daemon' is not installed, so not removed
                Package 'lxde-settings-daemon-dbgsym' is not installed, so not removed
                Package 'chromium-lwn4chrome' is not installed, so not removed
                Package 'chromium-shell' is not installed, so not removed
                Package 'chromium-driver' is not installed, so not removed
                Package 'chromium-headless-shell' is not installed, so not removed
                Package 'chromium-bsu' is not installed, so not removed
                Package 'chromium-bsu-data' is not installed, so not removed
                Package 'chromium-browser-l10n' is not installed, so not removed
                Package 'chromium-chromedriver' is not installed, so not removed
                Package 'chromium-common-dbgsym' is not installed, so not removed
                Package 'chromium-dbgsym' is not installed, so not removed
                Package 'chromium-headless-shell-dbgsym' is not installed, so not removed
                Package 'chromium-sandbox-dbgsym' is not installed, so not removed
                Package 'chromium-shell-dbgsym' is not installed, so not removed
                Package 'desktop-autoloader' is not installed, so not removed
                Package 'desktopfolder' is not installed, so not removed
                Package 'gnome-control-center' is not installed, so not removed
                Package 'gnome-screensaver' is not installed, so not removed
                Package 'gnome-themes-extra' is not installed, so not removed
                Package 'gnome-cards-data' is not installed, so not removed
                Package 'gnome-package-updater' is not installed, so not removed
                Package 'gnome-terminal' is not installed, so not removed
                Package 'gnome-panel-data' is not installed, so not removed
                Package 'gnome-common' is not installed, so not removed
                Package 'gnome-shell-extension-appindicator' is not installed, so not removed
                Package 'gnome-session-canberra' is not installed, so not removed
                Package 'gnome-settings-daemon' is not installed, so not removed
                Package 'gnome-user-docs' is not installed, so not removed
                Package 'gnome-user-share' is not installed, so not removed
                Package 'gnome-software' is not installed, so not removed
                Package 'gnome-packagekit' is not installed, so not removed
                Package 'gnome-calculator' is not installed, so not removed
                Package 'gnome-power-manager' is not installed, so not removed
                Package 'gnome-calls' is not installed, so not removed
                Package 'gnome-video-effects' is not installed, so not removed
                Package 'gnome-video-effects-frei0r' is not installed, so not removed
                Package 'gnome-backgrounds' is not installed, so not removed
                Package 'gnome-online-accounts-gtk' is not installed, so not removed
                Package 'gnome-text-editor' is not installed, so not removed
                Package 'gnome-screenshot' is not installed, so not removed
                Package 'gnome-snapshot' is not installed, so not removed
                Package 'gnome-characters' is not installed, so not removed
                Package 'gnome-disk-utility' is not installed, so not removed
                Package 'gnome-font-viewer' is not installed, so not removed
                Package 'gnome-games' is not installed, so not removed
                Package 'gnome-logs' is not installed, so not removed
                Package 'gnome-sound-recorder' is not installed, so not removed
                Package 'gnome-system-monitor' is not installed, so not removed
                Package 'gnome-connections' is not installed, so not removed
                Package 'gnome-color-manager' is not installed, so not removed
                Package 'gnome-desktop-testing' is not installed, so not removed
                Package 'gnome-accessibility-themes' is not installed, so not removed
                Package 'gnome-builder' is not installed, so not removed
                Package 'gnome-mines' is not installed, so not removed
                Package 'gnome-mahjongg' is not installed, so not removed
                Package 'gnomekiss' is not installed, so not removed
                Package 'gnome-clocks' is not installed, so not removed
                Package 'gnome-nibbles' is not installed, so not removed
                Package 'gnome-sudoku' is not installed, so not removed
                Package 'gnome-metronome' is not installed, so not removed
                Package 'gnome-pkg-tools' is not installed, so not removed
                Package 'gnome' is not installed, so not removed
                Package 'gnome-ponytail-daemon' is not installed, so not removed
                Package 'gnome-human-icon-theme' is not installed, so not removed
                Package 'gnome-epub-thumbnailer' is not installed, so not removed
                Package 'gnome-shell-extension-gamemode' is not installed, so not removed
                Package 'gnome-icon-theme-gartoon' is not installed, so not removed
                Package 'gnome-session' is not installed, so not removed
                Package 'gnome-session-bin' is not installed, so not removed
                Package 'gnome-session-common' is not installed, so not removed
                Package 'gnome-shell' is not installed, so not removed
                Package 'gnome-genius' is not installed, so not removed
                Package 'gnome-initial-setup' is not installed, so not removed
                Package 'gnome-maps' is not installed, so not removed
                Package 'gnome-2048' is not installed, so not removed
                Package 'gnome-activity-journal' is not installed, so not removed
                Package 'gnome-applets' is not installed, so not removed
                Package 'gnome-applets-data' is not installed, so not removed
                Package 'gnome-panel' is not installed, so not removed
                Package 'gnome-flashback' is not installed, so not removed
                Package 'gnome-audio' is not installed, so not removed
                Package 'gnome-core' is not installed, so not removed
                Package 'gnome-authenticator' is not installed, so not removed
                Package 'gnome-bluetooth-3-common' is not installed, so not removed
                Package 'gnome-bluetooth-sendto' is not installed, so not removed
                Package 'gnome-boxes' is not installed, so not removed
                Package 'gnome-breakout' is not installed, so not removed
                Package 'gnome-browser-connector' is not installed, so not removed
                Package 'gnome-calendar' is not installed, so not removed
                Package 'gnome-contacts' is not installed, so not removed
                Package 'gnome-calls-doc' is not installed, so not removed
                Package 'gnome-chess' is not installed, so not removed
                Package 'gnome-brave-icon-theme' is not installed, so not removed
                Package 'gnome-colors-common' is not installed, so not removed
                Package 'gnome-colors' is not installed, so not removed
                Package 'gnome-dust-icon-theme' is not installed, so not removed
                Package 'gnome-illustrious-icon-theme' is not installed, so not removed
                Package 'gnome-noble-icon-theme' is not installed, so not removed
                Package 'gnome-wine-icon-theme' is not installed, so not removed
                Package 'gnome-wise-icon-theme' is not installed, so not removed
                Package 'gnome-commander' is not installed, so not removed
                Package 'gnome-commander-data' is not installed, so not removed
                Package 'gnome-console' is not installed, so not removed
                Package 'gnome-control-center-data' is not installed, so not removed
                Package 'gnome-online-accounts' is not installed, so not removed
                Package 'gnome-remote-desktop' is not installed, so not removed
                Package 'gnome-control-center-dev' is not installed, so not removed
                Package 'gnome-decoder' is not installed, so not removed
                Package 'gnome-desktop-3-tests' is not installed, so not removed
                Package 'gnome-extra-icons' is not installed, so not removed
                Package 'gnome-feeds' is not installed, so not removed
                Package 'gnome-firmware' is not installed, so not removed
                Package 'gnome-flashback-common' is not installed, so not removed
                Package 'gnome-session-flashback' is not installed, so not removed
                Package 'gnome-hwp-support' is not installed, so not removed
                Package 'gnome-icon-theme-nuovo' is not installed, so not removed
                Package 'gnome-icon-theme-yasis' is not installed, so not removed
                Package 'gnome-keyring-pkcs11' is not installed, so not removed
                Package 'gnome-keysign' is not installed, so not removed
                Package 'gnome-kiosk' is not installed, so not removed
                Package 'gnome-kiosk-search-appliance' is not installed, so not removed
                Package 'gnome-kiosk-script-session' is not installed, so not removed
                Package 'gnome-klotski' is not installed, so not removed
                Package 'gnome-mastermind' is not installed, so not removed
                Package 'gnome-model-thumbnailer' is not installed, so not removed
                Package 'gnome-mousetrap' is not installed, so not removed
                Package 'gnome-multi-writer' is not installed, so not removed
                Package 'gnome-music' is not installed, so not removed
                Package 'gnome-nds-thumbnailer' is not installed, so not removed
                Package 'gnome-nettool' is not installed, so not removed
                Package 'gnome-network-displays' is not installed, so not removed
                Package 'gnome-packagekit-common' is not installed, so not removed
                Package 'gnome-pass-search-provider' is not installed, so not removed
                Package 'gnome-photos' is not installed, so not removed
                Package 'gnome-photos-tests' is not installed, so not removed
                Package 'gnome-pie' is not installed, so not removed
                Package 'gnome-podcasts' is not installed, so not removed
                Package 'gnome-settings-daemon-common' is not installed, so not removed
                Package 'gnome-recipes' is not installed, so not removed
                Package 'gnome-recipes-data' is not installed, so not removed
                Package 'gnome-robots' is not installed, so not removed
                Package 'gnome-screensaver-flags' is not installed, so not removed
                Package 'gnome-session-xsession' is not installed, so not removed
                Package 'gnome-settings-daemon-dev' is not installed, so not removed
                Package 'gnome-shell-common' is not installed, so not removed
                Package 'gnome-shell-extension-dash-to-panel' is not installed, so not removed
                Package 'gnome-shell-extension-dashtodock' is not installed, so not removed
                Package 'gnome-shell-extension-desktop-icons-ng' is not installed, so not removed
                Package 'gnome-shell-extensions' is not installed, so not removed
                Package 'gnome-shell-extension-prefs' is not installed, so not removed
                Package 'gnome-shell-extension-arc-menu' is not installed, so not removed
                Package 'gnome-shell-extension-autohidetopbar' is not installed, so not removed
                Package 'gnome-shell-extension-blur-my-shell' is not installed, so not removed
                Package 'gnome-shell-extension-caffeine' is not installed, so not removed
                Package 'gnome-shell-extension-manager' is not installed, so not removed
                Package 'gnome-shell-extension-easyscreencast' is not installed, so not removed
                Package 'gnome-shell-extension-flypie' is not installed, so not removed
                Package 'gnome-shell-extension-freon' is not installed, so not removed
