  3. Off Topic
  4. Pflege des Betriebssystems
  5. Betriebssystem-Paket-Updates verfügbar
    6.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
77 Beiträge 11 Kommentatoren 9.8k Aufrufe 10 Beobachtet
  • B Bernd_L
    @Thomas-Braun
    Jetzt bin ich gespannt
    Script v.2026-06-01
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 11 (bullseye)
       Static hostname: iOBroker
             Icon name: computer
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 1133 days ago (on 2023-05-03).
    Systemuptime and Load:
     15:48:52 up  1:18,  1 user,  load average: 0.68, 0.47, 0.36
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2026-06-09 15:48:52 CEST
               Universal time: Tue 2026-06-09 13:48:52 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    Bernd571
    HOME=/home/Bernd571
    GROUPS=Bernd571 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:            3.8G        2.1G        891M        1.0M        795M        1.6G
    Swap:            99M          0B         99M
    Total:          3.9G        2.1G        991M
    Active iob-Instances:   19
             3794 M total memory
             2107 M used memory
             2264 M active memory
              449 M inactive memory
              891 M free memory
               89 M buffer memory
              706 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 15:48:53 up  1:18,  1 user,  load average: 0.68, 0.47, 0.36
    Tasks: 175 total,   1 running, 174 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  8.7 us,  2.9 sy,  0.0 ni, 88.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3794.3 total,    891.2 free,   2107.2 used,    796.0 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1610.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       59G   15G   42G  26% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.1M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Tue Jun  9 14:30:47 2026] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Jun  9 14:30:47 2026] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Jun  9 14:30:50 2026] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.2G    /var/
    1.5G    /var/log/journal/f0afd730650d435998ff424a7140192e
    1.5G    /var/log
    418M    /var/cache
    Archived and active journals take up 1.4G in the file system.
    /opt/iobroker/backups:
    3.8G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    3.7G    /opt/iobroker/iobroker-data/
    3.3G    /opt/iobroker/iobroker-data/history
    268M    /opt/iobroker/iobroker-data/files
    65M     /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/files/vis
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/states.jsonl
    8.0M    /opt/iobroker/iobroker-data/files/daswetter.admin/assets/index-84bRrRlB.js
    7.5M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BeQV_TGa.js
    7.0M    /opt/iobroker/iobroker-data/files/vis/widgets/echarts/static/js/vendors-node_modules_mui_icons-material_esm_index_js.bfab266f.chunk.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.3
    /usr/bin/node           v22.22.3
    /usr/bin/npm            10.9.8
    /usr/bin/npx            10.9.8
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.3-1nodesource1
      Candidate: 22.22.3-1nodesource1
      Version table:
     *** 22.22.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u8 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iOBroker            iOBroker (version: 7.1.2, hostname: iOBroker      , alive, uptime: 4429)
    Core adapters versions
    js-controller:  7.1.2
    admin:          7.8.23
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iOBroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iOBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iOBroker                                 - disabled
      system.adapter.daswetter.1              : daswetter             : iOBroker                                 - disabled
      system.adapter.daswetter.2              : daswetter             : iOBroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iOBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iOBroker                                 - disabled
    + system.adapter.echarts.0                : echarts               : iOBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iOBroker                                 -  enabled
    + system.adapter.history.0                : history               : iOBroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iOBroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iOBroker                                 -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : iOBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.6                 : hm-rpc                : iOBroker                                 -  enabled, port: 12010
