  3. Entwicklung
  4. [Neuer Adapter] Reolink Kamera
reolinkneuer adaptertestenkamera
1.1k Beiträge 166 Kommentatoren 679.4k Aufrufe 146 Beobachtet
  • chucky666C chucky666
    @bloop danke für deine mühe
    reicht das ?
    	2026-06-05 12:11:39.065	info	Battery camera ready!
    reolink.2
    2026-06-05 12:11:39.017	debug	RTSP Sub Stream URL (when enabled): rtsp://127.0.0.1:8554/Haustuer/subStream
    reolink.2
    2026-06-05 12:11:39.016	debug	RTSP Main Stream URL (when enabled): rtsp://127.0.0.1:8554/Haustuer/mainStream
    reolink.2
    2026-06-05 12:11:39.016	debug	Battery camera states created
    reolink.2
    2026-06-05 12:11:38.961	debug	MQTT topics will use camera name: Haustuer
    reolink.2
    2026-06-05 12:11:38.961	info	Battery camera configured: Haustuer
    reolink.2
    2026-06-05 12:11:38.952	info	✅ ffmpeg found (7.1.3-0+deb13u1) - Snapshot feature available
    reolink.2
    2026-06-05 12:11:38.952	info	✅ GStreamer RTSP library found (installed)
    reolink.2
    2026-06-05 12:11:38.899	debug	Checking system dependencies for battery camera...
    reolink.2
    2026-06-05 12:11:38.899	debug	HTTP camera states cleanup complete
    reolink.2
    2026-06-05 12:11:38.892	debug	Cleaning up HTTP camera states...
    reolink.2
    2026-06-05 12:11:38.892	info	Battery-powered camera detected - using neolink
    reolink.2
    2026-06-05 12:11:38.892	info	Reolink adapter has started
    reolink.2
    2026-06-05 12:11:38.839	info	starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.reolink, node: v22.22.0, js-controller: 7.0.7
    reolink.2
    2026-06-05 12:11:38.772	debug	States connected to redis: 127.0.0.1:9000
    reolink.2
    2026-06-05 12:11:38.695	debug	States create User PubSub Client
    reolink.2
    2026-06-05 12:11:38.695	debug	States create System PubSub Client
    reolink.2
    2026-06-05 12:11:38.677	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    reolink.2
    2026-06-05 12:11:38.645	debug	Objects connected to redis: 127.0.0.1:9001
    reolink.2
    2026-06-05 12:11:38.644	debug	Objects client initialize lua scripts
    reolink.2
    2026-06-05 12:11:38.584	debug	Objects create User PubSub Client
    reolink.2
    2026-06-05 12:11:38.584	debug	Objects create System PubSub Client
    reolink.2
    2026-06-05 12:11:38.538	debug	Objects client ready ... initialize now
    reolink.2
    2026-06-05 12:11:38.505	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    bloop
    #1103
    @chucky666 Sieht alles ganz normal und vor allem korrekt aus...
    Wenn der Adapter korrekt eingerichtet ist und Startet sollten dir folgende Datenpunkte erstellt werden - unabhängig von der Kamera Version.
    Hast du sämtliche Einstellungen gemacht?
    chucky666C 1 Antwort Letzte Antwort
    • B bloop
      chucky666C Online
      chucky666C Online
      chucky666
      #1104
      @bloop welche Ip Adresse muss beim Broker rein ? Die von ioBroker oder ?
        #1105
        @chucky666 sagte:
        Edit: Jetzt genauer gelesen... Du meinst wohl den MQTT Host.
        Die IP des Host, auf dem MQTT läuft.
          bloop
          #1106
          @chucky666 funktioniert?
          • B bloop
            chucky666C Online
            chucky666C Online
            chucky666
            #1107
            @bloop er hat die Datenpunkte angelegt
            jetzt muss ich mich noch reinfuchsen , wie ich mir ein bild schicken kann .
            mqtt wird über zb bewegungsmelder aktiviert , habe ich das richtig verstanden ?
