  4. Ical: V 1.20.0 erzeugt Fehler im log
    6.1k
1.20.0fehler log
21 Beiträge 7 Kommentatoren 2.1k Aufrufe 5 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    habe ical upgedatet auf 1.20.0
    Folgende Fehler im log:
    ical.0
    2026-04-24 21:51:27.461	error	request.headers.split is not a function
    ical.0
    2026-04-24 21:51:27.461	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9) at Channel.publish (node:diagnostics_channel:156:9) at new Request (node:internal/deps/undici/undici:2124:27) at Client.[dispatch] (node:internal/deps/undici/undici:7916:25) at Intercept (node:internal/deps/undici/undici:7649:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:688:16) at Client.dispatch (node:internal/deps/undici/undici:704:44) at Pool.[dispatch] (node:internal/deps/undici/undici:935:32) at Pool.dispatch (node:internal/deps/undici/undici:704:44)
    ical.0
    2026-04-24 21:51:27.461	error	uncaught exception: request.headers.split is not a function
    ical.0
    2026-04-24 21:51:27.460	error	request.headers.split is not a function
    ical.0
    2026-04-24 21:51:27.460	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9) at Channel.publish (node:diagnostics_channel:156:9) at new Request (node:internal/deps/undici/undici:2124:27) at Client.[dispatch] (node:internal/deps/undici/undici:7916:25) at Intercept (node:internal/deps/undici/undici:7649:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:688:16) at Client.dispatch (node:internal/deps/undici/undici:704:44) at Pool.[dispatch] (node:internal/deps/undici/undici:935:32) at Pool.dispatch (node:internal/deps/undici/undici:704:44)
    ical.0
    2026-04-24 21:51:27.460	error	uncaught exception: request.headers.split is not a function
    ical.0
    2026-04-24 21:51:27.459	error	request.headers.split is not a function
    ical.0
    2026-04-24 21:51:27.458	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9) at Channel.publish (node:diagnostics_channel:156:9) at new Request (node:internal/deps/undici/undici:2124:27) at Client.[dispatch] (node:internal/deps/undici/undici:7916:25) at Intercept (node:internal/deps/undici/undici:7649:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:688:16) at Client.dispatch (node:internal/deps/undici/undici:704:44) at Pool.[dispatch] (node:internal/deps/undici/undici:935:32) at Pool.dispatch (node:internal/deps/undici/undici:704:44)
    ical.0
    2026-04-24 21:51:27.458	error	uncaught exception: request.headers.split is not a function
    ical.0
    2026-04-24 21:51:27.457	error	request.headers.split is not a function
    Wieder downgrade auf V 1.19.7 und alles läuft wieder (ohne Fehler im log)!
    Habt ihr diese Fehler auch mit der neuesten 1.20.0 ?
    mfg
    Dieter
    Danke.
    • bahnuhrB bahnuhr
      ical.0
      ical.0
      ical.0
      ical.0
      ical.0
      ical.0
      ical.0
      ical.0
      ical.0
      ical.0
      mfg
      Dieter
      @bahnuhr sagte:
      Nein.
      Dein Setup schaut wie aus?
      bahnuhrB 2 Antworten Letzte Antwort
        @bahnuhr sagte:
        Nein.
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @Thomas-Braun sagte:
        Danke.
          @bahnuhr sagte:
          Nein.
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          @Thomas-Braun
          Habs raus gefunden.
          Es liegt an diesem "sentry"
          ausgeschaltet und der Fehler ist weg.
          Der Adapter scheint also seit 1.20.0 einen bug zu haben.
          Danke.
          • MartinPM Online
            MartinPM Online
            MartinP
            Gleiches Problem - schalte jetzt auch mal Sentry im Adapter aus..
            Wieder alte Bauernregel nicht beachtet: NIE "Nuller" Versionen installieren ;.)
            Also xy.0 -> Böse. xy.1 usw. -> Besser
            Interessanterweise betrifft es bei mir nur eine von zwei ical - Instanzen.
            Instanz 0 funktioniert
            Instanz 1 funktioniert nicht
            Habe zwei Instanzen, weil ich den Abfallkalender nicht so häufig aktualisieren will - der Server scheint manchmal nicht erreichbar - meist zwischen Mitternacht und Arbeitsbeginn am Folgetag ....
            • MartinPM MartinP
              Hier läuft diese Version einwandfrei mit aktiviertem sentry:
              2026-04-25 08:50:13.147  - info: ical.0 (331769) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v25.9.0, js-controller: 7.1.1
              2026-04-25 08:50:13.953  - info: ical.0 (331769) processing URL: awb-direkt https://www.awbkoeln.de/fileadmin/ics/icscal.php?building_number=191&street_code=63&start_year=2025&end_year=2026&start_month=10&end_month=12&trigger=960&wertstoff=1&grey=1&brown=0&blue=1&red=0
              2026-04-25 08:50:19.144  - info: ical.0 (331769) Terminated (NO_ERROR): Without reason
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                @Thomas-Braun
                Das ist schön wenn es bei dir klappt.
                Habe auch issue erstellt.
                Aber die issues bei diesem Adapter werden ja seit 8 Jahren nicht bearbeitet.
                Schaun wir mal.
                Danke.
                • MartinPM Online
                  MartinPM Online
                  MartinP
                  Hier das Logging von meinem Adapter ...
