  4. Zigbee PAN ID Update auf 3.05
    6.3k
19 Beiträge 3 Kommentatoren 1.1k Aufrufe 6 Beobachtet
  • R rewenode
    @asgothian Also,
    1. Adapter geupdated auf 3.05
    4. Zigbee startet alle Geräte arbeiten ok. Ein paar Warnungen im Log:
    zigbee.0
    false2025-10-04 14:38:50.474	warn	DeviceConfigure:0x50325ffffe29eae3 TS0101 Failed to configure. --> ZCL command 0x50325ffffe29eae3/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    zigbee.0
    false2025-10-04 14:38:46.953	warn	DeviceConfigure:0x847127fffe29b7cd TS0601 Failed to configure. --> ZCL command 0x847127fffe29b7cd/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    zigbee.0
    2025-10-04 14:38:42.681	warn	error removing /tmp/LYWSD03MMC.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/LYWSD03MMC.png"}
    zigbee.0
    2025-10-04 14:38:42.651	warn	error removing /tmp/RTCGQ01LM.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/RTCGQ01LM.png"}
    zigbee.0
    false2025-10-04 14:38:42.649	warn	error removing /tmp/MCCGQ01LM.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/MCCGQ01LM.png"}
    zigbee.0
    false2025-10-04 14:38:42.648	warn	error removing /tmp/ZBMINI-L.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/ZBMINI-L.png"}
    zigbee.0
    false2025-10-04 14:38:42.610	warn	error removing /tmp/TS0044_1.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/TS0044_1.png"}
    zigbee.0
    false2025-10-04 14:38:42.608	warn	error removing /tmp/TS0042.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/TS0042.png"}
    zigbee.0
    2025-10-04 14:38:42.606	warn	error removing /tmp/AC08560-DIM.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/AC08560-DIM.png"}
    zigbee.0
    2025-10-04 14:38:42.604	warn	error removing /tmp/ZG-204Z.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/ZG-204Z.png"}
    zigbee.0
    2025-10-04 14:38:42.603	warn	error removing /tmp/WSDCGQ11LM.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/WSDCGQ11LM.png"}
    zigbee.0
    2025-10-04 14:38:39.990	warn	DeviceConfigure:0xa4c1380f4872d0f9 TS011F Failed to configure. --> ZCL command 0xa4c1380f4872d0f9/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    Scheint also erstmal ohne Probleme mit den 16D zu arbeiten.
    Gibt es einen zwingenden Grund die 16D auf die Schnelle loszuwerden?
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @rewenode sagte in Zigbee PAN ID Update auf 3.05:
    @asgothian Also,
    Nein. Aber wenn du den Koordinator (die Hardware) tauschen musst kann es sein das du alles neu anlernen musst.
    Bist du sicher das die 16D erhalten bleiben, wenn du auf read nvram backup klickst ?
    A.
    R 2 Antworten Letzte Antwort
    • AsgothianA Asgothian
      @asgothian Also,
      A.
      rewenode
      @asgothian sagte in Zigbee PAN ID Update auf 3.05:
      Nein, da bin ich nicht sicher, das habe ich noch nicht gemacht. Wollte vorsichtshalber das Zigbee.0 verz. sichern.
        @asgothian Also,
        A.
        rewenode
        @asgothian Sieht jetzt so aus:
        Muss ich die extPAN in die Einstellungen übertragen? da stehen nämlich immer noch 16D drin.
        R 1 Antwort Letzte Antwort
        • R rewenode
          rewenode
          @rewenode Ok, vergiss den letzten Post. Hab wohl nicht richtig NVRam geklickt. Jetzt sind die Daten automatisch übernommen und alles läuft wie geschmiert.
          Herzlichen Dank für deine Hilfe und Geduld!
            Aaaber, ich habe noch aus grauen Vorzeiten eine Extendet Pan ID: DDDDDDDDDDDDDDDD
            Ja, hab mal irgendwo gelesen das das keine gute Idee ist. Allerdings werde ich die wohl nicht mehr los ohne komplett neu anzulernen?
            Bei 60 Geräten und unzähligen Skripts etc. eine Horrorvorstellung.
            Muss ich mir Sorgen machen? Bzw. was muss ich beachten?
            Falls das schon irgendwo steht, bitte um Entschuldigung und wäre über einen entsprechenden Link dankbar.
            Nein, der 3.x adapter erlaubt es dir zu probieren davon weg zu kommen ohne das du irgendwas neu anlernen musst:
            1. Konfiguration öffnen
            2. Auf die Hardware-Seite gehen. Nach grünen Haken / orangenen Dreiecken / roten Kreuzen schauen. Die 16D sollten mit einem gelben Dreieck und einem roten X markiert sein
            3. das Zigbee Subsystem anhalten. Screenshot 2025-10-03 at 15.17.58.png Wichtig: der Folgende Text muss im Fenster und dieses Icon oben in der Titelzeile erscheinen. (Was schwarz und was rot ist kann anders sein - das Icon muss aber da sein, in rot und schwarz, nicht Orange und schwarz›Screenshot 2025-10-03 at 15.19.54.png
            stopping zigbee-herdsman
            Closing network.
            herdsman stopped !