            • madingM Offline
              madingM Offline
              mading
              schrieb am zuletzt editiert von mading
              #1108
              Ich schicke mir ein Bild so per cgi:
              <block xmlns="https://developers.google.com/blockly/xml" type="procedures_defnoreturn" id="31W4)co*hfllBmNKD0j2" x="2713" y="-113">
                <field name="NAME">HaustuerBilderSchicken</field>
                <comment pinned="false" h="80" w="160">holt ein Bild vom der Cam und schickt es per Telegram</comment>
                <statement name="STACK">
                  <block type="controls_if" id="A6cOkP*h,n}ZilH7=u]+">
                    <value name="IF0">
                      <block type="get_value" id="2xz7D/{7Cr;$%oJ]Qkn-">
                        <field name="OID">reolink.0.network.connected</field>
                      </block>
                    </value>
                    <statement name="DO0">
                      <block type="http_get" id="P^;u4LBNv`?U^}YD(64+">
                        <field name="TIMEOUT">2000</field>
                        <field name="UNIT">ms</field>
                        <field name="TYPE">arraybuffer</field>
                        <value name="URL">
                          <shadow type="text" id="H]!+Lf(Nc%5_V~fo4v7O">
                            <field name="TEXT">http://192.168.253.148/cgi-bin/api.cgi?cmd=Snap&amp;channel=0&amp;rs=&amp;user=admin&amp;password=xyz</field>
                          </shadow>
                        </value>
                        <statement name="STATEMENT">
                          <block type="telegram" id="r8,YW-hqOMW(=su_.DVb">
                            <field name="INSTANCE">.0</field>
                            <field name="LOG"></field>
                            <field name="ESCAPING">FALSE</field>
                            <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                            <value name="MESSAGE">
                              <shadow type="text" id="9eq;NDr4^eD/Qs0(3wN5">
                              </shadow>
                              <block type="http_response_tofile" id="!:Ngwi;@%%gZV,lT;T,x">
                                <value name="FILENAME">
                                  <shadow type="text" id="tO6FZSDjDBqC[fXo`v+?">
                                    <field name="TEXT">temp.jpg</field>
                                  </shadow>
                                </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </statement>
                    <statement name="ELSE">
                      <block type="telegram" id="Ov9ho$a#M2b#*oVML:(|">
                          <shadow type="text" id="]ynKN#t)%{I1c=V__Q(U">
                            <field name="TEXT">Kamera Haustüre nicht erreichbar!</field>
                          </shadow>
                        </value>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
              Alternativ per rtsp ein Video so, wenn aktiviert (ffmpeg muss installiert sein, ich speichere das Video/ Bild lokal ab)
              <block xmlns="https://developers.google.com/blockly/xml" type="procedures_defnoreturn" id=":u%-]}+:Oq#$%z.*G/X`" x="1897" y="-321">
                <field name="NAME">HaustuereVideoSchicken</field>
                  <block type="comment" id="=;Hz#?O{6CO(;J.tKZ}z">
                    <field name="COMMENT">h264Preview_01_ext</field>
                    <next>
                      <block type="variables_set" id="CSw$Oh|zU}or7j|W4sSn">
                        <field name="VAR" id="fJUJCIN5HrB8Akm?Xu?R">Befehl</field>
                        <value name="VALUE">
                          <block type="text_join" id="D6.783^7hR8$?`tMsiG~">
                            <value name="ADD0">
                              <block type="text" id="GKb14HP_!Jd~d|6;SWTH">
                                <field name="TEXT">ffmpeg -y -i rtsp://admin:xyz@192.168.253.148:554/h264Preview_01_main -t </field>
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="math_number" id="M_4$tL0mfoUN(A`|pHri">
                                <field name="NUM">30</field>
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="Wj-o%7;;v,y(I~6-t*bK">
                                <field name="TEXT"> -f mp4 -vcodec libx264 -pix_fmt yuv420p -an -vf scale=1024:768 -r 15 /opt/iobroker/CamSnapshots/Haustuere.mp4</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                          <block type="exec" id="]Mmgt=)}fsMT=2m/c0ub">
                            <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                            <field name="WITH_STATEMENT">TRUE</field>
                            <value name="COMMAND">
                              <shadow type="text" id="e.P0Y4sWi?jQvW0Ikv9n">
                              </shadow>
                              <block type="variables_get" id="qF?QeOdsvtvtsgYP][Aq">
                              </block>
                            </value>
                              <block type="telegram" id="Ch~%tXvQ*FvZheza+M.o">
                                  <shadow type="text" id="`}*6Z.:`6}.?55h*`(Nb">
                                    <field name="TEXT">/opt/iobroker/AlarmCam/ImouFlur.jpg</field>
                                  </shadow>
                                  <block type="text" id="Mp89tz^y0ft*:zf$N__P">
                                    <field name="TEXT">/opt/iobroker/CamSnapshots/Haustuere.mp4</field>
                                  </block>
                                </value>
                                <next>
                                  <block type="timeouts_wait" id="gDyq4a]Em:EvTOg?ONqG">
                                    <field name="DELAY">10</field>
                                    <next>
                                      <block type="exec" id="N64}k!dt^P+9a7-86D//">
                                        <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
                                        <field name="WITH_STATEMENT">FALSE</field>
