  3. Einsteigerfragen
  4. Installation
  5. Re-Installation von ioBroker Migration Bookworm -> Trixie
    6.8k
52 Beiträge 5 Kommentatoren 3.5k Aufrufe 5 Beobachtet
    @Sneak-L8 mach mal einen upload!
    https://www.iobroker.net/#de/documentation/tutorial/adapter.md
    Mit Filmchen (aus einem älteren admin)
    Sneak-L8
    Das Führt leider alles zum selben Ergebnis:
    iobroker upgrade rpi2@3.0.2
    This upgrade of "rpi2" will at least introduce the following changes:
    -> 3.0.2:
    Check for required libgpiod-dev package version
    -> 3.0.1:
    Updated logo, workflows and documentation
    admin 7.6.17 and js-controller 6.0.11 (or later) are required
    -> 3.0.0:
    NodeJS 20.x (or newer) is required
    Updated opengpio to v2 (works on Debian trixie)
    -> 2.4.0:
    read the current state of GPIO outputs during adapter startup.
    re-read GPIO input, if set by the user (with ack=false).
    add an option to invert true/false mapping to 1/0.
    Allow multiple instances of this adapter per host.
    tried to improve initialization of GPIO inputs.
    -> 2.3.2:
    added support for NVMe temperature (needs additional configuration, see README)
    fixed inital values for outputs.
    -> 2.3.1:
    fixed: GPIO library failed to load after recent dependency update.
    -> 2.3.0:
    correct interpretation of start value setting. Output with initial value 0/1 will set GPIO accordingly during startup. Output without an initial state will not set GPIO at all.
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade rpi2 from @1.3.2 to @3.0.2 now? [(y)es, (n)o]: y
    Update rpi2 from @1.3.2 to @3.0.2
    NPM version: 10.9.7
    Installing iobroker.rpi2@3.0.2... (System call)
    Updating objects from io-package.json for adapter "rpi2" with version "1.3.2"
    upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
    upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
    upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
    pi@RaspberryPi4B:~ $
    Er aktualisiert drei Dateien und meint dann, fertig zu sein...
    • S Sneak-L8
      -> 3.0.2:
      -> 3.0.1:
      -> 3.0.0:
      -> 2.4.0:
      -> 2.3.2:
      -> 2.3.1:
      -> 2.3.0:
      NPM version: 10.9.7
      @Sneak-L8 sagte:
      Und es steht nichts im debug-log?
      • S Sneak-L8
        Auch damit passiert genau so viel wie wenn ich das Update direkt in der GUI anstoße:
        pi@RaspberryPi4B:~ $ iob update
        Used repository: stable
        Adapter    "admin"        : 7.7.22   , installed 7.7.22
        Adapter    "backitup"     : 3.3.14   , installed 3.3.14
        Adapter    "email"        : 2.0.4    , installed 2.0.4
        Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
        Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
        Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
        Adapter    "ical"         : 1.20.0   , installed 1.20.0
        Adapter    "javascript"   : 9.0.18   , installed 9.0.18
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "kecontact"    : 3.6.0    , installed 3.6.0
        Adapter    "modbus"       : 8.0.3    , installed 8.0.3
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "ping"         : 1.7.9    , installed 1.7.9
        Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
        Adapter    "rpi2"         : 3.0.2    , installed 1.3.2  [Updatable]
        Adapter    "shelly"       : 10.6.1   , installed 10.6.1
        Adapter    "sma-em"       : 1.3.1    , installed 1.3.1
        Adapter    "socketio"     : 7.0.8    , installed 7.1.3
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
        Adapter    "web"          : 8.0.0    , installed 8.0.0
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "ws"           : 4.0.0    , installed 4.0.0
        Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
        pi@RaspberryPi4B:~ $ iob upgrade
        -> 3.0.2:
        -> 3.0.1:
        -> 3.0.0:
        -> 2.4.0:
        -> 2.3.2:
        -> 2.3.1:
        -> 2.3.0:
        NPM version: 10.9.7
        Der Stand danach ist unverändert (Repo habe ich auch aktualisiert):
        Ist die Beta evtl. nahezu identisch mitV3.0.2 hat aber eine veraltete Versions-Nr.?
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @Sneak-L8 sagte:
        Technisch ausgeschlossen.
        Die Repositories zeigen nur auf npm Pakete. Ein und dasselbe Paket kann nicht unterschiedliche Versionsnummern haben.
