  3. Off Topic
  4. Pflege des Betriebssystems
  5. Betriebssystem-Paket-Updates verfügbar
    5.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
77 Beiträge 11 Kommentatoren 9.3k Aufrufe 10 Beobachtet
  • B Bernd_L
    Script v.2026-06-01
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 11 (bullseye)
       Static hostname: iOBroker
             Icon name: computer
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 1133 days ago (on 2023-05-03).
    Systemuptime and Load:
     11:51:33 up 407 days, 19:02,  1 user,  load average: 0.27, 0.30, 0.26
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2026-06-09 11:51:33 CEST
               Universal time: Tue 2026-06-09 09:51:33 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    Bernd571
    HOME=/home/Bernd571
    GROUPS=Bernd571 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.7G        391M        0.0K        1.7G        2.0G
    Swap:            99M         15M         84M
    Total:          3.9G        1.8G        476M
    Active iob-Instances:   20
             3794 M total memory
             1740 M used memory
             1917 M active memory
             1214 M inactive memory
              391 M free memory
               61 M buffer memory
             1601 M swap cache
               99 M total swap
               15 M used swap
               84 M free swap
    top - 11:51:33 up 407 days, 19:02,  1 user,  load average: 0.33, 0.31, 0.27
    Tasks: 181 total,   2 running, 179 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 11.4 us,  7.1 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
    MiB Mem :   3794.3 total,    390.8 free,   1740.2 used,   1663.3 buff/cache
    MiB Swap:    100.0 total,     84.5 free,     15.5 used.   1978.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    58 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    /dev/root      ext4       59G   15G   42G  26% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.1M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Sun Apr 27 16:48:49 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Apr 27 16:48:49 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Apr 27 16:48:52 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    [Mon Nov  3 00:03:42 2025] EXT4-fs warning (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #26488: lblock 0: comm mandb: error -5 reading directory block
    [Fri Mar 20 00:06:10 2026] EXT4-fs warning (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #25981: lblock 0: comm mandb: error -5 reading directory block
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.1G    /var/
    1.5G    /var/log/journal/f0afd730650d435998ff424a7140192e
    1.5G    /var/log
    383M    /var/cache
    Archived and active journals take up 1.4G in the file system.
    /opt/iobroker/backups:
    3.8G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    3.6G    /opt/iobroker/iobroker-data/
    3.3G    /opt/iobroker/iobroker-data/history
    272M    /opt/iobroker/iobroker-data/files
    65M     /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/files/vis
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    13M     /opt/iobroker/iobroker-data/states.jsonl
    8.0M    /opt/iobroker/iobroker-data/files/daswetter.admin/assets/index-84bRrRlB.js
    7.5M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BeQV_TGa.js
    7.0M    /opt/iobroker/iobroker-data/files/vis/widgets/echarts/static/js/vendors-node_modules_mui_icons-material_esm_index_js.bfab266f.chunk.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.4
    /usr/bin/node           v20.19.4
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    ✓ Node.js installation is correct
    nodejs:
      Installed: 20.19.4-1nodesource1
      Candidate: 20.20.2-1nodesource1
      Version table:
         20.20.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.20.1-1nodesource1 1001
         20.20.0-1nodesource1 1001
         20.19.6-1nodesource1 1001
         20.19.5-1nodesource1 1001
     *** 20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u8 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    Vulnerabilities detected in the Node.js version!