                                          </shadow>
                                          <block type="text" id="^([ZI#zcti8E-p5%1bvt">
                                            <field name="TEXT">rm /opt/iobroker/CamSnapshots/Haustuere.mp4</field>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
              Oder per rtsp ein Bild:
              <block xmlns="https://developers.google.com/blockly/xml" type="procedures_defnoreturn" id="cNF_P%7p$3q@)VlD9RcI" x="687" y="-637">
                <field name="NAME">GarageBilderSchicken</field>
                  <block type="controls_if" id="5tw0Kk9C6KhbOhQ~+3d8">
                    <value name="IF0">
                      <block type="get_value" id="1N0(UgIDYHG19GwbbI+$">
                        <field name="OID">eusec.0.T8410P41223309EE.station.connection</field>
                      </block>
                    </value>
                      <block type="comment" id="C8uJ;_BHTJphhr/4j,xx">
                        <field name="COMMENT">http://192.168.253.11:8082/cameras.0/Garage</field>
                        <next>
                          <block type="exec" id="LewQAJP*XK;thd40bnp:">
                              </shadow>
                              <block type="text" id="m^y_-S$pJwo56SgTek/E">
                                <field name="TEXT">ffmpeg -i rtsp://Tu8OYn4QhkgG:xyz@192.168.253.62:554/live0 -y -f image2 -vframes 1 -pix_fmt yuvj420p /opt/iobroker/CamSnapshots/CamGarageSnapshot.jpg</field>
                              </block>
                            </value>
                              <block type="comment" id="bAfw8iK2x[QY2B?+Itin">
                                <field name="COMMENT">drei Sekunden notwendig, sonst ist das Bild nicht da!</field>
                                <next>
                                  <block type="telegram" id="EgJ0^+uDz,a1M]:Y~|EW">
                                      </shadow>
                                      <block type="text" id="c~%%IGop3Y?SJSFM^g%j">
                                        <field name="TEXT">/opt/iobroker/CamSnapshots/CamGarageSnapshot.jpg</field>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="timeouts_wait" id="aNb2$yz%UDoh|4Z]1Z=3">
                                        <field name="DELAY">3</field>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                            <next>
                              <block type="exec" id="cST;?A^C7P*WEs9=5yN6">
                                  </shadow>
                                  <block type="text" id="Ef4JUzA*l21b9$@?Bu8q">
                                    <field name="TEXT">rm /opt/iobroker/CamSnapshots/CamGarageSnapshot.jpg</field>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                      <block type="telegram" id="L#,-Ju-EW_M0@;:vhv_#">
                          <shadow type="text" id="/[jrJ1?-TV.rY/7Hj[R_">
                            <field name="TEXT">Kamera Garage nicht erreichbar!</field>
                          </shadow>
                        </value>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
              • madingM mading
                      <value name="IF0">
                        </block>
                      </value>
                          <value name="URL">
                            </shadow>
                          </value>
                                </shadow>
                                    </shadow>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                        </block>
                      </statement>
                            </shadow>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
                      <next>
                              <value name="ADD0">
                                </block>
                              </value>
                              <value name="ADD1">
                                </block>
                              </value>
                              <value name="ADD2">
                                </block>
                              </value>
                            </block>
                          </value>
                          <next>
                                </shadow>
                                </block>
                              </value>
                                    </shadow>
                                    </block>
                                  </value>
                                  <next>
                                      <next>
                                            </shadow>
                                            </block>
                                          </value>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
                      <value name="IF0">
                        </block>
                      </value>
                          <next>
                                </shadow>
                                </block>
                              </value>
                                  <next>
                                        </shadow>
                                        </block>
                                      </value>
                                      <next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                              <next>
                                    </shadow>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </statement>
                            </shadow>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
                chucky666C Online
                chucky666C Online
                chucky666
                #1109
                @mading Danke dir , teste ich nächste Woche ( Urlaub )
                • madingM Offline
                  madingM Offline
                  mading
                  #1110
                  Das hätte ich jetzt schon zeitnah erwartet 😉 Ne, im Ernst: bei mir funktioniert es so gut, ich habe eine reolink und zwei eufy Cams. Reolink unterstützt die cgi-Variante, welche ohne de rtsp-Overhead funktioniert, was einfacher ist.