        Hast du hier schon wo den Log deines Updates gezeigt? Hab jetzt nichts gefunden.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • S Sneak-L8
          -> 3.0.2:
          -> 3.0.1:
          -> 3.0.0:
          -> 2.4.0:
          -> 2.3.2:
          -> 2.3.1:
          -> 2.3.0:
          NPM version: 10.9.7
          @Sneak-L8
          sudo apt update
          apt policy libgpiod-dev
          sagt?
            Sneak-L8
            Hatte ich oben schon gepostet
            pi@RaspberryPi4B:~ $ apt policy libgpiod-dev
            libgpiod-dev:
            Installed: 2.2.1-2+deb13u1
            Candidate: 2.2.1-2+deb13u1
            Version table:
            *** 2.2.1-2+deb13u1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
            • S Sneak-L8
              libgpiod-dev:
              Version table:
              @Sneak-L8
              Dann weiß ich nicht, warum das bei dir falsch rein läuft. Auf meinem Testsystem wird jedenfalls die richtige Version gezogen:
              thomas@testpi:~ $ iob update
              Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
              • mcm1957M mcm1957
                @Sneak-L8 sagte:
                mcm1957M Online
                mcm1957M Online
                mcm1957
                mcm1957 sagte:
                Sorry, war wohl zu unklar die Frage:
                Hast du hie schon das log des Updates des Adapters wo gepostet?
                Was passiert wenn du auf die 3.0.2 in Admin klickst?
                  Sneak-L8
                  Ja, siehe Post #32. Da werden nur drei Files aktualisiert und das war's.
                  Ich würde jetzt einfach den kompletten Adapter löschen (nicht nur die Instanz) und neu installieren.
                  Damit ich meine SQL-Daten nicht verliere: reicht es, die SQL-Aufzeichnung zu deaktivieren vor dem De- und Install? Und danach wieder aktivieren. Wenn ich das nicht mache, würden sonst alle Sätze gelöscht, oder?
                  HomoranH mcm1957M 2 Antworten Letzte Antwort
                  • S Sneak-L8
                    @Sneak-L8 sagte:
                    Ja, siehe Post #32.
                    Das ist kein debug-log!
                    • S Sneak-L8
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @Sneak-L8 sagte:
                      Sorry, aber wenn du mit #32 das da meinst:
                      Da ist nicjht ein einziges LOGFILE dabei.
                      Unter log verstehe zumindest ich dass man (wenn möglich) den eingegebenen Befehl und allen Output sieht. Zumindest der komplette Output sollte da sein. In Beitrag #32 ist maximal eine Nacherzählung vorhanden, 'upgrade auf 3.0.2' kommt ziemlich sicher nie irgendwo als output.
                      P.S: Und UPLOAD ist keine Update/Upgrade Installation sondern aktualisisert nur die Anzeigedateien im Admin
                      • mcm1957M mcm1957
                        @Sneak-L8 sagte:
                        @mcm1957 sagte:
                        'upgrade auf 3.0.2'
                        Ist ein spoiler.
                        Darin ist der output, aber ohne --debug
                          Sneak-L8
                          Danke, die Info, wie ich hier das Debug-Log aktiviere, hatte mir gefehlt:
                          iobroker upgrade rpi2@3.0.2 --debug
                          -> 3.0.2:
                          -> 3.0.1:
                          -> 3.0.0:
                          -> 2.4.0:
                          -> 2.3.2:
                          -> 2.3.1:
                          -> 2.3.0:
                          NPM version: 10.9.7
                          > iobroker.rpi2@3.0.2 preinstall
                          > bash ./preinstall-check.sh
                          Checking package: libgpiod-dev >= 2.2
                          libgpiod-dev version OK: 2.2.1-2+deb13u1
                          > node-dht-sensor@0.4.5 install
                          > node-gyp configure
                          gyp info it worked if it ends with ok
                          gyp info using node-gyp@8.4.1
                          gyp info using node@22.22.2 | linux | arm64
                          (node:58457) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                          (Use `node --trace-deprecation ...` to show where the warning was created)
                          gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                          gyp info spawn /usr/bin/python3
                          gyp info spawn args [
                          gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                          gyp info spawn args   'binding.gyp',
                          gyp info spawn args   '-f',
                          gyp info spawn args   'make',
                          gyp info spawn args   '-I',
                          gyp info spawn args   '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',
                          gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                          gyp info spawn args   '/home/iobroker/.cache/node-gyp/22.22.2/include/node/common.gypi',
                          gyp info spawn args   '-Dlibrary=shared_library',
                          gyp info spawn args   '-Dvisibility=default',
                          gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.22.2',
                          gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                          gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.22.2/<(target_arch)/node.lib',
                          gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',
                          gyp info spawn args   '-Dnode_engine=v8',
                          gyp info spawn args   '--depth=.',
                          gyp info spawn args   '--no-parallel',
                          gyp info spawn args   '--generator-output',
                          gyp info spawn args   'build',
                          gyp info spawn args   '-Goutput_dir=.'