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iOBroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iOBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iOBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iOBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iOBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iOBroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iOBroker                                 -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iOBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iOBroker                                 -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iOBroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iOBroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iOBroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iOBroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iOBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iOBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iOBroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    Active repo(s): stable
    Upgrade policy: minor
    Installed ioBroker-Adapters
    │ (index) │ id                                  │ name                 │ version  │ upgrade policy │
    │ 0       │ 'system.adapter.admin'              │ 'admin'              │ '7.8.23' │ 'none'         │
    │ 1       │ 'system.adapter.backitup'           │ 'backitup'           │ '3.3.17' │ 'none'         │
    │ 2       │ 'system.adapter.broadlink2'         │ 'broadlink2'         │ '2.3.0'  │ 'none'         │
    │ 3       │ 'system.adapter.daswetter'          │ 'daswetter'          │ '4.5.3'  │ 'none'         │
    │ 4       │ 'system.adapter.discovery'          │ 'discovery'          │ '5.0.0'  │ 'none'         │
    │ 5       │ 'system.adapter.dwd'                │ 'dwd'                │ '2.8.5'  │ 'none'         │
    │ 6       │ 'system.adapter.echarts'            │ 'echarts'            │ '3.1.0'  │ 'none'         │
    │ 7       │ 'system.adapter.flot'               │ 'flot'               │ '1.12.0' │ 'none'         │
    │ 8       │ 'system.adapter.history'            │ 'history'            │ '4.0.0'  │ 'none'         │
    │ 9       │ 'system.adapter.hm-rega'            │ 'hm-rega'            │ '5.1.0'  │ 'none'         │
    │ 10      │ 'system.adapter.hm-rpc'             │ 'hm-rpc'             │ '3.0.1'  │ 'none'         │
    │ 11      │ 'system.adapter.hoover'             │ 'hoover'             │ '0.0.7'  │ 'none'         │
    │ 12      │ 'system.adapter.icons-mfd-png'      │ 'icons-mfd-png'      │ '1.2.1'  │ 'none'         │
    │ 13      │ 'system.adapter.jarvis'             │ 'jarvis'             │ '3.1.8'  │ 'none'         │
    │ 14      │ 'system.adapter.javascript'         │ 'javascript'         │ '9.0.18' │ 'none'         │
    │ 15      │ 'system.adapter.openweathermap'     │ 'openweathermap'     │ '1.4.0'  │ 'none'         │
    │ 16      │ 'system.adapter.ping'               │ 'ping'               │ '1.7.9'  │ 'none'         │
    │ 17      │ 'system.adapter.shelly'             │ 'shelly'             │ '10.6.1' │ 'none'         │
    │ 18      │ 'system.adapter.simple-api'         │ 'simple-api'         │ '2.8.0'  │ 'none'         │
    │ 19      │ 'system.adapter.socketio'           │ 'socketio'           │ '7.1.3'  │ 'none'         │
    │ 20      │ 'system.adapter.tr-064'             │ 'tr-064'             │ '4.3.0'  │ 'none'         │
    │ 21      │ 'system.adapter.vis'                │ 'vis'                │ '1.5.6'  │ 'none'         │
    │ 22      │ 'system.adapter.vis-hqwidgets'      │ 'vis-hqwidgets'      │ '1.6.1'  │ 'none'         │
    │ 23      │ 'system.adapter.vis-inventwo'       │ 'vis-inventwo'       │ '4.1.0'  │ 'none'         │
    │ 24      │ 'system.adapter.vis-jqui-mfd'       │ 'vis-jqui-mfd'       │ '1.1.3'  │ 'none'         │
    │ 25      │ 'system.adapter.vis-keyboard'       │ 'vis-keyboard'       │ '0.0.3'  │ 'none'         │
    │ 26      │ 'system.adapter.vis-metro'          │ 'vis-metro'          │ '1.2.0'  │ 'none'         │
    │ 27      │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2'  │ 'none'         │
    │ 28      │ 'system.adapter.vis-weather'        │ 'vis-weather'        │ '2.5.13' │ 'none'         │
    │ 29      │ 'system.adapter.web'                │ 'web'                │ '8.0.0'  │ 'none'         │
    │ 30      │ 'system.adapter.whatsapp-cmb'       │ 'whatsapp-cmb'       │ '0.3.0'  │ 'none'         │
    │ 31      │ 'system.adapter.ws'                 │ 'ws'                 │ '4.1.0'  │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.1.2    , installed 7.1.2
    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
    Adapter    "vis-inventwo" : 4.1.0    , installed 4.1.0
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "vis-keyboard" : 0.0.3    , installed 0.0.3
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Objects and States
    Objects:        12033
    States:         8752
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q  Local Address:Port          Peer Address:PortProcess
    udp   UNCONN 0      0             0.0.0.0:5683               0.0.0.0:*    users:(("io.shelly.1",pid=1589,fd=37))
    udp   UNCONN 0      0             0.0.0.0:bootpc             0.0.0.0:*    users:(("dhcpcd",pid=799,fd=10))
    udp   UNCONN 0      0             0.0.0.0:37133              0.0.0.0:*    users:(("avahi-daemon",pid=394,fd=14))
    udp   UNCONN 0      0             0.0.0.0:15001              0.0.0.0:*    users:(("io.broadlink2.0",pid=1602,fd=30))