    node:fs:2368
        return binding.writeFileUtf8(
    Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
        at Object.writeFileSync (node:fs:2368:20)
        at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
        at Object.onceWrapper (node:events:639:26)
        at ClientRequest.emit (node:events:524:28)
        at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27)
        at HTTPParser.parserOnHeadersComplete (node:_http_common:118:17)
        at TLSSocket.socketOnData (node:_http_client:544:22)
        at TLSSocket.emit (node:events:524:28)
        at addChunk (node:internal/streams/readable:561:12)
        at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
      errno: -13,
      code: 'EACCES',
      syscall: 'open',
      path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
    Node.js v20.19.4
    npm notice
    npm notice New major version of npm available! 10.8.2 -> 11.16.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.16.0
    npm notice To update run: npm install -g npm@11.16.0
    npm notice
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iOBroker            iOBroker (version: 7.0.7, hostname: iOBroker      , alive, uptime: 84084)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.8.23
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iOBroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iOBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iOBroker                                 - disabled
      system.adapter.daswetter.1              : daswetter             : iOBroker                                 - disabled
      system.adapter.daswetter.2              : daswetter             : iOBroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iOBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iOBroker                                 - disabled
    + system.adapter.echarts.0                : echarts               : iOBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iOBroker                                 -  enabled
    + system.adapter.history.0                : history               : iOBroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iOBroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iOBroker                                 -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : iOBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.6                 : hm-rpc                : iOBroker                                 -  enabled, port: 12010
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iOBroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iOBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iOBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iOBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iOBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iOBroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iOBroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iOBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iOBroker                                 -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iOBroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iOBroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iOBroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iOBroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iOBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iOBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iOBroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    Active repo(s): stable
    Upgrade policy: minor
    Installed ioBroker-Adapters
    │ (index) │ id                                  │ name                 │ version  │ upgrade policy │
    │ 0       │ 'system.adapter.admin'              │ 'admin'              │ '7.8.23' │ 'none'         │
    │ 1       │ 'system.adapter.backitup'           │ 'backitup'           │ '3.3.17' │ 'none'         │
    │ 2       │ 'system.adapter.broadlink2'         │ 'broadlink2'         │ '2.3.0'  │ 'none'         │
    │ 3       │ 'system.adapter.daswetter'          │ 'daswetter'          │ '4.5.3'  │ 'none'         │
    │ 4       │ 'system.adapter.discovery'          │ 'discovery'          │ '5.0.0'  │ 'none'         │
    │ 5       │ 'system.adapter.dwd'                │ 'dwd'                │ '2.8.5'  │ 'none'         │
    │ 6       │ 'system.adapter.echarts'            │ 'echarts'            │ '3.1.0'  │ 'none'         │
    │ 7       │ 'system.adapter.flot'               │ 'flot'               │ '1.12.0' │ 'none'         │
    │ 8       │ 'system.adapter.history'            │ 'history'            │ '4.0.0'  │ 'none'         │
    │ 9       │ 'system.adapter.hm-rega'            │ 'hm-rega'            │ '5.1.0'  │ 'none'         │
    │ 10      │ 'system.adapter.hm-rpc'             │ 'hm-rpc'             │ '3.0.1'  │ 'none'         │
    │ 11      │ 'system.adapter.hoover'             │ 'hoover'             │ '0.0.7'  │ 'none'         │
    │ 12      │ 'system.adapter.icons-mfd-png'      │ 'icons-mfd-png'      │ '1.2.1'  │ 'none'         │