                    bloop
                    #1111
                    @chucky666
                    mqtt ist bei den Akku Kameras Standard aus, und kann über den State reolink.0.mqtt.enable für die in den Einstellungen unter "Auto-disable MQTT" eingestellte Zeit Aktiviert werden. Wenn du bei den Akku Kameras mqtt an lassen würdest ist der Akku binnen 24std leer. nur wenn mqtt aktiv ist, kommen auch Meldungen vom Bewegungsmelder.
                    Einzige mir bekannte Möglichkeit von einer Akku Kamera einen Eingangs "Eventtrigger" zu erhalten ist über den Mail Server...
                    Um dir einen Snapshot schicken zu lassen gibt es folgende States:
                    "snapshot" triggern
                    kurz warten und du hast das aktuell Bild im State "snapshotImage"
                    • B bloop
                      @chucky666
                      "snapshot" triggern
                      chucky666C Online
                      chucky666C Online
                      chucky666
                      #1112
                      @bloop danke für die Erklärung
                      Ich versuche mir morgen ein blocky zu basteln, und teste das mit dem snapshot
                      • ElirionE Offline
                        ElirionE Offline
                        Elirion
                        schrieb am zuletzt editiert von Elirion
                        #1113
                        Hey, erstmal vielen Dank für den Adapter und die Mühe :)
                        Ich hänge gerade aktuell an der Anbindung meiner Solar Kameras über den Hub. Wenn ich im Hub die RTSP Einstellungen aktiviere und im Adapter die IP von dem Hub eintrage, dann erstellt er Datenpunkte für den rtsp-Stream, allerdings mit der lokalen Adresse 127.0.0.1 und nicht mit der IP von meinem iobroker Host oder Reolink Hub(?).
                        iobroker läuft bei mir im Docker Container, daher keine Ahnung, ob das die Ursache ist.
                        Faktisch kann ich den Stream leider nicht öffnen. Wenn ich über die IP vom Hub direkt gehe mit dem link: rtsp://admin:pass@hubip:554/h264Preview_01_main dann bekomme ich ein Bild.
                        Logischerweise gehen Snapshots ebenfalls nicht, da er den Stream nicht öffnen kann. Daher die Frage: Woher nimmt er sich die Komponenten für den Stream zusammen?
                        Das sind meine Settings:
                        und so siehen die Objekte dazu aus:
                        • andre1deA Offline
                          andre1deA Offline
                          andre1de
                          #1114
                          ich habe RLC-811WA von Reolink.
                          In iOBroker erfolgreich integriert, aber Push-Steuerung geht bei mir nicht.
                          Ich habe hier gelesen, dass möglicherwiese true/false von der Kamera nicht akzeptieren wird.
                          Mit oben beschriebenen Scripts komme ich nicht klar, weil ich nicht weiß, in welche Dateien ich sie schreiben soll.
                          Kann jemand das für solche Anfänger wie ich deutlicher beschreiben oder gibt es schon andere Möglichkeiten?
                          Danke!
                          • ElirionE Elirion
                            bloop
                            #1115
                            @Elirion
                            Guten Abend,
                            In der Akku Kamera Funktion wurde eine Verwendung des Hubs von Reolink nicht beachtet. Es gibt bisher keine RTSP-Host/Port-Option für eine Verwendung von Akku Kameras über Hub. Allerdings sollte ein Betrieb ohne den Extra Hacken bei Akkubetriebene Kamera möglich sein. Du sprichst aktuell ja mit dem Hub und nicht mit der Kamera direkt.
                            Ich arbeite bereits an einer Lösung. Bitte versuche die Version auf Github:
                            https://github.com/bloop16/ioBroker.reolink/tree/fix/rtsp-stream-stability
                            Habe eine fix eingespielt mit dem nun die angegebenen Adressen korrekt übernommen werden sollten.
                            Leider habe ich keinen Hub weshalb ich mir mit einer Umsetzung schwer tue.
                            • ElirionE Offline
                              ElirionE Offline
                              Elirion
                              #1116
                              Hey @bloop,
                              danke dir für die Rückmeldung.