                          gyp info spawn args ]
                          Traceback (most recent call last):
                           File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>
                             import gyp  # noqa: E402
                           File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>
                             import gyp.input
                           File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module>
                             from distutils.version import StrictVersion
                          ModuleNotFoundError: No module named 'distutils'
                          gyp ERR! configure error
                          gyp ERR! stack Error: `gyp` failed with exit code: 1
                          gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)
                          gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
                          gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
                          gyp ERR! System Linux 6.12.75+rpt-rpi-v8
                          gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
                          gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
                          gyp ERR! node -v v22.22.2
                          gyp ERR! node-gyp -v v8.4.1
                          gyp ERR! not ok
                          > opengpio@2.0.2 install
                          > node-gyp rebuild
                          (node:58475) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                          gyp info spawn args   '/opt/iobroker/node_modules/opengpio/build/config.gypi',
                          gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',
                             import gyp.input
                          gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                          gyp ERR! cwd /opt/iobroker/node_modules/opengpio
                          gyp ERR! not ok
                          npm error code 1
                          npm error path /opt/iobroker/node_modules/opengpio
                          npm error command failed
                          npm error command sh -c node-gyp rebuild
                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-04-29T06_57_29_211Z-debug-0.log
                          • S Sneak-L8
                            -> 3.0.2:
                            -> 3.0.1:
                            -> 3.0.0:
                            -> 2.4.0:
                            -> 2.3.2:
                            -> 2.3.1:
                            -> 2.3.0:
                            NPM version: 10.9.7
                            > node-gyp configure
                               import gyp.input
                            gyp ERR! not ok
                            > node-gyp rebuild
                               import gyp.input
                            gyp ERR! not ok
                            npm error code 1
                            @Sneak-L8 sagte:
                            Bitte auch zeigen!
                            Ich denke nicht dass der Error
                            @Sneak-L8 sagte:
                            noqa: E402
                            Der HTML 402 (payment required)sein sollte 😉
                              Sneak-L8
                              Gerne.
                              cat /home/iobroker/.npm/_logs/2026-04-29T06_57_29_211Z-debug-0.log
                              0 verbose cli /usr/bin/node /usr/bin/npm
                              1 info using npm@10.9.7
                              2 info using node@v22.22.2
                              3 silly config load:file:/usr/lib/node_modules/npm/npmrc
                              4 silly config load:file:/opt/iobroker/.npmrc
                              5 silly config load:file:/home/iobroker/.npmrc
                              6 silly config load:file:/usr/etc/npmrc
                              7 verbose title npm install iobroker.rpi2@3.0.2
                              8 verbose argv "install" "--save-exact" "iobroker.rpi2@3.0.2" "--foreground-scripts"
                              9 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2026-04-29T06_57_29_211Z-
                              10 verbose logfile /home/iobroker/.npm/_logs/2026-04-29T06_57_29_211Z-debug-0.log
                              11 silly logfile start cleaning logs, removing 1 files
                              12 silly packumentCache heap:2041053184 maxSize:510263296 maxEntrySize:255131648
                              13 silly logfile done cleaning log files
                              14 silly idealTree buildDeps
                              15 silly fetch manifest iobroker.rpi2@3.0.2
                              16 silly packumentCache full:https://registry.npmjs.org/iobroker.rpi2 cache-miss
                              17 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                              18 http fetch GET 200 https://registry.npmjs.org/iobroker.rpi2 2238ms (cache revalidated)
                              19 silly packumentCache full:https://registry.npmjs.org/iobroker.rpi2 set size:169789 disposed:false
                              20 silly placeDep ROOT iobroker.rpi2@3.0.2 REPLACE for: iobroker.inst@3.0.0 want: 3.0.2
                              21 silly fetch manifest ci@^2.3.0
                              22 silly packumentCache full:https://registry.npmjs.org/ci cache-miss
                              23 silly fetch manifest opengpio@^2.0.2
                              24 silly packumentCache full:https://registry.npmjs.org/opengpio cache-miss