    │ 13      │ 'system.adapter.jarvis'             │ 'jarvis'             │ '3.1.8'  │ 'none'         │
    │ 14      │ 'system.adapter.javascript'         │ 'javascript'         │ '9.0.18' │ 'none'         │
    │ 15      │ 'system.adapter.openweathermap'     │ 'openweathermap'     │ '1.4.0'  │ 'none'         │
    │ 16      │ 'system.adapter.ping'               │ 'ping'               │ '1.7.9'  │ 'none'         │
    │ 17      │ 'system.adapter.shelly'             │ 'shelly'             │ '10.6.1' │ 'none'         │
    │ 18      │ 'system.adapter.simple-api'         │ 'simple-api'         │ '2.8.0'  │ 'none'         │
    │ 19      │ 'system.adapter.socketio'           │ 'socketio'           │ '7.1.3'  │ 'none'         │
    │ 20      │ 'system.adapter.tr-064'             │ 'tr-064'             │ '4.3.0'  │ 'none'         │
    │ 21      │ 'system.adapter.vis'                │ 'vis'                │ '1.5.6'  │ 'none'         │
    │ 22      │ 'system.adapter.vis-hqwidgets'      │ 'vis-hqwidgets'      │ '1.6.1'  │ 'none'         │
    │ 23      │ 'system.adapter.vis-inventwo'       │ 'vis-inventwo'       │ '3.3.5'  │ 'none'         │
    │ 24      │ 'system.adapter.vis-jqui-mfd'       │ 'vis-jqui-mfd'       │ '1.1.3'  │ 'none'         │
    │ 25      │ 'system.adapter.vis-keyboard'       │ 'vis-keyboard'       │ '0.0.3'  │ 'none'         │
    │ 26      │ 'system.adapter.vis-metro'          │ 'vis-metro'          │ '1.2.0'  │ 'none'         │
    │ 27      │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2'  │ 'none'         │
    │ 28      │ 'system.adapter.vis-weather'        │ 'vis-weather'        │ '2.5.13' │ 'none'         │
    │ 29      │ 'system.adapter.web'                │ 'web'                │ '8.0.0'  │ 'none'         │
    │ 30      │ 'system.adapter.whatsapp-cmb'       │ 'whatsapp-cmb'       │ '0.3.0'  │ 'none'         │
    │ 31      │ 'system.adapter.ws'                 │ 'ws'                 │ '4.1.0'  │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.1.2    , installed 7.0.7  [Updatable]
    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
    Adapter    "vis-inventwo" : 4.1.0    , installed 3.3.5  [Updatable]
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "vis-keyboard" : 0.0.3    , installed 0.0.3
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Objects and States
    Objects:        12031
    States:         8750
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 95
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q  Local Address:Port          Peer Address:PortProcess
    udp   UNCONN 0      0             0.0.0.0:15001              0.0.0.0:*    users:(("io.broadlink2.0",pid=1567026,fd=27))
    udp   UNCONN 0      0             0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=396,fd=12))
    udp   UNCONN 0      0             0.0.0.0:56857              0.0.0.0:*    users:(("io.broadlink2.0",pid=1567026,fd=28))
    udp   UNCONN 0      0             0.0.0.0:5683               0.0.0.0:*    users:(("io.shelly.1",pid=1567011,fd=29))
    udp   UNCONN 0      0             0.0.0.0:40765              0.0.0.0:*    users:(("avahi-daemon",pid=396,fd=14))
    udp   UNCONN 0      0             0.0.0.0:bootpc             0.0.0.0:*    users:(("dhcpcd",pid=723,fd=13))
    udp   UNCONN 0      0             0.0.0.0:47244              0.0.0.0:*    users:(("io.broadlink2.0",pid=1567026,fd=29))
    udp   UNCONN 0      0                   *:dhcpv6-client            *:*    users:(("dhcpcd",pid=723,fd=16))
    udp   UNCONN 0      0                   *:49960                    *:*    users:(("avahi-daemon",pid=396,fd=15))
    udp   UNCONN 0      0                   *:mdns                     *:*    users:(("avahi-daemon",pid=396,fd=13))
    tcp   LISTEN 0      511           0.0.0.0:8400               0.0.0.0:*    users:(("io.jarvis.0",pid=1567118,fd=27))
    tcp   LISTEN 0      128           0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=1978425,fd=3))
    tcp   LISTEN 0      511    192.168.178.33:18701              0.0.0.0:*    users:(("io.hm-rpc.0",pid=1566927,fd=27))
    tcp   LISTEN 0      511    192.168.178.33:2001               0.0.0.0:*    users:(("io.hm-rpc.1",pid=1566942,fd=27))
    tcp   LISTEN 0      511         127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=1566786,fd=19))
    tcp   LISTEN 0      511         127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=1566786,fd=25))
    tcp   LISTEN 0      511    192.168.178.33:12010              0.0.0.0:*    users:(("io.hm-rpc.6",pid=1566957,fd=27))
    tcp   LISTEN 0      511           0.0.0.0:1882               0.0.0.0:*    users:(("io.shelly.0",pid=1566994,fd=39))
    tcp   LISTEN 0      128              [::]:ssh                   [::]:*    users:(("sshd",pid=1978425,fd=4))
    tcp   LISTEN 0      511                 *:tproxy                   *:*    users:(("io.admin.0",pid=1566804,fd=31))
    tcp   LISTEN 0      511                 *:8082                     *:*    users:(("io.web.0",pid=1567151,fd=27))
