  4. Linux-Controll keine Verbindung
    6.4k
14 Beiträge 5 Kommentatoren 739 Aufrufe 4 Beobachtet
  • Ro75R Ro75
    @Negalein hier fehlt das Abfrageintervall. Post 1 Bild 3.
    Ro75.
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    @Ro75 sagte:
    leider immer noch
    host.ioBroker
    2026-04-28 10:38:52.105	error	instance system.adapter.linux-control.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    linux-control.0
    2026-04-28 10:38:51.480	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    linux-control.0
    2026-04-28 10:38:51.474	error	adapter disabled
    javascript.0
    2026-04-28 10:38:29.472	info	script.js.Wetter.Open-Meteo-Widget: Weather widget: HTML successfully generated.
    javascript.0
    2026-04-28 10:38:28.460	info	script.js.Wetter.Open-Meteo-Widget: Weather widget: HTML successfully generated.
    host.ioBroker
    2026-04-28 10:38:21.158	info	"system.adapter.linux-control.0" disabled
    host.ioBroker
    2026-04-28 10:38:19.014	info	Restart adapter system.adapter.linux-control.0 because enabled
    host.ioBroker
    2026-04-28 10:38:19.014	error	instance system.adapter.linux-control.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[7]: at processTicksAndRejections (node:internal/process/task_queues:103:5)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[7]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[7]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[7]: Error: The pattern "io.linux-control.0.Proxmox_3_Keller.services.●.start" is not a valid ID pattern
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[7]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[6]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[6]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[6]: ReplyError: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[6]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[5]: at processTicksAndRejections (node:internal/process/task_queues:103:5)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[5]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[5]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[5]: Error: The pattern "io.linux-control.0.Proxmox_3_Keller.services.●.start" is not a valid ID pattern
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[4]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[4]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[4]: ReplyError: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[3]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[3]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[3]: ReplyError: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.stop" is not a valid ID pattern
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:103:5)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[1]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[1]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15)
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[1]: Error: The pattern "io.linux-control.0.Proxmox_3_Keller.services.●.start" is not a valid ID pattern
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.ioBroker
    2026-04-28 10:38:19.014	error	Caught by controller[0]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.ioBroker
    2026-04-28 10:38:19.013	error	Caught by controller[0]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.ioBroker
    2026-04-28 10:38:19.013	error	Caught by controller[0]: ReplyError: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern
    host.ioBroker
    2026-04-28 10:38:19.013	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    linux-control.0
    2026-04-28 10:38:18.812	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.stop changed to linux-control.0.Proxmox_3_Keller.services._.stop
    linux-control.0
    2026-04-28 10:38:18.808	error	Error: The pattern "io.linux-control.0.Proxmox_3_Keller.services.●.start" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27) at processTicksAndRejections (node:internal/process/task_queues:103:5)
    linux-control.0
    2026-04-28 10:38:18.807	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox_3_Keller.services.●.start" is not a valid ID pattern
    linux-control.0
    2026-04-28 10:38:18.807	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2026-04-28 10:38:18.804	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.start changed to linux-control.0.Proxmox_3_Keller.services._.start
    linux-control.0
    2026-04-28 10:38:18.797	error	ReplyError: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    linux-control.0
    2026-04-28 10:38:18.797	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern
    linux-control.0
    2026-04-28 10:38:18.797	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.ioBroker
    2026-04-28 10:38:18.796	warn	host.ioBroker-Server States 127.0.0.1:54768 Error from InMemDB: Error: The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:323:59) at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:240:14) at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26) at RedisHandler.emit (node:events:519:28) at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37) at processImmediate (node:internal/timers:484:21) at process.callbackTrampoline (node:internal/async_hooks:130:17)
    linux-control.0
    2026-04-28 10:38:18.794	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.restart changed to linux-control.0.Proxmox_3_Keller.services._.restart
    linux-control.0
    2026-04-28 10:38:18.751	warn	State "linux-control.0.Proxmox_3_Keller.services.●.description" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.748	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.description changed to linux-control.0.Proxmox_3_Keller.services._.description
    linux-control.0
    2026-04-28 10:38:18.744	warn	State "linux-control.0.Proxmox_3_Keller.services.●.running" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.743	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.running changed to linux-control.0.Proxmox_3_Keller.services._.running
    linux-control.0