    udp   UNCONN 0      0             0.0.0.0:52230              0.0.0.0:*    users:(("io.broadlink2.0",pid=1602,fd=32))
    udp   UNCONN 0      0             0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=394,fd=12))
    udp   UNCONN 0      0             0.0.0.0:34170              0.0.0.0:*    users:(("io.broadlink2.0",pid=1602,fd=31))
    udp   UNCONN 0      0                   *:dhcpv6-client            *:*    users:(("dhcpcd",pid=799,fd=16))
    udp   UNCONN 0      0                   *:mdns                     *:*    users:(("avahi-daemon",pid=394,fd=13))
    udp   UNCONN 0      0                   *:50630                    *:*    users:(("avahi-daemon",pid=394,fd=15))
    tcp   LISTEN 0      511           0.0.0.0:1882               0.0.0.0:*    users:(("io.shelly.0",pid=1572,fd=47))
    tcp   LISTEN 0      511    192.168.178.33:12010              0.0.0.0:*    users:(("io.hm-rpc.6",pid=1534,fd=35))
    tcp   LISTEN 0      511    192.168.178.33:2001               0.0.0.0:*    users:(("io.hm-rpc.1",pid=1521,fd=35))
    tcp   LISTEN 0      511         127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=1355,fd=29))
    tcp   LISTEN 0      511         127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=1355,fd=23))
    tcp   LISTEN 0      128           0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=536,fd=3))
    tcp   LISTEN 0      511    192.168.178.33:18701              0.0.0.0:*    users:(("io.hm-rpc.0",pid=1503,fd=35))
    tcp   LISTEN 0      511           0.0.0.0:8400               0.0.0.0:*    users:(("io.jarvis.0",pid=1724,fd=30))
    tcp   LISTEN 0      511                 *:tproxy                   *:*    users:(("io.admin.0",pid=1375,fd=39))
    tcp   LISTEN 0      511                 *:8082                     *:*    users:(("io.web.0",pid=2282,fd=35))
    tcp   LISTEN 0      128              [::]:ssh                   [::]:*    users:(("sshd",pid=536,fd=4))
    2026-06-09 15:35:05.967  - info: admin.0 (1375) <== Disconnect system.user.admin from ::ffff:192.168.178.42 javascript
    2026-06-09 15:35:15.978  - silly: backitup.0 (1470) States system redis pmessage system.adapter.*.logging/system.adapter.admin.0.logging:{"val":false,"ack":true,"ts":1781012115971,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1781012115971}
    2026-06-09 15:35:15.980  - silly: backitup.0 (1470) system.adapter.admin.0: logging false
    2026-06-09 15:36:37.989  - info: admin.0 (1375) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 15:36:38.208  - silly: backitup.0 (1470) States system redis pmessage system.adapter.*.logging/system.adapter.admin.0.logging:{"val":true,"ack":true,"ts":1781012198176,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1781012198176}
    2026-06-09 15:36:38.209  - silly: backitup.0 (1470) system.adapter.admin.0: logging true
    2026-06-09 15:36:38.210  - info: admin.0 (1375) <== Disconnect system.user.admin from ::ffff:192.168.178.42 admin
    2026-06-09 15:36:38.226  - info: admin.0 (1375) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 15:36:38.234  - info: admin.0 (1375) <== Disconnect system.user.admin from ::ffff:192.168.178.42 admin
    2026-06-09 15:36:40.241  - info: admin.0 (1375) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 15:36:40.621  - info: admin.0 (1375) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 15:36:41.022  - info: admin.0 (1375) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 15:36:46.199  - info: web.0 (2282) <== Disconnect system.user.admin from ::ffff:192.168.178.42 vis.0
    2026-06-09 15:37:02.628  - info: web.0 (2282) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 15:37:35.048  - info: host.iOBroker instance system.adapter.openweathermap.0 in version "1.4.0" started with pid 5585
    2026-06-09 15:37:40.749  - info: openweathermap.0 (5585) starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v22.22.3, js-controller: 7.1.2
    2026-06-09 15:38:03.686  - info: openweathermap.0 (5585) Terminated (NO_ERROR): Without reason
    2026-06-09 15:38:04.232  - info: host.iOBroker instance system.adapter.openweathermap.0 having pid 5585 terminated with code 0 (NO_ERROR)
    2026-06-09 15:40:14.628  - info: javascript.0 (1387) script.js.common.Wassermanagement_.Warnungen_Wasseraustritt: Stopping script
    2026-06-09 15:40:14.738  - info: javascript.0 (1387) script.js.common.Wassermanagement_.Warnungen_Wasseraustritt: start JavaScript (Blockly)
    2026-06-09 15:40:14.763  - info: javascript.0 (1387) script.js.common.Wassermanagement_.Warnungen_Wasseraustritt: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-06-09 15:40:19.792  - info: javascript.0 (1387) script.js.common.Wassermanagement_.Warnungen_Wasseraustritt: Stopping script
    2026-06-09 15:40:20.002  - info: javascript.0 (1387) script.js.common.Wassermanagement_.Warnungen_Wasseraustritt: start JavaScript (Blockly)
    2026-06-09 15:40:20.009  - info: javascript.0 (1387) script.js.common.Wassermanagement_.Warnungen_Wasseraustritt: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-06-09 15:44:31.119  - info: admin.0 (1375) <== Disconnect system.user.admin from ::ffff:192.168.178.42 javascript
    ============= Mark until here for C&P =============
    iob diag has finished.
