  4. Tester gesucht: Zigbee 3.4.10
    2.4k
    4.3k
134 Beiträge 18 Kommentatoren 9.8k Aufrufe 16 Beobachtet
  • AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #74
    Ich hatte 12 gewählt, und sie kommen nur bei Webkit an. Ich muss nochmal schauen - ich hab aktuell 2 unterschiedliche Entwicklungszweige.
    A.
    • WinniW Winni
      @Asgothian ok
      I01: Zigbee Event of Type commandTuyaAction from device 0xa4c13881cc14bf1f, incoming event: {"type":"commandTuyaAction","data":{"value":0,"data":{"type":"Buffer","data":[]}},"linkquality":66,"groupID":0,"cluster":"genOnOff","meta":{"rawData":{"type":"Buffer","data":[1,145,253,0]},"zclTransactionSequenceNumber":145,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":4}
      I04: value generated '66' from device a4c13881cc14bf1f for 'Link quality'
      I02: 1 converter available for '_TZ3000_mh9px7cq' 'a4c13881cc14bf1f' with cluster 'genOnOff' and type 'commandTuyaAction'
      I02.1a: converter 1 : Cluster genOnOff
      I02.0b: data: {"value":0,"data":{"type":"Buffer","data":[]}} options: {} meta:{"deviceIEEE":"0xa4c13881cc14bf1f","logger":"StatesController","state":{"state":""}} result:{"action":"4_single"}
      I02.1c: candidates: [{"action":"4_single"}] => payload {"action":"4_single"}
      I03: message received '{"action":"4_single"}' from device a4c13881cc14bf1f type '_TZ3000_mh9px7cq'
      I04-1: value generated '"4_single"' from device a4c13881cc14bf1f for 'Triggered action (e.g. a button click)'
      I04-2: value 'undefined' from device a4c13881cc14bf1f via getter for '1_single (ID 1_single with property action)
      ESTATE: unable to enumerate states of a4c13881cc14bf1f for payload {"action":"4_single"}, TypeError (Cannot read properties of undefined (reading 'key')).
      I01: Zigbee Event of Type commandTuyaAction from device 0xa4c13881cc14bf1f, incoming event: {"type":"commandTuyaAction","data":{"value":0,"data":{"type":"Buffer","data":[]}},"linkquality":66,"groupID":0,"cluster":"genOnOff","meta":{"rawData":{"type":"Buffer","data":[1,144,253,0]},"zclTransactionSequenceNumber":144,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":3}
      I02.0b: data: {"value":0,"data":{"type":"Buffer","data":[]}} options: {} meta:{"deviceIEEE":"0xa4c13881cc14bf1f","logger":"StatesController","state":{"state":""}} result:{"action":"3_single"}
      I02.1c: candidates: [{"action":"3_single"}] => payload {"action":"3_single"}
      I03: message received '{"action":"3_single"}' from device a4c13881cc14bf1f type '_TZ3000_mh9px7cq'
      I04-1: value generated '"3_single"' from device a4c13881cc14bf1f for 'Triggered action (e.g. a button click)'
      ESTATE: unable to enumerate states of a4c13881cc14bf1f for payload {"action":"3_single"}, TypeError (Cannot read properties of undefined (reading 'key')).
      I01: Zigbee Event of Type commandTuyaAction from device 0xa4c13881cc14bf1f, incoming event: {"type":"commandTuyaAction","data":{"value":0,"data":{"type":"Buffer","data":[]}},"linkquality":66,"groupID":0,"cluster":"genOnOff","meta":{"rawData":{"type":"Buffer","data":[1,143,253,0]},"zclTransactionSequenceNumber":143,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":2}
      I02.0b: data: {"value":0,"data":{"type":"Buffer","data":[]}} options: {} meta:{"deviceIEEE":"0xa4c13881cc14bf1f","logger":"StatesController","state":{"state":""}} result:{"action":"2_single"}
      I02.1c: candidates: [{"action":"2_single"}] => payload {"action":"2_single"}
      I03: message received '{"action":"2_single"}' from device a4c13881cc14bf1f type '_TZ3000_mh9px7cq'
      I04-1: value generated '"2_single"' from device a4c13881cc14bf1f for 'Triggered action (e.g. a button click)'
      ESTATE: unable to enumerate states of a4c13881cc14bf1f for payload {"action":"2_single"}, TypeError (Cannot read properties of undefined (reading 'key')).
      Passt das, oder brauchst du noch mehr?
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #75
      @Winni Kannst du mal bitte auf deinem System von Hand patchen:
      • in der Datei /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js
      • die Zeile 1260 von if (publishResult.key) auf if (publishResult?.key) wechseln
      • den adapter neu starten
      A.
      WinniW 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        A.