                  2026-04-25 08:57:04.507 - info: ical.1 (810693) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7
                  2026-04-25 08:57:05.271 - error: ical.1 (810693) uncaught exception: request.headers.split is not a function
                  2026-04-25 08:57:05.272 - error: ical.1 (810693) TypeError: request.headers.split is not a function
                  at new Request (node:internal/deps/undici/undici:2146:27)
                  at Client.[dispatch] (node:internal/deps/undici/undici:7944:25)
                  at Intercept (node:internal/deps/undici/undici:7677:20)
                  at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:707:16)
                  at Client.dispatch (node:internal/deps/undici/undici:723:44)
                  at Pool.[dispatch] (node:internal/deps/undici/undici:954:32)
                  at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:700:33)
                  2026-04-25 08:57:05.273 - error: ical.1 (810693) request.headers.split is not a function
                  2026-04-25 08:57:05.351 - info: ical.1 (810693) terminating
                  2026-04-25 08:57:05.352 - warn: ical.1 (810693) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2026-04-25 08:57:05.688 - error: host.iobroker-test-sicher instance system.adapter.ical.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  ical.0 läuft ohne Holpern
                  2026-04-25 09:00:22.095 - info: ical.0 (810735) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7
                  2026-04-25 09:00:27.502 - info: ical.0 (810735) processing URL: Martin_docker http://192.168.2.146:5232/martin/e4c584bc-2ea6-bae6-1d4e-debe6a702f21/
                  2026-04-25 09:00:34.864 - info: ical.0 (810735) Terminated (NO_ERROR): Without reason
                  Habe jetzt Sentry bei ical.1 ausgemacht ... für interessierte Mitleser - geht nur im Expertenmodus.
                  • bahnuhrB bahnuhr
                    @Thomas-Braun
                    Schaun wir mal.
                    @bahnuhr
                    Wie wäre es denn, wenigstens im Issue mal was gescheites aus deinem Log zu zeigen...
                    Welches System? Nodejs? Wie schaut der Adapterstart aus?
                    Steht in
                    iob logs
                    alles formatiert drin.
                    • MartinPM MartinP
                      FeuersturmF Offline
                      FeuersturmF Offline
                      Feuersturm
                      @MartinP @bahnuhr welche Version vom jscontroller habt ihr installiert?
                      • MartinPM Online
                        MartinPM Online
                        MartinP
                        Js-Controller 7.0.7 bin im stable Repo
                        • MartinPM MartinP
                          FeuersturmF Offline
                          FeuersturmF Offline
                          Feuersturm
                          @MartinP das ist die Ursache. Mit js-controller 7.1.0 ist das Problem gelöst. Ein sentry update war notwendig und wurde mit dem Release gemacht.
                          https://github.com/ioBroker/ioBroker.js-controller/blob/master/CHANGELOG.md#710-2025-12-06---milla
                          • FeuersturmF Feuersturm
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            @Feuersturm
                            Danke für die Info.
                            Probier ich bei Gelegenheit aus.
                            Danke.
                            • MartinPM Online
                              MartinPM Online
                              MartinP
                              Deshalb werde ich aber nicht auf das Beta Repository wechseln. Die paar Wochen werde ich dann eben Sentry im ical Adapter abschalten
                              • MartinPM MartinP
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                @MartinP
                                Ja, so mache ich es auch.
                                Aber warum wird ein Adapter ins stable gestellt, der ein js.controller erfordert der nicht im stable ist.
                                Merkwürdig.
                                Danke.
                                • bahnuhrB bahnuhr
                                  @MartinP
                                  Merkwürdig.
                                  @bahnuhr sagte:
                                  Merkwürdig
                                  Nöö, der Adapter ist stable!
                                  Sentry hat einen Schlag weg.
                                    @bahnuhr sagte:
                                    Merkwürdig
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    @Homoran sagte:
                                    Sehe ich anders.
                                    Dann dürfte aber beim Adapter die vorgänger Version auch nicht gehen.
                                    Bei mir:
                                    1.19.7 funktioniert mit sentry
                                    1.20.0 funktioniert nicht mit sentry
                                    m.E. bug im Adapter.
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      @Homoran sagte:
                                      Sehe ich anders.
                                      Bei mir:
                                      @bahnuhr ich hab mittlerweile diverse Adapter bei denen ich sentry abschalten musste.
                                      Alles stable
                                      • Michael SchmittM Online
                                        Michael Schmitt
                                        schrieb am zuletzt editiert von Michael Schmitt
                                        Nur mal nach gefragt= Warum kommt bei mir dann diese Meldung nicht ? Obwohl ich js-controller: 7.0.7 nutze
                                        ical.0
                                        	2026-04-25 17:43:11.747	info	Terminated (NO_ERROR): Without reason
                                        ical.0
                                        	2026-04-25 17:43:06.365	info	processing URL: Müllkalender https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxx8c%40group.calendar.google.com/private-32cc3a968fdxxxxxxxx6ce4d4/basic.ics
                                        ical.0
                                        	2026-04-25 17:43:05.546	info	starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7
                                        Edit ; sentry ist an
                                        • MartinPM Online
                                          MartinPM Online
                                          MartinP
                                          Ich denke, es ist irgendetwas in der Formatierung der Telemetrie-Nachrichten, die Sentry schicken will.
                                          Bei mir zickt Sentry nur bei einer von zwei ical Instanzen