                              25 http fetch GET 200 https://registry.npmjs.org/ci 570ms (cache revalidated)
                              26 silly packumentCache full:https://registry.npmjs.org/ci set size:22895 disposed:false
                              27 http fetch GET 200 https://registry.npmjs.org/opengpio 679ms (cache revalidated)
                              28 silly packumentCache full:https://registry.npmjs.org/opengpio set size:46175 disposed:false
                              29 silly placeDep ROOT ci@2.3.0 OK for: iobroker.rpi2@3.0.2 want: ^2.3.0
                              30 silly placeDep ROOT opengpio@2.0.2 OK for: iobroker.rpi2@3.0.2 want: ^2.0.2
                              31 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.rpi2' ]
                              32 silly reify mark retired [ '/opt/iobroker/node_modules/sync-exec' ]
                              33 silly reify moves {
                              33 silly reify   '/opt/iobroker/node_modules/iobroker.rpi2': '/opt/iobroker/node_modules/.iobroker.rpi2-2YWXQatr',
                              33 silly reify   '/opt/iobroker/node_modules/sync-exec': '/opt/iobroker/node_modules/.sync-exec-ypF59BB9'
                              33 silly reify }
                              34 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
                              35 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
                              36 http cache opengpio@https://registry.npmjs.org/opengpio/-/opengpio-2.0.2.tgz 0ms (cache hit)
                              37 http cache node-dht-sensor@https://registry.npmjs.org/node-dht-sensor/-/node-dht-sensor-0.4.5.tgz 0ms (cache hit)
                              38 http cache iobroker.rpi2@https://registry.npmjs.org/iobroker.rpi2/-/iobroker.rpi2-3.0.2.tgz 0ms (cache hit)
                              39 http cache ci@https://registry.npmjs.org/ci/-/ci-2.3.0.tgz 0ms (cache hit)
                              40 http cache node-addon-api@https://registry.npmjs.org/node-addon-api/-/node-addon-api-1.7.2.tgz 0ms (cache hit)
                              41 info run iobroker.rpi2@3.0.2 preinstall node_modules/iobroker.rpi2 bash ./preinstall-check.sh
                              42 info run iobroker.rpi2@3.0.2 preinstall { code: 0, signal: null }
                              43 info run node-dht-sensor@0.4.5 install node_modules/node-dht-sensor node-gyp configure
                              44 info run node-dht-sensor@0.4.5 install { code: 1, signal: null }
                              45 verbose reify failed optional dependency /opt/iobroker/node_modules/node-dht-sensor
                              46 silly reify mark deleted [ '/opt/iobroker/node_modules/node-dht-sensor' ]
                              47 verbose reify failed optional dependency /opt/iobroker/node_modules/node-dht-sensor/node_modules/node-addon-api
                              48 silly reify mark deleted [
                              48 silly reify   '/opt/iobroker/node_modules/node-dht-sensor/node_modules/node-addon-api'
                              48 silly reify ]
                              49 info run opengpio@2.0.2 install node_modules/opengpio node-gyp rebuild
                              50 info run opengpio@2.0.2 install { code: 1, signal: null }
                              51 verbose stack Error: command failed
                              51 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:22:22)
                              51 verbose stack     at spawnWithShell (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:124:10)
                              51 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:12:12)
                              51 verbose stack     at runScriptPkg (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script-pkg.js:79:13)
                              51 verbose stack     at runScript (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script.js:9:12)
                              51 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:329:17
                              51 verbose stack     at run (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:67:22)
                              51 verbose stack     at /usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:79:13
                              51 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:103:5)
                              52 verbose pkgid opengpio@2.0.2
                              53 error code 1
                              54 error path /opt/iobroker/node_modules/opengpio
                              55 error command failed
                              56 error command sh -c node-gyp rebuild
                              57 silly unfinished npm timer reify 1777445850399
                              58 silly unfinished npm timer reify:build 1777445856727
                              59 silly unfinished npm timer build 1777445856729
                              60 silly unfinished npm timer build:deps 1777445856729
                              61 silly unfinished npm timer build:run:install 1777445856791
                              62 silly unfinished npm timer build:run:install:node_modules/opengpio 1777445857732
                              63 verbose cwd /opt/iobroker
                              64 verbose os Linux 6.12.75+rpt-rpi-v8
                              65 verbose node v22.22.2
                              66 verbose npm  v10.9.7
                              67 verbose exit 1
                              68 verbose code 1
                              69 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-04-29T06_57_29_211Z-debug-0.log
                              • S Sneak-L8
                                Gerne.