        WinniW Offline
        WinniW Offline
        Winni
        #76
        @Asgothian Volltreffer funktioniert. Super, vielen Dank. 😀
          AsgothianA Offline
          Asgothian
          #77
          3.4.5 ist raus. mit bugfix für Winni und breiteren Webkit toolbars.
          A.
          FabioF haselchenH 2 Antworten Letzte Antwort
          • WinniW Offline
            WinniW Offline
            Winni
            #78
            Habs installiert und läuft 👍
              A.
              FabioF Offline
              FabioF Offline
              Fabio
              schrieb am zuletzt editiert von Fabio
              #79
              @Asgothian sagte:
              A.
              Läuft ohne Probleme, vielen Dank.
              Herzliche Grüße
              Fabio
              Iobroker:
              • Matter over Thread Hilfe
                A.
                haselchenH Offline
                haselchenH Offline
                haselchen
                #80
                @Asgothian
                Seit 3.3.5 funktioniert der 4 fach Switch nicht mehr.
                Bin wieder zurück auf die 3.3.5, da funktionieren wieder alle Buttons.
                  AsgothianA Offline
                  Asgothian
                  #81
                  Welche Version hattest du ? die 3.4.5 sollte das Problem behoben haben.
                  A.
                    A.
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    #82
                    @Asgothian
                    Gute Frage .
                    Könnte die 3.4.4 gewesen sein.
                    Ich mach nochmal nen Update und schau mal.
                    Edit: @asgothian geht mit der 3.4.5 wieder. Top und Danke.
                      Supernils
                      #83
                      Hallo @asgothian
                      Ich nutze 3.4.5 und es gibt viele warnings im Log:
                      zigbee.0
                      2026-05-22 06:55:58.099	warn	reading 0x00178801099dd468-EP-11-CL-8
                      zigbee.0
                      2026-05-22 06:55:58.097	warn	reading 0x00178801099dd468-EP-11-CL-6
                      zigbee.0
                      2026-05-22 06:55:48.180	warn	reading 0x00178801099dd468-EP-11-CL-8
                      zigbee.0
                      2026-05-22 06:55:48.178	warn	reading 0x00178801099dd468-EP-11-CL-6
                      zigbee.0
                      2026-05-22 06:55:38.263	warn	reading 0x00178801099dd468-EP-11-CL-8
                      zigbee.0
                      2026-05-22 06:55:38.261	warn	reading 0x00178801099dd468-EP-11-CL-6
                      zigbee.0
                      2026-05-22 06:55:28.351	warn	reading 0x00178801099dd468-EP-11-CL-8
                      zigbee.0
                      2026-05-22 06:55:28.350	warn	reading 0x00178801099dd468-EP-11-CL-6
                      zigbee.0
                      2026-05-22 06:55:18.448	warn	reading 0x00178801099dd468-EP-11-CL-8
                      zigbee.0
                      2026-05-22 06:55:18.447	warn	reading 0x00178801099dd468-EP-11-CL-6
                      Wie kann ich das fixen? Bzw. ist es ein Bug?
                        AsgothianA Offline
                        Asgothian
                        #84
                        Aktuell kannst du das nur fixen indem du den Adapter selber patchst. Die Meldungen kommen weil du ein 'Binding' benutzt, und der Adapter von dem gebundenen Device die relevanten States versucht auszulesen. Der entsprechende Code (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js, Zeile 1415ff) ist im Spoiler hinterlegt. Es ist hinreichend, die Zeilen die mit this.warn beginnen auszukommentieren (mit //)
                        Wobei ich durchaus überrascht bin das du diese Meldung alle 10 Sekunden bekommst. Kannst du bitte mal einen Screenshot vom Bindings Tab posten ?
                                                 switch (cluster) {
                                                    case 768:
                                                    case 'lightingColorControl':
                                                            const handle = this.boundReads[key];
                                                            if (handle) clearTimeout(handle);
                                                            this.boundReads[key] = setTimeout(() => {
        try {
        this.adapter.emit('sendToZigbee', { message: {id:target.address, ep: target.endpoint, cid:cluster, cmd:'read', cmdType:'foundation',
        zclData:{ 'currentHue':{}, 'currentSaturation':{}, 'currentX':{}, 'currentY':{}, 'colorTemperature':{}} }});
        this.warn(`reading ${key}`);
        delete this.boundReads[key];
        } catch (error) {
        this.warn('bla');/* intentionally empty */}
                                                            }, 500);
                                                        break;
                                                    case 6:
                                                    case 'onOff':
        try {
        this.adapter.emit('sendToZigbee', { message: {id:target.address, ep: target.endpoint, cid:cluster, cmd:'read', cmdType:'foundation', zclData:{ 'onOff':{}} }});
        } catch (error) {
                                                            }, 500);
                                                        break;
                                                    case 8:
                                                    case 'genLevelCtrl':
        try {
        this.adapter.emit('sendToZigbee', { message: {id:target.address, ep: target.endpoint, cid:cluster, cmd:'read', cmdType:'foundation', zclData:{ 'currentLevel':{}} }});
        } catch (error) {
                                                            }, 500);
                                                        break;
                          Supernils
                          #85
                          @asgothian
                            AsgothianA Offline
                            Asgothian
                            #86
                            Hast du die Knöpfe der Fernbedienung entsprechend oft gedrückt oder kommen die Meldungen automatisch ?