                              Also ich hab mich da auch etwas eingelesen.
                              Der Verbindungsaufbau bei dem Hub ist wie folgt:
                              Hub baut eigene Netze (2,4 und 5GHz) auf und die kameras verbinden sich dann dazu. Ansprechbar im eigenen Netz ist nur der Hub.
                              Wenn man einen Stream öffnen will, läuft es über die Adresse vom Hub.
                              Der Aufbau des Streams ist dann wie folgt:
                              rtsp://admin:<Passwort>@<IP des Hubs>:<hinterlegter Port, Standard ist 554, kann aber auch geändert werden>/h264Preview_<Kamera Channel>_main
                              So ergibt sich dann bspw.:
                              rtsp://admin:Password@192.168.1.44:8554/h264Preview_01_main für Kamera 1 und für die 2 Preview02_main.
                              Eventuell reicht das ja schon um etwas in deinen Adapter zu integrieren? Ob hier allerdings dann auch Pushnachrichten bei Bewegung rausgeschickt werden, weiß ich nicht.
                              Ich wäre gern bereit zu testen :)
                              • andre1deA andre1de
                                Danke!
                                bommel_030
                                #1117
                                @andre1de
                                Hast du Push in der Kamera aktiviert? Das muss aktiviert sein, sonst kann der Adapter nichts machen.
                                andre1deA 1 Antwort Letzte Antwort
                                • B bommel_030
                                  @andre1de
                                  andre1deA Offline
                                  andre1deA Offline
                                  andre1de
                                  schrieb am zuletzt editiert von andre1de
                                  #1118
                                  @bommel_030
                                  Push ist in der Kamera aktiviert. Ich versuche in ioBroker beim Objekt „push“ den Wert auf „false“ zu setzen. In der Kamera bleibt Push jedoch weiterhin aktiv.
                                  Genauso ist es umgekehrt: Wenn Push in der Kamera ausgeschaltet ist, kann ich es über ioBroker mit „true“ nicht einschalten.
                                  Das Umschalten anderer Funktionen, zum Beispiel der Aufnahme (scheduledRecording), funktioniert dagegen.
                                  Die Kamera ist per WLAN mit dem Netzwerk verbunden. Und den Wert von "push" ( true/false) in IoBroker wird rot angezeigt.
                                  Andere Kameras sind an den NVR angeschlossen – dort lässt sich Push über ioBroker problemlos steuern.
                                    @bommel_030
                                    bommel_030
                                    #1119
                                    @andre1de
                                    Hast du es mal ausprobiert? Push in der Kamera aktivieren, per ioBroker auf false setzen, vor der Kamera rumhüpfen...
                                    Bei RLC-822A, E1 Zoom und E1 Outdoor PoE kommt mit der Konfiguration defintiv keine Push Nachricht.
                                    • andre1deA Offline
                                      andre1deA Offline
                                      andre1de
                                      #1120
                                      Hab´s gerade probiert - funktioniert. Push Nachricht kommt.
                                      Ich habe RLC-811WA .
                                      • ElirionE Elirion
                                        Hey @bloop,
                                        bloop
                                        #1121
                                        @Elirion ähnlich habe ich die integration in den Reolink Adapter realisiert. Im Hintergrund läuft ebenfalls ein kleines tool (neolink) welches für die angegebene Zeit den Stream öffnet.
                                        Hast du die Möglichkeit und Erfahrung neolink zu testen?
                                        https://github.com/QuantumEntangledAndy/neolink
                                        Wenn es dir da gelingt eine Verbindung zum Hub herzustellen, ist eine Umsetzung im Adapter kein problem.
                                        Was ich gleich dazu sagen muss:
                                        Aktuell gibt es trotz verschiedener Github Projekte (neolink, nodelink-js, bairelay) noch keine Möglichkeit einen push von einer Akku Kamera zu erhalten. Wie das beim Hub funktioniert weis ich leider nicht.
                                        Ich habe es immer noch über E-Mail und Verarbeitung mit dem imap Adapter realisiert.
                                        ElirionE 1 Antwort Letzte Antwort
                                        • B bloop
                                          ElirionE Offline
                                          ElirionE Offline
                                          Elirion
                                          #1122
                                          @bloop
                                          Ich werde schauen, was ich rausfinde. Melde mich, wenn ich fündig geworden bin ;)
                                          Nachtrag: zumindest scheint es für Home Assistant zu funktionieren. Also mal sehen ...