                Package 'gnome-shell-extension-gsconnect' is not installed, so not removed
                Package 'gnome-shell-extension-gsconnect-browsers' is not installed, so not removed
                Package 'gnome-shell-extension-hamster' is not installed, so not removed
                Package 'gnome-shell-extension-hard-disk-led' is not installed, so not removed
                Package 'gnome-shell-extension-hide-activities' is not installed, so not removed
                Package 'gnome-shell-extension-impatience' is not installed, so not removed
                Package 'gnome-shell-extension-kimpanel' is not installed, so not removed
                Package 'gnome-shell-extension-no-annoyance' is not installed, so not removed
                Package 'gnome-shell-extension-runcat' is not installed, so not removed
                Package 'gnome-shell-extension-shortcuts' is not installed, so not removed
                Package 'gnome-shell-extension-tiling-assistant' is not installed, so not removed
                Package 'gnome-shell-extension-weather' is not installed, so not removed
                Package 'gnome-classic' is not installed, so not removed
                Package 'gnome-shell-extension-apps-menu' is not installed, so not removed
                Package 'gnome-shell-extension-places-menu' is not installed, so not removed
                Package 'gnome-shell-extension-launch-new-instance' is not installed, so not removed
                Package 'gnome-shell-extension-window-list' is not installed, so not removed
                Package 'gnome-classic-xsession' is not installed, so not removed
                Package 'gnome-shell-extensions-common' is not installed, so not removed
                Package 'gnome-shell-extension-auto-move-windows' is not installed, so not removed
                Package 'gnome-shell-extension-drive-menu' is not installed, so not removed
                Package 'gnome-shell-extension-light-style' is not installed, so not removed
                Package 'gnome-shell-extension-native-window-placement' is not installed, so not removed
                Package 'gnome-shell-extension-screenshot-window-sizer' is not installed, so not removed
                Package 'gnome-shell-extension-status-icons' is not installed, so not removed
                Package 'gnome-shell-extension-system-monitor' is not installed, so not removed
                Package 'gnome-shell-extension-user-theme' is not installed, so not removed
                Package 'gnome-shell-extension-windows-navigator' is not installed, so not removed
                Package 'gnome-shell-extension-workspace-indicator' is not installed, so not removed
                Package 'gnome-shell-extensions-extra' is not installed, so not removed
                Package 'gnome-tweaks' is not installed, so not removed
                Package 'gnome-shell-pomodoro' is not installed, so not removed
                Package 'gnome-shell-pomodoro-data' is not installed, so not removed
                Package 'gnome-software-plugin-deb' is not installed, so not removed
                Package 'gnome-software-common' is not installed, so not removed
                Package 'gnome-software-plugin-fwupd' is not installed, so not removed
                Package 'gnome-software-plugin-flatpak' is not installed, so not removed
                Package 'gnome-software-plugin-snap' is not installed, so not removed
                Package 'gnome-software-dev' is not installed, so not removed
                Package 'gnome-software-doc' is not installed, so not removed
                Package 'gnome-sushi' is not installed, so not removed
                Package 'gnome-system-tools' is not installed, so not removed
                Package 'gnome-taquin' is not installed, so not removed
                Package 'gnome-terminal-data' is not installed, so not removed
                Package 'gnome-tetravex' is not installed, so not removed
                Package 'gnome-tour' is not installed, so not removed
                Package 'gnome-usage' is not installed, so not removed
                Package 'gnome-video-effects-dev' is not installed, so not removed
                Package 'gnome-video-trimmer' is not installed, so not removed
                Package 'gnome-weather' is not installed, so not removed
                Package 'gnome-shell-extension-gpaste' is not installed, so not removed
                Package 'gnome-api-docs' is not installed, so not removed
                Package 'gnome-devel' is not installed, so not removed
                Package 'gnome-platform-devel' is not installed, so not removed
                Package 'gnome-theme-gilouche' is not installed, so not removed
                Package 'gnome-panel-control' is not installed, so not removed
                Package 'gnome-icon-theme-suede' is not installed, so not removed
                Package 'gnome-panel-control-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-plugins-ugly' is not installed, so not removed
                Package 'gstreamer1.0-pipewire' is not installed, so not removed
                Package 'gstreamer1.0-pulseaudio' is not installed, so not removed
                Package 'gstreamer1.0-tools' is not installed, so not removed
                Package 'gstreamer1.0-clutter-3.0' is not installed, so not removed
                Package 'gstreamer1.0-nice' is not installed, so not removed
                Package 'gstreamer1.0-gl' is not installed, so not removed
                Package 'gstreamer1.0-gtk3' is not installed, so not removed
                Package 'gstreamer1.0-gtk4' is not installed, so not removed
                Package 'gstreamer1.0-libcamera' is not installed, so not removed
                Package 'gstreamer1.0-opencv' is not installed, so not removed
                Package 'gstreamer1.0-plugins-bad-apps' is not installed, so not removed
                Package 'gstreamer1.0-wpe' is not installed, so not removed
                Package 'gstreamer1.0-plugins-base-apps' is not installed, so not removed
                Package 'gstreamer1.0-espeak' is not installed, so not removed
                Package 'gstreamer1.0-qt5' is not installed, so not removed
                Package 'gstreamer1.0-qt6' is not installed, so not removed
                Package 'gstreamer1.0-plugins-rtp' is not installed, so not removed
                Package 'gstreamer1.0-python3-plugin-loader' is not installed, so not removed
                Package 'gstreamer1.0-rtsp' is not installed, so not removed
                Package 'gstreamer1.0-vaapi' is not installed, so not removed
                Package 'gstreamer1.0-packagekit' is not installed, so not removed
                Package 'gstreamer1.0-pocketsphinx' is not installed, so not removed
                Package 'gstreamer1.0-adapter-pulseeffects' is not installed, so not removed
                Package 'gstreamer1.0-autogain-pulseeffects' is not installed, so not removed
                Package 'gstreamer1.0-convolver-pulseeffects' is not installed, so not removed
                Package 'gstreamer1.0-crystalizer-pulseeffects' is not installed, so not removed
                Package 'gstreamer1.0-fdkaac' is not installed, so not removed
                Package 'gstreamer1.0-alsa-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-gl-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-libcamera-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-opencv-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-pipewire-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-pispconvert' is not installed, so not removed
                Package 'gstreamer1.0-pispconvert-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-plugins-bad-apps-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-plugins-bad-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-plugins-base-apps-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-plugins-base-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-wpe-dbgsym' is not installed, so not removed
                Package 'gstreamer1.0-x-dbgsym' is not installed, so not removed
                Package 'gtk2-engines-murrine' is not installed, so not removed
                Package 'gtkmm-documentation' is not installed, so not removed
                Package 'gtkwave' is not installed, so not removed
                Package 'gtkatlantic' is not installed, so not removed
                Package 'gtkballs' is not installed, so not removed
                Package 'gtklp' is not installed, so not removed
                Package 'gtk-3-examples' is not installed, so not removed
                Package 'gtk-chtheme' is not installed, so not removed
                Package 'gtk-doc-tools' is not installed, so not removed
                Package 'gtk-im-libthai' is not installed, so not removed
                Package 'gtk3-im-libthai' is not installed, so not removed
                Package 'gtk-layer-shell-doc' is not installed, so not removed
                Package 'gtk-layer-shell-examples' is not installed, so not removed
                Package 'gtk-meshtastic-client' is not installed, so not removed
                Package 'gtk-session-lock-examples' is not installed, so not removed
                Package 'gtk-theme-switch' is not installed, so not removed
                Package 'gtk2-engines-aurora' is not installed, so not removed
                Package 'gtk2hs-buildtools' is not installed, so not removed
                Package 'gtk3-nocsd' is not installed, so not removed
                Package 'gtk-4-examples' is not installed, so not removed
                Package 'gtk-4-tests' is not installed, so not removed
                Package 'gtk4-layer-shell-doc' is not installed, so not removed
                Package 'gtk4-layer-shell-examples' is not installed, so not removed
                Package 'gtkam' is not installed, so not removed
                Package 'gtkcrypto' is not installed, so not removed
                Package 'gtkgreet' is not installed, so not removed
                Package 'gtkhash' is not installed, so not removed
                Package 'gtklock' is not installed, so not removed
                Package 'gtklock-playerctl-module' is not installed, so not removed
                Package 'gtklock-userinfo-module' is not installed, so not removed
                Package 'gtkman' is not installed, so not removed
                Package 'gtkterm' is not installed, so not removed
                Package 'gtk2-engines-qtcurve' is not installed, so not removed
                Package 'gtkmorph-example' is not installed, so not removed
                Package 'gtk-3-examples-dbgsym' is not installed, so not removed
                Package 'gtk-nop-dbgsym' is not installed, so not removed
                Package 'gtk2-engines-clearlookspix' is not installed, so not removed
                Package 'gtk2-engines-clearlookspix-dbgsym' is not installed, so not removed
                Package 'gtk2-engines-pixbuf-dbgsym' is not installed, so not removed
                Package 'gtk2-engines-pixflat-dbgsym' is not installed, so not removed
                Package 'lxc' is not installed, so not removed
                Package 'lxd' is not installed, so not removed
                Package 'lxqt-policykit' is not installed, so not removed
                Package 'lxi-tools' is not installed, so not removed
                Package 'lxc-dev' is not installed, so not removed
                Package 'lxqt-menu-data' is not installed, so not removed
                Package 'lxcfs' is not installed, so not removed
                Package 'lxd-tools' is not installed, so not removed
                Package 'lxqt-build-tools' is not installed, so not removed
                Package 'lx-gdb' is not installed, so not removed
                Package 'lxc-templates' is not installed, so not removed
                Package 'lxc-tests' is not installed, so not removed
                Package 'lxctl' is not installed, so not removed
                Package 'lxd-client' is not installed, so not removed
                Package 'lxd-agent' is not installed, so not removed
                Package 'lxd-migrate' is not installed, so not removed
                Package 'lxlock' is not installed, so not removed
                Package 'lxlauncher' is not installed, so not removed