                            A.
                              Supernils
                              #87
                              Automatisch alle zwei Stunden
                                AsgothianA Offline
                                Asgothian
                                #88
                                Ok, danke
                                  AsgothianA Offline
                                  Asgothian
                                  #89
                                  Du kannst versuchen von hier die aktuelle Alpha zu installieren - da gibt es dann weniger Meldungen, aber mit mehr Infos so das ich die Meldungen ggf. unterdrücken kann.
                                  Die Meldungen die dann automatisch kommen bräuchte ich dann.
                                  Die sehen dann so aus:
                                  zigbee.0
                                  	2026-05-23 20:03:09.711	warn	reading 0xa4c1388325e7845e-EP-3-CL-6 for message type commandOff
                                  zigbee.0
                                  	2026-05-23 20:03:09.701	warn	reading 0x000b57fffe8f487d-EP-1-CL-6 for message type commandOff
                                  zigbee.0
                                  	2026-05-23 20:03:06.833	warn	reading 0xa4c1388325e7845e-EP-3-CL-6 for message type commandOn
                                  A.
                                  https://github.com/asgothian/ioBroker.zigbee
                                    AsgothianA Offline
                                    Asgothian
                                    #90
                                    Die Version 4.5.6 sollte in kürze auf NPM und im Latest auftauchen. Folgende Anpassungen sind da drin:
                                    • update auf ZHC 26.63 / ZH 10.3
                                    • Sentry plugin entfernt
                                    • halbautomatisches OTA mittels 2 DP's
                                      --zigbee.0.info.ota um einen OTA Check über alle Geräte zu starten,
                                      -- zigbee.0.info.ota_available mit einer Liste von Geräten für die ein ota Update möglich ist
                                      -- start einzeln am Gerät (via 'startota' oder 'start_ota' als Text im DP 'send_payload')
                                      -- start für alle Geräte (einfach das Array ohne 'ack' in den DP 'ota_available' schreiben.
                                    • bugfix beim automatischen Neustart nach Verbindungsverlust.
                                    Tester sind willkommen - wenn es keine Auffälligkeiten gibt würde ich diese Version gerne ins Stable bringen (zum Ende des Monats)
                                    A.
                                      A.
                                      M Online
                                      M Online
                                      mrjeschke
                                      schrieb am zuletzt editiert von mrjeschke
                                      #91
                                      @Asgothian
                                      Mit der Version 3.4.6 kann ich die Gruppe nicht mehr bedienen. (1 Philips Hue / 1 Steckdose)
                                      Fehlermeldung:
                                      ELEVATED:EXPUB (129f) No entity for 1 : Cannot read properties of undefined (reading 'hasOwnProperty')
                                      • M mrjeschke
                                        @Asgothian
                                        Fehlermeldung:
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        #92
                                        @mrjeschke Kannst du bitte mehr Kontext posten ? (ein paar mehr Log Zeilen)
                                        A.
                                          A.
                                          M Online
                                          M Online
                                          mrjeschke
                                          #93
                                          @Asgothian
                                          Mehr kommt nicht. Auf silly kommt noch
                                          2026-06-11 20:02:26.420 - silly: zigbee.0 (2351) States system redis pmessage messagebox.system.adapter.zigbee.0/messagebox.system.adapter.zigbee.0:{"command":"setState","message":{"id":"zigbee.0.group_1.state","val":false},"from":"system.adapter.admin.0","callback":{"message":{"id":"zigbee.0.group_1.state","val":false},"id":281,"ack":false,"time":1781200946418},"_id":51435490}
                                          2026-06-11 20:02:26.426 - silly: zigbee.0 (2351) States user redis pmessage io.zigbee.0.*/io.zigbee.0.group_1.state:{"val":false,"ack":false,"ts":1781200946423,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1781200891023}
                                          2026-06-11 20:02:26.430 - debug: zigbee.0 (2351) localConfig:getOptions for group_1 : {}
                                          2026-06-11 20:02:26.434 - debug: zigbee.0 (2351) collect options for group_1: {}
                                          2026-06-11 20:02:26.434 - debug: zigbee.0 (2351) collect options for group_1: {"state":"OFF"}
                                          2026-06-11 20:02:26.438 - warn: zigbee.0 (2351) ELEVATED:EXPUB (84fb) No entity for 1 : Cannot read properties of undefined (reading 'hasOwnProperty')