    Bernd571@iOBroker:~ $ ========== Start marking the full check here ===========
    Script v.2026-06-01
    *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
    OS is similar to:
    Docker          : false
    Kernel          : aarch64
    Userland        : 64bit
    CPU threads     : 4
    Current issues:
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    Bernd571
    HOME=/home/Bernd571
    iobroker
    HOME=/home/iobroker
    Desktop:
    Session:                tty
    @Bernd_L sagte:
    Wo ist da alles neu?
    @Bernd_L sagte:
    nicht mehr oldold
    Doch, sogar EndOfLife = mausetot
      @Bernd_L sagte:
      @Bernd_L sagte:
      nicht mehr oldold
      Bernd_L
      @Homoran
      okay,
      ich habe keine Ahnung wofür die Bullenaugen benötigt werden, was muss ich machen?
      • B Bernd_L
        @Homoran
        okay,
        @Bernd_L bullseye ist der Name von Debian 11, danach kam Debian 12 = bookworm, dann debian 13 = Trixie (alles Figuren aus Toy Story).
        Zieh jetzt ein Backup mit backitup
        Dann nimmst du eine neue gute SD Karte und beschreibst die mit RaspberryPi OS lite 13 (Trixie)
        Dann tauschst du die SD Karten aus
        Darauf iobroker nebst allem nötigen mit dem "Einzeiler" installieren
        Und Backup wieder herstellen!
        Tschakka!!
        Das schaffst du!
        B 2 Antworten Letzte Antwort
        • teletapiT Offline
          teletapiT Offline
          teletapi
          So wie hier beschrieben
          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
            Tschakka!!
            Das schaffst du!
            Bernd_L
            @Homoran
            Danke sehr, ich sage ja, bin iOBroker Anwender, Linux sind für den Bäcker wie Mauer setzen.
            Ich muss mich jetzt erstmal um meine normale Todo Liste von heute kümmern, komme später oder morgen hierauf zurück.
            Nur damit ich nicht wieder Bahnhof verstehe: Was ist der "Einzeiler"?
            • B Bernd_L
              @Homoran
              @Bernd_L sagte:
              Hint:
              www.iobroker.net
              (unten links)
              • MartinPM Online
                MartinPM Online
                MartinP
                Die Ursache für Spannungsschwankungen muss nicht das Steckernetzteil sein.
                Wackelig gewordene / ausgeleierte Raspberry Pi Micro USB Buchse z.B.
                Was wird denn über die anderen USB-Ports des Pi noch versorgt?
                • B Bernd_L
                  @Thomas-Braun
                  Das ist das Original-Netzteil.
                  Dr. BakteriusD Online
                  Dr. Bakterius
                  @Bernd_L sagte:
                  Wirklich? Mit dem Raspberry-Logo darauf? Der Raspberry braucht nicht 5,0 Volt sondern etwas mehr. Die meisten Netzteile liefern aber nur die 5,0 Volt. Er läuft damit zwar, aber es kommen diese Meldungen.
                  Inwiefern sich das auswirkt, kann ich nicht sagen. Aber ein Netzteil, dass extra für den Raspberry gemacht ist, kostet zwar etwas mehr, doch man ist damit auf der sicheren Seite.