                Package 'lxinput' is not installed, so not removed
                Package 'lxmusic' is not installed, so not removed
                Package 'lxdm' is not installed, so not removed
                Package 'lxhotkey-plugin-openbox' is not installed, so not removed
                Package 'lxhotkey-data' is not installed, so not removed
                Package 'lxhotkey-dev' is not installed, so not removed
                Package 'lximage-qt' is not installed, so not removed
                Package 'lximage-qt-l10n' is not installed, so not removed
                Package 'lxpanel-dev' is not installed, so not removed
                Package 'lxqt-about' is not installed, so not removed
                Package 'lxqt-about-l10n' is not installed, so not removed
                Package 'lxqt-qtplugin' is not installed, so not removed
                Package 'lxqt-admin' is not installed, so not removed
                Package 'lxqt-admin-l10n' is not installed, so not removed
                Package 'lxqt-archiver' is not installed, so not removed
                Package 'lxqt-archiver-l10n' is not installed, so not removed
                Package 'lxqt-branding-debian' is not installed, so not removed
                Package 'lxqt-theme-debian' is not installed, so not removed
                Package 'lxqt-system-theme' is not installed, so not removed
                Package 'lxqt-build-tools-qt5' is not installed, so not removed
                Package 'lxqt-config' is not installed, so not removed
                Package 'lxqt-config-l10n' is not installed, so not removed
                Package 'lxqt-powermanagement' is not installed, so not removed
                Package 'lxqt-session' is not installed, so not removed
                Package 'lxqt' is not installed, so not removed
                Package 'lxqt-core' is not installed, so not removed
                Package 'lxqt-globalkeys' is not installed, so not removed
                Package 'lxqt-globalkeys-l10n' is not installed, so not removed
                Package 'lxqt-panel' is not installed, so not removed
                Package 'lxqt-openssh-askpass' is not installed, so not removed
                Package 'lxqt-sudo' is not installed, so not removed
                Package 'lxqt-themes' is not installed, so not removed
                Package 'lxqt-notificationd' is not installed, so not removed
                Package 'lxqt-runner' is not installed, so not removed
                Package 'lxqt-notificationd-l10n' is not installed, so not removed
                Package 'lxqt-openssh-askpass-l10n' is not installed, so not removed
                Package 'lxqt-panel-l10n' is not installed, so not removed
                Package 'lxqt-policykit-l10n' is not installed, so not removed
                Package 'lxqt-powermanagement-l10n' is not installed, so not removed
                Package 'lxqt-qt5plugin' is not installed, so not removed
                Package 'lxqt-runner-l10n' is not installed, so not removed
                Package 'lxqt-session-l10n' is not installed, so not removed
                Package 'lxqt-sudo-l10n' is not installed, so not removed
                Package 'lxsession-default-apps' is not installed, so not removed
                Package 'lxpanel-pi' is not installed, so not removed
                Package 'lxpanel-pi-dbgsym' is not installed, so not removed
                Package 'lxpanel-pi-dev' is not installed, so not removed
                Package 'lxpanel-pi-dev-dbgsym' is not installed, so not removed
                Package 'lxpolkit-dbgsym' is not installed, so not removed
                Package 'lxsession-dbgsym' is not installed, so not removed
                Package 'lxsession-default-apps-dbgsym' is not installed, so not removed
                Package 'lxsession-edit-dbgsym' is not installed, so not removed
                Package 'lxsession-logout-dbgsym' is not installed, so not removed
                Package 'lxtask-dbgsym' is not installed, so not removed
                Package 'lxterminal-dbgsym' is not installed, so not removed
                Package 'mesa-utils' is not installed, so not removed
                Package 'mesa-common-dev' is not installed, so not removed
                Package 'mesa-opencl-icd' is not installed, so not removed
                Package 'mesa-va-drivers' is not installed, so not removed
                Package 'mesaflash' is not installed, so not removed
                Package 'mesa-drm-shim' is not installed, so not removed
                Package 'mesa-teflon-delegate' is not installed, so not removed
                Package 'mesa-vulkan-drivers' is not installed, so not removed
                Package 'mesa-utils-bin' is not installed, so not removed
                Package 'mesa-drm-shim-dbgsym' is not installed, so not removed
                Package 'mesa-libgallium-dbgsym' is not installed, so not removed
                Package 'mesa-opencl-icd-dbgsym' is not installed, so not removed
                Package 'mesa-teflon-delegate-dbgsym' is not installed, so not removed
                Package 'mesa-vulkan-drivers-dbgsym' is not installed, so not removed
                You might want to run 'apt --fix-broken install' to correct these.
                The following packages have unmet dependencies:
                 adwaita-icon-theme : Depends: gtk-update-icon-cache
                                      Depends: hicolor-icon-theme but it is not going to be installed
                 alacarte : Depends: gnome-menus (>= 3.5.3) but it is not going to be installed
                 evince : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                          Depends: libgtk-3-0t64 (>= 3.22.0) but it is not going to be installed
                 galculator : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                              Depends: libgtk-3-0t64 (>= 3.3.16) but it is not going to be installed
                 gcr : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 gcr4 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 geany : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                         Depends: libgtk-3-0t64 (>= 3.21.5) but it is not going to be installed
                 gir1.2-glib-2.0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                 gir1.2-gtk-3.0 : Depends: libgtk-3-0t64 (>= 3.24.36-2+rpt1) but it is not going to be installed
                 girepository-tools : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                 gui-pkinst : Depends: libglib2.0-0t64 (>= 2.22.0) but it is not going to be installed
                              Depends: libgtk-3-0t64 (>= 3.24) but it is not going to be installed
                 gui-updater : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                 gvfs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                 gvfs-backends : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                                 Recommends: gnome-keyring or
                                             kwalletmanager but it is not going to be installed
                                 Recommends: wsdd but it is not installable
                 gvfs-common : Depends: desktop-file-utils
                 gvfs-daemons : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                 gvfs-fuse : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                 gvfs-libs : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                 libadwaita-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libappstream5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libatk1.0-0t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libatkmm-1.6-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                 libavahi-glib1 : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                 libavcodec61 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                 libayatana-ido3-0.4-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                         Depends: libgtk-3-0t64 (>= 3.21.4) but it is not going to be installed
                 libayatana-indicator3-7 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libbabeltrace1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                 libcairo-gobject2 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                 libcamera0.5 : Depends: libcamera-ipa (= 0.5.2+rpt20250903-1~bpo12+1) but 0.7.1+rpt20260609-1 is to be installed
                 libcloudproviders0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                 libegl-mesa0 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
                 libevdocument3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libevview3-3t64 : Depends: gstreamer1.0-plugins-base but it is not going to be installed
                 libfm-extra4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libfm-gtk3-4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libfm-modules : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                 Depends: libgtk-3-0t64 (>= 3.0.0) but it is not going to be installed
                 libfm4t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                             Depends: lxmenu-data but it is not going to be installed
                 libgbm1 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
                 libgck-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libgck-2-2 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                 libgcr-4-4 : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                 libgcr-base-3-1 : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                 libgcr-ui-3-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libgio-2.0-dev : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                 libgio-2.0-dev-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                 libgirepository-1.0-1 : Depends: libglib2.0-0t64 (>= 2.82.0) but it is not going to be installed
                 libgirepository-2.0-0 : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                 libglib2.0-bin : Depends: libglib2.0-0t64 (= 2.84.4-3~deb13u3) but it is not going to be installed
                 libglibmm-2.4-1t64 : Depends: libglib2.0-0t64 (>= 2.62.0) but it is not going to be installed
                 libglx-mesa0 : Depends: mesa-libgallium (= 25.0.7-2+rpt4) but it is not going to be installed
                 libgnome-desktop-3-20t64 : Depends: gnome-desktop3-data (>= 44.3-3) but it is not going to be installed
                                            Depends: gnome-desktop3-data (< 45~) but it is not going to be installed
                                            Depends: libgtk-3-0t64 (>= 3.9.10) but it is not going to be installed
                 libgoa-1.0-0b : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                 libgraphene-1.0-0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                 libgspell-1-3 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                 Depends: libgtk-3-0t64 (>= 3.20) but it is not going to be installed
                 libgstreamer-gl1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                        Recommends: gstreamer1.0-gl but it is not going to be installed
                 libgstreamer-plugins-bad1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                 libgstreamer-plugins-base1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                                                  Recommends: gstreamer1.0-plugins-base but it is not going to be installed
                 libgstreamer1.0-0 : Depends: libglib2.0-0t64 (>= 2.81.1) but it is not going to be installed
                 libgtk-3-0 : Depends: hicolor-icon-theme but it is not going to be installed
                              Recommends: libgtk-3-bin
                 libgtk-4-1 : Depends: hicolor-icon-theme but it is not going to be installed
                              Recommends: libgtk-4-bin
                              Recommends: libgtk-4-media-gstreamer
                 libgtk-layer-shell0 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
                                       Depends: libgtk-3-0t64 (>= 3.24.48) but it is not going to be installed
                 libgtk2.0-0 : Depends: hicolor-icon-theme but it is not going to be installed