    2026-06-09 11:04:45.555  - info: web.0 (1567151) <== Disconnect system.user.admin from ::ffff:192.168.178.54
    2026-06-09 11:36:06.721  - info: admin.0 (1566804) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 11:36:08.632  - info: admin.0 (1566804) <== Disconnect system.user.admin from ::ffff:192.168.178.42
    2026-06-09 11:36:10.394  - info: admin.0 (1566804) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 11:36:10.956  - info: admin.0 (1566804) <== Disconnect system.user.admin from ::ffff:192.168.178.42 javascript
    2026-06-09 11:36:12.809  - info: admin.0 (1566804) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 11:36:13.269  - info: admin.0 (1566804) <== Disconnect system.user.admin from ::ffff:192.168.178.42 backitup
    2026-06-09 11:37:20.085  - info: host.iOBroker instance system.adapter.openweathermap.0 in version "1.4.0" started with pid 1617831
    2026-06-09 11:37:22.031  - info: admin.0 (1566804) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 11:37:24.538  - info: openweathermap.0 (1617831) starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.19.4, js-controller: 7.0.7
    2026-06-09 11:37:43.251  - info: admin.0 (1566804) <== Disconnect system.user.admin from ::ffff:192.168.178.42 javascript
    2026-06-09 11:37:58.718  - info: openweathermap.0 (1617831) Terminated (NO_ERROR): Without reason
    2026-06-09 11:37:59.256  - info: host.iOBroker instance system.adapter.openweathermap.0 having pid 1617831 terminated with code 0 (NO_ERROR)
    2026-06-09 11:38:55.901  - info: admin.0 (1566804) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 11:38:56.318  - silly: backitup.0 (1566892) States system redis pmessage io.messagebox.system.adapter.backitup.0/io.messagebox.system.adapter.backitup.0:{"command":"getSystemInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":39,"ack":false,"time":1780997936317},"_id":60003566}
    2026-06-09 11:38:56.324  - silly: backitup.0 (1566892) sendTo "getSystemInfo" to system.adapter.admin.0 from system.adapter.backitup.0
    2026-06-09 11:38:59.234  - info: admin.0 (1566804) <== Disconnect system.user.admin from ::ffff:192.168.178.42 backitup
    2026-06-09 11:39:00.544  - info: admin.0 (1566804) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 11:39:11.830  - info: admin.0 (1566804) <== Disconnect system.user.admin from ::ffff:192.168.178.42 javascript
    2026-06-09 11:39:12.144  - info: admin.0 (1566804) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 11:39:15.233  - info: admin.0 (1566804) <== Disconnect system.user.admin from ::ffff:192.168.178.42
    2026-06-09 11:39:15.933  - info: admin.0 (1566804) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 11:39:17.385  - info: admin.0 (1566804) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2026-06-09 11:39:18.782  - info: admin.0 (1566804) <== Disconnect system.user.admin from ::ffff:192.168.178.42 echarts
    2026-06-09 11:39:18.785  - info: admin.0 (1566804) <== Disconnect system.user.admin from ::ffff:192.168.178.42 echarts-show
    ============= Mark until here for C&P =============
    @Bernd_L sagte:
    Was steht da drin?
      @Bernd_L sagte:
      Was steht da drin?
      Ich würde:
      Das Ding soweit wie noch möglich auf Stand bringen.
      iob stop
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      iob stop
      iob fix
      iob stop
      iob nodejs-update
      iob update
      iob upgrade all
      iob stop
      iob upgrade self
      iob start
      Und dann von Endergebnis ein Backup (nur ioBroker!) ziehen, das aktuelle RaspberryOS 13 'Trixie' komplett neuinstallieren (am besten auf einem neuen Datenträger), den ioBroker dort 'leer' installieren und dann das Backup dort einspielen.
        Bernd_L
        [Fri Jun 5 18:51:37 2026] hwmon hwmon1: Undervoltage detected!
        [Fri Jun 5 19:29:03 2026] hwmon hwmon1: Undervoltage detected!
        [Mon Jun 8 15:51:26 2026] hwmon hwmon1: Undervoltage detected!
        [Mon Jun 8 18:48:00 2026] hwmon hwmon1: Undervoltage detected!
        Ich weiß von einem Shelly flood dessen Batterie leer war, habe ich vor einer halben Stunde erneuert
        • B Bernd_L
          @Bernd_L sagte:
          Die Meldung kommt aber nicht vom Shelly sondern vom Raspberry. Verwendest du da das originale Netzteil?
          Irgendwelche Handy-Ladegeräte oder sowas sind keine stabilen Netzteile, es sind halt nur 'Ladegeräte'.
            @Bernd_L sagte:
            Bernd_L
            @Thomas-Braun
            Das ist das Original-Netzteil.
            Thomas BraunT Dr. BakteriusD 2 Antworten Letzte Antwort
            • B Bernd_L
              @Thomas-Braun
              @Bernd_L
              Okay.
              Hast du noch irgendwas an Peripherie an dem Ding hängen? Denn 58x 'dicke Backen' machen ist mit Sicherheit nicht normal.
                @Bernd_L
                Okay.
                Bernd_L
                @Thomas-Braun
                An dem Netzteil hängt nichts weiter dran, läuft seit Jahren ohne Probleme,
                An der Mehrfachsteckdose (240V) selbstverständlich.