            1. Die Daten des nvRam Backups einlesen
            An dieser Stelle können 3 Dinge passieren:
            Option 1 und 2 beginnen gleich: Das Zigbee-Subsystem startet normal, das rote Icon verschwindet, und die normalen Log Meldungen tauchen im Fenster auf (bsp:)
            overriding zigbee options with:
            extPanID : 4153102e004b1200
            panID : 3788
            channel : 11
            port : tcp://192.168.2.55:6638
            adapterType : zstack
            baudRate : 115200
            precfgkey : 01030507090b0d0f00020406080a0c0d
            flowCTRL : true
            Starting Adapter npm ...
            Installed Version: undefined (Converters 25.31.0 Herdsman 6.1.3)
            Starting zigbee-herdsman...
            Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20240710 (2-1.2.7.1)
            Network parameters: panID=3788 channel=11 extendedPanID=4153102e004b1200
            Unable to disable LED, unsupported function.
            8 devices and 5 groups are part of the network
            In diesem Fall solltest du (am besten in einem 2. Browserfenster) versuchen die Geräte zu schalten, um zu schauen ob sie wirklich alle da sind.
            Die Geräte funktionieren wirklich => das ist Option 1. Einstellungen speichern, Adapter neu starten, 16D los geworden.
            Die Geräte funktionieren nicht aber es gibt keine Meldungen => Netzwerk zum pairing öffnen und die Geräte extern triggern. (bei Sensoren => eine Statusmeldung zwingen, bei Fernbedienungen knöpfe drücken, etc.). Wenn sie dann gehen, dann hattest du Option 2 => weiter bei Option 1.
            In allen anderen Fällen gilt Option 3 - Log Meldungen posten :)
            Option 3: Das icon wird orange und dann wieder Rot - in diesem Fall musst du die Meldungen hier posten. Aus den Meldungen geht hervor was passiert ist.
            Wichtig dabei ist: solange du die Konfiguration nicht abspeicherst solltest du durch anhalten und Adapter neu starten immer zum vorherigen Stand zurück kommen.
            A.
            Nachtrag: zur Sicherheit solltest du ein Backup von nvbackup.json und shepherd.db machen bevor du damit beginnst - dazu vorher den Adapter anhalten !
            Meister MopperM Online
            Meister Mopper
            @Asgothian
            Ich danke dir für die Erläuterungen, ich habe jetzt zwei unabhängige Systeme auf v3.3.5 gebracht und einen neuen Transport Key erhalten. Alle Geräte wurden erkannt.
            Warum hat sich aber die ExtPanID nicht geändert?
            Proxmox und HA ...
            • AsgothianA Offline
              AsgothianA Offline
              Asgothian
              Weil du ein bestehendes System aktualisiert hast - da darf sich die ExtPanID eigentlich nicht ändern
              A.
                A.
                Meister Mopper
                @Asgothian sagte:
                A.
                Wie reagiere ich jetzt schlau (mit meinen möglichkeiten)?
                Proxmox und HA ...
                  AsgothianA Offline
                  Asgothian
                  Was meldet das System in diesem Dialog wenn du das Zigbee Netz startest ?
                  A.
                    A.
                    Meister Mopper
                    @Asgothian
                    Leider nichts, der Dialog ist bei mir leer, oder muss ich da noch etwas händisch aktualisieren?
                    Proxmox und HA ...
                      AsgothianA Offline
                      Asgothian
                      Na ja, du gehst auf die seite, hältst das zigbee Netz an (mit dem Start stop Button), wartest bis da `herdsman stopped steht, dann startest du es wieder
                      A.
                      • Meister MopperM Online
                        Meister Mopper
                        @asgothian
                        extPanID : DDDDDDDDDDDDDDDD
                        panID : 6754
                        channel : 15
                        port : /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
                        baudRate : 115200
                        precfgkey : 01030507090B0D0F00020406080A0C0D
                        flowCTRL : true
                        Installed Version: iobroker.zigbee@3.3.5 (Converters 25.112.0 Herdsman 8.1.0)
                        Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20210120 (2-1.2.7.1)
                        Network parameters: panID=6754 channel=15 extendedPanID=dddddddddddddddd
                        37 devices are part of the network
                        Proxmox und HA ...
                          AsgothianA Offline
                          Asgothian
                          Schlechte Nachrichten - um die 16D loszuwerden musst du wahrscheinlich alle Geräte neu anlernen, nachdem du Tramsportverschlüsselung und extPanID geändert hast
                          A.
                            A.
                            Meister Mopper
                            @Asgothian
                            Danke, dann bleibt es so, wie es jetzt ist.
                            Proxmox und HA ...