                               Recommends: libgail-common but it is not going to be installed
                 libgtk2.0-bin : Depends: gtk-update-icon-cache
                 libgtkmm-3.0-1t64 : Depends: libglib2.0-0t64 (>= 2.42.0) but it is not going to be installed
                                     Depends: libgtk-3-0t64 (>= 3.24.0) but it is not going to be installed
                 libgtksourceview-4-0 : Depends: libglib2.0-0t64 (>= 2.48.0) but it is not going to be installed
                 libgxps2t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libhandy-1-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                                Depends: libgtk-3-0t64 (>= 3.23.1) but it is not going to be installed
                 libharfbuzz-gobject0 : Depends: libglib2.0-0t64 (>= 2.14.0) but it is not going to be installed
                 libharfbuzz0b : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                 libinput-tools : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                                  Depends: libgtk-3-0t64 (>= 3.19.12) but it is not going to be installed
                 libinput10 : Depends: libmtdev1t64 (>= 1.1.0) but it is not going to be installed
                 libjavascriptcoregtk-4.1-0 : Depends: libglib2.0-0t64 (>= 2.66.0) but it is not going to be installed
                 libkeybinder-3.0-0 : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                 libmate-desktop-2-17t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libmenu-cache-bin : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                 libmousepad0 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                 libmsgraph-1-1 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libnetplan1 : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                 libnm0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
                 libnma0 : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
                 libpango-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libpangocairo-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libpangoft2-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libpangomm-1.4-1v5 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                 libpangoxft-1.0-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libpeas-1.0-0 : Depends: libglib2.0-0t64 (>= 2.44.0) but it is not going to be installed
                 libpipewire-0.3-modules : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                 libpoppler-glib8t64 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libproxy1v5 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libqt5ct-common1.8 : Depends: libqt5core5t64 (>= 5.9~) but it is not going to be installed
                                      Depends: libqt5gui5t64 (>= 5.9~) but it is not going to be installed or
                                               libqt5gui5-gles (>= 5.9~) but it is not going to be installed
                 libqt6core6t64 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                 libqt6gui6 : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                              Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
                              Recommends: qt6-svg-plugins but it is not going to be installed
                              Recommends: qt6-wayland but it is not going to be installed
                 libqt6network6 : Depends: libglib2.0-0t64 (>= 2.46.0) but it is not going to be installed
                 libqt6opengl6 : Depends: libmtdev1t64 (>= 1.0.8) but it is not going to be installed
                 libsane1 : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                 libspa-0.2-bluetooth : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                 libudev-dev : Depends: libudev1 (= 257.13-1~deb13u1) but 252.39-1~deb12u2 is to be installed
                 libvolume-key1 : Depends: libglib2.0-0t64 (>= 2.18.0) but it is not going to be installed
                 libvte-2.91-0 : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
                 libwacom9 : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                 libwebkit2gtk-4.1-0 : Depends: gstreamer1.0-plugins-base but it is not going to be installed
                                       Depends: gstreamer1.0-plugins-good but it is not going to be installed
                                       Depends: libgtk-3-0t64 (>= 3.23.0) but it is not going to be installed
                                       Recommends: gstreamer1.0-libav but it is not going to be installed
                                       Recommends: gstreamer1.0-plugins-bad but it is not going to be installed
                 libwnck-3-0 : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 libxfce4ui-2-0 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                 libxfce4util7 : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                                 Recommends: libxfce4util-bin but it is not going to be installed
                 libxfconf-0-3 : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                 libxmlb2 : Depends: libglib2.0-0t64 (>= 2.54.0) but it is not going to be installed
                 lp-connection-editor : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 mate-polkit : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                               Depends: libgtk-3-0t64 (>= 3.16.2) but it is not going to be installed
                 mousepad : Depends: libglib2.0-0t64 (>= 2.38.0) but it is not going to be installed
                            Depends: libgtk-3-0t64 (>= 3.13.7) but it is not going to be installed
                 netplan-generator : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                 netplan.io : Depends: libglib2.0-0t64 (>= 2.70.0) but it is not going to be installed
                              Recommends: python3-rich but it is not going to be installed
                 network-manager : Depends: libglib2.0-0t64 (>= 2.68.0) but it is not going to be installed
                                   Recommends: network-manager-l10n but it is not going to be installed
                 notification-daemon : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 obconf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                 openbox-lxde-session : Depends: lxde-common but it is not going to be installed
                                        Depends: lxsession but it is not going to be installed
                 openssh-sftp-server : Depends: openssh-client (= 1:9.2p1-2+deb12u10)
                 pango1.0-tools : Depends: libglib2.0-0t64 (>= 2.80) but it is not going to be installed
                 pcmanfm : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                           Recommends: lxde-icon-theme but it is not going to be installed or
                                       gnome-icon-theme but it is not going to be installed or
                                       oxygen-icon-theme but it is not going to be installed or
                                       tango-icon-theme but it is not going to be installed
                 pi-package : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 pi-package-session : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 piclone : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                 pipanel : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                 pishutdown : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                 piwiz : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                 pixflat-theme : Depends: gtk2-engines-pixbuf but it is not going to be installed
                                 Depends: gtk2-engines-pixflat but it is not going to be installed
                 pplug-ejecter-data : Depends: gtk-update-icon-cache
                 pplug-power-data : Depends: gtk-update-icon-cache
                 pplug-updater-data : Depends: gtk-update-icon-cache
                 python3-dbus : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                 python3-gi : Depends: libglib2.0-0t64 (>= 2.78.0) but it is not going to be installed
                 python3-pyqt5 : Depends: libqt5printsupport5 (>= 5.15)
                 qt5-gtk-platformtheme : Depends: libglib2.0-0t64 (>= 2.34.0) but it is not going to be installed
                                         Depends: libqt5core5t64 (>= 5.15.1) but it is not going to be installed
                                         Depends: libqt5dbus5t64 (>= 5.14.1) but it is not going to be installed
                                         Depends: libqt5gui5t64 (>= 5.14.1) but it is not going to be installed or
                                                  libqt5gui5-gles (>= 5.14.1) but it is not going to be installed
                                         Depends: qtbase-abi-5-15-15
                 qt6-gtk-platformtheme : Depends: gnome-themes-extra-data but it is not going to be installed
                 raindrop : Depends: libglib2.0-0t64 (>= 2.40.0) but it is not going to be installed
                            Depends: lightdm but it is not going to be installed
                 rasputin : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                 rc-gui : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                 rp-bookshelf : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                 rp-prefapps : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                 rpi-chromium-mods : Depends: chromium (>= 92) but it is not going to be installed
                 sudopwd : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                 vdpau-driver-all : Depends: mesa-vdpau-drivers but it is not going to be installed
                 wayfire : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                 wf-panel-pi : Depends: libglib2.0-0t64 (>= 2.74.0) but it is not going to be installed
                               Recommends: wfplug-clock but it is not going to be installed
                 wfplug-batt : Depends: libglib2.0-0t64 (>= 2.16.0) but it is not going to be installed
                 wfplug-bluetooth : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                 wfplug-connect : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
                 wfplug-cpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                 wfplug-cputemp : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                 wfplug-ejecter : Depends: libglib2.0-0t64 (>= 2.28.0) but it is not going to be installed
                 wfplug-gpu : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                 wfplug-menu : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                 wfplug-netman : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 wfplug-power : Depends: libglib2.0-0t64 (>= 2.36.0) but it is not going to be installed
                 wfplug-squeek : Depends: libglib2.0-0t64 (>= 2.26.0) but it is not going to be installed
                 wfplug-updater : Depends: libglib2.0-0t64 (>= 2.32.0) but it is not going to be installed
                 wfplug-volumepulse : Depends: libglib2.0-0t64 (>= 2.30.0) but it is not going to be installed
                 xarchiver : Depends: libglib2.0-0t64 (>= 2.76.0) but it is not going to be installed
                             Recommends: 7zip but it is not going to be installed
                 xdg-desktop-portal-gtk : Depends: libglib2.0-0t64 (>= 2.83.0) but it is not going to be installed
                 xfconf : Depends: libglib2.0-0t64 (>= 2.56.0) but it is not going to be installed
                 xorg : Depends: xserver-xorg (>= 1:7.7+24+deb13u1) but it is not going to be installed
                        Depends: xterm or
                                 x-terminal-emulator
                 xorgxrdp : Depends: xorg-input-abi-24
                            Depends: xorg-video-abi-25
                            Depends: xserver-xorg-core (>= 2:21.1.1) but it is not going to be installed
                 xwayland : Depends: xserver-common but it is not going to be installed
                 zenity : Depends: libglib2.0-0t64 (>= 2.80.0) but it is not going to be installed
                 zenoty : Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
                #240
                @Hadebe
                Installier das Ding komplett neu.