    2026-04-28 10:38:18.739	warn	State "linux-control.0.Proxmox_3_Keller.services.●.active" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.737	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.active changed to linux-control.0.Proxmox_3_Keller.services._.active
    linux-control.0
    2026-04-28 10:38:18.693	warn	State "linux-control.0.Proxmox_3_Keller.services.●.load" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.691	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.load changed to linux-control.0.Proxmox_3_Keller.services._.load
    linux-control.0
    2026-04-28 10:38:18.632	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.stop changed to linux-control.0.Proxmox_3_Keller.services._.stop
    linux-control.0
    2026-04-28 10:38:18.628	error	Error: The pattern "io.linux-control.0.Proxmox_3_Keller.services.●.start" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27) at processTicksAndRejections (node:internal/process/task_queues:103:5)
    linux-control.0
    2026-04-28 10:38:18.627	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox_3_Keller.services.●.start" is not a valid ID pattern
    linux-control.0
    2026-04-28 10:38:18.627	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2026-04-28 10:38:18.624	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.start changed to linux-control.0.Proxmox_3_Keller.services._.start
    linux-control.0
    2026-04-28 10:38:18.621	error	ReplyError: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    linux-control.0
    2026-04-28 10:38:18.620	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern
    linux-control.0
    2026-04-28 10:38:18.619	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.ioBroker
    2026-04-28 10:38:18.619	warn	host.ioBroker-Server States 127.0.0.1:54768 Error from InMemDB: Error: The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:323:59) at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:240:14) at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26) at RedisHandler.emit (node:events:519:28) at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37) at processImmediate (node:internal/timers:484:21) at process.callbackTrampoline (node:internal/async_hooks:130:17)
    linux-control.0
    2026-04-28 10:38:18.617	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.restart changed to linux-control.0.Proxmox_3_Keller.services._.restart
    linux-control.0
    2026-04-28 10:38:18.614	warn	State "linux-control.0.Proxmox_3_Keller.services.●.description" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.612	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.description changed to linux-control.0.Proxmox_3_Keller.services._.description
    linux-control.0
    2026-04-28 10:38:18.609	warn	State "linux-control.0.Proxmox_3_Keller.services.●.running" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.608	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.running changed to linux-control.0.Proxmox_3_Keller.services._.running
    linux-control.0
    2026-04-28 10:38:18.604	warn	State "linux-control.0.Proxmox_3_Keller.services.●.active" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.602	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.active changed to linux-control.0.Proxmox_3_Keller.services._.active
    linux-control.0
    2026-04-28 10:38:18.558	warn	State "linux-control.0.Proxmox_3_Keller.services.●.load" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.557	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.load changed to linux-control.0.Proxmox_3_Keller.services._.load
    linux-control.0
    2026-04-28 10:38:18.489	error	ReplyError: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.stop" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    linux-control.0
    2026-04-28 10:38:18.488	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.stop" is not a valid ID pattern
    linux-control.0
    2026-04-28 10:38:18.479	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.ioBroker
    2026-04-28 10:38:18.478	warn	host.ioBroker-Server States 127.0.0.1:54768 Error from InMemDB: Error: The pattern "linux-control.0.Proxmox_3_Keller.services.●.stop" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:323:59) at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:240:14) at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26) at RedisHandler.emit (node:events:519:28) at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37) at processImmediate (node:internal/timers:484:21) at process.callbackTrampoline (node:internal/async_hooks:130:17)
    linux-control.0
    2026-04-28 10:38:18.469	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.stop changed to linux-control.0.Proxmox_3_Keller.services._.stop
    linux-control.0
    2026-04-28 10:38:18.454	error	Error: The pattern "io.linux-control.0.Proxmox_3_Keller.services.●.start" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27) at processTicksAndRejections (node:internal/process/task_queues:103:5)
    linux-control.0
    2026-04-28 10:38:18.395	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox_3_Keller.services.●.start" is not a valid ID pattern
    linux-control.0
    2026-04-28 10:38:18.395	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2026-04-28 10:38:18.321	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.start changed to linux-control.0.Proxmox_3_Keller.services._.start
    linux-control.0
    2026-04-28 10:38:18.320	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    linux-control.0
    2026-04-28 10:38:18.311	error	Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern
    linux-control.0
    2026-04-28 10:38:18.311	error	ReplyError: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    linux-control.0
    2026-04-28 10:38:18.309	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern
    linux-control.0
    2026-04-28 10:38:18.309	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.ioBroker
    2026-04-28 10:38:18.308	warn	host.ioBroker-Server States 127.0.0.1:54768 Error from InMemDB: Error: The pattern "linux-control.0.Proxmox_3_Keller.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2507:15) at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:323:59) at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:240:14) at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26) at RedisHandler.emit (node:events:519:28) at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37) at processImmediate (node:internal/timers:484:21) at process.callbackTrampoline (node:internal/async_hooks:130:17)