                                33 silly reify }
                                48 silly reify ]
                                53 error code 1
                                67 verbose exit 1
                                68 verbose code 1
                                @Sneak-L8
                                sudo apt update
                                sudo apt install python3-setuptools
                                iob nodejs-update 22
                                Rückfragen von nodejs-update bejahen. Danach nochmal den rpi2-Adapter installieren.
                                  Sneak-L8
                                  Danke, jetzt hat es geklappt.
                                  ioBroker nodejs fixer 2026-01-31
                                  You requested to install latest version from nodejs v22 tree.
                                  Your current setup is:
                                  /usr/bin/nodejs         v22.22.2
                                  /usr/bin/node           v22.22.2
                                  /usr/bin/npm            10.9.7
                                  /usr/bin/npx            10.9.7
                                  We found these nodejs versions available for installation:
                                  nodejs:
                                   Installed: 22.22.2-1nodesource1
                                   Candidate: 22.22.2-1nodesource1
                                   Version table:
                                  *** 22.22.2-1nodesource1 1001
                                         500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                      22.22.1-1nodesource1 1001
                                      22.22.0-1nodesource1 1001
                                      22.21.0-1nodesource1 1001
                                      22.20.0-1nodesource1 1001
                                      22.19.0-1nodesource1 1001
                                      22.18.0-1nodesource1 1001
                                      22.17.1-1nodesource1 1001
                                      22.17.0-1nodesource1 1001
                                      22.16.0-1nodesource1 1001
                                      22.15.1-1nodesource1 1001
                                      22.15.0-1nodesource1 1001
                                      22.14.0-1nodesource1 1001
                                      22.13.1-1nodesource1 1001
                                      22.13.0-1nodesource1 1001
                                      22.12.0-1nodesource1 1001
                                      22.11.0-1nodesource1 1001
                                      22.10.0-1nodesource1 1001
                                      22.9.0-1nodesource1 1001
                                      22.8.0-1nodesource1 1001
                                      22.7.0-1nodesource1 1001
                                      22.6.0-1nodesource1 1001
                                      22.5.1-1nodesource1 1001
                                      22.5.0-1nodesource1 1001
                                      22.4.1-1nodesource1 1001
                                      22.4.0-1nodesource1 1001
                                      22.3.0-1nodesource1 1001
                                      22.2.0-1nodesource1 1001
                                      22.1.0-1nodesource1 1001
                                      22.0.0-1nodesource1 1001
                                      20.19.2+dfsg-1+deb13u2 500
                                         500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
                                      20.19.2+dfsg-1 500
                                  Nothing to do - Your installation is using the correct paths.
                                  You are missing the nodesource.list or
                                  you want to change your current nodejs version: v22.22.2 ?
                                  Press <y> to continue or any other key to quit
                                  Trying to fix your installation now. Please be patient.
                                  You are running nodejs v22.22.2. Do you want to install latest version from nodejs v.22 tree?
                                  rm: cannot remove '': No such file or directory
                                  Stopping ioBroker now
                                  ioBroker has been stopped
                                  Removing dfsg-nodejs
                                  *** These repos are active on your system:
                                  Hit:1 http://deb.debian.org/debian trixie InRelease
                                  Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                                  Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
                                  Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
                                  Reading package lists... Done
                                  *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                                  *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                                  Package: nodejs
                                  Pin: origin deb.nodesource.com
                                  Pin-Priority: 1001
                                  *** These repos are active after the adjustments:
                                  Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
                                  Get:6 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages [9768 B]
                                  Fetched 21.9 kB in 0s (79.7 kB/s)
                                  Installing nodejs now!
                                  Installing latest nodejs v22 release
                                  SUCCESS!
                                  v22.22.2 has been installed! You are using the latest nodejs@22 release now!
                                  COMPATIBILITY CHECK IN PROGRESS (Only a --dry-run! No modules are really changed or added!)
                                  add rpi-gpio-buttons 2.0.1
                                  add rpi-gpio 2.1.7
                                  add debug 3.2.7
                                  add node-dht-sensor 0.4.5
                                  add node-addon-api 1.7.2
                                  add fsevents 2.3.3
                                  add epoll 2.0.10
                                  add button-events 1.1.0
                                  add async-retry 1.3.3
                                  add retry 0.13.1
                                  added 10 packages in 6s
                                  294 packages are looking for funding
                                   run `npm fund` for details
                                  We tried our best to fix your nodejs. Please run iob diag again to verify.