                Ist eh die Empfehlung von RaspberryOS.
                In-line-upgrades sind nicht vorgesehen.
                Und lass dann den Desktop-Mumpitz direkt vom System. Installier die Lite-Version von RaspberryOS 13 'Trixie'.
                • H Offline
                  Hadebe
                  #241
                  Also komplette Neuinstallation - gar nicht schön, aber wenn es nicht anders geht.
                  Dann darf die Anleitung nur für Installationen ohne Desktop genutzt werden?
                  Thomas BraunT fuzzy1955F 2 Antworten Letzte Antwort
                  • H Hadebe
                    #242
                    @Hadebe sagte:
                    Die Anleitung setzt natürlich ein ohne Overhead aufgesetztes System voraus.
                    Damit nämlich genau solche Situationen, in den denen Pakete anders gebaut werden und damit andere Abhängigkeiten einfordern gar nicht erst berücksichtigt werden müssen.
                    Das ganze Abhängigkeits-Knäuel bei dir basiert nur auf Desktop-relevanten Paketen.
                    Kein Desktop = Kein Ärger damit.
                    Neben den weiteren Gründen, kein Desktop-Geraffel mitzuschleppen.
                    • H Offline
                      Hadebe
                      #243
                      Statt Neuinstallation - KI fragen, schrottiger als Schrott ging ja nicht
                      Vielleicht hilft es dem einen oder anderen weiter...
                      Ich habe natürlich eine Neuinstallation gescheut und als letzten Versuch die KI befragt. Mit dem Input meiner Posts und den Antworten von ThomasBraun habe ich jetzt gut eine Stunde mit der KI gechattet. Meine halb Bookworm halb Trixie Installation konnte tatsächlich repariert werden - unter konsequenter Löschung aller Pakete aus dem Desktop - iobroker läuft wieder, aber nun auf Trixie.
                      Für mich bestimmt deutlich schneller als eine Neuinstallation.
                      Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                      • H Hadebe
                        #244
                        @Hadebe
                        Da wage ich die ziemlich sichere Prognose, das wird dir in nächster Zeit wieder auf die Füße fallen.
                        Wie schaut ein
                        iog diag
                        für die Möhre jetzt aus?
                        • H Hadebe
                          #245
                          @Hadebe sagte:
                          Naja, Neuinstallation inkl. Rückspielen deines Backups dauert auch nicht länger. Aber dafür wäre die Basis besser.
                          • H Offline
                            Hadebe
                            schrieb am zuletzt editiert von Hadebe
                            #246
                            Ich bin weit entfernt von einem Linux Experten und mit Hand am Arm geht es besser. Check mal den Output von iob diag, bin gespannt was ich mit KI gebastelt hab:
                            ```bash
                            Script v.2026-06-01
                            *** BASE SYSTEM ***
                            Operating System: Debian GNU/Linux 13 (trixie)
                             Static hostname: raspi01
                                   Icon name: computer
                                      Kernel: Linux 6.18.33+rpt-rpi-2712
                                Architecture: arm64
                            OS is similar to:
                            Model           : Raspberry Pi 5 Model B Rev 1.0
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : 64bit
                            System was installed 921 days ago (on 2023-12-05).
                            Systemuptime and Load:
                             00:02:10 up 7 min,  1 user,  load average: 0.79, 0.85, 0.54
                            CPU threads     : 4
                            *** LIFE CYCLE STATUS ***
                            Operating System is the current Debian stable version codenamed 'trixie'!
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            *** TIME AND TIMEZONES ***
                                           Local time: Sun 2026-06-14 00:02:10 CEST
                                       Universal time: Sat 2026-06-13 22:02:10 UTC
                                             RTC time: Sat 2026-06-13 22:02:10
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            pi
                            HOME=/home/pi
                            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                            iobroker
                            HOME=/home/iobroker
                            *** DISPLAY-SERVER SETUP ***
                            Display-Server:         Unknown
                            Display-Manager:        * lightdm.service - Light Display Manager
                            Desktop:
                            Session:                tty
                            Boot Target:            multi-user.target
                            *** MEMORY ***
                            Mem:            8.5G        4.7G        2.1G         35M        1.8G        3.8G
                            Swap:           209M          0B        209M
                            Total:          8.7G        4.7G        2.3G
                            Active iob-Instances:   36
                                     8062 M total memory
                                     4446 M used memory
                                     4259 M active memory
                                     1235 M inactive memory
                                     2034 M free memory
                                      124 M buffer memory
                                     1578 M swap cache
                                      199 M total swap
                                        0 M used swap
                                      199 M free swap
                            top - 00:02:13 up 7 min,  1 user,  load average: 0.79, 0.85, 0.54
                            Tasks: 225 total,   1 running, 224 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 13.6 us,  4.5 sy,  0.0 ni, 81.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   8062.4 total,   2033.5 free,   4446.3 used,   1703.1 buff/cache
                            MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3616.0 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** DMESG CRITICAL ERRORS ***
                            No critical errors detected
                            *** FILESYSTEM ***
                            udev           devtmpfs  3.9G     0  3.9G   0% /dev
                            tmpfs          tmpfs     1.6G   16M  1.6G   1% /run
                            /dev/mmcblk0p2 ext4       58G   17G   39G  30% /
                            tmpfs          tmpfs     4.0G  9.4M  4.0G   1% /dev/shm
                            tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                            tmpfs          tmpfs     4.0G  8.8M  4.0G   1% /tmp
                            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                            /dev/mmcblk0p1 vfat      510M   90M  421M  18% /boot/firmware
                            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
                            tmpfs          tmpfs     807M  304K  806M   1% /run/user/1000
                            Messages concerning filesystems in dmesg:
                            [Sat Jun 13 23:54:24 2026] EXT4-fs (mmcblk0p2): mounted filesystem 4aa56689-dcb4-4759-90e6-179beae559ac ro with ordered data mode. Quota mode: none.
                            [Sat Jun 13 23:54:26 2026] EXT4-fs (mmcblk0p2): re-mounted 4aa56689-dcb4-4759-90e6-179beae559ac r/w.
                            Show mounted filesystems:
                            TARGET           SOURCE         FSTYPE OPTIONS
                            /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            1.4G    /var/
                            789M    /var/log
                            740M    /var/log/journal/50f983a78ca74122882bca60072380ca
                            220M    /var/lib
                            Archived and active journals take up 748.7M in the file system.
                            /opt/iobroker/backups:
                            40M     /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            859M    /opt/iobroker/iobroker-data/
                            302M    /opt/iobroker/iobroker-data/files
                            268M    /opt/iobroker/iobroker-data/history
                            207M    /opt/iobroker/iobroker-data/backup-objects
                            47M     /opt/iobroker/iobroker-data/files/admin.admin
                            57M     /opt/iobroker/iobroker-data/objects.jsonl
                            30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
                            27M     /opt/iobroker/iobroker-data/states.jsonl
                            11M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js
                            9.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.f592ece1.js
                            USB-Devices by-id:
                            USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                            please always prefer the links 'by-id':
                            /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2227875-if00
                            *** ZigBee Settings ***
                            ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                            Zigbee Network Settings on your coordinator / in nvbackup are:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            === ZigBee Port Overview ===
                            Instance        Configured Port                     Available by-id Port                Status
                            zigbee.0        ..._ConBee_II_DE2227875-if00        ..._ConBee_II_DE2227875-if00        ✓ Matching
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v22.22.3
                            /usr/bin/node           v22.22.3
                            /usr/bin/npm            10.9.8
                            /usr/bin/npx            10.9.8
                            ✓ Node.js installation is correct
                            nodejs:
                              Installed: 22.22.3-1nodesource1
                              Candidate: 22.22.3-1nodesource1
                              Version table:
                             *** 22.22.3-1nodesource1 100
                                 20.19.2+dfsg-1+deb13u2 500
                                    500 http://deb.debian.org/debian trixie/main arm64 Packages
                                    500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
                            No problems detected
                            Errors in npm tree: 0
                            No known Vulnerabilities detected!