    linux-control.0
    2026-04-28 10:38:18.306	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.restart changed to linux-control.0.Proxmox_3_Keller.services._.restart
    linux-control.0
    2026-04-28 10:38:18.261	warn	State "linux-control.0.Proxmox_3_Keller.services.●.description" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.259	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.description changed to linux-control.0.Proxmox_3_Keller.services._.description
    linux-control.0
    2026-04-28 10:38:18.256	warn	State "linux-control.0.Proxmox_3_Keller.services.●.running" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.255	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.running changed to linux-control.0.Proxmox_3_Keller.services._.running
    linux-control.0
    2026-04-28 10:38:18.252	warn	State "linux-control.0.Proxmox_3_Keller.services.●.active" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.250	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.active changed to linux-control.0.Proxmox_3_Keller.services._.active
    linux-control.0
    2026-04-28 10:38:18.206	warn	State "linux-control.0.Proxmox_3_Keller.services.●.load" has no existing object, this might lead to an error in future versions
    linux-control.0
    2026-04-28 10:38:18.202	warn	Used invalid characters: linux-control.0.Proxmox_3_Keller.services.●.load changed to linux-control.0.Proxmox_3_Keller.services._.load
    host.ioBroker
    2026-04-28 10:38:14.443	info	instance system.adapter.linux-control.0 in version "1.1.6" (non-npm: Scrounger/ioBroker.linux-control) started with pid 523161
    host.ioBroker
    2026-04-28 10:38:13.485	info	"system.adapter.linux-control.0" enabled
    ° Fixer ---> iob fix
    Ro75R crunchipC 2 Antworten Letzte Antwort
    • NegaleinN Negalein
      @Ro75 sagte:
      leider immer noch
      host.ioBroker
      linux-control.0
      linux-control.0
      javascript.0
      javascript.0
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      host.ioBroker
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      host.ioBroker
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      host.ioBroker
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      host.ioBroker
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      linux-control.0
      host.ioBroker
      host.ioBroker
      Ro75R Offline
      Ro75R Offline
      Ro75
      @Negalein sagte:
      Das Problem gab es schon bei anderen. Kan dir aber leider nicht mehr die Lösung sagen. Im Log sehe ich immer nur Keller_3.
      Ro75.
        @Ro75 sagte:
        leider immer noch
        host.ioBroker
        linux-control.0
        linux-control.0
        javascript.0
        javascript.0
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        host.ioBroker
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        host.ioBroker
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        host.ioBroker
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        host.ioBroker
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        host.ioBroker
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        host.ioBroker
        host.ioBroker
        crunchipC Abwesend
        crunchipC Abwesend
        @Negalein sagte:
        https://github.com/Scrounger/ioBroker.linux-control/issues/55
        mach den Haken mal weg bei services
          @Negalein sagte:
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          @crunchip sagte:
          ah, da war ja mal was von mir. hab ich vergessen.
          jetzt kommen nur noch die cpu-temp Fehler.
          hab das als Befehl
          vcgencmd measure_temp | awk '{print substr($1, length($0)-5,4)}'
          linux-control.0
          2026-04-28 11:41:26.934	error	[userCommandExecute] Proxmox_2_Keller (10.0.1.205:22, id: cpu-temp, description: die temp des servers): response error: bash: line 1: vcgencmd: command not found, stack: ResponseError: [userCommandExecute] Proxmox_2_Keller (10.0.1.205:22, id: cpu-temp, description: die temp des servers): bash: line 1: vcgencmd: command not found at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:907:26) at processTicksAndRejections (node:internal/process/task_queues:103:5) at LinuxControl.userCommandExecute (/opt/iobroker/node_modules/iobroker.linux-control/main.js:249:21)
          linux-control.0
          2026-04-28 11:41:26.681	error	[userCommandExecute] Proxmox_1_Heizraum (10.0.1.201:22, id: cpu-temp, description: die temp des servers): response error: bash: line 1: vcgencmd: command not found, stack: ResponseError: [userCommandExecute] Proxmox_1_Heizraum (10.0.1.201:22, id: cpu-temp, description: die temp des servers): bash: line 1: vcgencmd: command not found at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:907:26) at processTicksAndRejections (node:internal/process/task_queues:103:5) at LinuxControl.userCommandExecute (/opt/iobroker/node_modules/iobroker.linux-control/main.js:249:21)
          linux-control.0
          2026-04-28 11:41:25.087	error	[userCommandExecute] Proxmox_3_Keller (10.0.1.206:22, id: cpu-temp, description: die temp des servers): response error: bash: line 1: vcgencmd: command not found, stack: ResponseError: [userCommandExecute] Proxmox_3_Keller (10.0.1.206:22, id: cpu-temp, description: die temp des servers): bash: line 1: vcgencmd: command not found at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:907:26) at processTicksAndRejections (node:internal/process/task_queues:103:5) at LinuxControl.userCommandExecute (/opt/iobroker/node_modules/iobroker.linux-control/main.js:249:21)
            @crunchip sagte:
            hab das als Befehl
            linux-control.0
            linux-control.0
            linux-control.0
            @Negalein sagte:
            vcgencmd
            ist ein RaspberryOS spezifisches Kommando. Auf anderen Linuxen/anderer Hardware kommst du damit nicht ans Ziel.