                • B Bernd_L
                  @Thomas-Braun
                  @Bernd_L sagte:
                  Dein System sagt was anderes...
                    @Bernd_L sagte:
                    Bernd_L
                    @Thomas-Braun
                    Bis auf die anfangs beschriebene Meldung hatte ich bisher - bis auf einzelne Adapterupdate-Hinweise - keine Probleme. Zumindest keine entsprechende Meldungen. Werde mal kramen ob ich noch ein anderes Netzteil mit passenden Ausgangswerten habe.
                    • B Bernd_L
                      @Thomas-Braun
                      @Bernd_L sagte:
                      Doch, aber du schaust dir diese Meldungen ja offenbar nicht an .
                      • B Bernd_L
                        @Thomas-Braun
                        @Bernd_L sagte:
                        Da das Betriebssystemmeldungen sind, musst du auch dort nachsehen.
                        Da hat ioBroker nichts mit zu tun.
                        Die eingangs genannte Meldung ist ein Service von ioBroker damit man das Betriebssystem nicht ganz vergisst.
                          @Bernd_L sagte:
                          Bernd_L
                          @Thomas-Braun
                          Danke für den Watschen - aber für nicht-ITler sind Meldungen mit Hyoglyphen wenig aussagekräftig. Und solchen Meldungen versuche ich hier auf den Grund zu gehen. Außerdem lassen zumindest für mich Meldungen nach Updates nicht darauf schließen dass ein Netzteil defekt ist.
                          Okay, weiter im Text: Ich habe soeben festgestllt, dass an dem USB-C Port des Netzteils eventuell ein Wackelkontakt sein Unwesen treibt, je nachdem wie herum der Stecker eingesteckt ist.
                          Was sollte ich jetzt machen bevor ich die obigen Empfehlungen von Dir ausführe?
                            @Bernd_L sagte:
                            Bernd_L
                            @Homoran
                            ..und wo muss sich als Bäcker, Klemptner, Gärtner wie regelmäßig nach Betriebssystemmeldungen nachsehen? Ich war davon ausgegangen, dass, wenn keine Meldungen erfolgen auch alles in grünem Bereich ist.
                            • B Bernd_L
                              @Thomas-Braun
                              @Bernd_L sagte:
                              Das ist auch sehr löblich!
                              Bei der regelmäßigen (14-tägigen) Systempflege über die Konsole mit sudo apt update && sudo apt full-upgrade sollten diir zumindest einige der Glyphen schon untergekommen sein.
                              Wenn man sich dann ab und zu den Gesundheitszustand des gesamten Systems mit iob diag ansieht bekommt man einen Gesamtübersicht.
                              Oder machst du auch nur Updates bei Office, fährst aber immer noch auf WIN95?
                              EDIT:
                              Hat sich jetzt überschnitten!
                              Das war meine Reaktion auf deinen vorigen Post.
                              Bleiben noch Fragen, oder reichen die Infos?
                              • B Bernd_L
                                @Thomas-Braun
                                @Bernd_L sagte:
                                Für eine stabile Spannungsversorgung sorgen.
                                  @Bernd_L sagte:
                                  @Thomas-Braun sagte:
                                  @bernd_l
                                  ....Aber vor dem Wechsel des Netzteiles sauber herunterfahren!
                                    @bernd_l
                                    @Homoran sagte:
                                    Das ohnehin.
                                      @Bernd_L sagte:
                                      EDIT:
                                      Bernd_L
                                      @Homoran
                                      Ich danke die für die ergänzenden Hinweise zur "Bedienungsanleitung des Betriebssystems" Nehme mir das zu Herzen und werde versuchen das zu verinnerlichen. 😊
                                      • B Bernd_L
                                        @Homoran
                                        @Bernd_L Sehr gut!
                                        Wenn an dem Pi nicht noch USB Laufwerke, diverse USB-Sticks für zigbee/Leseköpfe o.ä. hängen sollte es bei e7nem guten Netzteil keine Undervoltage geben.
                                        Dann jetzt bitte deinen Dinosaurier so gut es geht aktualisieren und Backup machen
                                        • B Bernd_L
                                          @Homoran
                                          @Bernd_L
                                          Du kannst in das Systemlog auch in einer zweiten Session reinschauen, während du mit dem System spielst.
                                          sudo dmesg -wT