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            raspi01             raspi01 (version: 7.1.2, hostname: raspi01       , alive, uptime: 472)
                            Core adapters versions
                            js-controller:  7.1.2
                            admin:          7.9.1
                            javascript:     9.2.4
                            nodejs modules from github:     1
                            | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : raspi01                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.alexa2.0                 : alexa2                : raspi01                                  - disabled
                              system.adapter.alias-manager.0          : alias-manager         : raspi01                                  - disabled
                            + system.adapter.backitup.0               : backitup              : raspi01                                  -  enabled
                            + system.adapter.cloud.0                  : cloud                 : raspi01                                  -  enabled
                            + system.adapter.daswetter.0              : daswetter             : raspi01                                  -  enabled
                              system.adapter.devices.0                : devices               : raspi01                                  - disabled
                            + system.adapter.discovery.0              : discovery             : raspi01                                  -  enabled
                            + system.adapter.enigma2.0                : enigma2               : raspi01                                  -  enabled
                            + system.adapter.eusec.0                  : eusec                 : raspi01                                  -  enabled
                              system.adapter.flot.0                   : flot                  : raspi01                                  - disabled
                            + system.adapter.fritzdect.0              : fritzdect             : raspi01                                  -  enabled
                            + system.adapter.frontier_silicon.0       : frontier_silicon      : raspi01                                  -  enabled
                            + system.adapter.ham.0                    : ham                   : raspi01                                  -  enabled
                            + system.adapter.hass.0                   : hass                  : raspi01                                  -  enabled, port: 8123
                            + system.adapter.history.0                : history               : raspi01                                  -  enabled
                              system.adapter.homekit-controller.0     : homekit-controller    : raspi01                                  - disabled
                            + system.adapter.hue.0                    : hue                   : raspi01                                  -  enabled, port: 443
                              system.adapter.ical.0                   : ical                  : raspi01                                  -  enabled
                            + system.adapter.influxdb.0               : influxdb              : raspi01                                  -  enabled, port: 8086
                            + system.adapter.influxdb.1               : influxdb              : raspi01                                  -  enabled, port: 8086
                            + system.adapter.influxdb.2               : influxdb              : raspi01                                  -  enabled, port: 8086
                              system.adapter.iot.0                    : iot                   : raspi01                                  - disabled
                            + system.adapter.iqontrol.0               : iqontrol              : raspi01                                  -  enabled
                            + system.adapter.javascript.0             : javascript            : raspi01                                  -  enabled
                              system.adapter.linux-control.0          : linux-control         : raspi01                                  - disabled
                            + system.adapter.logparser.0              : logparser             : raspi01                                  -  enabled
                            + system.adapter.lupusec.0                : lupusec               : raspi01                                  -  enabled
                              system.adapter.mqtt.0                   : mqtt                  : raspi01                                  - disabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.notification-manager.0   : notification-manager  : raspi01                                  -  enabled
                            + system.adapter.panasonic-viera.1        : panasonic-viera       : raspi01                                  -  enabled
                            + system.adapter.pi-hole.0                : pi-hole               : raspi01                                  -  enabled
                            + system.adapter.ping.0                   : ping                  : raspi01                                  -  enabled
                            + system.adapter.pushover.0               : pushover              : raspi01                                  -  enabled
                              system.adapter.roborock.0               : roborock              : raspi01                                  - disabled
                            + system.adapter.rpi2.0                   : rpi2                  : raspi01                                  -  enabled
                            + system.adapter.samsung_tizen.0          : samsung_tizen         : raspi01                                  -  enabled, port: 8002
                              system.adapter.smartcontrol.0           : smartcontrol          : raspi01                                  - disabled
                            + system.adapter.sonos.0                  : sonos                 : raspi01                                  -  enabled
                            + system.adapter.synology.1               : synology              : raspi01                                  -  enabled, port: 45101
                            + system.adapter.synology.2               : synology              : raspi01                                  -  enabled, port: 45001
                              system.adapter.tr-064.0                 : tr-064                : raspi01                                  - disabled
                            + system.adapter.trashschedule.0          : trashschedule         : raspi01                                  -  enabled
                            + system.adapter.tuya.0                   : tuya                  : raspi01                                  -  enabled
                              system.adapter.uv-protect.0             : uv-protect            : raspi01                                  -  enabled
                            + system.adapter.viessmannapi.0           : viessmannapi          : raspi01                                  -  enabled
                              system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi01                                  - disabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi01                                  - disabled
                              system.adapter.vis-metro.0              : vis-metro             : raspi01                                  - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi01                                  - disabled
                              system.adapter.vis-weather.0            : vis-weather           : raspi01                                  - disabled
                              system.adapter.vis.0                    : vis                   : raspi01                                  -  enabled
                            + system.adapter.web.0                    : web                   : raspi01                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.zigbee.0                 : zigbee                : raspi01                                  -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2227875-if00
                            + instance is alive
                            ioBroker-Repositories
                            │ (index) │ name               │ url                                                     │ auto upgrade │
                            │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                            │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                            Active repo(s): Beta (latest)
                            Upgrade policy: none
                            Installed ioBroker-Adapters
                            │ (index) │ id                                    │ name                   │ version  │ upgrade policy │
                            │ 0       │ 'system.adapter.admin'                │ 'admin'                │ '7.9.1'  │ 'none'         │
                            │ 1       │ 'system.adapter.alexa2'               │ 'alexa2'               │ '3.28.1' │ 'none'         │
                            │ 2       │ 'system.adapter.alias-manager'        │ 'alias-manager'        │ '2.1.0'  │ 'none'         │
                            │ 3       │ 'system.adapter.backitup'             │ 'backitup'             │ '3.3.17' │ 'none'         │
                            │ 4       │ 'system.adapter.cloud'                │ 'cloud'                │ '6.1.2'  │ 'none'         │
                            │ 5       │ 'system.adapter.daswetter'            │ 'daswetter'            │ '4.5.4'  │ 'none'         │
                            │ 6       │ 'system.adapter.devices'              │ 'devices'              │ '2.1.1'  │ 'none'         │
                            │ 7       │ 'system.adapter.discovery'            │ 'discovery'            │ '5.0.0'  │ 'none'         │
                            │ 8       │ 'system.adapter.enigma2'              │ 'enigma2'              │ '2.3.0'  │ 'none'         │
                            │ 9       │ 'system.adapter.eusec'                │ 'eusec'                │ '2.0.3'  │ 'none'         │