              @Negalein sagte:
              vcgencmd
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              @Thomas-Braun sagte:
              ah, danke
              dann werd ich mich mal auf die Suche machen
                @crunchip sagte:
                hab das als Befehl
                linux-control.0
                linux-control.0
                linux-control.0
                crunchipC Abwesend
                crunchipC Abwesend
                @Negalein sagte:
                cpu-temp
                sensors | grep Package -m 1 | awk '{print $4}' | awk '{print substr($1, length($0)-6,2)}'
                  @Negalein sagte:
                  cpu-temp
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  @crunchip sagte:
                  Sind noch da
                  linux-control.0
                  2026-04-28 12:05:02.862	error	[userCommandExecute] Proxmox_1_Heizraum (10.0.1.201:22, id: cpu-temp, description: die temp des servers): response error: bash: line 1: sensors: command not found, stack: ResponseError: [userCommandExecute] Proxmox_1_Heizraum (10.0.1.201:22, id: cpu-temp, description: die temp des servers): bash: line 1: sensors: command not found at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:907:26) at processTicksAndRejections (node:internal/process/task_queues:103:5) at LinuxControl.userCommandExecute (/opt/iobroker/node_modules/iobroker.linux-control/main.js:249:21) at LinuxControl.userCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:204:10) at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:85:5) at async Promise.allSettled (index 0) at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:53:4)
                  linux-control.0
                  2026-04-28 12:05:02.412	error	[userCommandExecute] Proxmox_2_Keller (10.0.1.205:22, id: cpu-temp, description: die temp des servers): response error: bash: line 1: sensors: command not found, stack: ResponseError: [userCommandExecute] Proxmox_2_Keller (10.0.1.205:22, id: cpu-temp, description: die temp des servers): bash: line 1: sensors: command not found at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:907:26) at processTicksAndRejections (node:internal/process/task_queues:103:5) at LinuxControl.userCommandExecute (/opt/iobroker/node_modules/iobroker.linux-control/main.js:249:21) at LinuxControl.userCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:204:10) at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:85:5) at async Promise.allSettled (index 1) at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:53:4)
                  linux-control.0
                  2026-04-28 12:05:00.840	error	[userCommandExecute] Proxmox_3_Keller (10.0.1.206:22, id: cpu-temp, description: die temp des servers): response error: bash: line 1: sensors: command not found, stack: ResponseError: [userCommandExecute] Proxmox_3_Keller (10.0.1.206:22, id: cpu-temp, description: die temp des servers): bash: line 1: sensors: command not found at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:907:26) at processTicksAndRejections (node:internal/process/task_queues:103:5) at LinuxControl.userCommandExecute (/opt/iobroker/node_modules/iobroker.linux-control/main.js:249:21) at LinuxControl.userCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:204:10) at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:85:5) at async Promise.allSettled (index 2) at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:53:4)
                    @crunchip sagte:
                    Sind noch da
                    linux-control.0
                    linux-control.0
                    linux-control.0
                    @Negalein sagte:
                    Also ist auch das Kommando nicht verfügbar. Kann aber ggfls. nachinstalliert werden.
                    Wobei solch hardwarenahes Zeuch auch auf dem Proxmox-Host besser aufgehoben wäre, denke ich.
                      @crunchip sagte:
                      Sind noch da
                      linux-control.0
                      linux-control.0
                      linux-control.0
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @Negalein muss auf dem proxmox host installiert sein
                      apt install lm-sensors
                      dann ausführen
                      sensors-detect
                      anschliessend
                      sensors
                      zeigt dir im teminal die Werte an
                      somit sollte dann auch der Adapter die Werte abholen können
                        @Negalein sagte:
                        Meister MopperM Online
                        Meister Mopper
                        Ich bekomme die CPU-Temp meiner NUC mit
                        sensors | grep 'Package id 0:' | awk '{print $4}' | cut -c2-3
                        Proxmox und HA ...
                        • NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          Danke euch