                  • MartinPM MartinP
                    @MartinP sagte:
                    Deswegen hat der Pi4 ja USB-C!
                    @MartinP sagte:
                    Nichts!
                    • MartinPM Online
                      MartinPM Online
                      MartinP
                      Auch USB-C Buchsen können altern...
                      • MartinPM MartinP
                        Im aktuellen Lauf sind die Meldungen aber auch weg:
                        Current issues:
                        Bleibt halt noch zum beheben:
                        Mit der allfälligen Neuinstallation geben sich dann die anderen Kinken gleich mit.
                        • MartinPM Online
                          MartinPM Online
                          MartinP
                          Wer weiß, woher die Brown-Out Meldungen gekommen sind, vielleicht mal eine 2,5" USB-Platte, die über den USB-Port versorgt wird angeschlossen, um ein Backup zu ziehen?
                            Tschakka!!
                            Das schaffst du!
                            Bernd_L
                            @Homoran
                            Hallo zusammen, bin wieder zurück und habe Backups angelegt und auf einer neuen SD-Karte mittels des Pi-Imagers die Software installiert. und die neue Karte in den Rasp gesteckt.
                            Dies immer Accept
                            Das habe ich nun schon dreimal gemacht, weil mir der Putty immer mein Passwort ablehnt.
                            Wo ist denn diesmal mein Fehler?
                            • B Bernd_L
                              @Homoran
                              Dies immer Accept
                              @Bernd_L
                              Keine Ahnung. Ich verwende weder puTTY noch Windows. Da wird wohl noch ein alter Key irgendwo im Cache liegen.
                              • B Bernd_L
                                @Homoran
                                Dies immer Accept
                                @Bernd_L sagte:
                                Was hast du denn genau gemacht?
                                @Bernd_L sagte:
                                Mit welchen Einstellungen?
                                • User angelegt?
                                • SSH aktiv?
                                  • wahrscheinlich ja!
                                @Bernd_L sagte:
                                Dies immer Accept
                                Sollte eigentlich nur einmal nach Neuinstallation passieren
                                @Bernd_L sagte:
                                Wann und wie?
                                  @Bernd_L
                                  @Thomas-Braun sagte:
                                  Nach accept sollte der aber bei den known hosts überschrieben werden
                                  Hab da auch nie ein Problem mit dem Passwort gehabt.
                                  @bernd_l
                                  Ggf z und y vertauscht?
                                    @Bernd_L sagte:
                                    @Bernd_L sagte:
                                    • User angelegt?
                                    • SSH aktiv?
                                    @Bernd_L sagte:
                                    Dies immer Accept
                                    @Bernd_L sagte:
                                    Wann und wie?
                                    Bernd_L
                                    @Homoran sagte:
                                    @Bernd_L sagte:
                                    @Bernd_L sagte:
                                    • User angelegt?
                                    • SSH aktiv?
                                    Die Installation fragte nach Username und Passwort, beides angegeben, allerdings gegenüber vorherigen Installationen die gleichen.
                                    SSH kann ich jetzt nicht explizit beantworten
                                    @Bernd_L sagte:
                                    Dies immer Accept
                                    @Bernd_L sagte:
                                    Wann und wie?
                                    Immer direkt nach der Passwortabfrage
                                    • B Bernd_L
                                      @Homoran sagte:
                                      @Bernd_L sagte:
                                      @Bernd_L sagte:
                                      • User angelegt?
                                      • SSH aktiv?
                                      @Bernd_L sagte:
                                      Dies immer Accept
                                      @Bernd_L sagte:
                                      Wann und wie?
                                      @Bernd_L sagte:
                                      Wann und wie?
                                      Mit welcher exakten Meldung?
                                      @Bernd_L sagte:
                                      Mit irgendwelchen Sonderzeichen?
                                      Bei welchen Spracheinstellungen für die Tastatur?
                                        @Bernd_L sagte:
                                        Wann und wie?
                                        @Bernd_L sagte:
                                        Bernd_L
                                        @Homoran
                                        Nach Passwortabfrage "Access denied"
                                        Hab auch keine Buchstabenvertauschungen, mehrfach mit gut erinnerungsfähigen Passwörtern aufgelaufen
                                        • B Bernd_L
                                          @Homoran
                                          @Bernd_L
                                          Die Schlüssel dürften unter Windows im Ordner ssh oder .ssh liegen.
                                          Die Datei wird wohl known_hosts heißen.