                            │ 10      │ 'system.adapter.flot'                 │ 'flot'                 │ '1.12.0' │ 'none'         │
                            │ 11      │ 'system.adapter.fritzdect'            │ 'fritzdect'            │ '2.6.2'  │ 'none'         │
                            │ 12      │ 'system.adapter.frontier_silicon'     │ 'frontier_silicon'     │ '0.5.1'  │ 'none'         │
                            │ 13      │ 'system.adapter.ham'                  │ 'ham'                  │ '5.3.1'  │ 'none'         │
                            │ 14      │ 'system.adapter.hass'                 │ 'hass'                 │ '2.1.0'  │ 'none'         │
                            │ 15      │ 'system.adapter.history'              │ 'history'              │ '4.0.0'  │ 'none'         │
                            │ 16      │ 'system.adapter.homekit-controller'   │ 'homekit-controller'   │ '0.5.11' │ 'none'         │
                            │ 17      │ 'system.adapter.hue'                  │ 'hue'                  │ '3.16.2' │ 'none'         │
                            │ 18      │ 'system.adapter.ical'                 │ 'ical'                 │ '1.20.1' │ 'none'         │
                            │ 19      │ 'system.adapter.influxdb'             │ 'influxdb'             │ '4.0.2'  │ 'none'         │
                            │ 20      │ 'system.adapter.iot'                  │ 'iot'                  │ '6.1.3'  │ 'none'         │
                            │ 21      │ 'system.adapter.iqontrol'             │ 'iqontrol'             │ '3.0.0'  │ 'none'         │
                            │ 22      │ 'system.adapter.javascript'           │ 'javascript'           │ '9.2.4'  │ 'none'         │
                            │ 23      │ 'system.adapter.linux-control'        │ 'linux-control'        │ '1.1.5'  │ 'none'         │
                            │ 24      │ 'system.adapter.logparser'            │ 'logparser'            │ '2.5.0'  │ 'none'         │
                            │ 25      │ 'system.adapter.lupusec'              │ 'lupusec'              │ '2.0.8'  │ 'none'         │
                            │ 26      │ 'system.adapter.mqtt'                 │ 'mqtt'                 │ '6.1.4'  │ 'none'         │
                            │ 27      │ 'system.adapter.notification-manager' │ 'notification-manager' │ '1.3.0'  │ 'none'         │
                            │ 28      │ 'system.adapter.panasonic-viera'      │ 'panasonic-viera'      │ '2.1.0'  │ 'none'         │
                            │ 29      │ 'system.adapter.pi-hole'              │ 'pi-hole'              │ '2.0.0'  │ 'none'         │
                            │ 30      │ 'system.adapter.ping'                 │ 'ping'                 │ '2.2.4'  │ 'none'         │
                            │ 31      │ 'system.adapter.pushover'             │ 'pushover'             │ '5.0.0'  │ 'none'         │
                            │ 32      │ 'system.adapter.roborock'             │ 'roborock'             │ '0.7.4'  │ 'none'         │
                            │ 33      │ 'system.adapter.rpi2'                 │ 'rpi2'                 │ '3.0.2'  │ 'none'         │
                            │ 34      │ 'system.adapter.samsung_tizen'        │ 'samsung_tizen'        │ '1.1.0'  │ 'none'         │
                            │ 35      │ 'system.adapter.simple-api'           │ 'simple-api'           │ '3.0.7'  │ 'none'         │
                            │ 36      │ 'system.adapter.smartcontrol'         │ 'smartcontrol'         │ '2.0.1'  │ 'none'         │
                            │ 37      │ 'system.adapter.socketio'             │ 'socketio'             │ '7.1.3'  │ 'none'         │
                            │ 38      │ 'system.adapter.sonos'                │ 'sonos'                │ '3.0.0'  │ 'none'         │
                            │ 39      │ 'system.adapter.synology'             │ 'synology'             │ '3.1.0'  │ 'none'         │
                            │ 40      │ 'system.adapter.tr-064'               │ 'tr-064'               │ '4.3.0'  │ 'none'         │
                            │ 41      │ 'system.adapter.trashschedule'        │ 'trashschedule'        │ '5.3.0'  │ 'none'         │
                            │ 42      │ 'system.adapter.tuya'                 │ 'tuya'                 │ '3.17.0' │ 'none'         │
                            │ 43      │ 'system.adapter.uv-protect'           │ 'uv-protect'           │ '0.6.12' │ 'none'         │
                            │ 44      │ 'system.adapter.viessmannapi'         │ 'viessmannapi'         │ '2.4.5'  │ 'none'         │
                            │ 45      │ 'system.adapter.vis'                  │ 'vis'                  │ '1.5.6'  │ 'none'         │
                            │ 46      │ 'system.adapter.vis-colorpicker'      │ 'vis-colorpicker'      │ '2.1.0'  │ 'none'         │
                            │ 47      │ 'system.adapter.vis-jqui-mfd'         │ 'vis-jqui-mfd'         │ '1.1.3'  │ 'none'         │
                            │ 48      │ 'system.adapter.vis-metro'            │ 'vis-metro'            │ '1.2.0'  │ 'none'         │
                            │ 49      │ 'system.adapter.vis-timeandweather'   │ 'vis-timeandweather'   │ '1.2.2'  │ 'none'         │
                            │ 50      │ 'system.adapter.vis-weather'          │ 'vis-weather'          │ '2.5.13' │ 'none'         │
                            │ 51      │ 'system.adapter.web'                  │ 'web'                  │ '8.3.0'  │ 'none'         │
                            │ 52      │ 'system.adapter.ws'                   │ 'ws'                   │ '4.1.0'  │ 'none'         │
                            │ 53      │ 'system.adapter.zigbee'               │ 'zigbee'               │ '3.4.6'  │ 'none'         │
                            ioBroker-Adapter Versions and update status
                            Used repository: Beta (latest)
                            Adapter    "admin"        : 7.9.1    , installed 7.9.1
                            Adapter    "alexa2"       : 3.28.1   , installed 3.28.1
                            Adapter    "alias-manager": 2.1.0    , installed 2.1.0
                            Adapter    "backitup"     : 3.3.17   , installed 3.3.17
                            Adapter    "cloud"        : 6.1.2    , installed 6.1.2
                            Adapter    "daswetter"    : 4.5.4    , installed 4.5.4
                            Adapter    "devices"      : 2.1.1    , installed 2.1.1
                            Adapter    "enigma2"      : 2.3.0    , installed 2.3.0
                            Adapter    "eusec"        : 2.0.3    , installed 2.0.3
                            Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                            Adapter    "frontier_silicon": 0.5.1 , installed 0.5.1
                            Adapter    "ham"          : 5.3.1    , installed 5.3.1
                            Adapter    "hass"         : 2.1.0    , installed 2.1.0
                            Adapter    "history"      : 4.0.0    , installed 4.0.0
                            Adapter    "homekit-controller": 0.5.11, installed 0.5.11
                            Adapter    "hue"          : 3.16.2   , installed 3.16.2
                            Adapter    "ical"         : 1.20.1   , installed 1.20.1
                            Adapter    "iot"          : 6.1.3    , installed 6.1.3
                            Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                            Adapter    "javascript"   : 9.2.4    , installed 9.2.4
                            Controller "js-controller": 7.1.2    , installed 7.1.2
                            Adapter    "linux-control": 1.1.5    , installed 1.1.5
                            Adapter    "logparser"    : 2.5.0    , installed 2.5.0
                            Adapter    "lupusec"      : 2.0.8    , installed 2.0.8
                            Adapter    "mcp"          : 1.0.0    , installed 1.0.0
                            Adapter    "notification-manager": 1.3.0, installed 1.3.0
                            Adapter    "panasonic-viera": 2.1.0  , installed 2.1.0
                            Adapter    "pi-hole"      : 2.0.0    , installed 2.0.0
                            Adapter    "ping"         : 2.2.4    , installed 2.2.4
                            Adapter    "pushover"     : 5.0.0    , installed 5.0.0
                            Adapter    "roborock"     : 0.7.4    , installed 0.7.4
                            Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
                            Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                            Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                            Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                            Adapter    "socketio"     : 7.1.3    , installed 7.1.3
                            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                            Adapter    "synology"     : 3.1.0    , installed 3.1.0
                            Adapter    "trashschedule": 5.3.0    , installed 5.3.0
                            Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                            Adapter    "uv-protect"   : 0.6.12   , installed 0.6.12
                            Adapter    "viessmannapi" : 2.4.5    , installed 2.4.5
                            Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
                            Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
                            Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                            Adapter    "web"          : 8.3.0    , installed 8.3.0
                            Adapter    "ws"           : 4.1.0    , installed 4.1.0
                            Adapter    "zigbee"       : 3.4.6    , installed 3.4.6
                            Objects and States
                            Objects:        22012
                            States:         15487
                            Hit:1 http://deb.debian.org/debian trixie InRelease
                            Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
                            Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                            Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
                            Reading package lists...
