  2. English
  3. Development
  4. [New Adapter] ioBroker.leapmotor - Leapmotor
Geplant Angeheftet Gesperrt Verschoben Development
5 Beiträge 3 Kommentatoren 2.1k Aufrufe 3 Beobachtet
    backfisch88
    Title: [New Adapter] ioBroker.leapmotor - Leapmotor Electric Vehicle Integration
    Hi everyone,
    I’d like to present my new adapter for integrating Leapmotor electric vehicles into ioBroker.
    What it does
    • 🔋 Vehicle status every 1–60 minutes (SOC, range, temperature, tire pressure, GPS, doors, windows)
    • 🌡️ Remote control: climate (heat/cool/vent), lock/unlock, windows, trunk, find vehicle
    • 📊 Consumption statistics with weekly history
    • 🖼️ Dynamic vehicle dashboard (composite HTML widget for VIS)
    • 🔄 Automatic token refresh
    • 💾 Picture cache (vehicle images downloaded once, stored locally)
    Tested vehicles
    • Leapmotor T03 ✅
    Other models (C10, C11 etc.) may work but are untested.
    Installation
    iobroker url https://github.com/backfisch88/ioBroker.leapmotor
    Important note
    Please use a dedicated second account for the adapter (not your main account).
    The adapter maintains a permanent cloud session which conflicts with the Leapmotor app if the same account is used simultaneously.
    Setup: In the Leapmotor app → Personal Center → My Vehicle → [Vehicle Name] → Shared Members → Add Shared Member → grant all rights to the second account.
    Links
    • 🐙 GitHub: https://github.com/backfisch88/ioBroker.leapmotor
    • 📦 npm: https://www.npmjs.com/package/iobroker.leapmotor
    Feedback welcome!
    This is my first ioBroker adapter. I’d love to hear feedback, especially from owners of other Leapmotor models (C10, C11, C01 etc.) to confirm compatibility.
    Thanks!
    Henrik (backfisch88)
    • mcm1957M Offline
      mcm1957M Offline
      mcm1957
      Installation directly from GITHUB is DISCOURAGED and should never be performed at a productive system.
      If the adapter is published at npm, feel free to install it from npm, i.e. using iobroker url iobroker.leapmotor
      Direct installation of GitHub—especially on production systems—is explicitly discouraged.
      GitHub versions can change at any time (even at short notice) and may be inconsistent and faulty. Version information from GitHub installations is meaningless, as the version number, at least when using the standard environment, is only updated during the release process.
      At the developer's explicit request, a GitHub installation can be performed for troubleshooting or testing new functionality—albeit with the increased risk.
      Adapters that can only be installed via GitHub or npm (i.e., NOT from either of these repositories) should be treated with extreme caution. In such cases, the developer should be asked to request inclusion in the repositories, for example, by creating an issue in the adapter repository.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
        backfisch88
        Thanks for the hint! Installation via npm works perfectly:
        The adapter is published on npm: https://www.npmjs.com/package/iobroker.leapmotor
        I have already prepared the PR for inclusion in the official ioBroker repository and will submit it as soon as all requirements are met (npm collaborator confirmation still pending).
        • boriswernerB Offline
          boriswerner
          Hi @backfisch88
          first of all you have a german nickname, dont you speak german? Cause I guess you would reach more people in the german channel for adapter tests (see test thread for solaris adapter here in the english dev-channel).
          Then: I also have a T03 and will test the adapter as soon as I find the time.
          I already thought about making an adapter based on https://github.com/markoceri/leapmotor-api
          Do you know that project (based on the home assistant integration) and did you align your adapter with that implementation as it is already tested?
          I dont see that your adapter supports setting of the "charge limit". I currently load to 80% by default but would like to control dynamically when it should load to 100% (either when I need the extended range or when I have excess PV energy / I want to support the grid). Would be great to have the option.
          Looking forward to testing it.
          • boriswernerB boriswerner
            Hi @backfisch88
            backfisch88
            @boriswerner
            Yes, I’m German – thanks for the tip, I’ll cross-post this in the German section as well.
            Yes, I know leapmotor-api/leapmotor-ha from markoceri/kerniger – I cross-referenced them several times during development, e.g. for the B10/C10 signal mapping and cloud endpoints. Good call that you’re familiar with that project too.
            Regarding charge limit: the adapter actually already supports setting it (cmd.charge_limit_set, 50-100%), but I just found and fixed a bug – the limit wasn’t reliably applied because it was accidentally disabling the existing charge schedule every time it was set. The fix is currently being tested on my end and will be pushed to GitHub shortly. Feel free to test the adapter already, but I’d wait for the next release before relying on the charge limit feature specifically.
            Looking forward to your testing on the T03!