                                  *** RESTARTING ioBroker NOW! ***
                                  Please refresh or restart your browser in a few moments.
                                  • S Sneak-L8
                                    /usr/bin/npm            10.9.7
                                    /usr/bin/npx            10.9.7
                                    nodejs:
                                     Version table:
                                        20.19.2+dfsg-1 500
                                    Package: nodejs
                                    Pin-Priority: 1001
                                    SUCCESS!
                                    add rpi-gpio 2.1.7
                                    add debug 3.2.7
                                    add fsevents 2.3.3
                                    add epoll 2.0.10
                                    add retry 0.13.1
                                    @Sneak-L8
                                    Und die Installation von rpi2 sieht/sah wie aus?
                                    • S Sneak-L8
                                      /usr/bin/npm            10.9.7
                                      /usr/bin/npx            10.9.7
                                      nodejs:
                                       Version table:
                                          20.19.2+dfsg-1 500
                                      Package: nodejs
                                      Pin-Priority: 1001
                                      SUCCESS!
                                      add rpi-gpio 2.1.7
                                      add debug 3.2.7
                                      add fsevents 2.3.3
                                      add epoll 2.0.10
                                      add retry 0.13.1
                                      @Sneak-L8 sagte:
                                      Aah, soweit runter hatte ich nie gescrollt 🙈
                                        Sneak-L8
                                        Install hatte ich jetzt wieder in der GUI gemacht. Daher der Output aus dem Log.
                                        2026-04-29 10:15:08.189 - info: host.RaspberryPi4B iobroker Update "system.adapter.rpi2.0"
                                        2026-04-29 10:15:08.210 - info: host.RaspberryPi4B stopInstance system.adapter.rpi2.0 (force=false, process=true)
                                        2026-04-29 10:15:08.215 - info: rpi2.0 (62170) Got terminate signal TERMINATE_YOURSELF
                                        2026-04-29 10:15:08.218 - info: rpi2.0 (62170) terminating
                                        2026-04-29 10:15:08.220 - info: rpi2.0 (62170) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2026-04-29 10:15:08.295 - info: host.RaspberryPi4B stopInstance system.adapter.rpi2.0 send kill signal
                                        2026-04-29 10:15:08.354 - info: host.RaspberryPi4B iobroker upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        2026-04-29 10:15:08.370 - info: host.RaspberryPi4B iobroker upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                        2026-04-29 10:15:08.380 - info: host.RaspberryPi4B iobroker upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                        2026-04-29 10:15:08.388 - info: host.RaspberryPi4B iobroker upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                        2026-04-29 10:15:08.403 - info: host.RaspberryPi4B iobroker upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                        2026-04-29 10:15:08.411 - info: host.RaspberryPi4B iobroker upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                        2026-04-29 10:15:08.419 - info: host.RaspberryPi4B iobroker upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                        2026-04-29 10:15:08.426 - info: host.RaspberryPi4B iobroker upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                        2026-04-29 10:15:08.448 - info: host.RaspberryPi4B iobroker upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                        2026-04-29 10:15:08.458 - info: host.RaspberryPi4B iobroker upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                        2026-04-29 10:15:08.466 - info: host.RaspberryPi4B iobroker upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                        2026-04-29 10:15:08.474 - info: host.RaspberryPi4B iobroker upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
                                        2026-04-29 10:15:08.480 - info: host.RaspberryPi4B iobroker upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
                                        2026-04-29 10:15:08.488 - info: host.RaspberryPi4B iobroker upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                                        2026-04-29 10:15:08.723 - info: rpi2.0 (62170) terminating
                                        2026-04-29 10:15:08.825 - info: host.RaspberryPi4B instance system.adapter.rpi2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2026-04-29 10:15:09.526 - info: host.RaspberryPi4B iobroker exit 0
                                        2026-04-29 10:15:12.643 - info: host.RaspberryPi4B instance system.adapter.rpi2.0 in version "3.0.2" started with pid 63055
                                          @Sneak-L8 sagte:
                                          @Homoran sagte:
                                          Das wird immer angezeigt. Heißt nicht, dass die dfsg-Version auch installiert war.
                                          In der neusten Version von nodejs-update ist der Text an der Stelle auch geändert.
                                          Die Version ist aber noch nicht verfügbar.