                            Pending systemupdates: 0
                            *** Listening Ports ***
                            Netid State  Recv-Q Send-Q               Local Address:Port          Peer Address:PortProcess
                            udp   UNCONN 0      0                          0.0.0.0:6666               0.0.0.0:*    users:(("io.tuya.0",pid=2010,fd=38))
                            udp   UNCONN 0      0                          0.0.0.0:6667               0.0.0.0:*    users:(("io.tuya.0",pid=2010,fd=39))
                            udp   UNCONN 0      0                          0.0.0.0:domain             0.0.0.0:*    users:(("pihole-FTL",pid=1051,fd=20))
                            udp   UNCONN 0      0                          0.0.0.0:ntp                0.0.0.0:*    users:(("pihole-FTL",pid=1051,fd=39))
                            udp   UNCONN 0      0                          0.0.0.0:49585              0.0.0.0:*    users:(("io.eusec.0",pid=2061,fd=37))
                            udp   UNCONN 0      0                          0.0.0.0:37441              0.0.0.0:*    users:(("io.eusec.0",pid=2061,fd=38))
                            udp   UNCONN 0      0                          0.0.0.0:58123              0.0.0.0:*    users:(("avahi-daemon",pid=701,fd=14))
                            udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=701,fd=12))
                            udp   UNCONN 0      0                                *:55203                    *:*    users:(("avahi-daemon",pid=701,fd=15))
                            udp   UNCONN 0      0                                *:domain                   *:*    users:(("pihole-FTL",pid=1051,fd=22))
                            udp   UNCONN 0      0                                *:ntp                      *:*    users:(("pihole-FTL",pid=1051,fd=41))
                            udp   UNCONN 0      0                                *:8555                     *:*    users:(("go2rtc",pid=2125,fd=8))
                            udp   UNCONN 0      0      [fe80::545f:85e5:cea0:b736]:dhcpv6-client            *:*    users:(("NetworkManager",pid=851,fd=28))
                            udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=701,fd=13))
                            tcp   LISTEN 0      20                       127.0.0.1:smtp               0.0.0.0:*    users:(("exim4",pid=1322,fd=5))
                            tcp   LISTEN 0      4096                     127.0.0.1:ipp                0.0.0.0:*    users:(("cupsd",pid=940,fd=7))
                            tcp   LISTEN 0      200                        0.0.0.0:http               0.0.0.0:*    users:(("pihole-FTL",pid=1051,fd=35))
                            tcp   LISTEN 0      32                         0.0.0.0:domain             0.0.0.0:*    users:(("pihole-FTL",pid=1051,fd=21))
                            tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=978,fd=6))
                            tcp   LISTEN 0      200                        0.0.0.0:https              0.0.0.0:*    users:(("pihole-FTL",pid=1051,fd=36))
                            tcp   LISTEN 0      511                      127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=941,fd=23))
                            tcp   LISTEN 0      511                      127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=941,fd=29))
                            tcp   LISTEN 0      511                        0.0.0.0:bbs                0.0.0.0:*    users:(("io.lupusec.0",pid=2293,fd=36))
                            tcp   LISTEN 0      200                           [::]:http                  [::]:*    users:(("pihole-FTL",pid=1051,fd=37))
                            tcp   LISTEN 0      32                            [::]:domain                [::]:*    users:(("pihole-FTL",pid=1051,fd=23))
                            tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=978,fd=7))
                            tcp   LISTEN 0      200                           [::]:https                 [::]:*    users:(("pihole-FTL",pid=1051,fd=38))
                            tcp   LISTEN 0      4096                             *:8555                     *:*    users:(("go2rtc",pid=2125,fd=7))
                            tcp   LISTEN 0      4096                             *:1984                     *:*    users:(("go2rtc",pid=2125,fd=6))
                            tcp   LISTEN 0      4096                         [::1]:ipp                   [::]:*    users:(("cupsd",pid=940,fd=6))
                            tcp   LISTEN 0      16                               *:5900                     *:*    users:(("wayvnc",pid=969,fd=9))
                            tcp   LISTEN 0      20                           [::1]:smtp                  [::]:*    users:(("exim4",pid=1322,fd=6))
                            tcp   LISTEN 0      511                              *:tproxy                   *:*    users:(("io.admin.0",pid=1311,fd=39))
                            tcp   LISTEN 0      511                              *:8082                     *:*    users:(("io.web.0",pid=2286,fd=36))
                            tcp   LISTEN 0      511                              *:3500                     *:*    users:(("io.sonos.0",pid=1956,fd=31))
                            tcp   LISTEN 0      2                                *:ms-wbt-server            *:*    users:(("xrdp",pid=1028,fd=13))
                            2026-06-14 00:01:21.120  - warn: javascript.0 (1466)     at JavaScript.emit (node:events:519:28)
                            2026-06-14 00:01:21.120  - warn: javascript.0 (1466)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11135:57)
                            2026-06-14 00:01:21.120  - warn: javascript.0 (1466)     at processImmediate (node:internal/timers:484:21)
                            2026-06-14 00:01:21.120  - warn: javascript.0 (1466)     at process.callbackTrampoline (node:internal/async_hooks:130:17)
                            2026-06-14 00:01:21.120  - warn: javascript.0 (1466) getState "alias.0.Sensor.Th_Seitenbalkon.UNREACH" not found (3)
                            2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at BatterieCheck (script.js.common.91-Infrastruktur.9101-Batteriestatus:41:11)
                            2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at Object.<anonymous> (script.js.common.91-Infrastruktur.9101-Batteriestatus:83:9)
                            2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1846:38)
                            2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:839:29)
                            2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at JavaScript.emit (node:events:519:28)
                            2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11135:57)
                            2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at processImmediate (node:internal/timers:484:21)
                            2026-06-14 00:01:21.121  - warn: javascript.0 (1466)     at process.callbackTrampoline (node:internal/async_hooks:130:17)
                            2026-06-14 00:01:21.122  - warn: javascript.0 (1466) getState "alias.0.Sensor.Th_WG.UNREACH" not found (3)
                            2026-06-14 00:01:21.122  - warn: javascript.0 (1466)     at BatterieCheck (script.js.common.91-Infrastruktur.9101-Batteriestatus:41:11)
                            2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at Object.<anonymous> (script.js.common.91-Infrastruktur.9101-Batteriestatus:83:9)
                            2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1846:38)
                            2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:839:29)
                            2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at JavaScript.emit (node:events:519:28)
                            2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11135:57)
                            2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at processImmediate (node:internal/timers:484:21)
                            2026-06-14 00:01:21.123  - warn: javascript.0 (1466)     at process.callbackTrampoline (node:internal/async_hooks:130:17)
                            2026-06-14 00:01:21.120  - info: iqontrol.0 (2167) COUNTER UNREACH erreichbar: 52 of 60
                            2026-06-14 00:01:21.176  - info: iqontrol.0 (2167) COUNTER UNREACH unerreichbar: 7 of 60
                            2026-06-14 00:01:21.400  - info: iqontrol.0 (2167) CALCULATION UNREACH (Nicht-)Erreichbarkeit has changed
                            ============= Mark until here for C&P =============
                            • H Hadebe
                              ```bash
                              Script v.2026-06-01
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64bit
                              CPU threads     : 4
                              Current issues:
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Swap:           209M          0B        209M
                                       8062 M total memory
                                       4446 M used memory
                                       2034 M free memory
                                        124 M buffer memory
                                       1578 M swap cache
                                        199 M total swap
                                          0 M used swap
                                        199 M free swap
                              *** FILESYSTEM ***
                              /var:
                              1.4G    /var/
                              789M    /var/log
                              220M    /var/lib
                              USB-Devices by-id:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.9.8
                              /usr/bin/npx            10.9.8
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.9.1
                              javascript:     9.2.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        22012
                              States:         15487
                              #247
                              @Hadebe sagte:
                              pi
                              MIttlerweile wird der user 'pi' nicht mehr vorgesehen. Wäre bei einer Neuinstallation behoben.
                              Da ist immer noch GUI-Krempel installiert. Wäre bei einer Neuinstallation der Lite-Version nicht der Fall.
                              Swap: 209M
                              Wird mittlerweile anders angelegt. Wäre bei einer Neuinstallation behoben.
                              Das nodejs-Repo ist nicht richtig installiert. Hol das per
                              iob nodejs-update 22
                              nach. Rückfragen sind zu bejahen. Wäre bei einer Neuinstallation auch nicht passiert.
                              Insgesamt bleibe ich dabei: Das wird dir mit hoher Wahrscheinlichkeit in der ein oder anderen Form wieder auf die Füße fallen.
                              • H Hadebe
                                fuzzy1955F Online
                                fuzzy1955F Online
                                fuzzy1955
                                #248
                                @Hadebe sagte:
                                @Thomas-Braun
                                Hi, Hadebe!
                                Also - dank Thomas mache ich periodisch (alle 3 -4 Monate) eine Neuinstallation meines Testsystems inkl. Einspielen der aktuellen Backups vom Produktivsystem nur zum Zweck der Linux-Übung (ich kannte das Ding vor 2 Jahre nicht einmal ansatzweise) und dem Vorbeugen eines Totalausfalls meines Smart-Home-Systems mit IOB. An dem hängt meine 10 kWp-PV-Anlage samt 2 x WR und 3 x 10 kWh Speicher, 2 Wallboxen, die Pellets-Heizungsregelung, die Warmwasserbereitung, die Gartenbewässerung, die Garagentorsteuerung, das Brandmeldesystem usw. Also das gesamte Haus!
                                Ich möchte nicht riskieren, dass ich plötzlich "nackt" dastehe ....
                                Inzwischen macht es mir schon Spaß, das ganze System in 2-3 Stunden neu aufzusetzen. Und ich habe die Sicherheit, dass ich eben NICHT " plötzlich "nackt" dastehe!
                                Gruß, Fuzzy
                                Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
                                Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
                                Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
                                Großes Danke an alle tatkräftigen Helfer im Forum!
                                • H Hadebe
                                  #249
                                  @Hadebe sagte:
                                  Da solltest du aber mit
                                  @Hadebe sagte:
                                  gut eine Stunde
                                  Hand on Time bequem auskommen!
                                  Wenn man "genau" ist und die Zeit für den Neubau der Pakete nach dem Restore noch hinzunimmt, sollte es trotzdem nicht länger als "gut eine Stunde" dauern
                                  • fuzzy1955F fuzzy1955
                                    @Hadebe sagte:
                                    @Thomas-Braun
                                    Hi, Hadebe!
                                    Gruß, Fuzzy
                                    #250
                                    @fuzzy1955 sagte:
                                    LOL - kann mich nicht daran erinnern das in der Form mal empfohlen zu haben. Aber wenn es dir als 'Trainigslager' dient, okay.
                                    fuzzy1955F 1 Antwort Letzte Antwort
                                    • H Offline
                                      Hadebe
                                      #251
                                      Dass es noch Displayreste gibt, hätte ich selbst sehen können. Aber dass nodejs-repo nicht korrekt ist, erschließt sich mir nicht. Jedenfalls habe ich das nachgezogen. Danke dafür.
                                      Das Ganze zeigt aber, das du Recht hast, die Neuinstallation ist sinnvoller.
                                      • H Hadebe
                                        #252
                                        @Hadebe
                                        Das fehlende nodesource-Repo sieht man hier (bzw. sieht man eben nicht):
                                        sowie in der Ausgabe von
                                        nodejs:
                                          Version table:
                                        • H Offline
                                          Hadebe
                                          #253
                                          ja, der Abschnitt sieht jetzt so aus
                                          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                                          ist nur schwer, etwas zu sehen was nicht da ist
